1. Scope
This wiki describes the implementation of the Exegin ZSDK (Zigbee software design kit) API (application programming interface) for the Zigbee Cluster Library available on the STM32WBA Series based on V1.5 STM32Cube Firmware release. It describes all APIs used to control the cluster library.
By default, the ZigbeeCluster is delivered as a library. Nevertheless, it is possible to have access to the source code on demand through an NDA.
2. Introduction
Clusters are related sets of commands and attributes dedicated to a specific type of device, service, or sector. Developers use clusters to build a collection of functions suited to their needs. For example, the OnOff cluster allows applications to turn devices on and off, and contains commands and attributes to support that functionality. A developer would use the OnOff cluster in conjunction with an application to allow a device to be activated or deactivated over a Zigbee network.
This document details the API for Zigbee 3.0 cluster primitives, or "stubs", which Exegin has implemented based on the Zigbee Cluster Library revision 8 Specification [1] and The Zigbee Smart Energy Standard [2]. These cluster stubs must be paired with and modified for an application before they can be considered functional clusters.
For more information about Zigbee PRO network protocol, see [3].
For more information about cluster architecture and operations, see [1].
3. Overview
This section of the document provides basic information about cluster architecture and operation, covering such topics as:
- Client-Server Relationship
- Cluster Attributes & Commands
- Cluster Pointers
- Cluster Allocation Functions
- APS Endpoints
3.1. Client-Server Relationship
Cluster operation follows a client server model with clusters having a client component and a server component.
The server, under direction from the client, is responsible for interacting with applications to influence the state of a device according to the value of its cluster attributes, and for reporting changes in the values of its attributes in response to external events to the client.
In the case of the OnOff cluster, the server side of the OnOff cluster is hosted by a light fixture and receives On or Off commands from the client side of the cluster hosted by a light switch.
The client is responsible for altering the state of a cluster’s attributes on the server by sending the server commands, or for reporting the state of the server’s attributes to its application. In the case of the OnOff cluster example the light switch when toggled would send an on or off command to the light or lights to which it is bound. In turn the lights might send notifications of the change of their state attributes back to the switch.
Clients and servers are linked through bindings when they are created. Clusters have globally unique identifiers used in addressing. For more information about the Client-Server relationship, please see Section 2.2.2 in [1].
3.2. ZCL Attributes and Commands
In general:
- Attributes are variables representing the current state of a device, and are commonly held by the server portion of a cluster.
- Commands are functions used by applications to alter or report the value of attributes, and are commonly generated by the Client portion and sent to the server.
As an example:
- The OnOff cluster defines the functionality for devices that can be turned on or off;
- The OnOff cluster contains the attribute 'OnOff', the state of which determines if a device is on or off;
- The OnOff cluster defines commands that can read or change the state of the attribute OnOff
Commands are divided into two types:
- Cluster Specific (unique to to a cluster)
- Profile Wide (available on every cluster)
While profile wide commands are intended to access a cluster’s attributes, each cluster has its own unique cluster specific commands. Attributes are primarily accessed through profile-wide commands such as:
- Read Attribute
- Write Attribute
Profile-wide commands also include other general functions such as default response, configure reporting, discover attributes, etc.
Profile-wide commands are the same for all clusters.
For more information about attributes and commands, see Section 2 of [1].
3.3. APS Endpoints
Endpoints are a central feature of cluster addressing and usually represent a discrete logical device such as a light switch. Only a single instance of a cluster is allowed on a given endpoint, but each endpoint typically supports multiple clusters, (e.g. Basic, Alarms, Levels, etc.).
An application creates endpoints using the ZbZclAddEndpoint() function, which is declared in the Zigbee cluster library header file, zcl.h. When creating a new endpoint, the application should select a new unique endpoint between 1 and 239, and provide the ProfileId and DeviceID. Endpoints outside of the 1-239 range are reserved for internal Zigbee functions, such as the Zigbee Device object on endpoint 0.
After creating an endpoint, the application can create application clusters and add them to that endpoint. By default, every endpoint includes the basic cluster.
When an endpoint is created, the stack will internally create a simple descriptor for each endpoint created. The simple descriptor will have two cluster lists: “input” and “output”. Server clusters reside on the input list, and client clusters reside on the output list. These simple descriptors are discoverable by other devices in the networks and are used to steer clients to the correct servers, i.e. to allow light switches to find lights.
3.4. Cluster Pointer
All clusters are represented by the same ZbZclClusterT datatype, which represents an instance of a specific cluster. In general, the internal structure of this datatype is of no use to the application; however, it is very important because it is used throughout the cluster APIs as the generic representation of any cluster, regardless of the type of cluster. Because of this many APIs are generic and will work with any cluster. For example ZbZclReadReq() allows you to read the attribute in any cluster, whereas ZbZclDoorLockClientLockReq() only works with a Door Lock client cluster handle, but both use the same ZbZclClusterT datatype. The distinction between different functions is made contextually.
3.5. Cluster Allocation Functions
All clusters include server and client allocation functions, taking the form of:
#include "zcl.x.h" app->x_client_cluster = ZbZclxClientAlloc(zb, endpoint, …)
or:
app->x_server_cluster = ZbZclxServerAlloc(zb, endpoint, …)
if (app->x_server_cluster == NULL) {
The allocation functions return NULL on error, otherwise a cluster handle is returned. In general, the application never examines the contents of this struct. Instead this handle is used in most cluster library applications.
Like most ZSDK API functions the allocation functions take the structure ZigbeeT * stack pointer as their first argument. This binds the new cluster instance to the stack instance. After which all ZCL API functions take the structure ZbZclClusterT * returned by the allocation function, the reference to the newly created cluster instance.
The second argument for allocation functions is the endpoint ID. This binds the newly created cluster to the endpoint given as the argument. Multiple cluster instances can be bound to the same endpoint, provided there is only one instance of any given cluster. The remainder of the arguments in an allocation function are specific to the cluster.
Server clusters with multiple commands usually take a structure with multiple callbacks, one for each command that the application supports. The application provides a callback for each command that it supports. If the application provides NULL for the entire structure pointer or a specific command callback, the cluster will respond with a Default Response of ZCL_STATUS_UNSUPP_COMMAND for the specific command (or every command if the entire structure pointer is NULL).
Here is an example of how an application would implement such a callback, providing function app_get_profile_info() which will be called whenever the ZCL_ELEC_MEAS_CLI_GET_PROFILE_INFO command is received.
enum ZclStatusCodeT app_get_profile_info(struct ZbZclClusterT *cluster,
struct ZbZclAddrInfoT *src_info, void *arg)
return ZCL_STATUS_SUCCESS;
struct ElecMeasSvrCallbacksT callbacks =
{ app_get_profile_info,
NULL,
cluster = ZbZclElecMeasServerAlloc(zb, endpoint, callbacks, app);
Note that, in this example, the Get Measurement Profile callback is declared NULL. When this command is received, a Default Response of ZCL_STATUS_UNSUPP_COMMAND will automatically be sent. The enum ZclStatusCodeT defines the available status codes.
3.6. Command Request Function
The following is the function used to send ZCL Commands.
Function
enum ZclStatusCodeT ZbZclCommandReq(struct ZigBeeT *zb, struct ZbZclCommandReqT *zclReq, void (*callback) (struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Parameters
| Name | Description |
| zb | Zigbee stack instance |
| zclReq | ZCL Command Request Structure, detailed in the next section |
| callback | Callback function that will be invoked when the response is received. |
| arg | Pointer to application data that will included in the callback when invoked. |
3.7. Command Request Structure
The following is the ZCL Command Request Structure:
typedef struct ZbZclCommandReqT {
struct ZbApsAddrT dst;
uint16_t profileId;
enum ZbZclClusterIdT clusterId;
uint16_t srcEndpt;
uint16_t txOptions;
bool discoverRoute;
uint8_t radius;
struct ZbZclHeaderT hdr;
const void *payload;
unsigned int length;
unsigned int timeout;
} ZbZclCommandReqT;
This structure is mapped to the structure as defined in ZCL :
| Code | ZCL Spec | Description |
| dst | DstAddrMode, DstAddress, DstEndpoint | APS address information data structure |
| profileId | ProfileId | |
| clusterId | ClusterId | |
| srcEndpt | SrcEndpoint | |
| txOptions | TxOptions | e.g. ZB_APSDE_DATAREQ_TXOPTIONS_A CK |
| discoverRoute | Used for discovery if the destination is unknown. If you perform route discovery separately using ZbNlmeRouteDiscWait(), then you can set discoverRoute to zero, decreasing the length of time an APS data request may take if there is a problem sending the packet to the target. | |
| radius | Radius | |
| hdr | Frame control, Manufacturer code, Transaction sequence number, Command identifier | payload |
| Frame payload | if txOptions & ZB_APSDE_DATAREQ_TXOPTIONS_VE
CTO, payload is a pointer to list of struct ZbApsBufT, and length is the number of struct ZbApsBufTitems in the list |
length |
| timeout | timeout in milliseconds to wait for response. If zero, then a suitable default timeout will be used. |
3.8. ZCL Callbacks
The following is the callback used by ZCL commands. The callback function is called when the associated ZCL response is received, or if there is an error.
Function
(*callback)(struct ZbZclCommandRspT *rsp, void *arg)
Parameters
| rsp | ZCL Command Response Structure |
| arg | Pointer to application data provided in initiating API call |
3.8.1. ZCL Command Response Structure
The following in the Command Response Structure used by ZCL Callbacks.
struct ZbZclCommandRspT {
enum ZbStatusCodeT aps_status;
enum ZclStatusCodeT status;
struct ZbApsAddrT src;
uint16_t profileId;
uint8_t linkQuality;
const uint8_t *payload;
uint16_t length;
| aps_status | APSDE-DATA.confirm status | |
| status | Status | Status of the ZCL response. If a Default Response, it is the status code found within the response. If a cluster-specific response, it is set to ZB_STATUS_SUCCESS, and the application must parse the payload, if any, for any embedded status |
| src | SrcEndpoint | |
| linkQuality | LinkQuality | |
| hdr | Frame control, Manufacturer code, Transaction sequence number, Command identifier | |
| payload | Frame payload | |
| length | ASDULength |
4. Destination Addressing
The destination of ZCL messages is specified using the APS ZbApsAddrT structure. This structure can provide the destination addressing, and either the short or extended address of the target node (the source addressing comes from the originating cluster instance). It is a burden for the application to keep track of the destination of each message.
To assist in this process the APS layer provides the binding mechanism.
Instead of tracking the clients and addressing them individually each and every time a message needs to be sent, the application can set up bindings. Bindings are addressing information stored in the binding table. When it is time to send a message the application specifies that the addressing is to binding, and the address information will automatically be added from the binding table. This is done by specifying ZB_APSDE_ADDRMODE_NOTPRESENT as the mode in ZbApsAddrT. If the application wants to configure the destination to use bindings, there is a special global structure ZbApsAddrBinding which can be used to copy this configuration from or use as a pointer reference.
Prior to use bindings must be configured in the binding table using the ZbApsmeBindReq(). The bind request specifies a single ClusterId for the binding; For this ClusterId the binding then associates a source address and endpoint with a destination address and endpoint. Normally the source address is the device itself. When a sender has multiple cluster instances, they reside on separate endpoints; in order to use bindings with that endpoint, there must be bindings for each source endpoint. Each binding specifies a destination address and endpoint. A single source endpoint may also have a binding to multiple destination endpoints and even multiple endpoints on multiple address; it all depends on the bindings that have been configured in the binding table.
One thing to note is that when using binding for the addressing it is assumed that at least one suitable binding exists. If no binding exists a status of ZB_APS_STATUS_INVALID_BINDING is returned. However, if this is acceptable for the application it may ignore this status.
The binding mechanism is a general purpose APS layer mechanism available for any APS layer purpose. So, a cluster needs to send ZCL report, bindings are used, i.e. reports are sent to the available binding. Additionally, the Poll Control server cluster relies on bindings to send check-in requests; it will send check in requests to every client for which there is a binding present in its local binding table.
Bindings may also be configured from a remote node using the ZbZdoMgmtBindReq(). This is useful in cases like reporting or the Poll Control clients which need to establish bindings on the remote node back to themselves.
In addition to manually establishing a binding, locally through ZbApsmeBindReq() or remotely through ZbZdoMgmtBindReq() there is the Finding and Binding mechanism. When initiated, Finding and Binding scans the local endpoints for client clusters, then locates remote server endpoints using zigbee service discovery mechanisms, and establishes bindings on the client to server(s) discovered. Finding and Binding is triggered automatically by setting the ZB_BDB_CommissioningMode to BDB_COMMISSION_MODE_FIND_BIND prior to startup. When triggered automatically the Finding and Binding procedure will start approximately 5 seconds after a node joins a network. Additionally, Finding and Binding can be started manually from the application on all endpoints by calling ZbStartupFindBindStart(), or calling ZbStartupFindBindStartEndpoint() to start only from a particular endpoint.
5. Special ZCL Clusters
Some clusters require the application developer to have a better understanding of both their function and their interactions with other clusters in order for the cluster to be properly implemented. Additional information concerning three such clusters is contained within this section.
Those Clusters are:
- Scenes
- Alarms
- CBKE
5.1. Scenes Cluster
A scene is a set of values for attributes from multiple clusters capable of being applied at the same time. The few clusters that support scenes are identified by a section with the title "Scene Table Extensions" in the ZCL 8 Specification [1] section for those cluster. There is only one scene table (list of attributes) for a cluster that supports scenes, and when a scene is invoked all scene table attributes are set to the values given in the scene table.
To use the scene table for a cluster, the cluster must reside on an endpoint which also hosts an instance of the Scenes cluster. There may be multiple scene table supporting clusters on a given endpoint. A scene is defined in the scenes cluster and contains scene tables for one or more clusters. Through the use of group addressing a scene may be applied to multiple endpoints on a node.
A scene may be created by the scene cluster using the Add Scene command, where the application manually defines the scene table for each cluster included in that scene. All attributes must have values in the scene table, but inclusion of individual clusters is optional. A scene may also be created using the Store Scene command where the current value of all the attributes in the cluster at the time the Store Scene command is issued are recorded in the scene table for later use.
The Scenes cluster Recall Scene command takes the scene table for each cluster in that scene and sets the values of every scene table attribute.
For example, a node could contain three endpoints:
0x01with the OnOff and Window Covering clusters0x02with the OnOff and Door Lock clusters0x03with the OnOff and Level.
A scene is defined with a scene tables for the:
- OnOff cluster:
OnOff = On - Level cluster:
CurrentLevel = 50% - DoorLock cluster:
LockState = Locked
Additionally:
- Endpoints
0x01and0x02are in group0x0001 - Endpoint
0x03is not in group0x0001
If the scenes cluster Recall Scenes command is issued with group address 0x0001 and the scene defined above, then on endpoint 0x01 and 0x02 the OnOff cluster OnOff attribute will be set on and the DoorLock on endpoint 0x02 will be locked.
The Window Covering cluster on endpoint 0x01 will not be affected because this scene does not include a scene table for this cluster and all of endpoint 0x03 will be unaffected because it is not in group 0x0001.
For more information about the Scenes cluster, see Section 3.7 in [1].
5.2. Alarms Cluster
Zigbee defines an alarm as the occurrence of a specific condition. Individual clusters (such as Basic, Power Configuration, Door Lock, Ballast Configuration, etc.) define these conditions and a corresponding alarm code.
For the definition of the alarm condition its corresponding code for a specific cluster, see [1].
Alarm conditions are typically defined in terms of a cluster attribute. For example, the Power Configuration cluster defines alarm
code 0x00 for the alarm generated when the MainsVoltage attribute drops below the value specified in the MainsVoltageMinThreshold attribute for a time period greater than the MainsVoltageDwellTripPoint attribute in seconds.
Clusters typically have an additional AlarmMask attribute which is a bitmask that allows the client to enable or disable the generation of individual alarms when the corresponding alarm condition is met.
It is the responsibility of the cluster application implementation to detect the alarm condition, check the alarm mask, and when needed initiate generation of the alarm by calling ZbZclClusterSendAlarm() (defined in zcl.h), resulting in the sending of an Alarm command. It is important to note that this Alarm command is not sent from the originating cluster. Instead, it is sent from an instance of the Alarm cluster that must reside on the same endpoint as the originating cluster.
The alarm cluster sends the alarm command to all clients with bindings to the alarm cluster on this endpoint. It also adds alarm details to an internal log. The alarm cluster provides commands that allow clients to query this alarm log. The alarm log is shared by all clusters on the same endpoint. In order to receive alarms, clients must bind to the alarms cluster on the same endpoint as the alarm generating cluster. For clusters that support an alarm mask, any client can enable/disable generation of alarm commands by setting/clearing the mask bit in the originating cluster. The mask controls sending of alarms to all bound clients.
Some alarm conditions do not automatically reset and must be manually reset by the client. The Alarm cluster provides the Reset Alarm and Reset all Alarms commands for this reason the application should register a callback for each endpoint with cluster(s) that require resetting using ZbZclClusterRegisterAlarmResetHandler(). The callback handles the specific cluster(s) against which it was registered.
When the alarm cluster receives a Reset Alarm or Reset all Alarms command, the cluster application callback will be invoked and can then handle the whatever is necessary to internally reset to detect new occurrences of the alarm condition. The same callback is invoked for both commands. When the Reset all Alarms command is received the callback is invoked with an Alarm Code of 0xFF and Cluster ID of 0xFFFF. When a callback is provided the function return code is provided as the status in the Default Response. When no callbacks are provided the alarm cluster will send a Default Response with a status of SUCCESS.
As a summary:
- When an endpoint contains a cluster that can generate alarms, it is the application’s responsibility to also instantiate the alarms cluster on that endpoint.
- It is the responsibility of the cluster implementation to
- Detect alarm conditions
- Check the alarm mask (where supported)
- Generate an alarm by calling
- If the alarm conditions for any cluster(s) on an endpoint need to be manually reset, then the application should register a callback for each endpoint with cluster(s) that require resetting using
For more information about the Alarms cluster, see Section 3.11 in [1].
5.3. CBKE Cluster
The Certificate-based Key Establishment (CBKE) cluster is handled internally by the stack. When CBKE is enabled, the stack creates an instance of the CBKE cluster. There is no exposed public API to the CBKE cluster itself. CBKE is configured in the security.cbke (struct ZbStartupCbkeT) section of the ZbStartupT startup config. The basic setup procedure is to enable the supported suites in suite_mask and load the corresponding suite configuration and certificates for the enabled suites into the startup config before starting the stack.
6. ZCL Clusters
6.1. Built-In Clusters
6.1.1. Keep Alive
#include "zcl/se/zcl.keepalive.h"
Description
The Keep Alive clusters are typically used in Smart Energy applications.
The Keep Alive server and client clusters are allocated by the stack if the application configures the Key Exchange information in the ZbStartup configuration (struct ZbStartupCbkeT). The Keep Alive server is allocated if the tc_keepalive_server_enable flag is set to true, otherwise the Keep Alive client is allocated. Typically, the Keep Alive server is allocated on the Trust Center, and the Keep Alive client is allocated on devices joining the SE network.
If the Keep Alive client determines there’s a problem communicating with the Trust Center, it will call the application callback 'tcso_callback' configured in the ZbStartup configuration. At which point, the stack will perform the necessary Trust Center Swap Out (TCSO) routines to attempt to find a newly swapped-out Trust Center, or if the current Trust Center has moved to a different channel or other configuration.
Functions
ZbZclKeepAliveClientAlloc
struct ZbZclClusterT * ZbZclKeepAliveClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, bool (*tcso_callback)(enum ZbTcsoStatusT status, void *arg), void *tcso_arg);
Create a new instance of the Keep Alive Client cluster
Parameters
| endpoint | Endpoint on which to create cluster |
| tcso_callback | Callback function that will be invoked when the TCSO is ever started (ZB_TCSO_STATUS_DISCOVERY_UNDERWAY), and when it completes, with the resultant status. The return value for this callback determines whether the stack starts or continues with TCSO (true), or if the stack should not start or continue with TCSO (false). |
| tcso_arg | Pointer to application data that will included in the callback when invoked. |
Return
- Cluster pointer, or NULL if there is an error
ZbZclKeepAliveClientStart
void ZbZclKeepAliveClientStart(struct ZigBeeT *zb);
Start Keep Alive
Parameters
Return
- Void
ZbZclKeepAliveClientStop
void ZbZclKeepAliveClientStop(struct ZigBeeT *zb);
Stop Keep Alive and abort the TCSO
Parameters
Return
- Void
ZbZclKeepAliveServerAlloc
struct ZbZclClusterT * ZbZclKeepAliveServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Keep Alive Server cluster
Parameters
Return
ZbZclKeepAliveServerWriteDirect
enum ZclStatusCodeT ZbZclKeepAliveServerWriteDirect(struct ZigBeeT *zb, uint16_t attrId, uint16_t value);
Write a Keep Alive Server attribute
Parameters
| zb | Zigbee instance |
| attrId | The attribute Id to write |
| value | Attribute data to be writen. |
Return
- ZCL Status Code
Enumerations
ZbZclKeepAliveSvrAttrT
Keep Alive Server Attribute IDs
| ZCL_KEEPALIVE_SVR_ATTR_BASE | TC Keep-Alive Base - minutes (valid range is from 0x01 to 0xff, but not enforced by cluster, for testing) |
| ZCL_KEEPALIVE_SVR_ATTR_JITTER | TC Keep-Alive Jitter - seconds (valid range is from 0x0000 to 0x0200) |
6.2. General Clusters
6.2.1. Alarms
#include "zcl/general/zcl.alarm.h"
Description
ZCL 8 section 3.11
For the definition of the alarm condition its corresponding code for a specific cluster, see the Zigbee Cluster Library Specification 8 (ZCL8).
Alarm conditions are typically defined in terms of a cluster attribute. For example, the Power Configuration cluster defines alarm code 0x00 for the alarm generated when the MainsVoltage attribute drops below the value specified in the MainsVoltageMinThreshold attribute for a time period greater than the MainsVoltageDwellTripPoint attribute in seconds.
As a summary:
- Generate an alarm by calling ZbZclClusterSendAlarm()
- If the alarm conditions for any cluster(s) on an endpoint need to be manually reset, then the application should register a callback for each endpoint with cluster(s) that require resetting using ZbZclClusterRegisterAlarmResetHandler().
For more information about the Alarms cluster, see Section 3.11 in ZCL8.
Functions
ZbZclAlarmClientAlloc
struct ZbZclClusterT * ZbZclAlarmClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, ZbZclAlarmClientCallbackT callback, void *arg);
Create a new instance of the Alarms Client cluster
Parameters
| callback | Callback function that will be invoked when an alarm occurs |
| arg | Pointer to application data that will later be provided back to the callback function when it is invoked |
Return
ZbZclAlarmClientGetAlarmReq
enum ZclStatusCodeT ZbZclAlarmClientGetAlarmReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Alarm command
Parameters
| cluster | Cluster instance from which to send this command |
| dst | Destination address for request |
| callback | Callback function that will be invoked when response is received |
Return
- ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error
ZbZclAlarmClientResetAlarmLogReq
enum ZclStatusCodeT ZbZclAlarmClientResetAlarmLogReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Reset Alarm Log command
Parameters
Return
ZbZclAlarmClientResetAlarmReq
enum ZclStatusCodeT ZbZclAlarmClientResetAlarmReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, uint8_t alarm_code, uint16_t cluster_id, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Reset Alarm command
Parameters
| alarm_code | Code of the detected alarm condition |
| cluster_id | ID of cluster where alarm condition occurred |
Return
ZbZclAlarmClientResetAllAlarmsReq
enum ZclStatusCodeT ZbZclAlarmClientResetAllAlarmsReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Reset All Alarms command
Parameters
Return
ZbZclAlarmServerAlloc
struct ZbZclClusterT * ZbZclAlarmServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, uint16_t logSize, struct ZbZclClusterT *time_server);
Create a new instance of the Alarms Server cluster
Parameters
| logSize | Alarm log size |
| time_server | Time Server cluster instance |
Return
Enumerations
ZbZclAlarmsAttrT
Alarms Attribute IDs
| ZCL_ALARM_ATTR_COUNT | AlarmCount (Optional) |
6.2.2. Ballast Configuration
#include "zcl/general/zcl.ballast.config.h"
Functions
ZbZclBallastConfigClientAlloc
struct ZbZclClusterT * ZbZclBallastConfigClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Ballast Configuration Client cluster
Parameters
Return
ZbZclBallastConfigServerAlloc
struct ZbZclClusterT * ZbZclBallastConfigServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, uint8_t phyMin, uint8_t phyMax);
Create a new instance of the Ballast Configuration Server cluster
Parameters
| phyMin | The default minimum light output |
| phyMax | The default maximum light output |
Return
Enumerations
ZbZclBallastConfigSvrAttrT
Ballast Configuration Server Attributes IDs
| ZCL_BALLAST_CONFIG_ATTR_PHY_MIN_LEVEL | PhysicalMinLevel |
| ZCL_BALLAST_CONFIG_ATTR_PHY_MAX_LEVEL | PhysicalMaxLevel |
| ZCL_BALLAST_CONFIG_ATTR_BALLAST_STATUS | BallastStatus |
| ZCL_BALLAST_CONFIG_ATTR_MIN_LEVEL | MinLevel |
| ZCL_BALLAST_CONFIG_ATTR_MAX_LEVEL | MaxLevel |
| ZCL_BALLAST_CONFIG_ATTR_POWER_ON_LEVEL | PowerOnLevel (Deprecated) |
| ZCL_BALLAST_CONFIG_ATTR_POWER_ON_FADE_TIME | PowerOnFadeTime (Deprecated) |
| ZCL_BALLAST_CONFIG_ATTR_INTRINSIC_BALLAST_FACT OR | IntrinsicBallastFactor (Optional) |
| ZCL_BALLAST_CONFIG_ATTR_BALLAST_FACTOR_ADJUST MENT | BallastFactorAdjustment (Optional) |
| ZCL_BALLAST_CONFIG_ATTR_LAMP_QUANTITY | LampQuantity (Optional) |
| ZCL_BALLAST_CONFIG_ATTR_LAMP_TYPE | LampType (Optional) |
| ZCL_BALLAST_CONFIG_ATTR_LAMP_MANUFACTURER | LampManufacturer (Optional) |
| ZCL_BALLAST_CONFIG_ATTR_LAMP_RATED_HOURS | LampRatedHours (Optional) |
| ZCL_BALLAST_CONFIG_ATTR_LAMP_BURN_HOURS | LampBurnHours (Optional) |
| ZCL_BALLAST_CONFIG_ATTR_LAMP_ALARM_MODE | LampAlarmMode (Optional) |
| ZCL_BALLAST_CONFIG_ATTR_LAMP_BURN_HOURS_TRIP
_POINT |
LampBurnHoursTripPoint (Optional) |
6.2.3. Basic
#include "zcl/general/zcl.basic.h"
Functions
ZbZclBasicClientAlloc
struct ZbZclClusterT * ZbZclBasicClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Basic Client cluster
Parameters
Return
ZbZclBasicClientResetReq
enum ZclStatusCodeT ZbZclBasicClientResetReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst);
Send a Reset to Factory Defaults command
Parameters
Return
Enumerations
ZbZclBasicSvrAttrT
Basic Server Attribute IDs
| ZCL_BASIC_ATTR_ZCL_VERSION | ZCLVersion |
| ZCL_BASIC_ATTR_APP_VERSION | ApplicationVersion (Optional) |
| ZCL_BASIC_ATTR_STACK_VERSION | StackVersion (Optional) |
| ZCL_BASIC_ATTR_HARDWARE_VERSION | HWVersion (Optional) |
| ZCL_BASIC_ATTR_MFR_NAME | ManufacturerName (Optional) |
| ZCL_BASIC_ATTR_MODEL_NAME | ModelIdentifier (Optional) |
| ZCL_BASIC_ATTR_DATE_CODE | DateCode (Optional) |
| ZCL_BASIC_ATTR_POWER_SOURCE | PowerSource |
| ZCL_BASIC_ATTR_MFR_VERSION_DETAILS | ManufacturerVersionDetails (Optional) |
| ZCL_BASIC_ATTR_SERIAL_NUMBER | SerialNumber (Optional) |
| ZCL_BASIC_ATTR_PRODUCT_LABEL | ProductLabel (Optional) |
| ZCL_BASIC_ATTR_LOCATION | LocationDescription (Optional) |
| ZCL_BASIC_ATTR_ENVIRONMENT | PhysicalEnvironment (Optional) |
| ZCL_BASIC_ATTR_ENABLED | DeviceEnabled (Optional) |
| ZCL_BASIC_ATTR_ALARM_MASK | AlarmMask (Optional) |
| ZCL_BASIC_ATTR_DISABLE_LOCAL_CONFIG | DisableLocalConfig (Optional) |
| ZCL_BASIC_ATTR_SW_BUILD_ID | SWBuildID (Optional) |
6.2.4. Color Control
#include "zcl/general/zcl.color.h"
Functions
ZbZclColorClientAlloc
struct ZbZclClusterT * ZbZclColorClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Instantiate a new instance of the Color Control client cluster
Parameters
Return
ZbZclColorClientColorLoopSetReq
enum ZclStatusCodeT ZbZclColorClientColorLoopSetReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientColorLoopSetReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Color Loop Set command
Parameters
| req | Color Loop Set command request structure |
Return
ZbZclColorClientMoveColorTempReq
enum ZclStatusCodeT ZbZclColorClientMoveColorTempReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientMoveColorTempReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Move Color Temperature command
Parameters
| clusterPtr | Cluster instance from which to send this command |
| req | Move Color Temperature command request structure |
Return
ZbZclColorClientMoveColorXYReq
enum ZclStatusCodeT ZbZclColorClientMoveColorXYReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientMoveColorXYReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Move Color command
Parameters
| req | Move Color command request structure |
Return
ZbZclColorClientMoveHueEnhReq
enum ZclStatusCodeT ZbZclColorClientMoveHueEnhReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientMoveHueEnhReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Enhanced Move Hue command
Parameters
| req | Enhanced Move Hue command request structure |
Return
ZbZclColorClientMoveHueReq
enum ZclStatusCodeT ZbZclColorClientMoveHueReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientMoveHueReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Move Hue command
Parameters
| req | Move Hue command request structure |
Return
ZbZclColorClientMoveSatReq
enum ZclStatusCodeT ZbZclColorClientMoveSatReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientMoveSatReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Move Saturation command
Parameters
| req | Move Saturation command request structure |
Return
ZbZclColorClientMoveToColorTempReq
enum ZclStatusCodeT ZbZclColorClientMoveToColorTempReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientMoveToColorTempReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Move to Color Temperature command
Parameters
| req | Move to Color Temperature command request structure |
Return
ZbZclColorClientMoveToColorXYReq
enum ZclStatusCodeT ZbZclColorClientMoveToColorXYReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientMoveToColorXYReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Move to Color command
Parameters
| req | Move to Color command request structure |
Return
ZbZclColorClientMoveToHueEnhReq
enum ZclStatusCodeT ZbZclColorClientMoveToHueEnhReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientMoveToHueEnhReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Enhanced Move to Hue command
Parameters
| req | Enhanced Move to Hue command request structure |
Return
ZbZclColorClientMoveToHueReq
enum ZclStatusCodeT ZbZclColorClientMoveToHueReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientMoveToHueReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Move to Hue command
Parameters
| req | Move to Hue command request structure |
Return
ZbZclColorClientMoveToHueSatEnhReq
enum ZclStatusCodeT ZbZclColorClientMoveToHueSatEnhReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientMoveToHueSatEnhReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Enhanced Move to Hue and Saturation command
Parameters
| req | Enhanced Move to Hue and Saturation command request structure |
Return
ZbZclColorClientMoveToHueSatReq
enum ZclStatusCodeT ZbZclColorClientMoveToHueSatReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientMoveToHueSatReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Move to Hue and Saturation command
Parameters
| req | Move to Hue and Saturation command request structure |
Return
ZbZclColorClientMoveToSatReq
enum ZclStatusCodeT ZbZclColorClientMoveToSatReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientMoveToSatReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Move to Saturation command
Parameters
| req | Move to Saturation command command request structure |
Return
ZbZclColorClientStepColorTempReq
enum ZclStatusCodeT ZbZclColorClientStepColorTempReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientStepColorTempReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Step Color Temperature command
Parameters
| req | Step Color Temperature command request structure |
Return
ZbZclColorClientStepColorXYReq
enum ZclStatusCodeT ZbZclColorClientStepColorXYReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientStepColorXYReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Step Color command
Parameters
| req | Step Color command request structure |
Return
ZbZclColorClientStepHueEnhReq
enum ZclStatusCodeT ZbZclColorClientStepHueEnhReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientStepHueEnhReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Enhanced Step Hue command
Parameters
| req | Enhanced Step Hue command request structure |
Return
ZbZclColorClientStepHueReq
enum ZclStatusCodeT ZbZclColorClientStepHueReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientStepHueReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Step Hue command
Parameters
| req | Step Hue command request structure |
Return
ZbZclColorClientStepSatReq
enum ZclStatusCodeT ZbZclColorClientStepSatReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientStepSatReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Step Saturation command
Parameters
| req | Step Saturation command command request structure |
Return
ZbZclColorClientStopMoveStepReq
enum ZclStatusCodeT ZbZclColorClientStopMoveStepReq(struct ZbZclClusterT *clusterPtr, const struct ZbApsAddrT *dst, struct ZbZclColorClientStopMoveStepReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Stop Move Step command
Parameters
| req | Stop Move Step command request structure |
Return
ZbZclColorServerAlloc
struct ZbZclClusterT * ZbZclColorServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *onoff_server, const struct ZbZclAttrT *attribute_list, unsigned int num_attrs, struct ZbColorClusterConfig *config, void *arg);
Instantiate a new instance of the Color Control server cluster
Parameters
| onoff_server | OnOff Server cluster pointer for processing commands with the Options fields, may be NULL |
| attribute_list | List of application defined attributes to be appended, may be NULL |
| num_attrs | Number of application defined attributes to be added, may be 0 if attribute_list is NULL |
| config | Configuration containing Color Control capabilities and callbacks for handling requests |
Return
Enumerations
ZbZclColorSvrAttrT
Color Control Server Attribute IDs
| ZCL_COLOR_ATTR_CURRENT_HUE | CurrentHue |
| ZCL_COLOR_ATTR_CURRENT_SAT | CurrentSaturation |
| ZCL_COLOR_ATTR_REMAINING_TIME | RemainingTime (Optional but is used in mandatory commands) |
| ZCL_COLOR_ATTR_CURRENT_X | CurrentX |
| ZCL_COLOR_ATTR_CURRENT_Y | CurrentY |
| ZCL_COLOR_ATTR_DRIFT_COMP | DriftCompensation (Optional) |
| ZCL_COLOR_ATTR_COMPENSATION_TEXT | CompensationText (Optional) |
| ZCL_COLOR_ATTR_COLOR_TEMP_MIREDS | ColorTemperatureMireds |
| ZCL_COLOR_ATTR_COLOR_MODE | ColorMode |
| ZCL_COLOR_ATTR_OPTIONS | Options |
| ZCL_COLOR_ATTR_NUM_PRIMARIES | NumberOfPrimaries |
| ZCL_COLOR_ATTR_PRIMARY_1X | Primary1X |
| ZCL_COLOR_ATTR_PRIMARY_1Y | Primary1Y |
| ZCL_COLOR_ATTR_PRIMARY_1_INTENS | Primary1Intensity |
| ZCL_COLOR_ATTR_PRIMARY_2X | Primary2X |
| ZCL_COLOR_ATTR_PRIMARY_2Y | Primary2Y |
| ZCL_COLOR_ATTR_PRIMARY_2_INTENS | Primary2Intensity |
| ZCL_COLOR_ATTR_PRIMARY_3X | Primary3X |
| ZCL_COLOR_ATTR_PRIMARY_3Y | Primary3Y |
| ZCL_COLOR_ATTR_PRIMARY_3_INTENS | Primary3Intensity |
| ZCL_COLOR_ATTR_PRIMARY_4X | Primary4X |
| ZCL_COLOR_ATTR_PRIMARY_4Y | Primary4Y |
| ZCL_COLOR_ATTR_PRIMARY_4_INTENS | Primary4Intensity |
| ZCL_COLOR_ATTR_PRIMARY_5X | Primary5X |
| ZCL_COLOR_ATTR_PRIMARY_5Y | Primary5Y |
| ZCL_COLOR_ATTR_PRIMARY_5_INTENS | Primary5Intensity |
| ZCL_COLOR_ATTR_PRIMARY_6X | Primary6X |
| ZCL_COLOR_ATTR_PRIMARY_6Y | Primary6Y |
| ZCL_COLOR_ATTR_PRIMARY_6_INTENS | Primary6Intensity |
| ZCL_COLOR_ATTR_WHITE_POINT_X | WhitePointX (Optional) |
| ZCL_COLOR_ATTR_WHITE_POINT_Y | WhitePointY (Optional) |
| ZCL_COLOR_ATTR_COLOR_POINT_RX | ColorPointRX (Optional) |
| ZCL_COLOR_ATTR_COLOR_POINT_RY | ColorPointRY (Optional) |
| ZCL_COLOR_ATTR_COLOR_POINT_R_INTENS | ColorPointRIntensity (Optional) |
| ZCL_COLOR_ATTR_COLOR_POINT_GX | ColorPointGX (Optional) |
| ZCL_COLOR_ATTR_COLOR_POINT_GY | ColorPointGY (Optional) |
| ZCL_COLOR_ATTR_COLOR_POINT_G_INTENS | ColorPointGIntensity (Optional) |
| ZCL_COLOR_ATTR_COLOR_POINT_BX | ColorPointBX (Optional) |
| ZCL_COLOR_ATTR_COLOR_POINT_BY | ColorPointBY (Optional) |
| ZCL_COLOR_ATTR_COLOR_POINT_B_INTENS | ColorPointBIntensity (Optional) |
| ZCL_COLOR_ATTR_ENH_CURR_HUE | EnhancedCurrentHue |
| ZCL_COLOR_ATTR_ENH_COLOR_MODE | EnhancedColorMode |
| ZCL_COLOR_ATTR_COLOR_LOOP_ACTIVE | ColorLoopActive |
| ZCL_COLOR_ATTR_COLOR_LOOP_DIR | ColorLoopDirection |
| ZCL_COLOR_ATTR_COLOR_LOOP_TIME | ColorLoopTime |
| ZCL_COLOR_ATTR_COLOR_LOOP_START_HUE | ColorLoopStartEnhancedHue |
| ZCL_COLOR_ATTR_COLOR_LOOP_STORE_HUE | ColorLoopStoredEnhancedHue |
| ZCL_COLOR_ATTR_COLOR_CAPABILITIES | ColorCapabilities |
| ZCL_COLOR_ATTR_COLOR_TEMP_MIN | ColorTempPhysicalMinMireds |
| ZCL_COLOR_ATTR_COLOR_TEMP_MAX | ColorTempPhysicalMaxMireds |
| ZCL_COLOR_ATTR_COUPLE_COLOR_TL_MIN | ColorTempPhysicalMaxMireds |
| ZCL_COLOR_ATTR_STARTUP_COLOR_TEMP | StartUpColorTemperatureMireds |
Structures
Color Loop Set command structure
Parameters
| uint8_t update_flags | Update Flags |
| uint8_t action | Action |
| uint8_t direction | Direction |
| uint16_t transition_time | Time |
| uint16_t start_hue | Start Hue |
| uint8_t mask | OptionsMask |
| uint8_t override | OptionsOverride |
Move Color Temperature command structure
Parameters
| uint8_t move_mode | Move Mode |
| uint16_t rate | Rate |
| uint16_t color_temp_min | Color Temperature Minimum Mireds |
| uint16_t color_temp_max | Color Temperature Maximum Mireds |
Move Color command structure
Parameters
| uint16_t rate_x | RateX |
| uint16_t rate_y | RateY |
Enhanced Move Hue command structure
Parameters
Parameters
| uint8_t rate | Rate |
Move Saturation command structure
Parameters
Move to Color Temperature command structure
Parameters
| uint16_t color_temp | Color Temperature Mireds |
| uint16_t transition_time | Transition Time |
Move to Color command structure
Parameters
| uint16_t color_x | ColorX |
| uint16_t color_y | ColorY |
Enhanced Move to Hue command structure
Parameters
| uint16_t enh_hue | Enhanced Hue |
Parameters
| uint8_t hue | Hue |
Enhanced Move to Hue and Saturation command structure
Parameters
| uint8_t sat | Saturation |
Parameters
| uint8_t hue | Hue |
Move to Saturation command structure
Parameters
Step Color Temperature command structure
Parameters
| uint8_t step_mode | Step Mode |
| uint16_t step_size | Step Size |
Step Color command structure
Parameters
| uint16_t step_x | StepX |
| uint16_t step_y | StepY |
Enhanced Step Hue command structure
Parameters
Parameters
| uint8_t step_size | Step Size |
| uint8_t transition_time | Transition Time |
| uint8_t override |
Step Saturation command structure
Parameters
Stop Move Step command structure
Parameters
ZbZclColorServerCallbacksT
Color Control Server callbacks configuration
Parameters
| move_to_hue
(callback function pointer) |
enum ZclStatusCodeT (*move_to_hue)(struct ZbZclClusterT *cluster, struct ZbZclColorClientMoveToHueReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Move to Hue command. The application is expected to update ZCL_COLOR_ATTR_CURRENT_HUE, and ZCL_COLOR_ATTR_REMAINING_TIME |
| move_hue
enum ZclStatusCodeT (*move_hue)(struct ZbZclClusterT *cluster, struct ZbZclColorClientMoveHueReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Move Hue command. The application is expected to update ZCL_COLOR_ATTR_CURRENT_HUE, and ZCL_COLOR_ATTR_REMAINING_TIME |
| step_hue
enum ZclStatusCodeT (*step_hue)(struct ZbZclClusterT *cluster, struct ZbZclColorClientStepHueReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Step Hue command. The application is expected to update ZCL_COLOR_ATTR_CURRENT_HUE, and ZCL_COLOR_ATTR_REMAINING_TIME |
| move_to_sat
enum ZclStatusCodeT (*move_to_sat)(struct ZbZclClusterT *cluster, struct ZbZclColorClientMoveToSatReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Move to Saturation command. The application is expected to update ZCL_COLOR_ATTR_CURRENT_SAT, and ZCL_COLOR_ATTR_REMAINING_TIME |
| move_sat
enum ZclStatusCodeT (*move_sat)(struct ZbZclClusterT *cluster, struct ZbZclColorClientMoveSatReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Move Saturation command. The application is expected to update ZCL_COLOR_ATTR_CURRENT_SAT, and ZCL_COLOR_ATTR_REMAINING_TIME
| step_sat
enum ZclStatusCodeT (*step_sat)(struct ZbZclClusterT *cluster, struct ZbZclColorClientStepSatReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Step Saturation command. The application is expected to update ZCL_COLOR_ATTR_CURRENT_SAT, and ZCL_COLOR_ATTR_REMAINING_TIME |
| move_to_hue_sat
enum ZclStatusCodeT (*move_to_hue_sat)(struct ZbZclClusterT *cluster, struct ZbZclColorClientMoveToHueSatReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Move to Hue and Saturation command. The application is expected to update ZCL_COLOR_ATTR_CURRENT_HUE, ZCL_COLOR_ATTR_CURRENT_SAT, and ZCL_COLOR_ATTR_REMAINING_TIME |
| move_to_color_xy
enum ZclStatusCodeT (*move_to_color_xy)(struct ZbZclClusterT *cluster, struct ZbZclColorClientMoveToColorXYReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Move to Color command. The application is expected to update ZCL_COLOR_ATTR_CURRENT_X, ZCL_COLOR_ATTR_CURRENT_Y, and ZCL_COLOR_ATTR_REMAINING_TIME |
| move_color_xy
enum ZclStatusCodeT (*move_color_xy)(struct ZbZclClusterT *cluster, struct ZbZclColorClientMoveColorXYReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Move Color command. The application is expected to update ZCL_COLOR_ATTR_CURRENT_X, ZCL_COLOR_ATTR_CURRENT_Y, and ZCL_COLOR_ATTR_REMAINING_TIME |
| step_color_xy
enum ZclStatusCodeT (*step_color_xy)(struct ZbZclClusterT *cluster, struct ZbZclColorClientStepColorXYReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Step Color command. The application is expected to update ZCL_COLOR_ATTR_CURRENT_X, ZCL_COLOR_ATTR_CURRENT_Y, and ZCL_COLOR_ATTR_REMAINING_TIME |
| move_to_color_temp
enum ZclStatusCodeT (*move_to_color_temp)(struct ZbZclClusterT *cluster, struct ZbZclColorClientMoveToColorTempReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Move to Color Temperature command. The application is expected to update ZCL_COLOR_ATTR_COLOR_TEMP_MIREDS, and ZCL_COLOR_ATTR_REMAINING_TIME |
| move_to_hue_enh
enum ZclStatusCodeT (*move_to_hue_enh)(struct ZbZclClusterT *cluster, struct ZbZclColorClientMoveToHueEnhReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Enhanced Move to Hue command. The application is expected to update ZCL_COLOR_ATTR_ENH_CURR_HUE, and ZCL_COLOR_ATTR_REMAINING_TIME |
| move_hue_enh
enum ZclStatusCodeT (*move_hue_enh)(struct ZbZclClusterT *cluster, struct ZbZclColorClientMoveHueEnhReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Move Hue command. The application is expected to update ZCL_COLOR_ATTR_ENH_CURR_HUE, and ZCL_COLOR_ATTR_REMAINING_TIME |
| step_hue_enh
enum ZclStatusCodeT (*step_hue_enh)(struct ZbZclClusterT *cluster, struct ZbZclColorClientStepHueEnhReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Enhanced Step Hue command. The application is expected to update ZCL_COLOR_ATTR_ENH_CURR_HUE, and ZCL_COLOR_ATTR_REMAINING_TIME |
| move_to_hue_sat_enh
enum ZclStatusCodeT (*move_to_hue_sat_enh)(struct ZbZclClusterT *cluster, struct ZbZclColorClientMoveToHueSatEnhReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Enhanced Move to Hue and Saturation command. The application is expected to update ZCL_COLOR_ATTR_ENH_CURR_HUE, ZCL_COLOR_ATTR_CURRENT_SAT, and ZCL_COLOR_ATTR_REMAINING_TIME |
| color_loop_set
enum ZclStatusCodeT (*color_loop_set)(struct ZbZclClusterT *cluster, struct ZbZclColorClientColorLoopSetReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Color Loop Set command. The application is expected to update the following attributes according to the update flags and action fields: ZCL_COLOR_ATTR_COLOR_LOOP_ACTIVE, ZCL_COLOR_ATTR_COLOR_LOOP_DIR, ZCL_COLOR_ATTR_COLOR_LOOP_TIME, ZCL_COLOR_ATTR_COLOR_LOOP_START_HUE, ZCL_COLOR_ATTR_ENH_CURR_HUE, ZCL_COLOR_ATTR_COLOR_LOOP_STORE_HUE, and ZCL_COLOR_ATTR_REMAINING_TIME |
| stop_move_step
enum ZclStatusCodeT (*stop_move_step)(struct ZbZclClusterT *cluster, struct ZbZclColorClientStopMoveStepReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Stop Move Step command. The application is expected to update ZCL_COLOR_ATTR_REMAINING_TIME |
| move_color_temp
enum ZclStatusCodeT (*move_color_temp)(struct ZbZclClusterT *cluster, struct ZbZclColorClientMoveColorTempReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Move Color Temperature command. The application is expected to update ZCL_COLOR_ATTR_COLOR_TEMP_MIREDS, and ZCL_COLOR_ATTR_REMAINING_TIME |
| step_color_temp
enum ZclStatusCodeT (*step_color_temp)(struct ZbZclClusterT *cluster, struct ZbZclColorClientStepColorTempReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Step Color Temperature command. The application is expected to update ZCL_COLOR_ATTR_COLOR_TEMP_MIREDS, and ZCL_COLOR_ATTR_REMAINING_TIME |
6.2.5. Commissioning
#include "zcl/general/zcl.commission.h"
Functions
ZbZclCommissionClientAlloc
struct ZbZclClusterT * ZbZclCommissionClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, uint16_t profile, bool aps_secured);
Create a new instance of the Commissioning Client cluster
Parameters
| endpoint | Set to ZB_ENDPOINT_BCAST if using Inter-PAN for communicating ZCL messages. Otherwise, set a valid ZCL endpoint. |
| profile | Profile ID for this cluster (e.g. ZCL_PROFILE_HOME_AUTOMATION) |
| aps_secured | APS Security - true if APS Security enabled, else false |
Return
ZbZclCommissionClientEnable
enum ZclStatusCodeT ZbZclCommissionClientEnable(struct ZbZclClusterT *cluster, struct ZbZclCommissionClientEnableInfoT *info);
Enable Commissioning Client by configuring MAC layer to listen for packets.
