Template:UpdateNeededForNewRelease
This article describes how to get and use the Distribution Package of the STM32MPU Embedded Software for any development platform of the STM32MP1 family (STM32MP15 boards), in order to modify or add pieces of software, and to create the right Linux distribution, for the targeted product.
- Which Package better suits your needs (and especially the Distribution Package chapter)
- a build framework based on OpenEmbedded (aka distribution builder)
- for the OpenSTLinux distribution (development on Arm Cortex-A processor), all pieces of software in source code: the BSP (Linux kernel, U-Boot, TF-A, optionally OP-TEE), and the application frameworks (Wayland-Weston, GStreamer, ALSA...)
- for the STM32Cube MPU Package (development on Arm Cortex-M processor), all pieces of software in source code: BSP, HAL, middlewares and applications
- a toolset to tune the system for your needs, and to handle the built image (e.g. STM32CubeProgrammer to install the built image on the board)
Template:Highlight
☐ Checking the prerequisites
☐ Installing the Starter Package for your board
☐ Installing the OpenSTLinux distribution
☐ Building the OpenSTLinux distribution
☐ Flashing the built image
☐ Checking the boot sequence
- modify software running on Arm Cortex-A
- modify software running on Arm Cortex-M
- create your own Linux distribution
- generate your own Starter and Developer Packages
3.1. Knowledges[edit source]
- Host PC for cross-compilation and cross-debugging, installed as specified above
- Board assembled and configured as specified in the associated Starter Package article
- Mass storage device (for example, microSD card) to load and update the software images (binaries)
- A serial link between the host PC (through Terminal program) and the board for traces (even early boot traces), and access to the board from the remote PC (command lines)
- An Ethernet link between the host PC and the board for cross-development and cross-debugging through a local network. This is an alternative or a complement to the serial (or USB) link
- A display connected to the board, depending on the technologies available on the board: DSI LCD display, HDMI monitor (or TV) and so on
- A mouse and a keyboard connected through USB ports
Before installing and using the Distribution Package, Template:Highlight. All articles relative to Starter Packages are found in Category:Starter Package: find the one that corresponds to your board, and follow the installation instructions (if not yet done), before going further.
In brief, it means that:
- your board boots successfully
- the flashed image comes from the same release of the STM32MPU Embedded Software distribution than the OpenSTLinux distribution that will be downloaded in this article
- The STM32MP1 OpenSTLinux distribution is delivered through a manifest repository location and a manifest revision (openstlinux-4.14-rocko-mp1-18-11-26).
- The installation relies on the repo command. In case the Repo tool (a Google-built repository management tool that runs on top of Git) is not yet installed and configured on the host PC, refer to the PC prerequisites article.
- The OpenSTLinux distribution is massively using open source software (OSS) packages that are downloaded from a variety of open source repositories; so it is required that the IT infrastructure proxies do not forbid such accesses. If some proxy-related issues are suspected, refer to the How to avoid proxy issues article.
- Install the STM32MP1 OpenSTLinux distribution
STM32MP1 Distribution Package OpenSTLinux distribution - Beta1 release | |
Installation |
$ cd <working directory path>/Distribution-Package
$ mkdir openstlinux-4.14-rocko-mp1-18-11-26 $ cd openstlinux-4.14-rocko-mp1-18-11-26
Details:
The below command downloads (in the .repo directory) the latest repo source code and a manifest file (default.xml)) that describes the directory structure of the repositories for OpenSTLinux. The -u option specifies the manifest repository location, while the -b option specifies its branch. Template:InternalInfo
Template:STdotcomInfo
Note1: "ERROR 404" may appear during "repo init" command without any impact on the process machine github.com login "github login" password "github password"
Details:
If a local project does not yet exist, the command clones a new local directory from the remote repository and sets up tracking branches as specified in the manifest. If the local project already exists, the command updates the remote branches and rebases any new local changes on top of the new remote changes. $ repo sync |
Release note |
Details about the content of this software package are available in the associated STM32MP15 ecosystem release note. If interested in previous releases, go through the archives of the ecosystem release note. |
- The OpenSTLinux distribution installation directory is in the <Distribution Package installation directory>, and is named openstlinux-4.14-rocko-mp1-18-11-26:
Template:Green Template:Highlight ├── Template:Green Template:Highlight ├── Template:Green Template:Highlight ├── Template:Green Template:Highlight ├── Template:Green │ ├── Template:Green Template:Highlight │ ├── Template:Green Template:Highlight │ │ ├── Template:Green │ │ │ ├── Template:Green Template:Highlight │ │ │ ├── Template:Green Template:Highlight │ │ │ ├── Template:Green Template:Highlight │ │ │ └── Template:Green Template:Highlight │ │ ├── Template:Green │ │ │ ├── Template:Green Template:Highlight │ │ │ └── Template:Green Template:Highlight │ │ ├── Template:Green │ │ │ ├── Template:Green Template:Highlight │ │ │ └── [...] │ │ ├── Template:Green │ │ │ ├── Template:Green Template:Highlight │ │ │ └── Template:Green Template:Highlight │ │ ├── Template:Green │ │ │ └── Template:Green Template:Highlight │ │ ├── Template:Green │ │ │ └── Template:Green Template:Highlight │ │ └── [...] │ ├── Template:Green Template:Highlight │ └── Template:Green │ ├── envsetup.sh Template:Highlight │ └── [...] └── Template:Green Template:Highlight
Template:PC$ DISTRO=openstlinux-weston MACHINE=stm32mp1-boards-revb source meta-st/scripts/envsetup.sh
OR
Template:PC$ DISTRO=openstlinux-weston MACHINE=stm32mp1-boards-revc source meta-st/scripts/envsetup.sh
The BSP for STM32MP1 depends on packages and firmwares which are covered by an End User License Agreement (EULA). You will be asked to read and to accept this EULA.
