- briefly introduce the DBGMCU peripheral and its main features,
The DBGMCU peripheral is used by the boot chain and by OP-TEE to get the device ID and revision, to adapt their behavior accordingly.
The DBGMCU peripheral is also used to configure internal peripherals behavior when one of the available cores enters in debug mode.
During a debug session, the DBGMCU can be accessed via the debug access port (DAP) to configure the expected behavior on break, typically to get a watchdog (IWDG) frozen when the Cortex®-A enters in debug mode (via a breakpoint or JTAG break) and to avoid getting a watchdog reset during a debug session.
On STM32MP25x lines only, each peripheral freeze bit inherit the permissions that are set on the same peripheral it controls.
3.1.1. On STM32MP13x lines [edit source]
Cortex-A7 secure (TF-A BL2) |
Trace & Debug | DBGMCU | DBGMCU | ⬚ | ⬚ | ⬚ |
3.1.2. On STM32MP15x lines [edit source]
3.1.3. On STM32MP25x lines [edit source]
3.2.1. On STM32MP13x lines [edit source]
3.2.2. On STM32MP15x lines [edit source]
Cortex-M4 (STM32Cube) | |||
3.2.3. On STM32MP25x lines [edit source]
Cortex-M33 secure (TF-M) |
Cortex-M0+ (STM32Cube) | |||
Trace & Debug | DBGMCU | DBGMCU | ⬚ | ⬚ | ⬚ | ⬚ | ⬚ |
There is no software dedicated to the DBGMCU internal peripheral delivered with STM32MPU ecosystem. Nevertheless, debuggers like STM32CubeIDE and OpenOCD use the DBGMCU.
