TZC internal peripheral
  • briefly introduce the TZC peripheral and its main features
  • explain how it can be allocated to the three runtime contexts and linked to the corresponding software components
  • explain, when necessary, how to configure the TZC peripheral.
The TZC peripheral is used to filter read/write accesses to the DDR controller according to TrustZone access rights, and according to Non-Secure master Address ID (NSAID) on up to 9 programmable regions.
The TZC is a secure peripheral.
3. Peripheral usage and associated software[edit | edit source]
The TZC is configured at boot time to setup DDR accesses.
The TZC is a system peripheral and is controlled by the Arm® Cortex®-A7 secure.
Cortex-A7 S
Cortex-A7 NS
Cortex-M4
Security TZC OP-TEE TZC driver
The configuration is applied by the firmware running in the secure context.
This configuration is done in TF-A or in OP-TEE.
Internal peripherals
means that the peripheral can be assigned () to the given runtime context.
is used for system peripherals that cannot be unchecked because they are statically connected in the device.
Instance Cortex-A7 S
Cortex-A7 NS
Cortex-M4
Security TZC TZC
4. How to go further[edit | edit source]
The TZC is an Arm® peripheral: TZC-400 TrustZone Address Space Controller[1]
