1. Identify
#include "zcl/general/zcl.identify.h"
Functions
ZbZclIdentifyClientAlloc
struct ZbZclClusterT * ZbZclIdentifyClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Identify Client cluster
Parameters
| zb | Zigbee stack instance |
| endpoint | Endpoint on which to create cluster |
Return
- Cluster pointer, or NULL if there is an error
ZbZclIdentifyServerAlloc
struct ZbZclClusterT * ZbZclIdentifyServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, const struct zcl_identify_server_callbacks_t *callbacks, void *arg);
Create a new instance of the Identify Server cluster
Parameters
| arg | Pointer to application data that will included in the callback when invoked. |
Return
ZbZclIdentifyServerGetTime
uint16_t ZbZclIdentifyServerGetTime(struct ZbZclClusterT *cluster);
Get the local Identify Server time
Parameters
| cluster | Cluster instance with timer to get |
Return
- uint16_t Time remaining in zigbee timer
ZbZclIdentifyServerSetTime
void ZbZclIdentifyServerSetTime(struct ZbZclClusterT *cluster, uint16_t seconds);
Set the local Identify Server time
If BDB_COMMISSION_MODE_FIND_BIND is enabled and seconds > 0, seconds is adjusted to be >= ZB_BDBC_MinCommissioningTime
Parameters
| cluster | Cluster instance with timer to set |
| seconds | Seconds for updating the identify time counter |
Return
- Void
zcl_identify_cli_identify_req
enum ZclStatusCodeT zcl_identify_cli_identify_req(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, uint16_t identify_time, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Identify command
Parameters
| cluster | Cluster instance from which to send this command |
| dst | Destination address for request |
| identify_time | Time which will be used to set the IdentifyTime attribute |
| callback | Callback function that will be invoked when the response is received. |
Return
- ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error
zcl_identify_cli_query_req
enum ZclStatusCodeT zcl_identify_cli_query_req(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Identify Query command
Parameters
Return
Enumerations
ZbZclIdentifySvrAttrT
Identify Server Attribute IDs
| ZCL_IDENTIFY_ATTR_TIME | IdentifyTime |
2. Illuminance Level Sensing
#include "zcl/general/zcl.illum.level.h"
Functions
ZbZclIllumLevelClientAlloc
struct ZbZclClusterT * ZbZclIllumLevelClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Illuminance Level Sensing Client cluster
Parameters
Return
ZbZclIllumLevelServerAlloc
struct ZbZclClusterT * ZbZclIllumLevelServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Illuminance Level Sensing Server cluster
Parameters
Return
Enumerations
ZbZclIllumLevelSvrAttrT
Attribute Identifiers
| ZCL_ILLUM_LEVEL_ATTR_LEVEL_STATUS | LevelStatus |
| ZCL_ILLUM_LEVEL_ATTR_LIGHT_SENSOR_TYPE | LightSensorType |
| ZCL_ILLUM_LEVEL_ATTR_ILLUM_TARGET_LEVEL | IlluminanceTargetLevel |
3. Illuminance Measurement
#include "zcl/general/zcl.illum.meas.h"
Functions
ZbZclIllumMeasClientAlloc
struct ZbZclClusterT * ZbZclIllumMeasClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Illuminance Measurement Client cluster
Parameters
Return
ZbZclIllumMeasServerAlloc
struct ZbZclClusterT * ZbZclIllumMeasServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, uint16_t min, uint16_t max);
Create a new instance of the Illuminance Measurement Server cluster
Parameters
| min | Minimum value capable of being measured (MinMeasuredValue) |
| max | Maximum value capable of being measured (MaxMeasuredValue) |
Return
Enumerations
ZbZclIllumMeasSvrAttrT
Illuminance Measurement Server Attribute IDs
| ZCL_ILLUM_MEAS_ATTR_MEAS_VAL | MeasuredValue |
| ZCL_ILLUM_MEAS_ATTR_MIN_MEAS_VAL | MinMeasuredValue |
| ZCL_ILLUM_MEAS_ATTR_MAX_MEAS_VAL | MaxMeasuredValue |
| ZCL_ILLUM_MEAS_ATTR_TOLERANCE | Tolerance (Optional) |
| ZCL_ILLUM_MEAS_ATTR_LIGHT_SENSOR_TYPE | LightSensorType (Optional) |
4. Level
#include "zcl/general/zcl.level.h"
Functions
ZbZclLevelClientAlloc
struct ZbZclClusterT * ZbZclLevelClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Level Client cluster
Parameters
Return
ZbZclLevelClientMoveReq
enum ZclStatusCodeT ZbZclLevelClientMoveReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclLevelClientMoveReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Move command
Parameters
| req | Move command request structure |
Return
ZbZclLevelClientMoveToFreqReq
enum ZclStatusCodeT ZbZclLevelClientMoveToFreqReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclLevelClientMoveToFreqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Move to Frequency command
Parameters
| req | Stop command request structure |
Return
ZbZclLevelClientMoveToLevelReq
enum ZclStatusCodeT ZbZclLevelClientMoveToLevelReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclLevelClientMoveToLevelReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Move to Level command
Parameters
| req | Move To Level command request structure |
Return
ZbZclLevelClientStepReq
enum ZclStatusCodeT ZbZclLevelClientStepReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclLevelClientStepReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Step command
Parameters
| req | Step command request structure |
Return
ZbZclLevelClientStopReq
enum ZclStatusCodeT ZbZclLevelClientStopReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclLevelClientStopReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Stop command
Parameters
Return
ZbZclLevelServerAlloc
struct ZbZclClusterT * ZbZclLevelServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *onoff_server, struct ZbZclLevelServerCallbacksT *callbacks, void *arg);
Create a new instance of the Level Server cluster
Parameters
| onoff_server | OnOff server cluster pointer for processing commands with the Options fields. May be NULL |
| callbacks | Structure containing any callback function pointers for this cluster |
Return
Enumerations
ZbZclLevelSvrAttrT
Level Server Attribute IDs
| ZCL_LEVEL_ATTR_CURRLEVEL | CurrentLevel |
| ZCL_LEVEL_ATTR_REMAINTIME | RemainingTime (Optional) |
| ZCL_LEVEL_ATTR_MINLEVEL | MinLevel (Optional) |
| ZCL_LEVEL_ATTR_MAXLEVEL | MaxLevel (Optional) |
| ZCL_LEVEL_ATTR_CURRFREQ | CurrentFrequency (Optional) |
| ZCL_LEVEL_ATTR_MINFREQ | MinFrequency (Optional) |
| ZCL_LEVEL_ATTR_MAXFREQ | MaxFrequency (Optional) |
| ZCL_LEVEL_ATTR_OPTIONS | OnOffTransitionTime (Optional) |
| ZCL_LEVEL_ATTR_ONOFF_TRANS_TIME | OnLevel (Optional) |
| ZCL_LEVEL_ATTR_ONLEVEL | OnTransitionTime (Optional) |
| ZCL_LEVEL_ATTR_ON_TRANS_TIME | OffTransitionTime (Optional) |
| ZCL_LEVEL_ATTR_OFF_TRANS_TIME | DefaultMoveRate (Optional) |
| ZCL_LEVEL_ATTR_DEFAULT_MOVE_RATE | Options (Optional) |
| ZCL_LEVEL_ATTR_STARTUP_CURRLEVEL | StartUpCurrentLevel (Optional) |
Structures
Move command structure
Parameters
| bool with_onoff | With Onoff - If true then cmd is ZCL_LEVEL_CLI_CMD_MOVE_ONOFF, else ZCL_LEVEL_CLI_CMD_MOVE |
| uint8_t mode | Mode |
| uint8_t rate | Rate |
| uint8_t mask | OptionsMask - Not included if with_onoff is true |
| uint8_t override | OptionsOverride - Not included if with_onoff is true |
Move to Closest Frequency command structure
Parameters
| uint16_t freq | Frequency |
Move To Level command structure
Parameters
| bool with_onoff | With Onoff - If true then cmd is ZCL_LEVEL_CLI_CMD_MOVE_LEVEL_ONOFF, else ZCL_LEVEL_CLI_CMD_MOVE_LEVEL |
| uint8_t level | Level |
| uint16_t transition_time | Transition time |
Step command structure
Parameters
| bool with_onoff | With Onoff - If true then cmd is ZCL_LEVEL_CLI_CMD_STEP_ONOFF, else ZCL_LEVEL_CLI_CMD_STEP |
| uint8_t size | Size |
| uint16_t transition_time | Transition Time |
Stop command structure
Parameters
| bool with_onoff | With Onoff - If true then cmd is ZCL_LEVEL_CLI_CMD_STOP_ONOFF, else ZCL_LEVEL_CLI_CMD_STOP |
Level Server callbacks configuration
Parameters
| move_to_level
(callback function pointer) |
enum ZclStatusCodeT (*move_to_level)(struct ZbZclClusterT *cluster, struct ZbZclLevelClientMoveToLevelReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of a Move To Level command. Set with_onoff to true in the req struct when utilizing the onoff cluster on the same endpoint. The application is expected to update the ZCL_LEVEL_ATTR_CURRLEVEL attribute. |
| move
enum ZclStatusCodeT (*move)(struct ZbZclClusterT *cluster, struct ZbZclLevelClientMoveReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of a Move command. Set with_onoff to true in the req struct when utilizing the onoff cluster on the same endpoint. The application is expected to update the ZCL_LEVEL_ATTR_CURRLEVEL attribute. |
| step
enum ZclStatusCodeT (*step)(struct ZbZclClusterT *cluster, struct ZbZclLevelClientStepReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of a Step command. Set with_onoff to true in the req struct when utilizing the onoff cluster on the same endpoint. The application is expected to update the ZCL_LEVEL_ATTR_CURRLEVEL attribute. |
| stop
enum ZclStatusCodeT (*stop)(struct ZbZclClusterT *cluster, struct ZbZclLevelClientStopReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of a Stop command. Set with_onoff to true in the req struct when utilizing the onoff cluster on the same endpoint. The application is expected to update the ZCL_LEVEL_ATTR_CURRLEVEL attribute. |
| move_to_freq
enum ZclStatusCodeT (*move_to_freq)(struct ZbZclClusterT *cluster, struct ZbZclLevelClientMoveToFreqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of a Move to Frequency command. The application is expected to update the ZCL_LEVEL_ATTR_CURRFREQ attribute. |
5. Meter Identification
#include "zcl/general/zcl.meter.id.h"
Functions
ZbZclMeterIdClientAlloc
struct ZbZclClusterT * ZbZclMeterIdClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Instantiate a new instance of the Meter Identification Client cluster
Parameters
Return
ZbZclMeterIdServerAlloc
struct ZbZclClusterT * ZbZclMeterIdServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Instantiate a new instance of the Meter Identification Server cluster
