- There are two main ways to debug OP-TEE core: using embedded traces, or using JTAG/SWD to access the secure world.
- The OP-TEE trusted applications and libraries provide debug support relying on embedded traces only.
2. Debugging OP-TEE core[edit | edit source]
2.1. OP-TEE Version number[edit | edit source]
I/TC: OP-TEE version:<tag> #<buildcount> <date> <arch>
that is:
I/TC: OP-TEE version: openstlinux-19-01-11-10-g56ef3b0 #1 Wed Jan 30 09:12:56 UTC 2019 arm
2.2. Embedded assertions[edit | edit source]
static int increment_argument(int argument) { assert(argument > 0); return argument - 1; }
2.3. Debug with traces[edit | edit source]
Value | Name | Description with related macros |
0 | - | All trace messages are disabled |
1 | Error trace level | Only non-tagged and error trace messages are embedded: MSG(), MSG_RAW(), EMSG(), EMSG_RAW() |
2 | Info trace level | + info trace messages: IMSG(), IMSG_RAW() |
3 | Debug trace level | + debug trace messages: DMSG(), DMSG_RAW() |
4 | Flow trace level | + flow trace messages: FMSG(), FMSG_RAW() |
chosen { stdout-path = "serial0:115200n8"; };
2.4. Stack unwind support[edit | edit source]
2.5. Debug with GDB[edit | edit source]
2.5.1. Debug boot sequence[edit | edit source]
Linker script and memory map
0x000000002ffc0000 . = 0x2ffc0000
0x0000000000000001 ASSERT (0x1, text start should align to 32bytes)
0x000000002ffc0000 __text_start = .
0x000000002ffc0000 __flatmap_unpg_rx_start = ((__text_start / 0x1000) * 0x1000)
.text 0x000000002ffc0000 0xc538
*(SORT_BY_ALIGNMENT(.text._start))
.text._start 0x000000002ffc0000 0x98 out/stm32mp157c-ev1/core/arch/arm/kernel/entry_a32.o
0x000000002ffc0000 _start -> OP-TEE Load address
(gdb) hb _start
2.5.2. Debugging during runtime execution[edit | edit source]
(gdb) hb stm32_sip_service (gdb) continue
3. Debugging OP-TEE trusted applications[edit | edit source]
3.1. Embedded assertions[edit | edit source]
3.2. Debug with traces[edit | edit source]
3.3. Stack unwind support[edit | edit source]
[[Category:OP-TEE]