Parameters
| info | Commissioning Client Enable Information structure |
Return
ZbZclCommissionClientSendResetStartup
enum ZclStatusCodeT ZbZclCommissionClientSendResetStartup(struct ZbZclClusterT *cluster, uint64_t dst_ext, uint8_t dst_ep, struct ZbZclCommissionClientResetStartup *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Reset Startup Parameters command
Parameters
| dst_ext | Extended address of the device to send this command |
| dst_ep | If cluster is not using Inter-PAN, this is the destination endpoint to send the command to. |
| req | Reset Startup Parameters command structure |
Return
ZbZclCommissionClientSendRestart
enum ZclStatusCodeT ZbZclCommissionClientSendRestart(struct ZbZclClusterT *cluster, uint64_t dst_ext, uint8_t dst_ep, struct ZbZclCommissionClientRestartDev *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Restart Device command
Parameters
| req | Restart Device command structure |
Return
ZbZclCommissionClientSendRestoreStartup
enum ZclStatusCodeT ZbZclCommissionClientSendRestoreStartup(struct ZbZclClusterT *cluster, uint64_t dst_ext, uint8_t dst_ep, struct ZbZclCommissionClientRestoreStartup *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Restore Startup Parameters command
Parameters
| req | Restore Startup Parameters command structure |
Return
ZbZclCommissionClientSendSaveStartup
enum ZclStatusCodeT ZbZclCommissionClientSendSaveStartup(struct ZbZclClusterT *cluster, uint64_t dst_ext, uint8_t dst_ep, struct ZbZclCommissionClientSaveStartup *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Save Startup Parameters command
Parameters
| req | Save Startup Parameters command structure |
Return
ZbZclCommissionServerAlloc
struct ZbZclClusterT * ZbZclCommissionServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, uint16_t profile, bool aps_secured, struct ZbZclCommissionServerCallbacksT *callbacks, void *arg);
Create a new instance of the Commissioning Server cluster
Parameters
| callbacks | Structure containing any callback function pointers for this cluster |
Return
ZbZclCommissionServerEnable
enum ZclStatusCodeT ZbZclCommissionServerEnable(struct ZbZclClusterT *cluster, bool enable, struct ZbZclCommissionServerEnableInfoT *info);
Enable the Commissioning Server by configuring the MAC layer to listen for packets. If enable is false, then Commissioning Server will stop processing any received Commissioning packets.
Parameters
| enable | Enable or disable the ability to receive and process Commissioning commands. |
| info | Commissioning Server Enable Information structure. Contains information needed to start listening for Commissioning commands on a given channel. Optional and only applicable if enable is true. This may be NULL if already configured and operational on a network. |
Return
ZbZclCommissionServerGetStartup
enum ZclStatusCodeT ZbZclCommissionServerGetStartup(struct ZbZclClusterT *cluster, struct ZbStartupT *config);
Load startup configuration from Cluster Server’s attributes to the stack’s ZbStartupT structure
Parameters
| config | Zigbee Stack Startup Configuration structure |
Return
ZbZclCommissionServerResetStartup
enum ZclStatusCodeT ZbZclCommissionServerResetStartup(struct ZbZclClusterT *cluster);
Reset startup configurations cluster attributes back to defaults
Parameters
Return
ZbZclCommissionServerSendResetStartupRsp
enum ZclStatusCodeT ZbZclCommissionServerSendResetStartupRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclCommissionServerResetStartupRsp *rsp);
Send a Reset Startup Parameters Response command
Parameters
| dst | Destination address for response, including sequence number and tx options |
| rsp | Reset Startup Parameters Response command structure |
Return
ZbZclCommissionServerSendRestartRsp
enum ZclStatusCodeT ZbZclCommissionServerSendRestartRsp(struct ZbZclClusterT *cluster, struct
ZbZclAddrInfoT *dst, struct ZbZclCommissionServerRestartDevRsp *rsp);
Send a Restart Device Response command
Parameters
| rsp | Restart Device Response command structure |
Return
ZbZclCommissionServerSendRestoreStartupRsp
enum ZclStatusCodeT ZbZclCommissionServerSendRestoreStartupRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclCommissionServerRestoreStartupRsp *rsp);
Send a Restore Startup Parameters Response command
Parameters
| rsp | Restore Startup Parameters Response command structure |
Return
ZbZclCommissionServerSendSaveStartupRsp
enum ZclStatusCodeT ZbZclCommissionServerSendSaveStartupRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclCommissionServerSaveStartupRsp *rsp);
Send a Save Startup Parameters Response command
Parameters
| rsp | Save Startup Parameters Response command structure |
Return
Enumerations
ZbZclCommissionServerAttrT
Commissioning Server Attribute IDs
| ZCL_COMMISSION_SVR_ATTR_SHORT_ADDR | ShortAddress. This should only be set if StartupControl is equal to 0x00 (ZbStartTypePreconfigured) or 0x02 (ZbStartTypeRejoin). |
| ZCL_COMMISSION_SVR_ATTR_EPID | ExtendedPANId |
| ZCL_COMMISSION_SVR_ATTR_PANID | PANId. This should only be set if StartupControl is equal to 0x00 (ZbStartTypePreconfigured) or 0x02 (ZbStartTypeRejoin). |
| ZCL_COMMISSION_SVR_ATTR_CHANNELMASK | Channelmask |
| ZCL_COMMISSION_SVR_ATTR_PROTOCOLVER | ProtocolVersion. Default value is 0x0002 (ZB_PROTOCOL_VERSION_2007) |
| ZCL_COMMISSION_SVR_ATTR_STACKPROFILE | StackProfile. Default value is 0x02 (ZB_NWK_STACK_PROFILE_PRO) |
| ZCL_COMMISSION_SVR_ATTR_STARTUPCONTROL | StartupControl. ZbStartTypePreconfigured = 0x00, ZbStartTypeForm = 0x01, ZbStartTypeRejoin = 0x02, ZbStartTypeJoin = 0x03 |
| ZCL_COMMISSION_SVR_ATTR_TCADDR | TrustCenterAddress. This should only be set if StartupControl is equal to 0x00 (ZbStartTypePreconfigured). Otherwise it should be zero to allow the Transport Key to be decrypted and processed correctly during joining. |
| ZCL_COMMISSION_SVR_ATTR_TCMASTER | TrustCenterMasterKey (Optional) |
| ZCL_COMMISSION_SVR_ATTR_NWKKEY | NetworkKey. This should only be set if StartupControl is equal to 0x00 (ZbStartTypePreconfigured). |
| ZCL_COMMISSION_SVR_ATTR_USEINSECJOIN | UseInsecureJoin |
| ZCL_COMMISSION_SVR_ATTR_PRECONFLINKKEY | PreconfiguredLinkKey |
| ZCL_COMMISSION_SVR_ATTR_NWKKEYSEQNUM | NetworkKeySeqNum. This should only be set if StartupControl is equal to 0x00 (ZbStartTypePreconfigured). |
| ZCL_COMMISSION_SVR_ATTR_NWKKEYTYPE | NetworkKeyType. This should only be set if StartupControl is equal to 0x00 (ZbStartTypePreconfigured). |
| ZCL_COMMISSION_SVR_ATTR_NWKMGRADDR | NetworkManagerAddress. This should only be set if StartupControl is equal to 0x00 (ZbStartTypePreconfigured) or 0x02 (ZbStartTypeRejoin). |
| ZCL_COMMISSION_SVR_ATTR_SCANATTEMPTS | ScanAttempts (Optional) |
| ZCL_COMMISSION_SVR_ATTR_TIMEBTWSCANS | TimeBetweenScans (Optional) |
| ZCL_COMMISSION_SVR_ATTR_REJOININTERVAL | RejoinInterval (Optional) |
| ZCL_COMMISSION_SVR_ATTR_MAXREJOININTERVAL | MaxRejoinInterval (Optional) |
| ZCL_COMMISSION_SVR_ATTR_POLLRATE | IndirectPollRate (Optional) |
| ZCL_COMMISSION_SVR_ATTR_PARENTRETRYTHRESH | ParentRetryThreshold (Optional) |
| ZCL_COMMISSION_SVR_ATTR_CONCFLAG | ConcentratorFlag (Optional) |
| ZCL_COMMISSION_SVR_ATTR_CONCRADIUS | ConcentratorRadius (Optional) |
| ZCL_COMMISSION_SVR_ATTR_CONCDISCTIME | ConcentratorDiscoveryTime (Optional) |
Structures
Parameters
| uint8_t page | Page |
| uint8_t channel | Channel |
Parameters
| uint8_t options | Options - e.g. ZCL_COMMISS_RESET_OPTS_RESET_CURR |
| uint8_t index | Index |
Parameters
| uint8_t options | Options - e.g. ZCL_COMMISS_RESTART_OPTS_MODE_MASK |
| uint8_t delay | Delay (seconds) |
| uint8_t jitter | Jitter - RAND(jitter * 80) milliseconds |
Parameters
| uint8_t options | Options (Reserved) |
Parameters
Commissioning Server callbacks configuration
Parameters
| restart_device
enum ZclStatusCodeT (*restart_device)(struct ZbZclClusterT *cluster, struct ZbZclCommissionClientRestartDev *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Restart Device command. Should call ZbZclCommissionServerSendRestartRsp to send response. Since the application will end up calling ZbStartup or similar, the application must wait and let the stack send the response before something like ZbStartup is called. 100 milliseconds should be sufficient (ZCL_COMMISSION_RESTART_DEVICE_DELAY_MS). |
| save_startup
enum ZclStatusCodeT (*save_startup)(struct ZbZclClusterT *cluster, struct ZbZclCommissionClientSaveStartup *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Save Startup Parameters command. |
| restore_startup
enum ZclStatusCodeT (*restore_startup)(struct ZbZclClusterT *cluster, struct ZbZclCommissionClientRestoreStartup *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Restore Startup Parameters command. |
| reset_startup
enum ZclStatusCodeT (*reset_startup)(struct ZbZclClusterT *cluster, struct ZbZclCommissionClientResetStartup *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Reset Startup Parameters command. |
Parameters
Parameters
| enum ZclStatusCodeT status | ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error. |
Parameters
Parameters
Parameters
6.2.6. Dehumidification Control
#include "zcl/general/zcl.dehum.ctrl.h"
Functions
ZbZclDehumCtrlClientAlloc
struct ZbZclClusterT * ZbZclDehumCtrlClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Instantiate a new instance of the Dehumidification Control client cluster
Parameters
Return
ZbZclDehumCtrlServerAlloc
struct ZbZclClusterT * ZbZclDehumCtrlServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Instantiate a new instance of the Dehumidification Control server cluster
Parameters
Return
Enumerations
ZbZclDehumCtrlServerAttrT
Dehumidification Control Attribute Ids
| ZCL_DEHUM_CTRL_SVR_ATTR_REL_HUM | RelativeHumidity |
| ZCL_DEHUM_CTRL_SVR_ATTR_DEHUM_COOLING | DehumidificationCooling |
| ZCL_DEHUM_CTRL_SVR_ATTR_RHDH_SETPT | RHDehumidificationSetpoint |
| ZCL_DEHUM_CTRL_SVR_ATTR_RH_MODE | RelativeHumidityMode |
| ZCL_DEHUM_CTRL_SVR_ATTR_DH_LOCKOUT | DehumidificationLockout |
| ZCL_DEHUM_CTRL_SVR_ATTR_DH_HYS | DehumidificationHysteresis |
| ZCL_DEHUM_CTRL_SVR_ATTR_DH_MAX_COOL | DehumidificationMaxCool |
| ZCL_DEHUM_CTRL_SVR_ATTR_RH_DISPLAY | RelativeHumidityDisplay |
6.2.7. Device Temperature Configuration
#include "zcl/general/zcl.device.temp.h"
Functions
ZbZclDevTempClientAlloc
struct ZbZclClusterT * ZbZclDevTempClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Device Temperature Configuration Client cluster
Parameters
Return
ZbZclDevTempServerAlloc
struct ZbZclClusterT * ZbZclDevTempServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Instantiate a new instance of the Device Temp client cluster.
Parameters
Return
Enumerations
ZbZclDeviceTempAlarmCode
Device Temperature Configuration Alarm Code
| ZCL_DEV_TEMP_ALARM_CODE_LOW | Device Temperature too low |
| ZCL_DEV_TEMP_ALARM_CODE_HIGH | Device Temperature too high |
ZbZclDeviceTempAlarmMask
Device Temperature Configuration Alarm Mask
| ZCL_DEV_TEMP_ALARM_MASK_CLEAR | Alarm mask clear |
| ZCL_DEV_TEMP_ALARM_MASK_LOW | Alarm mask low |
| ZCL_DEV_TEMP_ALARM_MASK_HIGH | Alarm mask high |
ZbZclDeviceTempSvrAttrT
Device Temperature Cluster Attribute Ids
| ZCL_DEV_TEMP_CURRENT | CurrentTemperature |
| ZCL_DEV_TEMP_MIN_TEMP | MinTempExperienced (Optional) |
| ZCL_DEV_TEMP_MAX_TEMP | MaxTempExperienced (Optional) |
| ZCL_DEV_TEMP_OVER_TEMP_DWELL | OverTempTotalDwell (Optional) |
| ZCL_DEV_TEMP_ALARM_MASK | DeviceTempAlarmMask (Optional) |
| ZCL_DEV_TEMP_LOW_THRESHOLD | LowTempThreshold (Optional) |
| ZCL_DEV_TEMP_HIGH_THRESHOLD | HighTempThreshold (Optional) |
| ZCL_DEV_TEMP_LOW_DWELL_TRIP | LowTempDwellTripPoint (Optional) |
| ZCL_DEV_TEMP_HIGH_DWELL_TRIP | HighTempDwellTripPoint (Optional) |
6.2.8. Diagnostics
#include "zcl/general/zcl.diagnostics.h"
Functions
ZbZclDiagClientAlloc
struct ZbZclClusterT * ZbZclDiagClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Diagnostics Client cluster
Parameters
Return
ZbZclDiagServerAlloc
bool ZbZclDiagServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, uint16_t profileId, enum ZbStatusCodeT minSecurity);
Create a new instance of the Diagnostics Server cluster. Only one Diagnostics Server can be allocated on the device
Parameters
| profileId | Profile ID setting, unless set to ZCL_PROFILE_WILDCARD |
| minSecurity | Minimum security level can be either: ZB_APS_STATUS_UNSECURED, ZB_APS_STATUS_SECURED_NWK_KEY, or ZB_APS_STATUS_SECURED_LINK_KEY |
Return
- True on success, false otherwise
Enumerations
ZbZclDiagSvrAttrT
Diagnostics Server Attribute IDs
| ZCL_DIAG_SVR_ATTR_RESETS | NumberOfResets (Optional) |
| ZCL_DIAG_SVR_ATTR_PERSIST_WRITES | PersistentMemoryWrites (Optional) |
| ZCL_DIAG_SVR_ATTR_MAC_RX_BCAST | MacRxBcast (Optional) |
| ZCL_DIAG_SVR_ATTR_MAC_TX_BCAST | MacTxBcast (Optional) |
| ZCL_DIAG_SVR_ATTR_MAC_RX_UCAST | MacRxUcast (Optional) |
| ZCL_DIAG_SVR_ATTR_MAC_TX_UCAST | MacTxUcast (Optional) |
| ZCL_DIAG_SVR_ATTR_MAC_TX_UCAST_RETRY | MacTxUcastRetry (Optional) |
| ZCL_DIAG_SVR_ATTR_MAC_TX_UCAST_FAIL | MacTxUcastFail (Optional) |
| ZCL_DIAG_SVR_ATTR_APS_RX_BCAST | APSRxBcast (Optional) |
| ZCL_DIAG_SVR_ATTR_APS_TX_BCAST | APSTxBcast (Optional) |
| ZCL_DIAG_SVR_ATTR_APS_RX_UCAST | APSRxUcast (Optional) |
| ZCL_DIAG_SVR_ATTR_APS_TX_UCAST_SUCCESS | APSTxUcastSuccess (Optional) |
| ZCL_DIAG_SVR_ATTR_APS_TX_UCAST_RETRY | APSTxUcastRetry (Optional) |
| ZCL_DIAG_SVR_ATTR_APS_TX_UCAST_FAIL | APSTxUcastFail (Optional) |
| ZCL_DIAG_SVR_ATTR_ROUTE_DISC_INIT | RouteDiscInitiated (Optional) |
| ZCL_DIAG_SVR_ATTR_NEIGHBOR_ADDED | NeighborAdded (Optional) |
| ZCL_DIAG_SVR_ATTR_NEIGHBOUR_REMOVED | NeighborRemoved (Optional) |
| ZCL_DIAG_SVR_ATTR_NEIGHBOUR_STALE | NeighborStale (Optional) |
| ZCL_DIAG_SVR_ATTR_JOIN_IND | JoinIndication (Optional) |
| ZCL_DIAG_SVR_ATTR_CHILD_MOVED | ChildMoved (Optional) |
| ZCL_DIAG_SVR_ATTR_NWK_FC_FAILURE | NWKFCFailure (Optional) |
| ZCL_DIAG_SVR_ATTR_APS_FC_FAILURE | APSFCFailure (Optional) |
| ZCL_DIAG_SVR_ATTR_APS_UNAUTH_KEY | APSUnauthorizedKey (Optional) |
| ZCL_DIAG_SVR_ATTR_NWK_DECRYPT_FAILS | NWKDecryptFailures (Optional) |
| ZCL_DIAG_SVR_ATTR_APS_DECRYPT_FAILS | APSDecryptFailures (Optional) |
| ZCL_DIAG_SVR_ATTR_PACKET_BUF_ALLOC_FAILS | PacketBufferAllocateFailures (Optional) |
| ZCL_DIAG_SVR_ATTR_RELAYED_UCAST | RelayedUcast (Optional) |
| ZCL_DIAG_SVR_ATTR_PHY_MAC_QUEUE_LIM | PhytoMACqueuelimitreached (Optional) |
| ZCL_DIAG_SVR_ATTR_PACKET_VAL_DROP_COUNT | PacketValidatedropcount (Optional) |
| ZCL_DIAG_SVR_ATTR_AVG_MAC_RETRY_PER_APS_MSG | AverageMACRetryPerAPSMessageSent (Optional) |
| ZCL_DIAG_SVR_ATTR_LAST_MSG_LQI | LastMessageLQI (Optional) |
| ZCL_DIAG_SVR_ATTR_LAST_MSG_RSSI | LastMessageRSSI (Optional) |
6.2.9. Door Lock
#include "zcl/general/zcl.doorlock.h"
Functions
ZbZclDoorLockClientAlloc
struct ZbZclClusterT * ZbZclDoorLockClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Door Lock Client cluster
Parameters
Return
ZbZclDoorLockClientClrAllPinReq
enum ZclStatusCodeT ZbZclDoorLockClientClrAllPinReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Clear All PIN Codes request command
Parameters
Return
ZbZclDoorLockClientClrAllRfidReq
enum ZclStatusCodeT ZbZclDoorLockClientClrAllRfidReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Clear All RFID Codes request command
Parameters
Return
ZbZclDoorLockClientClrHDScheduleReq
enum ZclStatusCodeT ZbZclDoorLockClientClrHDScheduleReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockClrHDScheduleReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Clear Holiday Schedule request command
Parameters
| req | Clear Holiday Schedule request structure |
Return
ZbZclDoorLockClientClrPinReq
enum ZclStatusCodeT ZbZclDoorLockClientClrPinReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockClrPinReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Clear PIN Code request command
Parameters
| req | Clear PIN Code request structure |
Return
ZbZclDoorLockClientClrRfidReq
enum ZclStatusCodeT ZbZclDoorLockClientClrRfidReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockClrRfidReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Clear RFID Code request command
Parameters
| req | Clear RFID Code request structure |
Return
ZbZclDoorLockClientClrWDScheduleReq
enum ZclStatusCodeT ZbZclDoorLockClientClrWDScheduleReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockClrWDScheduleReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Clear Weekday Schedule request command
Parameters
| req | Clear Weekday Schedule request structure |
| callback | Callback function that will be invoked when the response is received. |
Return
ZbZclDoorLockClientClrYDScheduleReq
enum ZclStatusCodeT ZbZclDoorLockClientClrYDScheduleReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockClrYDScheduleReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Clear Year Day Schedule request command
Parameters
| req | Clear Year Day Schedule request structure |
Return
ZbZclDoorLockClientGetHDScheduleReq
enum ZclStatusCodeT ZbZclDoorLockClientGetHDScheduleReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockGetHDScheduleReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Holiday Schedule request command
Parameters
| req | Get Holiday Schedule request structure |
Return
ZbZclDoorLockClientGetLogReq
enum ZclStatusCodeT ZbZclDoorLockClientGetLogReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockGetLogReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Log Record request command
Parameters
| req | Get Log Record request structure |
Return
ZbZclDoorLockClientGetPinReq
enum ZclStatusCodeT ZbZclDoorLockClientGetPinReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockGetPinReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get PIN Code request command
Parameters
| req | Get PIN Code request structure |
Return
ZbZclDoorLockClientGetRfidReq
enum ZclStatusCodeT ZbZclDoorLockClientGetRfidReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockGetRfidReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get RFID Code request command
Parameters
| req | Get RFID Code request structure |
Return
ZbZclDoorLockClientGetUserStatusReq
enum ZclStatusCodeT ZbZclDoorLockClientGetUserStatusReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockGetUserStatusReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get User Status request command
Parameters
| req | Get User Status request structure |
Return
ZbZclDoorLockClientGetUserTypeReq
enum ZclStatusCodeT ZbZclDoorLockClientGetUserTypeReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockGetUserTypeReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get User Type request command
Parameters
| req | Get User Type request structure |
Return
ZbZclDoorLockClientGetWDScheduleReq
enum ZclStatusCodeT ZbZclDoorLockClientGetWDScheduleReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockGetWDScheduleReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Weekday Schedule request command
Parameters
| req | Get Weekday Schedule request structure |
Return
ZbZclDoorLockClientGetYDScheduleReq
enum ZclStatusCodeT ZbZclDoorLockClientGetYDScheduleReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockGetYDScheduleReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Year Day Schedule request command
Parameters
| req | Get Year Day Schedule request structure |
Return
ZbZclDoorLockClientLockReq
enum ZclStatusCodeT ZbZclDoorLockClientLockReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockLockDoorReqT *req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Lock Door request command
Parameters
| req | Lock Door request structure |
Return
ZbZclDoorLockClientSetHDScheduleReq
enum ZclStatusCodeT ZbZclDoorLockClientSetHDScheduleReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockSetHDScheduleReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Holiday Schedule request command
Parameters
| req | Set Holiday Schedule request structure |
Return
ZbZclDoorLockClientSetPinReq
enum ZclStatusCodeT ZbZclDoorLockClientSetPinReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockSetPinReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set PIN Code request command
Parameters
| req | Set PIN Code request structure |
Return
ZbZclDoorLockClientSetRfidReq
enum ZclStatusCodeT ZbZclDoorLockClientSetRfidReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockSetRfidReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set RFID Code request command
Parameters
| req | Set RFID Code request structure |
Return
ZbZclDoorLockClientSetUserStatusReq
enum ZclStatusCodeT ZbZclDoorLockClientSetUserStatusReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockSetUserStatusReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set User Status request command
Parameters
| req | Set User Status request structure |
Return
ZbZclDoorLockClientSetUserTypeReq
enum ZclStatusCodeT ZbZclDoorLockClientSetUserTypeReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockSetUserTypeReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set User Type request command
Parameters
| req | Set User Type request structure |
Return
ZbZclDoorLockClientSetWDScheduleReq
enum ZclStatusCodeT ZbZclDoorLockClientSetWDScheduleReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockSetWDScheduleReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Weekday Schedule request command
Parameters
| req | Set Weekday Schedule request structure |
Return
ZbZclDoorLockClientSetYDScheduleReq
enum ZclStatusCodeT ZbZclDoorLockClientSetYDScheduleReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockSetYDScheduleReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Year Day Schedule request command
Parameters
| req | Set Year Day Schedule request structure |
Return
ZbZclDoorLockClientToggleReq
enum ZclStatusCodeT ZbZclDoorLockClientToggleReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockToggleReqT *req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send Toggle request command
Parameters
| req | Toggle request structure |
Return
ZbZclDoorLockClientUnlockReq
enum ZclStatusCodeT ZbZclDoorLockClientUnlockReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockUnlockDoorReqT *req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send an Unlock Door request command
Parameters
| req | Unlock Door request structure |
Return
ZbZclDoorLockClientUnlockTimeoutReq
enum ZclStatusCodeT ZbZclDoorLockClientUnlockTimeoutReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDoorLockUnlockTimeoutReqT *req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send an Unlock with Timeout request command
Parameters
| req | Unlock with Timeout request structure |
Return
ZbZclDoorLockServerAlloc
struct ZbZclClusterT * ZbZclDoorLockServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclDoorLockServerCallbacksT *callbacks, void *arg);
Create a new instance of the Door Lock Server cluster
Parameters
| zb | Zigbee stack instance |
Return
ZbZclDoorLockServerSendClrAllPinRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendClrAllPinRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockClrAllPinRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Clear All PIN Codes response command
Parameters
| rsp | Clear All PIN Codes response structure |
Return
ZbZclDoorLockServerSendClrAllRfidRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendClrAllRfidRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockClrAllRfidRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Clear All RFID Codes response command
Parameters
| rsp | Clear All RFID Codes response structure |
Return
ZbZclDoorLockServerSendClrHDScheduleRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendClrHDScheduleRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockClrHDScheduleRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Clear Holiday Schedule response command
Parameters
| rsp | Clear Holiday Schedule response structure |
Return
ZbZclDoorLockServerSendClrPinRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendClrPinRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockClrPinRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Clear PIN Code response command
Parameters
| rsp | Clear PIN Code response structure |
Return
ZbZclDoorLockServerSendClrRfidRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendClrRfidRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockClrRfidRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Clear RFID Code response command
Parameters
| rsp | Clear RFID Code response structure |
Return
ZbZclDoorLockServerSendClrWDScheduleRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendClrWDScheduleRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockClrWDScheduleRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Clear Weekday Schedule response command
Parameters
| rsp | Clear Weekday Schedule response structure |
Return
ZbZclDoorLockServerSendClrYDScheduleRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendClrYDScheduleRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockClrYDScheduleRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Clear Year Day Schedule response command
Parameters
| rsp | Clear Year Day Schedule response structure |
Return
ZbZclDoorLockServerSendGetHDScheduleRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendGetHDScheduleRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockGetHDScheduleRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Get Holiday Schedule response command
Parameters
| rsp | Get Holiday Schedule response structure |
Return
ZbZclDoorLockServerSendGetLogRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendGetLogRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockGetLogRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Get Log Record response command
Parameters
| rsp | Get Log Record response structure |
Return
ZbZclDoorLockServerSendGetPinRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendGetPinRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockGetPinRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Get PIN Code response command
Parameters
| rsp | Get PIN Code response structure |
Return
ZbZclDoorLockServerSendGetRfidRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendGetRfidRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockGetRfidRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Get RFID Code response command
Parameters
| rsp | Get RFID Code response structure |
Return
ZbZclDoorLockServerSendGetUserStatusRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendGetUserStatusRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockGetUserStatusRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Get User Status response command
Parameters
| rsp | Get User Status response structure |
Return
ZbZclDoorLockServerSendGetUserTypeRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendGetUserTypeRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockGetUserTypeRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Get User Type response command
Parameters
| rsp | Get User Type response structure |
Return
ZbZclDoorLockServerSendGetWDScheduleRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendGetWDScheduleRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockGetWDScheduleRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Get Weekday Schedule response command
Parameters
| rsp | Get Weekday Schedule response structure |
Return
ZbZclDoorLockServerSendGetYDScheduleRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendGetYDScheduleRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockGetYDScheduleRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Get Year Day Schedule response command
Parameters
| rsp | Get Year Day Schedule response structure |
Return
ZbZclDoorLockServerSendLockRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendLockRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockLockDoorRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Lock Door response command
Parameters
| rsp | Lock Door response structure |
Return
ZbZclDoorLockServerSendSetHDScheduleRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendSetHDScheduleRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockSetHDScheduleRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Set Holiday Schedule response command
Parameters
| rsp | Set Holiday Schedule response structure |
Return
ZbZclDoorLockServerSendSetPinRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendSetPinRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockSetPinRspT *rsp,void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Set PIN Code response command
Parameters
| rsp | Set PIN Code response structure |
Return
ZbZclDoorLockServerSendSetRfidRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendSetRfidRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockSetRfidRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Set RFID Code response command
Parameters
| rsp | Set RFID Code response structure |
Return
ZbZclDoorLockServerSendSetUserStatusRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendSetUserStatusRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockSetUserStatusRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Set User Status response command
Parameters
| rsp | Set User Status response structure |
| arg | Pointer to application data that will included in the callback when invoked. |
Return
ZbZclDoorLockServerSendSetUserTypeRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendSetUserTypeRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockSetUserTypeRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Set User Type response command
Parameters
| rsp | Set User Type response structure |
Return
ZbZclDoorLockServerSendSetWDScheduleRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendSetWDScheduleRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockSetWDScheduleRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Set Weekday Schedule response command
Parameters
| rsp | Set Weekday Schedule response structure |
Return
ZbZclDoorLockServerSendSetYDScheduleRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendSetYDScheduleRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockSetYDScheduleRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Set Year Day Schedule response command
Parameters
| rsp | Set Year Day Schedule response structure |
Return
ZbZclDoorLockServerSendToggleRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendToggleRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockToggleRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Toggle response command
Parameters
| rsp | Toggle response structure |
Return
ZbZclDoorLockServerSendUnlockRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendUnlockRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockUnlockDoorRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send an Unlock Door response command
Parameters
| rsp | Unlock Door response structure |
Return
ZbZclDoorLockServerSendUnlockTimeoutRsp
enum ZclStatusCodeT ZbZclDoorLockServerSendUnlockTimeoutRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDoorLockUnlockTimeoutRspT *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send an Unlock with Timeout response command
Parameters
| rsp | Unlock with Timeout response structure |
Return
Structures
Parameters
| uint8_t status | Status |
Parameters
Parameters
| uint8_t schedule_id | Holiday Schedule ID |
Parameters
Parameters
| uint16_t user_id | User ID |
Parameters
Parameters
Parameters
Parameters
| uint8_t schedule_id | Schedule ID |
Parameters
Parameters
Parameters
Parameters
Parameters
| uint32_t local_start_time | Local Start Time |
| uint32_t local_end_time | Local End Time |
| uint8_t operating_mode | Operating Mode During Holiday |
Parameters
| uint16_t log_index | Log Index |
Parameters
| uint16_t log_entry_id | Log Entry ID |
| uint32_t time_stamp | Timestamp |
| uint8_t event_type | Event Type |
| uint8_t source | Source (see Operation Event Sources) |
| uint8_t alarm_code | Event ID/Alarm Code (see Operation Event Codes) |
| uint8_t pin | PIN |
| uint8_t pin_len | Length of PIN |
Parameters
Parameters
| uint8_t user_status | User Status |
| uint8_t user_type | User Type |
| uint8_t pin | Code |
| uint8_t pin_len | Length of Code |
Parameters
Parameters
| uint8_t rfid | RFID Code |
| uint8_t rfid_len | Length of RFID Code |
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
| uint8_t days_mask | Days Mask |
| uint8_t start_hour | Start Hour |
| uint8_t start_minute | Start Minute |
| uint8_t end_hour | End Hour |
| uint8_t end_minute | End Minute |
Parameters
Parameters
Parameters
| uint8_t pin | PIN/RFID Code |
| uint8_t pin_len | Length of PIN/RFID Code |
Parameters
Door Lock Server callbacks configuration
Parameters
| lock
enum ZclStatusCodeT (*lock)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockLockDoorReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Lock Door command. |
| unlock
enum ZclStatusCodeT (*unlock)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockUnlockDoorReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Unlock Door command. |
| toggle
enum ZclStatusCodeT (*toggle)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockToggleReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Toggle command. |
| unlock_timeout
enum ZclStatusCodeT (*unlock_timeout)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockUnlockTimeoutReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Unlock with Timeout command. |
| get_log
enum ZclStatusCodeT (*get_log)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockGetLogReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Get Log Record command. |
| set_pin
enum ZclStatusCodeT (*set_pin)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockSetPinReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Set PIN Code command. |
| get_pin
enum ZclStatusCodeT (*get_pin)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockGetPinReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Get PIN Code command. |
| clr_pin
enum ZclStatusCodeT (*clr_pin)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockClrPinReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Clear PIN Code command. |
| clr_all_pins
enum ZclStatusCodeT (*clr_all_pins)(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Clear All PIN Codes command. |
| set_user_status
enum ZclStatusCodeT (*set_user_status)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockSetUserStatusReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Set User Status command. |
| get_user_status
enum ZclStatusCodeT (*get_user_status)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockGetUserStatusReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Get User Status command. |
| set_wd_sched
enum ZclStatusCodeT (*set_wd_sched)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockSetWDScheduleReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Set Weekday Schedule command. |
| get_wd_sched
enum ZclStatusCodeT (*get_wd_sched)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockGetWDScheduleReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Get Weekday Schedule command. |
| clr_wd_sched
enum ZclStatusCodeT (*clr_wd_sched)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockClrWDScheduleReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Clear Weekday Schedule command. |
| set_yd_sched
enum ZclStatusCodeT (*set_yd_sched)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockSetYDScheduleReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Set Year Day Schedule command. |
| get_yd_sched
enum ZclStatusCodeT (*get_yd_sched)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockGetYDScheduleReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Get Year Day Schedule command. |
| clr_yd_sched
enum ZclStatusCodeT (*clr_yd_sched)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockClrYDScheduleReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
| set_hd_sched
enum ZclStatusCodeT (*set_hd_sched)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockSetHDScheduleReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Set Holiday Schedule command. |
| get_hd_sched
enum ZclStatusCodeT (*get_hd_sched)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockGetHDScheduleReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Get Holiday Schedule command. |
| clr_hd_sched
enum ZclStatusCodeT (*clr_hd_sched)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockClrHDScheduleReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Clear Holiday Schedule command. |
| set_user_type
enum ZclStatusCodeT (*set_user_type)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockSetUserTypeReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Set User Type command. |
| get_user_type
