- briefly introduce the DTS peripheral and its main features,
The DTS peripheral is used to monitor the device temperature and take some preventive action (like frequency scaling or peripheral disabling) in case it is becoming too high and before destroying the component.
3.1.1. On STM32MP1 series[edit source]
The DTS peripheral is not used at boot time.
3.1.2. On STM32MP2 series[edit source]
Power & Thermal | DTS | DTS | ⬚ |
3.2.1. On STM32MP13x lines [edit source]
Power & Thermal | DTS | DTS | ☐ |
3.2.2. On STM32MP15x lines [edit source]
Cortex-M4 (STM32Cube) | |||
3.2.3. On STM32MP25x lines [edit source]
Cortex-M33 secure (TF-M) |
Cortex-M0+ (STM32Cube) | |||
Power & Thermal | DTS | DTS | ⬚OP-TEE | ☐ | ⬚ |
Below are listed the software frameworks and drivers managing the DTS peripheral for the embedded software components listed in the above tables.
- Linux®: thermal framework
On STM32MP1 series:
On STM32MP2 series:
