- briefly introduce the GPU peripheral and its main features,
The GPU peripheral is a dedicated graphics processing unit. It accelerates numerous 3D graphics applications such as graphical user interface (GUI), menu display or animations. It works together with an optimized software stack designed for industry-standard APIs and supporting AndroidTM and Linux® embedded development platforms (read the STM32 MPU reference manual [1] for more details).
2.1. On STM32MP15x lines [edit source]
The GPU peripheral main API supports are:
- OpenGL® ES 1.1 and 2.0
- OpenVG® 1.1
- EGL™ 1.4
2.2. On STM32MP25x lines [edit source]
The GPU peripheral provides a powerful hardware acceleration means for all modern Graphic, but also Neural, and general parallel computing applications.
Main API are the same as on STM32MP15x lines , with the following extra ones:
- OpenGL® ES 3.2.8 (backward compatible: OpenGL® ES 2.1 & OpenGL® ES 1.1)
- Vulkan 1.2
- OpenVG® 1.3
- OpenCL® 3.0
- OpenVX® 1.3
3.1.1. On STM32MP1 series[edit source]
The GPU peripheral is not used at boot time.
3.1.2. On STM32MP2 series[edit source]
Visual | GPU | GPU | ⬚ |
3.2.1. On STM32MP15x lines [edit source]
Cortex-M4 (STM32Cube) | |||
Visual | GPU | GPU | ☐ |
3.2.2. On STM32MP25x lines [edit source]
Cortex-M33 secure (TF-M) |
Cortex-M0+ (STM32Cube) | |||
Visual | GPU | GPU | ⬚OP-TEE | ☑ | ⬚ | ⬚ |
Below are listed the software frameworks and drivers managing the GPU peripheral for the embedded software components listed in the above tables.
- Linux®: OpenGL® ES framework
Add a link to "GPU framework overview" article when available. |
See also additional information in the GPU device tree configuration article for Linux®.
Please go through the articles belonging to the GPU category.
- ↑ STM32 MPU reference manuals for more details
