- briefly introduce the VDEC peripheral and its main features,
The VDEC (Video DECoder) peripheral is an hardware accelerator for video compressed content decoding such as H264 or VP8 bitstream.
This chapter is applicable in the scope of the OpenSTLinux BSP running on the Arm® Cortex®-A processor(s).
3.1.1. On STM32MP2 series[edit source]
Visual | VDEC | VDEC | ⬚ |
3.2.1. On STM32MP25x lines [edit source]
Cortex-M33 secure (TF-M) |
Cortex-M0+ (STM32Cube) | |||
Visual | VDEC | VDEC | ⬚OP-TEE | ☑ | ⬚ | ⬚ |
Below are listed the software frameworks and drivers managing the VDEC peripheral for the embedded software components listed in the above tables.
- Linux®: V4L2 framework
- partial device trees (pin control and clock tree) for the OpenSTLinux software components,
See also additional information in the VDEC device tree configuration article for Linux®.
