Arm Cortex-M0+
Revision as of 15:10, 21 July 2023 by Registered User
Concerning the STM32MP25x lines More info.png, only the boot time assignment table and the runtime assignment table have been updated.
The other chapters have not been updated yet.
  • briefly introduce the Arm® Cortex®-M0+ (coprocessor) peripheral and its main features,
The Arm® Cortex®-M0+ (coprocessor) peripheral is used to ....
Under construction.png Coming soon
3.1.1. On STM32MP2 series[edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
non-secure
(U-Boot)
DOMAIN Arm® Cortex®-M0+ (coprocessor) Arm® Cortex®-M0+
3.2.1. On STM32MP25x lines More info.png[edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
non-secure
Cortex-M33
(TF-M)
Cortex-M33
non-secure
Cortex-M0+
DOMAIN Arm® Cortex®-M0+ (coprocessor) Arm® Cortex®-M0+ (coprocessor) OP-TEE
Below are listed the software frameworks and drivers managing the Arm® Cortex®-M0+ (coprocessor) for the embedded software components listed in the above tables.