Parameters
Return
Enumerations
ZbZclMeterIdSvrAttrT
| ZCL_METER_ID_ATTR_COMPANY_NAME | CompanyName |
| ZCL_METER_ID_ATTR_METER_TYPE_ID | MeterTypeID |
| ZCL_METER_ID_ATTR_DATA_QUAL_ID | DataQualityID |
| ZCL_METER_ID_ATTR_CUSTOMER_NAME | CustomerName (Optional) |
| ZCL_METER_ID_ATTR_MODEL | Model (Optional) |
| ZCL_METER_ID_ATTR_PART_NUMBER | PartNumber (Optional) |
| ZCL_METER_ID_ATTR_PRODUCT_REV | ProductRevision (Optional) |
| ZCL_METER_ID_ATTR_SOFTWARE_REV | SoftwareRevision (Optional) |
| ZCL_METER_ID_ATTR_UTILITY_NAME | UtilityName (Optional) |
| ZCL_METER_ID_ATTR_POD | POD |
| ZCL_METER_ID_ATTR_AVAILABLE_POWER | AvailablePower |
| ZCL_METER_ID_ATTR_POWER_THRESH | PowerThreshold |
6. Nearest Gateway
#include "zcl/general/zcl.nearest.gw.h"
Functions
ZbZclNearestGwClientAlloc
struct ZbZclClusterT * ZbZclNearestGwClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Instantiate a new instance of the Nearest Gateway client cluster
Parameters
Return
ZbZclNearestGwServerAlloc
struct ZbZclClusterT * ZbZclNearestGwServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Instantiate a new instance of the Nearest Gateway server cluster
Parameters
Return
Enumerations
ZbZclNearestGwServerAttrT
Nearest Gateway Attribute Ids
| ZCL_NEAREST_GW_SVR_ATTR_NEAREST_GW | Nearest Gateway |
| ZCL_NEAREST_GW_SVR_ATTR_NEW_MOBILE_NODE | New Mobile Node |
7. Occupancy Sensing
#include "zcl/general/zcl.occupancy.h"
Functions
ZbZclOccupancyClientAlloc
struct ZbZclClusterT * ZbZclOccupancyClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Occupancy Sensing Server cluster
Parameters
Return
ZbZclOccupancyServerAlloc
struct ZbZclClusterT * ZbZclOccupancyServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Occupancy Sensing Client cluster
Parameters
Return
Enumerations
ZbZclOccupancySvrAttrT
Occupancy Sensing Server Attribute IDs
| ZCL_OCC_ATTR_OCCUPANCY | Occupancy |
| ZCL_OCC_ATTR_SENSORTYPE | OccupancySensorType |
| ZCL_OCC_ATTR_SENSORTYPE_BITMAP | OccupancySensorTypeBitmap |
| ZCL_OCC_ATTR_PIR_OU_DELAY | PIROccupiedToUnoccupiedDelay (Optional) |
| ZCL_OCC_ATTR_PIR_UO_DELAY | PIRUnoccupiedToOccupiedDelay (Optional) |
| ZCL_OCC_ATTR_PIR_UO_THRESHOLD | PIRUnoccupiedToOccupiedThreshold (Optional) |
| ZCL_OCC_ATTR_US_OU_DELAY | UltrasonicOccupiedToUnoccupiedDelay (Optional) |
| ZCL_OCC_ATTR_US_UO_DELAY | UltrasonicUnoccupiedToOccupiedDelay (Optional) |
| ZCL_OCC_ATTR_US_UO_THRESHOLD | UltrasonicUnoccupiedToOccupiedThreshold (Optional) |
| ZCL_OCC_ATTR_PHY_OU_DELAY | PhysicalContactOccupiedToUnoccupiedDelay (Optional) |
| ZCL_OCC_ATTR_PHY_UO_DELAY | PhysicalContactUnoccupiedToOccupiedDelay (Optional) |
| ZCL_OCC_ATTR_PHY_UO_THRESHOLD | PhysicalContactUnoccupiedToOccupiedThreshold (Optional) |
8. On/Off Switch Configuration
#include "zcl/general/zcl.onoff.swconfig.h"
Functions
ZbZclOnOffSwConfigClientAlloc
struct ZbZclClusterT * ZbZclOnOffSwConfigClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the OnOff Switch Configuration Client cluster
Parameters
Return
ZbZclOnOffSwConfigServerAlloc
struct ZbZclClusterT * ZbZclOnOffSwConfigServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, uint8_t switch_type);
Create a new instance of the OnOff Switch Configuration Server cluster
Parameters
| switch_type | Type of switch associated with this cluster server |
Return
Enumerations
ZbZclOnOffSwConfigSvrAttrId
Onoff Switch Configuration cluster attribute IDs
| ZCL_ONOFF_SWCONFIG_ATTR_TYPE | SwitchType |
| ZCL_ONOFF_SWCONFIG_ATTR_ACTIONS | SwitchActions |
9. On/Off
#include "zcl/general/zcl.onoff.h"
Functions
ZbZclOnOffClientAlloc
struct ZbZclClusterT * ZbZclOnOffClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the OnOff Client cluster
Parameters
Return
ZbZclOnOffClientOffReq
enum ZclStatusCodeT ZbZclOnOffClientOffReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Off command
Parameters
| callback | Callback function that will be invoked when response is received |
Return
ZbZclOnOffClientOnReq
enum ZclStatusCodeT ZbZclOnOffClientOnReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an On command
Parameters
Return
ZbZclOnOffClientToggleReq
enum ZclStatusCodeT ZbZclOnOffClientToggleReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Toggle command
Parameters
Return
ZbZclOnOffServerAlloc
struct ZbZclClusterT * ZbZclOnOffServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclOnOffServerCallbacksT *callbacks, void *arg);
Create a new instance of the OnOff Server cluster
Parameters
Return
ZbZclOnOffServerSetLevelControlCallback
void ZbZclOnOffServerSetLevelControlCallback(struct ZbZclClusterT *on_off_cluster, struct ZbZclClusterT *level_cluster, ZbZclLevelControlCallbackT levelControlCallback);
Set the Level control callback
Parameters
| on_off_cluster | OnOff cluster instance |
| level_cluster | Level cluster instance |
| levelControlCallback | Level control callback function |
Return
- Void
Enumerations
ZbZclOnOffSvrAttrT
OnOff Server Attribute IDs
| ZCL_ONOFF_ATTR_ONOFF | OnOff |
| ZCL_ONOFF_ATTR_GLOBAL_SCENE_CONTROL | GlobalSceneControl (Optional) |
| ZCL_ONOFF_ATTR_ON_TIME | OnTime (Optional) |
| ZCL_ONOFF_ATTR_OFF_WAIT_TIME | OffWaitTime (Optional) |
Structures
OnOff Server callbacks configuration
Parameters
| off
enum ZclStatusCodeT (*off)(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of an Off command. The application is expected to update ZCL_ONOFF_ATTR_ONOFF. |
| on
enum ZclStatusCodeT (*on)(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of an On command. The application is expected to update ZCL_ONOFF_ATTR_ONOFF. |
| toggle
enum ZclStatusCodeT (*toggle)(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of a Toggle command. The application is expected to update ZCL_ONOFF_ATTR_ONOFF. |
10. Over-The-Air Upgrade
#include "zcl/general/zcl.ota.h"
Functions
ZbZclOtaClientAlloc
struct ZbZclClusterT * ZbZclOtaClientAlloc(struct ZigBeeT *zb, struct ZbZclOtaClientConfig *config, void *arg);
Create a new instance of the OTA Upgrade Client cluster
Parameters
| config | Pointer to OTA client configuration structure |
| arg | Pointer to application data provided in initiating API call |
Return
ZbZclOtaClientDiscover
enum ZclStatusCodeT ZbZclOtaClientDiscover(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *addr);
Discover OTA Upgrade Server
Parameters
| addr | Destination address for discovery |
Return
ZbZclOtaClientDiscoverForced
void ZbZclOtaClientDiscoverForced(struct ZbZclClusterT *cluster, uint64_t ieee, uint8_t endpoint);
Set the OTA Upgrade Server directly (without discovery)
Parameters
| ieee | OTA Upgrade server IEEE address |
Return
- None
ZbZclOtaClientGetDefaultCallbacks
void ZbZclOtaClientGetDefaultCallbacks(struct ZbZclOtaClientCallbacksT *callbacks);
Load the default callbacks for ECDSA Suite 2 support
Parameters
Return
- None
ZbZclOtaClientImageTransferResume
enum ZclStatusCodeT ZbZclOtaClientImageTransferResume(struct ZbZclClusterT *cluster);
Resume an OTA Upgrade transfer. ZbZclOtaClientImageTransferResume is called if the NHLE (app) returned ZCL_STATUS_WAIT_FOR_DATA for the write_image callback. The OTA Client won’t request the next block of data in this case, until this function is called.
Parameters
Return
ZbZclOtaClientImageTransferStart
enum ZclStatusCodeT ZbZclOtaClientImageTransferStart(struct ZbZclClusterT *cluster);
Initiate an OTA Upgrade transfer.
Parameters
Return
ZbZclOtaClientQueryNextImageReq
enum ZclStatusCodeT ZbZclOtaClientQueryNextImageReq(struct ZbZclClusterT *cluster, struct ZbZclOtaImageDefinition *image_definition, uint8_t field_control, uint16_t hardware_version);
Send a Query Next Image Request command. If a response is received, or an error occurs, the 'query_next' callback is invoked to the application.
Parameters
| image_definition | OTA Header Image Definition structure (See 'struct ZbZclOtaImageDefinition') |
| field_control | Field Control |
| hardware_version | Hardware Version to include in request, unless set to 0xff. |
Return
- ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error.
ZbZclOtaHeaderParse
uint8_t ZbZclOtaHeaderParse(const uint8_t *payload, const uint8_t length, struct ZbZclOtaHeader *header);
Parse an OTA Upgrade payload buffer’s header information
Parameters
| payload | OTA Upgrade Payload buffer |
| length | Length of OTA Upgrade Payload |
| header | OTA Upgrade Header Fields structure |
Return
- Number of bytes parsed
ZbZclOtaServerAlloc
struct ZbZclClusterT * ZbZclOtaServerAlloc(struct ZigBeeT *zb, struct ZbZclOtaServerConfig
- config, void *arg);
Create a new instance of the OTA Upgrade Server cluster
Parameters
| config | OTA Upgrade Server Configuration structure |
| arg | Pointer to application data that will later be provided back to the callback function when invoked |
Return
ZbZclOtaServerImageNotifyReq
enum ZclStatusCodeT ZbZclOtaServerImageNotifyReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, uint8_t payload_type, uint8_t jitter, struct ZbZclOtaImageDefinition *image_definition);
Send an OTA Image Notify Server command Registering an image does not automatically send an Image Notify message, the OTA Server application can use ZbZclOtaServerImageNotifyReq after registering an image to notify clients of the availability of a new image
Parameters
| payload_type | Payload Type |
| jitter | Jitter |
| image_definition | OTA Header Image Definition structure |
Return
ZbZclOtaServerUpgradeEndRespUnsolic
enum ZclStatusCodeT ZbZclOtaServerUpgradeEndRespUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclOtaImageDefinition *image_definition, struct ZbZclOtaEndResponseTimes *end_response_times);
Send an Unsolicited OTA Upgrade End Response. This command is sent at some point in time after receiving the Upgrade End Request, which was already responsed to by a Default Response. This should be the normal way to handle the Upgrade End commands, rather than the Solicated Upgrade End Response (ZbZclOtaServerUpgradeEndRespSolic).
