1. Thermostat
#include "zcl/general/zcl.therm.h"
Functions
ZbZclThermClientAlloc
struct ZbZclClusterT * ZbZclThermClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Scenes Client cluster
Parameters
| zb | Zigbee stack instance |
| endpoint | Endpoint on which to create cluster |
Return
- Cluster pointer, or NULL if there is an error
ZbZclThermClientClearWeeklySched
enum ZclStatusCodeT ZbZclThermClientClearWeeklySched(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Clear Weekly Schedule command (Optional)
Parameters
| cluster | Cluster instance from which to send this command |
| dst | Destination address for request |
| callback | Callback function that will be called when the response for this request is received |
| arg | Pointer to application data that will included in the callback when invoked. |
Return
- ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error
ZbZclThermClientGetRelayStatusLog
enum ZclStatusCodeT ZbZclThermClientGetRelayStatusLog(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Relay Status Log command (Optional)
Parameters
Return
ZbZclThermClientGetWeeklySched
enum ZclStatusCodeT ZbZclThermClientGetWeeklySched(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclThermCliGetWeeklyT *req, void (*callback)(struct ZbZclCommandRspT
- rsp, void *arg), void *arg);
Send a Get Weekly Schedule command (Optional)
Parameters
| req | Thermostat Get Weekly Schedule info |
Return
ZbZclThermClientSetWeeklySched
enum ZclStatusCodeT ZbZclThermClientSetWeeklySched(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclThermWeeklySchedT *req, void (*callback)(struct ZbZclCommandRspT
Send a Set Weekly Schedule command (Optional)
Parameters
| req | Thermostat Weekly Schedule structure |
Return
ZbZclThermClientSetpointRaiseLower
enum ZclStatusCodeT ZbZclThermClientSetpointRaiseLower(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclThermCliSetpointT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Setpoint Raise/Lower command
Parameters
| req | Thermostat Setpoint structure |
Return
ZbZclThermServerAlloc
struct ZbZclClusterT * ZbZclThermServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclThermServerCallbacksT *callbacks, void *arg);
Create a new instance of the Thermostat Server cluster
Parameters
| callbacks | Structure containing callback function pointers for this cluster |
Return
ZbZclThermServerGetRelayStatusLogRsp
enum ZclStatusCodeT ZbZclThermServerGetRelayStatusLogRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclThermSvrGetRelayStatusLogRspT *rsp);
Send a Get Relay Status Log Response command
Parameters
| rsp | Get Relay Status Log Response structure |
Return
ZbZclThermServerGetWeeklySchedRsp
enum ZclStatusCodeT ZbZclThermServerGetWeeklySchedRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclThermWeeklySchedT *rsp);
Send a Get Weekly Schedule Response command
Parameters
| rsp | Server Clear Get Weekly Schedule response |
Return
Enumerations
ZbZclThermAttrT
Thermostat Attribute IDs
| ZCL_THERM_SVR_ATTR_LOCAL_TEMP | LocalTemperature |
| ZCL_THERM_SVR_ATTR_OUTDOOR_TEMP | OutdoorTemperature (Optional) |
| ZCL_THERM_SVR_ATTR_OCCUPANCY | Occupancy (Optional) |
| ZCL_THERM_SVR_ATTR_ABS_MIN_HEAT_SETPOINT_LIMIT | AbsMinHeatSetpointLimit (Optional) |
| ZCL_THERM_SVR_ATTR_ABS_MAX_HEAT_SETPOINT_LIMI T | AbsMaxHeatSetpointLimit (Optional) |
| ZCL_THERM_SVR_ATTR_ABS_MIN_COOL_SETPOINT_LIMI T | AbsMinCoolSetpointLimit (Optional) |
| ZCL_THERM_SVR_ATTR_ABS_MAX_COOL_SETPOINT_LIMI T | AbsMaxCoolSetpointLimit (Optional) |
| ZCL_THERM_SVR_ATTR_PI_COOLING_DEMAND | PICoolingDemand (Optional) |
| ZCL_THERM_SVR_ATTR_PI_HEATING_DEMAND | PIHeatingDemand (Optional) |
| ZCL_THERM_SVR_ATTR_HVAC_SYSTYPE_CONFIG | HVACSystemTypeConfiguration (Optional) |
| ZCL_THERM_SVR_ATTR_LOCAL_TEMP_CALIB | LocalTemperatureCalibration (Optional) |
| ZCL_THERM_SVR_ATTR_OCCUP_COOL_SETPOINT | OccupiedCoolingSetpoint |
| ZCL_THERM_SVR_ATTR_OCCUP_HEAT_SETPOINT | OccupiedHeatingSetpoint |
| ZCL_THERM_SVR_ATTR_UNOCCUP_COOL_SETPOINT | UnoccupiedCoolingSetpoint (Optional) |
| ZCL_THERM_SVR_ATTR_UNOCCUP_HEAT_SETPOINT | UnoccupiedHeatingSetpoint (Optional) |
| ZCL_THERM_SVR_ATTR_MIN_HEAT_SETPOINT | MinHeatSetpointLimit (Optional) |
| ZCL_THERM_SVR_ATTR_MAX_HEAT_SETPOINT | MaxHeatSetpointLimit (Optional) |
| ZCL_THERM_SVR_ATTR_MIN_COOL_SETPOINT | MinCoolSetpointLimit (Optional) |
| ZCL_THERM_SVR_ATTR_MAX_COOL_SETPOINT | MaxCoolSetpointLimit (Optional) |
| ZCL_THERM_SVR_ATTR_MIN_SETPOINT_DEADBAND | MinSetpointDeadBand (Optional) |
| ZCL_THERM_SVR_ATTR_RMT_SENSE | RemoteSensing (Optional) |
| ZCL_THERM_SVR_ATTR_CONTROL_SEQ_OPER | ControlSequenceOfOperation |
| ZCL_THERM_SVR_ATTR_SYSTEM_MODE | SystemMode |
| ZCL_THERM_SVR_ATTR_ALARM_MASK | AlarmMask (Optional) |
| ZCL_THERM_SVR_ATTR_RUNNING_MODE | ThermostatRunningMode (Optional) |
| ZCL_THERM_SVR_ATTR_START_OF_WEEK | StartOfWeek (Optional) |
| ZCL_THERM_SVR_ATTR_NUM_WEEKLY_TRANSITIONS | NumberOfWeeklyTransitions (Optional) |
| ZCL_THERM_SVR_ATTR_NUM_DAILY_TRANSITIONS | NumberOfDailyTransitions (Optional) |
| ZCL_THERM_SVR_ATTR_TEMP_SETPOINT_HOLD | TemperatureSetpointHold (Optional) |
| ZCL_THERM_SVR_ATTR_TEMP_SETPOINT_HOLD_DUR | TemperatureSetpointHoldDuration (Optional) |
| ZCL_THERM_SVR_ATTR_PROG_OPER_MODE | ThermostatProgrammingOperationMode (Optional) |
| ZCL_THERM_SVR_ATTR_RUNNING_STATE | ThermostatRunningState (Optional) |
| ZCL_THERM_SVR_ATTR_SETPOINT_CHANGE_SRC | SetpointChangeSource |
| ZCL_THERM_SVR_ATTR_SETPOINT_CHANGE_AMT | SetpointChangeAmount |
| ZCL_THERM_SVR_ATTR_SETPOINT_CHANGE_TIMESTAMP | SetpointChangeSourceTimestamp |
| ZCL_THERM_SVR_ATTR_OCCUP_SETBACK | OccupiedSetback (Optional) |
| ZCL_THERM_SVR_ATTR_OCCUP_SETBACK_MIN | OccupiedSetbackMin (Optional) |
| ZCL_THERM_SVR_ATTR_OCCUP_SETBACK_MAX | OccupiedSetbackMax (Optional) |
| ZCL_THERM_SVR_ATTR_UNOCCUP_SETBACK | UnoccupiedSetback (Optional) |
| ZCL_THERM_SVR_ATTR_UNOCCUP_SETBACK_MIN | UnoccupiedSetbackMin (Optional) |
| ZCL_THERM_SVR_ATTR_UNOCCUP_SETBACK_MAX | UnoccupiedSetbackMax (Optional) |
| ZCL_THERM_SVR_ATTR_EMERGENCY_HEAT_DELTA | EmergencyHeatDelta (Optional) |
| ZCL_THERM_SVR_ATTR_AC_TYPE | ACType |
| ZCL_THERM_SVR_ATTR_AC_CAPACITY | ACCapacity |
| ZCL_THERM_SVR_ATTR_AC_REFIGERANT_TYPE | ACRefrigerantType |
| ZCL_THERM_SVR_ATTR_AC_COMPRESSOR_TYPE | ACCompressorType |
| ZCL_THERM_SVR_ATTR_AC_ERROR_CODE | ACErrorCode |
| ZCL_THERM_SVR_ATTR_AC_LOUVER_POSITION | ACLouverPosition |
| ZCL_THERM_SVR_ATTR_AC_COIL_TEMP | ACCoilTemperature |
| ZCL_THERM_SVR_ATTR_AC_CAPACITY_FORMAT | ACCapacityFormat |
Structures
Thermostat Get Weekly Schedule structure
Parameters
| uint8_t days_to_return | Days to Return |
| uint8_t mode_to_return | Mode to Return |
Parameters
| uint8_t mode | Mode |
| int8_t amount | Amount |
Thermostat Server callbacks configuration
Parameters
| setpoint_raise_lower
(callback function pointer) |
enum ZclStatusCodeT (*setpoint_raise_lower)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclThermCliSetpointT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to handle Setpoint Raise/Lower command response |
| set_weekly
enum ZclStatusCodeT (*set_weekly)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclThermWeeklySchedT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to handle Set Weekly Schedule command response |
| get_weekly
enum ZclStatusCodeT (*get_weekly)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclThermCliGetWeeklyT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to handle Get Weekly Schedule command response |
