PKA internal peripheral
  • briefly introduce the PKA peripheral and its main features
  • explain how it can be allocated to the runtime contexts and linked to the corresponding software components
  • explain, when necessary, how to configure the PKA peripheral.
The PKA (public key accelerator) is peripheral is used to ease computation of cryptographic public key primitives, specifically those related to RSA, Diffie-Hellmann or ECC (elliptic curve cryptography) over GF(p) (Galois fields).
2.1. Features[edit source]
Refer to the STM32MP13 reference manuals for the complete list of features, and to the software components, introduced below, to see which features are implemented.
The PKA is a secure peripheral (under ETZPC control).
3.1. Boot time[edit source]
PKA is a boot device, it is used to verify signature on a secure boot processing.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
PKA instance is allocated to:
  • the Arm® Cortex®-A7 secure core to be controlled in OP-TEE by the PKA OP-TEE driver through the ECC framework.
OP-TEE Linux
Security Peripheral (PKA internal peripheral) OP-TEE PKA driver Linux Crypto framework
non-secure
Security PKA PKA Assignment (single choice)
