BSEC internal peripheral
  • briefly introduce the BSEC peripheral and its main features
  • explain, when necessary, how to configure the BSEC peripheral.
The BSEC peripheral is used to control an OTP (one time programmable) fuse box, used for on-chip non-volatile storage for device configuration and security parameters.
2.1. Features[edit source]
The BSEC is a secure peripheral.
3.1. Boot time[edit source]
The BSEC is configured at boot time to set up platform security.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
The BSEC instance is a system peripheral and is controlled by the Arm® Cortex®-A7 secure.
Note that some BSEC features like lower OTP access can be made available to the Arm® Cortex®-A7 non-secure, via secure monitor calls (managed by TF-A or by OP-TEE).
| Security
| BSEC
| OP-TEE BSEC driver
| Linux NVMEM framework
The configuration is based on Device tree, please refer to BSEC device tree configuration article.
It can be applied by the firmware running in a secure context, done in TF-A or in OP-TEE.
It can also be configured by Linux® kernel, please refer to NVMEM overview article.
| rowspan="1" | Security
| rowspan="1" | BSEC
| BSEC
