- briefly introduce the I3C peripheral and its main features,
The I3C peripheral is used to handle communication between this device and others, such as sensors and host processors connected on an I3C bus.
An I3C bus is a two-wire, serial single-ended, multidrop bus, intended to improve a legacy I2C bus.
This I3C peripheral is SDR-only (single data rate) and implements all the features required by the MIPI® I3C specification v1.1.
It can control all I3C bus-specific sequencing, protocol, arbitration, and timing, and can act as controller (formerly known as master), or as target (formerly known as slave).
When acting as controller, the I3C peripheral improves the features on the I2C interface preserving some backward compatibility: it allows an I2C target to operate on an I3C bus in legacy I2C fast mode (Fm) or legacy I2C fast mode plus (Fm+), provided that the latter does not perform clock stretching.
For more information about I3C, refer to this link: MIPI® I3C Wikipedia page [1] or MIPI® I3C[2].
Here are the main features:
- MIPI® I3C specification v1.1, as:
- I3C SDR-only primary controller
- I3C SDR-only secondary controller
- I3C SDR-only target
- I3C SCL bus clock frequency up to 12.5 MHz
- Legacy I2C read/write messages to legacy I2C targets in Fm/Fm+
- I3C SDR read/write private messages
- I3C SDR broadcast CCC messages
- I3C SDR read/write direct CCC messages
This chapter is applicable in the scope of the OpenSTLinux BSP running on the Arm® Cortex®-A processor, and the STM32CubeMPU Package running on the Arm® Cortex®-M processor.
3.1.1. On STM32MP21 unknown microprocessor device[edit | edit source]
3.1.1.1. Cortex-A35 master boot[edit | edit source]
Low speed interface | I3C | I3C1 | ⬚ | ☐ | ||
I3C2 | ⬚ | ☐ | ||||
I3C3 | ⬚ | ☐ |
3.1.2. On STM32MP23 unknown microprocessor device[edit | edit source]
3.1.2.1. Cortex-A35 master boot[edit | edit source]
I3C2 | ⬚ | ☐ | ||||
I3C4 | ⬚ | ☐ |
3.1.3. On STM32MP25x lines [edit | edit source]
3.1.3.1. Cortex-A35 master boot[edit | edit source]
I3C2 | ⬚ | ☐ | ||||
I3C3 | ⬚ | ☐ | ||||
I3C4 | ⬚ | ☐ |
3.2.1. On STM32MP21 unknown microprocessor device[edit | edit source]
| rowspan="3" | Low speed interface
| rowspan="3" | I3C
| I3C1
| ⬚OP-TEE
⬚TF-A BL31
| I3C2
| ⬚OP-TEE
⬚TF-A BL31
| I3C3
| ⬚OP-TEE
⬚TF-A BL31
3.2.2. On STM32MP23 unknown microprocessor device[edit | edit source]
| rowspan="3" | I3C
| I3C1
| ⬚OP-TEE
⬚TF-A BL31
| I3C2
| ⬚OP-TEE
⬚TF-A BL31
| I3C4
| ⬚OP-TEE
⬚TF-A BL31
3.2.3. On STM32MP25x lines [edit | edit source]
Cortex-M33 secure (TF-M) |
Cortex-M0+ (STM32Cube) | |||
Low speed interface | I3C | I3C1 | ⬚OP-TEE ⬚TF-A BL31 |
I3C2 | ⬚OP-TEE ⬚TF-A BL31 |
I3C3 | ⬚OP-TEE ⬚TF-A BL31 |
I3C4 | ⬚OP-TEE ⬚TF-A BL31 |
Below are listed the software frameworks and drivers managing the I3C peripheral for the embedded software components listed in the above tables.
- Linux®: I3C SDR-only primary controller as defined in MIPI® I3C specification v1.1 in I3C driver using I3C framework
- STM32Cube: I3C HAL driver and header file of I3C HAL module
- partial device trees (pin control and clock tree) for the OpenSTLinux software components,