Note that:
- openstlinux-weston (OpenSTLinux distribution featuring Weston/Wayland) and stm32mp1-boards-rev[b/c] (machine configuration for all STM32MP1 hardware configurations) are the default values for DISTRO and MACHINE
- The software packages for the Starter Package (image) and for the Developer Package (SDK...) have been built with this configuration
- Other values for DISTRO and MACHINE are proposed in OpenSTLinux distribution
Among other things, the environment setup script creates the build directory named build-<distro>-<machine> directory (build-openstlinuxweston-stm32mp1-boards-rev[b/c] here). After the script runs, the current working directory is set to this build directory. Later, when the build completes, it contains all the files created during the build.
Template:Green OpenSTLinux distribution ├── Template:Green Template:Highlight │ ├── Template:Green │ │ ├── bblayers.conf Template:Highlight │ │ ├── local.conf Template:Highlight │ │ └── [...] │ └── Template:Green ├── Template:Green └── [...]
Template:PC$ bitbake st-image-weston
Note that:
- The software packages for the Starter Package (image) and for the Developer Package (SDK...) have been built for this st-image-weston image
- Other values for <image> are proposed as examples in OpenSTLinux distribution (take care of the compatibility between the value selected for DISTRO and the value targeted for <image>)
The build-<distro>-<machine>/tmp-glibc/deploy/images/stm32mp1-boards-rev[b/c] directory receives complete file system images.
Template:InfoTemplate:UpdateNeededForNewRelease
build-<distro>-<machine>/tmp-glibc/deploy └── Template:Green | └── Template:Green | ├── Template:Green Template:Highlight | │ ├── FlashLayout_emmc_stm32mp157c-ev1-optee.tsv Template:Highlight | │ ├── FlashLayout_emmc_stm32mp157c-ev1-trusted.tsv Template:Highlight | │ ├── FlashLayout_nand-4-256_stm32mp157c-ev1-optee.tsv Template:Highlight | │ ├── FlashLayout_nand-4-256_stm32mp157c-ev1-trusted.tsv Template:Highlight | │ ├── FlashLayout_nor-emmc_stm32mp157c-ev1-optee.tsv Template:Highlight | │ ├── FlashLayout_nor-emmc_stm32mp157c-ev1-trusted.tsv Template:Highlight | │ ├── FlashLayout_nor-nand-4-256_stm32mp157c-ev1-optee.tsv Template:Highlight | │ ├── FlashLayout_nor-nand-4-256_stm32mp157c-ev1-trusted.tsv Template:Highlight | │ ├── FlashLayout_nor-sdcard_stm32mp157c-ev1-optee.tsv Template:Highlight | │ ├── FlashLayout_nor-sdcard_stm32mp157c-ev1-trusted.tsv Template:Highlight | │ ├── FlashLayout_sdcard_stm32mp157c-dk2-basic.tsv Template:Highlight | │ ├── FlashLayout_sdcard_stm32mp157c-dk2-optee.tsv Template:Highlight | │ ├── FlashLayout_sdcard_stm32mp157c-dk2-trusted.tsv Template:Highlight | │ ├── FlashLayout_sdcard_stm32mp157c-ev1-basic.tsv Template:Highlight | │ ├── FlashLayout_sdcard_stm32mp157c-ev1-optee.tsv Template:Highlight | │ └── FlashLayout_sdcard_stm32mp157c-ev1-trusted.tsv Template:Highlight | │ └── [...] | ├── Template:Green | │ └── create_sdcard_from_flashlayout.sh | ├── splash.bin Template:Highlight | ├── st-image-bootfs-openstlinux-weston-stm32mp1-boards-rev[b/c].ext4 Template:Highlight | ├── st-image-userfs-openstlinux-weston-stm32mp1-boards-rev[b/c].ext4 Template:Highlight | ├── st-image-vendorfs-openstlinux-weston-stm32mp1-boards-rev[b/c].ext4 Template:Highlight | ├── st-image-weston-openstlinux-weston-stm32mp1-boards-rev[b/c].ext4 Template:Highlight | ├── stm32mp157c-d[*].dtb Template:Highlight | ├── stm32mp157c-e[*].dtb Template:Highlight | ├── tf-a-bl2-optee.elf Template:Highlight | ├── tf-a-bl2-trusted.elf Template:Highlight | ├── tf-a-bl32-trusted.elf Template:Highlight | ├── tf-a-stm32mp157c-dk2-optee.stm32 Template:Highlight | ├── tf-a-stm32mp157c-dk2-trusted.stm32 Template:Highlight | ├── tf-a-stm32mp157c-ev1-optee.stm32 Template:Highlight | ├── tf-a-stm32mp157c-ev1-trusted.stm32 Template:Highlight | ├── u-boot-spl.stm32-stm32mp157c-dk2-basic Template:Highlight | ├── u-boot-spl.stm32-stm32mp157c-ev1-basic Template:Highlight | ├── u-boot-stm32mp157c-dk2-basic.img Template:Highlight | ├── u-boot-stm32mp157c-dk2-optee.stm32 Template:Highlight | ├── u-boot-stm32mp157c-dk2-trusted.stm32 Template:Highlight | ├── u-boot-stm32mp157c-ev1-basic.img Template:Highlight | ├── u-boot-stm32mp157c-ev1-optee.stm32 Template:Highlight | ├── u-boot-stm32mp157c-ev1-trusted.stm32 Template:Highlight | ├── uImage Template:Highlight | ├── vmlinux Template:Highlight | └── [...] └── [...]
The procedure to flash your board is explained in the Starter Package article that corresponds to your board (remember that all articles relative to Starter Packages are found in Category:Starter Package):Template:UpdateNeededForNewBoard
- Flashing the built image on the STM32MP15 Evaluation board
- Flashing the built image on the STM32MP15 Discovery kit
Boot from microSD card on STM32MP15 Evaluation board | Boot from microSD card on STM32MP15 Discovery kit |
- remove the STM32Cube MPU Package from your own distribution
- install your own Cube Cortex-M project for your own distribution
- modify the STM32Cube MPU Package delivered by ST for your own distribution
Prerequisites:
- It is assumed here that your recipes have been updated with patches that reflect changes you make to the source files, thanks to the devtool update-recipe command
- So, either original recipes (.bb) have been modified with your changes, or recipes of your own layers (How to create a new open embedded layer) have been modified with your changes, so that the custom recipes (.bbappend) and your patches are clearly isolated from the original ones (recommended method to ease the maintenance)
- Run the environment setup script; select, for DISTRO and MACHINE, the values for which you want to generate the Starter and Developer Packages (see OpenSTLinux distribution for all possible values)
Template:PC$ DISTRO=<distro> MACHINE=<machine> source meta-st/scripts/envsetup.sh Example: Template:PC$ DISTRO=openstlinux-weston MACHINE=stm32mp1-boards-revb source meta-st/scripts/envsetup.sh
OR
- Modify the build-<distro>-<machine>/conf/local.conf file to enable archiver for recipes that are configured to use it; the objective is to generate the "source code" software packages for the Developer Package (Linux kernel, U-Boot, TF-A)
ST_ARCHIVER_ENABLE = "1"
- Build the image to ensure that your last developments integrated in the distribution are reflected in the image, and to generate the "source code" software packages for the Developer Package; select, for <image>, the value for which you want to generate the Starter and Developer Packages (see OpenSTLinux distribution for all possible values)
Template:PC$ bitbake <image> Example: Template:PC$ bitbake st-image-weston
- The image (binaries) for the Starter Package are available in the build-<DISTRO>-<MACHINE>/tmp-glibc/deploy/images/stm32mp1-boards-rev[b/c] directory
Note that the structure of this images/stm32mp1-boards-rev[b/c] directory is obviously similar to the directory structure of the Starter Package.
- The "source code" for the Developer Package software packages (Linux kernel, U-Boot and TF-A) are available in the build-<distro>-<machine>/tmp-glibc/deploy/sources/arm-openstlinux_weston-linux-gnueabi directory
Note that the structure of this sources/arm-openstlinux_weston-linux-gnueabi directory is obviously similar to the directory structure of the Developer Package for TF-A, Linux kernel and U-Boot.
Template:Green Build directory ├── Template:Green │ │ ├── Template:Green │ │ │ ├── Template:Green │ │ │ │ └── Template:Green │ │ │ │ ├── Template:Green Template:Highlight │ │ │ │ ├── Template:Green Template:Highlight │ │ │ │ └── Template:Green Template:Highlight │ │ │ └── [...] │ │ └── [...] │ └── [...] └── [...]
- Optionally, compress the different "source code" directories to get the Developer Package software packages
- Generate the last element namely the new software development kit (SDK) for the Developer Package with the How to create an SDK for OpenSTLinux distribution article
If you are already familiar with the Distribution Package for the STM32MPU Embedded Software distribution, fast links to the essential commands are listed below. {Info|With the links below, you will be redirected to other articles; use the back button of your browser to come back to these fast links}}
