NVMEM overview
Revision as of 10:18, 19 May 2022 by Registered User (→‎System overview)
This article introduces how NVMEM Linux® framework manages BSEC OTP data and how to read/write from/to it.
The NVMEM Linux® framework provides a generic interface for the device non-volatile memory data such as:
  • OTP (one-time programmable) fuses
  • EEPROM
It offers kernel space and user space interfaces to read and/or write data such as analog calibration data or MAC address.
NVMEM sysfs interfaceNVMEM consumers interfaceBSEC internal peripheralBSEC PTAOP-TEEOP-TEE linux driverTEE Client APINVMEM overview.png
  • NVMEM user (user space)
The user can use the NVMEM sysfs interface, from a user terminal or a custom application, to read/write data from/to NVMEM device(s) from user space.
  • NVMEM user (kernel space)
User drivers can use the NVMEM API to read/write data from/to NVMEM device(s) from kernel space (such as the analog calibration data used by an ADC driver).
  • NVMEM framework (kernel space)
  • NVMEM drivers (kernel space)
Provider drivers such as BSEC Linux® driver that exposes OTP data to the core.
  • TEE framework (kernel space)
Provider drivers such as OP-TEE Linux® driver that exposes secure service to the core, as OP-TEE OTP interface.
  • NVMEM hardware
NVMEM controller(s) such as the BSEC internal peripheral[1]
The NVMEM kernel documentation[2] describes:
  • Kernel space API for NVMEM providers and NVMEM consumers.
  • Userspace binary interface (sysfs).
See also sysfs-bus-nvmem[3] ABI documentation.
Activate NVMEM framework in the kernel configuration through the Linux® menuconfig tool, Menuconfig or how to configure kernel (CONFIG_NVMEM=y):
Device Drivers  --->
   [*] NVMEM Support  --->
      <*>   STMicroelectronics STM32 factory-programmed memory support
The NVMEM data device tree bindings describe:
  • The location of non-volatile memory data
  • The NVMEM data providers[4]
  • The NVMEM data consumers[5]
The BSEC internal peripheral[1] device tree bindings are explained in BSEC device tree configuration article.
4.1. How to use NVMEM with sysfs interface[edit source]
4.1.1. How to list NVMEM devices[edit source]
The available NVMEM devices can be listed in sysfs directory /sys/bus/nvmem/devices
Example to list nvmem devices: BSEC is stm32-romem0
 ls /sys/bus/nvmem/devices/
stm32-romem0
4.1.2. How to read OTPs using NVMEM[edit source]
Userspace can read/write the raw NVMEM file located at: /sys/bus/nvmem/devices/*/nvmem
For BSEC, the NVEM stm32-romem0 device, the content of non-secure OTPs can be read but the secured OTPs are masked, theirs values are replaced by 0.
Normally only the 32 lower OTPs can be accessed and the upper OTPS is restricted to security. If user needs more than the 32 lower OTPs, there is an exception management explained in BSEC device tree configuration.
  • Example to read all nvmem data content on stm32-romem0 devices
 dd if=/sys/bus/nvmem/devices/stm32-romem0/nvmem of=/tmp/file
  • Example to display nvmem data content
 hexdump -C -v /sys/bus/nvmem/devices/stm32-romem0/nvmem
A dedicated page describe the OTP mapping for STM32MP13 and STM32MP15.
4.1.3. How to write BSEC OTPs using NVMEM[edit source]
In OpenSTLinux it is not possible to write data to the NVMEM BSEC device with Linux driver; BSEC is defined as a read only NVMEM device.
OTP can be updated by using STM32CubeProgrammer.
 cd /sys/kernel/debug/tracing
 cat available_filter_functions | grep nvmem             # Show available filter functions
rtc_nvmem_register
rtc_nvmem_unregister
nvmem_reg_read
bin_attr_nvmem_read
 echo function > current_tracer
 echo "*nvmem*" > set_ftrace_filter                      # Trace all nvmem filter functions
 echo 1 > tracing_on                                     # start ftrace
 hexdump -C -v /sys/bus/nvmem/devices/stm32-romem0/nvmem # dump nvmem
00000000  17 00 00 00 01 80 00 00  00 00 00 00 00 00 00 00  |................|
 echo 0 > tracing_on                                     # stop ftrace
 cat trace
# tracer: function
#                              _-----=> irqs-off
#                             / _----=> need-resched
#                            | / _---=> hardirq/softirq
#                            || / _--=> preempt-depth
#                            ||| /     delay
#           TASK-PID   CPU#  ||||    TIMESTAMP  FUNCTION
         hexdump-478   [000] ....   423.502278: bin_attr_nvmem_read <-sysfs_kf_bin_read
         hexdump-478   [000] ....   423.502290: nvmem_reg_read <-bin_attr_nvmem_read
         hexdump-478   [000] ....   423.515804: bin_attr_nvmem_read <-sysfs_kf_bin_read