enum ZclStatusCodeT (*get_user_type)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockGetUserTypeReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Get User Type command. |
| set_rfid
enum ZclStatusCodeT (*set_rfid)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockSetRfidReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Set RFID Code command. |
| get_rfid
enum ZclStatusCodeT (*get_rfid)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockGetRfidReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Get RFID Code command. |
| clr_rfid
enum ZclStatusCodeT (*clr_rfid)(struct ZbZclClusterT *cluster, struct ZbZclDoorLockClrRfidReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Clear RFID Code command. |
| clr_all_rfids
enum ZclStatusCodeT (*clr_all_rfids)(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Clear All RFID Codes command. |
Parameters
Parameters
Parameters
| uint8_t pin | PIN |
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
| uint8_t schedule_id | ScheduleID # |
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
| uint16_t timeout | Timeout in seconds |
Parameters
6.2.10. Electrical Measurement
#include "zcl/general/zcl.elec.meas.h"
Functions
ZbZclElecMeasClientAlloc
struct ZbZclClusterT * ZbZclElecMeasClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Electrical Measurement Client cluster
Parameters
| endpoint | Endpoint on which to create cluster |
Return
- Cluster pointer, or NULL if there is an error
ZbZclElecMeasClientGetMeasProfileReq
enum ZclStatusCodeT ZbZclElecMeasClientGetMeasProfileReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclElecMeasClientGetMeasProfileReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Measurement Profile command
Parameters
| cluster | Cluster instance from which to send this command |
| dst | Destination address for request |
| req | Get Measurement Profile command structure |
Return
- ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error
ZbZclElecMeasClientGetProfileInfoReq
enum ZclStatusCodeT ZbZclElecMeasClientGetProfileInfoReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Profile Info command
Parameters
Return
ZbZclElecMeasServerAlloc
struct ZbZclClusterT * ZbZclElecMeasServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclElecMeasSvrCallbacksT *callbacks, void *arg);
Create a new instance of the Electrical Measurement Server cluster
Parameters
Return
ZbZclElecMeasServerSendMeasProfileRsp
enum ZclStatusCodeT ZbZclElecMeasServerSendMeasProfileRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclElecMeasSvrGetMeasProfileRspT *rsp);
Send a Get Measurement Profile response
Parameters
| rsp | Get Measurement Profile response structure |
Return
ZbZclElecMeasServerSendProfileInfoRsp
enum ZclStatusCodeT ZbZclElecMeasServerSendProfileInfoRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclElecMeasSvrGetProfileInfoRspT *rsp);
Send a Get Profile Info response
Parameters
| rsp | Get Profile Info response structure |
Return
Enumerations
ZbZclElecMeasSvrAttrT
Electrical Measurement Server Attribute IDs
| ZCL_ELEC_MEAS_ATTR_MEAS_TYPE | MeasurementType |
| ZCL_ELEC_MEAS_ATTR_DC_VOLT | DCVoltage (Optional) |
| ZCL_ELEC_MEAS_ATTR_DC_VOLT_MIN | DCVoltageMin (Optional) |
| ZCL_ELEC_MEAS_ATTR_DC_VOLT_MAX | DCVoltageMax (Optional) |
| ZCL_ELEC_MEAS_ATTR_DC_CURRENT | DCCurrent (Optional) |
| ZCL_ELEC_MEAS_ATTR_DC_CURRENT_MIN | DCCurrentMin (Optional) |
| ZCL_ELEC_MEAS_ATTR_DC_CURRENT_MAX | DCCurrentMax (Optional) |
| ZCL_ELEC_MEAS_ATTR_DC_POWER | DCPower (Optional) |
| ZCL_ELEC_MEAS_ATTR_DC_POWER_MIN | DCPowerMin (Optional) |
| ZCL_ELEC_MEAS_ATTR_DC_POWER_MAX | DCPowerMax (Optional) |
| ZCL_ELEC_MEAS_ATTR_DC_VOLT_MULTIPLIER | DCVoltageMultiplier (Optional) |
| ZCL_ELEC_MEAS_ATTR_DC_VOLT_DIVISOR | DCVoltageDivisor (Optional) |
| ZCL_ELEC_MEAS_ATTR_DC_CURR_MULTIPLIER | DCCurrentMultiplier (Optional) |
| ZCL_ELEC_MEAS_ATTR_DC_CURR_DIVISOR | DCCurrentDivisor (Optional) |
| ZCL_ELEC_MEAS_ATTR_DC_PWR_MULTIPLIER | DCPowerMultiplier (Optional) |
| ZCL_ELEC_MEAS_ATTR_DC_PWR_DIVISOR | DCPowerDivisor (Optional) |
| ZCL_ELEC_MEAS_ATTR_AC_FREQ | ACFrequency (Optional) |
| ZCL_ELEC_MEAS_ATTR_AC_FREQ_MIN | ACFrequencyMin (Optional) |
| ZCL_ELEC_MEAS_ATTR_AC_FREQ_MAX | ACFrequencyMax (Optional) |
| ZCL_ELEC_MEAS_ATTR_NEUTRAL_CURR | NeutralCurrent (Optional) |
| ZCL_ELEC_MEAS_ATTR_TOTAL_ACTIVE_PWR | TotalActivePower (Optional) |
| ZCL_ELEC_MEAS_ATTR_TOTAL_REACTIVE_PWR | TotalReactivePower (Optional) |
| ZCL_ELEC_MEAS_ATTR_TOTAL_APPARENT_PWR | TotalApparentPower (Optional) |
| ZCL_ELEC_MEAS_ATTR_1ST_HARM_CURR | Measured1stHarmonicCurrent (Optional) |
| ZCL_ELEC_MEAS_ATTR_3RD_HARM_CURR | Measured3rdHarmonicCurrent (Optional) |
| ZCL_ELEC_MEAS_ATTR_5TH_HARM_CURR | Measured5thHarmonicCurrent (Optional) |
| ZCL_ELEC_MEAS_ATTR_7TH_HARM_CURR | Measured7thHarmonicCurrent (Optional) |
| ZCL_ELEC_MEAS_ATTR_9TH_HARM_CURR | Measured9thHarmonicCurrent (Optional) |
| ZCL_ELEC_MEAS_ATTR_11TH_HARM_CURR | Measured11thHarmonicCurrent (Optional) |
| ZCL_ELEC_MEAS_ATTR_PHASE_1ST_HARM_CURR | MeasuredPhase1stHarmonicCurrent (Optional) |
| ZCL_ELEC_MEAS_ATTR_PHASE_3RD_HARM_CURR | MeasuredPhase3rdHarmonicCurrent (Optional) |
| ZCL_ELEC_MEAS_ATTR_PHASE_5TH_HARM_CURR | MeasuredPhase5thHarmonicCurrent (Optional) |
| ZCL_ELEC_MEAS_ATTR_PHASE_7TH_HARM_CURR | MeasuredPhase7thHarmonicCurrent (Optional) |
| ZCL_ELEC_MEAS_ATTR_PHASE_9TH_HARM_CURR | MeasuredPhase9thHarmonicCurrent (Optional) |
| ZCL_ELEC_MEAS_ATTR_PHASE_11TH_HARM_CURR | MeasuredPhase11thHarmonicCurrent (Optional) |
| ZCL_ELEC_MEAS_ATTR_AC_FREQ_MULTIPLIER | ACFrequencyMultiplier (Optional) |
| ZCL_ELEC_MEAS_ATTR_AC_FREQ_DIVISOR | ACFrequencyDivisor (Optional) |
| ZCL_ELEC_MEAS_ATTR_PWR_MULTIPLIER | PowerMultiplier (Optional) |
| ZCL_ELEC_MEAS_ATTR_PWR_DIVISOR | PowerDivisor (Optional) |
| ZCL_ELEC_MEAS_ATTR_HARM_CURR_MULTIPLIER | HarmonicCurrentMultiplier (Optional) |
| ZCL_ELEC_MEAS_ATTR_PHASE_CURR_MULTIPLIER | PhaseHarmonicCurrentMultiplier (Optional) |
| ZCL_ELEC_MEAS_ATTR_LINE_CURR | LineCurrent (Optional) |
| ZCL_ELEC_MEAS_ATTR_ACTIVE_CURR | ActiveCurrent (Optional) |
| ZCL_ELEC_MEAS_ATTR_REACTIVE_CURR | ReactiveCurrent (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_VOLT | RMSVoltage (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_VOLT_MIN | RMSVoltageMin (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_VOLT_MAX | RMSVoltageMax (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_CURR | RMSCurrent (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_CURR_MIN | RMSCurrentMin (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_CURR_MAX | RMSCurrentMax (Optional) |
| ZCL_ELEC_MEAS_ATTR_ACTIVE_PWR | ActivePower (Optional) |
| ZCL_ELEC_MEAS_ATTR_ACTIVE_PWR_MIN | ActivePowerMin (Optional) |
| ZCL_ELEC_MEAS_ATTR_ACTIVE_PWR_MAX | ActivePowerMax (Optional) |
| ZCL_ELEC_MEAS_ATTR_REACTIVE_PWR | ReactivePower (Optional) |
| ZCL_ELEC_MEAS_ATTR_APPARENT_PWR | ApparentPower (Optional) |
| ZCL_ELEC_MEAS_ATTR_PWR_FACTOR | PowerFactor (Optional) |
| ZCL_ELEC_MEAS_ATTR_AVG_RMS_VOLT_PERIOD | AverageRMSVoltageMeasurementPeriod (Optional) |
| ZCL_ELEC_MEAS_ATTR_AVG_RMS_OV_COUNT | AverageRMSOverVoltageCounter (Optional) |
| ZCL_ELEC_MEAS_ATTR_AVG_RMS_UV_COUNT | AverageRMSUnderVoltageCounter (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_EXT_OVER_PERIOD | RMSExtremeOverVoltagePeriod (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_EXT_UNDER_PERIOD | RMSExtremeUnderVoltagePeriod (Optional) |
| ZCL_ELEC_MEAS_ATTR_VOLT_SAG_PERIOD | RMSVoltageSagPeriod (Optional) |
| ZCL_ELEC_MEAS_ATTR_VOLT_SWELL_PERIOD | RMSVoltageSwellPeriod (Optional) |
| ZCL_ELEC_MEAS_ATTR_AC_VOLT_MULTIPLIER | ACVoltageMultiplier (Optional) |
| ZCL_ELEC_MEAS_ATTR_AC_VOLT_DIVISOR | ACVoltageDivisor (Optional) |
| ZCL_ELEC_MEAS_ATTR_AC_CURR_MULT | ACCurrentMultiplier (Optional) |
| ZCL_ELEC_MEAS_ATTR_AC_CURR_DIVISOR | ACCurrentDivisor (Optional) |
| ZCL_ELEC_MEAS_ATTR_AC_PWR_MULTIPLIER | ACPowerMultiplier (Optional) |
| ZCL_ELEC_MEAS_ATTR_AC_PWR_DIVISOR | ACPowerDivisor (Optional) |
| ZCL_ELEC_MEAS_ATTR_DC_OL_ALARMS_MASK | DCOverloadAlarmsMask (Optional) |
| ZCL_ELEC_MEAS_ATTR_DC_VOLT_OL | DCVoltageOverload (Optional) |
| ZCL_ELEC_MEAS_ATTR_DC_CURR_OL | DCCurrentOverload (Optional) |
| ZCL_ELEC_MEAS_ATTR_AC_ALARMS_MASK | ACAlarmsMask (Optional) |
| ZCL_ELEC_MEAS_ATTR_AC_VOLT_OL | ACVoltageOverload (Optional) |
| ZCL_ELEC_MEAS_ATTR_AC_CURR_OL | ACCurrentOverload (Optional) |
| ZCL_ELEC_MEAS_ATTR_AC_ACTIVE_PWR_OL | ACActivePowerOverload (Optional) |
| ZCL_ELEC_MEAS_ATTR_AC_REACTIVE_PWR_OL | ACReactivePowerOverload (Optional) |
| ZCL_ELEC_MEAS_ATTR_AVG_RMS_OV | AverageRMSOverVoltage (Optional) |
| ZCL_ELEC_MEAS_ATTR_AVG_RMS_UV | AverageRMSUnderVoltage (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_EXT_OV | RMSExtremeOverVoltage (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_EXT_UV | RMSExtremeUnderVoltage (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_VOLT_SAG | RMSVoltageSag (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_VOLT_SWELL | RMSVoltageSwell (Optional) |
| ZCL_ELEC_MEAS_ATTR_LINE_CURR_B | LineCurrentPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_ACTIVE_CURR_B | ActiveCurrentPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_REACTIVE_CURR_B | ReactiveCurrentPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_VOLT_B | RMSVoltagePhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_VOLT_MIN_B | RMSVoltageMinPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_VOLT_MAX_B | RMSVoltageMaxPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_CURR_B | RMSCurrentPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_CURR_MIN_B | RMSCurrentMinPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_CURR_MAX_B | RMSCurrentMaxPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_ACTIVE_PWR_B | ActivePowerPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_ACTIVE_PWR_MIN_B | ActivePowerMinPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_ACTIVE_PWR_MAX_B | ActivePowerMaxPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_REACTIVE_PWR_B | ReactivePowerPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_APPARENT_PWR_B | ApparentPowerPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_PWR_FACTOR_B | PowerFactorPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_AVG_RMS_VOLT_PERIOD_B | AverageRMSVoltageMeasurementPeriodPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_AVG_RMS_OV_B | AverageRMSOverVoltageCounterPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_AVG_RMS_UV_B | AverageRMSUnderVoltageCounterPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_EXT_OVER_B | RMSExtremeOverVoltagePeriodPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_EXT_UNDER_B | RMSExtremeUnderVoltagePeriodPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_SAG_PERIOD_B | RMSVoltageSagPeriodPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_SWELL_PERIOD_B | RMSVoltageSwellPeriodPhB (Optional) |
| ZCL_ELEC_MEAS_ATTR_LINE_CURR_C | LineCurrentPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_ACTIVE_CURR_C | ActiveCurrentPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_REACTIVE_CURR_C | ReactiveCurrentPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_VOLT_C | RMSVoltagePhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_VOLT_MIN_C | RMSVoltageMinPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_VOLT_MAX_C | RMSVoltageMaxPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_CURR_C | RMSCurrentPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_CURR_MIN_C | RMSCurrentMinPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_CURR_MAX_C | RMSCurrentMaxPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_ACTIVE_PWR_C | ActivePowerPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_ACTIVE_PWR_MIN_C | ActivePowerMinPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_ACTIVE_PWR_MAX_C | ActivePowerMaxPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_REACTIVE_PWR_C | ReactivePowerPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_APPARENT_PWR_C | ApparentPowerPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_PWR_FACTOR_C | PowerFactorPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_AVG_RMS_VOLT_PERIOD_C | AverageRMSVoltageMeasurementPeriodPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_AVG_RMS_OV_C | AverageRMSOverVoltageCounterPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_AVG_RMS_UV_C | AverageRMSUnderVoltageCounterPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_EXT_OVER_C | RMSExtremeOverVoltagePeriodPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_EXT_UNDER_C | RMSExtremeUnderVoltagePeriodPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_SAG_PERIOD_C | RMSVoltageSagPeriodPhC (Optional) |
| ZCL_ELEC_MEAS_ATTR_RMS_SWELL_PERIOD_C | RMSVoltageSwellPeriodPhC (Optional) |
Structures
Parameters
| uint16_t attr_id | Attribute ID |
| uint32_t start_time | Start Time |
| uint8_t num_intervals | NumberOfIntervals |
Electrical Measurement Server callbacks configuration
Parameters
| get_profile_info
(callback function pointer) |
enum ZclStatusCodeT (*get_profile_info)(struct ZbZclClusterT *clusterPtr, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Get Profile Info command. |
| get_meas_profile
enum ZclStatusCodeT (*get_meas_profile)(struct ZbZclClusterT *clusterPtr, struct ZbZclElecMeasClientGetMeasProfileReqT *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Get Measurement Profile command. |
Parameters
| uint32_t start_time | StartTime |
| uint8_t profile_interval_period | ProfileIntervalPeriod |
| uint8_t num_intervals_delivered | NumberOfIntervalsDelivered |
| uint8_t *interval_data | Intervals |
| uint16_t interval_len | Number of Intervals |
Parameters
| uint8_t profile_count | Profile Count |
| uint8_t max_num_intervals | MaxNumberOfIntervals |
| uint16_t *attr_list | ListOfAttributes |
6.2.11. Fan Control
#include "zcl/general/zcl.fan.h"
Functions
ZbZclFanClientAlloc
struct ZbZclClusterT * ZbZclFanClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Fan Control Client cluster
Parameters'
Return
ZbZclFanServerAlloc
struct ZbZclClusterT * ZbZclFanServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Fan Control Server cluster
Parameters'
Return
Enumerations
ZbZclFanModeT
Fan Mode Attribute Values
| ZCL_FAN_MODE_OFF | Off |
| ZCL_FAN_MODE_LOW | Low |
| ZCL_FAN_MODE_MED | Medium |
| ZCL_FAN_MODE_HI | High |
| ZCL_FAN_MODE_ON | On |
| ZCL_FAN_MODE_AUTO | Auto (the fan speed is self-regulated) |
| ZCL_FAN_MODE_SMART | Smart (when the heated/cooled space is occupied, the fan is always on) |
ZbZclFanSeqT
Fan Sequence Operation Attribute Values
| ZCL_FAN_SEQ_LMH | Low/Med/High |
| ZCL_FAN_SEQ_LH | Low/High |
| ZCL_FAN_SEQ_LMHA | Low/Med/High/Auto |
| ZCL_FAN_SEQ_LHA | Low/High/Auto |
| ZCL_FAN_SEQ_OA | On/Auto |
ZbZclFanSvrAttrT
Fan Control Server Attribute IDs
| ZCL_FAN_ATTR_MODE | FanMode |
| ZCL_FAN_ATTR_SEQUENCE | FanModeSequence |
6.2.12. Groups
#include "zcl/general/zcl.groups.h"
Functions
ZbZclGroupsClientAddIdentifyingReq
enum ZclStatusCodeT ZbZclGroupsClientAddIdentifyingReq(struct ZbZclClusterT *cluster, struct ZbZclGroupsClientAddIdentifyingReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Add Group If Identifying command
Parameters
| req | Add Group If Identifying command request structure |
Return
ZbZclGroupsClientAddReq
enum ZclStatusCodeT ZbZclGroupsClientAddReq(struct ZbZclClusterT *cluster, struct ZbZclGroupsClientAddReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Add Group command
Parameters
| req | Add Group command request structure |
Return
ZbZclGroupsClientAlloc
struct ZbZclClusterT * ZbZclGroupsClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Groups Client cluster
Parameters
Return
ZbZclGroupsClientGetMembershipReq
enum ZclStatusCodeT ZbZclGroupsClientGetMembershipReq(struct ZbZclClusterT *cluster, struct ZbZclGroupsClientGetMembershipReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Group Membership command
Parameters
| req | Get Group Membership command request structure |
Return
ZbZclGroupsClientRemoveAllReq
enum ZclStatusCodeT ZbZclGroupsClientRemoveAllReq(struct ZbZclClusterT *cluster, struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Remove All Groups command
Parameters
| req | Remove All Group command request structure |
Return
ZbZclGroupsClientRemoveReq
enum ZclStatusCodeT ZbZclGroupsClientRemoveReq(struct ZbZclClusterT *cluster, struct ZbZclGroupsClientRemoveReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Remove Group command
Parameters
| req | Remove Group command request structure |
Return
ZbZclGroupsClientViewReq
enum ZclStatusCodeT ZbZclGroupsClientViewReq(struct ZbZclClusterT *cluster, struct ZbZclGroupsClientViewReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a View Group command
Parameters
| req | View Group command request structure |
Return
ZbZclGroupsServerAlloc
struct ZbZclClusterT * ZbZclGroupsServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Groups Server cluster
Parameters
Return
Enumerations
ZbZclGroupsSvrAttrT
Groups Server Attribute IDs
| ZCL_GROUPS_ATTR_NAME_SUPPORT | NameSupport |
Structures
Add Group If Identifying command structure
Parameters
| struct ZbApsAddrT dst | Destination Address |
| uint16_t group_id | Group ID |
Add Group command structure
Parameters
Get Group Membership command structure
Parameters
| uint8_t num_groups | Group count |
| uint16_t group_list | Group list |
Remove Group command structure
Parameters
View Group command structure
Parameters
6.2.13. Identify
#include "zcl/general/zcl.identify.h"
Functions
ZbZclIdentifyClientAlloc
struct ZbZclClusterT * ZbZclIdentifyClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Identify Client cluster
Parameters
Return
ZbZclIdentifyServerAlloc
struct ZbZclClusterT * ZbZclIdentifyServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, const struct zcl_identify_server_callbacks_t *callbacks, void *arg);
Create a new instance of the Identify Server cluster
Parameters
Return
ZbZclIdentifyServerGetTime
uint16_t ZbZclIdentifyServerGetTime(struct ZbZclClusterT *cluster);
Get the local Identify Server time
Parameters
| cluster | Cluster instance with timer to get |
Return
- uint16_t Time remaining in zigbee timer
ZbZclIdentifyServerSetTime
void ZbZclIdentifyServerSetTime(struct ZbZclClusterT *cluster, uint16_t seconds);
Set the local Identify Server time
If BDB_COMMISSION_MODE_FIND_BIND is enabled and seconds > 0, seconds is adjusted to be >= ZB_BDBC_MinCommissioningTime
Parameters
| cluster | Cluster instance with timer to set |
| seconds | Seconds for updating the identify time counter |
Return
- Void
zcl_identify_cli_identify_req
enum ZclStatusCodeT zcl_identify_cli_identify_req(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, uint16_t identify_time, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Identify command
Parameters
| identify_time | Time which will be used to set the IdentifyTime attribute |
Return
zcl_identify_cli_query_req
enum ZclStatusCodeT zcl_identify_cli_query_req(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Identify Query command
Parameters
Return
Enumerations
ZbZclIdentifySvrAttrT
Identify Server Attribute IDs
| ZCL_IDENTIFY_ATTR_TIME | IdentifyTime |
6.2.14. Illuminance Level Sensing
#include "zcl/general/zcl.illum.level.h"
Functions
ZbZclIllumLevelClientAlloc
struct ZbZclClusterT * ZbZclIllumLevelClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Illuminance Level Sensing Client cluster
Parameters
Return
ZbZclIllumLevelServerAlloc
struct ZbZclClusterT * ZbZclIllumLevelServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Illuminance Level Sensing Server cluster
Parameters
Return
Enumerations
ZbZclIllumLevelSvrAttrT
Attribute Identifiers
| ZCL_ILLUM_LEVEL_ATTR_LEVEL_STATUS | LevelStatus |
| ZCL_ILLUM_LEVEL_ATTR_LIGHT_SENSOR_TYPE | LightSensorType |
| ZCL_ILLUM_LEVEL_ATTR_ILLUM_TARGET_LEVEL | IlluminanceTargetLevel |
6.2.15. Illuminance Measurement
#include "zcl/general/zcl.illum.meas.h"
Functions
ZbZclIllumMeasClientAlloc
struct ZbZclClusterT * ZbZclIllumMeasClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Illuminance Measurement Client cluster
Parameters
Return
ZbZclIllumMeasServerAlloc
struct ZbZclClusterT * ZbZclIllumMeasServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, uint16_t min, uint16_t max);
Create a new instance of the Illuminance Measurement Server cluster
Parameters
| min | Minimum value capable of being measured (MinMeasuredValue) |
| max | Maximum value capable of being measured (MaxMeasuredValue) |
Return
Enumerations
ZbZclIllumMeasSvrAttrT
Illuminance Measurement Server Attribute IDs
| ZCL_ILLUM_MEAS_ATTR_MEAS_VAL | MeasuredValue |
| ZCL_ILLUM_MEAS_ATTR_MIN_MEAS_VAL | MinMeasuredValue |
| ZCL_ILLUM_MEAS_ATTR_MAX_MEAS_VAL | MaxMeasuredValue |
| ZCL_ILLUM_MEAS_ATTR_TOLERANCE | Tolerance (Optional) |
| ZCL_ILLUM_MEAS_ATTR_LIGHT_SENSOR_TYPE | LightSensorType (Optional) |
6.2.16. Level
#include "zcl/general/zcl.level.h"
Functions
ZbZclLevelClientAlloc
struct ZbZclClusterT * ZbZclLevelClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Level Client cluster
Parameters
Return
ZbZclLevelClientMoveReq
enum ZclStatusCodeT ZbZclLevelClientMoveReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclLevelClientMoveReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Move command
Parameters
| req | Move command request structure |
Return
ZbZclLevelClientMoveToFreqReq
enum ZclStatusCodeT ZbZclLevelClientMoveToFreqReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclLevelClientMoveToFreqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Move to Frequency command
Parameters
| req | Stop command request structure |
Return
ZbZclLevelClientMoveToLevelReq
enum ZclStatusCodeT ZbZclLevelClientMoveToLevelReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclLevelClientMoveToLevelReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Move to Level command
Parameters
| req | Move To Level command request structure |
Return
ZbZclLevelClientStepReq
enum ZclStatusCodeT ZbZclLevelClientStepReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclLevelClientStepReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Step command
Parameters
| req | Step command request structure |
Return
ZbZclLevelClientStopReq
enum ZclStatusCodeT ZbZclLevelClientStopReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclLevelClientStopReqT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Stop command
Parameters
Return
ZbZclLevelServerAlloc
struct ZbZclClusterT * ZbZclLevelServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *onoff_server, struct ZbZclLevelServerCallbacksT *callbacks, void *arg);
Create a new instance of the Level Server cluster
Parameters
| onoff_server | OnOff server cluster pointer for processing commands with the Options fields. May be NULL |
| callbacks | Structure containing any callback function pointers for this cluster |
Return
Enumerations
ZbZclLevelSvrAttrT
Level Server Attribute IDs
| ZCL_LEVEL_ATTR_CURRLEVEL | CurrentLevel |
| ZCL_LEVEL_ATTR_REMAINTIME | RemainingTime (Optional) |
| ZCL_LEVEL_ATTR_MINLEVEL | MinLevel (Optional) |
| ZCL_LEVEL_ATTR_MAXLEVEL | MaxLevel (Optional) |
| ZCL_LEVEL_ATTR_CURRFREQ | CurrentFrequency (Optional) |
| ZCL_LEVEL_ATTR_MINFREQ | MinFrequency (Optional) |
| ZCL_LEVEL_ATTR_MAXFREQ | MaxFrequency (Optional) |
| ZCL_LEVEL_ATTR_OPTIONS | OnOffTransitionTime (Optional) |
| ZCL_LEVEL_ATTR_ONOFF_TRANS_TIME | OnLevel (Optional) |
| ZCL_LEVEL_ATTR_ONLEVEL | OnTransitionTime (Optional) |
| ZCL_LEVEL_ATTR_ON_TRANS_TIME | OffTransitionTime (Optional) |
| ZCL_LEVEL_ATTR_OFF_TRANS_TIME | DefaultMoveRate (Optional) |
| ZCL_LEVEL_ATTR_DEFAULT_MOVE_RATE | Options (Optional) |
| ZCL_LEVEL_ATTR_STARTUP_CURRLEVEL | StartUpCurrentLevel (Optional) |
Structures
Move command structure
Parameters
| bool with_onoff | With Onoff - If true then cmd is ZCL_LEVEL_CLI_CMD_MOVE_ONOFF, else ZCL_LEVEL_CLI_CMD_MOVE |
| uint8_t mode | Mode |
| uint8_t rate | Rate |
| uint8_t mask | OptionsMask - Not included if with_onoff is true |
| uint8_t override | OptionsOverride - Not included if with_onoff is true |
Move to Closest Frequency command structure
Parameters
| uint16_t freq | Frequency |
Move To Level command structure
Parameters
| bool with_onoff | With Onoff - If true then cmd is ZCL_LEVEL_CLI_CMD_MOVE_LEVEL_ONOFF, else ZCL_LEVEL_CLI_CMD_MOVE_LEVEL |
| uint8_t level | Level |
| uint16_t transition_time | Transition time |
Step command structure
Parameters
| bool with_onoff | With Onoff - If true then cmd is ZCL_LEVEL_CLI_CMD_STEP_ONOFF, else ZCL_LEVEL_CLI_CMD_STEP |
| uint8_t size | Size |
| uint16_t transition_time | Transition Time |
Stop command structure
Parameters
| bool with_onoff | With Onoff - If true then cmd is ZCL_LEVEL_CLI_CMD_STOP_ONOFF, else ZCL_LEVEL_CLI_CMD_STOP |
Level Server callbacks configuration
Parameters
| move_to_level
enum ZclStatusCodeT (*move_to_level)(struct ZbZclClusterT *cluster, struct ZbZclLevelClientMoveToLevelReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of a Move To Level command. Set with_onoff to true in the req struct when utilizing the onoff cluster on the same endpoint. The application is expected to update the ZCL_LEVEL_ATTR_CURRLEVEL attribute. |
| move
enum ZclStatusCodeT (*move)(struct ZbZclClusterT *cluster, struct ZbZclLevelClientMoveReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of a Move command. Set with_onoff to true in the req struct when utilizing the onoff cluster on the same endpoint. The application is expected to update the ZCL_LEVEL_ATTR_CURRLEVEL attribute. |
| step
enum ZclStatusCodeT (*step)(struct ZbZclClusterT *cluster, struct ZbZclLevelClientStepReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of a Step command. Set with_onoff to true in the req struct when utilizing the onoff cluster on the same endpoint. The application is expected to update the ZCL_LEVEL_ATTR_CURRLEVEL attribute. |
| stop
enum ZclStatusCodeT (*stop)(struct ZbZclClusterT *cluster, struct ZbZclLevelClientStopReqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of a Stop command. Set with_onoff to true in the req struct when utilizing the onoff cluster on the same endpoint. The application is expected to update the ZCL_LEVEL_ATTR_CURRLEVEL attribute. |
| move_to_freq
enum ZclStatusCodeT (*move_to_freq)(struct ZbZclClusterT *cluster, struct ZbZclLevelClientMoveToFreqT *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of a Move to Frequency command. The application is expected to update the ZCL_LEVEL_ATTR_CURRFREQ attribute. |
6.2.17. Meter Identification
#include "zcl/general/zcl.meter.id.h"
Functions
ZbZclMeterIdClientAlloc
struct ZbZclClusterT * ZbZclMeterIdClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Instantiate a new instance of the Meter Identification Client cluster
Parameters
Return
ZbZclMeterIdServerAlloc
struct ZbZclClusterT * ZbZclMeterIdServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Instantiate a new instance of the Meter Identification Server cluster
Parameters
Return
Enumerations
ZbZclMeterIdSvrAttrT
| ZCL_METER_ID_ATTR_COMPANY_NAME | CompanyName |
| ZCL_METER_ID_ATTR_METER_TYPE_ID | MeterTypeID |
| ZCL_METER_ID_ATTR_DATA_QUAL_ID | DataQualityID |
| ZCL_METER_ID_ATTR_CUSTOMER_NAME | CustomerName (Optional) |
| ZCL_METER_ID_ATTR_MODEL | Model (Optional) |
| ZCL_METER_ID_ATTR_PART_NUMBER | PartNumber (Optional) |
| ZCL_METER_ID_ATTR_PRODUCT_REV | ProductRevision (Optional) |
| ZCL_METER_ID_ATTR_SOFTWARE_REV | SoftwareRevision (Optional) |
| ZCL_METER_ID_ATTR_UTILITY_NAME | UtilityName (Optional) |
| ZCL_METER_ID_ATTR_POD | POD |
| ZCL_METER_ID_ATTR_AVAILABLE_POWER | AvailablePower |
| ZCL_METER_ID_ATTR_POWER_THRESH | PowerThreshold |
6.2.18. Nearest Gateway
#include "zcl/general/zcl.nearest.gw.h"
Functions
ZbZclNearestGwClientAlloc
struct ZbZclClusterT * ZbZclNearestGwClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Instantiate a new instance of the Nearest Gateway client cluster
Parameters
Return
ZbZclNearestGwServerAlloc
struct ZbZclClusterT * ZbZclNearestGwServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Instantiate a new instance of the Nearest Gateway server cluster
Parameters
Return
Enumerations
ZbZclNearestGwServerAttrT
Nearest Gateway Attribute Ids
| ZCL_NEAREST_GW_SVR_ATTR_NEAREST_GW | Nearest Gateway |
| ZCL_NEAREST_GW_SVR_ATTR_NEW_MOBILE_NODE | New Mobile Node |
6.2.19. Occupancy Sensing
#include "zcl/general/zcl.occupancy.h"
Functions
ZbZclOccupancyClientAlloc
struct ZbZclClusterT * ZbZclOccupancyClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Occupancy Sensing Server cluster
Parameters
Return
ZbZclOccupancyServerAlloc
struct ZbZclClusterT * ZbZclOccupancyServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Occupancy Sensing Client cluster
Parameters
Return
Enumerations
ZbZclOccupancySvrAttrT
Occupancy Sensing Server Attribute IDs
| ZCL_OCC_ATTR_OCCUPANCY | Occupancy |
| ZCL_OCC_ATTR_SENSORTYPE | OccupancySensorType |
| ZCL_OCC_ATTR_SENSORTYPE_BITMAP | OccupancySensorTypeBitmap |
| ZCL_OCC_ATTR_PIR_OU_DELAY | PIROccupiedToUnoccupiedDelay (Optional) |
| ZCL_OCC_ATTR_PIR_UO_DELAY | PIRUnoccupiedToOccupiedDelay (Optional) |
| ZCL_OCC_ATTR_PIR_UO_THRESHOLD | PIRUnoccupiedToOccupiedThreshold (Optional) |
| ZCL_OCC_ATTR_US_OU_DELAY | UltrasonicOccupiedToUnoccupiedDelay (Optional) |
| ZCL_OCC_ATTR_US_UO_DELAY | UltrasonicUnoccupiedToOccupiedDelay (Optional) |
| ZCL_OCC_ATTR_US_UO_THRESHOLD | UltrasonicUnoccupiedToOccupiedThreshold (Optional) |
| ZCL_OCC_ATTR_PHY_OU_DELAY | PhysicalContactOccupiedToUnoccupiedDelay (Optional) |
| ZCL_OCC_ATTR_PHY_UO_DELAY | PhysicalContactUnoccupiedToOccupiedDelay (Optional) |
| ZCL_OCC_ATTR_PHY_UO_THRESHOLD | PhysicalContactUnoccupiedToOccupiedThreshold (Optional) |
6.2.20. On/Off Switch Configuration
#include "zcl/general/zcl.onoff.swconfig.h"
Functions
ZbZclOnOffSwConfigClientAlloc
struct ZbZclClusterT * ZbZclOnOffSwConfigClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the OnOff Switch Configuration Client cluster
Parameters
Return
ZbZclOnOffSwConfigServerAlloc
struct ZbZclClusterT * ZbZclOnOffSwConfigServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, uint8_t switch_type);
Create a new instance of the OnOff Switch Configuration Server cluster
Parameters
| switch_type | Type of switch associated with this cluster server |
Return
Enumerations
ZbZclOnOffSwConfigSvrAttrId
Onoff Switch Configuration cluster attribute IDs
| ZCL_ONOFF_SWCONFIG_ATTR_TYPE | SwitchType |
| ZCL_ONOFF_SWCONFIG_ATTR_ACTIONS | SwitchActions |
6.2.21. On/Off
#include "zcl/general/zcl.onoff.h"
Functions
ZbZclOnOffClientAlloc
struct ZbZclClusterT * ZbZclOnOffClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the OnOff Client cluster
Parameters
Return
ZbZclOnOffClientOffReq
enum ZclStatusCodeT ZbZclOnOffClientOffReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Off command
Parameters
| callback | Callback function that will be invoked when response is received |
Return
ZbZclOnOffClientOnReq
enum ZclStatusCodeT ZbZclOnOffClientOnReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an On command
Parameters
Return
ZbZclOnOffClientToggleReq
enum ZclStatusCodeT ZbZclOnOffClientToggleReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Toggle command
Parameters
Return
ZbZclOnOffServerAlloc
struct ZbZclClusterT * ZbZclOnOffServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclOnOffServerCallbacksT *callbacks, void *arg);
Create a new instance of the OnOff Server cluster
Parameters
Return
ZbZclOnOffServerSetLevelControlCallback
void ZbZclOnOffServerSetLevelControlCallback(struct ZbZclClusterT *on_off_cluster, struct ZbZclClusterT *level_cluster, ZbZclLevelControlCallbackT levelControlCallback);
Set the Level control callback
Parameters
| on_off_cluster | OnOff cluster instance |
| level_cluster | Level cluster instance |
| levelControlCallback | Level control callback function |
Return
- Void
Enumerations
ZbZclOnOffSvrAttrT
OnOff Server Attribute IDs
| ZCL_ONOFF_ATTR_ONOFF | OnOff |
| ZCL_ONOFF_ATTR_GLOBAL_SCENE_CONTROL | GlobalSceneControl (Optional) |
| ZCL_ONOFF_ATTR_ON_TIME | OnTime (Optional) |
| ZCL_ONOFF_ATTR_OFF_WAIT_TIME | OffWaitTime (Optional) |
Structures
OnOff Server callbacks configuration
Parameters
| off
enum ZclStatusCodeT (*off)(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of an Off command. The application is expected to update ZCL_ONOFF_ATTR_ONOFF. |
| on
enum ZclStatusCodeT (*on)(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of an On command. The application is expected to update ZCL_ONOFF_ATTR_ONOFF. |
| toggle
enum ZclStatusCodeT (*toggle)(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of a Toggle command. The application is expected to update ZCL_ONOFF_ATTR_ONOFF. |
6.2.22. Over-The-Air Upgrade
#include "zcl/general/zcl.ota.h"
Functions
ZbZclOtaClientAlloc
struct ZbZclClusterT * ZbZclOtaClientAlloc(struct ZigBeeT *zb, struct ZbZclOtaClientConfig *config, void *arg);
Create a new instance of the OTA Upgrade Client cluster
Parameters
| config | Pointer to OTA client configuration structure |
| arg | Pointer to application data provided in initiating API call |
Return
ZbZclOtaClientDiscover
enum ZclStatusCodeT ZbZclOtaClientDiscover(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *addr);
Discover OTA Upgrade Server
Parameters
| addr | Destination address for discovery |
Return
ZbZclOtaClientDiscoverForced
void ZbZclOtaClientDiscoverForced(struct ZbZclClusterT *cluster, uint64_t ieee, uint8_t endpoint);
Set the OTA Upgrade Server directly (without discovery)
Parameters
| ieee | OTA Upgrade server IEEE address |
Return
- None
ZbZclOtaClientGetDefaultCallbacks
void ZbZclOtaClientGetDefaultCallbacks(struct ZbZclOtaClientCallbacksT *callbacks);
Load the default callbacks for ECDSA Suite 2 support
Parameters
Return
- None
ZbZclOtaClientImageTransferResume
enum ZclStatusCodeT ZbZclOtaClientImageTransferResume(struct ZbZclClusterT *cluster);
Resume an OTA Upgrade transfer. ZbZclOtaClientImageTransferResume is called if the NHLE (app) returned ZCL_STATUS_WAIT_FOR_DATA for the write_image callback. The OTA Client won’t request the next block of data in this case, until this function is called.
Parameters
Return
ZbZclOtaClientImageTransferStart
enum ZclStatusCodeT ZbZclOtaClientImageTransferStart(struct ZbZclClusterT *cluster);
Initiate an OTA Upgrade transfer.
Parameters
Return
ZbZclOtaClientQueryNextImageReq
enum ZclStatusCodeT ZbZclOtaClientQueryNextImageReq(struct ZbZclClusterT *cluster, struct ZbZclOtaImageDefinition *image_definition, uint8_t field_control, uint16_t hardware_version);
Send a Query Next Image Request command. If a response is received, or an error occurs, the 'query_next' callback is invoked to the application.
Parameters
| image_definition | OTA Header Image Definition structure (See 'struct ZbZclOtaImageDefinition') |
| field_control | Field Control |
| hardware_version | Hardware Version to include in request, unless set to 0xff. |
Return
- ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error.
ZbZclOtaHeaderParse
uint8_t ZbZclOtaHeaderParse(const uint8_t *payload, const uint8_t length, struct ZbZclOtaHeader *header);
Parse an OTA Upgrade payload buffer’s header information
Parameters
| payload | OTA Upgrade Payload buffer |
| length | Length of OTA Upgrade Payload |
| header | OTA Upgrade Header Fields structure |
Return
- Number of bytes parsed
ZbZclOtaServerAlloc
struct ZbZclClusterT * ZbZclOtaServerAlloc(struct ZigBeeT *zb, struct ZbZclOtaServerConfig
- config, void *arg);
Create a new instance of the OTA Upgrade Server cluster
Parameters
| config | OTA Upgrade Server Configuration structure |
| arg | Pointer to application data that will later be provided back to the callback function when invoked |
Return
ZbZclOtaServerImageNotifyReq
enum ZclStatusCodeT ZbZclOtaServerImageNotifyReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, uint8_t payload_type, uint8_t jitter, struct ZbZclOtaImageDefinition *image_definition);
Send an OTA Image Notify Server command Registering an image does not automatically send an Image Notify message, the OTA Server application can use ZbZclOtaServerImageNotifyReq after registering an image to notify clients of the availability of a new image
Parameters
| payload_type | Payload Type |
| jitter | Jitter |
| image_definition | OTA Header Image Definition structure |
Return
ZbZclOtaServerUpgradeEndRespUnsolic
enum ZclStatusCodeT ZbZclOtaServerUpgradeEndRespUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclOtaImageDefinition *image_definition, struct ZbZclOtaEndResponseTimes *end_response_times);
Send an Unsolicited OTA Upgrade End Response. This command is sent at some point in time after receiving the Upgrade End Request, which was already responsed to by a Default Response. This should be the normal way to handle the Upgrade End commands, rather than the Solicated Upgrade End Response (ZbZclOtaServerUpgradeEndRespSolic).