Parameters
| image_definition | OTA Header Image Definition |
| end_response_times | Upgrade End Response command |
Return
Enumerations
ZbZclOtaActivationPolicy
OTA Upgrade UpgradeActivationPolicy enumerations
| ZCL_OTA_ACTIVATION_POLICY_SERVER | OTA Server Activation Allowed |
| ZCL_OTA_ACTIVATION_POLICY_OUT_OF_BAND | Out-of-band Activation Only |
ZbZclOtaHeaderFieldCtrlBitmask
OTA Upgrade Header Field Control Bitmask enumerations
| ZCL_OTA_HEADER_FIELD_CONTROL_SECURITY_VERSION | Security Credential Version Present |
| ZCL_OTA_HEADER_FIELD_CONTROL_DEVICE_SPECIFIC | Device Specific File |
| ZCL_OTA_HEADER_FIELD_CONTROL_HARDWARE_VERSI ONS | Hardware Versions Present |
ZbZclOtaImageBlkReqFldCtrl
OTA Upgrade Image Block Request Field Control Bitmask enumerations
| ZCL_OTA_IMAGE_BLOCK_FC_IEEE | Request node’s IEEE address Present |
| ZCL_OTA_IMAGE_BLOCK_FC_MIN_PERIOD | MinimumBlockPeriod present |
ZbZclOtaImageNotifyCmd
OTA Upgrade Image Notify Command Payload enumerations
| ZCL_OTA_NOTIFY_TYPE_JITTER | Query jitter |
| ZCL_OTA_NOTIFY_TYPE_MFG_CODE | Query jitter and manufacturer code |
| ZCL_OTA_NOTIFY_TYPE_IMAGE_TYPE | Query jitter, manufacturer code, and image type |
| ZCL_OTA_NOTIFY_TYPE_FILE_VERSION | Query jitter, manufacturer code, image type, and new file version |
ZbZclOtaImageType
OTA Upgrade Image Types enumerations
| ZCL_OTA_IMAGE_TYPE_MFG_MIN | Manufacturer Specific (start) |
| ZCL_OTA_IMAGE_TYPE_MFG_MAX | Manufacturer Specific (end) |
| ZCL_OTA_IMAGE_TYPE_CLI_SECURITY_CRED | Client Security credentials |
| ZCL_OTA_IMAGE_TYPE_CLI_CONFIG | Client Configuration |
| ZCL_OTA_IMAGE_TYPE_SERVER_LOG | Server Log |
| ZCL_OTA_IMAGE_TYPE_PICTURE | Picture |
| ZCL_OTA_IMAGE_TYPE_WILDCARD | Wild Card |
ZbZclOtaQueryFldCtrlHwVer
OTA Upgrade Field Control Hardware Version enumerations
| ZCL_OTA_QUERY_FIELD_CONTROL_HW_VERSION | Hardware Version |
ZbZclOtaSecCredential
OTA Upgrade Security Credential Version enumerations
| ZCL_OTA_SEC_CRED_SE_1_0 | SE 1.0 |
| ZCL_OTA_SEC_CRED_SE_1_1 | SE 1.1 |
| ZCL_OTA_SEC_CRED_SE_2_0 | SE 2.0 |
| ZCL_OTA_SEC_CRED_SE_1_2 | SE 1.2 |
ZbZclOtaStackVersion
OTA Upgrade Zigbee Stack Version Values
| ZCL_OTA_STACK_VERSION_2006 | ZigBee 2006 |
| ZCL_OTA_STACK_VERSION_2007 | ZigBee 2007 |
| ZCL_OTA_STACK_VERSION_PRO | ZigBee Pro |
| ZCL_OTA_STACK_VERSION_IP | ZigBee IP |
ZbZclOtaStatus
OTA Upgrade Status Attribute Values (ImageUpgradeStatus)
| ZCL_OTA_STATUS_NORMAL | Normal |
| ZCL_OTA_STATUS_DOWNLOAD_IN_PROGRESS | Download in progress |
| ZCL_OTA_STATUS_DOWNLOAD_COMPLETE | Download complete |
| ZCL_OTA_STATUS_WAITING_TO_UPGRADE | Waiting to upgrade |
| ZCL_OTA_STATUS_COUNT_DOWN | Count down |
| ZCL_OTA_STATUS_WAIT_FOR_MORE | Wait for more |
| ZCL_OTA_STATUS_WAIT_UPGRADE_EXT | Waiting to Upgrade via External Event |
ZbZclOtaSubElementTag
OTA Upgrade Tag Identifiers enumerations
| ZCL_OTA_SUB_TAG_UPGRADE_IMAGE | Upgrade Image |
| ZCL_OTA_SUB_TAG_ECDSA_SIG1 | ECDSA Signature (Crypto Suite 1) |
| ZCL_OTA_SUB_TAG_ECDSA_CERT_1 | ECDSA Signing Certificate (Crypto Suite 1) |
| ZCL_OTA_SUB_TAG_IMAGE_INTEGRITY_CODE | Image Integrity Code |
| ZCL_OTA_SUB_TAG_PICTURE_DATA | Picture Data |
| ZCL_OTA_SUB_TAG_ECDSA_SIG2 | ECDSA Signature (Crypto Suite 2) |
| ZCL_OTA_SUB_TAG_ECDSA_CERT_2 | ECDSA Signing Certificate (Crypto Suite 2) |
ZbZclOtaSvrAttrId
OTA Upgrade Server Attribute IDs
| ZCL_OTA_ATTR_UPGRADE_SERVER_ID | UpgradeServerID |
| ZCL_OTA_ATTR_FILE_OFFSET | FileOffset (Optional).
When writing a non-zero value to ZCL_OTA_ATTR_FILE_OFFSET, the entire OTA Header must have already been received by this cluster. This can be used to resume a transfer that was interrupted by the local device being power cycled in the middle of an OTA download. The procedure in this case is to start the transfer over (ZbZclOtaClientImageTransferStart) and during the first write_image() callback to the application, you write a new value to the FileOffset attribute before returning from the callback. The OTA Client will then request the next block starting from the new FileOffset. During the write_image() callback, the application can also compare that the current OTA header matches the previous one, if saved before the reset. If relying on the Integrity Code (hash), the application must define it’s own image_validate() callback. This is because data that has already been saved to NVM will be skipped by the OTA Client after the reset, so the running hash is no longer valid. |
| ZCL_OTA_ATTR_CURRENT_FILE_VERSION | CurrentFileVersion (Optional) |
| ZCL_OTA_ATTR_CURRENT_STACK_VERSION | CurrentZigBeeStackVersion (Optional) |
| ZCL_OTA_ATTR_DOWNLOAD_FILE_VERSION | DownloadedFileVersion (Optional) |
| ZCL_OTA_ATTR_DOWNLOAD_STACK_VERSION | DownloadedZigBeeStackVersion (Optional) |
| ZCL_OTA_ATTR_IMAGE_UPGRADE_STATUS | ImageUpgradeStatus (Optional).
Writing ZCL_OTA_STATUS_NORMAL (0) to this attribute will reset the cluster back to defaults. |
| ZCL_OTA_ATTR_MANUFACTURER_ID | ManufacturerID (Optional) |
| ZCL_OTA_ATTR_IMAGE_TYPE_ID | ImageTypeID (Optional) |
| ZCL_OTA_ATTR_MIN_BLOCK_PERIOD | MinimumBlockPeriod (Optional) |
| ZCL_OTA_ATTR_IMAGE_STAMP | ImageStamp (Optional) |
| ZCL_OTA_ATTR_UPGRADE_ACTIVATION_POLICY | UpgradeActivationPolicy (Optional) |
| ZCL_OTA_ATTR_UPGRADE_TIMEOUT_POLICY | UpgradeTimeoutPolicy (Optional) |
ZbZclOtaTimeoutPolicy
OTA Upgrade UpgradeTimeoutPolicy enumerations
| ZCL_OTA_TIMEOUT_POLICY_APPLY_UPGRADE | Apply Upgrade After Timeout |
| ZCL_OTA_TIMEOUT_POLICY_DO_NOT_APPLY | Do not Apply Upgrade After Timeout |
Structures
OTA Upgrade callbacks configuration
Parameters
| discover_complete
void (*discover_complete)(struct ZbZclClusterT *cluster, enum ZclStatusCodeT status, void *arg)
Callback to Server, invoked on discovery of OTA Upgrade Server. If NULL and ZbZclOtaClientDiscover is successful, the default handler will automatically call ZbZclOtaClientQueryNextImageReq. |
| image_notify
enum ZclStatusCodeT (*image_notify)(struct ZbZclClusterT *cluster, uint8_t payload_type, uint8_t jitter, struct ZbZclOtaImageDefinition *image_definition, struct ZbApsdeDataIndT *data_ind, struct ZbZclHeaderT *zcl_header)
Callback to Server, invoked on receipt of Image Notify Server command If NULL, the OTA Client has default callback handlers to take care of a typical OTA firmware upgrade file. Callback Function Parameters:
The value of the payload type from the Image Notify command payload. The value indicates which parameters in the image_definition are valid.
The value of the query jitter from the Image Notify command payload. The jitter is used to decide if the client should drop the command or not. Refer to section 11.13.3.4 (Effect on Receipt) of the ZCL6 spec.
Pointer to the parsed image definition of the image from the Image notify payload.
The manufacturer code for this image.
The manufacturer specific image type, defined by the manufacturer.
The file version.
Pointer to the incoming APSDE-DATA.indication struct.
Pointer to the incoming ZCL Header struct. |
| query_next
void (*query_next)(struct ZbZclClusterT *cluster, enum ZclStatusCodeT status, struct ZbZclOtaImageDefinition image_definition, uint32_t image_size, void *arg)
Callback to Server, invoked on receipt of Query Next Image Response command. If no image was found, the status will be set to ZCL_STATUS_NO_IMAGE_AVAILABLE. Otherwise the status should be set to ZCL_STATUS_SUCCESS from the OTA Server. |
| update_raw
enum ZclStatusCodeT (*update_raw)(struct ZbZclClusterT *cluster, uint8_t length, uint8_t *data, void *arg)
Raw image data is sent through this callback, to update running hash of image for example. Normally, this callback should be left to use the cluster’s default internal handler, but if the application does define its own callback, it must also provide its own handler for the 'image_validate' callback. Return code is ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error (e.g. ZCL_STATUS_FAILURE). Callback Function Parameters:
The length of the data to be written in this invocation
The data to be written |
| write_tag
enum ZclStatusCodeT (*write_tag)(struct ZbZclClusterT *cluster, struct ZbZclOtaHeader *header, uint16_t tag_id, uint32_t tag_length, uint8_t data_length, uint8_t *data, void *arg)
Callback to write tag sub-element information. Normally this is left as-is after the cluster is allocated to use the default internal callback handler. The default handler will call the 'write_image' callback to process any image tag data (i.e. the actual firmware binary). Callback Function Parameters:
A pointer to the OTA header from the start of the transferred, see Table 11-2 OTA Header Fields in the OTA spec
The tag id for the data to be written, see Table 11-9 Tag Identifiers
The total length of data assocated with this tag. This value will remain constant for a given image for each tag id
The data to be written Return Code: ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error (e.g. ZCL_STATUS_FAILURE). |
| write_image
enum ZclStatusCodeT (*write_image)(struct ZbZclClusterT *cluster, struct ZbZclOtaHeader *header, uint8_t length, uint8_t *data, void *arg)
If not NULL, this is called by the cluster’s default 'write_tag' handler for ZCL_OTA_SUB_TAG_UPGRADE_IMAGE data. If the application has provided its own 'write_tag' handler, then this callback is not used. Callback Function Parameters:
A pointer to the OTA header.
| integrity_code
void (*integrity_code)(struct ZbZclClusterT *cluster, struct ZbZclOtaHeader *header, uint8_t length, uint8_t *data, void *arg)
If not NULL, this is called upon reception of the IMAGE_INTEGRITY_CODE sub-tag field. The 'data' parameter will contain the 16-byte hash value. This is used in conjunction with the 'update_raw' callback, which is called for all data up to just before the IMAGE_INTEGRITY_CODE sub-tag. |
| image_validate
enum ZclStatusCodeT (*image_validate)(struct ZbZclClusterT *cluster, struct ZbZclOtaHeader *header, void *arg)
If not NULL, this is called to validate the image, such as the hash. If NULL, and the image is verified using a Security Certificate, the application must provide a valid ca_pub_key_array parameter in ZbZclOtaClientConfig at initialization. Return code is ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error (e.g. ZCL_STATUS_FAILURE). Callback Function Parameters: header A pointer to the OTA header from the start of the transferred, see Table 11-2 OTA Header Fields in the OTA specification. Return Code:
The the image has passed validation and the upgrade is ready to proceed.
