CRYP internal peripheral
  • briefly introduce the CRYP peripheral and its main features,
The CRYP peripheral provides hardware acceleration to encrypt or decrypt data using the DES[1], TDES[2] or AES[3] algorithms. It also supports multiple key sizes and chaining modes.
3.1.1. On STM32MP13x lines More info.png[edit source]
CRYP could be used in ROM code during boot process for FSBL decryption.
Domain Peripheral Boot time allocation Comment
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
Security CRYP CRYP Boot ROM allocation is manage with the bit 7 in OTP 9
3.1.2. On STM32MP15x lines More info.png[edit source]
The CRYP peripheral is not used at boot time.
3.2.1. On STM32MP13x lines More info.png[edit source]
non-secure
Security CRYP CRYP Assignment (single choice)
3.2.2. On STM32MP15x lines More info.png[edit source]
non-secure
Cortex-M4
Security CRYP CRYP1 Assignment (single choice)
CRYP2
Below are listed the software frameworks and drivers managing the CRYP peripheral for the embedded software components listed in the above tables.
