RNG device tree configuration
This article explains how to configure the RNG internal peripheral when it is assigned to the Linux® OS. In that case, it is controlled by the Hardware random framework.
The configuration is performed using the device tree mechanism that provides a hardware description of the RNG peripheral, used by the STM32 RNG Linux driver.
The RNG is represented by the STM32 RNG device tree bindings[1]
The RNG node is declared in stm32mp157c.dtsi[2]. It describes the hardware register address, clock and reset.
 rng1: rng@54003000 {                                          Template:Highlight
 	compatible = "st,stm32-rng";
 	reg = <0x54003000 0x400>;                               Template:Highlight
 	clocks = <&rcc RNG1_K>;
 	resets = <&rcc RNG1_R>;
 	status = "disabled";
Template:Warning
This part is used to enable the RNG used on a board which is done by setting the status property to okay.
A clock-error-detect property is available depending the clock choosen for entropy. It can be enabled to manage the clock detection.
&rng1 {
	status = "okay";
	clock-error-detect;