Validation of the image has failed
This image has passed validation, but this device requires more images which are yet to be received before performing an upgrade. The application will need to use one of the CheckForUpdate API calls to locate then transfer the remaining images. When all images have been successfully transferred and validated a SUCCESS status should should be returned instead.
The client is aborting the upgrade. These status codes are used to notify the OTA server of the completion of the transfer via the UpgradeEnd message. |
| upgrade_end
enum ZclStatusCodeT (*upgrade_end)(struct ZbZclClusterT *cluster, struct ZbZclOtaHeader *header, uint32_t current_time, uint32_t upgrade_time, void *arg)
Callback to handle an Upgrade End Response command, which specifies the time to perform the reboot and start using the updated firmware. If using the default callback handler defined by ZbZclOtaClientGetDefaultCallbacks, the 'reboot' callback will be called when the transfer has completed succesfully and it’s time for the upgrade to take place. If the application has selected the "Out-of-band" Activation Policy, then it’s best for the application to define its own 'upgrade_end' callback to decide when to perform the upgrade. The callback should update the ZCL_OTA_ATTR_IMAGE_UPGRADE_STATUS attribute accordingly. Writing ZCL_OTA_STATUS_NORMAL to the ZCL_OTA_ATTR_IMAGE_UPGRADE_STATUS attribute will reset the cluster back to defaults. If the callback returns ZCL_STATUS_SUCCESS, the cluster data is not reset, since the OTA upgrade may be waiting to finish through an external event or timeout. Return code is ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error (e.g. ZCL_STATUS_FAILURE). If the callback returns an error, the cluster is reset back to defaults. Callback Function Parameters:
| reboot
void (*reboot)(struct ZbZclClusterT *cluster, void *arg)
If using the default 'upgrade_end' handler, then a callback must be provided by the application. This is called by the 'upgrade_end' handler if the OTA download was successful, to indicate it is now time to reboot the system. |
| abort_download
enum ZclStatusCodeT (*abort_download)(struct ZbZclClusterT *cluster, enum ZbZclOtaCommandId commandId, void *arg)
Callback to inform application of a problem with the download. It gives the application the option to perform network diagnostics or repairs (e.g. NWK Route Discovery) before attempting to restart the OTA transfer where it left off. The application can also tell the OTA Client to abort this transfer by returning ZCL_STATUS_SUCCESS. This callback cannot be set to NULL. The commandId is the OTA command responsible for aborting the transmission (e.g. ZCL_OTA_COMMAND_IMAGE_BLOCK_RESPONSE). If the application returns ZCL_STATUS_SUCCESS, the OTA transfer will be aborted and cluster reset to defaults, ready for a new transfer. If the application returns an error (i.e. ZCL_STATUS_FAILURE), the OTA transfer will be paused rather than aborted, and can be resumed by the application calling ZbZclOtaClientImageTransferResume. Callback Function Parameters:
The associated command responsible for this callback. E.g. Image Block Request (0x04) if there was a problem sending the command to retrieve more data, or Image Block Response (0x05) if the block response contained the ABORT status code. Return Code:
The OTA transfer will be aborted and cluster reset to defaults, ready for a new transfer.
The OTA transfer will be paused rather than aborted, and can be resumed by the application calling ZbZclOtaClientImageTransferResume. The application may use this opportunity to perform a Route Discovery of the OTA Server or try to poll the OTA Server until it comes back online and communication is able to resume. Refer to the Resume a Partial Download section for more information. |
OTA Upgrade Client Configuration structure
Parameters
| uint16_t profile_id | Profile ID |
| uint8_t endpoint | Endpoint on which the cluster is created on |
| enum ZbZclOtaActivationPolicy
activation_policy |
Activation Policy |
| enum ZbZclOtaTimeoutPolicy
timeout_policy |
Timeout Policy - Value written to ZCL_OTA_ATTR_UPGRADE_TIMEOUT_POLICY |
| uint32_t image_block_delay | Image block delay - milliseconds |
| struct ZbZclOtaHeader current_image | OTA Upgrade Header Fields structure. This is used to configure the client’s attributes that describe the firmware image currently running on the device. |
| uint16_t hardware_version | Revision (0x00NN). Included in the Query Next Image command. |
| const uint8_t *ca_pub_key_array | CA Public Key array |
| unsigned int ca_pub_key_len | CA Public Key array length |
callbacks |
Client callback functions |
Upgrade End Response command structure
Parameters
| uint32_t current_time | Current time |
| uint32_t upgrade_time | Upgrade time |
ZbZclOtaHeader
Parameters
| uint32_t file_identifier | OTA Upgrade file identifier |
| uint16_t header_version | OTA Header version |
| uint16_t header_length | OTA Header length |
| uint16_t header_field_control | OTA Header Field control |
| uint16_t manufacturer_code | Manufacturer code |
| uint16_t image_type | Image type |
| uint32_t file_version | File version |
| uint16_t stack_version | Zigbee Stack version |
| uint8_t header_string | OTA Header string |
| uint32_t total_image_size | Total Image size (including header) |
| uint8_t sec_credential_version | Security credential version (Optional) |
| uint64_t file_destination | Upgrade file destination (Optional) |
| uint16_t min_hardware_version | Minimum hardware version (Optional) |
| uint16_t max_hardware_version | Maximum hardware version (Optional) |
ZbZclOtaImageData
OTA Upgrade Image Data structure
Parameters
| uint32_t file_offset | File Offset |
| uint8_t data_size | Data Size |
| uint8_t data | Data |
Parameters
ZbZclOtaImageWaitForData
Image Block Response Command Payload with WAIT_FOR_DATA status structure
Parameters
| uint32_t request_time | Request time |
| uint16_t minimum_block_period | MinimumBlock Period |
Parameters
| uint16_t minimum_block_period | Minimum block period |
| uint32_t upgrade_end_current_time | Upgrade End Current Time |
| uint32_t upgrade_end_upgrade_time | Upgrade End Upgrade Time |
| ZbZclOtaServerImageEvalT image_eval | Callback to determine if a suitable image exists |
| ZbZclOtaServerImageReadT image_read | Callback read image data from the server |
| ZbZclOtaServerUpgradeEndReqT
image_upgrade_end_req |
Callback to handle client Upgrade End request |
| void *arg | Pointer to application data that will later be provided back to the callback function when invoked |
11. Poll Control
#include "zcl/general/zcl.poll.control.h"
Description
ZCL 8 section 3.16
A Sleepy End Device (SED) may instantiate the Poll Control server to allow external devices to control its polling behaviour, including a short interval of rapid polling in order to communicate with the SED in a timely fashion. SEDs are usually in their sleep state where they are not able to receive packets, and devices may not know when those SEDs are awake and polling for data. The Poll Control cluster is used to solve this dilemma.
Devices with Poll Control clients can use Finding & Binding to create the bindings necessary to communicate with the Poll Control servers. The Poll Control server will perform periodic check-ins with any bound Poll Control clients, where the check-in response may ask the SED to start fast polling to allow the server device to exchange messages with it.
Functions
zcl_poll_client_alloc
struct ZbZclClusterT * zcl_poll_client_alloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclPollControlClientCallbackT *callbacks, void *arg);
Create a new instance of the Poll Control Client cluster
Parameters
Return
zcl_poll_client_set_checkin_rsp
enum ZclStatusCodeT zcl_poll_client_set_checkin_rsp(struct ZbZclClusterT *cluster, struct ZbZclPollControlClientCheckinInfo *info);
Set Check-in Response configuration
Parameters
| info | Check-in configuration info |
Return
zcl_poll_client_set_long_intvl_req
enum ZclStatusCodeT zcl_poll_client_set_long_intvl_req(struct ZbZclClusterT *cluster, struct ZbZclPollControlClientSetLongReq *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Long Interval command
Parameters
| req | Set Long Interval command request structure |
Return
zcl_poll_client_set_short_intvl_req
enum ZclStatusCodeT zcl_poll_client_set_short_intvl_req(struct ZbZclClusterT *cluster, struct ZbZclPollControlClientSetShortReq *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Short Interval command
Parameters
| req | Set Short Interval command request structure |
Return
zcl_poll_client_stop_fastpoll_req
enum ZclStatusCodeT zcl_poll_client_stop_fastpoll_req(struct ZbZclClusterT *cluster, struct ZbZclPollControlClientStopReq *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Fast Poll Stop command
Parameters
| req | Fast Poll Stop command request structure |
Return
zcl_poll_server_alloc
struct ZbZclClusterT * zcl_poll_server_alloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclPollControlServerCallbackT *callbacks, void *arg);
Create a new instance of the Poll Control Server cluster
Parameters
Return
zcl_poll_server_send_checkin
enum ZclStatusCodeT zcl_poll_server_send_checkin(struct ZbZclClusterT *cluster);
Send a Check-in command to any bound Clients.
