HASH device tree configuration
Revision as of 08:40, 23 May 2022 by Registered User
The purpose of this article is to explain how to configure the HASH using the device tree mechanism, relying on the bindings documentation, that is the description of the required and optional device-tree properties.
The peripheral can be assigned to different contexts/software components, depending on the final product needs. Refer to How to assign an internal peripheral to a runtime context article for guidelines on this configuration .
The HASH node is located in the device tree file for the software components, supporting the peripheral and listed in the above DT bindings documentation paragraph.
The objective of this chapter is to explain how to enable and configure the HASH DT nodes for a board.
Peripheral configuration should be done in specific board device tree files (board dts file).
   &hash {
        status = "okay";
