TSGEN internal peripheral
1 Article purpose[edit]
  • Briefly introduce the TSGEN peripheral and its main features
  • Indicate the level of security supported by this hardware block
  • Explain how each instance can be allocated to the three runtime contexts and linked to the corresponding software components
  • Explain, when necessary, how to configure the TSGEN peripheral.
2 Peripheral overview[edit]
The TSGEN peripheral generates a universal reference in time, named timestamps, and sends it to the CoreSight™ source peripherals (such as STM and ETM internal peripherals). Source peripherals use then this reference to integrate it in the generated trace. Since multiple trace generators can be implemented in a CoreSight system, the timestamp allows traces to be ordered chronologically.
2.1 Features[edit]
Refer to the STM32MP15 reference manuals for the complete list of features, and to the software components, introduced below, to see which features are really implemented.
2.2 Security support[edit]
The TSGEN is a non secure peripheral.
3 Peripheral usage and associated software[edit]
3.1 Boot time[edit]
The TSGEN can be used at boot time to provide time stamping for ETM and STM traces.
3.2 Runtime[edit]
3.2.1 Overview[edit]
The TSGEN can be used at run time to provide time stamping for ETM and STM traces.
3.2.2 Software frameworks[edit]
There is no software dedicated to the TSGEN internal peripheral delivered with STM32MPU ecosystem.
3.2.3 Peripheral configuration[edit]
Configuration of the TSGEN is done via JTAG scripts. Those scripts must be built by the user thanks to STM32MP15 reference manuals .
3.2.4 Peripheral assignment[edit]
non-secure
Cortex-M4
Trace & Debug TSGEN TSGEN No assignment possible
4 References[edit]