Parameters
Return
Enumerations
ZbZclPollControlSvrAttrT
Poll Control Server Attribute IDs
| ZCL_POLL_CHECK_IN_INTERVAL | Check-inInterval. Range is (0, 0x6E0000), where 0 means disabled. 0x6E0000 = 7208960 qs = ~500 hours. Other than 0, the Min value is also governed by ZCL_POLL_CHECK_IN_INTERVAL_MIN. |
| ZCL_POLL_LONG_POLL_INTERVAL | LongPollInterval. Range is (0x04, 0x6E0000) = (1 sec, ~500 hours). Min value is also governed by the value of ZCL_POLL_LONG_POLL_INTERVAL_MIN. |
| ZCL_POLL_SHORT_POLL_INTERVAL | ShortPollInterval. Range is (1, 4) = (250 ms, 1 sec) |
| ZCL_POLL_FAST_POLL_TIMEOUT | FastPollTimeout. Range is (0x0001, 0xffff) = (250 ms, 4.55 hours). Max value is also governed by the value of ZCL_POLL_FAST_POLL_TIMEOUT_MAX. |
| ZCL_POLL_CHECK_IN_INTERVAL_MIN | Check-inIntervalMin (Optional). Range is (0, 0x6E0000) |
| ZCL_POLL_LONG_POLL_INTERVAL_MIN | LongPollIntervalMin (Optional). Range is (0x4, 0x6E0000) |
| ZCL_POLL_FAST_POLL_TIMEOUT_MAX | FastPollTimeoutMax (Optional). Range is (0x2, 0xffff) |
| ZCL_POLL_LONG_POLL_FROM_CLUSTER | If True, the Poll Server cluster will perform the NLME- SYNC.request (polling) at the interval given by the 'LongPollInterval' (ZCL_POLL_LONG_POLL_INTERVAL). If False, the Poll Server will only expose the 'LongPollInterval' via the attribute to devices that want to read it, but the application will be responsible for any long polling it wants to do. Default is False (disabled), meaning the cluster will not perform an NLME- SYNC.request at the long poll intervals. |
| ZCL_POLL_CHECK_IN_RSP_WAIT_AFTER | If True, then wait for the full check-in response timeout before stopping fast-polling for responses. If False, then as soon as the number of received check-in responses matches the number of bound clients, then stop fast-polling immediately. Note that this is an Exegin custom attribute and not exposed to the network. |
Structures
Poll Control Client callbacks configuration
Parameters
| checkin_rsp_callback
enum ZclStatusCodeT (*checkin_rsp_callback)(struct ZbZclClusterT *clusterPtr, struct zcl_poll_checkin_rsp_t *rsp_info, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Check-in Response command |
Check-in Info structure
Parameters
| struct ZbApsAddrT dst | Destination Address |
| bool start_fast_poll | Start Fast Poll |
| uint16_t fast_poll_timeout | Fast Poll Timeout |
| bool auto_refresh | If true, check-in response is automatically refreshed for the next check-in request. If false, this is a one-time event. |
Set Long Poll Interval command structure
Parameters
| uint32_t interval | NewLongPollInterval |
Set Short Poll Interval command structure
Parameters
| uint16_t interval | New Short Poll Interval |
Fast Poll Stop command structure
Parameters
Poll Control Server callbacks configuration
Parameters
| checkin_rsp
bool (*checkin_rsp)(struct ZbZclClusterT *clusterPtr, struct zcl_poll_checkin_rsp_t *rsp_info, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Check-in Response command. If the callback returns true, then the Check-in Response is allowed to start fast polling. The ZCL8 Spec makes it optional whether these commands allow the device to start fast polling, even if "Start Fast Polling" payload parameter is set to true. If the callback return false, then this command shall not have an effect on fast polling. |
Check-in Response command structure
Parameters
| enum ZclStatusCodeT status | Status |
| bool start_fast_poll | Start Fast Polling |
12. Power Configuration
#include "zcl/general/zcl.power.config.h"
Functions
ZbZclPowerConfigClientAlloc
struct ZbZclClusterT * ZbZclPowerConfigClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Power Configuration Client cluster
Parameters
Return
ZbZclPowerConfigServerAlloc
struct ZbZclClusterT * ZbZclPowerConfigServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Power Configuration Server cluster
Parameters
Return
Enumerations
ZbZclPowerConfigSvrAttrT
Power Configuration Server Attributes IDs
| ZCL_POWER_CONFIG_ATTR_MAINS_VOLTAGE | MainsVoltage (Optional) |
| ZCL_POWER_CONFIG_ATTR_MAINS_FREQ | MainsFrequency (Optional) |
| ZCL_POWER_CONFIG_ATTR_MAINS_ALARM_MASK | MainsAlarmMask (Optional) |
| ZCL_POWER_CONFIG_ATTR_MAINS_VOLT_MIN | MainsVoltageMinThreshold (Optional) |
| ZCL_POWER_CONFIG_ATTR_MAINS_VOLT_MAX | MainsVoltageMaxThreshold (Optional) |
| ZCL_POWER_CONFIG_ATTR_MAINS_VOLT_DWELL | MainsVoltageDwellTripPoint (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_VOLTAGE | BatteryVoltage (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_PCT | BatteryPercentageRemaining (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_MFR_NAME | BatteryManufacturer (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_SIZE | BatterySize (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_AHRRATING | BatteryAHrRating (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_QUANTITY | BatteryQuantity (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_RATED_VOLT | BatteryRatedVoltage (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_ALARM_MASK | BatteryAlarmMask (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_VOLT_MIN | BatteryVoltageMinThreshold (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_VTHRESHOLD1 | BatteryVoltageThreshold1 (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_VTHRESHOLD2 | BatteryVoltageThreshold2 (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_VTHRESHOLD3 | BatteryVoltageThreshold3 (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_PCT_MIN | BatteryPercentageMinThreshold (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_PTHRESHOLD1 | BatteryPercentageThreshold1 (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_PTHRESHOLD2 | BatteryPercentageThreshold2 (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_PTHRESHOLD3 | BatteryPercentageThreshold3 (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_ALARM_STATE | BatteryAlarmState (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_VOLTAGE | BatteryVoltage - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_PCT | BatteryPercentageRemaining - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_MFR_NAME | BatteryManufacturer - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_SIZE | BatterySize - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_AHRRATING | BatteryAHrRating - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_QUANTITY | BatteryQuantity - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_RATED_VOLT | BatteryRatedVoltage - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_ALARM_MASK | BatteryAlarmMask - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_VOLT_MIN | BatteryVoltageMinThreshold - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_VTHRESHOLD1 | BatteryVoltageThreshold1 - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_VTHRESHOLD2 | BatteryVoltageThreshold2 - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_VTHRESHOLD3 | BatteryVoltageThreshold3 - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_PCT_MIN | BatteryPercentageMinThreshold - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_PTHRESHOLD1 | BatteryPercentageThreshold1 - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_PTHRESHOLD2 | BatteryPercentageThreshold2 - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_PTHRESHOLD3 | BatteryPercentageThreshold3 - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_ALARM_STATE | BatteryAlarmState - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_VOLTAGE | BatteryVoltage - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_PCT | BatteryPercentageRemaining - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_MFR_NAME | BatteryManufacturer - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_SIZE | BatterySize - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_AHRRATING | BatteryAHrRating - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_QUANTITY | BatteryQuantity - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_RATED_VOLT | BatteryRatedVoltage - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_ALARM_MASK | BatteryAlarmMask - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_VOLT_MIN | BatteryVoltageMinThreshold - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_VTHRESHOLD1 | BatteryVoltageThreshold1 - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_VTHRESHOLD2 | BatteryVoltageThreshold2 - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_VTHRESHOLD3 | BatteryVoltageThreshold3 - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_PCT_MIN | BatteryPercentageMinThreshold - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_PTHRESHOLD1 | BatteryPercentageThreshold1 - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_PTHRESHOLD2 | BatteryPercentageThreshold2 - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_PTHRESHOLD3 | BatteryPercentageThreshold3 - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_ALARM_STATE | BatteryAlarmState - Third Battery (Optional) |
13. Power Profile
#include "zcl/general/zcl.power.profile.h"
Functions
ZbZclPowerProfClientAlloc
struct ZbZclClusterT * ZbZclPowerProfClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclPowerProfClientCallbacks *callbacks, void *arg);
Create a new instance of the Power Profile Client cluster
Parameters
Return
ZbZclPowerProfClientPhasesNotify
enum ZclStatusCodeT ZbZclPowerProfClientPhasesNotify(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfCliPhasesNotify *notify, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Energy Phases Schedule Notification command
Parameters
| notify | Energy Phases Schedule Notification command structure |
Return
ZbZclPowerProfClientPhasesResponse
enum ZclStatusCodeT ZbZclPowerProfClientPhasesResponse(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPowerProfCliPhasesNotify *notify, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a EnergyPhasesScheduleResponse command
Parameters
| dst | Destination address for response, including sequence number and tx options |
| rsp | EnergyPhasesScheduleResponse command response structure |
Return
ZbZclPowerProfClientPhasesSchedStateReq
enum ZclStatusCodeT ZbZclPowerProfClientPhasesSchedStateReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfCliProfileReq *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a EnergyPhasesScheduleStateRequest command
Parameters
| req | EnergyPhasesScheduleStateRequest command request structure |
Return
ZbZclPowerProfClientPriceExtRsp
enum ZclStatusCodeT ZbZclPowerProfClientPriceExtRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPowerProfCliPriceRsp *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a GetPowerProfilePriceExtendedResponse command
Parameters
| rsp | GetPowerProfilePriceExtendedResponse command response structure |
Return
ZbZclPowerProfClientPriceRsp
enum ZclStatusCodeT ZbZclPowerProfClientPriceRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPowerProfCliPriceRsp *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a GetPowerProfilePriceResponse command
Parameters
| rsp | GetPowerProfilePriceResponse command response structure |
Return
ZbZclPowerProfClientProfileReq
enum ZclStatusCodeT ZbZclPowerProfClientProfileReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfCliProfileReq *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a PowerProfileRequest command
Parameters
| req | PowerProfileRequest command request structure |
Return
ZbZclPowerProfClientSchedConsReq
enum ZclStatusCodeT ZbZclPowerProfClientSchedConsReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfCliProfileReq *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a PowerProfileScheduleConstraintsRequest command
Parameters
| req | PowerProfileScheduleConstraintsRequest command request structure |
Return
ZbZclPowerProfClientSchedPriceRsp