Parameters
| image_definition | OTA Header Image Definition |
| end_response_times | Upgrade End Response command |
Return
Enumerations
ZbZclOtaActivationPolicy
OTA Upgrade UpgradeActivationPolicy enumerations
| ZCL_OTA_ACTIVATION_POLICY_SERVER | OTA Server Activation Allowed |
| ZCL_OTA_ACTIVATION_POLICY_OUT_OF_BAND | Out-of-band Activation Only |
ZbZclOtaHeaderFieldCtrlBitmask
OTA Upgrade Header Field Control Bitmask enumerations
| ZCL_OTA_HEADER_FIELD_CONTROL_SECURITY_VERSION | Security Credential Version Present |
| ZCL_OTA_HEADER_FIELD_CONTROL_DEVICE_SPECIFIC | Device Specific File |
| ZCL_OTA_HEADER_FIELD_CONTROL_HARDWARE_VERSI ONS | Hardware Versions Present |
ZbZclOtaImageBlkReqFldCtrl
OTA Upgrade Image Block Request Field Control Bitmask enumerations
| ZCL_OTA_IMAGE_BLOCK_FC_IEEE | Request node’s IEEE address Present |
| ZCL_OTA_IMAGE_BLOCK_FC_MIN_PERIOD | MinimumBlockPeriod present |
ZbZclOtaImageNotifyCmd
OTA Upgrade Image Notify Command Payload enumerations
| ZCL_OTA_NOTIFY_TYPE_JITTER | Query jitter |
| ZCL_OTA_NOTIFY_TYPE_MFG_CODE | Query jitter and manufacturer code |
| ZCL_OTA_NOTIFY_TYPE_IMAGE_TYPE | Query jitter, manufacturer code, and image type |
| ZCL_OTA_NOTIFY_TYPE_FILE_VERSION | Query jitter, manufacturer code, image type, and new file version |
ZbZclOtaImageType
OTA Upgrade Image Types enumerations
| ZCL_OTA_IMAGE_TYPE_MFG_MIN | Manufacturer Specific (start) |
| ZCL_OTA_IMAGE_TYPE_MFG_MAX | Manufacturer Specific (end) |
| ZCL_OTA_IMAGE_TYPE_CLI_SECURITY_CRED | Client Security credentials |
| ZCL_OTA_IMAGE_TYPE_CLI_CONFIG | Client Configuration |
| ZCL_OTA_IMAGE_TYPE_SERVER_LOG | Server Log |
| ZCL_OTA_IMAGE_TYPE_PICTURE | Picture |
| ZCL_OTA_IMAGE_TYPE_WILDCARD | Wild Card |
ZbZclOtaQueryFldCtrlHwVer
OTA Upgrade Field Control Hardware Version enumerations
| ZCL_OTA_QUERY_FIELD_CONTROL_HW_VERSION | Hardware Version |
ZbZclOtaSecCredential
OTA Upgrade Security Credential Version enumerations
| ZCL_OTA_SEC_CRED_SE_1_0 | SE 1.0 |
| ZCL_OTA_SEC_CRED_SE_1_1 | SE 1.1 |
| ZCL_OTA_SEC_CRED_SE_2_0 | SE 2.0 |
| ZCL_OTA_SEC_CRED_SE_1_2 | SE 1.2 |
ZbZclOtaStackVersion
OTA Upgrade Zigbee Stack Version Values
| ZCL_OTA_STACK_VERSION_2006 | ZigBee 2006 |
| ZCL_OTA_STACK_VERSION_2007 | ZigBee 2007 |
| ZCL_OTA_STACK_VERSION_PRO | ZigBee Pro |
| ZCL_OTA_STACK_VERSION_IP | ZigBee IP |
ZbZclOtaStatus
OTA Upgrade Status Attribute Values (ImageUpgradeStatus)
| ZCL_OTA_STATUS_NORMAL | Normal |
| ZCL_OTA_STATUS_DOWNLOAD_IN_PROGRESS | Download in progress |
| ZCL_OTA_STATUS_DOWNLOAD_COMPLETE | Download complete |
| ZCL_OTA_STATUS_WAITING_TO_UPGRADE | Waiting to upgrade |
| ZCL_OTA_STATUS_COUNT_DOWN | Count down |
| ZCL_OTA_STATUS_WAIT_FOR_MORE | Wait for more |
| ZCL_OTA_STATUS_WAIT_UPGRADE_EXT | Waiting to Upgrade via External Event |
ZbZclOtaSubElementTag
OTA Upgrade Tag Identifiers enumerations
| ZCL_OTA_SUB_TAG_UPGRADE_IMAGE | Upgrade Image |
| ZCL_OTA_SUB_TAG_ECDSA_SIG1 | ECDSA Signature (Crypto Suite 1) |
| ZCL_OTA_SUB_TAG_ECDSA_CERT_1 | ECDSA Signing Certificate (Crypto Suite 1) |
| ZCL_OTA_SUB_TAG_IMAGE_INTEGRITY_CODE | Image Integrity Code |
| ZCL_OTA_SUB_TAG_PICTURE_DATA | Picture Data |
| ZCL_OTA_SUB_TAG_ECDSA_SIG2 | ECDSA Signature (Crypto Suite 2) |
| ZCL_OTA_SUB_TAG_ECDSA_CERT_2 | ECDSA Signing Certificate (Crypto Suite 2) |
ZbZclOtaSvrAttrId
OTA Upgrade Server Attribute IDs
| ZCL_OTA_ATTR_UPGRADE_SERVER_ID | UpgradeServerID |
| ZCL_OTA_ATTR_FILE_OFFSET | FileOffset (Optional).
When writing a non-zero value to ZCL_OTA_ATTR_FILE_OFFSET, the entire OTA Header must have already been received by this cluster. This can be used to resume a transfer that was interrupted by the local device being power cycled in the middle of an OTA download. The procedure in this case is to start the transfer over (ZbZclOtaClientImageTransferStart) and during the first write_image() callback to the application, you write a new value to the FileOffset attribute before returning from the callback. The OTA Client will then request the next block starting from the new FileOffset. During the write_image() callback, the application can also compare that the current OTA header matches the previous one, if saved before the reset. If relying on the Integrity Code (hash), the application must define it’s own image_validate() callback. This is because data that has already been saved to NVM will be skipped by the OTA Client after the reset, so the running hash is no longer valid. |
| ZCL_OTA_ATTR_CURRENT_FILE_VERSION | CurrentFileVersion (Optional) |
| ZCL_OTA_ATTR_CURRENT_STACK_VERSION | CurrentZigBeeStackVersion (Optional) |
| ZCL_OTA_ATTR_DOWNLOAD_FILE_VERSION | DownloadedFileVersion (Optional) |
| ZCL_OTA_ATTR_DOWNLOAD_STACK_VERSION | DownloadedZigBeeStackVersion (Optional) |
| ZCL_OTA_ATTR_IMAGE_UPGRADE_STATUS | ImageUpgradeStatus (Optional).
Writing ZCL_OTA_STATUS_NORMAL (0) to this attribute will reset the cluster back to defaults. |
| ZCL_OTA_ATTR_MANUFACTURER_ID | ManufacturerID (Optional) |
| ZCL_OTA_ATTR_IMAGE_TYPE_ID | ImageTypeID (Optional) |
| ZCL_OTA_ATTR_MIN_BLOCK_PERIOD | MinimumBlockPeriod (Optional) |
| ZCL_OTA_ATTR_IMAGE_STAMP | ImageStamp (Optional) |
| ZCL_OTA_ATTR_UPGRADE_ACTIVATION_POLICY | UpgradeActivationPolicy (Optional) |
| ZCL_OTA_ATTR_UPGRADE_TIMEOUT_POLICY | UpgradeTimeoutPolicy (Optional) |
ZbZclOtaTimeoutPolicy
OTA Upgrade UpgradeTimeoutPolicy enumerations
| ZCL_OTA_TIMEOUT_POLICY_APPLY_UPGRADE | Apply Upgrade After Timeout |
| ZCL_OTA_TIMEOUT_POLICY_DO_NOT_APPLY | Do not Apply Upgrade After Timeout |
Structures
OTA Upgrade callbacks configuration
Parameters
| discover_complete
void (*discover_complete)(struct ZbZclClusterT *cluster, enum ZclStatusCodeT status, void *arg)
Callback to Server, invoked on discovery of OTA Upgrade Server. If NULL and ZbZclOtaClientDiscover is successful, the default handler will automatically call ZbZclOtaClientQueryNextImageReq. |
| image_notify
enum ZclStatusCodeT (*image_notify)(struct ZbZclClusterT *cluster, uint8_t payload_type, uint8_t jitter, struct ZbZclOtaImageDefinition *image_definition, struct ZbApsdeDataIndT *data_ind, struct ZbZclHeaderT *zcl_header)
Callback to Server, invoked on receipt of Image Notify Server command If NULL, the OTA Client has default callback handlers to take care of a typical OTA firmware upgrade file. Callback Function Parameters:
The value of the payload type from the Image Notify command payload. The value indicates which parameters in the image_definition are valid.
The value of the query jitter from the Image Notify command payload. The jitter is used to decide if the client should drop the command or not. Refer to section 11.13.3.4 (Effect on Receipt) of the ZCL6 spec.
Pointer to the parsed image definition of the image from the Image notify payload.
The manufacturer code for this image.
The manufacturer specific image type, defined by the manufacturer.
The file version.
Pointer to the incoming APSDE-DATA.indication struct.
Pointer to the incoming ZCL Header struct. |
| query_next
void (*query_next)(struct ZbZclClusterT *cluster, enum ZclStatusCodeT status, struct ZbZclOtaImageDefinition image_definition, uint32_t image_size, void *arg)
Callback to Server, invoked on receipt of Query Next Image Response command. If no image was found, the status will be set to ZCL_STATUS_NO_IMAGE_AVAILABLE. Otherwise the status should be set to ZCL_STATUS_SUCCESS from the OTA Server. |
| update_raw
enum ZclStatusCodeT (*update_raw)(struct ZbZclClusterT *cluster, uint8_t length, uint8_t *data, void *arg)
Raw image data is sent through this callback, to update running hash of image for example. Normally, this callback should be left to use the cluster’s default internal handler, but if the application does define its own callback, it must also provide its own handler for the 'image_validate' callback. Return code is ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error (e.g. ZCL_STATUS_FAILURE). Callback Function Parameters:
The length of the data to be written in this invocation
The data to be written |
| write_tag
enum ZclStatusCodeT (*write_tag)(struct ZbZclClusterT *cluster, struct ZbZclOtaHeader *header, uint16_t tag_id, uint32_t tag_length, uint8_t data_length, uint8_t *data, void *arg)
Callback to write tag sub-element information. Normally this is left as-is after the cluster is allocated to use the default internal callback handler. The default handler will call the 'write_image' callback to process any image tag data (i.e. the actual firmware binary). Callback Function Parameters:
A pointer to the OTA header from the start of the transferred, see Table 11-2 OTA Header Fields in the OTA spec
The tag id for the data to be written, see Table 11-9 Tag Identifiers
The total length of data assocated with this tag. This value will remain constant for a given image for each tag id
The data to be written Return Code: ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error (e.g. ZCL_STATUS_FAILURE). |
| write_image
enum ZclStatusCodeT (*write_image)(struct ZbZclClusterT *cluster, struct ZbZclOtaHeader *header, uint8_t length, uint8_t *data, void *arg)
If not NULL, this is called by the cluster’s default 'write_tag' handler for ZCL_OTA_SUB_TAG_UPGRADE_IMAGE data. If the application has provided its own 'write_tag' handler, then this callback is not used. Callback Function Parameters:
A pointer to the OTA header.
| integrity_code
void (*integrity_code)(struct ZbZclClusterT *cluster, struct ZbZclOtaHeader *header, uint8_t length, uint8_t *data, void *arg)
If not NULL, this is called upon reception of the IMAGE_INTEGRITY_CODE sub-tag field. The 'data' parameter will contain the 16-byte hash value. This is used in conjunction with the 'update_raw' callback, which is called for all data up to just before the IMAGE_INTEGRITY_CODE sub-tag. |
| image_validate
enum ZclStatusCodeT (*image_validate)(struct ZbZclClusterT *cluster, struct ZbZclOtaHeader *header, void *arg)
If not NULL, this is called to validate the image, such as the hash. If NULL, and the image is verified using a Security Certificate, the application must provide a valid ca_pub_key_array parameter in ZbZclOtaClientConfig at initialization. Return code is ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error (e.g. ZCL_STATUS_FAILURE). Callback Function Parameters: header A pointer to the OTA header from the start of the transferred, see Table 11-2 OTA Header Fields in the OTA specification. Return Code:
The the image has passed validation and the upgrade is ready to proceed.
Validation of the image has failed
This image has passed validation, but this device requires more images which are yet to be received before performing an upgrade. The application will need to use one of the CheckForUpdate API calls to locate then transfer the remaining images. When all images have been successfully transferred and validated a SUCCESS status should should be returned instead.
The client is aborting the upgrade. These status codes are used to notify the OTA server of the completion of the transfer via the UpgradeEnd message. |
| upgrade_end
enum ZclStatusCodeT (*upgrade_end)(struct ZbZclClusterT *cluster, struct ZbZclOtaHeader *header, uint32_t current_time, uint32_t upgrade_time, void *arg)
Callback to handle an Upgrade End Response command, which specifies the time to perform the reboot and start using the updated firmware. If using the default callback handler defined by ZbZclOtaClientGetDefaultCallbacks, the 'reboot' callback will be called when the transfer has completed succesfully and it’s time for the upgrade to take place. If the application has selected the "Out-of-band" Activation Policy, then it’s best for the application to define its own 'upgrade_end' callback to decide when to perform the upgrade. The callback should update the ZCL_OTA_ATTR_IMAGE_UPGRADE_STATUS attribute accordingly. Writing ZCL_OTA_STATUS_NORMAL to the ZCL_OTA_ATTR_IMAGE_UPGRADE_STATUS attribute will reset the cluster back to defaults. If the callback returns ZCL_STATUS_SUCCESS, the cluster data is not reset, since the OTA upgrade may be waiting to finish through an external event or timeout. Return code is ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error (e.g. ZCL_STATUS_FAILURE). If the callback returns an error, the cluster is reset back to defaults. Callback Function Parameters:
| reboot
void (*reboot)(struct ZbZclClusterT *cluster, void *arg)
If using the default 'upgrade_end' handler, then a callback must be provided by the application. This is called by the 'upgrade_end' handler if the OTA download was successful, to indicate it is now time to reboot the system. |
| abort_download
enum ZclStatusCodeT (*abort_download)(struct ZbZclClusterT *cluster, enum ZbZclOtaCommandId commandId, void *arg)
Callback to inform application of a problem with the download. It gives the application the option to perform network diagnostics or repairs (e.g. NWK Route Discovery) before attempting to restart the OTA transfer where it left off. The application can also tell the OTA Client to abort this transfer by returning ZCL_STATUS_SUCCESS. This callback cannot be set to NULL. The commandId is the OTA command responsible for aborting the transmission (e.g. ZCL_OTA_COMMAND_IMAGE_BLOCK_RESPONSE). If the application returns ZCL_STATUS_SUCCESS, the OTA transfer will be aborted and cluster reset to defaults, ready for a new transfer. If the application returns an error (i.e. ZCL_STATUS_FAILURE), the OTA transfer will be paused rather than aborted, and can be resumed by the application calling ZbZclOtaClientImageTransferResume. Callback Function Parameters:
The associated command responsible for this callback. E.g. Image Block Request (0x04) if there was a problem sending the command to retrieve more data, or Image Block Response (0x05) if the block response contained the ABORT status code. Return Code:
The OTA transfer will be aborted and cluster reset to defaults, ready for a new transfer.
The OTA transfer will be paused rather than aborted, and can be resumed by the application calling ZbZclOtaClientImageTransferResume. The application may use this opportunity to perform a Route Discovery of the OTA Server or try to poll the OTA Server until it comes back online and communication is able to resume. Refer to the Resume a Partial Download section for more information. |
OTA Upgrade Client Configuration structure
Parameters
| uint16_t profile_id | Profile ID |
| uint8_t endpoint | Endpoint on which the cluster is created on |
| enum ZbZclOtaActivationPolicy
activation_policy |
Activation Policy |
| enum ZbZclOtaTimeoutPolicy
timeout_policy |
Timeout Policy - Value written to ZCL_OTA_ATTR_UPGRADE_TIMEOUT_POLICY |
| uint32_t image_block_delay | Image block delay - milliseconds |
| struct ZbZclOtaHeader current_image | OTA Upgrade Header Fields structure. This is used to configure the client’s attributes that describe the firmware image currently running on the device. |
| uint16_t hardware_version | Revision (0x00NN). Included in the Query Next Image command. |
| const uint8_t *ca_pub_key_array | CA Public Key array |
| unsigned int ca_pub_key_len | CA Public Key array length |
callbacks |
Client callback functions |
Upgrade End Response command structure
Parameters
| uint32_t current_time | Current time |
| uint32_t upgrade_time | Upgrade time |
ZbZclOtaHeader
Parameters
| uint32_t file_identifier | OTA Upgrade file identifier |
| uint16_t header_version | OTA Header version |
| uint16_t header_length | OTA Header length |
| uint16_t header_field_control | OTA Header Field control |
| uint16_t manufacturer_code | Manufacturer code |
| uint16_t image_type | Image type |
| uint32_t file_version | File version |
| uint16_t stack_version | Zigbee Stack version |
| uint8_t header_string | OTA Header string |
| uint32_t total_image_size | Total Image size (including header) |
| uint8_t sec_credential_version | Security credential version (Optional) |
| uint64_t file_destination | Upgrade file destination (Optional) |
| uint16_t min_hardware_version | Minimum hardware version (Optional) |
| uint16_t max_hardware_version | Maximum hardware version (Optional) |
ZbZclOtaImageData
OTA Upgrade Image Data structure
Parameters
| uint32_t file_offset | File Offset |
| uint8_t data_size | Data Size |
| uint8_t data | Data |
Parameters
ZbZclOtaImageWaitForData
Image Block Response Command Payload with WAIT_FOR_DATA status structure
Parameters
| uint32_t request_time | Request time |
| uint16_t minimum_block_period | MinimumBlock Period |
Parameters
| uint16_t minimum_block_period | Minimum block period |
| uint32_t upgrade_end_current_time | Upgrade End Current Time |
| uint32_t upgrade_end_upgrade_time | Upgrade End Upgrade Time |
| ZbZclOtaServerImageEvalT image_eval | Callback to determine if a suitable image exists |
| ZbZclOtaServerImageReadT image_read | Callback read image data from the server |
| ZbZclOtaServerUpgradeEndReqT
image_upgrade_end_req |
Callback to handle client Upgrade End request |
| void *arg | Pointer to application data that will later be provided back to the callback function when invoked |
6.2.23. Poll Control
#include "zcl/general/zcl.poll.control.h"
Description
ZCL 8 section 3.16
A Sleepy End Device (SED) may instantiate the Poll Control server to allow external devices to control its polling behaviour, including a short interval of rapid polling in order to communicate with the SED in a timely fashion. SEDs are usually in their sleep state where they are not able to receive packets, and devices may not know when those SEDs are awake and polling for data. The Poll Control cluster is used to solve this dilemma.
Devices with Poll Control clients can use Finding & Binding to create the bindings necessary to communicate with the Poll Control servers. The Poll Control server will perform periodic check-ins with any bound Poll Control clients, where the check-in response may ask the SED to start fast polling to allow the server device to exchange messages with it.
Functions
zcl_poll_client_alloc
struct ZbZclClusterT * zcl_poll_client_alloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclPollControlClientCallbackT *callbacks, void *arg);
Create a new instance of the Poll Control Client cluster
Parameters
| zb | Zigbee stack instance |
| arg | Pointer to application data that will included in the callback when invoked. |
Return
zcl_poll_client_set_checkin_rsp
enum ZclStatusCodeT zcl_poll_client_set_checkin_rsp(struct ZbZclClusterT *cluster, struct ZbZclPollControlClientCheckinInfo *info);
Set Check-in Response configuration
Parameters
| info | Check-in configuration info |
Return
zcl_poll_client_set_long_intvl_req
enum ZclStatusCodeT zcl_poll_client_set_long_intvl_req(struct ZbZclClusterT *cluster, struct ZbZclPollControlClientSetLongReq *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Long Interval command
Parameters
| req | Set Long Interval command request structure |
| callback | Callback function that will be invoked when the response is received. |
Return
zcl_poll_client_set_short_intvl_req
enum ZclStatusCodeT zcl_poll_client_set_short_intvl_req(struct ZbZclClusterT *cluster, struct ZbZclPollControlClientSetShortReq *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Short Interval command
Parameters
| req | Set Short Interval command request structure |
Return
zcl_poll_client_stop_fastpoll_req
enum ZclStatusCodeT zcl_poll_client_stop_fastpoll_req(struct ZbZclClusterT *cluster, struct ZbZclPollControlClientStopReq *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Fast Poll Stop command
Parameters
| req | Fast Poll Stop command request structure |
Return
zcl_poll_server_alloc
struct ZbZclClusterT * zcl_poll_server_alloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclPollControlServerCallbackT *callbacks, void *arg);
Create a new instance of the Poll Control Server cluster
Parameters
Return
zcl_poll_server_send_checkin
enum ZclStatusCodeT zcl_poll_server_send_checkin(struct ZbZclClusterT *cluster);
Send a Check-in command to any bound Clients.
Parameters
Return
Enumerations
ZbZclPollControlSvrAttrT
Poll Control Server Attribute IDs
| ZCL_POLL_CHECK_IN_INTERVAL | Check-inInterval. Range is (0, 0x6E0000), where 0 means disabled. 0x6E0000 = 7208960 qs = ~500 hours. Other than 0, the Min value is also governed by ZCL_POLL_CHECK_IN_INTERVAL_MIN. |
| ZCL_POLL_LONG_POLL_INTERVAL | LongPollInterval. Range is (0x04, 0x6E0000) = (1 sec, ~500 hours). Min value is also governed by the value of ZCL_POLL_LONG_POLL_INTERVAL_MIN. |
| ZCL_POLL_SHORT_POLL_INTERVAL | ShortPollInterval. Range is (1, 4) = (250 ms, 1 sec) |
| ZCL_POLL_FAST_POLL_TIMEOUT | FastPollTimeout. Range is (0x0001, 0xffff) = (250 ms, 4.55 hours). Max value is also governed by the value of ZCL_POLL_FAST_POLL_TIMEOUT_MAX. |
| ZCL_POLL_CHECK_IN_INTERVAL_MIN | Check-inIntervalMin (Optional). Range is (0, 0x6E0000) |
| ZCL_POLL_LONG_POLL_INTERVAL_MIN | LongPollIntervalMin (Optional). Range is (0x4, 0x6E0000) |
| ZCL_POLL_FAST_POLL_TIMEOUT_MAX | FastPollTimeoutMax (Optional). Range is (0x2, 0xffff) |
| ZCL_POLL_LONG_POLL_FROM_CLUSTER | If True, the Poll Server cluster will perform the NLME- SYNC.request (polling) at the interval given by the 'LongPollInterval' (ZCL_POLL_LONG_POLL_INTERVAL). If False, the Poll Server will only expose the 'LongPollInterval' via the attribute to devices that want to read it, but the application will be responsible for any long polling it wants to do. Default is False (disabled), meaning the cluster will not perform an NLME- SYNC.request at the long poll intervals. |
| ZCL_POLL_CHECK_IN_RSP_WAIT_AFTER | If True, then wait for the full check-in response timeout before stopping fast-polling for responses. If False, then as soon as the number of received check-in responses matches the number of bound clients, then stop fast-polling immediately. Note that this is an Exegin custom attribute and not exposed to the network. |
Structures
Poll Control Client callbacks configuration
Parameters
| checkin_rsp_callback
enum ZclStatusCodeT (*checkin_rsp_callback)(struct ZbZclClusterT *clusterPtr, struct zcl_poll_checkin_rsp_t *rsp_info, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Check-in Response command |
Check-in Info structure
Parameters
| bool start_fast_poll | Start Fast Poll |
| uint16_t fast_poll_timeout | Fast Poll Timeout |
| bool auto_refresh | If true, check-in response is automatically refreshed for the next check-in request. If false, this is a one-time event. |
Set Long Poll Interval command structure
Parameters
| uint32_t interval | NewLongPollInterval |
Set Short Poll Interval command structure
Parameters
| uint16_t interval | New Short Poll Interval |
Fast Poll Stop command structure
Parameters
Poll Control Server callbacks configuration
Parameters
| checkin_rsp
bool (*checkin_rsp)(struct ZbZclClusterT *clusterPtr, struct zcl_poll_checkin_rsp_t *rsp_info, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Check-in Response command. If the callback returns true, then the Check-in Response is allowed to start fast polling. The ZCL8 Spec makes it optional whether these commands allow the device to start fast polling, even if "Start Fast Polling" payload parameter is set to true. If the callback return false, then this command shall not have an effect on fast polling. |
Check-in Response command structure
Parameters
| enum ZclStatusCodeT status | Status |
| bool start_fast_poll | Start Fast Polling |
6.2.24. Power Configuration
#include "zcl/general/zcl.power.config.h"
Functions
ZbZclPowerConfigClientAlloc
struct ZbZclClusterT * ZbZclPowerConfigClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Power Configuration Client cluster
Parameters
Return
ZbZclPowerConfigServerAlloc
struct ZbZclClusterT * ZbZclPowerConfigServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Power Configuration Server cluster
Parameters
| endpoint | Endpoint on which to create cluster |
Return
- Cluster pointer, or NULL if there is an error
Enumerations
ZbZclPowerConfigSvrAttrT
Power Configuration Server Attributes IDs
| ZCL_POWER_CONFIG_ATTR_MAINS_VOLTAGE | MainsVoltage (Optional) |
| ZCL_POWER_CONFIG_ATTR_MAINS_FREQ | MainsFrequency (Optional) |
| ZCL_POWER_CONFIG_ATTR_MAINS_ALARM_MASK | MainsAlarmMask (Optional) |
| ZCL_POWER_CONFIG_ATTR_MAINS_VOLT_MIN | MainsVoltageMinThreshold (Optional) |
| ZCL_POWER_CONFIG_ATTR_MAINS_VOLT_MAX | MainsVoltageMaxThreshold (Optional) |
| ZCL_POWER_CONFIG_ATTR_MAINS_VOLT_DWELL | MainsVoltageDwellTripPoint (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_VOLTAGE | BatteryVoltage (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_PCT | BatteryPercentageRemaining (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_MFR_NAME | BatteryManufacturer (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_SIZE | BatterySize (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_AHRRATING | BatteryAHrRating (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_QUANTITY | BatteryQuantity (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_RATED_VOLT | BatteryRatedVoltage (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_ALARM_MASK | BatteryAlarmMask (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_VOLT_MIN | BatteryVoltageMinThreshold (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_VTHRESHOLD1 | BatteryVoltageThreshold1 (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_VTHRESHOLD2 | BatteryVoltageThreshold2 (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_VTHRESHOLD3 | BatteryVoltageThreshold3 (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_PCT_MIN | BatteryPercentageMinThreshold (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_PTHRESHOLD1 | BatteryPercentageThreshold1 (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_PTHRESHOLD2 | BatteryPercentageThreshold2 (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_PTHRESHOLD3 | BatteryPercentageThreshold3 (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY_ALARM_STATE | BatteryAlarmState (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_VOLTAGE | BatteryVoltage - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_PCT | BatteryPercentageRemaining - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_MFR_NAME | BatteryManufacturer - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_SIZE | BatterySize - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_AHRRATING | BatteryAHrRating - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_QUANTITY | BatteryQuantity - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_RATED_VOLT | BatteryRatedVoltage - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_ALARM_MASK | BatteryAlarmMask - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_VOLT_MIN | BatteryVoltageMinThreshold - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_VTHRESHOLD1 | BatteryVoltageThreshold1 - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_VTHRESHOLD2 | BatteryVoltageThreshold2 - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_VTHRESHOLD3 | BatteryVoltageThreshold3 - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_PCT_MIN | BatteryPercentageMinThreshold - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_PTHRESHOLD1 | BatteryPercentageThreshold1 - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_PTHRESHOLD2 | BatteryPercentageThreshold2 - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_PTHRESHOLD3 | BatteryPercentageThreshold3 - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY2_ALARM_STATE | BatteryAlarmState - Second battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_VOLTAGE | BatteryVoltage - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_PCT | BatteryPercentageRemaining - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_MFR_NAME | BatteryManufacturer - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_SIZE | BatterySize - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_AHRRATING | BatteryAHrRating - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_QUANTITY | BatteryQuantity - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_RATED_VOLT | BatteryRatedVoltage - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_ALARM_MASK | BatteryAlarmMask - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_VOLT_MIN | BatteryVoltageMinThreshold - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_VTHRESHOLD1 | BatteryVoltageThreshold1 - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_VTHRESHOLD2 | BatteryVoltageThreshold2 - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_VTHRESHOLD3 | BatteryVoltageThreshold3 - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_PCT_MIN | BatteryPercentageMinThreshold - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_PTHRESHOLD1 | BatteryPercentageThreshold1 - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_PTHRESHOLD2 | BatteryPercentageThreshold2 - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_PTHRESHOLD3 | BatteryPercentageThreshold3 - Third Battery (Optional) |
| ZCL_POWER_CONFIG_ATTR_BATTERY3_ALARM_STATE | BatteryAlarmState - Third Battery (Optional) |
6.2.25. Power Profile
#include "zcl/general/zcl.power.profile.h"
Functions
ZbZclPowerProfClientAlloc
struct ZbZclClusterT * ZbZclPowerProfClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclPowerProfClientCallbacks *callbacks, void *arg);
Create a new instance of the Power Profile Client cluster
Parameters
Return
ZbZclPowerProfClientPhasesNotify
enum ZclStatusCodeT ZbZclPowerProfClientPhasesNotify(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfCliPhasesNotify *notify, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Energy Phases Schedule Notification command
Parameters
| cluster | Cluster instance from which to send this command |
| dst | Destination address for request |
| notify | Energy Phases Schedule Notification command structure |
Return
ZbZclPowerProfClientPhasesResponse
enum ZclStatusCodeT ZbZclPowerProfClientPhasesResponse(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPowerProfCliPhasesNotify *notify, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a EnergyPhasesScheduleResponse command
Parameters
| dst | Destination address for response, including sequence number and tx options |
| rsp | EnergyPhasesScheduleResponse command response structure |
Return
ZbZclPowerProfClientPhasesSchedStateReq
enum ZclStatusCodeT ZbZclPowerProfClientPhasesSchedStateReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfCliProfileReq *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a EnergyPhasesScheduleStateRequest command
Parameters
| req | EnergyPhasesScheduleStateRequest command request structure |
Return
ZbZclPowerProfClientPriceExtRsp
enum ZclStatusCodeT ZbZclPowerProfClientPriceExtRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPowerProfCliPriceRsp *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a GetPowerProfilePriceExtendedResponse command
Parameters
| rsp | GetPowerProfilePriceExtendedResponse command response structure |
Return
ZbZclPowerProfClientPriceRsp
enum ZclStatusCodeT ZbZclPowerProfClientPriceRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPowerProfCliPriceRsp *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a GetPowerProfilePriceResponse command
Parameters
| rsp | GetPowerProfilePriceResponse command response structure |
Return
ZbZclPowerProfClientProfileReq
enum ZclStatusCodeT ZbZclPowerProfClientProfileReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfCliProfileReq *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a PowerProfileRequest command
Parameters
| req | PowerProfileRequest command request structure |
Return
ZbZclPowerProfClientSchedConsReq
enum ZclStatusCodeT ZbZclPowerProfClientSchedConsReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfCliProfileReq *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a PowerProfileScheduleConstraintsRequest command
Parameters
| req | PowerProfileScheduleConstraintsRequest command request structure |
Return
ZbZclPowerProfClientSchedPriceRsp
enum ZclStatusCodeT ZbZclPowerProfClientSchedPriceRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPowerProfCliSchedPriceRsp *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a GetOverallSchedulePriceResponse command
Parameters
| rsp | GetOverallSchedulePriceResponse command response structure |
Return
ZbZclPowerProfClientStateReq
enum ZclStatusCodeT ZbZclPowerProfClientStateReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a PowerProfileStateRequest command
Parameters
Return
ZbZclPowerProfServerAlloc
struct ZbZclClusterT * ZbZclPowerProfServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclPowerProfServerCallbacks *callbacks, void *arg);
Create a new instance of the Power Profile Server cluster
Parameters
Return
ZbZclPowerProfServerConstraintsNotify
enum ZclStatusCodeT ZbZclPowerProfServerConstraintsNotify(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfSvrConstraintsNotify *notify, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a PowerProfileScheduleConstraintsNotification Command
Parameters
| notify | PowerProfileScheduleConstraintsNotification command structure |
Return
ZbZclPowerProfServerConstraintsRsp
enum ZclStatusCodeT ZbZclPowerProfServerConstraintsRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPowerProfSvrConstraintsNotify *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a PowerProfileScheduleConstraintsResponse command
Parameters
| rsp | PowerProfileScheduleConstraintsResponse command response structure |
Return
ZbZclPowerProfServerGetPriceReq
enum ZclStatusCodeT ZbZclPowerProfServerGetPriceReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfCliProfileReq *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a GetPowerProfilePrice command
Parameters
| req | GetPowerProfilePrice command request structure |
Return
ZbZclPowerProfServerGetPriceReqExtReq
enum ZclStatusCodeT ZbZclPowerProfServerGetPriceReqExtReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfSvrGetPriceExtReq *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a GetPowerProfilePriceExtended command
Parameters
| req | GetPowerProfilePriceExtended command request structure |
Return
ZbZclPowerProfServerGetSchedPriceReq
enum ZclStatusCodeT ZbZclPowerProfServerGetSchedPriceReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a GetOverallSchedulePrice command
Parameters
| req | GetOverallSchedulePrice command request structure |
Return
ZbZclPowerProfServerPhasesNotify
enum ZclStatusCodeT ZbZclPowerProfServerPhasesNotify(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfSvrPhasesRsp *notify, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a EnergyPhasesScheduleStateNotification Command
Parameters
| notify | EnergyPhasesScheduleStateNotification command structure |
Return
ZbZclPowerProfServerPhasesReq
enum ZclStatusCodeT ZbZclPowerProfServerPhasesReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfCliProfileReq *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a EnergyPhasesScheduleRequest command
Parameters
| req | EnergyPhasesScheduleRequest command request structure |
Return
ZbZclPowerProfServerPhasesRsp
enum ZclStatusCodeT ZbZclPowerProfServerPhasesRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPowerProfSvrPhasesRsp *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a EnergyPhasesScheduleStateResponse command
Parameters
| rsp | EnergyPhasesScheduleStateResponse command response structure |
Return
ZbZclPowerProfServerProfileNotify
enum ZclStatusCodeT ZbZclPowerProfServerProfileNotify(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfSvrProfileRsp *notify, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a PowerProfileNotification Command. It is sent as a ZCL request with a unique sequence number, and can receive a Default Response if applicable
Parameters
| notify | PowerProfileNotification command structure |
Return
ZbZclPowerProfServerProfileRsp
enum ZclStatusCodeT ZbZclPowerProfServerProfileRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPowerProfSvrProfileRsp *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a PowerProfileResponse command
Parameters
| rsp | PowerProfileResponse command response structure |
Return
ZbZclPowerProfServerStateNotify
enum ZclStatusCodeT ZbZclPowerProfServerStateNotify(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPowerProfSvrStateRsp *notify, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a PowerProfileStateNotification Command
Parameters
| notify | PowerProfileStateNotification command structure |
Return
ZbZclPowerProfServerStateRsp
enum ZclStatusCodeT ZbZclPowerProfServerStateRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPowerProfSvrStateRsp *rsp, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a PowerProfileStateResponse command
Parameters
| rsp | PowerProfileStateResponse command response structure |
Return
Enumerations
ZbZclPowerProfileSvrAttrT
Power Profile Server Attribute IDs
| ZCL_POWER_PROF_SVR_ATTR_TOTAL_PROFILENUM | TotalProfileNum |
| ZCL_POWER_PROF_SVR_ATTR_MULTIPLE_SCHED | MultipleScheduling |
| ZCL_POWER_PROF_SVR_ATTR_ENERGY_FORMAT | EnergyFormatting |
| ZCL_POWER_PROF_SVR_ATTR_ENERGY_REMOTE | EnergyRemote |
| ZCL_POWER_PROF_SVR_ATTR_SCHEDULE_MODE | ScheduleMode |
Structures
Parameters
| uint8_t profile_id | Power ProfileID |
| uint8_t num_phases | Num of Scheduled Phases |
| struct ZbZclPowerProfSchedPhase
sched_list |
Schedule List |
GetPowerProfilePriceResponse command structure
Parameters
| uint8_t profile_id | Power Profile ID |
| uint16_t currency | Currency |
| uint32_t price | Price |
| uint8_t trailing_digit | Price Trailing Digit |
PowerProfileRequest command structure
Parameters
| uint8_t profile_id | PowerProfileID |
GetOverallSchedulePriceResponse command structure
Parameters
Power Profile Client callbacks configuration
Parameters
| profile_notify
(callback function pointer) |
enum ZclStatusCodeT (*profile_notify)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfSvrProfileRsp *notify, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of PowerProfileNotification command |
| get_price
enum ZclStatusCodeT (*get_price)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfCliProfileReq *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of GetPowerProfilePrice command |
| state_notify
enum ZclStatusCodeT (*state_notify)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfSvrStateRsp *notify, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of PowerProfileStateNotification command |
| get_sched_price
enum ZclStatusCodeT (*get_sched_price)(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of GetOverallSchedulePrice command |
| phases_req
enum ZclStatusCodeT (*phases_req)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfCliProfileReq *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of EnergyPhasesScheduleRequest command |
| phases_notify
enum ZclStatusCodeT (*phases_notify)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfSvrPhasesRsp *notify, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of EnergyPhasesScheduleStateNotification command |
| constraints_notify
enum ZclStatusCodeT (*constraints_notify)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfSvrConstraintsNotify *notify, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of PowerProfileScheduleConstraintsNotification command |
| get_price_ext
enum ZclStatusCodeT (*get_price_ext)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfSvrGetPriceExtReq *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of GetPowerProfilePriceExtended command |
ZbZclPowerProfPhase
Phase structure
Parameters
| uint8_t energy_phase_id | Energy PhaseID |
| uint8_t macro_phase_id | Macro PhaseID |
| uint16_t expect_duration | ExpectedDuration |
| uint16_t peak_power | Peak Power |
| uint16_t energy | Energy |
| uint16_t max_activation_delay | MaxActivationDelay |
Schedule Phase structure
Parameters
| uint16_t sched_time | Scheduled Time |
Power Profile Server callbacks configuration
Parameters
| profile_req
enum ZclStatusCodeT (*profile_req)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfCliProfileReq *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of PowerProfileRequest command |
| state_req
enum ZclStatusCodeT (*state_req)(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of PowerProfileStateRequest command |
| phases_notify
enum ZclStatusCodeT (*phases_notify)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfCliPhasesNotify *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of Energy Phases Schedule Notification command |
| sched_contraints_req
enum ZclStatusCodeT (*sched_contraints_req)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfCliProfileReq *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of PowerProfileScheduleConstraintsRequest command |
| phases_sched_state_req
enum ZclStatusCodeT (*phases_sched_state_req)(struct ZbZclClusterT *cluster, struct ZbZclPowerProfCliProfileReq *req, struct ZbZclAddrInfoT *srcInfo, void *arg)
Callback to application, invoked on receipt of EnergyPhasesScheduleStateRequest command |
Parameters
| uint16_t start_after | Start After |
| uint16_t stop_before | Stop Before |
GetPowerProfilePriceExtended command structure
Parameters
| uint8_t options | Options - e.g. ZCL_PWR_PROF_PRICE_EXT_OPT_START_TIME_PRESENT |
| uint16_t start_time | PowerProfileStartTime - optional (ZCL_PWR_PROF_PRICE_EXT_OPT_START_TIME_PRESENT) |
Energy Phases Schedule Notification and EnergyPhasesScheduleResponse command structure
Parameters
| uint8_t num_sched_energy_phases | Num of Scheduled Phases |
PowerProfileNotification and PowerProfileResponse command structure
Parameters
| uint8_t total_profile_num | Total Profile Num |
| uint8_t num_transferred_phases | Num of Transferred Phases |
| struct ZbZclPowerProfPhase phase_list | Phase List |
PowerProfileStateResponse command structure
Parameters
| uint8_t profile_count | Power Profile Count |
| struct ZbZclPowerProfileRecord record_list | Record List |
Record structure
Parameters
| uint8_t energy_phase_id | Energy Phase ID |
| uint8_t remote_control | PowerProfileRemoteControl |
| enum ZbZclPowerProfState state | PowerProfile State |
6.2.26. Pressure Measurement
#include "zcl/general/zcl.press.meas.h"
Functions
ZbZclPressMeasClientAlloc
struct ZbZclClusterT * ZbZclPressMeasClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Pressure Measurement Client cluster
Parameters
Return
ZbZclPressMeasServerAlloc
struct ZbZclClusterT * ZbZclPressMeasServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, int16_t min, int16_t max);
Create a new instance of the Pressure Measurement Server cluster
Parameters
| min | Default minimum measured value written to ZCL_PRESS_MEAS_ATTR_MIN_MEAS_VAL attribute during allocation |
| max | Default maximum measured value written to ZCL_PRESS_MEAS_ATTR_MAX_MEAS_VAL attribute during allocation |
Return
Enumerations
ZbZclPressMeasSvrAttrT
Pressure Measurement Attribute IDs
| ZCL_PRESS_MEAS_ATTR_MEAS_VAL | MeasuredValue |
| ZCL_PRESS_MEAS_ATTR_MIN_MEAS_VAL | MinMeasuredValue |
| ZCL_PRESS_MEAS_ATTR_MAX_MEAS_VAL | MaxMeasuredValue |
| ZCL_PRESS_MEAS_ATTR_TOLERANCE | Tolerance (Optional) |
| ZCL_PRESS_MEAS_ATTR_SCALED_VAL | ScaledValue (Optional) |
| ZCL_PRESS_MEAS_ATTR_MIN_SCALED_VAL | MinScaledValue (Optional) |
| ZCL_PRESS_MEAS_ATTR_MAX_SCALED_VAL | MaxScaledValue (Optional) |
| ZCL_PRESS_MEAS_ATTR_SCALED_TOL | ScaledTolerance (Optional) |
| ZCL_PRESS_MEAS_ATTR_SCALE | Scale (Optional) |
6.2.27. Pump Configuration and Control
#include "zcl/general/zcl.pump.h"
Functions
ZbZclPumpClientAlloc
struct ZbZclClusterT * ZbZclPumpClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Instantiate a new instance of the Pump Configuration and Control client cluster
Parameters
Return
ZbZclPumpServerAlloc
struct ZbZclClusterT * ZbZclPumpServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Instantiate a new instance of the Pump Configuration and Control server cluster
Parameters
Return
Enumerations
ZbZclPumpServerAttrT
Pump Configuration and Control Attribute Ids
| ZCL_PUMP_SVR_ATTR_MAX_PRESSURE | MaxPressure |
| ZCL_PUMP_SVR_ATTR_MAX_SPEED | MaxSpeed |
| ZCL_PUMP_SVR_ATTR_MAX_FLOW | MaxFlow |
| ZCL_PUMP_SVR_ATTR_MIN_CONST_PRESSURE | MinConstPressure |
| ZCL_PUMP_SVR_ATTR_MAX_CONST_PRESSURE | MaxConstPressure |
| ZCL_PUMP_SVR_ATTR_MIN_COMP_PRESSURE | MinCompPressure |
| ZCL_PUMP_SVR_ATTR_MAX_COMP_PRESSURE | MaxCompPressure |
| ZCL_PUMP_SVR_ATTR_MIN_CONST_SPEED | MinConstSpeed |
| ZCL_PUMP_SVR_ATTR_MAX_CONST_SPEED | MaxConstSpeed |
| ZCL_PUMP_SVR_ATTR_MIN_CONST_FLOW | MinConstFlow |
| ZCL_PUMP_SVR_ATTR_MAX_CONST_FLOW | MaxConstFlow |
| ZCL_PUMP_SVR_ATTR_MIN_CONST_TEMP | MinConstTemp |
| ZCL_PUMP_SVR_ATTR_MAX_CONST_TEMP | MaxConstTemp |
| ZCL_PUMP_SVR_ATTR_PUMP_STATUS | PumpStatus |
| ZCL_PUMP_SVR_ATTR_EFF_OP_MODE | EffectiveOperationMode |
| ZCL_PUMP_SVR_ATTR_EFF_CTRL_MODE | EffectiveControlMode |
| ZCL_PUMP_SVR_ATTR_CAPACITY | Capacity |
| ZCL_PUMP_SVR_ATTR_SPEED | Speed |
| ZCL_PUMP_SVR_ATTR_RUNNING_HOURS | LifetimeRunningHours |
| ZCL_PUMP_SVR_ATTR_POWER | Power |
| ZCL_PUMP_SVR_ATTR_ENERGY_CONSUMED | LifetimeEnergyConsumed |
| ZCL_PUMP_SVR_ATTR_OP_MODE | OperationMode |
| ZCL_PUMP_SVR_ATTR_CTRL_MODE | ControlMode |
| ZCL_PUMP_SVR_ATTR_ALARM_MASK | AlarmMask |
6.2.28. RSSI Location
#include "zcl/general/zcl.rssi.loc.h"
Functions
ZbZclRssiLocClientAlloc
struct ZbZclClusterT * ZbZclRssiLocClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct zcl_rssi_loc_client_callbacks_t *callbacks, void *arg);
Create a new instance of the RSSI Location Client cluster
Parameters
| callbacks | Structure containing any callback function pointers for this cluster |
Return
ZbZclRssiLocClientAnchorNodeAnnc
enum ZclStatusCodeT ZbZclRssiLocClientAnchorNodeAnnc(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct rssi_loc_anchor_node_annc *anchor_node_annc, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Anchor Node Announce command
Parameters
| anchor_node_annc | Anchor Node Announce command structure |
Return
ZbZclRssiLocClientGetDevConfig
enum ZclStatusCodeT ZbZclRssiLocClientGetDevConfig(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct rssi_loc_get_dev_config *get_dev_config, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Device Configuration command
Parameters
| get_dev_config | Get Device Configuration command structure |
Return
ZbZclRssiLocClientGetLocData
enum ZclStatusCodeT ZbZclRssiLocClientGetLocData(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct rssi_loc_get_loc_data *get_loc_data, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Location Data command
Parameters
| get_loc_data | Get Location Data command structure |
Return
ZbZclRssiLocClientSendPings
enum ZclStatusCodeT ZbZclRssiLocClientSendPings(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct rssi_loc_send_pings *send_pings, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Send Pings command
Parameters
| send_pings | Send Pings command structure |
Return
ZbZclRssiLocClientSendRssiRsp
enum ZclStatusCodeT ZbZclRssiLocClientSendRssiRsp(struct ZbZclClusterT *clusterPtr, struct ZbZclAddrInfoT *dst_info, struct rssi_loc_rssi_rsp *rsp);
Send a RSSI Response command
Parameters
| clusterPtr | Cluster instance from which to send this command |
| dst_info | Destination address for request |
| rsp | Rssi Response structure |
Return
ZbZclRssiLocClientSetAbsLocation
enum ZclStatusCodeT ZbZclRssiLocClientSetAbsLocation(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct rssi_loc_set_abs_loc *set_abs_loc, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Absolute Location command
Parameters
| set_abs_loc | Set Absolute Location command structure |
Return
ZbZclRssiLocClientSetDevConfig
enum ZclStatusCodeT ZbZclRssiLocClientSetDevConfig(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct rssi_loc_set_dev_config *set_dev_config, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Device Configuration command
Parameters
| set_dev_config | Set Device Config command structure |
Return
ZbZclRssiLocServerAlloc
struct ZbZclClusterT * ZbZclRssiLocServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct zcl_rssi_loc_server_callbacks_t *callbacks, void *arg);
Create a new instance of the RSSI Location Server cluster
Parameters
Return
ZbZclRssiLocServerCompDataNotif
enum ZclStatusCodeT ZbZclRssiLocServerCompDataNotif(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Compact Data Notification command
Parameters
Return
ZbZclRssiLocServerLocDataNotif
enum ZclStatusCodeT ZbZclRssiLocServerLocDataNotif(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Location Data Notification command
Parameters
Return
ZbZclRssiLocServerReportRssi
enum ZclStatusCodeT ZbZclRssiLocServerReportRssi(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct rssi_loc_report_rssi *report_rssi, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Report RSSI command
Parameters
| report_rssi | Report Rssi command structure |
Return
ZbZclRssiLocServerReqOwnLoc
enum ZclStatusCodeT ZbZclRssiLocServerReqOwnLoc(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct rssi_loc_req_own_loc *req_own_loc, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Request Own Location command
Parameters
| req_own_loc | Request Own Location command structure |
Return
ZbZclRssiLocServerRssiPing
enum ZclStatusCodeT ZbZclRssiLocServerRssiPing(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a RSSI Ping command
Parameters
Return
ZbZclRssiLocServerRssiReq
enum ZclStatusCodeT ZbZclRssiLocServerRssiReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a RSSI Request command
Parameters
Return
ZbZclRssiLocServerSendDevConfigRsp
enum ZclStatusCodeT ZbZclRssiLocServerSendDevConfigRsp(struct ZbZclClusterT *clusterPtr, struct ZbZclAddrInfoT *dst_info, struct rssi_loc_dev_config_rsp *rsp);
Send a Device Configuration Response command
Parameters
| rsp | Send Device Configuration response structure |
Return
ZbZclRssiLocServerSendLocDataRsp
enum ZclStatusCodeT ZbZclRssiLocServerSendLocDataRsp(struct ZbZclClusterT *clusterPtr, struct ZbZclAddrInfoT *dst_info, struct rssi_loc_loc_data_rsp *rsp);
Send a Location Data Response command
Parameters
| rsp | Send Location Data response structure |
Return
Enumerations
ZbZclRssiLocSvrAttrT
Rssi Location Attribute IDs
| ZCL_RSSI_LOC_SVR_ATTR_LOCATION_TYPE | LocationType |
| ZCL_RSSI_LOC_SVR_ATTR_LOCATION_METHOD | LocationMethod |
| ZCL_RSSI_LOC_SVR_ATTR_LOCATION_AGE | LocationAge (Optional) |
| ZCL_RSSI_LOC_SVR_ATTR_QUALITY_MEAS | QualityMeasure (Optional) |
| ZCL_RSSI_LOC_SVR_ATTR_NUM_DEVICES | NumberOfDevices (Optional) |
| ZCL_RSSI_LOC_SVR_ATTR_COORD1 | Coordinate1 |
| ZCL_RSSI_LOC_SVR_ATTR_COORD2 | Coordinate2 |
| ZCL_RSSI_LOC_SVR_ATTR_COORD3 | Coordinate3 (Optional) |
| ZCL_RSSI_LOC_SVR_ATTR_POWER | Power |
| ZCL_RSSI_LOC_SVR_ATTR_PATH_LOSS_EXP | PathLossExponent |
| ZCL_RSSI_LOC_SVR_ATTR_REPORT_PERIOD | ReportingPeriod (Optional) |
| ZCL_RSSI_LOC_SVR_ATTR_CALC_PERIOD | CalculationPeriod (Optional) |
| ZCL_RSSI_LOC_SVR_ATTR_NUM_RSSI_MEAS | NumberRSSIMeasurements |
Structures
Parameters
| uint64_t addr | Anchor Node IEEE Address |
| int16_t x | X |
| int16_t y | Y |
| int16_t z | Z |
rssi_loc_comp_data_notif
Compact Data Notification command structure
Parameters
| uint8_t loc_type | Location Type |
| int16_t coord1 | Coordinate 1 |
| int16_t coord2 | Coordinate 2 |
| int16_t coord3 | Coordinate 3 |
| uint8_t quality_meas | Quality Measure |
| uint16_t loc_age | Location Age |
Parameters
| int16_t power | Power |
| uint16_t path_loss_exp | Path Loss Exponent |
| uint16_t calc_period | Calculation Period |
| uint8_t num_rssi_meas | Number RSSI Measurements |
| uint16_t report_period | Reporting Period |
Parameters
| uint64_t target_addr | Target Address |
Parameters
| uint8_t bitmap | Bitmap |
| uint8_t num_responses | Number Responses |
rssi_loc_loc_data_notif
Location Data Notification command structure
Parameters
| uint8_t loc_method | Location Method |
Parameters
rssi_loc_neighbour_info
Neighbour Info structure
Parameters
| uint64_t neighbour | Neighbour |
| int16_t x | X |
| int16_t y | Y |
| int16_t z | Z |
| int8_t rssi | RSSI |
| uint8_t num_rssi_meas | NumberRSSIMeasurements |
Parameters
| uint64_t measuring_dev | Measuring Device |
| uint8_t n_neighbours | N Neighbours |
| struct rssi_loc_neighbour_info neighbours_info | NeighboursInfo |
Parameters
| uint64_t addr | IEEE Address of the Blind Node |
rssi_loc_rssi_ping
Rssi Ping command structure
Parameters
rssi_loc_rssi_req
Rssi Request structure
Parameters
| uint8_t rssi | Rssi |
rssi_loc_rssi_rsp
Rssi response structure
Parameters
| uint64_t replying_dev | Replying Device |
| int16_t x | X |
| int16_t y | Y |
| int16_t z | Z |
rssi_loc_send_pings
Parameters
| uint16_t calc_period | CalculationPeriod |
Parameters
Set Device Configuration command structure
Parameters
| uint8_t num_rssi_meas | Number Rssi Measurements |
Rssi Location Client callbacks configuration
Parameters
| loc_data_notif
enum ZclStatusCodeT (*loc_data_notif)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_loc_data_notif *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Location Data Notification command |
| comp_data_notif
enum ZclStatusCodeT (*comp_data_notif)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_comp_data_notif *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Compact Data Notification command |
| rssi_ping
enum ZclStatusCodeT (*rssi_ping)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_rssi_ping *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of RSSI Ping command |
| rssi_req
enum ZclStatusCodeT (*rssi_req)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_rssi_req *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of RSSI request. |
| report_rssi
enum ZclStatusCodeT (*report_rssi)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_report_rssi *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Report Rssi command |
| req_own_loc
enum ZclStatusCodeT (*req_own_loc)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_req_own_loc *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Request Own Location command |
Rssi Location Server callbacks configuration
Parameters
| get_dev_config
enum ZclStatusCodeT (*get_dev_config)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_get_dev_config *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Get Device Configuration command |
| get_loc_data
enum ZclStatusCodeT (*get_loc_data)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_get_loc_data *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Get Location Data command |
| send_pings
enum ZclStatusCodeT (*send_pings)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_send_pings *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Send Pings command |
| anchor_node_annc
enum ZclStatusCodeT (*anchor_node_annc)(struct ZbZclClusterT *clusterPtr, struct rssi_loc_anchor_node_annc *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Anchor Node Announce command |
6.2.29. Scenes
#include "zcl/general/zcl.scenes.h"
Description
ZCL 8 section 3.7
A scene is a set of values for attributes from multiple clusters capable of being applied at the same time. The few clusters that support scenes are identified by a section with the title "Scene Table Extensions" in the ZCL 8 Specification (ZCL8) section for those cluster. There is only one scene table (list of attributes) for a cluster that supports scenes, and when a scene is invoked all scene table attributes are set to the values given in the scene table.
