VENC internal peripheral
  • briefly introduce the VENC peripheral and its main features,
The VENC (Video ENCoder) peripheral is an hardware accelerator for video compressed content encoding such as H264 or VP8 bitstream.
This chapter is applicable in the scope of the OpenSTLinux BSP running on the Arm® Cortex®-A processor(s).
3.1.1. On STM32MP2 series[edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
non-secure
(U-Boot)
Visual VENC VENC
3.2.1. On STM32MP25x lines More info.png[edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
non-secure
Cortex-M33
(TF-M)
Cortex-M33
non-secure
Cortex-M0+
Visual VENC VENC OP-TEE
Below are listed the software frameworks and drivers managing the VENC peripheral for the embedded software components listed in the above tables.
See also additional information in the VENC device tree configuration article for Linux®.