| clear_weekly
enum ZclStatusCodeT (*clear_weekly)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to handle Clear Weekly Schedule command response |
| get_relay_status_log
enum ZclStatusCodeT (*get_relay_status_log)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to handle Get Relay Status Log command response |
Parameters
| uint16_t time_of_day | Time of Day |
| uint16_t relay_status | Relay Status |
| int16_t local_temp | Local Temperature |
| uint8_t humidity_percent | Humidity in Percentage |
| int16_t set_point | Unread Entries |
ZbZclThermTransitionsT
Thermostat Transition structure
Parameters
| uint16_t transition_time | Transition Time |
| int16_t heat_set_point | Heat Set Point (optional) |
| int16_t cool_set_point | Cool Set Point (optional) |
Parameters
| uint8_t num_transitions | Number of Transitions for Sequence |
| uint8_t day_of_week_seq | Day of the Week for Sequence - e.g. ZCL_THERM_DAY_OF_WEEK_SUNDAY |
| uint8_t mode_for_seq | Mode for Sequence - e.g. ZCL_THERM_MODE_HEAT_SETPOINT_PRESENT |
| struct ZbZclThermTransitionsT
transitions |
List of transitions |
2. Thermostat User Interface
#include "zcl/general/zcl.therm.ui.h"
Functions
ZbZclThermUiClientAlloc
struct ZbZclClusterT * ZbZclThermUiClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Thermostat User Interface Client cluster
Parameters
Return
ZbZclThermUiServerAlloc
struct ZbZclClusterT * ZbZclThermUiServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Thermostat User Interface Server cluster
Parameters
Return
Enumerations
ZbZclThermUiServerAttrT
Thermostat User Interface Attribute IDs
| ZCL_THERM_UI_SVR_ATTR_DISPLAY_MODE | TemperatureDisplayMode |
| ZCL_THERM_UI_SVR_ATTR_KEYPAD_LOCKOUT | KeypadLockout |
| ZCL_THERM_UI_SVR_ATTR_SCHEDULE_PROG_VIS | ScheduleProgrammingVisibility (Optional) |
3. Time
#include "zcl/general/zcl.time.h"
Functions
ZbZclTimeClientAlloc
struct ZbZclClusterT * ZbZclTimeClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Time Client cluster
Parameters
Return
ZbZclTimeServerAlloc
struct ZbZclClusterT * ZbZclTimeServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclTimeServerCallbacks *callbacks, void *arg);
Create a new instance of the Time Server cluster
Parameters
| callbacks | Structure containing any callback function pointers for this cluster |
Return
ZbZclTimeServerCurrentTime
uint32_t ZbZclTimeServerCurrentTime(struct ZbZclClusterT *cluster);
Call the get_time callback defined as part of the Time Server callbacks configuration
Parameters
Return
- Current time in seconds since Zigbee Epoch: Jan 1st 2000
ZbZclTimeServerSetTime
void ZbZclTimeServerSetTime(struct ZbZclClusterT *cluster, uint32_t current_time);
Call the set_time callback defined as part of the Time Server callbacks configuration
Parameters
| current_time | New current time value to set |
Return
- Void
Enumerations
ZbZclTimeSvrAttrT
Time Server Attribute IDs
| ZCL_TIME_ATTR_TIME | Time |
| ZCL_TIME_ATTR_STATUS | TimeStatus |
| ZCL_TIME_ATTR_TIME_ZONE | TimeZone (Optional) |
| ZCL_TIME_ATTR_DST_START | DstStart (Optional) |
| ZCL_TIME_ATTR_DST_END | DstEnd (Optional) |
| ZCL_TIME_ATTR_DST_SHIFT | DstShift (Optional) |
| ZCL_TIME_ATTR_STANDARD_TIME | StandardTime (Optional) |
| ZCL_TIME_ATTR_LOCAL_TIME | LocalTime (Optional) |
| ZCL_TIME_ATTR_LAST_SET_TIME | LastSetTime (Optional) |
| ZCL_TIME_ATTR_VALID_UNTIL_TIME | ValidUntilTime (Optional) |
Structures
Parameters
| get_time
uint32_t (*get_time)(struct ZbZclClusterT *clusterPtr, void *arg)
Callback to application, invoked on receipt of Read Attribute request. Returns current time in seconds since Zigbee Epoch: Jan 1st 2000. |
| set_time
void (*set_time)(struct ZbZclClusterT *clusterPtr, uint32_t time_val, void *arg)
Callback to application, invoked on receipt of Write Attribute request for the ZCL_TIME_ATTR_TIME attribute. The set_time app callback should also set the ZCL_TIME_ATTR_LAST_SET_TIME attribute if successful. The time_val parameter is the current time in seconds since Zigbee Epoch: Jan 1st 2000. |
4. Voice Over Zigbee
#include "zcl/general/zcl.voice.h"
Functions
ZbZclVoiceClientAlloc
struct ZbZclClusterT * ZbZclVoiceClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct zcl_voice_client_callbacks_t *callbacks, void *arg);
Create a new instance of the Voice Over Zigbee Client cluster
Parameters
Return
ZbZclVoiceClientEstabReq
enum ZclStatusCodeT ZbZclVoiceClientEstabReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct voice_estab_req_t *estab_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Establishment Request command
Parameters
| estab_req | Establishment Request command request structure |
| callback | Callback function that will be invoked when the response is received. |
Return
ZbZclVoiceClientSendControlRsp
enum ZclStatusCodeT ZbZclVoiceClientSendControlRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst_info, struct voice_control_rsp_t *rsp);
Send an Control command
Parameters
| dst_info | Destination address for response, including sequence number and tx options |
| rsp | Control command response structure |
Return
ZbZclVoiceServerAlloc
struct ZbZclClusterT * ZbZclVoiceServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct zcl_voice_server_callbacks_t *callbacks, void *arg);
Create a new instance of the Voice Over Zigbee Server cluster
Parameters
Return
ZbZclVoiceServerControlReq
enum ZclStatusCodeT ZbZclVoiceServerControlReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct voice_control_t *control_cmd, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Control command
Parameters
| control_cmd | Control command request structure |
Return
ZbZclVoiceServerSendEstabRsp
enum ZclStatusCodeT ZbZclVoiceServerSendEstabRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst_info, struct voice_estab_rsp_t *rsp);
Send an Establishment Response command
Parameters
| rsp | Establishment Response command structure |
Return
ZbZclVoiceServerSendVoiceTxRsp
enum ZclStatusCodeT ZbZclVoiceServerSendVoiceTxRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct voice_voice_tx_rsp_t *rsp);
Send a Voice Transmission Response command. The application calls this if it ever encounters an error processing a Voice Transmission packet
Parameters
| rsp | Voice Transmission Response command structure |
Return
ZbZclVoiceTxCompletedReq
enum ZclStatusCodeT ZbZclVoiceTxCompletedReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback) (struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Voice Transmission Complete command
Parameters
Return
ZbZclVoiceVoiceTxReq
enum ZclStatusCodeT ZbZclVoiceVoiceTxReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct voice_voice_tx_t *voice_tx, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Voice Transmission command
Parameters
| voice_tx | Voice Transmission command request structure |
Return
Enumerations
ZbZclVoiceSvrAttrT
Voice Over Zigbee Server Attribute IDs
| ZCL_VOICE_ATTR_CODEC_TYPE | CodecType |
| ZCL_VOICE_ATTR_SAMP_FREQ | SamplingFrequency |
| ZCL_VOICE_ATTR_CODECRATE | Codecrate |
| ZCL_VOICE_ATTR_ESTAB_TIMEOUT | EstablishmentTimeout |
| ZCL_VOICE_ATTR_CODEC_TYPE_SUB_1 | CodecTypeSub1 (Optional) |
| ZCL_VOICE_ATTR_CODEC_TYPE_SUB_2 | CodecTypeSub2 (Optional) |
| ZCL_VOICE_ATTR_CODEC_TYPE_SUB_3 | CodecTypeSub3 (Optional) |
| ZCL_VOICE_ATTR_COMPRESSION_TYPE | CompressionType (Optional) |
| ZCL_VOICE_ATTR_COMPRESSION_RATE | CompressionRate (Optional) |
