HASH internal peripheral
Revision as of 16:11, 25 July 2024 by Registered User
The HASH peripheral is used to compute a message digest.
The HASH peripheral is also able to give the HMAC[1] used for authentication using the same algorithm support.
1.1. On STM32MP13x lines More info.png and STM32MP25x lines More info.png[edit source]
Secure Hash algorithms supports:
  • SHA-1 [2]
  • SHA-2 [3]:
    • SHA-224
    • SHA-256
    • SHA-384
    • SHA-512
    • Truncated output SHA-512/224, SHA512/256
  • SHA-3 [4]:
    • SHA3-224
    • SHA3-256
    • SHA3-384
    • SHA3-512
    • SHAKE128 and 256
    • Keccak-based functions
  • HMAC support for all supported algorithm
Refer to the STM32MP13 reference manuals or STM32MP25 reference manuals for the complete list of features, and to the software frameworks and drivers, introduced below, to see which features are implemented.
1.2. On STM32MP15x lines More info.png[edit source]
  • MD5 [5]
  • SHA-1 [2]
  • SHA-2 [3]:
    • SHA-224
    • SHA-256
2. Peripheral usage[edit source]
2.1. Boot time assignment[edit source]
The HASH instance is used as boot device to support binary authentication.
2.1.1. On STM32MP13x lines More info.png[edit source]
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
Security HASH HASH
2.1.2. On STM32MP15x lines More info.png[edit source]
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
Security HASH HASH1
HASH2 not used at boot time.
2.1.3. On STM32MP2 series[edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
non-secure
(U-Boot)
Security HASH HASH
2.2. Runtime assignment[edit source]
2.2.1. On STM32MP13x lines More info.png[edit source]
non-secure
Security HASH HASH Assignment (single choice)
2.2.2. On STM32MP15x lines More info.png[edit source]
non-secure
Cortex-M4
Security HASH HASH1 Assignment (single choice)
HASH2
2.2.3. On STM32MP25x lines More info.png[edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
non-secure
Cortex-M33
(TF-M)
Cortex-M33
non-secure
Cortex-M0+
Security HASH HASH OP-TEE
3. Software frameworks and drivers[edit source]
Below are listed the software frameworks and drivers managing the HASH peripheral for the embedded software components listed in the above tables.
4. How to assign and configure the peripheral[edit source]