To use the scene table for a cluster, the cluster must reside on an endpoint which also hosts an instance of the Scenes cluster. There may be multiple scene table supporting clusters on a given endpoint. A scene is defined in the scenes cluster and contains scene tables for one or more clusters. Through the use of group addressing a scene may be applied to multiple endpoints on a node.
A scene may be created by the scene cluster using the Add Scene command, where the application manually defines the scene table for each cluster included in that scene. All attributes must have values in the scene table, but inclusion of individual clusters is optional. A scene may also be created using the Store Scene command where the current value of all the attributes in the cluster at the time the Store Scene command is issued are recorded in the scene table for later use.
The Scenes cluster Recall Scene command takes the scene table for each cluster in that scene and sets the values of every scene table attribute.
For example, a node could contain three endpoints:
- 0x01 with the OnOff and Window Covering clusters
- 0x02 with the OnOff and Door Lock clusters
- 0x03 with the OnOff and Level.
A scene is defined with a scene tables for the:
- OnOff cluster: OnOff = On
- Level cluster: CurrentLevel = 50%
- DoorLock cluster: LockState = Locked
Additionally:
- Endpoints 0x01 and 0x02 are in group 0x0001
- Endpoint 0x03 is not in group 0x0001
If the scenes cluster Recall Scenes command is issued with group address 0x0001 and the scene defined above, then on endpoint
0x01 and 0x02 the OnOff cluster OnOff attribute will be set on and the DoorLock on endpoint 0x02 will be locked.
The Window Covering cluster on endpoint 0x01 will not be affected because this scene does not include a scene table for this cluster and all of endpoint 0x03 will be unaffected because it is not in group 0x0001.
For more information about the Scenes cluster, see Section 3.7 in ZCL8.
Functions
ZbZclScenesClientAlloc
struct ZbZclClusterT * ZbZclScenesClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Scenes Client cluster
Parameters
Return
ZbZclScenesServerAlloc
struct ZbZclClusterT * ZbZclScenesServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, uint8_t maxScenes);
Create a new instance of the Scenes Server cluster
Parameters
| maxScenes | Maximum number of scenes supported by this cluster |
Return
zcl_scenes_client_add_req
enum ZclStatusCodeT zcl_scenes_client_add_req(struct ZbZclClusterT *cluster, struct zcl_scenes_add_request_t *add_req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send an Add Scene or Enhanced Add Scene command, depending on isEnhanced flag in Add Scene command structure
Parameters
| add_req | Add Scene command structure |
| callback | Callback function that will be called when the response for this request is received |
| arg | Pointer to application data provided in initiating API call |
Return
- ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error
zcl_scenes_client_add_rsp_parse
enum ZclStatusCodeT zcl_scenes_client_add_rsp_parse(struct zcl_scenes_add_response_t *add_rsp, struct ZbZclCommandRspT *zcl_rsp);
Parse an Add Scene Response command payload into a structure
Parameters
| add_rsp | Add Scene Response command structure |
| zcl_rsp | Cluster response structure |
Return
zcl_scenes_client_copy_req
enum ZclStatusCodeT zcl_scenes_client_copy_req(struct ZbZclClusterT *cluster, struct zcl_scenes_copy_request_t *copy_req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Copy Scene command
Parameters
| copy_req | Copy Scene command structure |
Return
zcl_scenes_client_copy_rsp_parse
enum ZclStatusCodeT zcl_scenes_client_copy_rsp_parse(struct zcl_scenes_copy_response_t *copy_rsp, struct ZbZclCommandRspT *zcl_rsp);
Parse a Copy Scene Response command payload into a structure
Parameters
| copy_rsp | Copy Scene response command structure |
Return
zcl_scenes_client_get_membership_req
enum ZclStatusCodeT zcl_scenes_client_get_membership_req(struct ZbZclClusterT *cluster, struct zcl_scenes_membership_request_t *get_req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Get Scene Membership command
Parameters
| get_req | Get Scene Membership command structure |
Return
zcl_scenes_client_get_membership_rsp_parse
enum ZclStatusCodeT zcl_scenes_client_get_membership_rsp_parse(struct zcl_scenes_membership_response_t *get_rsp, struct ZbZclCommandRspT *zcl_rsp);
Parse a Get Scene Membership Response command payload into a structure
Parameters
| get_rsp | Get Scene Membership Response command structure |
Return
zcl_scenes_client_recall_req
enum ZclStatusCodeT zcl_scenes_client_recall_req(struct ZbZclClusterT *cluster, struct zcl_scenes_recall_request_t *recall_req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Recall Scene command
Parameters
| recall_req | Recall Scene command structure |
Return
zcl_scenes_client_recall_rsp_parse
enum ZclStatusCodeT zcl_scenes_client_recall_rsp_parse(struct zcl_scenes_recall_response_t *recall_rsp, struct ZbZclCommandRspT *zcl_rsp);
Parse a Recall Scene Response command payload into a structure
Parameters
| recall_rsp | Recall Scene response command structure |
Return
zcl_scenes_client_remove_all_req
enum ZclStatusCodeT zcl_scenes_client_remove_all_req(struct ZbZclClusterT *cluster, struct zcl_scenes_remove_all_request_t *remove_req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Remove All Scenes command
Parameters
| remove_req | Remove All Scenes command structure |
Return
zcl_scenes_client_remove_all_rsp_parse
enum ZclStatusCodeT zcl_scenes_client_remove_all_rsp_parse(struct zcl_scenes_remove_all_response_t *remove_rsp, struct ZbZclCommandRspT *zcl_rsp);
Parse a Remove All Scenes Response command payload into a structure
Parameters
| remove_rsp | Remove All Scenes Response command structure |
Return
zcl_scenes_client_remove_req
enum ZclStatusCodeT zcl_scenes_client_remove_req(struct ZbZclClusterT *cluster, struct zcl_scenes_remove_request_t *remove_req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Remove Scene command
Parameters
| remove_req | Remove Scene command structure |
Return
zcl_scenes_client_remove_rsp_parse
enum ZclStatusCodeT zcl_scenes_client_remove_rsp_parse(struct zcl_scenes_remove_response_t *remove_rsp, struct ZbZclCommandRspT *zcl_rsp);
Parse a Remove Scene Response command payload into a structure
Parameters
| remove_rsp | Remove Scene Response command structure |
Return
zcl_scenes_client_store_req
enum ZclStatusCodeT zcl_scenes_client_store_req(struct ZbZclClusterT *cluster, struct zcl_scenes_store_request_t *store_req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Store Scene command
Parameters
| store_req | Store Scene command structure |
Return
zcl_scenes_client_store_rsp_parse
enum ZclStatusCodeT zcl_scenes_client_store_rsp_parse(struct zcl_scenes_store_response_t *store_rsp, struct ZbZclCommandRspT *zcl_rsp);
Parse a Store Scene Response command payload into a structure
Parameters
| store_rsp | Store Scene Response command structure |
Return
zcl_scenes_client_view_req
enum ZclStatusCodeT zcl_scenes_client_view_req(struct ZbZclClusterT *cluster, struct zcl_scenes_view_request_t *view_req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send an View Scene or Enhanced View Scene command, depending on isEnhanced flag in View Scene command structure
Parameters
| view_req | View Scene command structure |
Return
zcl_scenes_client_view_rsp_parse
enum ZclStatusCodeT zcl_scenes_client_view_rsp_parse(struct zcl_scenes_view_response_t *view_rsp, struct ZbZclCommandRspT *zcl_rsp);
Parse a View Scene Response command payload into a structure
Parameters
| view_rsp | View Scene Response command structure |
Return
Enumerations
ZbZclScenesAttrT
Scenes Attribute IDs
| ZCL_SCENES_ATTR_SCENE_COUNT | SceneCount |
| ZCL_SCENES_ATTR_CURRENT_SCENE | CurrentScene |
| ZCL_SCENES_ATTR_CURRENT_GROUP | CurrentGroup |
| ZCL_SCENES_ATTR_SCENE_VALID | SceneValid |
| ZCL_SCENES_ATTR_NAME_SUPPORT | NameSupport |
| ZCL_SCENES_ATTR_LAST_CONFIGURED_BY | LastConfiguredBy (Optional) |
Structures
Parameters
| bool isEnhanced | If true, send an Enhanced Add Scene request |
| struct ZbApsAddrT dst | Destination address for request |
| uint16_t groupId | Group ID |
| uint8_t sceneId | Scene ID |
| uint16_t transition | Transition time |
| const char *sceneName | Scene Name (string length must be <= ZCL_SCENES_NAME_MAX_LENGTH) |
| const char *extStrPtr | Extension field sets as an ASCII hex string in the format as sent in the command payload. As per the ZCL Spec, each set has the format: {clusterId, length, {extension field set}} E.g. For the OnOff cluster: "06000101" |
Parameters
| uint8_t status | Status |
Parameters
| bool allScenes | Copy All Scenes - sets bit within Mode parameter to enable Copy All Scenes |
| uint16_t groupFrom | Group identifier from |
| uint8_t sceneFrom | Scene identifier from - only used if allScenes is FALSE |
| uint16_t groupTo | Group identifier to |
| uint8_t sceneTo | Scene identifier to - only used if allScenes is FALSE |
Copy Scene Response command structure
Parameters
| uint8_t sceneFrom | Scene identifier from |
Parameters
Parameters
| uint8_t capacity | Capacity |
| uint8_t sceneCount | Scent count |
| uint8_t sceneList | Scene list |
Parameters
| uint16_t transition | Transition time - time in 1/10ths of second. ZCL_SCENES_RECALL_TRANSITION_INVALID (0xffff) means invalid, and won’t be included. (Optional) |
Recall Scene Response command structure
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
| bool isEnhanced | If true, send an Enhanced View Scene request |
Parameters
| char nameStr | Scene Name |
| uint8_t extNum | Number of Extension field sets |
| struct { uint16_t clusterId | Cluster ID |
| uint8_t length | Length |
| uint8_t field | Field - ZCL_SCENES_VIEW_EXT_FIELD_MAX_LEN |
6.2.30. Temperature Measurement
#include "zcl/general/zcl.temp.meas.h"
Functions
ZbZclTempMeasClientAlloc
struct ZbZclClusterT * ZbZclTempMeasClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Temperature Measurement Client cluster
Parameters
Return
ZbZclTempMeasServerAlloc
struct ZbZclClusterT * ZbZclTempMeasServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, int16_t min, int16_t max, uint16_t tolerance);
Create a new instance of the Temperature Measurement Server cluster
Parameters
| min | Minimum value capable of being measured (MinMeasuredValue) |
| max | Maximum value capable of being measured (MaxMeasuredValue) |
| tolerance | Tolerance |
Return
Enumerations
ZbZclTempMeasSvrAttrT
Temperature Measurement Server Attribute IDs
| ZCL_TEMP_MEAS_ATTR_MEAS_VAL | MeasuredValue |
| ZCL_TEMP_MEAS_ATTR_MIN_MEAS_VAL | MinMeasuredValue |
| ZCL_TEMP_MEAS_ATTR_MAX_MEAS_VAL | MaxMeasuredValue |
| ZCL_TEMP_MEAS_ATTR_TOLERANCE | Tolerance (Optional) |
6.2.31. Thermostat
#include "zcl/general/zcl.therm.h"
Functions
ZbZclThermClientAlloc
struct ZbZclClusterT * ZbZclThermClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Parameters
Return
ZbZclThermClientClearWeeklySched
enum ZclStatusCodeT ZbZclThermClientClearWeeklySched(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Clear Weekly Schedule command (Optional)
Parameters
Return
ZbZclThermClientGetRelayStatusLog
enum ZclStatusCodeT ZbZclThermClientGetRelayStatusLog(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Relay Status Log command (Optional)
Parameters
Return
ZbZclThermClientGetWeeklySched
enum ZclStatusCodeT ZbZclThermClientGetWeeklySched(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclThermCliGetWeeklyT *req, void (*callback)(struct ZbZclCommandRspT
- rsp, void *arg), void *arg);
Send a Get Weekly Schedule command (Optional)
Parameters
| req | Thermostat Get Weekly Schedule info |
Return
ZbZclThermClientSetWeeklySched
enum ZclStatusCodeT ZbZclThermClientSetWeeklySched(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclThermWeeklySchedT *req, void (*callback)(struct ZbZclCommandRspT
Send a Set Weekly Schedule command (Optional)
Parameters
| req | Thermostat Weekly Schedule structure |
Return
ZbZclThermClientSetpointRaiseLower
enum ZclStatusCodeT ZbZclThermClientSetpointRaiseLower(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclThermCliSetpointT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Setpoint Raise/Lower command
Parameters
| req | Thermostat Setpoint structure |
Return
ZbZclThermServerAlloc
struct ZbZclClusterT * ZbZclThermServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclThermServerCallbacksT *callbacks, void *arg);
Create a new instance of the Thermostat Server cluster
Parameters
| callbacks | Structure containing callback function pointers for this cluster |
Return
ZbZclThermServerGetRelayStatusLogRsp
enum ZclStatusCodeT ZbZclThermServerGetRelayStatusLogRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclThermSvrGetRelayStatusLogRspT *rsp);
Send a Get Relay Status Log Response command
Parameters
| rsp | Get Relay Status Log Response structure |
Return
ZbZclThermServerGetWeeklySchedRsp
enum ZclStatusCodeT ZbZclThermServerGetWeeklySchedRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclThermWeeklySchedT *rsp);
Send a Get Weekly Schedule Response command
Parameters
| rsp | Server Clear Get Weekly Schedule response |
Return
Enumerations
ZbZclThermAttrT
Thermostat Attribute IDs
| ZCL_THERM_SVR_ATTR_LOCAL_TEMP | LocalTemperature |
| ZCL_THERM_SVR_ATTR_OUTDOOR_TEMP | OutdoorTemperature (Optional) |
| ZCL_THERM_SVR_ATTR_OCCUPANCY | Occupancy (Optional) |
| ZCL_THERM_SVR_ATTR_ABS_MIN_HEAT_SETPOINT_LIMIT | AbsMinHeatSetpointLimit (Optional) |
| ZCL_THERM_SVR_ATTR_ABS_MAX_HEAT_SETPOINT_LIMI T | AbsMaxHeatSetpointLimit (Optional) |
| ZCL_THERM_SVR_ATTR_ABS_MIN_COOL_SETPOINT_LIMI T | AbsMinCoolSetpointLimit (Optional) |
| ZCL_THERM_SVR_ATTR_ABS_MAX_COOL_SETPOINT_LIMI T | AbsMaxCoolSetpointLimit (Optional) |
| ZCL_THERM_SVR_ATTR_PI_COOLING_DEMAND | PICoolingDemand (Optional) |
| ZCL_THERM_SVR_ATTR_PI_HEATING_DEMAND | PIHeatingDemand (Optional) |
| ZCL_THERM_SVR_ATTR_HVAC_SYSTYPE_CONFIG | HVACSystemTypeConfiguration (Optional) |
| ZCL_THERM_SVR_ATTR_LOCAL_TEMP_CALIB | LocalTemperatureCalibration (Optional) |
| ZCL_THERM_SVR_ATTR_OCCUP_COOL_SETPOINT | OccupiedCoolingSetpoint |
| ZCL_THERM_SVR_ATTR_OCCUP_HEAT_SETPOINT | OccupiedHeatingSetpoint |
| ZCL_THERM_SVR_ATTR_UNOCCUP_COOL_SETPOINT | UnoccupiedCoolingSetpoint (Optional) |
| ZCL_THERM_SVR_ATTR_UNOCCUP_HEAT_SETPOINT | UnoccupiedHeatingSetpoint (Optional) |
| ZCL_THERM_SVR_ATTR_MIN_HEAT_SETPOINT | MinHeatSetpointLimit (Optional) |
| ZCL_THERM_SVR_ATTR_MAX_HEAT_SETPOINT | MaxHeatSetpointLimit (Optional) |
| ZCL_THERM_SVR_ATTR_MIN_COOL_SETPOINT | MinCoolSetpointLimit (Optional) |
| ZCL_THERM_SVR_ATTR_MAX_COOL_SETPOINT | MaxCoolSetpointLimit (Optional) |
| ZCL_THERM_SVR_ATTR_MIN_SETPOINT_DEADBAND | MinSetpointDeadBand (Optional) |
| ZCL_THERM_SVR_ATTR_RMT_SENSE | RemoteSensing (Optional) |
| ZCL_THERM_SVR_ATTR_CONTROL_SEQ_OPER | ControlSequenceOfOperation |
| ZCL_THERM_SVR_ATTR_SYSTEM_MODE | SystemMode |
| ZCL_THERM_SVR_ATTR_ALARM_MASK | AlarmMask (Optional) |
| ZCL_THERM_SVR_ATTR_RUNNING_MODE | ThermostatRunningMode (Optional) |
| ZCL_THERM_SVR_ATTR_START_OF_WEEK | StartOfWeek (Optional) |
| ZCL_THERM_SVR_ATTR_NUM_WEEKLY_TRANSITIONS | NumberOfWeeklyTransitions (Optional) |
| ZCL_THERM_SVR_ATTR_NUM_DAILY_TRANSITIONS | NumberOfDailyTransitions (Optional) |
| ZCL_THERM_SVR_ATTR_TEMP_SETPOINT_HOLD | TemperatureSetpointHold (Optional) |
| ZCL_THERM_SVR_ATTR_TEMP_SETPOINT_HOLD_DUR | TemperatureSetpointHoldDuration (Optional) |
| ZCL_THERM_SVR_ATTR_PROG_OPER_MODE | ThermostatProgrammingOperationMode (Optional) |
| ZCL_THERM_SVR_ATTR_RUNNING_STATE | ThermostatRunningState (Optional) |
| ZCL_THERM_SVR_ATTR_SETPOINT_CHANGE_SRC | SetpointChangeSource |
| ZCL_THERM_SVR_ATTR_SETPOINT_CHANGE_AMT | SetpointChangeAmount |
| ZCL_THERM_SVR_ATTR_SETPOINT_CHANGE_TIMESTAMP | SetpointChangeSourceTimestamp |
| ZCL_THERM_SVR_ATTR_OCCUP_SETBACK | OccupiedSetback (Optional) |
| ZCL_THERM_SVR_ATTR_OCCUP_SETBACK_MIN | OccupiedSetbackMin (Optional) |
| ZCL_THERM_SVR_ATTR_OCCUP_SETBACK_MAX | OccupiedSetbackMax (Optional) |
| ZCL_THERM_SVR_ATTR_UNOCCUP_SETBACK | UnoccupiedSetback (Optional) |
| ZCL_THERM_SVR_ATTR_UNOCCUP_SETBACK_MIN | UnoccupiedSetbackMin (Optional) |
| ZCL_THERM_SVR_ATTR_UNOCCUP_SETBACK_MAX | UnoccupiedSetbackMax (Optional) |
| ZCL_THERM_SVR_ATTR_EMERGENCY_HEAT_DELTA | EmergencyHeatDelta (Optional) |
| ZCL_THERM_SVR_ATTR_AC_TYPE | ACType |
| ZCL_THERM_SVR_ATTR_AC_CAPACITY | ACCapacity |
| ZCL_THERM_SVR_ATTR_AC_REFIGERANT_TYPE | ACRefrigerantType |
| ZCL_THERM_SVR_ATTR_AC_COMPRESSOR_TYPE | ACCompressorType |
| ZCL_THERM_SVR_ATTR_AC_ERROR_CODE | ACErrorCode |
| ZCL_THERM_SVR_ATTR_AC_LOUVER_POSITION | ACLouverPosition |
| ZCL_THERM_SVR_ATTR_AC_COIL_TEMP | ACCoilTemperature |
| ZCL_THERM_SVR_ATTR_AC_CAPACITY_FORMAT | ACCapacityFormat |
Structures
Thermostat Get Weekly Schedule structure
Parameters
| uint8_t days_to_return | Days to Return |
| uint8_t mode_to_return | Mode to Return |
Parameters
| uint8_t mode | Mode |
| int8_t amount | Amount |
Thermostat Server callbacks configuration
Parameters
| setpoint_raise_lower
enum ZclStatusCodeT (*setpoint_raise_lower)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclThermCliSetpointT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to handle Setpoint Raise/Lower command response |
| set_weekly
enum ZclStatusCodeT (*set_weekly)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclThermWeeklySchedT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to handle Set Weekly Schedule command response |
| get_weekly
enum ZclStatusCodeT (*get_weekly)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclThermCliGetWeeklyT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to handle Get Weekly Schedule command response |
| clear_weekly
enum ZclStatusCodeT (*clear_weekly)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to handle Clear Weekly Schedule command response |
| get_relay_status_log
enum ZclStatusCodeT (*get_relay_status_log)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to handle Get Relay Status Log command response |
Parameters
| uint16_t time_of_day | Time of Day |
| uint16_t relay_status | Relay Status |
| int16_t local_temp | Local Temperature |
| uint8_t humidity_percent | Humidity in Percentage |
| int16_t set_point | Unread Entries |
ZbZclThermTransitionsT
Thermostat Transition structure
Parameters
| uint16_t transition_time | Transition Time |
| int16_t heat_set_point | Heat Set Point (optional) |
| int16_t cool_set_point | Cool Set Point (optional) |
Parameters
| uint8_t num_transitions | Number of Transitions for Sequence |
| uint8_t day_of_week_seq | Day of the Week for Sequence - e.g. ZCL_THERM_DAY_OF_WEEK_SUNDAY |
| uint8_t mode_for_seq | Mode for Sequence - e.g. ZCL_THERM_MODE_HEAT_SETPOINT_PRESENT |
| struct ZbZclThermTransitionsT
transitions |
List of transitions |
6.2.32. Thermostat User Interface
#include "zcl/general/zcl.therm.ui.h"
Functions
ZbZclThermUiClientAlloc
struct ZbZclClusterT * ZbZclThermUiClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Thermostat User Interface Client cluster
Parameters
Return
ZbZclThermUiServerAlloc
struct ZbZclClusterT * ZbZclThermUiServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Thermostat User Interface Server cluster
Parameters
Return
Enumerations
ZbZclThermUiServerAttrT
Thermostat User Interface Attribute IDs
| ZCL_THERM_UI_SVR_ATTR_DISPLAY_MODE | TemperatureDisplayMode |
| ZCL_THERM_UI_SVR_ATTR_KEYPAD_LOCKOUT | KeypadLockout |
| ZCL_THERM_UI_SVR_ATTR_SCHEDULE_PROG_VIS | ScheduleProgrammingVisibility (Optional) |
6.2.33. Time
#include "zcl/general/zcl.time.h"
Functions
ZbZclTimeClientAlloc
struct ZbZclClusterT * ZbZclTimeClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Time Client cluster
Parameters
| zb | Zigbee stack instance |
Return
ZbZclTimeServerAlloc
struct ZbZclClusterT * ZbZclTimeServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclTimeServerCallbacks *callbacks, void *arg);
Create a new instance of the Time Server cluster
Parameters
| arg | Pointer to application data that will included in the callback when invoked. |
Return
ZbZclTimeServerCurrentTime
uint32_t ZbZclTimeServerCurrentTime(struct ZbZclClusterT *cluster);
Call the get_time callback defined as part of the Time Server callbacks configuration
Parameters
Return
- Current time in seconds since Zigbee Epoch: Jan 1st 2000
ZbZclTimeServerSetTime
void ZbZclTimeServerSetTime(struct ZbZclClusterT *cluster, uint32_t current_time);
Call the set_time callback defined as part of the Time Server callbacks configuration
Parameters
| current_time | New current time value to set |
Return
- Void
Enumerations
ZbZclTimeSvrAttrT
Time Server Attribute IDs
| ZCL_TIME_ATTR_TIME | Time |
| ZCL_TIME_ATTR_STATUS | TimeStatus |
| ZCL_TIME_ATTR_TIME_ZONE | TimeZone (Optional) |
| ZCL_TIME_ATTR_DST_START | DstStart (Optional) |
| ZCL_TIME_ATTR_DST_END | DstEnd (Optional) |
| ZCL_TIME_ATTR_DST_SHIFT | DstShift (Optional) |
| ZCL_TIME_ATTR_STANDARD_TIME | StandardTime (Optional) |
| ZCL_TIME_ATTR_LOCAL_TIME | LocalTime (Optional) |
| ZCL_TIME_ATTR_LAST_SET_TIME | LastSetTime (Optional) |
| ZCL_TIME_ATTR_VALID_UNTIL_TIME | ValidUntilTime (Optional) |
Structures
Parameters
| get_time
uint32_t (*get_time)(struct ZbZclClusterT *clusterPtr, void *arg)
Callback to application, invoked on receipt of Read Attribute request. Returns current time in seconds since Zigbee Epoch: Jan 1st 2000. |
| set_time
void (*set_time)(struct ZbZclClusterT *clusterPtr, uint32_t time_val, void *arg)
Callback to application, invoked on receipt of Write Attribute request for the ZCL_TIME_ATTR_TIME attribute. The set_time app callback should also set the ZCL_TIME_ATTR_LAST_SET_TIME attribute if successful. The time_val parameter is the current time in seconds since Zigbee Epoch: Jan 1st 2000. |
6.2.34. Voice Over Zigbee
#include "zcl/general/zcl.voice.h"
Functions
ZbZclVoiceClientAlloc
struct ZbZclClusterT * ZbZclVoiceClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct zcl_voice_client_callbacks_t *callbacks, void *arg);
Create a new instance of the Voice Over Zigbee Client cluster
Parameters
Return
ZbZclVoiceClientEstabReq
enum ZclStatusCodeT ZbZclVoiceClientEstabReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct voice_estab_req_t *estab_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Establishment Request command
Parameters
| estab_req | Establishment Request command request structure |
| callback | Callback function that will be invoked when the response is received. |
Return
ZbZclVoiceClientSendControlRsp
enum ZclStatusCodeT ZbZclVoiceClientSendControlRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst_info, struct voice_control_rsp_t *rsp);
Send an Control command
Parameters
| dst_info | Destination address for response, including sequence number and tx options |
| rsp | Control command response structure |
Return
ZbZclVoiceServerAlloc
struct ZbZclClusterT * ZbZclVoiceServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct zcl_voice_server_callbacks_t *callbacks, void *arg);
Create a new instance of the Voice Over Zigbee Server cluster
Parameters
Return
ZbZclVoiceServerControlReq
enum ZclStatusCodeT ZbZclVoiceServerControlReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct voice_control_t *control_cmd, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Control command
Parameters
| control_cmd | Control command request structure |
Return
ZbZclVoiceServerSendEstabRsp
enum ZclStatusCodeT ZbZclVoiceServerSendEstabRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst_info, struct voice_estab_rsp_t *rsp);
Send an Establishment Response command
Parameters
| rsp | Establishment Response command structure |
Return
ZbZclVoiceServerSendVoiceTxRsp
enum ZclStatusCodeT ZbZclVoiceServerSendVoiceTxRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct voice_voice_tx_rsp_t *rsp);
Send a Voice Transmission Response command. The application calls this if it ever encounters an error processing a Voice Transmission packet
Parameters
| rsp | Voice Transmission Response command structure |
Return
ZbZclVoiceTxCompletedReq
enum ZclStatusCodeT ZbZclVoiceTxCompletedReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback) (struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Voice Transmission Complete command
Parameters
Return
ZbZclVoiceVoiceTxReq
enum ZclStatusCodeT ZbZclVoiceVoiceTxReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct voice_voice_tx_t *voice_tx, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Voice Transmission command
Parameters
| voice_tx | Voice Transmission command request structure |
Return
Enumerations
ZbZclVoiceSvrAttrT
Voice Over Zigbee Server Attribute IDs
| ZCL_VOICE_ATTR_CODEC_TYPE | CodecType |
| ZCL_VOICE_ATTR_SAMP_FREQ | SamplingFrequency |
| ZCL_VOICE_ATTR_CODECRATE | Codecrate |
| ZCL_VOICE_ATTR_ESTAB_TIMEOUT | EstablishmentTimeout |
| ZCL_VOICE_ATTR_CODEC_TYPE_SUB_1 | CodecTypeSub1 (Optional) |
| ZCL_VOICE_ATTR_CODEC_TYPE_SUB_2 | CodecTypeSub2 (Optional) |
| ZCL_VOICE_ATTR_CODEC_TYPE_SUB_3 | CodecTypeSub3 (Optional) |
| ZCL_VOICE_ATTR_COMPRESSION_TYPE | CompressionType (Optional) |
| ZCL_VOICE_ATTR_COMPRESSION_RATE | CompressionRate (Optional) |
| ZCL_VOICE_ATTR_OPTION_FLAGS | OptionFlags (Optional) |
| ZCL_VOICE_ATTR_THRESHOLD | Threshold (Optional) |
Structures
voice_control_rsp_t
Control Response command structure
Parameters
| uint8_t ack_nak | ACK=0x01 NAK=0x00 |
voice_control_t
Control command structure
Parameters
| uint8_t control_type | Control Type |
voice_estab_req_t
Establishment Request command structure
Parameters
| uint8_t flag | Flag |
| uint8_t codec_type | Codec Type |
| uint8_t samp_freq | Samp. Freq. |
| uint8_t codec_rate | Codec Rate |
| uint8_t service_type | Service Type |
| uint8_t codec_type_s1 | Codec TypeS1 |
| uint8_t codec_type_s2 | Codec TypeS2 |
| uint8_t codec_type_s3 | Codec TypeS3 |
| uint8_t comp_type | Comp. Type |
| uint8_t comp_rate | Comp. Rate |
voice_estab_rsp_t
Parameters
| uint8_t codec_type | CodecType |
Parameters
| uint8_t error_flag | Error Flag - e.g. ZCL_VOICE_TX_RSP_ERROR_DECODE |
voice_voice_tx_t
Voice Transmission command structure
Parameters
| uint8_t *voice_data | Voice Data |
| uint16_t voice_data_len | Voice Data Length |
Voice Over Zigbee Client callbacks configuration
Parameters
| control
enum ZclStatusCodeT (*control)(struct ZbZclClusterT *clusterPtr, struct voice_control_t *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Control command |
Voice Over Zigbee Server callbacks configuration
Parameters
| estab_req
enum ZclStatusCodeT (*estab_req)(struct ZbZclClusterT *clusterPtr, struct voice_estab_req_t *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Establishment Request command |
| voice_tx
enum ZclStatusCodeT (*voice_tx)(struct ZbZclClusterT *clusterPtr, struct voice_voice_tx_t *cmd_req, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Voice Transmission command. The application should return ZCL_STATUS_SUCCESS or call ZbZclVoiceServerSendVoiceTxRsp to send an error response and return ZCL_STATUS_SUCCESS_NO_DEFAULT_RESPONSE |
| tx_complete
enum ZclStatusCodeT (*tx_complete)(struct ZbZclClusterT *clusterPtr, struct ZbZclAddrInfoT *src_info, void *arg)
Callback to application, invoked on receipt of Voice Transmission Completion command |
6.2.35. Water Content Measurement
#include "zcl/general/zcl.wcm.h"
Functions
ZbZclWaterContentMeasClientAlloc
struct ZbZclClusterT * ZbZclWaterContentMeasClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, enum ZbZclClusterIdT clusterID);
Create a new instance of the Water Content Measurement Client cluster
Parameters
| endpoint | Endpoint on which to create cluster |
| clusterID | Cluster identifier (Relative Humidity 0x0405, Leaf Wetness 0x0407 or Soil Moisture 0x0408) |
- Cluster pointer, or NULL if there is an error
ZbZclWaterContentMeasServerAlloc
struct ZbZclClusterT * ZbZclWaterContentMeasServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, enum ZbZclClusterIdT clusterID, uint16_t min, uint16_t max);
Create a new instance of the Water Content Measurement Server cluster
Parameters
| min | Default minimum value |
| max | Default maximum value |
Return
Enumerations
ZbZclWcmSvrAttrT
Water Content Measurement Server Attribute IDs
| ZCL_WC_MEAS_ATTR_MEAS_VAL | MeasuredValue |
| ZCL_WC_MEAS_ATTR_MIN_MEAS_VAL | MinMeasuredValue |
| ZCL_WC_MEAS_ATTR_MAX_MEAS_VAL | MaxMeasuredValue |
| ZCL_WC_MEAS_ATTR_TOLERANCE | Tolerance (Optional) |
6.2.36. Window Covering
#include "zcl/general/zcl.window.h"
Functions
ZbZclWindowClientAlloc
struct ZbZclClusterT * ZbZclWindowClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Window Covering Client cluster
Parameters
ZbZclWindowClientCommandDown
enum ZclStatusCodeT ZbZclWindowClientCommandDown(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Down/Close command
Parameters
| dst | The destination address information |
Return
ZbZclWindowClientCommandStop
enum ZclStatusCodeT ZbZclWindowClientCommandStop(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Stop command
Parameters
Return
ZbZclWindowClientCommandUp
enum ZclStatusCodeT ZbZclWindowClientCommandUp(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send an Up/Open command
Parameters
Return
ZbZclWindowClosureServerMode
enum ZclStatusCodeT ZbZclWindowClosureServerMode(struct ZbZclClusterT *cluster, uint8_t mode);
Configure the Window Covering mode
Parameters
| mode | Window Covering mode bit mask |
Return
ZbZclWindowServerAlloc
struct ZbZclClusterT * ZbZclWindowServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclWindowServerCallbacksT *callbacks, void *arg);
Create a new instance of the Window Covering Server cluster
Parameters
Return
Enumerations
ZbZclWncvServerAttrT
Window Covering Server Attribute Ids
| ZCL_WNCV_SVR_ATTR_COVERING_TYPE | WindowCoveringType |
| ZCL_WNCV_SVR_ATTR_PHY_CLOSE_LIMIT_LIFT | PhysicalClosedLimitLift (Optional) |
| ZCL_WNCV_SVR_ATTR_PHY_CLOSE_LIMIT_TILT | PhysicalClosedLimitTilt (Optional) |
| ZCL_WNCV_SVR_ATTR_CURR_POSITION_LIFT | CurrentPositionLift (Optional) |
| ZCL_WNCV_SVR_ATTR_CURR_POSITION_TILT | CurrentPositionTilt (Optional) |
| ZCL_WNCV_SVR_ATTR_ACTUATION_NUMBER_LIFT | NumberOfActuationsLift (Optional) |
| ZCL_WNCV_SVR_ATTR_ACCUATION_NUMBER_TILT | NumberOfActuationsTilt (Optional) |
| ZCL_WNCV_SVR_ATTR_CONFIG_STATUS | ConfigStatus |
| ZCL_WNCV_SVR_ATTR_CURR_POS_LIFT_PERCENT | CurrentPositionLiftPercentage |
| ZCL_WNCV_SVR_ATTR_CURR_POS_TILT_PERCENT | CurrentPositionTiltPercentage |
| ZCL_WNCV_SVR_ATTR_INSTALLED_OPENED_LIMIT_LIFT | InstalledOpenLimitLift |
| ZCL_WNCV_SVR_ATTR_INSTALLED_CLOSED_LIMIT_LIFT | InstalledClosedLimitLift |
| ZCL_WNCV_SVR_ATTR_INSTALLED_OPENED_LIMIT_TILT | InstalledOpenLimitTilt |
| ZCL_WNCV_SVR_ATTR_INSTALLED_CLOSED_LIMIT_TILT | InstalledClosedLimitTilt |
| ZCL_WNCV_SVR_ATTR_VELOCITY_LIFT | VelocityLift (Optional) |
| ZCL_WNCV_SVR_ATTR_ACCELERATION_TIME_LIFT | AccelerationTimeLift (Optional) |
| ZCL_WNCV_SVR_ATTR_DECELERATION_TIME_LIFT | DecelerationTimeLift (Optional) |
| ZCL_WNCV_SVR_ATTR_MODE | Mode |
| ZCL_WNCV_SVR_ATTR_INTERMEDIATE_SETPOINTS_LIFT | Intermediate Setpoints - Lift (Optional) |
| ZCL_WNCV_SVR_ATTR_INTERMEDIATE_SETPOINTS_TILT | Intermediate Setpoints - Tilt (Optional) |
ZbZclWncvTypes
Window Covering Type enumerations
| ZCL_WNCV_TYPE_ROLLERSHADE | Rollershade |
| ZCL_WNCV_TYPE_ROLLERSHADE_2_MOTOR | Rollershade - 2 Motor |
