ETM internal peripheral
1 Article purpose[edit]
  • briefly introduce the ETM peripheral and its main features
  • explain, when necessary, how to configure the ETM peripheral.
2 Peripheral overview[edit]
The ETM peripheral is used to log the Cortex®-A7 execution trace into the embedded trace FIFO (ETF). Once in the ETF buffer, the trace can directly be dumped from the Cortex®-A7 or to the trace port interface unit (TPIU), connected to an external probe able to decode it.
This peripheral has two instances, one for each Cortex®-A7 core.
2.1 Features[edit]
Refer to the STM32MP13 reference manuals or STM32MP15 reference manuals for the complete list of features, and to the software components, introduced below, to see which features are really implemented.
2.2 Security support[edit]
The ETM is a non secure peripheral.
3 Peripheral usage and associated software[edit]
3.1 Boot time[edit]
The ETM can be used to debug the boot sequence using external probe.
3.2 Runtime[edit]
3.2.1 Overview[edit]
The ETM can be used to debug the run time application using external probe.
3.2.2 Software frameworks[edit]
There is no software dedicated to the ETM internal peripheral delivered with STM32MPU ecosystem. Nevertheless, the ETM trace can be captured using an external probe.
3.2.3 Peripheral configuration[edit]
Configuration of the ETM is done via JTAG scripts. Those scripts must be built by user thanks to STM32MP13 reference manuals or STM32MP15 reference manuals .
3.2.4 Peripheral assignment[edit]
3.2.4.1 On STM32MP13x lines More info.png[edit]
non-secure
Trace & Debug ETM ETM
3.2.4.2 On STM32MP15x lines More info.png[edit]
non-secure
Cortex-M4
Trace & Debug ETM ETM0
ETM1
4 References[edit]
