DMAMUX internal peripheral
  • briefly introduce the DMAMUX peripheral and its main features
  • explain, when necessary, how to configure the DMAMUX peripheral.
The DMAMUX peripheral is used to perform requestor line (or device controller) selection for each channel from DMA instances:
  • In STM32MP13x lines More info.png there is a first DMAMUX instance to cover both DMA1 and DMA2, and second DMAMUX instance to cover DMA3.
  • In STM32MP15x lines More info.png there is a single DMAMUX instance to cover both DMA1 and DMA2.
Refer to STM32MP13 reference manuals or STM32MP15 reference manuals for the complete feature list and to the software components, introduced below, to see which features are implemented.
2.2.1. On STM32MP13x lines More info.png[edit | edit source]
The DMAMUX1 is a non-secure peripheral. The DMAMUX2 is a secure peripheral.
2.2.2. On STM32MP15x lines More info.png[edit | edit source]
The DMAMUX is a non secure peripheral.
3. Peripheral usage and associated software[edit | edit source]
The DMAMUX is not used at boot time.
3.2.1.1. On STM32MP13x lines More info.png[edit | edit source]
The DMAMUX1 manages DMA1 and DMA2 requestor line selection, so it can be assigned to the Arm® Cortex®-A7 non-secure context to be controlled in Linux® by the dmaengine framework. The DMAMUX2 manages DMA3 requestor line selection, so it can be assigned to the Arm® Cortex®-A7 secure context to be controlled by a DMAMUX OP-TEE driver, not supported yet by OpenSTLinux.
3.2.1.2. On STM32MP15x lines More info.png[edit | edit source]
The DMAMUX manages DMA1 and DMA2 requestor line selection via different registers so it is possible to concurrently access to DMAMUX from Cortex®-A7 non-secure and Cortex®-M4 contexts, as far as each core is only configuring the requestor lines for the DMA instances (DMA1 and/or DMA2) assigned to itself.
Finally, DMAMUX can be allocated to:
  • the Arm® Cortex®-A7 non-secure core to be controlled in Linux® by the dmaengine framework
  • the Arm® Cortex®-M4 to be controlled in STM32Cube MPU Package by the DMA HAL driver
3.2.2.1. On STM32MP13x lines More info.png[edit | edit source]
OP-TEE Linux
Core/DMA DMAMUX OP-TEE DMAMUX driver Linux dmaengine framework
3.2.2.2. On STM32MP15x lines More info.png[edit | edit source]
OP-TEE Linux STM32Cube
Core/DMA DMAMUX Linux dmaengine framework STM32Cube DMAMUX driver
3.2.4.1. On STM32MP13x lines More info.png[edit | edit source]
non-secure
Core/DMA DMAMUX DMAMUX1 Assignment (single choice)
DMAMUX2 Assignment (single choice)
3.2.4.2. On STM32MP15x lines More info.png[edit | edit source]
non-secure
Cortex-M4
Core/DMA DMAMUX DMAMUX Shareable (multiple choices supported)
