GPU device tree configuration
Applicable for STM32MP15x lines, STM32MP23x lines, STM32MP25x lines
The purpose of this article is to explain how to configure the GPU internal peripheral using the device tree mechanism, relying on the bindings documentation, that is the description of the required and optional device-tree properties.
3.1. DT configuration (STM32/SoC level)[edit | edit source]
The GPU node is located in the device tree file for the software components, supporting the peripheral and listed in the above DT bindings documentation paragraph.
The declaration (shown below) defines the hardware registers base address, the interrupt, the clocks and the reset.
	soc {
		gpu: gpu@59000000 {
			compatible = "vivante,gc";
			reg = <0x59000000 0x800>;
			interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&rcc GPU>, <&rcc GPU_K>;
			clock-names = "bus" ,"core";
			resets = <&rcc GPU_R>;
	thermal-zones {
		cpu-thermal {
			trips {
				gpu_alert: gpu-alert {
					temperature = <110000>;
					hysteresis = <10000>;
					type = "passive";
			cooling-maps {
				map1 {
					trip = <&gpu_alert>;
					cooling-device = <&gpu 1 6>;
&rifsc {
	gpu: gpu@48280000 {
		reg = <0x48280000 0x800>;
		interrupts = <GIC_SPI 183 IRQ_TYPE_LEVEL_HIGH>;
		clock-names = "bus", "core";
		clocks = <&rcc CK_BUS_GPU>, <&rcc CK_KER_GPU>;
		power-domains = <&scmi_devpd PD_SCMI_GPU>, <&CLUSTER_PD>;
		access-controllers = <&rifsc 79>;
		status = "disabled";
		throttle,max_state = <6>;
		#cooling-cells = <2>;
	thermal-zones {
		cpu-thermal {
			trips {
					type = "passive";
			cooling-maps {
				map1 {
&rifsc {
	gpu: gpu@48280000 {
The objective of this chapter is to explain how to enable and configure the GPU DT nodes for a board.
Peripheral configuration should be done in specific board device tree files (board dts file).
Under construction.png Add information on gpu_reserved memory configuration and a link to its related "how to" article.
3.2.1. On STM32MP15x lines More info.png[edit | edit source]
A full example of the STM32MP157 Evaluation board device tree is available in stm32mp157c-ed1.dts , included in stm32mp157c-ev1.dts :
	reserved-memory {
		#address-cells = <1>;
		#size-cells = <1>;
		ranges;
		gpu_reserved: gpu@e8000000 {
			reg = <0xe8000000 0x8000000>;
			no-map;
&gpu {
	contiguous-area = <&gpu_reserved>;
3.2.2. On STM32MP23x lines More info.png and STM32MP25x lines More info.png[edit | edit source]
A full example of the STM32MP257 Evaluation board device tree is available in stm32mp257f-ev1.dts :
&gpu {
	status = "okay";
The related "<&gpu_reserved>" node is located in stm32mp257f-ev1-ca35tdcid-resmem.dtsi :
	reserved-memory {
		#address-cells = <2>;
		#size-cells = <2>;
		ranges;
		gpu_reserved: gpu-reserved@fa800000 {
			reg = <0x0 0xfa800000 0x0 0x4000000>;
			no-map;
