CEC internal peripheral
  • briefly introduce the CEC peripheral and its main features,
The CEC (consumer electronics control) or HDMI-CEC peripheral is used to receive/send messages from/to devices, such as TV or tuner, through a HDMI cable.
Refer to the STM32 CEC presentation [1] for an overview of the CEC hardware block capabilities.
The CEC peripheral is not used at boot time.
3.2.1. On STM32MP15x lines More info.png[edit | edit source]
non-secure
Cortex-M4
Visual CEC CEC Assignment (single choice)
Below are listed the software frameworks and drivers managing the CEC peripheral for the embedded software components listed in the above tables.
See also additional information in the CEC device tree configuration article for Linux®.
Refer to the STM32 CEC application note (AN4066) [2] for a detailed description of the CEC peripheral and applicable use-cases.
