BSEC internal peripheral
Revision as of 15:20, 20 December 2018 by deleted>Frq08988
  • briefly introduce the BSEC peripheral and its main features
  • explain, when necessary, how to configure the BSEC peripheral.
The BSEC peripheral is used to control an OTP (one time programmable) fuse box, used for on-chip non-volatile storage for device configuration and security parameters.
2.1. Features[edit source]
The BSEC is a secure peripheral.
3.1. Boot time[edit source]
The BSEC is configured at boot time to set up platform security.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
The BSEC instance is a system peripheral and is controlled by the Arm® Cortex®-A7 secure.
| Security
| BSEC
| OP-TEE BSEC driver
| Linux NVMEM framework
The configuration is applied by the firmware running in a secure context.
This configuration is done in TF-A or in OP-TEE.
| rowspan="1" | Security
| rowspan="1" | BSEC
| BSEC
