- briefly introduce the CRC peripheral and its main features,
The CRC peripheral is used to verify data transmission or storage integrity.
3.1.1. On STM32MP1 series[edit source]
Cortex-A7 secure (TF-A BL2) |
Security | CRC | CRC | ⬚ |
3.1.2. On STM32MP2 series[edit source]
Security | CRC | CRC | ⬚ | ⬚ |
3.2.1. On STM32MP13x lines [edit source]
Security | CRC | CRC | ☐ |
3.2.2. On STM32MP15x lines [edit source]
Cortex-M4 (STM32Cube) | |||
Security | CRC | CRC1 | ☐ | ☐ | ||
CRC2 | ☐ | ☐ |
3.2.3. On STM32MP25x lines [edit source]
Cortex-M33 secure (TF-M) |
Cortex-M0+ (STM32Cube) | |||
Security | CRC | CRC | ⬚OP-TEE | ☐ | ⬚ | ☐ |
Below are listed the software frameworks and drivers managing the CRC peripheral for the embedded software components listed in the above tables.
- Linux®: crypto framework
- STM32Cube: CRC HAL driver and header file of CRC HAL module