| ZCL_VOICE_ATTR_OPTION_FLAGS | OptionFlags (Optional) |
| ZCL_VOICE_ATTR_THRESHOLD | Threshold (Optional) |
Structures
voice_control_rsp_t
Control Response command structure
Parameters
| uint8_t ack_nak | ACK=0x01 NAK=0x00 |
voice_control_t
Control command structure
Parameters
| uint8_t control_type | Control Type |
voice_estab_req_t
Establishment Request command structure
Parameters
| uint8_t flag | Flag |
| uint8_t codec_type | Codec Type |
| uint8_t samp_freq | Samp. Freq. |
| uint8_t codec_rate | Codec Rate |
| uint8_t service_type | Service Type |
| uint8_t codec_type_s1 | Codec TypeS1 |
| uint8_t codec_type_s2 | Codec TypeS2 |
| uint8_t codec_type_s3 | Codec TypeS3 |
| uint8_t comp_type | Comp. Type |
| uint8_t comp_rate | Comp. Rate |
voice_estab_rsp_t
Parameters
| uint8_t codec_type | CodecType |
Parameters
| uint8_t error_flag | Error Flag - e.g. ZCL_VOICE_TX_RSP_ERROR_DECODE |
voice_voice_tx_t
Voice Transmission command structure
Parameters
| uint8_t *voice_data | Voice Data |
| uint16_t voice_data_len | Voice Data Length |
Voice Over Zigbee Client callbacks configuration
Parameters
| control
enum ZclStatusCodeT (*control)(struct ZbZclClusterT *clusterPtr, struct voice_control_t *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Control command |
Voice Over Zigbee Server callbacks configuration
Parameters
| estab_req
enum ZclStatusCodeT (*estab_req)(struct ZbZclClusterT *clusterPtr, struct voice_estab_req_t *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Establishment Request command |
| voice_tx
enum ZclStatusCodeT (*voice_tx)(struct ZbZclClusterT *clusterPtr, struct voice_voice_tx_t *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Voice Transmission command. The application should return ZCL_STATUS_SUCCESS or call ZbZclVoiceServerSendVoiceTxRsp to send an error response and return ZCL_STATUS_SUCCESS_NO_DEFAULT_RESPONSE |
| tx_complete
enum ZclStatusCodeT (*tx_complete)(struct ZbZclClusterT *clusterPtr, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Voice Transmission Completion command |
5. Water Content Measurement
#include "zcl/general/zcl.wcm.h"
Functions
ZbZclWaterContentMeasClientAlloc
struct ZbZclClusterT * ZbZclWaterContentMeasClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, enum ZbZclClusterIdT clusterID);
Create a new instance of the Water Content Measurement Client cluster
Parameters
| clusterID | Cluster identifier (Relative Humidity 0x0405, Leaf Wetness 0x0407 or Soil Moisture 0x0408) |
ZbZclWaterContentMeasServerAlloc
struct ZbZclClusterT * ZbZclWaterContentMeasServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, enum ZbZclClusterIdT clusterID, uint16_t min, uint16_t max);
Create a new instance of the Water Content Measurement Server cluster
Parameters
| min | Default minimum value |
| max | Default maximum value |
Return
Enumerations
ZbZclWcmSvrAttrT
Water Content Measurement Server Attribute IDs
| ZCL_WC_MEAS_ATTR_MEAS_VAL | MeasuredValue |
| ZCL_WC_MEAS_ATTR_MIN_MEAS_VAL | MinMeasuredValue |
| ZCL_WC_MEAS_ATTR_MAX_MEAS_VAL | MaxMeasuredValue |
| ZCL_WC_MEAS_ATTR_TOLERANCE | Tolerance (Optional) |
6. Window Covering
#include "zcl/general/zcl.window.h"
Functions
ZbZclWindowClientAlloc
struct ZbZclClusterT * ZbZclWindowClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Window Covering Client cluster
Parameters
ZbZclWindowClientCommandDown
enum ZclStatusCodeT ZbZclWindowClientCommandDown(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Down/Close command
Parameters
| dst | The destination address information |
Return
ZbZclWindowClientCommandStop
enum ZclStatusCodeT ZbZclWindowClientCommandStop(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Stop command
Parameters
Return
ZbZclWindowClientCommandUp
enum ZclStatusCodeT ZbZclWindowClientCommandUp(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send an Up/Open command
Parameters
Return
ZbZclWindowClosureServerMode
enum ZclStatusCodeT ZbZclWindowClosureServerMode(struct ZbZclClusterT *cluster, uint8_t mode);
Configure the Window Covering mode
Parameters
| mode | Window Covering mode bit mask |
Return
ZbZclWindowServerAlloc
struct ZbZclClusterT * ZbZclWindowServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclWindowServerCallbacksT *callbacks, void *arg);
Create a new instance of the Window Covering Server cluster
Parameters
Return
Enumerations
ZbZclWncvServerAttrT
Window Covering Server Attribute Ids
| ZCL_WNCV_SVR_ATTR_COVERING_TYPE | WindowCoveringType |
| ZCL_WNCV_SVR_ATTR_PHY_CLOSE_LIMIT_LIFT | PhysicalClosedLimitLift (Optional) |
| ZCL_WNCV_SVR_ATTR_PHY_CLOSE_LIMIT_TILT | PhysicalClosedLimitTilt (Optional) |
| ZCL_WNCV_SVR_ATTR_CURR_POSITION_LIFT | CurrentPositionLift (Optional) |
| ZCL_WNCV_SVR_ATTR_CURR_POSITION_TILT | CurrentPositionTilt (Optional) |
| ZCL_WNCV_SVR_ATTR_ACTUATION_NUMBER_LIFT | NumberOfActuationsLift (Optional) |
| ZCL_WNCV_SVR_ATTR_ACCUATION_NUMBER_TILT | NumberOfActuationsTilt (Optional) |
| ZCL_WNCV_SVR_ATTR_CONFIG_STATUS | ConfigStatus |
| ZCL_WNCV_SVR_ATTR_CURR_POS_LIFT_PERCENT | CurrentPositionLiftPercentage |
| ZCL_WNCV_SVR_ATTR_CURR_POS_TILT_PERCENT | CurrentPositionTiltPercentage |
| ZCL_WNCV_SVR_ATTR_INSTALLED_OPENED_LIMIT_LIFT | InstalledOpenLimitLift |
| ZCL_WNCV_SVR_ATTR_INSTALLED_CLOSED_LIMIT_LIFT | InstalledClosedLimitLift |
| ZCL_WNCV_SVR_ATTR_INSTALLED_OPENED_LIMIT_TILT | InstalledOpenLimitTilt |
| ZCL_WNCV_SVR_ATTR_INSTALLED_CLOSED_LIMIT_TILT | InstalledClosedLimitTilt |
| ZCL_WNCV_SVR_ATTR_VELOCITY_LIFT | VelocityLift (Optional) |
| ZCL_WNCV_SVR_ATTR_ACCELERATION_TIME_LIFT | AccelerationTimeLift (Optional) |
| ZCL_WNCV_SVR_ATTR_DECELERATION_TIME_LIFT | DecelerationTimeLift (Optional) |
| ZCL_WNCV_SVR_ATTR_MODE | Mode |
| ZCL_WNCV_SVR_ATTR_INTERMEDIATE_SETPOINTS_LIFT | Intermediate Setpoints - Lift (Optional) |
| ZCL_WNCV_SVR_ATTR_INTERMEDIATE_SETPOINTS_TILT | Intermediate Setpoints - Tilt (Optional) |
ZbZclWncvTypes
Window Covering Type enumerations
| ZCL_WNCV_TYPE_ROLLERSHADE | Rollershade |
| ZCL_WNCV_TYPE_ROLLERSHADE_2_MOTOR | Rollershade - 2 Motor |
| ZCL_WNCV_TYPE_ROLLERSHADE_EXTERIOR | Rollershade – Exterior |
| ZCL_WNCV_TYPE_ROLLERSHADE_EXTERIOR_2_MOTOR | Rollershade - Exterior - 2 Motor |
| ZCL_WNCV_TYPE_DRAPERY | Drapery |
| ZCL_WNCV_TYPE_AWNING | Awning |
| ZCL_WNCV_TYPE_SHUTTER | Shutter |
| ZCL_WNCV_TYPE_TILT_BLIND_TILT_ONLY | Tilt Blind - Tilt Only |
| ZCL_WNCV_TYPE_TILT_BLIND_LIFT_TILT | Tilt Blind - Lift and Tilt |
| ZCL_WNCV_TYPE_PROJECTOR_SCREEN | Projector Screen |
Structures
Window Covering Server callbacks configuration
Parameters
| up_command
enum ZclStatusCodeT (*up_command)(struct ZbZclClusterT *cluster, struct ZbZclHeaderT *zclHdrPtr, struct ZbApsdeDataIndT *dataIndPtr, void *arg)
Callback to application, invoked on receipt of Up/Open command. Application should update ZCL_WNCV_SVR_ATTR_CURR_POS_LIFT_PERCENT and ZCL_WNCV_SVR_ATTR_CURR_POS_TILT_PERCENT. |
| down_command
enum ZclStatusCodeT (*down_command)(struct ZbZclClusterT *cluster, struct ZbZclHeaderT *zclHdrPtr, struct ZbApsdeDataIndT *dataIndPtr, void *arg)
Callback to application, invoked on receipt of Down/Close command. Application should update ZCL_WNCV_SVR_ATTR_CURR_POS_LIFT_PERCENT and ZCL_WNCV_SVR_ATTR_CURR_POS_TILT_PERCENT. |
| stop_command
enum ZclStatusCodeT (*stop_command)(struct ZbZclClusterT *cluster, struct ZbZclHeaderT *zclHdrPtr, struct ZbApsdeDataIndT *dataIndPtr, void *arg)