enum ZclStatusCodeT ZbZclPowerProfClientSchedPriceRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPowerProfCliSchedPriceRsp *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a GetOverallSchedulePriceResponse command
Parameters
| rsp | GetOverallSchedulePriceResponse command response structure |
Return
ZbZclPowerProfClientStateReq
enum ZclStatusCodeT ZbZclPowerProfClientStateReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a PowerProfileStateRequest command
Parameters
Return
ZbZclPowerProfServerAlloc
struct ZbZclClusterT * ZbZclPowerProfServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclPowerProfServerCallbacks *callbacks, void *arg);
Create a new instance of the Power Profile Server cluster
Parameters
Return
ZbZclPowerProfServerConstraintsNotify
enum ZclStatusCodeT ZbZclPowerProfServerConstraintsNotify(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfSvrConstraintsNotify *notify, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a PowerProfileScheduleConstraintsNotification Command
Parameters
| notify | PowerProfileScheduleConstraintsNotification command structure |
Return
ZbZclPowerProfServerConstraintsRsp
enum ZclStatusCodeT ZbZclPowerProfServerConstraintsRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPowerProfSvrConstraintsNotify *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a PowerProfileScheduleConstraintsResponse command
Parameters
| rsp | PowerProfileScheduleConstraintsResponse command response structure |
Return
ZbZclPowerProfServerGetPriceReq
enum ZclStatusCodeT ZbZclPowerProfServerGetPriceReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfCliProfileReq *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a GetPowerProfilePrice command
Parameters
| req | GetPowerProfilePrice command request structure |
Return
ZbZclPowerProfServerGetPriceReqExtReq
enum ZclStatusCodeT ZbZclPowerProfServerGetPriceReqExtReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfSvrGetPriceExtReq *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a GetPowerProfilePriceExtended command
Parameters
| req | GetPowerProfilePriceExtended command request structure |
Return
ZbZclPowerProfServerGetSchedPriceReq
enum ZclStatusCodeT ZbZclPowerProfServerGetSchedPriceReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a GetOverallSchedulePrice command
Parameters
| req | GetOverallSchedulePrice command request structure |
Return
ZbZclPowerProfServerPhasesNotify
enum ZclStatusCodeT ZbZclPowerProfServerPhasesNotify(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfSvrPhasesRsp *notify, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a EnergyPhasesScheduleStateNotification Command
Parameters
| notify | EnergyPhasesScheduleStateNotification command structure |
Return
ZbZclPowerProfServerPhasesReq
enum ZclStatusCodeT ZbZclPowerProfServerPhasesReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfCliProfileReq *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a EnergyPhasesScheduleRequest command
Parameters
| req | EnergyPhasesScheduleRequest command request structure |
Return
ZbZclPowerProfServerPhasesRsp
enum ZclStatusCodeT ZbZclPowerProfServerPhasesRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPowerProfSvrPhasesRsp *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a EnergyPhasesScheduleStateResponse command
Parameters
| rsp | EnergyPhasesScheduleStateResponse command response structure |
Return
ZbZclPowerProfServerProfileNotify
enum ZclStatusCodeT ZbZclPowerProfServerProfileNotify(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfSvrProfileRsp *notify, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a PowerProfileNotification Command. It is sent as a ZCL request with a unique sequence number, and can receive a Default Response if applicable
Parameters
| notify | PowerProfileNotification command structure |
Return
ZbZclPowerProfServerProfileRsp
enum ZclStatusCodeT ZbZclPowerProfServerProfileRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPowerProfSvrProfileRsp *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a PowerProfileResponse command
Parameters
| rsp | PowerProfileResponse command response structure |
Return
ZbZclPowerProfServerStateNotify
enum ZclStatusCodeT ZbZclPowerProfServerStateNotify(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfSvrStateRsp *notify, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a PowerProfileStateNotification Command
Parameters
| notify | PowerProfileStateNotification command structure |
Return
ZbZclPowerProfServerStateRsp
enum ZclStatusCodeT ZbZclPowerProfServerStateRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPowerProfSvrStateRsp *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a PowerProfileStateResponse command
Parameters
| rsp | PowerProfileStateResponse command response structure |
Return
Enumerations
ZbZclPowerProfileSvrAttrT
Power Profile Server Attribute IDs
| ZCL_POWER_PROF_SVR_ATTR_TOTAL_PROFILENUM | TotalProfileNum |
| ZCL_POWER_PROF_SVR_ATTR_MULTIPLE_SCHED | MultipleScheduling |
| ZCL_POWER_PROF_SVR_ATTR_ENERGY_FORMAT | EnergyFormatting |
| ZCL_POWER_PROF_SVR_ATTR_ENERGY_REMOTE | EnergyRemote |
| ZCL_POWER_PROF_SVR_ATTR_SCHEDULE_MODE | ScheduleMode |
Structures
Parameters
| uint8_t profile_id | Power ProfileID |
| uint8_t num_phases | Num of Scheduled Phases |
| struct ZbZclPowerProfSchedPhase
sched_list |
Schedule List |
GetPowerProfilePriceResponse command structure
Parameters
| uint8_t profile_id | Power Profile ID |
| uint16_t currency | Currency |
| uint32_t price | Price |
| uint8_t trailing_digit | Price Trailing Digit |
PowerProfileRequest command structure
Parameters
| uint8_t profile_id | PowerProfileID |
GetOverallSchedulePriceResponse command structure
Parameters
Power Profile Client callbacks configuration
Parameters
| profile_notify
enum ZclStatusCodeT (*profile_notify)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfSvrProfileRsp *notify, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of PowerProfileNotification command |
| get_price
enum ZclStatusCodeT (*get_price)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfCliProfileReq *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of GetPowerProfilePrice command |
| state_notify
enum ZclStatusCodeT (*state_notify)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfSvrStateRsp *notify, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of PowerProfileStateNotification command |
| get_sched_price
enum ZclStatusCodeT (*get_sched_price)(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of GetOverallSchedulePrice command |
| phases_req
enum ZclStatusCodeT (*phases_req)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfCliProfileReq *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of EnergyPhasesScheduleRequest command |
| phases_notify
enum ZclStatusCodeT (*phases_notify)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfSvrPhasesRsp *notify, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of EnergyPhasesScheduleStateNotification command |
| constraints_notify
enum ZclStatusCodeT (*constraints_notify)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfSvrConstraintsNotify *notify, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of PowerProfileScheduleConstraintsNotification command |
| get_price_ext
enum ZclStatusCodeT (*get_price_ext)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfSvrGetPriceExtReq *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of GetPowerProfilePriceExtended command |
ZbZclPowerProfPhase
Phase structure
Parameters
| uint8_t energy_phase_id | Energy PhaseID |
| uint8_t macro_phase_id | Macro PhaseID |
| uint16_t expect_duration | ExpectedDuration |
| uint16_t peak_power | Peak Power |
| uint16_t energy | Energy |
| uint16_t max_activation_delay | MaxActivationDelay |
Schedule Phase structure
Parameters
| uint16_t sched_time | Scheduled Time |
Power Profile Server callbacks configuration
Parameters
| profile_req
enum ZclStatusCodeT (*profile_req)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfCliProfileReq *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of PowerProfileRequest command |
| state_req
enum ZclStatusCodeT (*state_req)(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of PowerProfileStateRequest command |
| phases_notify
enum ZclStatusCodeT (*phases_notify)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfCliPhasesNotify *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Energy Phases Schedule Notification command |
| sched_contraints_req
enum ZclStatusCodeT (*sched_contraints_req)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfCliProfileReq *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of PowerProfileScheduleConstraintsRequest command |
| phases_sched_state_req
enum ZclStatusCodeT (*phases_sched_state_req)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfCliProfileReq *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of EnergyPhasesScheduleStateRequest command |
Parameters
| uint16_t start_after | Start After |
| uint16_t stop_before | Stop Before |
GetPowerProfilePriceExtended command structure
Parameters
| uint8_t options | Options - e.g. ZCL_PWR_PROF_PRICE_EXT_OPT_START_TIME_PRESENT |
| uint16_t start_time | PowerProfileStartTime - optional (ZCL_PWR_PROF_PRICE_EXT_OPT_START_TIME_PRESENT) |
Energy Phases Schedule Notification and EnergyPhasesScheduleResponse command structure
Parameters
| uint8_t num_sched_energy_phases | Num of Scheduled Phases |
PowerProfileNotification and PowerProfileResponse command structure
Parameters
| uint8_t total_profile_num | Total Profile Num |
| uint8_t num_transferred_phases | Num of Transferred Phases |
| struct ZbZclPowerProfPhase phase_list | Phase List |
PowerProfileStateResponse command structure
Parameters
| uint8_t profile_count | Power Profile Count |
| struct ZbZclPowerProfileRecord record_list | Record List |
Record structure
Parameters
| uint8_t energy_phase_id | Energy Phase ID |
| uint8_t remote_control | PowerProfileRemoteControl |
| enum ZbZclPowerProfState state | PowerProfile State |
14. Pressure Measurement
#include "zcl/general/zcl.press.meas.h"
Functions
ZbZclPressMeasClientAlloc
struct ZbZclClusterT * ZbZclPressMeasClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Pressure Measurement Client cluster
Parameters
| zb | Zigbee stack instance |
| endpoint | Endpoint on which to create cluster |
Return
- Cluster pointer, or NULL if there is an error
ZbZclPressMeasServerAlloc
struct ZbZclClusterT * ZbZclPressMeasServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, int16_t min, int16_t max);
Create a new instance of the Pressure Measurement Server cluster
Parameters
| min | Default minimum measured value written to ZCL_PRESS_MEAS_ATTR_MIN_MEAS_VAL attribute during allocation |
| max | Default maximum measured value written to ZCL_PRESS_MEAS_ATTR_MAX_MEAS_VAL attribute during allocation |
Return
Enumerations
ZbZclPressMeasSvrAttrT
Pressure Measurement Attribute IDs
| ZCL_PRESS_MEAS_ATTR_MEAS_VAL | MeasuredValue |
| ZCL_PRESS_MEAS_ATTR_MIN_MEAS_VAL | MinMeasuredValue |
| ZCL_PRESS_MEAS_ATTR_MAX_MEAS_VAL | MaxMeasuredValue |
| ZCL_PRESS_MEAS_ATTR_TOLERANCE | Tolerance (Optional) |
| ZCL_PRESS_MEAS_ATTR_SCALED_VAL | ScaledValue (Optional) |
| ZCL_PRESS_MEAS_ATTR_MIN_SCALED_VAL | MinScaledValue (Optional) |
| ZCL_PRESS_MEAS_ATTR_MAX_SCALED_VAL | MaxScaledValue (Optional) |
| ZCL_PRESS_MEAS_ATTR_SCALED_TOL | ScaledTolerance (Optional) |
| ZCL_PRESS_MEAS_ATTR_SCALE | Scale (Optional) |
15. Pump Configuration and Control
#include "zcl/general/zcl.pump.h"
Functions
ZbZclPumpClientAlloc
struct ZbZclClusterT * ZbZclPumpClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Instantiate a new instance of the Pump Configuration and Control client cluster
Parameters
Return
ZbZclPumpServerAlloc
struct ZbZclClusterT * ZbZclPumpServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Instantiate a new instance of the Pump Configuration and Control server cluster
Parameters
Return
