DAC device tree configuration
Revision as of 10:05, 25 January 2021 by Registered User
1. Purpose[edit source]
The purpose of this article is to explain how to configure the digital-to-analog converter (DAC)[1] when the peripheral is assigned to Linux® OS, and in particular:
  • how to configure and enable the DAC peripheral
  • how to configure the board, the DAC channels, reference voltage regulator and pins.
It is used by the DAC Linux driver that registers relevant information in IIO framework, such as IIO devices, channels and voltage scale.
STM32 DAC device tree bindings[3] deal with all the required or optional properties.
This hardware description is a combination of STM32 and board device tree files. See Device tree for explanations on device tree file split.
The DAC nodes are declared in stm32mp151.dtsi[4]:
  • DT root node ('dac') describes the DAC hardware block parameters such as registers area and clocks.
  • DT child nodes ('dac1' and 'dac2') describe DAC channels independently.
dac: dac@address {
	compatible = "st,stm32h7-dac-core";
	...        /* common resources in 'dac' root node. */
	dac1: dac@1 {
		compatible = "st,stm32-dac";
		reg = <1>;                                                             /* DAC identifier (e.g. 1 for DAC1) */
		...        /* private resources in 'dac1' child node. */
	dac2: dac@2 {
		reg = <2>;                                                             /* DAC identifier (e.g. 2 for DAC2) */
		...        /* private resources in 'dac2' child node. */
This device tree part is related to STM32 microprocessors. It should be kept as is, without being modified by the end-user.
Follow the below sequence to configure and enable the DAC on your board:
  • Enable DT root node named 'dac' by setting status = "okay".
  • Configure pins in use via pinctrl through pinctrl-0 and pinctrl-names.
  • Configure analog reference voltage regulator[5] by setting vref-supply = <&your_regulator>.
  • Enable DT child node(s) for 'dac1' and/or 'dac2' channels(s) in use by setting status = "okay".
The DAC can use the internal VREFBUF[6] or any other external regulator[5] wired to the VREF+ pin
The example below shows how to configure DAC1 and DAC2 channels:
dac_ch1_pins_a: dac-ch1 {
	pins {
		pinmux = <STM32_PINMUX('A', 4, ANALOG)>;                 /* configure 'PA4' as ANALOG */
dac_ch2_pins_a: dac-ch2 {
	pins {
		pinmux = <STM32_PINMUX('A', 5, ANALOG)>;                 /* configure 'PA5' as ANALOG */
&dac {
	pinctrl-names = "default";
	pinctrl-0 = <&dac_ch1_pins_a &dac_ch2_pins_a>;                   /* Use PA4 and PA5 pin as ANALOG */
	vref-supply = <&vrefbuf>;                                        /* Example to use VREFBUF (It needs to be enabled as well) */
	status = "okay";                                                 /* Enable the DAC block */
	dac1: dac@1 {
		status = "okay";                                         /* Enable DAC1 */
	dac2: dac@2 {
		status = "okay";                                         /* Enable DAC2 */