Callback to application, invoked on receipt of Stop command. Application should update ZCL_WNCV_SVR_ATTR_CURR_POS_LIFT_PERCENT and ZCL_WNCV_SVR_ATTR_CURR_POS_TILT_PERCENT. |
| set_lift_and_tilt_command
enum ZclStatusCodeT (*set_lift_and_tilt_command)(struct ZbZclClusterT *cluster, void *arg, uint8_t liftPercentage, uint8_t tiltPercentage)
Callback to application, invoked to handle setting a Scene, which includes Lift and Tilt values. Application should update ZCL_WNCV_SVR_ATTR_CURR_POS_LIFT_PERCENT and ZCL_WNCV_SVR_ATTR_CURR_POS_TILT_PERCENT. |
7. IAS Security Clusters
7.1. IAS ACE
#include "zcl/security/zcl.ias_ace.h"
Functions
ZbZclIasAceClientAlloc
struct ZbZclClusterT * ZbZclIasAceClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, void *arg);
Allocate the IAS ACE Client cluster
Parameters
Return
ZbZclIasAceClientCommandArmReq
enum ZclStatusCodeT ZbZclIasAceClientCommandArmReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclIasAceClientCommandArmT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Arm command
Parameters
| cmd_req | Arm command request structure |
Return
ZbZclIasAceClientCommandBypassReq
enum ZclStatusCodeT ZbZclIasAceClientCommandBypassReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclIasAceClientCommandBypassT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Bypass command
Parameters
| cmd_req | Bypass command request structure |
Return
ZbZclIasAceClientCommandEmergencyReq
enum ZclStatusCodeT ZbZclIasAceClientCommandEmergencyReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Emergency command
Parameters
Return
ZbZclIasAceClientCommandFireReq
enum ZclStatusCodeT ZbZclIasAceClientCommandFireReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Fire command
Parameters
Return
ZbZclIasAceClientCommandGetBypassedZoneListReq
enum ZclStatusCodeT ZbZclIasAceClientCommandGetBypassedZoneListReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Bypassed Zone List command
Parameters
Return
ZbZclIasAceClientCommandGetPanelStatusReq
enum ZclStatusCodeT ZbZclIasAceClientCommandGetPanelStatusReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Panel Status changed request
Parameters
Return
ZbZclIasAceClientCommandGetZoneIdMapReq
enum ZclStatusCodeT ZbZclIasAceClientCommandGetZoneIdMapReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Zone ID Map command
Parameters
Return
ZbZclIasAceClientCommandGetZoneInfoReq
enum ZclStatusCodeT ZbZclIasAceClientCommandGetZoneInfoReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclIasAceClientCommandGetZoneInfoT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Zone Info command
Parameters
| cmd_req | Get Zone Info command request structure |
Return
ZbZclIasAceClientCommandGetZoneStatusReq
enum ZclStatusCodeT ZbZclIasAceClientCommandGetZoneStatusReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclIasAceClientCommandGetZoneStatusT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Zone Status command
Parameters
| cmd_req | Get Zone Status command request structure |
Return
ZbZclIasAceClientCommandPanicReq
enum ZclStatusCodeT ZbZclIasAceClientCommandPanicReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Panic command
Parameters
Return
ZbZclIasAceClientParseArmRsp
bool ZbZclIasAceClientParseArmRsp(const uint8_t *buf, unsigned int len, struct ZbZclIasAceServerCommandArmRspT *rsp);
Parse an Arm Response command payload into a data structure
Parameters
| buf | Response buffer |
| len | Length of response buffer |
| rsp | Arm response structure |
Return
- True on success, false otherwise
ZbZclIasAceClientParseBypassRsp
bool ZbZclIasAceClientParseBypassRsp(const uint8_t *buf, unsigned int len, struct ZbZclIasAceServerCommandBypassRspT *rsp);
Parse a Bypass Response command payload into a data structure
Parameters
| rsp | Bypass Response structure |
Return
ZbZclIasAceClientParseGetPanelStatusRsp
bool ZbZclIasAceClientParseGetPanelStatusRsp(const uint8_t *buf, unsigned int len, struct ZbZclIasAceServerCommandGetPanelStatusRspT *rsp);
Parse a Get Panel Status Response command payload into a data structure
Parameters
| rsp | Zone Status Changed Response structure |
Return
ZbZclIasAceClientParseGetZoneIdMapRsp
bool ZbZclIasAceClientParseGetZoneIdMapRsp(const uint8_t *buf, unsigned int len, struct ZbZclIasAceServerCommandGetZoneIdMapRspT *rsp);
Parse a Get Zone ID Map Response command payload into a data structure
Parameters
| rsp | Get Zone ID Map Response structure |
Return
ZbZclIasAceClientParseGetZoneInfoRsp
bool ZbZclIasAceClientParseGetZoneInfoRsp(const uint8_t *buf, unsigned int len, struct ZbZclIasAceServerCommandGetZoneInfoRspT *rsp);
Parse a Get Zone Info Response command payload into a data structure
Parameters
| rsp | Get Zone Info Response structure |
Return
ZbZclIasAceClientParseGetZoneStatusRsp
bool ZbZclIasAceClientParseGetZoneStatusRsp(const uint8_t *buf, unsigned int len, struct ZbZclIasAceServerCommandGetZoneStatusRspT *rsp);
Parse a Get Zone Status Response command payload into a data structure
Parameters
| rsp | Get Zone Status Response structure |
Return
ZbZclIasAceClientParseSetBypassedZoneList
bool ZbZclIasAceClientParseSetBypassedZoneList(const uint8_t *buf, unsigned int len, struct ZbZclIasAceServerCommandSetBypassedZoneListT *rsp);
Parse a Set Bypassed Zone List Response command payload into a data structure
Parameters
| rsp | Set Bypassed Zone List Response structure |
Return
ZbZclIasAceClientParseZoneStatusChanged
bool ZbZclIasAceClientParseZoneStatusChanged(const uint8_t *buf, unsigned int len, struct ZbZclIasAceServerCommandZoneStatusChangedT *rsp);
Parse a Zone Status Changed Response command payload into a data structure
Parameters
Return
ZbZclIasAceServerAlloc
struct ZbZclClusterT * ZbZclIasAceServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclIasAceServerCallbacksT *callbacks, void *arg);
Create a new instance of the IAS ACE Server cluster
If 'use_trip_pair' is true, application must call ZbZclIasAceServerEnrollRequest to perform the 'trip-to-pair' process, unless the IAS CIE has sent us an unsolicited Auto-Enroll-Response
Parameters
Return
ZbZclIasAceServerGetFreeZoneId
bool ZbZclIasAceServerGetFreeZoneId(struct ZbZclClusterT *cluster, uint8_t *zone_id_ptr);
Returns the first free Zone ID not already in the Zone Table
Parameters
| zone_id_ptr | Zone ID value |
Return
ZbZclIasAceServerPanelCodeConfig
bool ZbZclIasAceServerPanelCodeConfig(struct ZbZclClusterT *cluster, const char *arm_code);
Change the Panel Arm/Disarm Code
Parameters
| arm_code | Arm code |
Return
ZbZclIasAceServerPanelStatusConfig
bool ZbZclIasAceServerPanelStatusConfig(struct ZbZclClusterT *cluster, enum ZbZclIasAcePanelStatusT panel_status, uint8_t seconds_remain, enum ZbZclIasAceAudibleNotifyT audible_notify);
Update the Panel Status
Parameters
| panel_status | Panel Status enumeration |
| seconds_remain | Seconds remaining |
Return
ZbZclIasAceServerZoneBypassConfig
enum ZbZclIasAceBypassResultT ZbZclIasAceServerZoneBypassConfig(struct ZbZclClusterT *cluster, uint8_t zone_id, bool bypass);
Bypass zone if allowed
Parameters
| zone_id | Zone ID of zone in question |
| bypass | True if zone will be bypassed, false if not |
Return
- Result of bypass config command
ZbZclIasAceServerZoneBypassPerms
bool ZbZclIasAceServerZoneBypassPerms(struct ZbZclClusterT *cluster, uint8_t zone_id, enum ZbZclIasAceBypassPermsT bypass_perms);
Configure Bypass Permissions
Parameters
| bypass_perms | Desired bypass permissions |
Return
ZbZclIasAceServerZoneStatusConfig
