- briefly introduce the DCMI peripheral and its main features,
The DCMI (digital camera memory interface) peripheral is used to receive some video data from an external parallel camera sensor device or any other digital video equipment supporting parallel interface.
The DCMI hardware block can receive raw data frames in RGB565 and YUV422 formats as well as JPEG compressed data.
Refer to STM32 DCMI presentation [1] for an overview of DCMI hardware block and its capabilities.
3.1.1. On STM32MP15x lines [edit | edit source]
The DCMI peripheral is not used at boot time.
3.1.2. On STM32MP2 series[edit | edit source]
Check boxes illustrate the possible peripheral allocations supported by OpenSTLinux BSP:
- ⬚ means that the peripheral can be assigned to the given boot time context, but this configuration is not supported in OpenSTLinux BSP.
- ☑ means that the peripheral is assigned by default to the given boot time context and that the peripheral is mandatory for the OpenSTLinux BSP.
Cortex-A35 nonsecure (U-Boot) | |||
Visual | DCMI | DCMI | ⬚ |
3.2.1. On STM32MP15x lines [edit | edit source]
Cortex-M4 (STM32Cube) | |||
Visual | DCMI | DCMI | ☑ | ☐ | Assignment (single choice) |
3.2.2. On STM32MP21x lines [edit | edit source]
- ⬚ means that the peripheral can be assigned to the given runtime context, but this configuration is not supported in OpenSTLinux BSP.
- ☑ means that the peripheral is assigned by default to the given runtime context and that the peripheral is mandatory for the OpenSTLinux BSP.
Domain | Peripheral | Runtime allocation | Comment | ||||
Cortex-A35 nonsecure (Linux) |
Cortex-M33 secure (TF-M) |
Cortex-M33 nonsecure (STM32Cube) | |||
Visual | DCMI | DCMI | ⬚OP-TEE | ☑ | ⬚ | ☐ |
3.2.3. On STM32MP23x lines [edit | edit source]
3.2.4. On STM32MP25x lines [edit | edit source]
Cortex-M0+ (STM32Cube) | |||
Below are listed the software frameworks and drivers managing the DCMI peripheral for the embedded software components listed in the above tables.
- Linux®: V4L2 framework
- STM32Cube:
- for STM32MP15x lines : DCMI HAL driver and header file of DCMI HAL module
- for STM32MP2 series: DCMI HAL driver and header file of DCMI HAL module
See also additional information in the DCMI device tree configuration article for Linux®.
Refer to STM32 DCMI Application Note (AN5020)[2] for a detailed description of the DCMI peripheral and applicable use-cases.
This application note is related to STM32 microcontrollers but it is also applicable to STM32 MPUs. This document can help to better understand stm32-dcmi V4L2 kernel driver and debug camera sensor and DCMI interactions.