| ZCL_WNCV_TYPE_ROLLERSHADE_EXTERIOR | Rollershade – Exterior |
| ZCL_WNCV_TYPE_ROLLERSHADE_EXTERIOR_2_MOTOR | Rollershade - Exterior - 2 Motor |
| ZCL_WNCV_TYPE_DRAPERY | Drapery |
| ZCL_WNCV_TYPE_AWNING | Awning |
| ZCL_WNCV_TYPE_SHUTTER | Shutter |
| ZCL_WNCV_TYPE_TILT_BLIND_TILT_ONLY | Tilt Blind - Tilt Only |
| ZCL_WNCV_TYPE_TILT_BLIND_LIFT_TILT | Tilt Blind - Lift and Tilt |
| ZCL_WNCV_TYPE_PROJECTOR_SCREEN | Projector Screen |
Structures
Window Covering Server callbacks configuration
Parameters
| up_command
enum ZclStatusCodeT (*up_command)(struct ZbZclClusterT *cluster, struct ZbZclHeaderT *zclHdrPtr, struct ZbApsdeDataIndT *dataIndPtr, void *arg)
Callback to application, invoked on receipt of Up/Open command. Application should update ZCL_WNCV_SVR_ATTR_CURR_POS_LIFT_PERCENT and ZCL_WNCV_SVR_ATTR_CURR_POS_TILT_PERCENT. |
| down_command
enum ZclStatusCodeT (*down_command)(struct ZbZclClusterT *cluster, struct ZbZclHeaderT *zclHdrPtr, struct ZbApsdeDataIndT *dataIndPtr, void *arg)
Callback to application, invoked on receipt of Down/Close command. Application should update ZCL_WNCV_SVR_ATTR_CURR_POS_LIFT_PERCENT and ZCL_WNCV_SVR_ATTR_CURR_POS_TILT_PERCENT. |
| stop_command
enum ZclStatusCodeT (*stop_command)(struct ZbZclClusterT *cluster, struct ZbZclHeaderT *zclHdrPtr, struct ZbApsdeDataIndT *dataIndPtr, void *arg)
Callback to application, invoked on receipt of Stop command. Application should update ZCL_WNCV_SVR_ATTR_CURR_POS_LIFT_PERCENT and ZCL_WNCV_SVR_ATTR_CURR_POS_TILT_PERCENT. |
| set_lift_and_tilt_command
enum ZclStatusCodeT (*set_lift_and_tilt_command)(struct ZbZclClusterT *cluster, void *arg, uint8_t liftPercentage, uint8_t tiltPercentage)
Callback to application, invoked to handle setting a Scene, which includes Lift and Tilt values. Application should update ZCL_WNCV_SVR_ATTR_CURR_POS_LIFT_PERCENT and ZCL_WNCV_SVR_ATTR_CURR_POS_TILT_PERCENT. |
6.3. IAS Security Clusters
6.3.1. IAS ACE
#include "zcl/security/zcl.ias_ace.h"
Functions
ZbZclIasAceClientAlloc
struct ZbZclClusterT * ZbZclIasAceClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, void *arg);
Allocate the IAS ACE Client cluster
Parameters
Return
ZbZclIasAceClientCommandArmReq
enum ZclStatusCodeT ZbZclIasAceClientCommandArmReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclIasAceClientCommandArmT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Arm command
Parameters
| cluster | Cluster instance from which to send this command |
| cmd_req | Arm command request structure |
Return
ZbZclIasAceClientCommandBypassReq
enum ZclStatusCodeT ZbZclIasAceClientCommandBypassReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclIasAceClientCommandBypassT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Bypass command
Parameters
| cmd_req | Bypass command request structure |
Return
ZbZclIasAceClientCommandEmergencyReq
enum ZclStatusCodeT ZbZclIasAceClientCommandEmergencyReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Emergency command
Parameters
Return
ZbZclIasAceClientCommandFireReq
enum ZclStatusCodeT ZbZclIasAceClientCommandFireReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Fire command
Parameters
Return
ZbZclIasAceClientCommandGetBypassedZoneListReq
enum ZclStatusCodeT ZbZclIasAceClientCommandGetBypassedZoneListReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Bypassed Zone List command
Parameters
Return
ZbZclIasAceClientCommandGetPanelStatusReq
enum ZclStatusCodeT ZbZclIasAceClientCommandGetPanelStatusReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Panel Status changed request
Parameters
Return
ZbZclIasAceClientCommandGetZoneIdMapReq
enum ZclStatusCodeT ZbZclIasAceClientCommandGetZoneIdMapReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Zone ID Map command
Parameters
Return
ZbZclIasAceClientCommandGetZoneInfoReq
enum ZclStatusCodeT ZbZclIasAceClientCommandGetZoneInfoReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclIasAceClientCommandGetZoneInfoT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Zone Info command
Parameters
| cmd_req | Get Zone Info command request structure |
Return
ZbZclIasAceClientCommandGetZoneStatusReq
enum ZclStatusCodeT ZbZclIasAceClientCommandGetZoneStatusReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclIasAceClientCommandGetZoneStatusT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Zone Status command
Parameters
| cmd_req | Get Zone Status command request structure |
Return
ZbZclIasAceClientCommandPanicReq
enum ZclStatusCodeT ZbZclIasAceClientCommandPanicReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Panic command
Parameters
Return
ZbZclIasAceClientParseArmRsp
bool ZbZclIasAceClientParseArmRsp(const uint8_t *buf, unsigned int len, struct ZbZclIasAceServerCommandArmRspT *rsp);
Parse an Arm Response command payload into a data structure
Parameters
| buf | Response buffer |
| len | Length of response buffer |
| rsp | Arm response structure |
Return
- True on success, false otherwise
ZbZclIasAceClientParseBypassRsp
bool ZbZclIasAceClientParseBypassRsp(const uint8_t *buf, unsigned int len, struct ZbZclIasAceServerCommandBypassRspT *rsp);
Parse a Bypass Response command payload into a data structure
Parameters
| rsp | Bypass Response structure |
Return
ZbZclIasAceClientParseGetPanelStatusRsp
bool ZbZclIasAceClientParseGetPanelStatusRsp(const uint8_t *buf, unsigned int len, struct ZbZclIasAceServerCommandGetPanelStatusRspT *rsp);
Parse a Get Panel Status Response command payload into a data structure
Parameters
| rsp | Zone Status Changed Response structure |
Return
ZbZclIasAceClientParseGetZoneIdMapRsp
bool ZbZclIasAceClientParseGetZoneIdMapRsp(const uint8_t *buf, unsigned int len, struct ZbZclIasAceServerCommandGetZoneIdMapRspT *rsp);
Parse a Get Zone ID Map Response command payload into a data structure
Parameters
| rsp | Get Zone ID Map Response structure |
Return
ZbZclIasAceClientParseGetZoneInfoRsp
bool ZbZclIasAceClientParseGetZoneInfoRsp(const uint8_t *buf, unsigned int len, struct ZbZclIasAceServerCommandGetZoneInfoRspT *rsp);
Parse a Get Zone Info Response command payload into a data structure
Parameters
| rsp | Get Zone Info Response structure |
Return
ZbZclIasAceClientParseGetZoneStatusRsp
bool ZbZclIasAceClientParseGetZoneStatusRsp(const uint8_t *buf, unsigned int len, struct ZbZclIasAceServerCommandGetZoneStatusRspT *rsp);
Parse a Get Zone Status Response command payload into a data structure
Parameters
| rsp | Get Zone Status Response structure |
Return
ZbZclIasAceClientParseSetBypassedZoneList
bool ZbZclIasAceClientParseSetBypassedZoneList(const uint8_t *buf, unsigned int len, struct ZbZclIasAceServerCommandSetBypassedZoneListT *rsp);
Parse a Set Bypassed Zone List Response command payload into a data structure
Parameters
| rsp | Set Bypassed Zone List Response structure |
Return
ZbZclIasAceClientParseZoneStatusChanged
bool ZbZclIasAceClientParseZoneStatusChanged(const uint8_t *buf, unsigned int len, struct ZbZclIasAceServerCommandZoneStatusChangedT *rsp);
Parse a Zone Status Changed Response command payload into a data structure
Parameters
Return
ZbZclIasAceServerAlloc
struct ZbZclClusterT * ZbZclIasAceServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclIasAceServerCallbacksT *callbacks, void *arg);
Create a new instance of the IAS ACE Server cluster
If 'use_trip_pair' is true, application must call ZbZclIasAceServerEnrollRequest to perform the 'trip-to-pair' process, unless the IAS CIE has sent us an unsolicited Auto-Enroll-Response
Parameters
Return
ZbZclIasAceServerGetFreeZoneId
bool ZbZclIasAceServerGetFreeZoneId(struct ZbZclClusterT *cluster, uint8_t *zone_id_ptr);
Returns the first free Zone ID not already in the Zone Table
Parameters
| zone_id_ptr | Zone ID value |
Return
ZbZclIasAceServerPanelCodeConfig
bool ZbZclIasAceServerPanelCodeConfig(struct ZbZclClusterT *cluster, const char *arm_code);
Change the Panel Arm/Disarm Code
Parameters
| arm_code | Arm code |
Return
ZbZclIasAceServerPanelStatusConfig
bool ZbZclIasAceServerPanelStatusConfig(struct ZbZclClusterT *cluster, enum ZbZclIasAcePanelStatusT panel_status, uint8_t seconds_remain, enum ZbZclIasAceAudibleNotifyT audible_notify);
Update the Panel Status
Parameters
| panel_status | Panel Status enumeration |
| seconds_remain | Seconds remaining |
Return
ZbZclIasAceServerZoneBypassConfig
enum ZbZclIasAceBypassResultT ZbZclIasAceServerZoneBypassConfig(struct ZbZclClusterT *cluster, uint8_t zone_id, bool bypass);
Bypass zone if allowed
Parameters
| zone_id | Zone ID of zone in question |
| bypass | True if zone will be bypassed, false if not |
Return
- Result of bypass config command
ZbZclIasAceServerZoneBypassPerms
bool ZbZclIasAceServerZoneBypassPerms(struct ZbZclClusterT *cluster, uint8_t zone_id, enum ZbZclIasAceBypassPermsT bypass_perms);
Configure Bypass Permissions
Parameters
| bypass_perms | Desired bypass permissions |
Return
ZbZclIasAceServerZoneStatusConfig
bool ZbZclIasAceServerZoneStatusConfig(struct ZbZclClusterT *cluster, uint8_t zone_id, enum ZbZclIasZoneServerZoneStatusT zone_status, enum ZbZclIasAceAudibleNotifyT audible_notify);
Configure Zone Status
Parameters
| zone_status | Desired zone status |
| audible_notify | Determines if zone notification is audible or not |
Return
ZbZclIasAceServerZoneTableAdd
bool ZbZclIasAceServerZoneTableAdd(struct ZbZclClusterT *cluster, struct ZbZclIasAceServerZoneTableAddT *req);
Add new zone entry
Parameters
| req | Zone Table Add request structure |
Return
ZbZclIasAceServerZoneTableAddrLookup
uint64_t ZbZclIasAceServerZoneTableAddrLookup(struct ZbZclClusterT *cluster, uint8_t zone_id);
Returns address of paired zone, or 0 if not found
Parameters
| zone_id | ID of zone to be returned |
Return
- Address of zone if successful, 0 on error
ZbZclIasAceServerZoneTableDeleteByAddr
bool ZbZclIasAceServerZoneTableDeleteByAddr(struct ZbZclClusterT *cluster, uint64_t addr);
Delete a zone by address
Parameters
| addr | Address of zone to be deleted |
Return
ZbZclIasAceServerZoneTableDeleteById
bool ZbZclIasAceServerZoneTableDeleteById(struct ZbZclClusterT *cluster, uint8_t zone_id);
Delete a zone by zone ID
Parameters
| zone_id | ID of zone to be deleted |
Return
ZbZclIasAceServerZoneTableIdLookup
bool ZbZclIasAceServerZoneTableIdLookup(struct ZbZclClusterT *cluster, uint64_t zone_addr, uint8_t *zone_id_ptr);
Attempts to find a zone based on extended address, and returns the zone Id if found
Parameters
| zone_addr | Address of Zone being looked up |
| zone_id_ptr | If successful, points to zone ID that was looked up |
Return
Structures
Arm command structure
Parameters
| enum ZbZclIasAceArmModeT arm_mode | Arm Mode |
| char arm_code | Arm/Disarm Code |
| uint8_t zone_id | Zone ID |
Bypass command structure
Parameters
| uint8_t num_zones | Number of Zones |
| uint8_t zone_id_list | Zone ID List |
Get Zone Info command structure
Parameters
Get Zone Status command structure
Parameters
| uint8_t starting_zone_id | Starting Zone ID |
| uint8_t max_zone_ids | Max Number of Zone IDs |
| uint8_t zone_status_mask_flag | Zone Status Mask Flag |
| uint16_t zone_status_mask | Zone Status Mask |
IAS ACE Server callbacks configuration
Parameters
| arm_req
(callback function pointer) |
bool (*arm_req)(struct ZbZclClusterT *clusterPtr, void *arg, struct ZbZclIasAceClientCommandArmT *arm_req, struct ZbZclIasAceServerCommandArmRspT *arm_rsp)
Callback to application, invoked on receipt of Arm command |
| bypass_req
void (*bypass_req)(struct ZbZclClusterT *clusterPtr, void *arg, struct ZbZclIasAceClientCommandBypassT *bypass_req, struct ZbZclIasAceServerCommandBypassRspT *bypass_rsp)
Callback to application, invoked on receipt of Bypass command |
| emerg_req
enum ZclStatusCodeT (*emerg_req)(struct ZbZclClusterT *clusterPtr, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Emergency command |
| fire_req
enum ZclStatusCodeT (*fire_req)(struct ZbZclClusterT *clusterPtr, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Fire command |
| panic_req
enum ZclStatusCodeT (*panic_req)(struct ZbZclClusterT *clusterPtr, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Panic command |
Parameters
| enum ZbZclIasAceArmNotifyT arm_notify | Arm Notification |
Bypass Response response structure
Parameters
bypass_result_list |
Bypass Result for Zone ID List |
Get Panel Status response structure
Parameters
panel_status |
Panel Status |
| uint8_t seconds_remain | Seconds Remaining |
audible_notify |
Audible Notification |
| enum ZbZclIasAceAlarmStatusT
alarm_status |
Alarm Status |
Get Zone ID Map response structure
Parameters
| uint16_t zond_id_map_list | Zone ID Map List |
Get Zone Info response structure
Parameters
| enum ZbZclIasZoneServerZoneTypeT
zone_type |
Zone Type |
| uint64_t zone_addr | IEEE Address |
| char zone_label | Zone Label |
Get Zone Status response structure
Parameters
| uint8_t zone_status_complete | Zone Status Complete |
| struct { uint8_t zone_id | Zone ID |
zone_status |
Zone Status |
Set Bypassed Zone List command structure
Parameters
Zone Status Changed command structure
Parameters
zone_status |
Zone Status |
audible_notify |
Parameters
zone_type |
Zone Type |
| uint64_t zone_addr | Zone Address |
| const char *zone_label | Zone Label - May be NULL, Max length = ZCL_IAS_ACE_ZONE_LABEL_STRING_MAX_LEN |
| uint8_t zone_id | Zone ID - can use ZbZclIasAceServerGetFreeZoneId |
6.3.2. IAS WD
#include "zcl/security/zcl.ias_wd.h"
Functions
ZbZclIasWdClientAlloc
struct ZbZclClusterT * ZbZclIasWdClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, void *arg);
Create a new instance of the IAS Warning Device Client cluster
Parameters
Return
ZbZclIasWdServerAlloc
struct ZbZclClusterT * ZbZclIasWdServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclIasWdServerCallbacksT *callbacks, void *arg);
Create a new instance of the IAS Warning Device Server cluster
Parameters
Return
Enumerations
ZbZclIasWdLevelT
IAS Warning Device Siren Level Field Values
| ZCL_IAS_WD_LEVEL_LOW | Low level sound |
| ZCL_IAS_WD_LEVEL_MEDIUM | Medium level sound |
| ZCL_IAS_WD_LEVEL_HIGH | High level sound |
| ZCL_IAS_WD_LEVEL_VERY_HIGH | Very high level sound |
ZbZclIasWdSquawkModeT
IAS Warning Device Squawk Mode Field
| ZCL_IAS_WD_SQUAWK_MODE_ARMED | Notification sound for “System is armed” |
| ZCL_IAS_WD_SQUAWK_MODE_DISARMED | Notification sound for "System is disarmed" |
ZbZclIasWdStrobeT
IAS Warning Device Strobe Field
| ZCL_IAS_WD_STROBE_OFF | No strobe |
| ZCL_IAS_WD_STROBE_ON | Use strobe in parallel to warning |
ZbZclIasWdSvrAttrT
IAS Warning Device Server Attribute IDs
| ZCL_IAS_WD_SVR_ATTR_MAX_DURATION | MaxDuration |
ZbZclIasWdWarningModeT
IAS Warning Device Warning Modes
| ZCL_IAS_WD_WARNING_MODE_STOP | Stop (no warning) |
| ZCL_IAS_WD_WARNING_MODE_BURGLAR | Burglar |
| ZCL_IAS_WD_WARNING_MODE_FIRE | Fire |
| ZCL_IAS_WD_WARNING_MODE_EMERGENCY | Emergency |
| ZCL_IAS_WD_WARNING_MODE_POLICE_PANIC | Police panic |
| ZCL_IAS_WD_WARNING_MODE_FIRE_PANIC | Fire panic |
| ZCL_IAS_WD_WARNING_MODE_EMERGENCY_PANIC | Emergency Panic (i.e., medical issue) |
Structures
ZbZclIasWdClientSquawkReqT
IAS Warning Device Client Squawk command structure
Parameters
| enum ZbZclIasWdSquawkModeT
squawk_mode |
Squawk mode |
| enum ZbZclIasWdStrobeT strobe | Strobe |
| enum ZbZclIasWdLevelT squawk_level | Squawk level |
ZbZclIasWdClientStartWarningReqT
IAS Warning Device Client Start Warning command structure
Parameters
| enum ZbZclIasWdWarningModeT
warning_mode |
Warning Mode |
| enum ZbZclIasWdLevelT siren_level | Siren Level |
| uint16_t warning_duration | Warning Duration |
| uint8_t strobe_dutycycle | Strobe Duty Cycle |
| enum ZbZclIasWdLevelT strobe_level | Strobe Level |
IAS Warning Server callbacks configuration
Parameters
| start_warning
enum ZclStatusCodeT (*start_warning)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclIasWdClientStartWarningReqT *warn_req)
Callback to handle Start Warning command. ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error. |
| squawk
enum ZclStatusCodeT (*squawk)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclIasWdClientSquawkReqT *squawk_req)
Callback to handle Squawk command. ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error. |
6.3.3. IAS Zone
#include "zcl/security/zcl.ias_zone.h"
Functions
ZbZclIasZoneClientAlloc
struct ZbZclClusterT * ZbZclIasZoneClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclIasZoneClientCallbacksT *callbacks, void *arg);
Create a new instance of the IAS Zone Client cluster
Parameters
| callbacks | Structure containing any callback function pointers for this cluster |
Return
ZbZclIasZoneClientInitiateAutoEnroll
enum ZclStatusCodeT ZbZclIasZoneClientInitiateAutoEnroll(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(const struct ZbZclWriteRspT *, void *), void *arg);
Send a Zone Auto-Enroll request command
Parameters
Return
ZbZclIasZoneClientInitiateNormalMode
enum ZclStatusCodeT ZbZclIasZoneClientInitiateNormalMode(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Initiate Normal Operation Mode request command
Parameters
Return
ZbZclIasZoneClientInitiateTestMode
enum ZclStatusCodeT ZbZclIasZoneClientInitiateTestMode(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclIasZoneClientTestModeReqT *req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Initiate Test Mode request command
Parameters
| req | Initiate Test Mode request structure |
Return
ZbZclIasZoneClientSendAutoEnrollResponse
enum ZclStatusCodeT ZbZclIasZoneClientSendAutoEnrollResponse(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, uint8_t zone_id, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Zone Auto-Enroll response command
Parameters
| zone_id | Zone ID |
Return
ZbZclIasZoneServerAlloc
struct ZbZclClusterT * ZbZclIasZoneServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, uint16_t zone_type, uint16_t manuf_code, bool use_trip_pair, struct ZbZclIasZoneServerCallbacksT *callbacks, void *arg);
Create a new instance of the IAS Zone Server cluster
Parameters
| zone_type | Zone Type |
| manuf_code | Manufacturer Code |
| use_trip_pair | If true, use 'trip-to-pair' application must call ZbZclIasZoneServerEnrollRequest to perform the 'trip-to-pair' process, unless the IAS CIE has sent us an unsolicited Auto-Enroll-Response |
Return
enum ZclStatusCodeT ZbZclIasZoneServerEnrollRequest(struct ZbZclClusterT *cluster, void (*callback)(struct ZbZclIasZoneClientEnrollResponseT *enrl_rsp, void *arg), void *arg);
Send a Zone Enroll request command Used with 'trip-to-pair'. Before sending a Zone Enroll Request, the IAS CIE must write to the IAS_CIE_Address attribute with its IEEE address.
Parameters
Return
Enumerations
ZbZclIasZoneClientResponseCodeT
IAS Zone Enroll Response Code
| ZCL_IAS_ZONE_CLI_RESP_SUCCESS | Success |
| ZCL_IAS_ZONE_CLI_RESP_NOT_SUPPORTED | Not supported |
| ZCL_IAS_ZONE_CLI_RESP_NO_ENROLL_PERMIT | No enroll permit |
| ZCL_IAS_ZONE_CLI_RESP_TOO_MANY_ZONES | Too many zones |
ZbZclIasZoneServerAttrT
IAS Zone Server Attribute IDs
| ZCL_IAS_ZONE_SVR_ATTR_ZONE_STATE | ZoneState |
| ZCL_IAS_ZONE_SVR_ATTR_ZONE_TYPE | ZoneType |
| ZCL_IAS_ZONE_SVR_ATTR_ZONE_STATUS | ZoneStatus |
| ZCL_IAS_ZONE_SVR_ATTR_CIE_ADDR | IAS_CIE_Address |
| ZCL_IAS_ZONE_SVR_ATTR_ZONE_ID | ZoneID |
| ZCL_IAS_ZONE_SVR_ATTR_NUM_ZONE_SENSITIVITY_SUP PORTED | NumberOfZoneSensitivityLevelsSupported (Optional) |
| ZCL_IAS_ZONE_SVR_ATTR_CURRENT_ZONE_SENSITIVITY_LEVEL | CurrentZoneSensitivityLevel (Optional) |
| ZCL_IAS_ZONE_SVR_ATTR_CIE_ENDPOINT | Exegin internal (Optional) |
ZbZclIasZoneServerModeT
IAS Zone ZoneStatus Attribute Bit Test Value
| ZCL_IAS_ZONE_SVR_MODE_NORMAL | Normal |
| ZCL_IAS_ZONE_SVR_MODE_TEST | Set |
ZbZclIasZoneServerZoneStateT
IAS Zone ZoneState Attribute
| ZCL_IAS_ZONE_SVR_STATE_NOT_ENROLLED | Not enrolled |
| ZCL_IAS_ZONE_SVR_STATE_ENROLLED | Enrolled (the client will react to Zone State Change Notification commands from the server) |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_NONE | Alarm1 |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_ALARM2 | Alarm2 |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_TAMPER | Tamper |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_BATTERY | Battery |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_SUPERVISION_REPO RTS | Supervision Notify |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_RESTORE_REPORTS | Restore Notify |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_TROUBLE | Trouble |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_AC_MAINS | AC (mains) |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_TEST | Test |
| ZCL_IAS_ZONE_SVR_ZONE_STATUS_BATTERY_DEFECT | Battery Defect |
IAS Zone ZoneType Attribute
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_STANDARD_CIE | Standard CIE |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_MOTION_SENSOR | Motion sensor |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_CONTACT_SWITCH | Contact switch |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_DOOR_WINDOW | Door/Window handle |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_FIRE_SENSOR | Fire sensor |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_WATER_SENSOR | Water sensor |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_CO_SENSOR | Carbon Monoxide (CO) sensor |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_PERSONAL_EMERG_D EVICE | Personal emergency device |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_MOVEMENT_SENSOR | Vibration/Movement sensor |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_REMOTE_CONTROL | Remote Control |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_KEY_FOB | Key fob |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_KEYPAD | Keypad |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_STANDARD_WARNING_ DEVICE | Standard Warning Device (see [N1] part 4) |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_GLASS_SENSOR | Glass break sensor |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_SECURITY_REPEATER | Security repeater |
| ZCL_IAS_ZONE_SVR_ZONE_TYPE_INVALID | Invalid Zone Type |
Structures
IAS Zone Client callbacks configuration
Parameters
| zone_status_change
void (*zone_status_change)( struct ZbZclClusterT *cluster, void *arg, struct ZbZclIasZoneServerStatusChangeNotifyT *notify, const struct ZbApsAddrT *src)
Callback to application, invoked on receipt of Zone Status Change Notification command |
| zone_enroll_req
enum ZclStatusCodeT (*zone_enroll_req)( struct ZbZclClusterT *cluster, void *arg, struct ZbZclIasZoneServerEnrollRequestT *req, uint64_t ext_src_addr, enum ZbZclIasZoneClientResponseCodeT *rsp_code, uint8_t *zone_id)
Callback to application, invoked on receipt of Zone Enroll command |
Zone Enroll response structure
Parameters
| enum ZclStatusCodeT zcl_status | Response status |
| enum ZbZclIasZoneClientResponseCodeT enroll_status | Enroll response code |
Parameters
| uint8_t test_duration | Test Mode Duration |
| uint8_t current_zone_sensitivity | Current Zone Sensitivity Level |
IAS Zone Server callbacks configuration
Parameters
| mode_change
enum ZclStatusCodeT (*mode_change)(struct ZbZclClusterT
Callback to application, invoked on receipt of Initiate Normal Operation Mode or Initiate Test Mode command |
Zone Enroll request structure
Parameters
zone_type |
Zone Type |
| uint16_t manuf_code | Manufacturer Code |
Zone State Change Notification request structure
Parameters
zone_status |
Zone Status |
| uint8_t ext_status | Extended Status |
| uint16_t delay | Delay |
6.4. Smart Energy Clusters
6.4.1. Calendar
#include "zcl/se/zcl.calendar.h"
Functions
ZbZclCalClientAlloc
struct ZbZclClusterT * ZbZclCalClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclCalClientCallbacksT *callbacks, void *arg);
Create a new instance of the Calendar client cluster
Parameters
Return
ZbZclCalClientCommandGetCalCancelReq
enum ZclStatusCodeT ZbZclCalClientCommandGetCalCancelReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Calendar Cancellation command
Parameters
Return
ZbZclCalClientCommandGetCalReq
enum ZclStatusCodeT ZbZclCalClientCommandGetCalReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalGetCalendarT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Calendar command
Parameters
| cmd_req | Get Calendar command request structure |
Return
ZbZclCalClientCommandGetDayProfilesReq
enum ZclStatusCodeT ZbZclCalClientCommandGetDayProfilesReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalGetDayProfilesT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Day Profiles command
Parameters
| cmd_req | Get Day Profiles command request structure |
Return
ZbZclCalClientCommandGetSeasonsReq
enum ZclStatusCodeT ZbZclCalClientCommandGetSeasonsReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalGetSeasonsT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Seasons command
Parameters
| cmd_req | Get Seasons command request structure |
Return
ZbZclCalClientCommandGetSpecialDaysReq
enum ZclStatusCodeT ZbZclCalClientCommandGetSpecialDaysReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalGetSpecialDaysT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Special Days command
Parameters
| cmd_req | Get Special Days command request structure |
Return
ZbZclCalClientCommandGetWeekProfilesReq
enum ZclStatusCodeT ZbZclCalClientCommandGetWeekProfilesReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalGetWeekProfilesT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Week Profile command
Parameters
| cmd_req | Get Week Profile command request structure |
Return
ZbZclCalParseCancelCalendar
bool ZbZclCalParseCancelCalendar(const uint8_t *buf, unsigned int len, struct ZbZclCalCancelCalendarT *rsp);
Parse a Cancel Calendar command
Parameters
| buf | Buffer containing response information |
| len | Length of response information in bytes |
| rsp | Cancel Calendar command structure |
Return
ZbZclCalParsePublishCalendar
bool ZbZclCalParsePublishCalendar(const uint8_t *buf, unsigned int len, struct ZbZclCalServerPublishCalendarT *rsp);
Parse a Publish Calendar command
Parameters
| rsp | Publish Calendar command structure |
Return
ZbZclCalParsePublishDayProfile
bool ZbZclCalParsePublishDayProfile(const uint8_t *buf, unsigned int len, struct ZbZclCalServerPublishDayProfileT *rsp);
Parse a Publish Day Profile command
Parameters
| rsp | Publish Day Profile command structure |
Return
ZbZclCalParsePublishSeasons
bool ZbZclCalParsePublishSeasons(const uint8_t *buf, unsigned int len, struct ZbZclCalPublishSeasonsT *rsp);
Parse a Publish Seasons command
Parameters
Return
ZbZclCalParsePublishSpecialDays
bool ZbZclCalParsePublishSpecialDays(const uint8_t *buf, unsigned int len, struct ZbZclCalPublishSpecialDaysT *rsp);
Parse a Publish Special Days command
Parameters
| rsp | Publish Special Days command structure |
Return
ZbZclCalParsePublishWeekProfile
bool ZbZclCalParsePublishWeekProfile(const uint8_t *buf, unsigned int len, struct ZbZclCalServerPublishWeekProfileT *rsp);
Parse a Publish Week Profile command
Parameters
| rsp | Publish Week Profile command structure |
Return
ZbZclCalServerAlloc
struct ZbZclClusterT * ZbZclCalServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclCalServerCallbacksT *callbacks, void *arg);
Create a new instance of the Calendar server cluster
Parameters
Return
ZbZclCalServerPublishCalendarRsp
enum ZclStatusCodeT ZbZclCalServerPublishCalendarRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclCalServerPublishCalendarT *info);
Send a Publish Calendar as a response
Parameters
| dstInfo | Destination address for response |
| info | Publish Calendar command structure |
Return
ZbZclCalServerPublishCalendarUnsolic
enum ZclStatusCodeT ZbZclCalServerPublishCalendarUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalServerPublishCalendarT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Publish Calendar as an unsolicited command
Parameters
| dst | Destination address for response |
| callback | Callback function that will be invoked when response is received, if one is expected. If broadcasting, then this should be set to NULL since no response is expected |
| arg | Pointer to application data that will later be provided back to the callback function when invoked |
Return
ZbZclCalServerPublishDayProfileRsp
enum ZclStatusCodeT ZbZclCalServerPublishDayProfileRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclCalServerPublishDayProfileT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Day Profile as a response
Parameters
| info | Publish Day Profile command structure |
| callback | Callback function for an APSDE-DATA.confirm |
Return
ZbZclCalServerPublishDayProfileUnsolic
enum ZclStatusCodeT ZbZclCalServerPublishDayProfileUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalServerPublishDayProfileT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Publish Day Profile as an unsolicited command
Parameters
Return
ZbZclCalServerPublishSeasonsRsp
enum ZclStatusCodeT ZbZclCalServerPublishSeasonsRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclCalPublishSeasonsT *info);
Send a Publish Seasons as a response
Parameters
| info | Publish Seasons command structure |
Return
ZbZclCalServerPublishSeasonsUnsolic
enum ZclStatusCodeT ZbZclCalServerPublishSeasonsUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalPublishSeasonsT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Publish Seasons as an unsolicited command
Parameters
Return
ZbZclCalServerPublishSpecialDaysRsp
enum ZclStatusCodeT ZbZclCalServerPublishSpecialDaysRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclCalPublishSpecialDaysT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Special Days as a response
Parameters
| info | Publish Special Days command structure |
Return
ZbZclCalServerPublishSpecialDaysUnsolic
enum ZclStatusCodeT ZbZclCalServerPublishSpecialDaysUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalPublishSpecialDaysT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Publish Special Days as an unsolicited command
Parameters
Return
- ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error
ZbZclCalServerPublishWeekProfileRsp
enum ZclStatusCodeT ZbZclCalServerPublishWeekProfileRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclCalServerPublishWeekProfileT *info);
Send a Publish Week Profile as a response
Parameters
| info | Publish Week Profile command structure |
Return
ZbZclCalServerPublishWeekProfileUnsolic
enum ZclStatusCodeT ZbZclCalServerPublishWeekProfileUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalServerPublishWeekProfileT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Publish Week Profile as an unsolicited command
Parameters
Return
ZbZclCalServerSendCancelCalendarRsp
enum ZclStatusCodeT ZbZclCalServerSendCancelCalendarRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclCalCancelCalendarT *info);
Send a Cancel Calendar as a response
Parameters
| info | Cancel Calendar command structure |
Return
ZbZclCalServerSendCancelCalendarUnsolic
enum ZclStatusCodeT ZbZclCalServerSendCancelCalendarUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclCalCancelCalendarT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Cancel Calendar as an unsolicited command
Parameters
Return
ZbZclCalendarMirrorAlloc
struct ZbZclClusterT * ZbZclCalendarMirrorAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *calendar_server, struct ZbZclClusterT *meter_mirror, struct ZbZclClusterT *meter_client);
Allocates a Calendar Client Mirror cluster.
