RNG internal peripheral
Revision as of 14:18, 29 May 2023 by Registered User
  • Briefly introduce the RNG peripheral and its main features,
  • Indicate the peripheral instances assignment at boot time and their assignment at runtime (including whether instances can be allocated to secure contexts),
  • List the software frameworks and drivers managing the peripheral,
  • Explain how to configure the peripheral.
The RNG peripheral is used to provide 32-bit random numbers.
The RNG can be assigned to non-secure or secure world (default behavior). If the RNG is assigned to the secure world then the non-secure world can request random numbers through the OP-TEE RNG PTA. More information about this mechanism can be found in OP-TEE documentation [1]. Else, the software component uses its RNG driver directly.
What is applicable for the Linux Kernel is applicable for U-Boot.
RNG implementations overview
The hardware RNG peripheral for Arm® Cortex®-A processor is default assigned to OP-TEE, for which the driver and interfaces are maintained. This is the default and recommended setup.
It is still possible to assign the RNG to the Linux Kernel, but it is necessary to deactivate it in OP-TEE device tree and activate it in the Linux kernel device tree, declare it as a firewall exception in the OP-TEE firewall driver and declare your board in the flavorlist-no_rng in the OP-TEE board configuration makefile .
3.1.1. On STM32MP13x lines More info.png[edit source]
Domain Peripheral Boot time allocation Comment
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
Security RNG RNG1 Required for DPA peripheral protection
3.1.2. On STM32MP15x lines More info.png[edit source]
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
Security RNG RNG1
If the Arm® Cortex®-A processor hardware RNG peripheral is assigned to OP-TEE, then the Linux Kernel can request random numbers through the hardware random framework which is interfaced with the OP-TEE RNG Linux driver .
If the Arm® Cortex®-A processor hardware RNG peripheral is assigned to the Linux Kernel, then the Linux Kernel can access it through the hardware random framework which is interfaced with the Linux RNG driver .
3.2.1. On STM32MP13x lines More info.png[edit source]
non-secure
Security RNG RNG Assignment (single choice)
3.2.2. On STM32MP15x lines More info.png[edit source]
non-secure
Cortex-M4
Security RNG RNG1 Assignment (single choice)
RNG2
Below are listed the software frameworks and drivers managing the RNG peripheral for the embedded software components listed in the above tables.
This configuration is done in OP-TEE, through device tree.
Refer to RNG device tree configuration.
