Sysprof
Revision as of 13:26, 25 June 2024 by Registered User
This article provides the basic information needed to start using the Linux kernel tool: sysprof[1].
2. Introduction[edit source]
No Developer Package is presently delivered.
The tool (even if marked as present) has not been yet tested with the current release.
sysprof Monitoring tools sysprof[1] is a statistical, system-wide profiler for Linux. It helps in finding the functions in which a program spends most of its time.
sysprof proposes a user interface available directly on the board display screen.
Yes Yes Yes No No No
3.1. Using STM32MPU Embedded Software distribution[edit source]
sysprof is installed by default and ready to be used with all STM32MPU Embedded Software Packages.
which sysprof
/usr/bin/sysprof
Sysprof is integrated in weston image distribution through packagegroup-framework-tools-kernel package defined in meta-st-openstlinux/recipes-st/packagegroups/packagegroup-framework-tools.bb.
SUMMARY:packagegroup-framework-tools-kernel = "Framework tools components for kernel"
RDEPENDS:packagegroup-framework-tools-kernel = "\
    cpufrequtils    \
    sysfsutils      \
    dosfstools      \
    mmc-utils       \
    blktool         \
    mtd-utils-ubifs \
    sysprof         \
sysprof is working only with screen resolution at least 700x1200, so it doesn't work on STM32MP135x-DK Discovery kit More info green.png and STM32MP157x-DKx Discovery kit More info green.png
  • Starting sysprof on the board: Need to specify the display to be used, for example:
sysprof --display=/run/user/1000/$WAYLAND_DISPLAY
Sysprof proposes a User interface through the board X interface to the display. It might be more convenient to plug a mouse (and optionally a keyboard) to use the tool interface.
  • Recording
Clicking on the top left Record button launches the recording. Recording is stopped by clicking on the top left Stop button (that replaces the record button).
The following report is then available on the board display:
5. To go further[edit source]
Several options are available to the user in order to filter the report, and then study the results:
  • Possibility to browse on Functions list, Descendants list
  • Possibility to select a certain period of the CPUs graph.
  • Possibility to save traces, to make screen shots...
  • Useful external links
Sysprof from Gnome Standard Wiki page
Profiling using Sysprof User manual Linux.com
