Audio codecs hardware components
  • list the audio codec hardware components that might be integrated in the different STM32MPU boards
  • link these components to the corresponding software framework(s)
  • point to the datasheet(s) of these components
  • explain, when necessary, how to configure these components.
2. Software frameworks[edit source]
OP-TEE Linux STM32Cube
Audio Wolfson wm8994 ALSA framework DAC & ADC audio codec
Audio Cirrus cs42l51 ALSA framework DAC & ADC audio codec
Audio Silab sil9022 ALSA framework HDMI transmitter
Audio Analog device ADV7535 ALSA framework HDMI transmitter
Audio ST MP34DT01-M ALSA framework Digital microphone
3. Wolfson wm8994[edit source]
The WM8994 is a highly integrated ultra-low power hi-fi CODEC rich in multimedia features.
For details and the datasheet please contact the WM8994 codec provider.
3.1. Linux driver[edit source]
Bindings: Documentation/devicetree/bindings/sound/wm8994.txt
Sources:
4. Cirrus cs42l51[edit source]
The CS42L51 is a highly integrated, 24-bit, low-power stereo CODEC.
For details and the datasheet please contact the CS42L51 codec provider.
4.1. Linux driver[edit source]
Bindings: Documentation/devicetree/bindings/sound/cirrus,cs42l51.yaml
Sources: sound/soc/codecs/cs42l51.c
5. Silab sil9022[edit source]
The SiI9022A HDMI transmitter supports the HDMI® Specification on a wide range of mobile products.
For details and the datasheet please contact the SiI9022A HDMI transmitter provider.
5.1. Linux driver[edit source]
Bindings: Documentation/devicetree/bindings/display/bridge/sil,sii9022.yaml
Sources: drivers/gpu/drm/bridge/sii902x.c
6. Analog Device ADV7535[edit source]
The ADV7535 provides a High-Definition Multimedia Interface (HDMI®) transmitter output.
For details and the datasheet please contact the ADV7535 HDMI transmitter provider.
6.1. Linux driver[edit source]
Bindings: Documentation/devicetree/bindings/display/bridge/adi,adv7533.yaml
Sources: drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
7. ST MP34DT01-M[edit source]
The MP34DT01-M is an ultra-compact, low-power, omnidirectional, digital MEMS microphone.
Datasheet: https://www.st.com/resource/en/datasheet/mp34dt01-m.pdf
7.1. Linux driver[edit source]
Bindings: Documentation/devicetree/bindings/sound/dmic.txt
Sources: sound/soc/codecs/dmic.c
