This article explains how to configure the DSI [1] when the peripheral is assigned to the Linux® OS.
The configuration is performed using the device tree mechanism [2].
The Device tree provides a hardware description of the DSI [1] used by the STM32 DSI Linux driver.
The DSI is represented by the STM32 DSI device tree bindings [3].
3.1. DT configuration (STM32/SoC level)[edit | edit source]
The DSI node is located in the device tree file for the software components, supporting the peripheral and listed in the above DT bindings documentation paragraph.
For STM32MP15x lines , the DSI device tree node is declared in stm32mp157.dtsi [4].
dsi: dsi@5a000000 { compatible = "st,stm32-dsi"; reg = <0x5a000000 0x800>; phy-dsi-supply = <®18>; clocks = <&rcc DSI>, <&clk_hse>, <&rcc DSI_PX>; clock-names = "pclk", "ref", "px_clk"; resets = <&rcc DSI_R>; reset-names = "apb"; status = "disabled"; };
For STM32MP25x lines , the DSI device tree node is declared in stm32mp251.dtsi [5].
dsi: dsi@48000000 { compatible = "st,stm32-dsi"; reg = <0x48000000 0x800>; #clock-cells = <0>; clocks = <&rcc CK_BUS_DSI>, <&rcc CK_KER_DSIPHY>, <&rcc CK_KER_LTDC>; clock-names = "pclk", "ref", "px_clk"; resets = <&rcc DSI_R>; reset-names = "apb"; feature-domains = <&rifsc STM32MP25_RIFSC_DSI_CMN_ID>; power-domains = <&CLUSTER_PD>; status = "disabled"; };
The DSI device tree related to a particular board may have the following nodes, depending on the board hardware:
- dsi node: containing the in/out port descriptions and a panel sub-node.
- ltdc node: containing the in/out port description related to the dsi node.
- panel_backlight node: related to the panel node.
For STM32MP15x lines , a full example of the STM32MP157 Evaluation board device tree is available in stm32mp157c-ev1.dts [6].
/ { model = "STMicroelectronics STM32MP157C eval daughter on eval mother"; compatible = "st,stm32mp157c-ev1", "st,stm32mp157c-ed1", "st,stm32mp157"; ... panel_backlight: panel-backlight { compatible = "gpio-backlight"; gpios = <&gpiod 13 GPIO_ACTIVE_LOW>; default-on; status = "okay"; }; ... }; ... &dsi { #address-cells = <1>; #size-cells = <0>; status = "okay"; ports { #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; dsi_in: endpoint { remote-endpoint = <<dc_ep0_out>; }; }; port@1 { reg = <1>; dsi_out: endpoint { remote-endpoint = <&dsi_panel_in>; }; }; }; panel_dsi: panel-dsi@0 { compatible = "raydium,rm68200"; reg = <0>; reset-gpios = <&gpiof 15 GPIO_ACTIVE_LOW>; backlight = <&panel_backlight>; power-supply = <&v3v3>; status = "okay"; port { dsi_panel_in: endpoint { remote-endpoint = <&dsi_out>; }; }; }; }; ... <dc { status = "okay"; port { ltdc_ep0_out: endpoint { remote-endpoint = <&dsi_in>; }; }; };
For STM32MP25x lines , a full example of the STM32MP257 Evaluation board device tree is available in stm32mp257f-ev1.dts [7].
&dsi {
#size-cells = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
dsi_in: endpoint {
port@1 {
reg = <1>;
dsi_out1: endpoint {
remote-endpoint = <&adv7535_in>;
&i2c2 {
pinctrl-0 = <&i2c2_pins_a>;
pinctrl-1 = <&i2c2_sleep_pins_a>;
i2c-scl-rising-time-ns = <100>;
i2c-scl-falling-time-ns = <13>;
clock-frequency = <400000>;
status = "okay";
/* spare dmas for other usage */
/delete-property/dmas;
/delete-property/dma-names;
adv7535: hdmi@3d {
compatible = "adi,adv7535";
reg = <0x3d>, <0x3c>, <0x3f>, <0x38>;
reg-names = "main", "cec", "edid", "packet";
adi,dsi-lanes = <4>;
reset-gpios = <&gpiog 14 GPIO_ACTIVE_LOW>;
avdd-supply = <&scmi_v3v3>;
dvdd-supply = <&scmi_v3v3>;
pvdd-supply = <&scmi_v3v3>;
a2vdd-supply = <&scmi_v3v3>;
v3p3-supply = <&scmi_v3v3>;
v1p2-supply = <&scmi_v3v3>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
adv7535_in: endpoint {
remote-endpoint = <&dsi_out1>;
port@2 {
reg = <2>;
adv7535_tx_endpoint: endpoint {
remote-endpoint = <&i2s2_endpoint>;
<dc {
rotation-memory = <<dc_sec_rotation>;
status = "okay";
port {
#size-cells = <0>;
ltdc_ep0_out: endpoint@0 {
reg = <0>;
ltdc_ep1_out: endpoint@1 {
reg = <1>;
remote-endpoint = <&lvds_in>;
- ↑ 1.0 1.1 DSI internal peripheral
- ↑ Device tree
- ↑ st,stm32-dsi.yaml Linux kernel bindings (including dsi)
- ↑ Linux kernel STM32MP157 device tree (stm32mp157.dtsi)
- ↑ Linux kernel STM32MP251 device tree (stm32mp251.dtsi)
- ↑ Linux kernel STM32MP157 Evaluation board device tree (stm32mp157c-ev1.dts)
- ↑ Linux kernel STM32MP257 Evaluation board device tree (stm32mp257f-ev1.dts)
