- briefly introduce the DCMIPP peripheral and its main features,
The DCMIPP (digital camera memory interface pixel processor) peripheral is used to receive video data from an external parallel camera sensor device, or from any other digital video equipment supporting a parallel interface.
The DCMIPP hardware block can receive various frame data formats such as: RAW8, RGB565, YUV422 and other formats, as well as compressed data such as JPEG.
Moreover, on STM32MP25x lines :
- the DCMIPP is also connected to the CSI internal peripheral that provides an interface to communicate with MIPI® CSI-compliant camera sensors: the DCMIPP is able to get pixels from the parallel or MIPI® CSI interface.
- the DCMIPP embeds 3 dedicated pixel pipelines named "dump", "main" and "ancillary": camera sensor data go into these pixel pipelines before they are sent to memory for further processing or display purposes.
3.1.1. On STM32MP1 series[edit | edit source]
The DCMIPP peripheral is not used at boot time.
3.1.2. On STM32MP2 series[edit | edit source]
STM32MP2 internal peripherals assignment table template
| rowspan="1" | Visual | rowspan="1" | DCMIPP | DCMIPP | | | ⬚ | |-
3.2.1. On STM32MP13x lines [edit | edit source]
Visual | DCMIPP | DCMIPP | ☑ |
3.2.2. On STM32MP25x lines [edit | edit source]
| rowspan="1" | Visual | rowspan="1" | DCMIPP | DCMIPP | ⬚OP-TEE | ☑ | ⬚ | ☐ | | |-
Below are listed the software frameworks and drivers managing the DCMIPP peripheral for the embedded software components listed in the above tables.
- Linux®: V4L2 framework
- STM32Cube:
- for STM32MP13x lines : DCMIPP HAL driver and Unsupported domain!
- for STM32MP25x lines : DCMIPP HAL driver and Unsupported domain!
STM32Cube DCMIPP HAL related information are still under construction. |
See also additional information in the DCMIPP device tree configuration article for Linux®.