Parameters
| calendar_server | Pointer to Calendar Server cluster. This is used by the Metering Mirror to send mirrored commands to the BOMD. |
| meter_mirror | Pointer to Metering Mirror cluster. This is used to queue any commands that need to be forwarded to the BOMD when it wakes up. |
| meter_client | Pointer to Metering Client cluster. This is used to know the existing notification scheme setup between BOMD & ESI and to determine if the command needs to be queued or only the notification flag needs to be set. |
Return
Enumerations
ZbZclCalSvrAttrT
Calendar Server Attribute IDs
| ZCL_CAL_SVR_ATTR_AuxSwitch1Label | AuxSwitch1Label (Optional) |
| ZCL_CAL_SVR_ATTR_AuxSwitch2Label | AuxSwitch2Label (Optional) |
| ZCL_CAL_SVR_ATTR_AuxSwitch3Label | AuxSwitch3Label (Optional) |
| ZCL_CAL_SVR_ATTR_AuxSwitch4Label | AuxSwitch4Label (Optional) |
| ZCL_CAL_SVR_ATTR_AuxSwitch5Label | AuxSwitch5Label (Optional) |
| ZCL_CAL_SVR_ATTR_AuxSwitch6Label | AuxSwitch6Label (Optional) |
| ZCL_CAL_SVR_ATTR_AuxSwitch7Label | AuxSwitch7Label (Optional) |
| ZCL_CAL_SVR_ATTR_AuxSwitch8Label | AuxSwitch8Label (Optional) |
Structures
Parameters
| uint32_t provider_id | Provider Id |
| uint32_t issuer_calendar_id | Issuer Calendar ID |
| enum ZbZclCalTypeT calendar_type | Calendar Type |
| bool to_bomd | If true, the timeout for this command is extended since it’s being sent to a BOMD (in One-Way Mirror). |
Calendar Client callbacks configuration
Parameters
| publish_calendar
enum ZclStatusCodeT (*publish_calendar)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalServerPublishCalendarT *notify, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Calendar command |
| publish_day_profile
enum ZclStatusCodeT (*publish_day_profile)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalServerPublishDayProfileT *notify, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Day Profile command |
| publish_week_profile
enum ZclStatusCodeT (*publish_week_profile)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalServerPublishWeekProfileT *notify, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Week Profile command |
| publish_seasons
enum ZclStatusCodeT (*publish_seasons)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalPublishSeasonsT *notify, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Seasons command |
| publish_special_days
enum ZclStatusCodeT (*publish_special_days)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalPublishSpecialDaysT *notify, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Special Days command |
| cancel_calendar
enum ZclStatusCodeT (*cancel_calendar)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalCancelCalendarT *notify, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Cancel Calendar command |
Get Calendar command structure
Parameters
| uint32_t earliest_start_time | Earliest Start Time |
| uint32_t min_issuer_event_id | Min. Issuer Even ID |
| uint8_t num_calendars | Number of Calendars |
Get Day Profiles command structure
Parameters
| uint8_t start_day_id | Start Day Id |
| uint8_t num_days | Number of Days |
ZbZclCalGetSeasonsT
Get Seasons command structure
Parameters
Get Special Days command structure
Parameters
| uint32_t start_time | Start Time |
| uint8_t num_events | Number of Events |
Get Week Profiles command structure
Parameters
| uint8_t start_week_id | Start Week Id |
| uint8_t num_weeks | Number of Weeks |
Parameters
| uint32_t issuer_event_id | Issuer Event ID |
| uint8_t command_index | Command Index |
| uint8_t num_commands | Total Number of Commands |
| struct ZbZclCalendarSeasonT entry_list | Season Entry |
| uint8_t num_entries | Number of Season Entries - maximum is 8, since ZCL_PAYLOAD_UNFRAG_SAFE_SIZE = 54 |
Parameters
| uint32_t start_time | Start Time - UTCTime |
| uint8_t total_days | Total Number of Special Days |
| struct ZbZclCalendarSpecialDayT
entry_list |
Special Day Entry |
| uint8_t num_entries | Number of Special Day Entries - maximum is 6, since ZCL_PAYLOAD_UNFRAG_SAFE_SIZE = 54 |
Calendar Server callbacks configuration
Parameters
| get_calendar
enum ZclStatusCodeT (*get_calendar)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalGetCalendarT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Calendar command. The ZCL Status return value is included in the Default Response. The application may call ZbZclCalServerPublishCalendarRsp to elicit a PublishCalendar command notification. |
| get_day_profiles
enum ZclStatusCodeT (*get_day_profiles)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalGetDayProfilesT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Day Profiles command. The ZCL Status return value is included in the Default Response. The application may call ZbZclCalServerPublishDayProfile to elicit a PublishDayProfile command notification. |
| get_week_profiles
enum ZclStatusCodeT (*get_week_profiles)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalGetWeekProfilesT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Week Profiles command. The ZCL Status return value is included in the Default Response. The application may call ZbZclCalServerPublishWeekProfile to elicit a PublishWeekProfile command notification. |
| get_seasons
enum ZclStatusCodeT (*get_seasons)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalGetSeasonsT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Seasons command. The ZCL Status return value is included in the Default Response. The application may call ZbZclCalServerPublishSeasons to elicit a PublishSeasons command notification. |
| get_special_days
enum ZclStatusCodeT (*get_special_days)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclCalGetSpecialDaysT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Special Days command. The ZCL Status return value is included in the Default Response. The application may call ZbZclCalServerPublishSpecialDays to elicit a PublishSpecialDays command notification. |
| get_calendar_cancellation
enum ZclStatusCodeT (*get_calendar_cancellation)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclAddrInfoT *srcInfo)
Parameters
| enum ZbZclCalTypeT calendar_type | Calendary Type |
| uint8_t calendar_time_ref | Calendar Time Reference |
| uint8_t calendar_name | Calendar Name (ZCL string char, first byte is length) |
| uint8_t num_seasons | Number of Seasons |
| uint8_t num_week_profiles | Number of Week Profiles |
| uint8_t num_day_profiles | Number of Day Profiles |
Parameters
| uint8_t day_id | Day ID |
| uint8_t total_entries | Total Number of Schedule Entries |
| struct ZbZclCalendarDayScheduleT
entry_list |
Day Schedule Entries |
| uint8_t num_entries | Number of Day Schedule Entries - maximum is 12, since ZCL_PAYLOAD_UNFRAG_SAFE_SIZE = 54 |
Parameters
| uint8_t week_id | Week ID |
| uint8_t day_id_ref_mon | Day ID Ref Monday |
| uint8_t day_id_ref_tue | Day ID Ref Tuesday |
| uint8_t day_id_ref_wed | Day ID Ref Wednesday |
| uint8_t day_id_ref_thu | Day ID Ref Thursday |
| uint8_t day_id_ref_fri | Day ID Ref Friday |
| uint8_t day_id_ref_sat | Day ID Ref Saturday |
| uint8_t day_id_ref_sun | Day ID Ref Sunday |
Day Schedule Entries structure
Parameters
| uint16_t start_time | Start Time |
| uint8_t value_u8 | Price Tier - if calendar type is 0x00 – 0x02. Friendly Credit Enable - if calendar type is 0x03. Auxiliary Load Switch State - if calendar type is 0x04. |
Season Entry structure
Parameters
| uint32_t start_date |
Parameters
| uint32_t specialDayDate |
6.4.2. Device Management
#include "zcl/se/zcl.device_mgmt.h"
Functions
ZbZclDeviceMgmtClientAlloc
struct ZbZclClusterT * ZbZclDeviceMgmtClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclDeviceMgmtClientCallbacksT *callbacks, void *arg);
Create a new instance of the Device Management Client cluster
Parameters
Return
ZbZclDeviceMgmtClientGetChangeSupplier
enum ZclStatusCodeT ZbZclDeviceMgmtClientGetChangeSupplier(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Change of Supplier command
Parameters
| dst | Destination address for request |
| arg | Pointer to application data that will be included in the callback when invoked. |
Return
ZbZclDeviceMgmtClientGetChangeTenancy
enum ZclStatusCodeT ZbZclDeviceMgmtClientGetChangeTenancy(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Change of Tenancy command
Parameters
Return
ZbZclDeviceMgmtClientGetCin
enum ZclStatusCodeT ZbZclDeviceMgmtClientGetCin(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get CIN command
Parameters
Return
ZbZclDeviceMgmtClientGetSiteId
enum ZclStatusCodeT ZbZclDeviceMgmtClientGetSiteId(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Site ID command
Parameters
Return
ZbZclDeviceMgmtClientReportEventConfig
enum ZclStatusCodeT ZbZclDeviceMgmtClientReportEventConfig(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDeviceMgmtReportEvtConfigT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Report Event Configuration command
Parameters
| info | Report Event Configuration command structure |
Return
ZbZclDeviceMgmtClientReqNewPassword
enum ZclStatusCodeT ZbZclDeviceMgmtClientReqNewPassword(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDeviceMgmtReqNewPassT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Request New Password command
Parameters
| info | Request New Password command structure |
Return
ZbZclDeviceMgmtMirrorAlloc
struct ZbZclClusterT * ZbZclDeviceMgmtMirrorAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *device_mgmt_server, struct ZbZclClusterT *meter_mirror);
Allocates a Device Management Client Mirror cluster. The caller (application) must attach any attributes to the cluster you want to mirror.
Parameters
| device_mgmt_server | Pointer to Device Mgmt Server cluster. This is used by the Metering Mirror to send mirrored commands to the BOMD. |
Return
ZbZclDeviceMgmtParseReportEvtConfig
enum ZclStatusCodeT ZbZclDeviceMgmtParseReportEvtConfig(struct ZbZclClusterT *cluster, struct ZbApsdeDataIndT *dataIndPtr, struct ZbZclDeviceMgmtReportEvtConfigT *info);
Parse a Report Event Configuration command
Parameters
| dataIndPtr | Data Indication structure containing the command payload to be parsed |
Return
ZbZclDeviceMgmtParseReqNewPassRsp
bool ZbZclDeviceMgmtParseReqNewPassRsp(const uint8_t *buf, unsigned int len, struct ZbZclDeviceMgmtReqNewPassRspT *rsp);
Parse a Request New Password Response command
Parameters
| rsp | Request New Password Response command structure |
Return
ZbZclDeviceMgmtParseUpdateCin
bool ZbZclDeviceMgmtParseUpdateCin(const uint8_t *buf, unsigned int len, struct ZbZclDeviceMgmtUpdateCinT *rsp);
Parse an Update CIN command
Parameters
| rsp | Update CIN command structure |
Return
ZbZclDeviceMgmtParseUpdateSiteId
bool ZbZclDeviceMgmtParseUpdateSiteId(const uint8_t *buf, unsigned int len, struct ZbZclDeviceMgmtUpdateSiteIdT *rsp);
Parse an Update Site ID command
Parameters
| rsp | Update Site ID command structure |
Return
ZbZclDeviceMgmtServerAlloc
struct ZbZclClusterT * ZbZclDeviceMgmtServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclDeviceMgmtServerCallbacksT *callbacks, void *arg);
Create a new instance of the Device Management Server cluster
Parameters
Return
ZbZclDeviceMgmtServerGetEventConfigReq
enum ZclStatusCodeT ZbZclDeviceMgmtServerGetEventConfigReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDeviceMgmtGetEventConfigT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Event Configuration command
Parameters
| info | Get Event Configuration command structure |
Return
ZbZclDeviceMgmtServerPublishChangeSupplierRsp
enum ZclStatusCodeT ZbZclDeviceMgmtServerPublishChangeSupplierRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDeviceMgmtPublishChangeSupplierT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Change of Supplier as a response to the Get Change of Supplier command.
Parameters
| dst | Destination address for response, including sequence number and tx options |
| info | Publish Change of Supplier command structure |
Return
ZbZclDeviceMgmtServerPublishChangeSupplierUnsolic
enum ZclStatusCodeT ZbZclDeviceMgmtServerPublishChangeSupplierUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDeviceMgmtPublishChangeSupplierT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Publish Change of Supplier as an unsolicited command
Parameters
Return
ZbZclDeviceMgmtServerPublishChangeTenancyRsp
enum ZclStatusCodeT ZbZclDeviceMgmtServerPublishChangeTenancyRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDeviceMgmtPublishChangeTenancyT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Change of Tenancy as a response to the Get Change of Tenancy command.
Parameters
| info | Publish Change of Tenancy command structure |
Return
ZbZclDeviceMgmtServerPublishChangeTenancyUnsolic
enum ZclStatusCodeT ZbZclDeviceMgmtServerPublishChangeTenancyUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDeviceMgmtPublishChangeTenancyT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Publish Change of Tenancy as an unsolicited command
Parameters
Return
ZbZclDeviceMgmtServerReqNewPassRsp
enum ZclStatusCodeT ZbZclDeviceMgmtServerReqNewPassRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDeviceMgmtReqNewPassRspT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Request New Password Response as a response to the Request New Password command.
Parameters
| info | Request New Password Response command structure |
Return
ZbZclDeviceMgmtServerReqNewPassRspUnsolic
enum ZclStatusCodeT ZbZclDeviceMgmtServerReqNewPassRspUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDeviceMgmtReqNewPassRspT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Request New Password Response as an unsolicited command
Parameters
Return
ZbZclDeviceMgmtServerSetEventConfigReq
enum ZclStatusCodeT ZbZclDeviceMgmtServerSetEventConfigReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDeviceMgmtSetEventConfigT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Event Configuration command
Parameters
| info | Set Event Configuration command structure |
Return
ZbZclDeviceMgmtServerUpdateCinRsp
enum ZclStatusCodeT ZbZclDeviceMgmtServerUpdateCinRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDeviceMgmtUpdateCinT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send an Update CIN as a response to the Get CIN command.
Parameters
| info | Update CIN command structure |
Return
ZbZclDeviceMgmtServerUpdateCinUnsolic
enum ZclStatusCodeT ZbZclDeviceMgmtServerUpdateCinUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDeviceMgmtUpdateCinT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Update CIN as an unsolicited command
Parameters
Return
ZbZclDeviceMgmtServerUpdateSiteIdRsp
enum ZclStatusCodeT ZbZclDeviceMgmtServerUpdateSiteIdRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDeviceMgmtUpdateSiteIdT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send an Update SiteID as a response to the Get SiteID command.
Parameters
| info | Update SiteID command structure |
Return
ZbZclDeviceMgmtServerUpdateSiteIdUnsolic
enum ZclStatusCodeT ZbZclDeviceMgmtServerUpdateSiteIdUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDeviceMgmtUpdateSiteIdT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Update SiteID as an unsolicited command
Parameters
Return
Enumerations
ZbZclDeviceMgmtCliAttrT
Device Management Client Attribute IDs
| ZCL_DEVICE_MGMT_CLI_ATTR_ProviderID | Provider ID |
| ZCL_DEVICE_MGMT_CLI_ATTR_ReceivedProviderID | ReceivedProvider ID |
| ZCL_DEVICE_MGMT_CLI_ATTR_PRICE_START | Price Event Configuration Attribute Set (First Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_TOUTariffActivation | TOUTariffActivation |
| ZCL_DEVICE_MGMT_CLI_ATTR_BlockTariffactivated | BlockTariffactivated |
| ZCL_DEVICE_MGMT_CLI_ATTR_BlockTOUTariffActivated | BlockTOUTariffActivated |
| ZCL_DEVICE_MGMT_CLI_ATTR_SingleTariffRateActivated | SingleTariffRateActivated |
| ZCL_DEVICE_MGMT_CLI_ATTR_AsychronousBillingOccurred | AsychronousBillingOccurred |
| ZCL_DEVICE_MGMT_CLI_ATTR_SynchronousBillingOccurred | SynchronousBillingOccurred |
| ZCL_DEVICE_MGMT_CLI_ATTR_TariffNotSupported | Tariff NotSupported |
| ZCL_DEVICE_MGMT_CLI_ATTR_PriceClusterNotFound | PriceClusterNotFound |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishPriceReceived | PublishPriceReceived |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishPriceActioned | PublishPriceActioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishPriceCancelled | PublishPriceCancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishPriceRejected | PublishPriceRejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishTariffInformation | PublishTariffInformation Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishTariffInformationActio ned | PublishTariffInformation Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishTariffInformationCanc elled | PublishTariffInformation Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishTariffInformationReje cted | PublishTariffInformation Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishPriceMatrixReceived | PublishPriceMatrixReceived |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishPriceMatrixActioned | PublishPriceMatrixActioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishPriceMatrixCancelled | PublishPriceMatrixCancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishPriceMatrixRejected | PublishPriceMatrixRejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishBlockThresholdsRece ived | PublishBlockThresholdsReceived |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishBlockThresholdsActio ned | PublishBlockThresholdsActioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishBlockThresholdsCanc elled | PublishBlockThresholdsCancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishBlockThresholdsReje cted | PublishBlockThresholdsRejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PRICE_GROUP_ID | Price cluster Group ID (Last Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_METERING_START | Metering Event Configuration Attribute Set (First Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_CheckMeter | Check Meter |
| ZCL_DEVICE_MGMT_CLI_ATTR_LowBattery | Low Battery |
| ZCL_DEVICE_MGMT_CLI_ATTR_TamperDetect | Tamper Detect |
| ZCL_DEVICE_MGMT_CLI_ATTR_SupplyStatus | Supply Status |
| ZCL_DEVICE_MGMT_CLI_ATTR_SupplyQuality | Supply Quality |
| ZCL_DEVICE_MGMT_CLI_ATTR_LeakDetect | Leak Detect |
| ZCL_DEVICE_MGMT_CLI_ATTR_BatteryFailure | BatteryFailure |
| ZCL_DEVICE_MGMT_CLI_ATTR_LowVoltageL1 | LowVoltageL1 |
| ZCL_DEVICE_MGMT_CLI_ATTR_HighVoltageL1 | HighVoltageL1 |
| ZCL_DEVICE_MGMT_CLI_ATTR_UnderVoltage | UnderVoltage |
| ZCL_DEVICE_MGMT_CLI_ATTR_OverVoltage | OverVoltage |
| ZCL_DEVICE_MGMT_CLI_ATTR_PressureTooLow | PressureTooLow |
| ZCL_DEVICE_MGMT_CLI_ATTR_PressureTooHigh | PressureTooHigh |
| ZCL_DEVICE_MGMT_CLI_ATTR_GetProfileCommandReceive d | Get Profile Command Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_GetProfileCommandActioned | Get Profile Command Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_GetProfileCommandCancelle d | Get Profile Command Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_GetProfileCommandRejected | Get Profile Command Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_RequestMirrorResponseCom mandReceived | RequestMirrorResponse Command Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_RequestMirrorResponseCom mandActioned | RequestMirrorResponse Command Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_RequestMirrorResponseCom mandCancelled | RequestMirrorResponse Command Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_RequestMirrorResponseCom mandRejected | RequestMirrorResponse Command Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_MirrorRemoved0CommandR eceived | MirrorRemoved Command Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_MirrorRemoved0CommandA ctioned | MirrorRemoved Command Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_MirrorRemoved0CommandC ancelled | MirrorRemoved Command Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_MirrorRemoved0CommandR ejected | MirrorRemoved Command Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_GetSampledDataCommandR eceived | GetSampledData Command Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_GetSampledDataCommandA ctioned | GetSampledData Command Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_GetSampledDataCommandC ancelled | GetSampledData Command Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_GetSampledDataCommandR ejected | GetSampledData Command Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_SupplyON | Supply ON |
| ZCL_DEVICE_MGMT_CLI_ATTR_SupplyARMED | Supply ARMED |
| ZCL_DEVICE_MGMT_CLI_ATTR_SupplyOFF | Supply OFF |
| ZCL_DEVICE_MGMT_CLI_ATTR_METERING_GROUP_ID | Metering cluster Group ID (Last Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_MESSAGING_START | Messaging Event Configuration Attribute Set (First Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_MessageConfirmationSent | Message Confirmation Sent |
| ZCL_DEVICE_MGMT_CLI_ATTR_DisplayMessageReceived | DisplayMessageReceived |
| ZCL_DEVICE_MGMT_CLI_ATTR_DisplayMessageActioned | DisplayMessageActioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_DisplayMessageCancelled | DisplayMessageCancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_DisplayMessageRejected | DisplayMessageRejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_CancelMessageReceived | CancelMessageReceived |
| ZCL_DEVICE_MGMT_CLI_ATTR_CancelMessageActioned | CancelMessageActioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_CancelMessageCancelled | CancelMessageCancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_CancelMessageRejected | CancelMessageRejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_MESSAGING_GROUP_ID | Messaging cluster Group ID (Last Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_PREPAYMENT_START | Prepayment Event Configuration Attribute Set (First Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_LowCredit | Low Credit |
| ZCL_DEVICE_MGMT_CLI_ATTR_NoCredit | No Credit (Zero Credit) |
| ZCL_DEVICE_MGMT_CLI_ATTR_CreditExhausted | Credit Exhausted |
| ZCL_DEVICE_MGMT_CLI_ATTR_EmergencyCreditEnabled | Emergency Credit Enabled |
| ZCL_DEVICE_MGMT_CLI_ATTR_EmergencyCreditExhausted | Emergency Credit Exhausted |
| ZCL_DEVICE_MGMT_CLI_ATTR_CreditAdjustment | Credit Adjustment |
| ZCL_DEVICE_MGMT_CLI_ATTR_CreditAdjustFail | Credit Adjust Fail |
| ZCL_DEVICE_MGMT_CLI_ATTR_PrepayClusterNotFound | Prepay Cluster Not Found |
| ZCL_DEVICE_MGMT_CLI_ATTR_SelectAvailableEmergencyCr editReceived | SelectAvailableEmergencyCredit Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_SelectAvailableEmergencyCr editActioned | SelectAvailableEmergencyCredit Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_SelectAvailableEmergencyCr editCancelled | SelectAvailableEmergencyCredit Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_SelectAvailableEmergencyCr editRejected | SelectAvailableEmergencyCredit Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_EmergencyCreditSetupRecei ved | Emergency Credit Setup Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_EmergencyCreditSetupActio ned | Emergency Credit Setup Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_EmergencyCreditSetupCanc elled | Emergency Credit Setup Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_EmergencyCreditSetupRejec ted | Emergency Credit Setup Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_CreditAdjustmentReceived | Credit Adjustment Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_CreditAdjustmentActioned | Credit Adjustment Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_CreditAdjustmentCancelled | Credit Adjustment Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_CreditAdjustmentRejected | Credit Adjustment Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetLowCreditWarningLevelR eceived | Set Low Credit Warning Level Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetLowCreditWarningLevelA ctioned | Set Low Credit Warning Level Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetLowCreditWarningLevelC ancelled | Set Low Credit Warning Level Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetLowCreditWarningLevelR ejected | Set Low Credit Warning Level Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetMaximumCreditLimitRece ived | SetMaximumCreditLimit Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetMaximumCreditLimitActio ned | SetMaximumCreditLimit Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetMaximumCreditLimitCanc elled | SetMaximumCreditLimit Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetMaximumCreditLimitReje cted | SetMaximumCreditLimit Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PREPAYMENT_GROUP_ID | Prepayment cluster Group ID (Last Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_CALENDAR_START | Calendar Event Configuration Attribute Set (First Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_CalendarClusterNotFound | Calendar Cluster Not Found |
| ZCL_DEVICE_MGMT_CLI_ATTR_CalendarChangePassiveActi vated | Calendar Change Passive Activated |
| ZCL_DEVICE_MGMT_CLI_ATTR_CalendarChangePassiveUpd ated | Calendar Change Passive Updated |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCalendarReceived | PublishCalendar Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCalendarActioned | PublishCalendar Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCalendarCancelled | PublishCalendar Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCalendarRejected | PublishCalendar Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishDayProfileReceived | Publish Day Profile Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishDayProfileActioned | Publish Day Profile Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishDayProfileCancelled | Publish Day Profile Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishDayProfileRejected | Publish Day Profile Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishWeekProfileReceived | Publish Week Profile Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishWeekProfileActioned | Publish Week Profile Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishWeekProfileCancelled | Publish Week Profile Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishWeekProfileRejected | Publish Week Profile Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishSeasonsReceived | Publish Seasons Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishSeasonsActioned | Publish Seasons Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishSeasonsCancelled | Publish Seasons Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishSeasonsRejected | Publish Seasons Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishSpecialDaysReceived | Publish Special Days Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishSpecialDaysActioned | Publish Special Days Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishSpecialDaysCancelle d | Publish Special Days Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishSpecialDaysRejected | Publish Special Days Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_CALENDAR_GROUP_ID | Calendar cluster Group ID (Last Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_DEVICE_MGMT_START | Device Management Event Configuration Attribute Set (First Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_Password1Change | Password1Change |
| ZCL_DEVICE_MGMT_CLI_ATTR_EventLogCleared | EventLogCleared |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCoTReceived | Publish CoT Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCoTActioned | Publish CoT Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCoTCancelled | Publish CoT Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCoTRejected | Publish CoT Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCoSReceived | Publish CoS Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCoSActioned | Publish CoS Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCoSCancelled | Publish CoS Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCoSRejected | Publish CoS Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_ChangePasswordReceived | Change Password Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_ChangepasswordActioned | Change password Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_ChangePasswordCancelled | Change Password Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_ChangePasswordRejected | Change Password Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetEventConfigurationRecei ved | SetEventConfiguration Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetEventConfigurationAction ed | SetEventConfiguration Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetEventConfigurationCance lled | SetEventConfiguration Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetEventConfigurationReject ed | SetEventConfiguration Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpdateSiteIDReceived | UpdateSiteID Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpdateSiteIDActioned | UpdateSiteID Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpdateSiteIDCancelled | UpdateSiteID Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpdateSiteIDRejected | UpdateSiteID Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpdateCINReceived | UpdateCIN Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpdateCINActioned | UpdateCIN Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpdateCINCancelled | UpdateCIN Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpdateCINRejected | UpdateCIN Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_DEVICE_MGMT_GROUP_ID | Device Management cluster Group ID (Last Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_TUNNEL_START | Tunnel Event Configuration Attribute Set (First Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_TunnelingClusterNotFound | Tunneling Cluster Not Found |
| ZCL_DEVICE_MGMT_CLI_ATTR_RequestTunnelCommandRe ceived | RequestTunnel Command Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_RequestTunnelCommandRej ected | RequestTunnel Command Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_RequestTunnelCommandGe nerated | RequestTunnel Command Generated |
| ZCL_DEVICE_MGMT_CLI_ATTR_CloseTunnelCommandRecei ved | CloseTunnel Command Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_CloseTunnelCommandRejec ted | CloseTunnel Command Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_CloseTunnelCommandGener ated | CloseTunnel Command Generated |
| ZCL_DEVICE_MGMT_CLI_ATTR_TransferDataCommandRecei ved | TransferData Command Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_TransferDataCommandRejec ted | TransferData Command Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_TransferDataCommandGene rated | TransferData Command Generated |
| ZCL_DEVICE_MGMT_CLI_ATTR_TransferDataErrorCommand Received | TransferDataError Command Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_TransferDataErrorCommand Rejected | TransferDataError Command Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_TransferDataErrorCommand Generated | TransferDataError Command Generated |
| ZCL_DEVICE_MGMT_CLI_ATTR_TUNNEL_GROUP_ID | Tunnel cluster Group ID (Last Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_OTA_START | OTA Event Configuration Attribute Set (First Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_FirmwareReadyForActivation | FirmwareReadyForActivation |
| ZCL_DEVICE_MGMT_CLI_ATTR_FirmwareActivated | FirmwareActivated |
| ZCL_DEVICE_MGMT_CLI_ATTR_FirmwareActivationFailure | Firmware Activation Failure |
| ZCL_DEVICE_MGMT_CLI_ATTR_PatchReadyForActivation | Patch Ready For Activation |
| ZCL_DEVICE_MGMT_CLI_ATTR_PatchActivated | Patch Activated |
| ZCL_DEVICE_MGMT_CLI_ATTR_PatchFailure | Patch Failure |
| ZCL_DEVICE_MGMT_CLI_ATTR_ImageNotifyCommandReceiv ed | Image Notify Command Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_ImageNotifyCommandReject ed | Image Notify Command Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_QueryNextImageRequestGe nerated | Query Next Image Request Generated |
| ZCL_DEVICE_MGMT_CLI_ATTR_QueryNextImageResponseR eceived | Query Next Image Response Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_QueryNextImageResponseR ejected | Query Next Image Response Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_ImageBlockRequestGenerat ed | Image Block Request Generated |
| ZCL_DEVICE_MGMT_CLI_ATTR_ImagePageRequestGenerate d | Image Page Request Generated |
| ZCL_DEVICE_MGMT_CLI_ATTR_ImageBlockResponseReceiv ed | Image Block Response Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_ImageBlockResponseReject ed | Image Block Response Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpgradeEndRequestGenerat ed | Upgrade End Request Generated |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpgradeEndResponseRecei ved | Upgrade End Response Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpgradeEndResponseReject ed | Upgrade End Response Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_QuerySpecificFileRequestGe nerated | Query Specific File Request Generated |
| ZCL_DEVICE_MGMT_CLI_ATTR_QuerySpecificFileResponse Received | Query Specific File Response Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_QuerySpecificFileResponse Rejected | Query Specific File Response Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_OTA_GROUP_ID | OTA cluster Group ID (Last Id) |
ZbZclDeviceMgmtSvrAttrT
Device Management Server Attribute IDs
| ZCL_DEVICE_MGMT_SVR_ATTR_ProviderID | ProviderID (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ProviderName | ProviderName (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ProviderContactDetails | ProviderContactDetails (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ProposedProviderID | ProposedProviderID (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ProposedProviderName | ProposedProviderName (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ProposedProviderChangeD ate | ProposedProviderChangeDate/Time (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ProposedProviderChangeC ontrol | ProposedProviderChangeControl (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ProposedProviderContactD etails | ProposedProviderContactDetails (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ReceivedProviderID | ReceivedProviderID (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ReceivedProviderName | ReceivedProviderName (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ReceivedProviderContactD etails | ReceivedProviderContactDetails (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ReceivedProposedProviderI D | ReceivedProposedProviderID (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ReceivedProposedProvider Name | ReceivedProposedProviderName (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ReceivedProposedProvider ChangeDate | ReceivedProposedProviderChangeDate/Time (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ReceivedProposedProvider ChangeControl | ReceivedProposedProviderChangeControl (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ReceivedProposedProvider ContactDetails | ReceivedProposedProviderContactDetails (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ChangeofTenancyUpdateD ate | ChangeofTenancyUpdateDate/Time (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ProposedTenancyChangeC ontrol | ProposedTenancyChangeControl (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_WANStatus | WAN Status (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_LowMediumThreshold | LowMediumThreshold (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_MediumHighThreshold | MediumHighThreshold (Optional) |
Structures
Device Management Client callbacks configuration
Parameters
| publish_change_tenancy
enum ZclStatusCodeT (*publish_change_tenancy)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclDeviceMgmtPublishChangeTenancyT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'Publish Change Tenancy' command. The return code (e.g. ZCL_STATUS_SUCCESS) is included in the standard Default Response. |
| publish_change_supplier
enum ZclStatusCodeT (*publish_change_supplier)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclDeviceMgmtPublishChangeSupplierT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'Publish Change Supplier' command. The return code (e.g. ZCL_STATUS_SUCCESS) is included in the standard Default Response. |
| req_new_pass_rsp_unsolic
enum ZclStatusCodeT (*req_new_pass_rsp_unsolic)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclDeviceMgmtReqNewPassRspT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of an unsolicited 'Request New Password Response' command. The return code (e.g. ZCL_STATUS_SUCCESS) is included in the standard Default Response. |
| update_site_id
enum ZclStatusCodeT (*update_site_id)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclDeviceMgmtUpdateSiteIdT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'Update SiteID' command. The return code (e.g. ZCL_STATUS_SUCCESS) is included in the standard Default Response. |
| set_event_config
enum ZclStatusCodeT (*set_event_config)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclDeviceMgmtSetEventConfigT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'Set Event Configuration' command. The return code (e.g. ZCL_STATUS_SUCCESS) is included in the standard Default Response. |
| get_event_config
enum ZclStatusCodeT (*get_event_config)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclDeviceMgmtGetEventConfigT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'Get Event Configuration' command. The return code (e.g. ZCL_STATUS_SUCCESS) is included in the standard Default Response. |
| update_cin
enum ZclStatusCodeT (*update_cin)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclDeviceMgmtUpdateCinT *info, struct ZbZclAddrInfoT *srcInfo)
ZbZclDeviceMgmtEventConfigPayloadT
Event Configuration Payload structure
Parameters
| uint16_t event_id | Event ID |
| uint8_t event_config | Event Configuration |
Parameters
| bool to_bomd | If true, the timeout for this command is extended since it’s being sent to a BOMD via a Mirror device. |
Parameters
| uint32_t curr_provider_id | Current Provider ID |
| uint8_t tariff_type | Tariff Type |
| uint32_t proposed_provider_id | Proposed Provider ID |
| uint32_t provider_change_impl_time | Provider Change Implementation Time |
| uint32_t provider_change_ctrl | Provider Change Control |
| uint8_t proposed_provider_name | Proposed Provider Name |
| uint8_t proposed_provider_contact | Proposed Provider Contact Details |
Parameters
| uint32_t provider_id | Provider ID |
| uint32_t issuer_id | Issuer Event ID |
| uint32_t implement_time | Implementation Date/Time |
| uint32_t prop_tenancy_change_ctrl | Proposed Tenancy Change Control |
Parameters
| uint8_t total_commands | Total Commands |
| struct ZbZclDeviceMgmtEventConfigPayloadT event_config_payload | Event Configuration Payload |
| uint8_t num_entries | Number of Payload Entries |
Parameters
| uint16_t duration | Duration |
| uint8_t password_type | Password Type |
| uint8_t password | Password |
Parameters
Device Management Server callbacks configuration
Parameters
| get_change_tenancy
enum ZclStatusCodeT (*get_change_tenancy)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'Get Change of Tenancy' command. The ESI may send a PublishChangeofTenancy command (ZbZclDeviceMgmtServerPublishChangeTenancy). Return ZCL_STATUS_SUCCESS if PublishChangeofTenancy was sent, or ZCL_STATUS_NOT_FOUND otherwise. |
| get_change_supplier
enum ZclStatusCodeT (*get_change_supplier)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'Get Change of Supplier' command. The ESI may send a PublishChangeofSupplier command (ZbZclDeviceMgmtServerPublishChangeSupplier). Return ZCL_STATUS_SUCCESS if PublishChangeofSupplier was sent, or ZCL_STATUS_NOT_FOUND otherwise. |
| request_new_pass
enum ZclStatusCodeT (*request_new_pass)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclDeviceMgmtReqNewPassT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'Request New Password' command. The ESI may send a RequestNewPasswordResponse command (ZbZclDeviceMgmtServerReqNewPassRsp). Return ZCL_STATUS_SUCCESS if RequestNewPasswordResponse was sent, or ZCL_STATUS_NOT_FOUND otherwise. |
| get_site_id
(callback function pointer) |
enum ZclStatusCodeT (*get_site_id)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'GetSiteID' command. The ESI may send a UpdateSiteID command (ZbZclDeviceMgmtServerUpdateSiteId). Return ZCL_STATUS_SUCCESS if UpdateSiteID was sent, or ZCL_STATUS_NOT_FOUND otherwise. |
| get_cin
enum ZclStatusCodeT (*get_cin)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'GetCIN' command. The ESI may send a UpdateCIN command (ZbZclDeviceMgmtServerUpdateCin). Return ZCL_STATUS_SUCCESS if UpdateCIN was sent, or ZCL_STATUS_NOT_FOUND otherwise. |
Set Event command structure
Parameters
| uint32_t start_time | Start Date/Time |
| enum ZbZclDeviceMgmtEventConfigCtrl
config_ctrl |
Configuration Control |
| union { struct { uint8_t num_events | Number of Events |
| uint16_t event_id_list | Event IDs |
| struct { uint16_t group_id | Event Group ID |
| struct { uint8_t log_id | Log ID |
| struct { uint8_t config_match | Configuration Value Match |
Update CIN Configuration command structure
Parameters
| uint32_t cin_implement_time | CIN Implementation Time |
| uint8_t customer_id | CustomerID Number |
Parameters
| uint32_t site_id_time | SiteID Time |
| uint8_t site_id | Site ID |
6.4.3. Demand Response and Load Control
#include "zcl/se/zcl.drlc.h"
Functions
ZbZclDrlcClientAlloc
struct ZbZclClusterT * ZbZclDrlcClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *time_server, struct ZbZclDrlcClientCallbacksT *callbacks, void *cb_arg);
Create a new instance of the DRLC Client cluster
Parameters
| zb | Zigbee stack instance |
| endpoint | Endpoint on which to create cluster |
| time_server | Time server cluster instance used to retrieve timing information of events |
| cb_arg | Pointer to application data that will included in the callback when invoked. |
Return
- Cluster pointer, or NULL if there is an error
ZbZclDrlcClientCommandGetEventsReq
enum ZclStatusCodeT ZbZclDrlcClientCommandGetEventsReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDrlcGetEventsReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Get Scheduled Events
Parameters
| cluster | Cluster instance from which to send this command |
| cmd_req | Get Scheduled Events command request structure |
| callback | Callback function that will be invoked when the response is received. |
Return
ZbZclDrlcClientCommandReportStatusReq
enum ZclStatusCodeT ZbZclDrlcClientCommandReportStatusReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDrlcStatusT *statusPtr, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Report Event Status Command
Parameters
| statusPtr | Report Event Status command request structure |
Return
ZbZclDrlcClientGetEventList
unsigned int ZbZclDrlcClientGetEventList(struct ZbZclClusterT *cluster, struct ZbZclDrlcEventT *eventList, unsigned int maxEntries);
Send a Get Event List command
Parameters
| eventList | Holds a pointer to the event list if successful |
| maxEntries | Max event list entries |
Return
- Event list size if successful, or 0 on error
ZbZclDrlcClientOptOutAdd
enum ZclStatusCodeT ZbZclDrlcClientOptOutAdd(struct ZbZclClusterT *cluster, uint32_t issuer_id);
Append an Issuer Event ID to "opt-out" of
Parameters
| eventList | Holds a pointer to the opt-outs list if successful |
Return
ZbZclDrlcClientOptOutClear
enum ZclStatusCodeT ZbZclDrlcClientOptOutClear(struct ZbZclClusterT *cluster);
Clear all Issuer Event IDs in list to "opt-out" of
Parameters
Return
ZbZclDrlcClientOptOutDel
enum ZclStatusCodeT ZbZclDrlcClientOptOutDel(struct ZbZclClusterT *cluster, uint32_t issuer_id);
Invalidate an Issuer Event ID to "opt-out" of
Parameters
Return
ZbZclDrlcServerAlloc
struct ZbZclClusterT * ZbZclDrlcServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclDrlcServerCallbacksT *callbacks, void *arg);
Create a new instance of the DRLC Server cluster
Parameters
Return
ZbZclDrlcServerCommandCancelAllReq
enum ZclStatusCodeT ZbZclDrlcServerCommandCancelAllReq(struct ZbZclClusterT *cluster, uint8_t ctrl, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Cancel All Load Control Event command
Parameters
| ctrl | Cancel control bitmap, used to determine method of cancellation - e.g. ZCL_DRLC_CANCEL_CONTROL_GRACEFUL |
Return
ZbZclDrlcServerCommandCancelReq
enum ZclStatusCodeT ZbZclDrlcServerCommandCancelReq(struct ZbZclClusterT *cluster, struct ZbZclDrlcCancelT *cancelInfoPtr, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Cancel Load Control Event command
Parameters
| eventPtr | Cancel Load Control Event command request structure |
Return
ZbZclDrlcServerCommandEventReq
enum ZclStatusCodeT ZbZclDrlcServerCommandEventReq(struct ZbZclClusterT *cluster, struct ZbZclDrlcEventT *eventPtr, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Load Control Event command
Parameters
| eventPtr | Load Control Event command request structure |
Return
Enumerations
ZbZclDrlcCliAttrT
DRLC Client Attribute IDs
| ZCL_DRLC_CLI_ATTR_UTILITY_ENROL_GRP | UtilityEnrollmentGroup |
| ZCL_DRLC_CLI_ATTR_START_RAND_MINS | StartRandomizationMinutes |
| ZCL_DRLC_CLI_ATTR_DURATION_RAND_MINS | DurationRandomizationMinutes |
| ZCL_DRLC_CLI_ATTR_DEVICE_CLASS | DeviceClassValue |
Structures
ZbZclDrlcCancelT
Cancel Load Control Event command structure
Parameters
| uint16_t device_class | Device Class |
| uint8_t util_enrol_group | Utility Enrollment Group |
| uint8_t cancel_control | Cancel Control - e.g. ZCL_DRLC_CANCEL_CONTROL_GRACEFUL |
DRLC Client callbacks configuration
Parameters
| start
bool (*start)(void *arg, struct ZbZclDrlcEventT *event)
Callback to application, invoked on the start of an event |
| stop
void (*stop)(void *arg, struct ZbZclDrlcEventT *event)
Callback to application, invoked on the end of an event |
ZbZclDrlcEventT
Parameters
| uint8_t util_enrol_group | Utility Entrollment Group |
| uint32_t start_time | Start Time - UTC, or 0 = now |
| uint16_t duration | Duration in Minutes |
| enum ZbZclDrlcCriticalityLevelT criticality | Criticality Level |
| uint8_t cool_offset | Cooling Temperature Offset (Optional) |
| uint8_t heat_offset | Heating Temperature Offset (Optional) |
| int16_t cool_setpoint | Cooling Temperature Set Point (Optional) |
| int16_t heat_setpoint | Heating Temperature Set Point (Optional) |
| int8_t avg_load_adj | Average Load Adjustment Percentage (Optional) |
| uint8_t dutycycle | Duty Cycle (Optional) |
| uint8_t event_control | Event Control - e.g. ZCL_DRLC_EVENT_CTRL_RAND_START |
Get Scheduled Events command structure
Parameters
| uint32_t earliest_end_time | Earliest End Time |
DRLC Server callbacks configuration
Parameters
| report_status
void (*report_status)(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *srcInfo, struct ZbZclDrlcStatusT *status, void *arg)
Callback to application, invoked on receipt of Report Event Status command |
| get_events
enum ZclStatusCodeT (*get_events)(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *srcInfo, struct ZbZclDrlcGetEventsReqT *req, void *arg)
Callback to application, invoked on receipt of Get Scheduled Events command. The get_events callback handler in the application should return ZCL_STATUS_SUCCESS, or ZCL_STATUS_NOT_FOUND if no events are found.Events are re-issued by calling ZbZclDrlcServerCommandEventReq() |
ZbZclDrlcStatusT
Report Event Status command structure
Parameters
| enum ZbZclDrlcEventStatusT status | Event Status |
| uint32_t status_time | Event Status Time |
crit_level_applied |
Criticality Level Applied |
| uint16_t cool_setpoint_applied | Cooling Temperature Set Point Applied (Optional). Set to ZCL_DRLC_COOL_SETPOINT_IGNORED if not used |
| uint16_t heat_setpoint_applied | Heating Temperature Set Point Applied (Optional). Set to ZCL_DRLC_HEAT_SETPOINT_IGNORED if not used |
| int8_t avg_load_adj_applied | Average Load Adjustment Percentage Applied (Optional). Set to ZCL_DRLC_AVG_LOAD_ADJ_IGNORED if not used |
| uint8_t dutycycle_applied | Duty Cycle Applied (Optional). Set to ZCL_DRLC_DUTYCYCLE_IGNORED if not used |
| uint8_t event_control | Event Control |
| enum ZbZclDrlcSignatureT sig_type | Signature Type |
| uint8_t sig_data | Signature (Optional) |
6.4.4. Energy Management
#include "zcl/se/zcl.energy_mgmt.h"
Functions
ZbZclEnergyMgmtClientAlloc
struct ZbZclClusterT * ZbZclEnergyMgmtClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Energy Management Client cluster
Parameters
Return
ZbZclEnergyMgmtClientManageEventReq
enum ZclStatusCodeT ZbZclEnergyMgmtClientManageEventReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclEnergyMgmtManageEventT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Manage Event command
Parameters
| info | Manage Event command request structure |
Return
ZbZclEnergyMgmtServerAlloc
struct ZbZclClusterT * ZbZclEnergyMgmtServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclEnergyMgmtServerCallbacksT *callbacks, void *arg);
Create a new instance of the Energy Management Server cluster
Parameters
| callbacks | Structure containing any callback function pointers for this cluster |
Return
ZbZclEnergyMgmtServerReportEvtStatus
enum ZclStatusCodeT ZbZclEnergyMgmtServerReportEvtStatus(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDrlcStatusT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Parameters
| cluster | |
| dst | |
| info | |
| callback | |
| arg |
Return
- Undocumented
Enumerations
ZbZclEnergyMgmtSvrAttrT
Energy Management Server Attribute IDs
| ZCL_ENERGY_MGMT_SVR_ATTR_LOAD_CONTROL_STATE | LoadControlState |
| ZCL_ENERGY_MGMT_SVR_ATTR_CURR_EVENT_ID | CurrentEventID |
| ZCL_ENERGY_MGMT_SVR_ATTR_CURR_EVENT_STATUS | CurrentEventStatus |
| ZCL_ENERGY_MGMT_SVR_ATTR_CONFORMANCE_LEVEL | ConformanceLevel |
| ZCL_ENERGY_MGMT_SVR_ATTR_MIN_OFF_TIME | MinimumOffTime |
| ZCL_ENERGY_MGMT_SVR_ATTR_MIN_ON_TIME | MinimumOnTime |
| ZCL_ENERGY_MGMT_SVR_ATTR_MIN_CYCLE_PERIOD | MinimumCyclePeriod |
Structures
Manage Event (ZCL_ENERGY_MGMT_CLI_CMD_MANAGE_EVENT) command structure
Parameters
| uint8_t utility_enrol_group | Utility Enrollment Group |
| uint8_t actions_required | Action(s) Required |
Energy Management Server callbacks configuration
Parameters
| manage_event
enum ZclStatusCodeT (*manage_event)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclEnergyMgmtManageEventT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Manage Event command |
6.4.5. Events
#include "zcl/se/zcl.events.h"
Functions
ZbZclEventsClientAlloc
struct ZbZclClusterT * ZbZclEventsClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclEventsClientCallbacksT *callbacks, void *arg);
Create a new instance of the Events Client cluster
Parameters
Return
ZbZclEventsClientCommandClearEventLogReq
enum ZclStatusCodeT ZbZclEventsClientCommandClearEventLogReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclEventsClientClearEventLogT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Clear Event Log command
Parameters
| dst | Destination address for command |
| cmd_req | Clear Event Log command structure |
Return
ZbZclEventsClientCommandGetEventLogReq
enum ZclStatusCodeT ZbZclEventsClientCommandGetEventLogReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclEventsClientGetEventLogT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Event Log command
Parameters
| cmd_req | Get Event Log command structure |
Return
ZbZclEventsMirrorAlloc
struct ZbZclClusterT * ZbZclEventsMirrorAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *events_client, struct ZbZclClusterT *meter_mirror);
Allocates a Events Server Mirror cluster. The caller (application) must attach any attributes to the cluster you want to mirror.
