How to measure the performance of your models using ONNX Runtime
Revision as of 18:46, 28 June 2024 by Registered User (→‎Testing with MobileNet)
This article describes how to measure the performance of an ONNX model using ONNX Runtime on STM32MPUs platform.
1. Installation[edit source]
1.1. Installing from the OpenSTLinux AI package repository[edit source]
After having configured the AI OpenSTLinux package, install X-LINUX-AI components for this application. The minimum package required is:
 x-linux-ai -i onnxruntime-tools
The model used in this example can be installed from the following package:
 x-linux-ai -i img-models-mobilenetv2-10-224
2. How to use the benchmark application[edit source]
2.1. Executing with the command line[edit source]
The onnxruntime_perf_test executable is located in the userfs partition:
/usr/local/bin/onnxruntime-*/tools/onnxruntime_perf_test
usage: ./onnxruntime_perf_test [options...] model_path [result_file]
Options:
        -m [test_mode]: Specifies the test mode. Value could be 'duration' or 'times'.
                Provide 'duration' to run the test for a fix duration, and 'times' to repeated for a certain times.
        -M: Disable memory pattern.
        -A: Disable memory arena
        -I: Generate tensor input binding (Free dimensions are treated as 1.)
        -c [parallel runs]: Specifies the (max) number of runs to invoke simultaneously. Default:1..
        -r [repeated_times]: Specifies the repeated times if running in 'times' test mode.Default:1000.
        -t [seconds_to_run]: Specifies the seconds to run for 'duration' mode. Default:600.
        -p [profile_file]: Specifies the profile name to enable profiling and dump the profile data to the file.
        -s: Show statistics result, like P75, P90. If no result_file provided this defaults to on.
        -v: Show verbose information.
        -x [intra_op_num_threads]: Sets the number of threads used to parallelize the execution within nodes, A value of 0 means ORT will pick a default. Must >=0.
        -y [inter_op_num_threads]: Sets the number of threads used to parallelize the execution of the graph (across nodes), A value of 0 means ORT will pick a default. Must >=0.
        -f [free_dimension_override]: Specifies a free dimension by name to override to a specific value for performance optimization. Syntax is [dimension_name:override_value]. override_value must > 0
        -F [free_dimension_override]: Specifies a free dimension by denotation to override to a specific value for performance optimization. Syntax is [dimension_denotation:override_value]. override_value must > 0
        -P: Use parallel executor instead of sequential executor.
        -o [optimization level]: Default is 99 (all). Valid values are 0 (disable), 1 (basic), 2 (extended), 99 (all).
                Please see onnxruntime_c_api.h (enum GraphOptimizationLevel) for the full list of all optimization levels.
        -u [optimized_model_path]: Specify the optimized model path for saving.
        -z: Set denormal as zero. When turning on this option reduces latency dramatically, a model may have denormals.
        -h: help
2.2. Testing with MobileNet[edit source]
The model used for testing is mobilenet_v2_1.0_224_int8_per_tensor.onnx, installed by the img-models-mobilenetv2-10-224 package. It is a model used for image classification.
On the target, the model is located here:
/usr/local/x-linux-ai/image-classification/models/mobilenet/
To benchmark an ONNX model with onnxruntime_perf_test, use the following command:
 /usr/local/bin/onnxruntime-*/tools/onnxruntime_perf_test -I -m times -r 8 /usr/local/x-linux-ai/image-classification/models/mobilenet/mobilenet_v2_1.0_224_int8_per_tensor.onnx
Console output:
Session creation time cost: 0.632683 s
Total inference time cost: 1.41846 s
Total inference requests: 8
Average inference time cost: 177.308 ms
Total inference run time: 1.4186 s
Number of inferences per second: 5.63936
Avg CPU usage: 98 %
Peak working set size: 52129792 bytes
Avg CPU usage:98
Peak working set size:52129792
Runs:8
Min Latency: 0.17603 s
Max Latency: 0.182825 s
P50 Latency: 0.176624 s
P90 Latency: 0.182825 s
P95 Latency: 0.182825 s
P99 Latency: 0.182825 s
P999 Latency: 0.182825 s
To obtain the best performance, it is interesting to use the additional flags -P -x 2 -y 1 to use more than one thread for the benchmark depending of the hardware used.
 /usr/local/bin/onnxruntime-*/tools/onnxruntime_perf_test -I -m times -r 8 -P -x 2 -y 1 /usr/local/x-linux-ai/image-classification/models/mobilenet/mobilenet_v2_1.0_224_int8_per_tensor.onnx
Console output:
Setting intra_op_num_threads to 2
Setting inter_op_num_threads to 1
Session creation time cost: 0.483545 s
Total inference time cost: 1.43479 s
Average inference time cost: 179.349 ms
Total inference run time: 1.43495 s
Number of inferences per second: 5.57509
Avg CPU usage: 96 %
Peak working set size: 43249664 bytes
Avg CPU usage:96
Peak working set size:43249664
Runs:8
Min Latency: 0.177462 s
Max Latency: 0.181616 s
P50 Latency: 0.178953 s
P90 Latency: 0.181616 s
P95 Latency: 0.181616 s
P99 Latency: 0.181616 s
P999 Latency: 0.181616 s
To display more information, use the flag -v.
3. References[edit source]
