media-ctl is a V4L2 utility[1] used to set up and configure the camera subsystem subdevices. It is based on the media controller Linux kernel interface[2].
2. Usage[edit | edit source]
media-ctl --help
media-ctl [options]
-d, --device dev Media device name (default: /dev/media0)
If <dev> starts with a digit, then /dev/media<dev> is used.
If <dev> doesn't exist, then find a media device that
reports a bus info string equal to <dev>.
-e, --entity name Print the device name associated with the given entity
-V, --set-v4l2 v4l2 Comma-separated list of formats to setup
--get-v4l2 pad Print the active format on a given pad
--get-dv pad Print detected and current DV timings on a given pad
--set-dv pad Configure DV timings on a given pad
-R, --set-routes routes Configure routes on a given subdev entity
-h, --help Show verbose help and exit
-i, --interactive Modify links interactively
-l, --links links Comma-separated list of link descriptors to setup
--known-mbus-fmts List known media bus formats and their numeric values
-p, --print-topology Print the device topology. If an entity
is specified through the -e option, print
information for that entity only.
--print-dot Print the device topology as a dot graph
-r, --reset Reset all links to inactive
-v, --verbose Be verbose
--version Show version information
Links and formats are defined as
links = link { ',' link } ;
link = pad '->' pad '[' flags ']' ;
pad = entity ':' pad-number { '/' stream-number } ;
entity = entity-number | ( '"' entity-name '"' ) ;
v4l2 = pad '[' v4l2-properties ']' ;
v4l2-properties = v4l2-property { ',' v4l2-property } ;
v4l2-property = v4l2-mbusfmt | v4l2-crop | v4l2-interval
| v4l2-compose | v4l2-interval ;
v4l2-mbusfmt = 'fmt:' fcc '/' size ; { 'field:' v4l2-field ; } { 'colorspace:' v4l2-colorspace ; }
{ 'xfer:' v4l2-xfer-func ; } { 'ycbcr:' v4l2-ycbcr-enc ; }
{ 'quantization:' v4l2-quant ; }
v4l2-crop = 'crop:' rectangle ;
v4l2-compose = 'compose:' rectangle ;
v4l2-interval = '@' numerator '/' denominator ;
rectangle = '(' left ',' top, ')' '/' size ;
size = width 'x' height ;
routes = entity '[' route { ',' route } ']' ;
route = pad-number '/' stream-number '->' pad-number '/' stream-number '[' route-flags ']' ;
where the fields are
entity-number Entity numeric identifier
entity-name Entity name (string)
pad-number Pad numeric identifier
stream-number Stream numeric identifier
flags Link flags (0: inactive, 1: active)
route-flags Route flags (bitmask of route flags: active - 0x1)
fcc Format FourCC
width Image width in pixels
height Image height in pixels
numerator Frame interval numerator
denominator Frame interval denominator
v4l2-field One of the following:
any
none
top
bottom
interlaced
seq-tb
seq-bt
alternate
interlaced-tb
interlaced-bt
v4l2-colorspace One of the following:
default
smpte170m
smpte240m
rec709
unknown
470m
470bg
jpeg
srgb
oprgb
bt2020
raw
dcip3
v4l2-xfer-func One of the following:
default
709
srgb
oprgb
smpte240m
none
dcip3
smpte2084
v4l2-quant One of the following:
default
full-range
lim-range
v4l2-ycbcr-enc One of the following:
default
601
709
xv601
xv709
unknown
bt2020
bt2020c
smpte240m
3. Examples[edit | edit source]
Refer to V4L2 camera subsystem setup for examples of usage.
