This page is a candidate for deletion. The supplied reason is: Qt browsing will be described in a dedicated section within X-LINUX-QT package documentation . -- Registered User (-) 08:54, 20 June 2024 (CEST). Wiki maintainers: remember to check if anything links this page before deleting it. |
A simple web browser, based on Qt5, can be easily installed using the package repository for OpenSTLinux distribution service.
2 solutions exist:
- Qt® application
- Qt® Python™ application
1. qt-wpe-simple-browser[edit source]
1.1. Installation[edit source]
apt-get update apt-get install qt-wpe-simple-browser
1.2. Usage[edit source]
qt-wpe-simple-browser <url http://>
2. python3-pyqt5[edit source]
2.1. Installation[edit source]
apt-get update apt-get install python3-pyqt5
Create the web_browser.py script:
# web_browser.py
# Copyright (c) STMicroelectronics
# License: BSD-3-Clause
from PyQt5.QtCore import *
from PyQt5.QtWidgets import *
from PyQt5.QtGui import *
from PyQt5.QtWebKitWidgets import *
import sys
class MainWindow(QMainWindow):
def __init__(self, *args, **kwargs):
super(MainWindow,self).__init__(*args, **kwargs)
self.setWindowTitle(sys.argv[1])
self.browser = QWebView()
self.browser.setUrl( QUrl(sys.argv[1]) )
self.setCentralWidget(self.browser)
self.show()
QApplication.setAttribute(Qt.AA_ShareOpenGLContexts)
app = QApplication(sys.argv)
window = MainWindow()
app.exec_()
2.2. Usage[edit source]
python3 web_browser.py <url http://>
3. Display platform[edit source]
Two solutions exist to display the web browser:
- using eglfs
- using Wayland
3.1. wayland[edit source]
- Weston must be started. If you have stopped it, you can restart Weston with the following command
systemctl start weston@root
- Install qtwayland
apt-get install qtwayland
- Set Wayland egl as display platform
export QT_QPA_PLATFORM=wayland-egl
- And set the following variable
export QML2_IMPORT_PATH='/usr/lib/qt5/qml/'
- Launch the Python web browser
python3 web_browser.py <url http://> --qwindowgeometry <width>x<height>
3.2. eglfs[edit source]
- Stop the Weston application
systemctl stop weston@root
- Set eglfs as display platform
export QT_QPA_PLATFORM=eglfs
- And set the following variables
export QML2_IMPORT_PATH='/usr/lib/qt5/qml/' export QT_QPA_EGLFS_ALWAYS_SET_MODE='1'
- Launch the web browser
With HDMI connection, it is advised to use the following kms eglfs_config.json config file in order to avoid cursor rendering issue.
{ "device": "/dev/dri/card0", "hwcursor": false, "pbuffers": true, "outputs": [ { "name": "HDMI1", "mode": "1280x720" } ] } Set Qt variable to use the json config file: Board $> export QT_QPA_EGLFS_KMS_CONFIG='/home/root/eglfs_config.json'
