STM32MP15 VREFBUF internal peripheral
Revision as of 08:45, 20 June 2023 by Registered User
  • briefly introduce the VREFBUF peripheral and its main features,
The VREFBUF is supplied via the VDDA pin. When enabled, it can provide a reference voltage in the range of: 1,5V, 1,8V, 2,048V or 2,5V.
The VREFBUF can be used to provide an analog voltage reference for:
3.1.1. On STM32MP15x lines More info.png[edit source]
The VREFBUF is not used at boot time.
3.2.1. On STM32MP15x lines More info.png[edit source]
non-secure
Cortex-M4
Analog VREFBUF VREFBUF Assignment (single choice)
Below are listed the software frameworks and drivers managing the VREFBUF peripheral for the embedded software components listed in the above tables.
The VREFBUF is a system resource[1] which needs to be also controlled by the resource manager[1] in case its consumers (e.g. ADC, DAC or an external device connected to VREF+ pin) are spread across:
  • the Arm® Cortex®-A7 non-secure context
  • the Arm® Cortex®-M4 context
For this reason, the direct control of VREFBUF from the Arm® Cortex®-M4 is not recommended in STM32Cube by default.
It's recommended to implement it in STM32Cube only if all consumers and the VDDA supply pin are controlled in the Arm® Cortex®-M4 context.
  1. 1.0 1.1 Resource manager for coprocessing, focus on system resources
