LVDS internal peripheral
  • introduce briefly the LVDS peripheral and its main features,
The LVDS display interface transmitter (LVDS) handles the LVDS protocol. It maps the pixels received from the upstream Pixel-DMA (LTDC[1]) onto the LVDS PHY.
It regroups three subblocks.
  • LVDS host: it handles the LVDS protocol (FPD-Link/OpenLDI) by mapping its input pixels onto the data lanes of the PHY.
  • LVDS PHY: it parallelizes the data and drives the LVDS data lanes.
  • LVDS wrapper: it handles the top-level settings.
The LVDS host supports the following high-level features:
  • FPD-Link I and OpenLDI (v0.95) protocols
  • Single link or dual link operation
  • Single display or double display (with the same content duplicated on both)
  • Flexible bit-mapping, including JEIDA and VESA
  • RGB888 or RGB666 output
  • Synchronous design, with one input pixel per clock cycle
  • No resolution limitation.
The LVDS PHY supports the following high-level features:
  • FPD-Link bitrate: 784 Mbps/lane (112 Mpixel/s/link, 224 Mpixel/s if dual link)
  • OpenLDI bitrate: 1100 Mbps/lane (157 Mpixel/s/link, 314 Mpixel/s if dual link)
This chapter is applicable in the scope of the OpenSTLinux BSP running on the Arm® Cortex®-A processor, and the STM32CubeMPU package running on the Arm® Cortex®-M processor.
The LVDS can be used at boot time for displaying a splash screen thanks to the U-Boot framework [2].
3.1.1. On STM32MP25x lines More info.png[edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
non-secure
(U-Boot)
Visual LVDS LVDS
3.2.1. On STM32MP25x lines More info.png[edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
non-secure
Cortex-M33
(TF-M)
Cortex-M33
non-secure
Cortex-M0+
Visual LVDS LVDS OP-TEE
Below are listed the software frameworks and drivers managing the LVDS peripheral for the embedded software components listed in the above tables.
  • Partial device trees (pin control and clock tree) for the OpenSTLinux software components,
  • HAL initialization code for the STM32CubeMPU package.
See also additional information in the LVDS device tree configuration article for Linux®.
Refer to the STM32 MPU reference manuals for a detailed description of the LVDS peripheral and applicable use cases.
