CRC internal peripheral
Revision as of 15:08, 4 January 2024 by Registered User
  • briefly introduce the CRC peripheral and its main features,
The CRC peripheral is used to verify data transmission or storage integrity.
The CRC peripheral is not used at boot time.
3.2.1. On STM32MP13x lines More info.png[edit source]
non-secure
Security CRC CRC
3.2.2. On STM32MP15x lines More info.png[edit source]
non-secure
Cortex-M4
Security CRC CRC1
CRC2
3.2.3. On STM32MP25x lines More info.png[edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
non-secure
Cortex-M33
(TF-M)
Cortex-M33
non-secure
Cortex-M0+
Security CRC CRC OP-TEE
Below are listed the software frameworks and drivers managing the CRC peripheral for the embedded software components listed in the above tables.
