- Last edited 3 months ago ago
STM internal peripheral
Contents
1 Article purpose[edit]
- briefly introduce the STM peripheral and its main features,
2 Peripheral overview[edit]
The STM peripheral is used to log STM traces into the embedded trace FIFO (ETF). This trace can include hardware events (the list is given in the STM32MP15 reference manuals) or direct 'printf like' log from the Cortex®-A7. Once in the ETF buffer, the trace can be dumped directly from the Cortex®-A7 or to the trace port interface unit (TPIU), connected to an external probe able to decode it.
3 Peripheral usage[edit]
3.1 Boot time assignment[edit]
3.1.1 On STM32MP1 series[edit]
The STM can be used to debug the boot sequence using an external probe, without any associated embedded software.
3.2 Runtime assignment[edit]
3.2.1 On STM32MP15x lines
[edit]
Cortex-M4 (STM32Cube) | |||
Trace & Debug | STM | STM | ☐ |
4 Software frameworks and drivers[edit]
The STM can be used to debug the run time application using an external probe, without any associated embedded software.
There is no software dedicated to the STM internal peripheral delivered with the STM32 MPU ecosystem but the STM trace can be captured using an external probe.
5 How to assign and configure the peripheral[edit]
Configuration of the STM is done via JTAG scripts. Those scripts must be built by the user using the STM32MP15 reference manuals .