Enumerations
ZbZclPumpServerAttrT
Pump Configuration and Control Attribute Ids
| ZCL_PUMP_SVR_ATTR_MAX_PRESSURE | MaxPressure |
| ZCL_PUMP_SVR_ATTR_MAX_SPEED | MaxSpeed |
| ZCL_PUMP_SVR_ATTR_MAX_FLOW | MaxFlow |
| ZCL_PUMP_SVR_ATTR_MIN_CONST_PRESSURE | MinConstPressure |
| ZCL_PUMP_SVR_ATTR_MAX_CONST_PRESSURE | MaxConstPressure |
| ZCL_PUMP_SVR_ATTR_MIN_COMP_PRESSURE | MinCompPressure |
| ZCL_PUMP_SVR_ATTR_MAX_COMP_PRESSURE | MaxCompPressure |
| ZCL_PUMP_SVR_ATTR_MIN_CONST_SPEED | MinConstSpeed |
| ZCL_PUMP_SVR_ATTR_MAX_CONST_SPEED | MaxConstSpeed |
| ZCL_PUMP_SVR_ATTR_MIN_CONST_FLOW | MinConstFlow |
| ZCL_PUMP_SVR_ATTR_MAX_CONST_FLOW | MaxConstFlow |
| ZCL_PUMP_SVR_ATTR_MIN_CONST_TEMP | MinConstTemp |
| ZCL_PUMP_SVR_ATTR_MAX_CONST_TEMP | MaxConstTemp |
| ZCL_PUMP_SVR_ATTR_PUMP_STATUS | PumpStatus |
| ZCL_PUMP_SVR_ATTR_EFF_OP_MODE | EffectiveOperationMode |
| ZCL_PUMP_SVR_ATTR_EFF_CTRL_MODE | EffectiveControlMode |
| ZCL_PUMP_SVR_ATTR_CAPACITY | Capacity |
| ZCL_PUMP_SVR_ATTR_SPEED | Speed |
| ZCL_PUMP_SVR_ATTR_RUNNING_HOURS | LifetimeRunningHours |
| ZCL_PUMP_SVR_ATTR_POWER | Power |
| ZCL_PUMP_SVR_ATTR_ENERGY_CONSUMED | LifetimeEnergyConsumed |
| ZCL_PUMP_SVR_ATTR_OP_MODE | OperationMode |
| ZCL_PUMP_SVR_ATTR_CTRL_MODE | ControlMode |
| ZCL_PUMP_SVR_ATTR_ALARM_MASK | AlarmMask |
16. RSSI Location
#include "zcl/general/zcl.rssi.loc.h"
Functions
ZbZclRssiLocClientAlloc
struct ZbZclClusterT * ZbZclRssiLocClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct zcl_rssi_loc_client_callbacks_t *callbacks, void *arg);
Create a new instance of the RSSI Location Client cluster
Parameters
| callbacks | Structure containing any callback function pointers for this cluster |
| arg | Pointer to application data that will included in the callback when invoked. |
Return
ZbZclRssiLocClientAnchorNodeAnnc
enum ZclStatusCodeT ZbZclRssiLocClientAnchorNodeAnnc(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct rssi_loc_anchor_node_annc *anchor_node_annc, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Anchor Node Announce command
Parameters
| cluster | Cluster instance from which to send this command |
| dst | Destination address for request |
| anchor_node_annc | Anchor Node Announce command structure |
| callback | Callback function that will be invoked when the response is received. |
Return
ZbZclRssiLocClientGetDevConfig
enum ZclStatusCodeT ZbZclRssiLocClientGetDevConfig(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct rssi_loc_get_dev_config *get_dev_config, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Device Configuration command
Parameters
| get_dev_config | Get Device Configuration command structure |
Return
ZbZclRssiLocClientGetLocData
enum ZclStatusCodeT ZbZclRssiLocClientGetLocData(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct rssi_loc_get_loc_data *get_loc_data, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Location Data command
Parameters
| get_loc_data | Get Location Data command structure |
Return
ZbZclRssiLocClientSendPings
enum ZclStatusCodeT ZbZclRssiLocClientSendPings(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct rssi_loc_send_pings *send_pings, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Send Pings command
Parameters
| send_pings | Send Pings command structure |
Return
ZbZclRssiLocClientSendRssiRsp
enum ZclStatusCodeT ZbZclRssiLocClientSendRssiRsp(struct ZbZclClusterT *clusterPtr, struct ZbZclAddrInfoT *dst_info, struct rssi_loc_rssi_rsp *rsp);
Send a RSSI Response command
Parameters
| clusterPtr | Cluster instance from which to send this command |
| dst_info | Destination address for request |
| rsp | Rssi Response structure |
Return
ZbZclRssiLocClientSetAbsLocation
enum ZclStatusCodeT ZbZclRssiLocClientSetAbsLocation(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct rssi_loc_set_abs_loc *set_abs_loc, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Absolute Location command
Parameters
| set_abs_loc | Set Absolute Location command structure |
Return
ZbZclRssiLocClientSetDevConfig
enum ZclStatusCodeT ZbZclRssiLocClientSetDevConfig(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct rssi_loc_set_dev_config *set_dev_config, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Device Configuration command
Parameters
| set_dev_config | Set Device Config command structure |
Return
ZbZclRssiLocServerAlloc
struct ZbZclClusterT * ZbZclRssiLocServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct zcl_rssi_loc_server_callbacks_t *callbacks, void *arg);
Create a new instance of the RSSI Location Server cluster
Parameters
Return
ZbZclRssiLocServerCompDataNotif
enum ZclStatusCodeT ZbZclRssiLocServerCompDataNotif(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Compact Data Notification command
Parameters
Return
ZbZclRssiLocServerLocDataNotif
enum ZclStatusCodeT ZbZclRssiLocServerLocDataNotif(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Location Data Notification command
Parameters
Return
ZbZclRssiLocServerReportRssi
enum ZclStatusCodeT ZbZclRssiLocServerReportRssi(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct rssi_loc_report_rssi *report_rssi, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Report RSSI command
Parameters
| report_rssi | Report Rssi command structure |
Return
ZbZclRssiLocServerReqOwnLoc
enum ZclStatusCodeT ZbZclRssiLocServerReqOwnLoc(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct rssi_loc_req_own_loc *req_own_loc, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Request Own Location command
Parameters
| req_own_loc | Request Own Location command structure |
Return
ZbZclRssiLocServerRssiPing
enum ZclStatusCodeT ZbZclRssiLocServerRssiPing(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a RSSI Ping command
Parameters
Return
ZbZclRssiLocServerRssiReq
enum ZclStatusCodeT ZbZclRssiLocServerRssiReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a RSSI Request command
Parameters
Return
ZbZclRssiLocServerSendDevConfigRsp
enum ZclStatusCodeT ZbZclRssiLocServerSendDevConfigRsp(struct ZbZclClusterT *clusterPtr, struct ZbZclAddrInfoT *dst_info, struct rssi_loc_dev_config_rsp *rsp);
Send a Device Configuration Response command
Parameters
| rsp | Send Device Configuration response structure |
Return
ZbZclRssiLocServerSendLocDataRsp
enum ZclStatusCodeT ZbZclRssiLocServerSendLocDataRsp(struct ZbZclClusterT *clusterPtr, struct ZbZclAddrInfoT *dst_info, struct rssi_loc_loc_data_rsp *rsp);
Send a Location Data Response command
Parameters
| rsp | Send Location Data response structure |
Return
Enumerations
ZbZclRssiLocSvrAttrT
Rssi Location Attribute IDs
| ZCL_RSSI_LOC_SVR_ATTR_LOCATION_TYPE | LocationType |
| ZCL_RSSI_LOC_SVR_ATTR_LOCATION_METHOD | LocationMethod |
| ZCL_RSSI_LOC_SVR_ATTR_LOCATION_AGE | LocationAge (Optional) |
| ZCL_RSSI_LOC_SVR_ATTR_QUALITY_MEAS | QualityMeasure (Optional) |
| ZCL_RSSI_LOC_SVR_ATTR_NUM_DEVICES | NumberOfDevices (Optional) |
| ZCL_RSSI_LOC_SVR_ATTR_COORD1 | Coordinate1 |
| ZCL_RSSI_LOC_SVR_ATTR_COORD2 | Coordinate2 |
| ZCL_RSSI_LOC_SVR_ATTR_COORD3 | Coordinate3 (Optional) |
| ZCL_RSSI_LOC_SVR_ATTR_POWER | Power |
| ZCL_RSSI_LOC_SVR_ATTR_PATH_LOSS_EXP | PathLossExponent |
| ZCL_RSSI_LOC_SVR_ATTR_REPORT_PERIOD | ReportingPeriod (Optional) |
| ZCL_RSSI_LOC_SVR_ATTR_CALC_PERIOD | CalculationPeriod (Optional) |
| ZCL_RSSI_LOC_SVR_ATTR_NUM_RSSI_MEAS | NumberRSSIMeasurements |
Structures
Parameters
| uint64_t addr | Anchor Node IEEE Address |
| int16_t x | X |
| int16_t y | Y |
| int16_t z | Z |
rssi_loc_comp_data_notif
Compact Data Notification command structure
Parameters
| uint8_t loc_type | Location Type |
| int16_t coord1 | Coordinate 1 |
| int16_t coord2 | Coordinate 2 |
| int16_t coord3 | Coordinate 3 |
| uint8_t quality_meas | Quality Measure |
| uint16_t loc_age | Location Age |
Parameters
| int16_t power | Power |
| uint16_t path_loss_exp | Path Loss Exponent |
| uint16_t calc_period | Calculation Period |
| uint8_t num_rssi_meas | Number RSSI Measurements |
| uint16_t report_period | Reporting Period |
Parameters
| uint64_t target_addr | Target Address |
Parameters
| uint8_t bitmap | Bitmap |
| uint8_t num_responses | Number Responses |
rssi_loc_loc_data_notif
Location Data Notification command structure
Parameters
| uint8_t loc_method | Location Method |
Parameters
rssi_loc_neighbour_info
Neighbour Info structure
Parameters
| uint64_t neighbour | Neighbour |
| int16_t x | X |
| int16_t y | Y |
| int16_t z | Z |
| int8_t rssi | RSSI |
| uint8_t num_rssi_meas | NumberRSSIMeasurements |
Parameters
| uint64_t measuring_dev | Measuring Device |
| uint8_t n_neighbours | N Neighbours |
| struct rssi_loc_neighbour_info neighbours_info | NeighboursInfo |
Parameters
| uint64_t addr | IEEE Address of the Blind Node |
rssi_loc_rssi_ping
Rssi Ping command structure
Parameters
rssi_loc_rssi_req
Rssi Request structure
Parameters
| uint8_t rssi | Rssi |
rssi_loc_rssi_rsp
Rssi response structure
Parameters
| uint64_t replying_dev | Replying Device |
| int16_t x | X |
| int16_t y | Y |
| int16_t z | Z |
rssi_loc_send_pings
Parameters
| uint16_t calc_period | CalculationPeriod |
Parameters
Set Device Configuration command structure
Parameters
| uint8_t num_rssi_meas | Number Rssi Measurements |
Rssi Location Client callbacks configuration
Parameters
| loc_data_notif
(callback function pointer) |
enum ZclStatusCodeT (*loc_data_notif)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_loc_data_notif *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Location Data Notification command |
| comp_data_notif
enum ZclStatusCodeT (*comp_data_notif)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_comp_data_notif *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Compact Data Notification command |
| rssi_ping
enum ZclStatusCodeT (*rssi_ping)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_rssi_ping *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of RSSI Ping command |
| rssi_req
enum ZclStatusCodeT (*rssi_req)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_rssi_req *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of RSSI request. |
| report_rssi
enum ZclStatusCodeT (*report_rssi)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_report_rssi *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Report Rssi command |
| req_own_loc
enum ZclStatusCodeT (*req_own_loc)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_req_own_loc *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Request Own Location command |
Rssi Location Server callbacks configuration
Parameters
| get_dev_config
enum ZclStatusCodeT (*get_dev_config)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_get_dev_config *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Get Device Configuration command |
| get_loc_data
enum ZclStatusCodeT (*get_loc_data)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_get_loc_data *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Get Location Data command |
| send_pings
enum ZclStatusCodeT (*send_pings)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_send_pings *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Send Pings command |
| anchor_node_annc
enum ZclStatusCodeT (*anchor_node_annc)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_anchor_node_annc *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Anchor Node Announce command |
17. Scenes
#include "zcl/general/zcl.scenes.h"
Description
ZCL 8 section 3.7
A scene is a set of values for attributes from multiple clusters capable of being applied at the same time. The few clusters that support scenes are identified by a section with the title "Scene Table Extensions" in the ZCL 8 Specification (ZCL8) section for those cluster. There is only one scene table (list of attributes) for a cluster that supports scenes, and when a scene is invoked all scene table attributes are set to the values given in the scene table.