bool ZbZclIasAceServerZoneStatusConfig(struct ZbZclClusterT *cluster, uint8_t zone_id, enum ZbZclIasZoneServerZoneStatusT zone_status, enum ZbZclIasAceAudibleNotifyT audible_notify);
Configure Zone Status
Parameters
| zone_status | Desired zone status |
| audible_notify | Determines if zone notification is audible or not |
Return
ZbZclIasAceServerZoneTableAdd
bool ZbZclIasAceServerZoneTableAdd(struct ZbZclClusterT *cluster, struct ZbZclIasAceServerZoneTableAddT *req);
Add new zone entry
Parameters
| req | Zone Table Add request structure |
Return
ZbZclIasAceServerZoneTableAddrLookup
uint64_t ZbZclIasAceServerZoneTableAddrLookup(struct ZbZclClusterT *cluster, uint8_t zone_id);
Returns address of paired zone, or 0 if not found
Parameters
| zone_id | ID of zone to be returned |
Return
- Address of zone if successful, 0 on error
ZbZclIasAceServerZoneTableDeleteByAddr
bool ZbZclIasAceServerZoneTableDeleteByAddr(struct ZbZclClusterT *cluster, uint64_t addr);
Delete a zone by address
Parameters
| addr | Address of zone to be deleted |
Return
ZbZclIasAceServerZoneTableDeleteById
bool ZbZclIasAceServerZoneTableDeleteById(struct ZbZclClusterT *cluster, uint8_t zone_id);
Delete a zone by zone ID
Parameters
| zone_id | ID of zone to be deleted |
Return
ZbZclIasAceServerZoneTableIdLookup
bool ZbZclIasAceServerZoneTableIdLookup(struct ZbZclClusterT *cluster, uint64_t zone_addr, uint8_t *zone_id_ptr);
Attempts to find a zone based on extended address, and returns the zone Id if found
Parameters
| zone_addr | Address of Zone being looked up |
| zone_id_ptr | If successful, points to zone ID that was looked up |
Return
Structures
Arm command structure
Parameters
| enum ZbZclIasAceArmModeT arm_mode | Arm Mode |
| char arm_code | Arm/Disarm Code |
| uint8_t zone_id | Zone ID |
Bypass command structure
Parameters
| uint8_t num_zones | Number of Zones |
| uint8_t zone_id_list | Zone ID List |
Get Zone Info command structure
Parameters
Get Zone Status command structure
Parameters
| uint8_t starting_zone_id | Starting Zone ID |
| uint8_t max_zone_ids | Max Number of Zone IDs |
| uint8_t zone_status_mask_flag | Zone Status Mask Flag |
| uint16_t zone_status_mask | Zone Status Mask |
IAS ACE Server callbacks configuration
Parameters
| arm_req
bool (*arm_req)(struct ZbZclClusterT *clusterPtr, void *arg, struct ZbZclIasAceClientCommandArmT *arm_req, struct ZbZclIasAceServerCommandArmRspT *arm_rsp)
Callback to application, invoked on receipt of Arm command |
| bypass_req
void (*bypass_req)(struct ZbZclClusterT *clusterPtr, void *arg, struct ZbZclIasAceClientCommandBypassT *bypass_req, struct ZbZclIasAceServerCommandBypassRspT *bypass_rsp)
Callback to application, invoked on receipt of Bypass command |
| emerg_req
enum ZclStatusCodeT (*emerg_req)(struct ZbZclClusterT *clusterPtr, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Emergency command |
| fire_req
enum ZclStatusCodeT (*fire_req)(struct ZbZclClusterT *clusterPtr, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Fire command |
| panic_req
enum ZclStatusCodeT (*panic_req)(struct ZbZclClusterT *clusterPtr, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Panic command |
Parameters
| enum ZbZclIasAceArmNotifyT arm_notify | Arm Notification |
Bypass Response response structure
Parameters
bypass_result_list |
Bypass Result for Zone ID List |
Get Panel Status response structure
Parameters
panel_status |
Panel Status |
| uint8_t seconds_remain | Seconds Remaining |
audible_notify |
Audible Notification |
| enum ZbZclIasAceAlarmStatusT
alarm_status |
Alarm Status |
Get Zone ID Map response structure
Parameters
| uint16_t zond_id_map_list | Zone ID Map List |
Get Zone Info response structure
Parameters
| enum ZbZclIasZoneServerZoneTypeT
zone_type |
Zone Type |
| uint64_t zone_addr | IEEE Address |
| char zone_label | Zone Label |
Get Zone Status response structure
Parameters
| uint8_t zone_status_complete | Zone Status Complete |
| struct { uint8_t zone_id | Zone ID |
zone_status |
Zone Status |
Set Bypassed Zone List command structure
Parameters
Zone Status Changed command structure
Parameters
zone_status |
Zone Status |
audible_notify |
Parameters
zone_type |
Zone Type |
| uint64_t zone_addr | Zone Address |
| const char *zone_label | Zone Label - May be NULL, Max length = ZCL_IAS_ACE_ZONE_LABEL_STRING_MAX_LEN |
| uint8_t zone_id | Zone ID - can use ZbZclIasAceServerGetFreeZoneId |
7.2. IAS WD
#include "zcl/security/zcl.ias_wd.h"
Functions
ZbZclIasWdClientAlloc
struct ZbZclClusterT * ZbZclIasWdClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, void *arg);
Create a new instance of the IAS Warning Device Client cluster
Parameters
Return
ZbZclIasWdServerAlloc
struct ZbZclClusterT * ZbZclIasWdServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclIasWdServerCallbacksT *callbacks, void *arg);
Create a new instance of the IAS Warning Device Server cluster
Parameters
Return
Enumerations
ZbZclIasWdLevelT
IAS Warning Device Siren Level Field Values
| ZCL_IAS_WD_LEVEL_LOW | Low level sound |
| ZCL_IAS_WD_LEVEL_MEDIUM | Medium level sound |
| ZCL_IAS_WD_LEVEL_HIGH | High level sound |
| ZCL_IAS_WD_LEVEL_VERY_HIGH | Very high level sound |
ZbZclIasWdSquawkModeT
IAS Warning Device Squawk Mode Field
| ZCL_IAS_WD_SQUAWK_MODE_ARMED | Notification sound for “System is armed” |
| ZCL_IAS_WD_SQUAWK_MODE_DISARMED | Notification sound for "System is disarmed" |
ZbZclIasWdStrobeT
IAS Warning Device Strobe Field
| ZCL_IAS_WD_STROBE_OFF | No strobe |
| ZCL_IAS_WD_STROBE_ON | Use strobe in parallel to warning |
ZbZclIasWdSvrAttrT
IAS Warning Device Server Attribute IDs
| ZCL_IAS_WD_SVR_ATTR_MAX_DURATION | MaxDuration |
ZbZclIasWdWarningModeT
IAS Warning Device Warning Modes
| ZCL_IAS_WD_WARNING_MODE_STOP | Stop (no warning) |
| ZCL_IAS_WD_WARNING_MODE_BURGLAR | Burglar |
| ZCL_IAS_WD_WARNING_MODE_FIRE | Fire |
| ZCL_IAS_WD_WARNING_MODE_EMERGENCY | Emergency |
| ZCL_IAS_WD_WARNING_MODE_POLICE_PANIC | Police panic |
| ZCL_IAS_WD_WARNING_MODE_FIRE_PANIC | Fire panic |
| ZCL_IAS_WD_WARNING_MODE_EMERGENCY_PANIC | Emergency Panic (i.e., medical issue) |
Structures
ZbZclIasWdClientSquawkReqT
IAS Warning Device Client Squawk command structure
Parameters
| enum ZbZclIasWdSquawkModeT
squawk_mode |
Squawk mode |
| enum ZbZclIasWdStrobeT strobe | Strobe |
| enum ZbZclIasWdLevelT squawk_level | Squawk level |
ZbZclIasWdClientStartWarningReqT
IAS Warning Device Client Start Warning command structure
Parameters
| enum ZbZclIasWdWarningModeT
warning_mode |
Warning Mode |
| enum ZbZclIasWdLevelT siren_level | Siren Level |
| uint16_t warning_duration | Warning Duration |
| uint8_t strobe_dutycycle | Strobe Duty Cycle |
| enum ZbZclIasWdLevelT strobe_level | Strobe Level |
IAS Warning Server callbacks configuration
Parameters
| start_warning
enum ZclStatusCodeT (*start_warning)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclIasWdClientStartWarningReqT *warn_req)
Callback to handle Start Warning command. ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error. |
| squawk
enum ZclStatusCodeT (*squawk)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclIasWdClientSquawkReqT *squawk_req)
Callback to handle Squawk command. ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error. |
7.3. IAS Zone
#include "zcl/security/zcl.ias_zone.h"
Functions
ZbZclIasZoneClientAlloc
struct ZbZclClusterT * ZbZclIasZoneClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclIasZoneClientCallbacksT *callbacks, void *arg);
Create a new instance of the IAS Zone Client cluster
Parameters
Return
ZbZclIasZoneClientInitiateAutoEnroll
enum ZclStatusCodeT ZbZclIasZoneClientInitiateAutoEnroll(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(const struct ZbZclWriteRspT *, void *), void *arg);
Send a Zone Auto-Enroll request command
Parameters
Return
ZbZclIasZoneClientInitiateNormalMode
enum ZclStatusCodeT ZbZclIasZoneClientInitiateNormalMode(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Initiate Normal Operation Mode request command
Parameters
Return
ZbZclIasZoneClientInitiateTestMode
enum ZclStatusCodeT ZbZclIasZoneClientInitiateTestMode(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclIasZoneClientTestModeReqT *req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Initiate Test Mode request command
Parameters
| req | Initiate Test Mode request structure |
Return
ZbZclIasZoneClientSendAutoEnrollResponse
enum ZclStatusCodeT ZbZclIasZoneClientSendAutoEnrollResponse(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, uint8_t zone_id, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Zone Auto-Enroll response command
Parameters
| zone_id | Zone ID |
Return
ZbZclIasZoneServerAlloc
struct ZbZclClusterT * ZbZclIasZoneServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, uint16_t zone_type, uint16_t manuf_code, bool use_trip_pair, struct ZbZclIasZoneServerCallbacksT *callbacks, void *arg);
Create a new instance of the IAS Zone Server cluster
Parameters
| zone_type | Zone Type |
| manuf_code | Manufacturer Code |
| use_trip_pair | If true, use 'trip-to-pair' application must call ZbZclIasZoneServerEnrollRequest to perform the 'trip-to-pair' process, unless the IAS CIE has sent us an unsolicited Auto-Enroll-Response |
Return
enum ZclStatusCodeT ZbZclIasZoneServerEnrollRequest(struct ZbZclClusterT *cluster, void (*callback)(struct ZbZclIasZoneClientEnrollResponseT *enrl_rsp, void *arg), void *arg);
Send a Zone Enroll request command Used with 'trip-to-pair'. Before sending a Zone Enroll Request, the IAS CIE must write to the IAS_CIE_Address attribute with its IEEE address.
Parameters
Return
Enumerations
ZbZclIasZoneClientResponseCodeT
IAS Zone Enroll Response Code
| ZCL_IAS_ZONE_CLI_RESP_SUCCESS | Success |
| ZCL_IAS_ZONE_CLI_RESP_NOT_SUPPORTED | Not supported |
| ZCL_IAS_ZONE_CLI_RESP_NO_ENROLL_PERMIT | No enroll permit |
| ZCL_IAS_ZONE_CLI_RESP_TOO_MANY_ZONES | Too many zones |
ZbZclIasZoneServerAttrT
IAS Zone Server Attribute IDs
| ZCL_IAS_ZONE_SVR_ATTR_ZONE_STATE | ZoneState |
| ZCL_IAS_ZONE_SVR_ATTR_ZONE_TYPE | ZoneType |
| ZCL_IAS_ZONE_SVR_ATTR_ZONE_STATUS | ZoneStatus |
| ZCL_IAS_ZONE_SVR_ATTR_CIE_ADDR | IAS_CIE_Address |
| ZCL_IAS_ZONE_SVR_ATTR_ZONE_ID | ZoneID |
| ZCL_IAS_ZONE_SVR_ATTR_NUM_ZONE_SENSITIVITY_SUP PORTED | NumberOfZoneSensitivityLevelsSupported (Optional) |
| ZCL_IAS_ZONE_SVR_ATTR_CURRENT_ZONE_SENSITIVITY_LEVEL | CurrentZoneSensitivityLevel (Optional) |
| ZCL_IAS_ZONE_SVR_ATTR_CIE_ENDPOINT | Exegin internal (Optional) |
ZbZclIasZoneServerModeT
IAS Zone ZoneStatus Attribute Bit Test Value
| ZCL_IAS_ZONE_SVR_MODE_NORMAL | Normal |
| ZCL_IAS_ZONE_SVR_MODE_TEST | Set |
ZbZclIasZoneServerZoneStateT
IAS Zone ZoneState Attribute
| ZCL_IAS_ZONE_SVR_STATE_NOT_ENROLLED | Not enrolled |
| ZCL_IAS_ZONE_SVR_STATE_ENROLLED | Enrolled (the client will react to Zone State Change Notification commands from the server) |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_NONE | Alarm1 |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_ALARM2 | Alarm2 |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_TAMPER | Tamper |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_BATTERY | Battery |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_SUPERVISION_REPO RTS | Supervision Notify |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_RESTORE_REPORTS | Restore Notify |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_TROUBLE | Trouble |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_AC_MAINS | AC (mains) |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_TEST | Test |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_BATTERY_DEFECT | Battery Defect |
IAS Zone ZoneType Attribute
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_STANDARD_CIE | Standard CIE |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_MOTION_SENSOR | Motion sensor |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_CONTACT_SWITCH | Contact switch |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_DOOR_WINDOW | Door/Window handle |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_FIRE_SENSOR | Fire sensor |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_WATER_SENSOR | Water sensor |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_CO_SENSOR | Carbon Monoxide (CO) sensor |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_PERSONAL_EMERG_D EVICE | Personal emergency device |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_MOVEMENT_SENSOR | Vibration/Movement sensor |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_REMOTE_CONTROL | Remote Control |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_KEY_FOB | Key fob |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_KEYPAD | Keypad |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_STANDARD_WARNING_ DEVICE | Standard Warning Device (see [N1] part 4) |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_GLASS_SENSOR | Glass break sensor |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_SECURITY_REPEATER | Security repeater |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_INVALID | Invalid Zone Type |
Structures
IAS Zone Client callbacks configuration
Parameters
| zone_status_change
void (*zone_status_change)( struct ZbZclClusterT *cluster, void *arg, struct ZbZclIasZoneServerStatusChangeNotifyT *notify, const struct ZbApsAddrT *src)
Callback to application, invoked on receipt of Zone Status Change Notification command |
| zone_enroll_req
enum ZclStatusCodeT (*zone_enroll_req)( struct ZbZclClusterT *cluster, void *arg, struct ZbZclIasZoneServerEnrollRequestT *req, uint64_t ext_src_addr, enum ZbZclIasZoneClientResponseCodeT *rsp_code, uint8_t *zone_id)
Callback to application, invoked on receipt of Zone Enroll command |
Zone Enroll response structure
Parameters
| enum ZclStatusCodeT zcl_status | Response status |
| enum ZbZclIasZoneClientResponseCodeT enroll_status | Enroll response code |
Parameters
| uint8_t test_duration | Test Mode Duration |
| uint8_t current_zone_sensitivity | Current Zone Sensitivity Level |
IAS Zone Server callbacks configuration
Parameters
| mode_change
enum ZclStatusCodeT (*mode_change)(struct ZbZclClusterT
Callback to application, invoked on receipt of Initiate Normal Operation Mode or Initiate Test Mode command |
Zone Enroll request structure
Parameters
zone_type |
Zone Type |
| uint16_t manuf_code | Manufacturer Code |
Zone State Change Notification request structure
Parameters
zone_status |
Zone Status |
| uint8_t ext_status | Extended Status |
| uint16_t delay | Delay |
8. Smart Energy Clusters
8.1. Calendar
#include "zcl/se/zcl.calendar.h"
Functions
ZbZclCalClientAlloc
struct ZbZclClusterT * ZbZclCalClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclCalClientCallbacksT *callbacks, void *arg);
Create a new instance of the Calendar client cluster
Parameters
Return
ZbZclCalClientCommandGetCalCancelReq
enum ZclStatusCodeT ZbZclCalClientCommandGetCalCancelReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Calendar Cancellation command
