GTK demo launcher
Revision as of 20:31, 29 November 2021 by Registered User (→‎Video playback)
1. Main menu[edit source]
1.1. For STM32MP13x lines More info.png[edit source]
The main menu is composed of three demonstrations:
Main menu
1.2. For STM32MP15x lines More info.png[edit source]
Main menu
  • On STM32MP157C-DK2 Warning.png boards, a USB webcam can be used.
  • On STM32MP157C-EV1 Warning.png and STM32MP135x-DK More info green.png boards, either a MB1379 camera daughter board or a USB webcam can be used.
Video Playback
Artificial Intelligence
  • A: launches audio playback
  • C: launches camera preview
  • P: displays a picture
It is possible to start several instances of the same application (for example three audio playbacks at the same time). However this is not recommended.
6. 3D GPU[edit source]
3D GPU
Bluetooth speaker
First use:
8. Info menu[edit source]
  • must manage the QUIT/EXIT.
 /usr/local/demo/application/
 ├── 02-video.yaml
 └── video
     ├── bin
     │   └── launch_video.sh
     └── pictures
The touch-event-gtk-player application is available to use gstreamer graph for camera preview or video playback. It allows playing a gstreamer graph, managing play/pause event via a simple click/touch and quitting/exiting playback via double click/touch.
/usr/local/demo/bin/touch-event-gtk-player --graph "<gstreamer graph>"
 Application:
    Name: <name of application>
    Icon: <icon of application>
    Type: <script|python>
    Board:
    Script:
        Exist:
    Python:
        Exist:
    Action:
Description of parameters:
Name
Description
Icon
Board
Type
Available types:
Script
Exist
Example
        Exist:
            File: /dev/video0
                    /dev/video0 doesn't exist
Python
Example
Exist
Example
        Exist:
            Command: hciconfig hci0 up
9.2. File tree[edit source]
 ├── 000-netdata.yaml
 ├── 010-camera.yaml
 ├── 020-video.yaml
 ├── 030-3d_cube.yaml
 ├── 040-m4_ai.yaml
 ├── 3d_cube
 │   ├── bin
 │   │   └── launch_cube_3D.sh
 │   └── pictures
 ├── bluetooth
 │   ├── bluetooth_audio.py
 │   ├── __init__.py
 │   ├── pictures
 │   └── wrap_blctl.py
 ├── camera
 │   ├── bin
 │   ├── pictures
 │   └── shaders
 ├── __init__.py
 ├── m4_ai
 │   ├── bin
 │   │   └── launch_AI.sh
 │   └── pictures
 ├── netdata
 │   ├── bin
 │   │   └── build_qrcode.sh
 │   ├── __init__.py
 │   ├── netdata.py
 │   └── pictures
 └── video
     ├── bin
     └── pictures
Application:
    Description: GPU with picture
    Board:
        NotList: stm32mp151
    Type: script
    Script:
        Exist:
            File: /dev/galcore
    Action:
Application:
    Description: shader
    Board:
        List: all
    Type: script
    Script:
        Exist:
            File: /dev/video0
    Action:
Application:
    Description: speaker
    Type: Python
    Board:
        List: stm32mp157 stm32mp153
    Python:
        Exist:
    Action:
chmod 0755 <script name>
├── 100-3d-cube.yaml
├── 101-3d-cube-shader.yaml
├── 110-3d-cube-video.yaml
├── 115-3d_cube_camera.yaml
└── 3d-cube-extra
    ├── bin
    └── pictures
  • Associated recipe:
HOMEPAGE = "wiki.st.com"
LICENSE = "BSD-3-Clause"
SRC_URI = " \
    file://100-3d-cube.yaml \
do_configure[noexec] = "1"
do_compile[noexec] = "1"
do_install() {
    # install yaml file
    # install bin
    # install pictures
 dpkg -l | grep demo-launcher
apt-get update
apt-get install demo-launcher
To add 3D application:
10. References[edit source]
