PKA internal peripheral
Applicable for STM32MP13x lines, STM32MP25x lines
  • briefly introduce the PKA peripheral and its main features,
The PKA (public key accelerator) peripheral is used to ease computation of cryptographic public key primitives, specifically those related to RSA, Diffie-Hellmann or ECC (elliptic curve cryptography) over GF(p) (Galois fields).
Refer to the STM32MP13 reference manuals for the complete list of features, and to the software frameworks and drivers, introduced below, to see which features are implemented.
3.1.1. On STM32MP13x lines More info.png[edit source]
The PKA peripheral is a boot device, it is used for signature verification on secure boot processing.
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
Security PKA PKA Assignment is mandatory only for secure boot
3.1.2. On STM32MP2 series[edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
non-secure
(U-Boot)
3.2.1. On STM32MP13x lines More info.png[edit source]
non-secure
Security PKA PKA Assignment (single choice)
3.2.2. On STM32MP25x lines More info.png[edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
non-secure
Cortex-M33
(TF-M)
Cortex-M33
non-secure
Cortex-M0+
Security PKA PKA OP-TEE
Below are listed the software frameworks and drivers managing the PKA peripheral for the embedded software components listed in the above tables.
