1. OTP partition[edit source]
The OTP partition is identified by the reserved Id 0xF2 and is exported as a specific alternate setting of the USB DFU [1].
This is used to access the STM32MP's on-chip one time programmable memory, and is only supported in U-Boot.
The OTP partition must be programmed without a header and must have a fixed size of 1024 bytes = 256 words (32 bits), following the structure described in chapter #Data Structure.
For read operation, the host requests the OTP partition data, and the platform replies with all the partition content (1024 bytes).
1.1. Data structure[edit source]
1.1.1. Version 1[edit source]
The data structure for the STM32MP15x Series based on TF-A SMC is described in the table below.
Access can be RWS = Read / Write / Sticky
Word | Field name | Description | RWS |
0 | Version | Version of this structure = 1 | R |
1 | Configuration |
RW |
2 | Reserved | ||
3 | Status |
R |
4 | General Lock conf |
RWS |
5 | Debug conf |
RW |
6 | Reserved | ||
7 | Reserved | ||
8 | Disturbed status 1 |
R |
9 | Disturbed status 2 |
R |
10 | Disturbed status 3 |
R |
11 | Reserved | ||
12 | Reserved | ||
13 | Reserved | ||
14 | Error status 1 |
R |
15 | Error status 2 |
R |
16 | Error status 3 |
R |
17 | Reserved | ||
18 | Reserved | ||
19 | Reserved | ||
20 | Permanent lock 1 |
RWS |
21 | Permanent lock 2 |
RWS |
22 | Permanent lock 3 |
RWS |
23 | Reserved | ||
24 | Reserved | ||
25 | Reserved | ||
26 | Programming lock 1 |
RWS |
27 | Programming lock 2 |
RWS |
28 | Programming lock 3 |
RWS |
29 | Reserved | ||
30 | Reserved | ||
31 | Reserved | ||
32 | Shadow write lock 1 |
RWS |
33 | Shadow write lock 2 |
RWS |
34 | Shadow write lock 3 |
RWS |
35 | Reserved | ||
36 | Reserved | ||
37 | Reserved | ||
38 | Shadow read lock 1 |
RWS |
39 | Shadow read lock 2 |
RWS |
40 | Shadow read lock 3 |
RWS |
41 | Reserved | ||
42 | Reserved | ||
43 | Reserved | ||
44 | OTP 0 | Value of OTP 0 | RW |
45 | OTP 1 | Value of OTP 1 | RW |
... | OTP ... | Value of OTP ... | RW |
139 | OTP95 | Value of OTP 95 | RW |
140 | Reserved | ||
... | Reserved | ||
251 | Reserved | ||
252 | Configuration register |
R |
253 | IP version |
R |
254 | IP ID | R | |
255 | IP_Magic_ID | R |
1.1.2. Version 2[edit source]
The data structure version 2 for the OP-TEE provisioning TA is described in the table below and with 96 OPT for STM32MP15x and for STM32MP13x its size is (2 * 96 + 2) * 4 = 776 bytes.
0 | Version | Version of this structure = 2 for OP-TEE TA |
1 | Global State | bitfield with state of BSEC the OTP provider
2 | OTP[0] | OTP value
3 | OPT[0] status | Status of OTP:
4 | OTP[1] | OTP value |
5 | OPT[2] status | Status of OTP |
2+M*2 | OTP[M] | Value of OTP M |
3+M*2 | OTP[M] status | Status of OTP M |
You can write OTP without other opration than write in the alternate a buffer initialized with 0x0.
If you read a current value of OTP, you can write this buffer without modify the OTPS as bit 31 of status = 0.
To update a OTP you just need to write a buffer and for the modified OTP: - the OTP value (0x0 if unmodified) - the OTP status lock values for prog lock and/or read lock (0x0 if unmodified) - request the update: set the bit 31 of the OTP staus to indicated a modified OTP
NB: Global state is not used during a write operation.
1.1.2.1. Example[edit source]
1.1.2.1.1. write X in OTP_N[edit source]
OTP[N] value = X OPT[N] status = 0x80000000
1.1.2.1.2. prog lock OTP N[edit source]
OTP[N] value = 0x0 OPT[N] status = 0xC0000000
1.1.2.1.3. write and lock OTP N[edit source]
OTP[N] value = X OPT[N] status = 0xC0000000
1.1.2.1.4. write value and read+prog lock for OTP N to N+2[edit source]
OTP[N] value = X OPT[N] status = 0xE0000000
OTP[N + 1] value = Y OPT[N + 1] status = 0xE0000000
OTP[N + 2] value = Z OPT[N + 2] status = 0xE0000000
1.2. Reference list[edit source]
