RNG device tree configuration
The purpose of this article is to explain how to configure the RNG using the device tree mechanism, relying on the bindings documentation, that is the description of the required and optional device-tree properties.
The peripheral can be assigned to different contexts/software components, depending on the final product needs. Refer to How to assign an internal peripheral to a runtime context article for guidelines on this configuration .
3.1. DT configuration (STM32/SoC level)[edit | edit source]
The RNG node is located in the device tree file for the software components, supporting the peripheral and listed in the above DT bindings documentation paragraph.
It is only included on SoC supporting secure boot.
The objective of this chapter is to explain how to enable and configure the RNG DT nodes for a board.
Peripheral configuration should be done in specific board device tree files (board dts file).
RNG runs on two different clocks:
  • AHB bus clock to access registers
  • a dedicated RNG clock connected to internal random blocks.
Depending the clock source selected for the RNG clocks, the RNG dedicated clock must be higher than AHB clock / 32 if clock error detection is enabled.
   &rng {
        status = "okay";
        clock-error-detect;      // Enable the clock error management