Parameters
Return
ZbZclCalClientCommandGetCalReq
enum ZclStatusCodeT ZbZclCalClientCommandGetCalReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalGetCalendarT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Calendar command
Parameters
| cmd_req | Get Calendar command request structure |
Return
ZbZclCalClientCommandGetDayProfilesReq
enum ZclStatusCodeT ZbZclCalClientCommandGetDayProfilesReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalGetDayProfilesT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Day Profiles command
Parameters
| cmd_req | Get Day Profiles command request structure |
Return
ZbZclCalClientCommandGetSeasonsReq
enum ZclStatusCodeT ZbZclCalClientCommandGetSeasonsReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalGetSeasonsT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Seasons command
Parameters
| cmd_req | Get Seasons command request structure |
Return
ZbZclCalClientCommandGetSpecialDaysReq
enum ZclStatusCodeT ZbZclCalClientCommandGetSpecialDaysReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalGetSpecialDaysT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Special Days command
Parameters
| cmd_req | Get Special Days command request structure |
Return
ZbZclCalClientCommandGetWeekProfilesReq
enum ZclStatusCodeT ZbZclCalClientCommandGetWeekProfilesReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalGetWeekProfilesT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Week Profile command
Parameters
| cmd_req | Get Week Profile command request structure |
Return
ZbZclCalParseCancelCalendar
bool ZbZclCalParseCancelCalendar(const uint8_t *buf, unsigned int len, struct ZbZclCalCancelCalendarT *rsp);
Parse a Cancel Calendar command
Parameters
| buf | Buffer containing response information |
| len | Length of response information in bytes |
| rsp | Cancel Calendar command structure |
Return
ZbZclCalParsePublishCalendar
bool ZbZclCalParsePublishCalendar(const uint8_t *buf, unsigned int len, struct ZbZclCalServerPublishCalendarT *rsp);
Parse a Publish Calendar command
Parameters
| rsp | Publish Calendar command structure |
Return
ZbZclCalParsePublishDayProfile
bool ZbZclCalParsePublishDayProfile(const uint8_t *buf, unsigned int len, struct ZbZclCalServerPublishDayProfileT *rsp);
Parse a Publish Day Profile command
Parameters
| rsp | Publish Day Profile command structure |
Return
ZbZclCalParsePublishSeasons
bool ZbZclCalParsePublishSeasons(const uint8_t *buf, unsigned int len, struct ZbZclCalPublishSeasonsT *rsp);
Parse a Publish Seasons command
Parameters
Return
ZbZclCalParsePublishSpecialDays
bool ZbZclCalParsePublishSpecialDays(const uint8_t *buf, unsigned int len, struct ZbZclCalPublishSpecialDaysT *rsp);
Parse a Publish Special Days command
Parameters
| rsp | Publish Special Days command structure |
Return
ZbZclCalParsePublishWeekProfile
bool ZbZclCalParsePublishWeekProfile(const uint8_t *buf, unsigned int len, struct ZbZclCalServerPublishWeekProfileT *rsp);
Parse a Publish Week Profile command
Parameters
| rsp | Publish Week Profile command structure |
Return
ZbZclCalServerAlloc
struct ZbZclClusterT * ZbZclCalServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclCalServerCallbacksT *callbacks, void *arg);
Create a new instance of the Calendar server cluster
Parameters
Return
ZbZclCalServerPublishCalendarRsp
enum ZclStatusCodeT ZbZclCalServerPublishCalendarRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclCalServerPublishCalendarT *info);
Send a Publish Calendar as a response
Parameters
| dstInfo | Destination address for response |
| info | Publish Calendar command structure |
Return
ZbZclCalServerPublishCalendarUnsolic
enum ZclStatusCodeT ZbZclCalServerPublishCalendarUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalServerPublishCalendarT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Publish Calendar as an unsolicited command
Parameters
| dst | Destination address for response |
| callback | Callback function that will be invoked when response is received, if one is expected. If broadcasting, then this should be set to NULL since no response is expected |
| arg | Pointer to application data that will later be provided back to the callback function when invoked |
Return
ZbZclCalServerPublishDayProfileRsp
enum ZclStatusCodeT ZbZclCalServerPublishDayProfileRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclCalServerPublishDayProfileT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Day Profile as a response
Parameters
| info | Publish Day Profile command structure |
| callback | Callback function for an APSDE-DATA.confirm |
Return
ZbZclCalServerPublishDayProfileUnsolic
enum ZclStatusCodeT ZbZclCalServerPublishDayProfileUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalServerPublishDayProfileT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Publish Day Profile as an unsolicited command
Parameters
Return
ZbZclCalServerPublishSeasonsRsp
enum ZclStatusCodeT ZbZclCalServerPublishSeasonsRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclCalPublishSeasonsT *info);
Send a Publish Seasons as a response
Parameters
| info | Publish Seasons command structure |
Return
ZbZclCalServerPublishSeasonsUnsolic
enum ZclStatusCodeT ZbZclCalServerPublishSeasonsUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalPublishSeasonsT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Publish Seasons as an unsolicited command
Parameters
Return
ZbZclCalServerPublishSpecialDaysRsp
enum ZclStatusCodeT ZbZclCalServerPublishSpecialDaysRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclCalPublishSpecialDaysT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Special Days as a response
Parameters
| info | Publish Special Days command structure |
Return
ZbZclCalServerPublishSpecialDaysUnsolic
enum ZclStatusCodeT ZbZclCalServerPublishSpecialDaysUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalPublishSpecialDaysT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Publish Special Days as an unsolicited command
Parameters
Return
ZbZclCalServerPublishWeekProfileRsp
enum ZclStatusCodeT ZbZclCalServerPublishWeekProfileRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclCalServerPublishWeekProfileT *info);
Send a Publish Week Profile as a response
Parameters
| info | Publish Week Profile command structure |
Return
ZbZclCalServerPublishWeekProfileUnsolic
enum ZclStatusCodeT ZbZclCalServerPublishWeekProfileUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalServerPublishWeekProfileT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Publish Week Profile as an unsolicited command
Parameters
Return
ZbZclCalServerSendCancelCalendarRsp
enum ZclStatusCodeT ZbZclCalServerSendCancelCalendarRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclCalCancelCalendarT *info);
Send a Cancel Calendar as a response
Parameters
| info | Cancel Calendar command structure |
Return
ZbZclCalServerSendCancelCalendarUnsolic
enum ZclStatusCodeT ZbZclCalServerSendCancelCalendarUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalCancelCalendarT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Cancel Calendar as an unsolicited command
Parameters
Return
ZbZclCalendarMirrorAlloc
struct ZbZclClusterT * ZbZclCalendarMirrorAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *calendar_server, struct ZbZclClusterT *meter_mirror, struct ZbZclClusterT *meter_client);
Allocates a Calendar Client Mirror cluster.
Parameters
| calendar_server | Pointer to Calendar Server cluster. This is used by the Metering Mirror to send mirrored commands to the BOMD. |
| meter_mirror | Pointer to Metering Mirror cluster. This is used to queue any commands that need to be forwarded to the BOMD when it wakes up. |
| meter_client | Pointer to Metering Client cluster. This is used to know the existing notification scheme setup between BOMD & ESI and to determine if the command needs to be queued or only the notification flag needs to be set. |
Return
Enumerations
ZbZclCalSvrAttrT
Calendar Server Attribute IDs
| ZCL_CAL_SVR_ATTR_AuxSwitch1Label | AuxSwitch1Label (Optional) |
| ZCL_CAL_SVR_ATTR_AuxSwitch2Label | AuxSwitch2Label (Optional) |
| ZCL_CAL_SVR_ATTR_AuxSwitch3Label | AuxSwitch3Label (Optional) |
| ZCL_CAL_SVR_ATTR_AuxSwitch4Label | AuxSwitch4Label (Optional) |
| ZCL_CAL_SVR_ATTR_AuxSwitch5Label | AuxSwitch5Label (Optional) |
| ZCL_CAL_SVR_ATTR_AuxSwitch6Label | AuxSwitch6Label (Optional) |
| ZCL_CAL_SVR_ATTR_AuxSwitch7Label | AuxSwitch7Label (Optional) |
| ZCL_CAL_SVR_ATTR_AuxSwitch8Label | AuxSwitch8Label (Optional) |
Structures
Parameters
| uint32_t provider_id | Provider Id |
| uint32_t issuer_calendar_id | Issuer Calendar ID |
| enum ZbZclCalTypeT calendar_type | Calendar Type |
| bool to_bomd | If true, the timeout for this command is extended since it’s being sent to a BOMD (in One-Way Mirror). |
Calendar Client callbacks configuration
Parameters
| publish_calendar
enum ZclStatusCodeT (*publish_calendar)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalServerPublishCalendarT *notify, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Calendar command |
| publish_day_profile
enum ZclStatusCodeT (*publish_day_profile)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalServerPublishDayProfileT *notify, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Day Profile command |
| publish_week_profile
enum ZclStatusCodeT (*publish_week_profile)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalServerPublishWeekProfileT *notify, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Week Profile command |
| publish_seasons
enum ZclStatusCodeT (*publish_seasons)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalPublishSeasonsT *notify, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Seasons command |
| publish_special_days
enum ZclStatusCodeT (*publish_special_days)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalPublishSpecialDaysT *notify, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Special Days command |
| cancel_calendar
enum ZclStatusCodeT (*cancel_calendar)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalCancelCalendarT *notify, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Cancel Calendar command |
Get Calendar command structure
Parameters
| uint32_t earliest_start_time | Earliest Start Time |
| uint32_t min_issuer_event_id | Min. Issuer Even ID |
| uint8_t num_calendars | Number of Calendars |
Get Day Profiles command structure
Parameters
| uint8_t start_day_id | Start Day Id |
| uint8_t num_days | Number of Days |
ZbZclCalGetSeasonsT
Get Seasons command structure
Parameters
Get Special Days command structure
Parameters
| uint32_t start_time | Start Time |
| uint8_t num_events | Number of Events |
Get Week Profiles command structure
Parameters
| uint8_t start_week_id | Start Week Id |
| uint8_t num_weeks | Number of Weeks |
Parameters
| uint32_t issuer_event_id | Issuer Event ID |
| uint8_t command_index | Command Index |
| uint8_t num_commands | Total Number of Commands |
| struct ZbZclCalendarSeasonT entry_list | Season Entry |
| uint8_t num_entries | Number of Season Entries - maximum is 8, since ZCL_PAYLOAD_UNFRAG_SAFE_SIZE = 54 |
Parameters
| uint32_t start_time | Start Time - UTCTime |
| uint8_t total_days | Total Number of Special Days |
| struct ZbZclCalendarSpecialDayT
entry_list |
Special Day Entry |
| uint8_t num_entries | Number of Special Day Entries - maximum is 6, since ZCL_PAYLOAD_UNFRAG_SAFE_SIZE = 54 |
Calendar Server callbacks configuration
Parameters
| get_calendar
enum ZclStatusCodeT (*get_calendar)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalGetCalendarT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Calendar command. The ZCL Status return value is included in the Default Response. The application may call ZbZclCalServerPublishCalendarRsp to elicit a PublishCalendar command notification. |
| get_day_profiles
enum ZclStatusCodeT (*get_day_profiles)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalGetDayProfilesT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Day Profiles command. The ZCL Status return value is included in the Default Response. The application may call ZbZclCalServerPublishDayProfile to elicit a PublishDayProfile command notification. |
| get_week_profiles
enum ZclStatusCodeT (*get_week_profiles)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalGetWeekProfilesT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Week Profiles command. The ZCL Status return value is included in the Default Response. The application may call ZbZclCalServerPublishWeekProfile to elicit a PublishWeekProfile command notification. |
| get_seasons
enum ZclStatusCodeT (*get_seasons)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalGetSeasonsT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Seasons command. The ZCL Status return value is included in the Default Response. The application may call ZbZclCalServerPublishSeasons to elicit a PublishSeasons command notification. |
| get_special_days
enum ZclStatusCodeT (*get_special_days)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalGetSpecialDaysT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Special Days command. The ZCL Status return value is included in the Default Response. The application may call ZbZclCalServerPublishSpecialDays to elicit a PublishSpecialDays command notification. |
| get_calendar_cancellation
enum ZclStatusCodeT (*get_calendar_cancellation)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclAddrInfoT *srcInfo)
Parameters
| enum ZbZclCalTypeT calendar_type | Calendary Type |
| uint8_t calendar_time_ref | Calendar Time Reference |
| uint8_t calendar_name | Calendar Name (ZCL string char, first byte is length) |
| uint8_t num_seasons | Number of Seasons |
| uint8_t num_week_profiles | Number of Week Profiles |
| uint8_t num_day_profiles | Number of Day Profiles |
Parameters
| uint8_t day_id | Day ID |
| uint8_t total_entries | Total Number of Schedule Entries |
| struct ZbZclCalendarDayScheduleT
entry_list |
Day Schedule Entries |
| uint8_t num_entries | Number of Day Schedule Entries - maximum is 12, since ZCL_PAYLOAD_UNFRAG_SAFE_SIZE = 54 |
Parameters
| uint8_t week_id | Week ID |
| uint8_t day_id_ref_mon | Day ID Ref Monday |
| uint8_t day_id_ref_tue | Day ID Ref Tuesday |
| uint8_t day_id_ref_wed | Day ID Ref Wednesday |
| uint8_t day_id_ref_thu | Day ID Ref Thursday |
| uint8_t day_id_ref_fri | Day ID Ref Friday |
| uint8_t day_id_ref_sat | Day ID Ref Saturday |
| uint8_t day_id_ref_sun | Day ID Ref Sunday |
Day Schedule Entries structure
Parameters
| uint16_t start_time | Start Time |
| uint8_t value_u8 | Price Tier - if calendar type is 0x00 – 0x02. Friendly Credit Enable - if calendar type is 0x03. Auxiliary Load Switch State - if calendar type is 0x04. |
Season Entry structure
Parameters
| uint32_t start_date |
Parameters
| uint32_t specialDayDate |
