Ifconfig
Revision as of 09:44, 31 July 2019 by Registered User
This article provides the basic information needed to start using the Linux® kernel tool: ifconfig[1].
2. Introduction[edit source]
STM32MPU Embedded Software distribution for Android™ is no more supported by ST. You can contact our ST partner, Witekio, who can help you to port and maintain it on STM32MP15 platform.
ifconfig Monitoring tools ifconfig[1] is a system administration utility for network interface configuration.
ifconfig is deprecated and has been replaced by ip.
A web page provides a comparison between ifconfig and ip [2]
Yes Yes Yes Yes Yes Yes
ifconfig is installed by default and ready to be used with all STM32MPU Embedded Software Packages.
It comes with the busybox:
 which ifconfig | xargs ls -la
/sbin/ifconfig -> /bin/busybox.nosuid
Perfetto is installed by default and ready to be used with all STM32MPU Embedded Software Packages.
It comes with the toybox:
/system/bin/ifconfig -> toybox
Follow the sequence described below to get started with the ifconfig tool.
Android logo.png Below information is related to the Android™ distribution
Need to enable root access rights for any changes
  • Using ADB shell is ADB link available:
 adb root
 adb shell
  • Using uart console shell:
 su
4.1. List the available network interfaces[edit source]
 ifconfig
eth0      Link encap:Ethernet  HWaddr 00:80:E1:42:43:65
          inet addr:10.48.1.144  Bcast:10.48.3.255  Mask:255.255.252.0
          inet6 addr: fe80::280:e1ff:fe42:4365%lo/64 Scope:Link
          RX packets:181274 errors:0 dropped:14553 overruns:0 frame:0
          TX packets:28583 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:23082127 (22.0 MiB)  TX bytes:6438412 (6.1 MiB)
          Interrupt:66 Base address:0x4000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1%1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:202 errors:0 dropped:0 overruns:0 frame:0
          TX packets:202 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:13454 (13.1 KiB)  TX bytes:13454 (13.1 KiB)
4.2. Disable the network interface[edit source]
Please make sure that no remote terminal is connected through this network (ssh), otherwise you will lost your shell connection.
  • For example, proceed as follows for eth0
 ifconfig eth0 down
4.3. Enable the network interface if it is not already available[edit source]
 ifconfig eth0 up
4.4. Assign a given IP address to a network interface[edit source]
  • Proceed as follows to assign 10.48.1.324 address to eth0
 ifconfig eth0 10.48.1.324
5. To go further[edit source]
Refer to the man page[1] for more details on command options.