To use the scene table for a cluster, the cluster must reside on an endpoint which also hosts an instance of the Scenes cluster. There may be multiple scene table supporting clusters on a given endpoint. A scene is defined in the scenes cluster and contains scene tables for one or more clusters. Through the use of group addressing a scene may be applied to multiple endpoints on a node.
A scene may be created by the scene cluster using the Add Scene command, where the application manually defines the scene table for each cluster included in that scene. All attributes must have values in the scene table, but inclusion of individual clusters is optional. A scene may also be created using the Store Scene command where the current value of all the attributes in the cluster at the time the Store Scene command is issued are recorded in the scene table for later use.
The Scenes cluster Recall Scene command takes the scene table for each cluster in that scene and sets the values of every scene table attribute.
For example, a node could contain three endpoints:
- 0x01 with the OnOff and Window Covering clusters
- 0x02 with the OnOff and Door Lock clusters
- 0x03 with the OnOff and Level.
A scene is defined with a scene tables for the:
- OnOff cluster: OnOff = On
- Level cluster: CurrentLevel = 50%
- DoorLock cluster: LockState = Locked
Additionally:
- Endpoints 0x01 and 0x02 are in group 0x0001
- Endpoint 0x03 is not in group 0x0001
If the scenes cluster Recall Scenes command is issued with group address 0x0001 and the scene defined above, then on endpoint
0x01 and 0x02 the OnOff cluster OnOff attribute will be set on and the DoorLock on endpoint 0x02 will be locked.
The Window Covering cluster on endpoint 0x01 will not be affected because this scene does not include a scene table for this cluster and all of endpoint 0x03 will be unaffected because it is not in group 0x0001.
For more information about the Scenes cluster, see Section 3.7 in ZCL8.
Functions
ZbZclScenesClientAlloc
struct ZbZclClusterT * ZbZclScenesClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Scenes Client cluster
Parameters
Return
ZbZclScenesServerAlloc
struct ZbZclClusterT * ZbZclScenesServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, uint8_t maxScenes);
Create a new instance of the Scenes Server cluster
Parameters
| maxScenes | Maximum number of scenes supported by this cluster |
Return
zcl_scenes_client_add_req
enum ZclStatusCodeT zcl_scenes_client_add_req(struct ZbZclClusterT *cluster, struct zcl_scenes_add_request_t *add_req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send an Add Scene or Enhanced Add Scene command, depending on isEnhanced flag in Add Scene command structure
Parameters
| add_req | Add Scene command structure |
| callback | Callback function that will be called when the response for this request is received |
| arg | Pointer to application data provided in initiating API call |
Return
- ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error
zcl_scenes_client_add_rsp_parse
enum ZclStatusCodeT zcl_scenes_client_add_rsp_parse(struct zcl_scenes_add_response_t *add_rsp, struct ZbZclCommandRspT *zcl_rsp);
Parse an Add Scene Response command payload into a structure
Parameters
| add_rsp | Add Scene Response command structure |
| zcl_rsp | Cluster response structure |
Return
zcl_scenes_client_copy_req
enum ZclStatusCodeT zcl_scenes_client_copy_req(struct ZbZclClusterT *cluster, struct zcl_scenes_copy_request_t *copy_req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Copy Scene command
Parameters
| copy_req | Copy Scene command structure |
Return
zcl_scenes_client_copy_rsp_parse
enum ZclStatusCodeT zcl_scenes_client_copy_rsp_parse(struct zcl_scenes_copy_response_t *copy_rsp, struct ZbZclCommandRspT *zcl_rsp);
Parse a Copy Scene Response command payload into a structure
Parameters
| copy_rsp | Copy Scene response command structure |
Return
zcl_scenes_client_get_membership_req
enum ZclStatusCodeT zcl_scenes_client_get_membership_req(struct ZbZclClusterT *cluster, struct zcl_scenes_membership_request_t *get_req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Get Scene Membership command
Parameters
| get_req | Get Scene Membership command structure |
Return
zcl_scenes_client_get_membership_rsp_parse
enum ZclStatusCodeT zcl_scenes_client_get_membership_rsp_parse(struct zcl_scenes_membership_response_t *get_rsp, struct ZbZclCommandRspT *zcl_rsp);
Parse a Get Scene Membership Response command payload into a structure
Parameters
| get_rsp | Get Scene Membership Response command structure |
Return
zcl_scenes_client_recall_req
enum ZclStatusCodeT zcl_scenes_client_recall_req(struct ZbZclClusterT *cluster, struct zcl_scenes_recall_request_t *recall_req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Recall Scene command
Parameters
| recall_req | Recall Scene command structure |
Return
zcl_scenes_client_recall_rsp_parse
enum ZclStatusCodeT zcl_scenes_client_recall_rsp_parse(struct zcl_scenes_recall_response_t *recall_rsp, struct ZbZclCommandRspT *zcl_rsp);
Parse a Recall Scene Response command payload into a structure
Parameters
| recall_rsp | Recall Scene response command structure |
Return
zcl_scenes_client_remove_all_req
enum ZclStatusCodeT zcl_scenes_client_remove_all_req(struct ZbZclClusterT *cluster, struct zcl_scenes_remove_all_request_t *remove_req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Remove All Scenes command
Parameters
| remove_req | Remove All Scenes command structure |
Return
zcl_scenes_client_remove_all_rsp_parse
enum ZclStatusCodeT zcl_scenes_client_remove_all_rsp_parse(struct zcl_scenes_remove_all_response_t *remove_rsp, struct ZbZclCommandRspT *zcl_rsp);
Parse a Remove All Scenes Response command payload into a structure
Parameters
| remove_rsp | Remove All Scenes Response command structure |
Return
zcl_scenes_client_remove_req
enum ZclStatusCodeT zcl_scenes_client_remove_req(struct ZbZclClusterT *cluster, struct zcl_scenes_remove_request_t *remove_req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Remove Scene command
Parameters
| remove_req | Remove Scene command structure |
Return
zcl_scenes_client_remove_rsp_parse
enum ZclStatusCodeT zcl_scenes_client_remove_rsp_parse(struct zcl_scenes_remove_response_t *remove_rsp, struct ZbZclCommandRspT *zcl_rsp);
Parse a Remove Scene Response command payload into a structure
Parameters
| remove_rsp | Remove Scene Response command structure |
Return
zcl_scenes_client_store_req
enum ZclStatusCodeT zcl_scenes_client_store_req(struct ZbZclClusterT *cluster, struct zcl_scenes_store_request_t *store_req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Store Scene command
Parameters
| store_req | Store Scene command structure |
Return
zcl_scenes_client_store_rsp_parse
enum ZclStatusCodeT zcl_scenes_client_store_rsp_parse(struct zcl_scenes_store_response_t *store_rsp, struct ZbZclCommandRspT *zcl_rsp);
Parse a Store Scene Response command payload into a structure
Parameters
| store_rsp | Store Scene Response command structure |
Return
zcl_scenes_client_view_req
enum ZclStatusCodeT zcl_scenes_client_view_req(struct ZbZclClusterT *cluster, struct zcl_scenes_view_request_t *view_req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send an View Scene or Enhanced View Scene command, depending on isEnhanced flag in View Scene command structure
Parameters
| view_req | View Scene command structure |
Return
zcl_scenes_client_view_rsp_parse
enum ZclStatusCodeT zcl_scenes_client_view_rsp_parse(struct zcl_scenes_view_response_t *view_rsp, struct ZbZclCommandRspT *zcl_rsp);
Parse a View Scene Response command payload into a structure
Parameters
| view_rsp | View Scene Response command structure |
Return
Enumerations
ZbZclScenesAttrT
Scenes Attribute IDs
| ZCL_SCENES_ATTR_SCENE_COUNT | SceneCount |
| ZCL_SCENES_ATTR_CURRENT_SCENE | CurrentScene |
| ZCL_SCENES_ATTR_CURRENT_GROUP | CurrentGroup |
| ZCL_SCENES_ATTR_SCENE_VALID | SceneValid |
| ZCL_SCENES_ATTR_NAME_SUPPORT | NameSupport |
| ZCL_SCENES_ATTR_LAST_CONFIGURED_BY | LastConfiguredBy (Optional) |
Structures
Parameters
| bool isEnhanced | If true, send an Enhanced Add Scene request |
| struct ZbApsAddrT dst | Destination address for request |
| uint16_t groupId | Group ID |
| uint8_t sceneId | Scene ID |
| uint16_t transition | Transition time |
| const char *sceneName | Scene Name (string length must be <= ZCL_SCENES_NAME_MAX_LENGTH) |
| const char *extStrPtr | Extension field sets as an ASCII hex string in the format as sent in the command payload. As per the ZCL Spec, each set has the format: {clusterId, length, {extension field set}} E.g. For the OnOff cluster: "06000101" |
Parameters
| uint8_t status | Status |
Parameters
| bool allScenes | Copy All Scenes - sets bit within Mode parameter to enable Copy All Scenes |
| uint16_t groupFrom | Group identifier from |
| uint8_t sceneFrom | Scene identifier from - only used if allScenes is FALSE |
| uint16_t groupTo | Group identifier to |
| uint8_t sceneTo | Scene identifier to - only used if allScenes is FALSE |
Copy Scene Response command structure
Parameters
| uint8_t sceneFrom | Scene identifier from |
Parameters
Parameters
| uint8_t capacity | Capacity |
| uint8_t sceneCount | Scent count |
| uint8_t sceneList | Scene list |
Parameters
| uint16_t transition | Transition time - time in 1/10ths of second. ZCL_SCENES_RECALL_TRANSITION_INVALID (0xffff) means invalid, and won’t be included. (Optional) |
Recall Scene Response command structure
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
| bool isEnhanced | If true, send an Enhanced View Scene request |
Parameters
| char nameStr | Scene Name |
| uint8_t extNum | Number of Extension field sets |
| struct { uint16_t clusterId | Cluster ID |
| uint8_t length | Length |
| uint8_t field | Field - ZCL_SCENES_VIEW_EXT_FIELD_MAX_LEN |
18. Temperature Measurement
#include "zcl/general/zcl.temp.meas.h"
Functions
ZbZclTempMeasClientAlloc
struct ZbZclClusterT * ZbZclTempMeasClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Temperature Measurement Client cluster
Parameters
Return
ZbZclTempMeasServerAlloc
struct ZbZclClusterT * ZbZclTempMeasServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, int16_t min, int16_t max, uint16_t tolerance);
Create a new instance of the Temperature Measurement Server cluster
Parameters
| min | Minimum value capable of being measured (MinMeasuredValue) |
| max | Maximum value capable of being measured (MaxMeasuredValue) |
| tolerance | Tolerance |
Return
Enumerations
ZbZclTempMeasSvrAttrT
Temperature Measurement Server Attribute IDs
| ZCL_TEMP_MEAS_ATTR_MEAS_VAL | MeasuredValue |
| ZCL_TEMP_MEAS_ATTR_MIN_MEAS_VAL | MinMeasuredValue |
| ZCL_TEMP_MEAS_ATTR_MAX_MEAS_VAL | MaxMeasuredValue |
| ZCL_TEMP_MEAS_ATTR_TOLERANCE | Tolerance (Optional) |
