Unspecified MPUs checklist
- briefly introduce the DMAMUX peripheral and its main features
- explain, when necessary, how to configure the DMAMUX peripheral.
The DMAMUX peripheral is used to perform requestor line (or device controller) selection for each channel from DMA instances:
- In STM32MP13x lines there is a first DMAMUX instance to cover both DMA1 and DMA2, and second DMAMUX instance to cover DMA3.
- In STM32MP15x lines there is a single DMAMUX instance to cover both DMA1 and DMA2.
2.1. Features[edit source]
- In STM32MP13x lines the first DMAMUX instance, covering both DMA1 and DMA2, is a non secure peripheral and the second DMAMUX instance, covering DMA3, is a secure peripheral.
- In STM32MP15x lines the single DMAMUX instance, covering both DMA1 and DMA2, is a non secure peripheral.
3.1. Boot time[edit source]
The DMAMUX is not used at boot time.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
The DMAMUX manages DMA1 and DMA2 requestor line selection via different registers so it is possible to concurrently access to DMAMUX from Cortex®-A7 non-secure and Cortex®-M4 contexts, as far as each core is only configuring the requestor lines for the DMA instances (DMA1 and/or DMA2) assigned to itself.
Finally, DMAMUX can be allocated to:
- the Arm® Cortex®-A7 non-secure core to be controlled in Linux® by the dmaengine framework
- the Arm® Cortex®-M4 to be controlled in STM32Cube MPU Package by the DMA HAL driver
| Core/DMA | DMAMUX | | Linux dmaengine framework | STM32Cube DMAMUX driver | |- |}
| rowspan="1" | Core/DMA | rowspan="1" | DMAMUX | DMAMUX | | ☐ | ☐ | Shareable (multiple choices supported) |-
