USBH internal peripheral
Applicable for STM32MP13x lines, STM32MP15x lines, Unknown MPU, Unknown MPU, STM32MP25x lines
  • briefly introduce the USBH peripheral and its main features,
The USBH peripheral is used to interconnect other systems with STM32 MPU devices, using USB standard.
The USBH peripheral is a USB Host controller supporting high-speed (480 Mbit/s) using an EHCI controller, and full- and low- speeds (12 and 1.5 Mbit/s) through OHCI controller.
The USBH peripheral supports the following PHY interfaces:
SoC Number of physical ports (UTMI+) USBH peripheral PHY interfaces
STM32MP1 series 2 USBPHYC internal peripheral
STM32MP2 series 1 USB2PHY internal peripheral
The supported standards are:
  • Universal Serial Bus Revision 2.0 Specification[1], Revision 2.0, April 27, 2000
  • USB 2.0 Link Power Management Addendum Engineering Change Notice to the USB 2.0 specification[2], July 16, 2007
  • Enhanced Host Controller Interface Specification for Universal Serial Bus[3], Revision 1.0, March 12, 2002
  • EHCI v1.1 Addendum[4], August 2008
  • Open Host Controller Interface Specification for USB[5], Release 1.0a, September 14, 1999
  • USB 2.0 Transceiver Macrocell Interface (UTMI) Specification[6], Version 1.05, March 29, 2001
  • UTMI+ Specification[7], Revision 1.0, February 25, 2004
The USBH peripheral is usually not used at boot time. But it may be used by the SSBL (see Boot chain overview), for example to boot a kernel stored on a USB key (mass storage).
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
High speed interface USBH (USB Host) USBH (USB Host)
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
non-secure
(U-Boot)
High speed interface USBH USBH
non-secure
non-secure
Cortex-M4
3.2.3. On STM32MP21 unknown microprocessor device[edit | edit source]
| rowspan="1" | High speed interface | rowspan="1" | USBH | USBH | OP-TEE | | | | |-
3.2.4. On STM32MP23 unknown microprocessor device[edit | edit source]
3.2.5. On STM32MP25x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
non-secure
Cortex-M33
(TF-M)
Cortex-M33
non-secure
Cortex-M0+
High speed interface USBH USBH OP-TEE
Below are listed the software frameworks and drivers managing the USBH peripheral for the embedded software components listed in the above tables.
For Linux kernel and U-boot configuration, please refer to USBH device tree configuration.
