This article explains how to configure the VENC [1] when the peripheral is assigned to the Linux® OS.
The configuration is performed using the device tree mechanism [2].
The Device tree provides a hardware description of the VENC [1] used by the STM32 VENC Linux driver.
The VENC is represented by the STM32 VENC device tree bindings [3].
The VENC node is located in the device tree file for the software components, supporting the peripheral and listed in the above DT bindings documentation paragraph.
For STM32MP25x lines , the VENC device tree node is declared in stm32mp255.dtsi [4].
... soc@0 { rifsc: rifsc@42080000 { ... venc: venc@480e0000 { compatible = "st,stm32mp25-venc"; reg = <0x480e0000 0x800>; reset-names = "venc-rst"; resets = <&rcc VENC_R>; interrupt-names = "venc"; interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; clock-names = "venc-clk"; clocks = <&rcc CK_BUS_VENC>; feature-domains = <&rifsc STM32MP25_RIFSC_VENC_ID>; power-domains = <&CLUSTER_PD>; }; ...
For STM32MP25x lines , the STM32 VENC is already enabled by default in stm32mp255.dtsi [4] so there is no need to enable it at board level.