Parameters
| events_client | Pointer to Events Client cluster. This is used by the Metering Mirror to send mirrored commands to the BOMD. |
Return
ZbZclEventsServerAlloc
struct ZbZclClusterT * ZbZclEventsServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclEventsServerCallbacksT *callbacks, void *arg);
Create a new instance of the Events Server cluster
Parameters
Return
ZbZclEventsServerClearEventLogRsp
enum ZclStatusCodeT ZbZclEventsServerClearEventLogRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclEventsServerClearEventLogResponseT *rsp);
Send a Clear Event Log Response command
Parameters
| rsp | Clear Event Log Response command structure |
Return
ZbZclEventsServerPublishEventUnsolic
enum ZclStatusCodeT ZbZclEventsServerPublishEventUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclEventsServerPublishEventT *event, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Publish Event command
Parameters
| event | Publish Event command structure |
Return
Structures
Events Client callbacks configuration
Parameters
| publish_event
enum ZclStatusCodeT (*publish_event)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclEventsServerPublishEventT *event, const struct ZbApsAddrT *src)
Callback to application, invoked on receipt of Publish Event command. |
| publish_event_log
enum ZclStatusCodeT (*publish_event_log)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclEventsServerPublishEventLogT *event_log, const struct ZbApsAddrT *src)
Callback to application, invoked on receipt of Publish Event Log command. |
Parameters
| bool to_bomd | If true, the timeout for this command is extended since it’s being sent to a BOMD. |
Parameters
| uint8_t event_ctrl_log_id | Event Control/Log ID. Event Control is high nibble. Log ID is low nibble. |
| uint32_t start_time | Start Time - UTC Time |
| uint32_t end_time | End Time - UTC Time |
| uint8_t number_of_events | Number of Events |
| uint16_t event_offset | Event Offset |
Events Server callbacks configuration
Parameters
| get_event_log
enum ZclStatusCodeT (*get_event_log)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclEventsClientGetEventLogT *get_log, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Event Log command. Application should call ZbZclEventsServerPublishEventLogRsp for any matching event log, or return ZCL_STATUS_NOT_FOUND otherwise to return a Default Response. |
| clear_event_log
enum ZclStatusCodeT (*clear_event_log)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclEventsClientClearEventLogT *clear_log, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Clear Event Log Request command. Application calls ZbZclEventsServerClearEventLogRsp to send the response. Application should always return ZCL_STATUS_SUCCESS. |
Parameters
| uint8_t cleared_events_logs | ClearedEventsLogs |
ZbZclEventsServerEventLogPayloadT
Publish Event Log Payload structure
Parameters
| uint8_t control | Log Payload Control |
event_list |
Publish Event Response Payload |
Publish Event Log command structure
Parameters
| uint16_t total_matching_events | Total Number of Matching Events |
| struct ZbZclEventsServerEventLogPayloadT log_payload | Log Payload |
Parameters
| uint32_t event_time | Event Time - UTC time |
| uint8_t *event_data | Event Data - max length = ZCL_EVENTS_SVR_EVENT_DATA_MAX_LEN |
| uint8_t event_data_len | Event Data length |
6.4.6. Messaging
#include "zcl/se/zcl.message.h"
Functions
ZbZclMessageClientParseDisplayMsg
enum ZclStatusCodeT ZbZclMessageClientParseDisplayMsg(struct ZbZclMsgMessageT *msg, uint8_t *payload, unsigned int len);
Parses a ZCL_MESSAGE_SVR_CMD_DISPLAY_MESSAGE paylaod into a 'struct ZbZclMsgMessageT'.
Parameters
| msg | Structure to parse message into |
| payload | ZCL payload of ZCL_MESSAGE_SVR_CMD_DISPLAY_MESSAGE packet |
| len | Length of payload |
Return
ZbZclMsgClientAlloc
struct ZbZclClusterT * ZbZclMsgClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclMsgClientCallbacksT *callbacks, void *arg);
Create a new instance of the Messaging Client cluster
Parameters
Return
ZbZclMsgClientConfEnhReq
enum ZclStatusCodeT ZbZclMsgClientConfEnhReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMsgConfirmEnhT *msg_conf_enh, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Enhanced Message Confirmation command
Parameters
| msg_conf_enh | Enhanced Message Confirmation command request structure |
Return
ZbZclMsgClientConfReq
enum ZclStatusCodeT ZbZclMsgClientConfReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMsgConfirmT *msg_conf, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Message Confirmation command
Parameters
| msg_conf | Message Confirmation command request structure |
Return
ZbZclMsgClientGetLastReq
enum ZclStatusCodeT ZbZclMsgClientGetLastReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Last Message command
Parameters
Return
ZbZclMsgClientGetMsgCancelReq
enum ZclStatusCodeT ZbZclMsgClientGetMsgCancelReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, uint32_t earliestTime, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Message Cancellation command
Parameters
| earliestTime | UTC Timestamp indicating the earliest implementation time of a Cancel All Messages command to be returned |
Return
ZbZclMsgMirrorAlloc
struct ZbZclClusterT * ZbZclMsgMirrorAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *msg_server, struct ZbZclClusterT *meter_mirror, struct ZbZclClusterT *meter_client);
Allocates a Messaging Client Mirror cluster.
Parameters
| msg_server | Pointer to Messaging Server cluster. This is used by the Metering Mirror to send mirrored commands to the BOMD. |
Return
ZbZclMsgServerAlloc
struct ZbZclClusterT * ZbZclMsgServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclMsgServerCallbacksT *callbacks, void *arg);
Create a new instance of the Messaging Server cluster
Parameters
Return
ZbZclMsgServerCancelAllRsp
enum ZclStatusCodeT ZbZclMsgServerCancelAllRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclMsgMessageCancelAllT *cancel_all);
Send a Cancel All Messages command as a response
Parameters
| dstInfo | Destination address for response |
| cancel_all | Cancel All Messages command structure |
Return
ZbZclMsgServerCancelAllUnsolic
enum ZclStatusCodeT ZbZclMsgServerCancelAllUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMsgMessageCancelAllT *cancel_all, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Unsolicited Cancel All Messages command
Parameters
| cancel_all | Cancel All Messages command request structure |
Return
- ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error
ZbZclMsgServerCancelMessageReq
enum ZclStatusCodeT ZbZclMsgServerCancelMessageReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMsgMessageCancelT *cancel, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Cancel Message command
Parameters
| cancel | Cancel Message command request structure |
Return
ZbZclMsgServerDisplayMessageRsp
enum ZclStatusCodeT ZbZclMsgServerDisplayMessageRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclMsgMessageT *msg);
Send a Display or Display Protected Message as response
Parameters
| dstInfo | Destination address for command, including sequence number and tx options |
| msg | Display Message command structure |
Return
ZbZclMsgServerDisplayMessageUnsolic
enum ZclStatusCodeT ZbZclMsgServerDisplayMessageUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMsgMessageT *msg, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Display or Display Protected Message command
Parameters
| msg | Display Message command request structure |
Return
Structures
Messaging Client callbacks configuration
Parameters
| display_message
enum ZclStatusCodeT (*display_message)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclMsgMessageT *msg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Display Message command |
| cancel_message
enum ZclStatusCodeT (*cancel_message)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclMsgMessageCancelT *cancel, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Cancel Message command |
| cancel_all_messages
enum ZclStatusCodeT (*cancel_all_messages)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclMsgMessageCancelAllT *cancel_all, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Cancel All Messages command |
| display_protected_message
enum ZclStatusCodeT (*display_protected_message)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclMsgMessageT *msg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Display Protected Message command |
ZbZclMsgConfirmEnhT
Enhanced Message Confirmation command structure
Parameters
| uint32_t message_id | Message ID |
| uint32_t confirm_time | Confirmation Time |
| uint8_t confirm_control | Message Confirmation Control |
| char confirm_response | Message Confirmation Response |
ZbZclMsgConfirmT
Parameters
ZbZclMsgGetMsgCancellationT
Get Messsage Cancellation command structure
Parameters
| uint32_t earliest_impl_time | Earliest Implementation Time |
Parameters
| uint32_t implementation_time | Implementation Date/Time |
Cancel Message command structure
Parameters
| uint8_t control | Message Control |
ZbZclMsgMessageConfT
Message Confirmation callback structure
Parameters
| bool has_confirm_control | Has Message Confirmation Control |
| bool has_confirm_response | Has Message Confirmation Response |
| uint8_t confirm_response | Message Confirmation Response |
ZbZclMsgMessageT
Display Message/Display Protected Message command structure
Parameters
| uint32_t start_time | Start Time - UTC Seconds |
| uint16_t duration | Duration In Minutes |
| uint8_t message_control | Message Control |
| uint8_t message_len | Message Length |
| uint8_t *message_str | Message - UTF-8 |
| uint8_t extended_control | Extended Message Control |
| bool protected_msg | If true, indicates display message is protected. |
Messaging Server callbacks configuration
Parameters
| get_last_message
enum ZclStatusCodeT (*get_last_message)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Last Message command |
| message_confirmation
enum ZclStatusCodeT (*message_confirmation)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclMsgMessageConfT *conf, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Message Confirmation command |
| get_message_cancellation
enum ZclStatusCodeT (*get_message_cancellation)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclMsgGetMsgCancellationT *req, struct ZbZclAddrInfoT *source)
Callback to application, invoked on receipt of Get Message Cancellation command |
6.4.7. Metering
#include "zcl/se/zcl.meter.h"
Functions
ZbZclMeterClientAlloc
struct ZbZclClusterT * ZbZclMeterClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclMeterClientCallbacksT *callbacks, void *arg);
Create a new instance of the Metering Client cluster
Parameters
Return
ZbZclMeterClientAttachMirror
bool ZbZclMeterClientAttachMirror(struct ZbZclClusterT *cluster, struct ZbZclClusterT mirror_server, uint64_t rmt_addr, uint8_t rmt_endpoint);
Attach the Meter Mirror Server to the Meter Client. Configures the Client to manage the Mirror Server, and handle reports from the remote Meter and update the Mirror Server attributes.
Parameters
| cluster | EXEGIN |
| mirror_server | Pointer to the Mirror Server cluster. |
| rmt_addr | EUI64 address of the remote Meter Server. |
| rmt_endpoint | Endpoint on the remote Meter Server. |
Return
- True if the Mirror Server could be attached, false otherwise.
ZbZclMeterClientClearNotifFlag
bool ZbZclMeterClientClearNotifFlag(struct ZbZclClusterT *cluster, uint16_t attr_id, uint32_t notif_flag);
Clear the Metering Client notification flag(s).
Parameters
| cluster | Metering client cluster instance. |
| attr_id | Notification flag attribute id. |
| notif_flag | Notification flag(s) to be cleared. |
Return
- True if notification flag is cleared successfully, false otherwise.
ZbZclMeterClientCommandChangeSupplyReq
enum ZclStatusCodeT ZbZclMeterClientCommandChangeSupplyReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientChangeSupplyReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Change Supply Command
Parameters
| cmd_req | Change Supply payload information structure. |
Return
- ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error. The callback will only be called if this function returns SUCCESS.
ZbZclMeterClientCommandFastPollReq
enum ZclStatusCodeT ZbZclMeterClientCommandFastPollReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientFastPollModeReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Request Fast Poll Mode command
Parameters
| cmd_req | Request Fast Poll Mode command structure |
Return
ZbZclMeterClientCommandGetProfileReq
enum ZclStatusCodeT ZbZclMeterClientCommandGetProfileReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientGetProfileReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Profile command
Parameters
| cmd_req | Get Profile command structure |
Return
ZbZclMeterClientCommandGetSampledDataReq
enum ZclStatusCodeT ZbZclMeterClientCommandGetSampledDataReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientGetSampledDataReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Sampled Data command
Parameters
| cmd_req | Get Sampled Data command structure |
Return
ZbZclMeterClientCommandGetSnapshotReq
enum ZclStatusCodeT ZbZclMeterClientCommandGetSnapshotReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientGetSnapshotReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Snapshot command
Parameters
| cmd_req | Get Snapshot command structure |
Return
ZbZclMeterClientCommandLocalChangeSupplyReq
enum ZclStatusCodeT ZbZclMeterClientCommandLocalChangeSupplyReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientLocalChangeSupplyReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Local Change Supply command
Parameters
Return
ZbZclMeterClientCommandResetLoadLimitCounterReq
enum ZclStatusCodeT ZbZclMeterClientCommandResetLoadLimitCounterReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientResetLoadLimitCounterReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send Reset Load Limit Counter command
Parameters
| cmd_req | Reset Load Limit Counter command structure |
Return
ZbZclMeterClientCommandScheduleSnapshotReq
enum ZclStatusCodeT ZbZclMeterClientCommandScheduleSnapshotReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientScheduleSnapshotReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Schedule Snapshot Request command
Parameters
| cmd_req | Schedule Snapshot Request command structure |
Return
ZbZclMeterClientCommandSetSupplyStatusReq
enum ZclStatusCodeT ZbZclMeterClientCommandSetSupplyStatusReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientSetSupplyStatusReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Supply Status command
Parameters
| cmd_req | Set Supply Status command structure |
Return
ZbZclMeterClientCommandSetUnctrlFlowThreshReq
enum ZclStatusCodeT ZbZclMeterClientCommandSetUnctrlFlowThreshReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientSetUnctrlFlowThreshReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Uncontrolled Flow Threshold command
Parameters
| cmd_req | Set Uncontrolled Flow Threshold command structure |
Return
ZbZclMeterClientCommandStartSamplingReq
enum ZclStatusCodeT ZbZclMeterClientCommandStartSamplingReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientStartSamplingReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Start Sampling command
Parameters
| dst | Destination address for request |
| cmd_req | Start Sampling command structure |
Return
ZbZclMeterClientCommandTakeSnapshotReq
enum ZclStatusCodeT ZbZclMeterClientCommandTakeSnapshotReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientTakeSnapshotReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Take Snapshot command
Parameters
| cmd_req | Take Snapshot command structure |
Return
ZbZclMeterClientSetNotifFlag
bool ZbZclMeterClientSetNotifFlag(struct ZbZclClusterT *cluster, uint16_t attr_id, uint32_t notif_flag);
Set the Metering Client notification flag(s).
Parameters
| notif_flag | Notification(s) flag to be set. |
Return
- True if notification flag is set successfully, false otherwise.
ZbZclMeterFormSampledData
int ZbZclMeterFormSampledData(uint8_t *sample_data, unsigned int max_len, uint32_t *samples, uint16_t num_samples);
Convert an array of 24-bit integers to the Zigbee frame format
Parameters
| sample_data | Converted data for Zigbee frame |
| max_len | Maximum length |
| samples | Array of 24-bit integers to convert |
| num_samples | Number of integers to convert |
Return
- Returns the number of octets written to sample_data or -1 on error
ZbZclMeterGetProfileIntervalPeriod
int ZbZclMeterGetProfileIntervalPeriod(uint8_t profile_interval_id);
Convert the profile interval period enumerated value to a time in seconds
Parameters
| profile_interval_id | Zigbee stack instance |
Return
- Converted time in seconds or -1 on error
ZbZclMeterMirrorAlloc
struct ZbZclClusterT * ZbZclMeterMirrorAlloc(struct ZigBeeT *zb, struct ZbZclClusterT *client, uint8_t endpoint, uint64_t meter_extaddr, uint8_t meter_endpoint);
Allocate a Meter Server used for Mirroring.
Parameters
| zb | |
| client | Meter Client being used to manage this Mirror Server |
| endpoint | |
| meter_extaddr | The EUI64 of the remote Meter Server |
| meter_endpoint | The endpoint on the remote Meter Server |
Return
- Undocumented
ZbZclMeterMirrorBomdReadReq
enum ZclStatusCodeT ZbZclMeterMirrorBomdReadReq(struct ZbZclClusterT *meter_mirror, struct ZbZclClusterT *client, struct ZbZclReadReqT *req, void (*callback)(const struct ZbZclReadRspT *readRsp, void *cb_arg), void *arg);
Sends a One-Way Mirror ZCL Read Request to the BOMD. The request is queued until the BOMD wakes up. The ZCL_METER_FUNC_NOTIF_FLAG_STAY_AWAKE_HAN notification flag is set so the BOMD knows to keep polling for data after waking up. The Metering Mirror Cluster must already be allocated.
Parameters
| meter_mirror | Metering Mirror cluster |
| client | Client cluster originating this request |
| req | ZCL Read Request struct |
Return
ZbZclMeterMirrorBomdWriteReq
enum ZclStatusCodeT ZbZclMeterMirrorBomdWriteReq(struct ZbZclClusterT *meter_mirror, struct ZbZclClusterT *client, struct ZbZclWriteReqT *req, void (*callback)(const struct ZbZclWriteRspT *writeRsp, void *cb_arg), void *arg);
Sends a One-Way Mirror ZCL Write Request to the BOMD. The request is queued until the BOMD wakes up. The ZCL_METER_FUNC_NOTIF_FLAG_STAY_AWAKE_HAN notification flag is set so the BOMD knows to keep polling for data after waking up. The Metering Mirror Cluster must already be allocated.
Parameters
| req | ZCL Write Request struct |
Return
ZbZclMeterServerAlloc
struct ZbZclClusterT * ZbZclMeterServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclMeterServerCallbacksT *callbacks, void *arg);
Create a new instance of the Metering Server cluster
Parameters
| arg | Pointer to application data that will included in the callbacks when invoked. |
Return
ZbZclMeterServerPublishSnapshotRsp
enum ZclStatusCodeT ZbZclMeterServerPublishSnapshotRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclMeterServerPublishSnapshotT *rsp);
Send a Publish Snapshot Response command
Parameters
| dstInfo | Destination address for response, including sequence number and tx options |
| rsp | Publish Snapshot Response command structure |
Return
ZbZclMeterServerPublishSnapshotUnsolic
enum ZclStatusCodeT ZbZclMeterServerPublishSnapshotUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterServerPublishSnapshotT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Unsolicited Publish Snapshot command
Parameters
| dst | Destination of command. |
| req | Publish Snapshot command structure. |
Return
ZbZclMeterServerSendConfigMirror
enum ZclStatusCodeT ZbZclMeterServerSendConfigMirror(struct ZbZclClusterT *cluster, struct ZbApsAddrT *dst, struct ZbZclMeterServerConfigMirrorT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a ConfigureMirror Command (ZCL_METER_SVR_CMD_CONFIGURE_MIRROR)
Parameters
| dst | Destination of command. Should be the Coordinator / TC / Comms Hub in this case. |
| req | ConfigureMirror parameters |
Return
ZbZclMeterServerSendConfigNotifFlags
enum ZclStatusCodeT ZbZclMeterServerSendConfigNotifFlags(struct ZbZclClusterT *cluster, struct ZbApsAddrT *dst, struct ZbZclMeterServerConfigNotifFlagsT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Configure Notification Flags Command (ZCL_METER_SVR_CMD_CONFIGURE_NOTIFICATION_FLAG) "Where ‘Two Way Mirroring’ is being implemented, and a non-default Notification Scheme is to be used, the ConfigureNotificationFlags command allows a BOMD to set the commands relating to the bit value for each NotificationFlags#N attribute that the scheme is proposing to use. This command should be used in conjunction with the associated ConfigureNotificationScheme command."
Parameters
| req | Configure Notification Flags payload information structure. |
Return
ZbZclMeterServerSendConfigNotifScheme
enum ZclStatusCodeT ZbZclMeterServerSendConfigNotifScheme(struct ZbZclClusterT *cluster, struct ZbApsAddrT *dst, struct ZbZclMeterServerConfigNotifSchemeT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Configure Notification Scheme Command (ZCL_METER_SVR_CMD_CONFIGURE_NOTIFICATION_SCHEME)
Parameters
| req | Configure Notification Scheme payload information structure. |
Return
ZbZclMeterServerSendFastPollModeRsp
enum ZclStatusCodeT ZbZclMeterServerSendFastPollModeRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclMeterServerFastPollModeRspT *rsp);
Send a Request Fast Poll Mode Response command
Parameters
| rsp | Request Fast Poll Mode Response command structure |
Return
ZbZclMeterServerSendGetNotifMsg
enum ZclStatusCodeT ZbZclMeterServerSendGetNotifMsg(struct ZbZclClusterT *cluster, struct ZbApsAddrT *dst, struct ZbZclMeterServerGetNotifMsgT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Notified Message Command.
Parameters
| dst | Destination address for response, including sequence number and tx options |
| req | Get Notified Message payload information structure. |
Return
ZbZclMeterServerSendGetProfileRsp
enum ZclStatusCodeT ZbZclMeterServerSendGetProfileRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclMeterServerGetProfileRspT *rsp);
Send a Get Profile Response command
Parameters
| rsp | Get Profile Response command structure |
Return
ZbZclMeterServerSendGetSampledDataRsp
enum ZclStatusCodeT ZbZclMeterServerSendGetSampledDataRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclMeterServerGetSampledDataRspT *rsp);
Send a Get Sampled Data Response command
Parameters
| rsp | Get Sampled Data Response command structure |
Return
ZbZclMeterServerSendRemoveMirror
enum ZclStatusCodeT ZbZclMeterServerSendRemoveMirror(struct ZbZclClusterT *cluster, struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Remove Mirror Command (ZCL_METER_SVR_CMD_REMOVE_MIRROR)
Parameters
Return
ZbZclMeterServerSendRequestMirror
enum ZclStatusCodeT ZbZclMeterServerSendRequestMirror(struct ZbZclClusterT *cluster, struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Request Mirror Command (ZCL_METER_SVR_CMD_REQUEST_MIRROR)
Parameters
Return
ZbZclMeterServerSendScheduleSnapshotRsp
enum ZclStatusCodeT ZbZclMeterServerSendScheduleSnapshotRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclMeterClientScheduleSnapshotRspT *rsp);
Send a Schedule Snapshot Response command
Parameters
| rsp | Schedule Snapshot Response command structure |
Return
ZbZclMeterServerSendStartSamplingRsp
enum ZclStatusCodeT ZbZclMeterServerSendStartSamplingRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclMeterClientStartSamplingRspT *rsp);
Send a Start Sampling Response command
Parameters
| rsp | Start Sampling Response command structure |
Return
ZbZclMeterServerSendSupplyStatusRsp
enum ZclStatusCodeT ZbZclMeterServerSendSupplyStatusRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclMeterServerSupplyStatusRspT *rsp);
Send a Supply Status Response command
Parameters
| rsp | Supply Status Response command structure |
Return
ZbZclMeterServerSendTakeSnapshotRsp
enum ZclStatusCodeT ZbZclMeterServerSendTakeSnapshotRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclMeterClientTakeSnapshotRspT *rsp);
Send a Take Snapshot Response command
Parameters
| rsp | Take Snapshot Response command structure |
Return
Structures
ZbZclMeterClientMirrorReportAttrRspT
MirrorReportAttributeResponse Command
Parameters
| enum ZbZclMeterNotifSchemesT
notif_scheme |
Notification Scheme |
| uint8_t num_flags | Notification Flags |
6.4.8. Prepayment
#include "zcl/se/zcl.prepay.h"
Functions
ZbZclPrepayClientAlloc
struct ZbZclClusterT * ZbZclPrepayClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclPrepayClientCallbacksT *callbacks, void *arg);
Create a new instance of the Prepayment Client cluster
Parameters
Return
ZbZclPrepayClientChangeDebtReq
enum ZclStatusCodeT ZbZclPrepayClientChangeDebtReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayChangeDebtReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Change Debt command
Parameters
| info | Change Debt command structure |
| arg | Pointer to application data that will be included in the callback when invoked. |
Return
ZbZclPrepayClientChangePaymentModeReq
enum ZclStatusCodeT ZbZclPrepayClientChangePaymentModeReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayChangePaymentModeReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Change Payment Mode command
Parameters
| info | Change Payment Mode command structure |
Return
ZbZclPrepayClientConsumerTopUpReq
enum ZclStatusCodeT ZbZclPrepayClientConsumerTopUpReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayConsumerTopUpReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Consumer Top Up command
Parameters
| info | Consumer Top Up command structure |
Return
ZbZclPrepayClientCreateMirror
struct ZbZclClusterT * ZbZclPrepayClientCreateMirror(struct ZbZclClusterT *cluster, uint8_t endpoint, struct ZbZclClusterT *meter_mirror_client, struct ZbZclClusterT *meter_mirror_server, uint64_t rmt_addr, uint8_t rmt_endpoint);
Allocates a PrePayment Server Mirror cluster. The caller (application) must attach any attributes to the cluster you want to mirror. By default, stack attaches the mandatory prepayment server attributes.
Parameters
| cluster | Prepayment client cluster instance |
| endpoint | Endpoint on which to create the mirror cluster |
| meter_mirror_client | Metering Mirror Client cluster. This is used to manage the Mirror. |
| meter_mirror_server | Metering Mirror Server cluster. This is used to queue any commands that need to be forwarded to the BOMD when it wakes up. |
| rmt_addr | Extended address of the remote Metering device being mirrored. |
| rmt_endpoint | Endpoint on the remote Metering device being mirrored. |
Return
ZbZclPrepayClientCreditAdjustReq
enum ZclStatusCodeT ZbZclPrepayClientCreditAdjustReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayCreditAdjustReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Credit Adjustment command
Parameters
| info | Credit Adjustment command structure |
Return
ZbZclPrepayClientEmergCreditSetupReq
enum ZclStatusCodeT ZbZclPrepayClientEmergCreditSetupReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayEmergCreditSetupReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Emergency Credit Setup command
Parameters
| info | Emergency Credit Setup command structure |
Return
ZbZclPrepayClientGetDebtRepayLogReq
enum ZclStatusCodeT ZbZclPrepayClientGetDebtRepayLogReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayGetDebtRepayLogReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Debt Repayment Log command
Parameters
| info | Get Debt Repayment Log command structure |
Return
ZbZclPrepayClientGetPrepaySnapshotReq
enum ZclStatusCodeT ZbZclPrepayClientGetPrepaySnapshotReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayGetPrepaySnapshotReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Prepay Snapshot command
Parameters
| info | Get Prepay Snapshot command structure |
Return
ZbZclPrepayClientGetTopUpLogReq
enum ZclStatusCodeT ZbZclPrepayClientGetTopUpLogReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayGetTopUpLogReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get TopUp Log command
Parameters
| info | Get TopUp Log command structure |
Return
ZbZclPrepayClientSelectAvailEmergCreditReq
enum ZclStatusCodeT ZbZclPrepayClientSelectAvailEmergCreditReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepaySelectAvailEmergCreditReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Select Available Emergency Credit command
Parameters
| info | Select Available Emergency Credit command structure |
Return
ZbZclPrepayClientSetLowCreditWarnLevelReq
enum ZclStatusCodeT ZbZclPrepayClientSetLowCreditWarnLevelReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepaySetLowCreditWarnLevelReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Low Credit Warning Level command
Parameters
| info | Set Low Credit Warning Level command structure |
Return
ZbZclPrepayClientSetMaxCreditLimitReq
enum ZclStatusCodeT ZbZclPrepayClientSetMaxCreditLimitReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepaySetMaxCreditLimitReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Max Credit Limit command
Parameters
| info | Set Max Credit Limit command structure |
Return
ZbZclPrepayClientSetOverallDebtCapReq
enum ZclStatusCodeT ZbZclPrepayClientSetOverallDebtCapReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepaySetOverallDebtCapReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Overall Debt Cap command
Parameters
| info | Set Overall Debt Cap command structure |
Return
ZbZclPrepayServerAlloc
struct ZbZclClusterT * ZbZclPrepayServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *time_server, struct ZbZclPrepayServerCallbacksT *callbacks, void *arg);
Create a new instance of the Prepayment Server cluster
Parameters
| time_server | Pointer to time server cluster |
Return
ZbZclPrepayServerAttrCreditRemainingWriteCb
enum ZclStatusCodeT ZbZclPrepayServerAttrCreditRemainingWriteCb(struct ZbZclClusterT *cluster, struct ZbZclAttrCbInfoT *info);
Prepayment server default write callback for optional attribute 'Credit Remaining'.
Parameters
| cluster | Cluster instance for Prepayment server. |
| info | Attribute information structure. |
Return
ZbZclPrepayServerChangePaymentModeRsp
enum ZclStatusCodeT ZbZclPrepayServerChangePaymentModeRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPrepayChangePaymentModeRspT *info);
Send a Change Payment Mode response
Parameters
| info | Change Payment Mode Response command structure |
Return
ZbZclPrepayServerConsumerTopUpRsp
enum ZclStatusCodeT ZbZclPrepayServerConsumerTopUpRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPrepayConsumerTopUpRspT *info);
Send a Consumer Top Up response
Parameters
| info | Consumer Top Up Response command structure |
Return
ZbZclPrepayServerPublishDebtLogRsp
enum ZclStatusCodeT ZbZclPrepayServerPublishDebtLogRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclPrepayPublishDebtLogT *info);
Send a Publish Debt Log Response
Parameters
| info | Publish Debt Log command structure |
Return
ZbZclPrepayServerPublishDebtLogUnsolic
enum ZclStatusCodeT ZbZclPrepayServerPublishDebtLogUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayPublishDebtLogT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Debt Log
Parameters
| dst | Destination address for this unsolicted command. |
| info | Publish Debt Log command structure. |
| callback | Callback function that will be invoked when the Default Response is received, or times-out. |
Return
ZbZclPrepayServerPublishPrepaySnapshotRsp
enum ZclStatusCodeT ZbZclPrepayServerPublishPrepaySnapshotRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclPrepayPublishPrepaySnapshotT *info);
Send a Publish Prepay Snapshot as a response to the GetPrepaySnapshot command.
Parameters
| info | Publish Prepay Snapshot command structure |
Return
ZbZclPrepayServerPublishPrepaySnapshotUnsolic
enum ZclStatusCodeT ZbZclPrepayServerPublishPrepaySnapshotUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayPublishPrepaySnapshotT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Publish Prepay Snapshot as an unsolicited command
Parameters
Return
ZbZclPrepayServerPublishTopUpLogRsp
enum ZclStatusCodeT ZbZclPrepayServerPublishTopUpLogRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclPrepayPublishTopUpLogT *info);
Send a Publish Top Up Log as a response
Parameters
Return
ZbZclPrepayServerPublishTopUpLogUnsolic
enum ZclStatusCodeT ZbZclPrepayServerPublishTopUpLogUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayPublishTopUpLogT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Publish Top Up Log as an unsolicited command
Parameters
| info | Publish Top Up Log command structure |
Return
ZbZclPrepayServerUpdateAlarmStatusFlag
enum ZclStatusCodeT ZbZclPrepayServerUpdateAlarmStatusFlag(struct ZbZclClusterT *cluster, uint16_t flag, bool set);
Set/Clear the alram status flag in 'Alarm Status' attribute.
Parameters
| flag | Alarm status flags e.g, ZCL_PREPAY_ALARM_LOW_CREDIT_WARN |
| set | if true, sets the input flags. Otherwise, clears the flags. |
Return
ZbZclPrepayServerUpdateCreditStatusFlag
enum ZclStatusCodeT ZbZclPrepayServerUpdateCreditStatusFlag(struct ZbZclClusterT *cluster, uint8_t flag, bool set);
Set/Clear the credit status flag in 'Credit Status' attribute.
Parameters
| flag | Credit status flags e.g, ZCL_PREPAY_CREDIT_OK |
Return
zcl_prepay_get_topup_record
bool zcl_prepay_get_topup_record(struct ZbZclClusterT *cluster, struct ZbZclPrepayTopUpPayloadT *payload, uint8_t attr_idx);
Helper function to retrieve the topup record from the topup attribute set pointed by attribute index.
Parameters
| cluster | Cluster instance to get the topup record. |
| payload | Pointer to TopUp record payload. |
| attr_idx | Attribute index to the TopUp attribute set |
Return
- true if the top up record is retrieved successfully, false otherwise.
zcl_prepay_topup_code_duplicate_check
bool zcl_prepay_topup_code_duplicate_check(struct ZbZclClusterT *cluster, const uint8_t *topup_code);
Helper function to check if the topup code received is duplicate or not.
Parameters
| topup_code | Pointer to topup_code received as part of comsumer topup command. |
Return
- true if the received topup code is duplicate, false otherwise.
zcl_prepay_update_topup_attrs
enum ZbZclPrepayTopUpResultT zcl_prepay_update_topup_attrs(struct ZbZclClusterT *cluster, enum ZbZclPrepayOriginDeviceT origin_device, uint8_t *topup_code, int32_t topup_value);
Helper function to update the prepayment server topup attributes on receiving the consumer topup command.
Parameters
| cluster | Cluster instance to check the topup attributes. |
| origin_device | Origin device of the consumer topup command. |
| topup_code | Pointer to topup code received as part of consumer topup command. |
| topup_value | topup amount derived from the topup code. |
Return
- ZCL_PREPAY_TOPUP_RSLT_ACCEPTED if the topup attributes are updated successfully, ZCL_PREPAY_TOPUP_RSLT_RJCTD_MAX_CREDIT if the top amount results in credit remaining value exceeding the maximum credit limit.
Enumerations
ZbZclPreaymentSvrAttrT
Prepayment Server Attribute IDs
| ZCL_PREPAY_SVR_ATTR_PAYMENT_CONTROL_CONFIG | Payment Control Configuration |
| ZCL_PREPAY_SVR_ATTR_CREDIT_REMAINING | Credit Remaining (Optional) |
| ZCL_PREPAY_SVR_ATTR_EMERG_CREDIT_REMAINING | Emergency Credit Remaining (Optional) |
| ZCL_PREPAY_SVR_ATTR_CREDIT_STATUS | Credit Status (Optional) |
| ZCL_PREPAY_SVR_ATTR_CREDIT_REMAIN_TIMESTAMP | CreditRemaining TimeStamp (Optional) |
| ZCL_PREPAY_SVR_ATTR_ACCUMULATED_DEBT | Accumulated Debt (Optional) |
| ZCL_PREPAY_SVR_ATTR_OVERALL_DEBT_CAP | OverallDebtCap (Optional) |
| ZCL_PREPAY_SVR_ATTR_EMERG_CREDIT_ALLOWANCE | EmergencyCredit Limit/Allowance (Optional) |
| ZCL_PREPAY_SVR_ATTR_EMERG_CREDIT_THRESHOLD | EmergencyCredit Threshold (Optional) |
| ZCL_PREPAY_SVR_ATTR_TOTAL_CREDIT_ADDED | TotalCreditAdded (Optional) |
| ZCL_PREPAY_SVR_ATTR_MAX_CRED_LIMIT | MaxCreditLimit (Optional) |
| ZCL_PREPAY_SVR_ATTR_MAX_CRED_PER_TOPUP | MaxCreditPerTopUp (Optional) |
| ZCL_PREPAY_SVR_ATTR_FRIENDLY_CREDIT_WARNING | FriendlyCredit Warning (Optional) |
| ZCL_PREPAY_SVR_ATTR_LOW_CREDIT_WARNING | LowCredit Warning (Optional) |
| ZCL_PREPAY_SVR_ATTR_IHD_LOW_CREDIT_WARNING | IHDLow CreditWarning (Optional) |
| ZCL_PREPAY_SVR_ATTR_INTERRUPT_SUSPEND_TIME | InterruptSuspend Time (Optional) |
| ZCL_PREPAY_SVR_ATTR_REMAINING_FRIENDLY_CREDIT
_TIME |
RemainingFriendlyCreditTime (Optional) |
| ZCL_PREPAY_SVR_ATTR_NEXT_FRIENDLY_CREDIT_TIME | NextFriendly CreditPeriod (Optional) |
| ZCL_PREPAY_SVR_ATTR_CUT_OFF_VALUE | CutOffValue (Optional) |
| ZCL_PREPAY_SVR_ATTR_TOKEN_CARRIER_ID | TokenCarrierID (Optional) |
| ZCL_PREPAY_SVR_ATTR_TOPUP_DATE_TIME_1 | Top up Date/Time #1 (Optional) ZCL_PREPAY_SVR_ATTR_TOPUP_DATE_TIME_N(1) For the
remaining Top up Date/Time attributes, use the ZCL_PREPAY_SVR_ATTR_TOPUP_DATE_TIME_N macro. |
| ZCL_PREPAY_SVR_ATTR_TOPUP_AMOUNT_1 | Top up Amount #1 (Optional) ZCL_PREPAY_SVR_ATTR_TOPUP_AMOUNT_N(1) For the remaining Top up Amount attributes, use the ZCL_PREPAY_SVR_ATTR_TOPUP_AMOUNT_N macro. |
| ZCL_PREPAY_SVR_ATTR_TOPUP_ORIGINATOR | Originating Device #1 (Optional) ZCL_PREPAY_SVR_ATTR_TOPUP_ORIGINATOR_N(1) For the remaining Orginating Device attributes, use the ZCL_PREPAY_SVR_ATTR_TOPUP_ORIGINATOR_N macro. |
| ZCL_PREPAY_SVR_ATTR_TOPUP_CODE | Top up Code #1 (Optional) ZCL_PREPAY_SVR_ATTR_TOPUP_CODE_N(1) For the remaining Top up Code attributes, use the ZCL_PREPAY_SVR_ATTR_TOPUP_CODE_N macro. |
| ZCL_PREPAY_SVR_ATTR_DEBT_LABEL_1 | DebtLabel#1 (Optional) ZCL_PREPAY_SVR_ATTR_DEBT_LABEL_N(1) For the remaining DebtLabel attributes, use the ZCL_PREPAY_SVR_ATTR_DEBT_LABEL_N macro. |
| ZCL_PREPAY_SVR_ATTR_DEBT_AMOUNT_1 | DebtAmount#1 (Optional) ZCL_PREPAY_SVR_ATTR_DEBT_AMOUNT_N(1) For the remaining DebtAmount attributes, use the ZCL_PREPAY_SVR_ATTR_DEBT_AMOUNT_N macro. |
| ZCL_PREPAY_SVR_ATTR_DEBT_REC_METHOD_1 | DebtRecovery Method#1 (Optional) ZCL_PREPAY_SVR_ATTR_DEBT_REC_METHOD_N(1) For the remaining DebtRecovery Method attributes, use the ZCL_PREPAY_SVR_ATTR_DEBT_REC_METHOD_N macro. |
| ZCL_PREPAY_SVR_ATTR_DEBT_REC_START_TIME_1 | DebtRecovery StartTime#1 (Optional) ZCL_PREPAY_SVR_ATTR_DEBT_REC_START_TIME_N(1)
For the remaining DebtRecovery StartTime attributes, use the ZCL_PREPAY_SVR_ATTR_DEBT_REC_START_TIME_N macro. |
| ZCL_PREPAY_SVR_ATTR_DEBT_REC_COLLECT_TIME_1 | DebtRecovery CollectionTime#1 (Optional) ZCL_PREPAY_SVR_ATTR_DEBT_REC_COLLECT_TIME_N(1)
For the remaining DebtRecovery CollectionTime attributes, use the ZCL_PREPAY_SVR_ATTR_DEBT_REC_COLLECT_TIME_N macro. |
| ZCL_PREPAY_SVR_ATTR_DEBT_REC_FREQ_1 | DebtRecovery Frequency#1 (Optional) ZCL_PREPAY_SVR_ATTR_DEBT_REC_FREQ_N(1) For the
remaining DebtRecovery Frequency attributes, use the ZCL_PREPAY_SVR_ATTR_DEBT_REC_FREQ_N macro. |
| ZCL_PREPAY_SVR_ATTR_DEBT_REC_AMOUNT_1 | DebtRecovery Amount#1 (Optional) ZCL_PREPAY_SVR_ATTR_DEBT_REC_AMOUNT_N(1) For
the remaining DebtRecovery Amount attributes, use the ZCL_PREPAY_SVR_ATTR_DEBT_REC_AMOUNT_N macro. |
| ZCL_PREPAY_SVR_ATTR_DEBT_REC_TOPUP_PERCENT_1 | DebtRecovery TopUpPercentage#1 (Optional) ZCL_PREPAY_SVR_ATTR_DEBT_REC_TOPUP_PERCENT_
N(1) For the remaining DebtRecovery TopUpPercentage attributes, use the ZCL_PREPAY_SVR_ATTR_DEBT_REC_TOPUP_PERCENT_N macro. |
| ZCL_PREPAY_SVR_ATTR_ALARM_STATUS | PrepaymentAlarmStatus (Optional) |
| ZCL_PREPAY_SVR_ATTR_GENERIC_ALARM_MASK | PrepayGenericAlarmMask (Optional) |
| ZCL_PREPAY_SVR_ATTR_SWITCH_ALARM_MASK | PrepaySwitchAlarmMask (Optional) |
| ZCL_PREPAY_SVR_ATTR_EVENT_ALARM_MASK | PrepayEventAlarmMask (Optional) |
| ZCL_PREPAY_SVR_ATTR_HIST_CCTION_FORMAT | HistoricalCostConsumption Formatting (Optional) |
| ZCL_PREPAY_SVR_ATTR_CONSUMPTION_UNIT_OF_MEAS URE | ConsumptionUnitofMeasurement (Optional) |
| ZCL_PREPAY_SVR_ATTR_CURRENCY_SCALING_FACTOR | CurrencyScalingFactor (Optional) |
| ZCL_PREPAY_SVR_ATTR_CURRENCY | Currency (Optional) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_DAY_0 | CurrentDay CostConsumptionDelivered (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_DAY_N(0) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_DAY_0 | CurrentDay CostConsumptionReceived (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_DAY_N(0) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_DAY_1 | PreviousDay CostConsumptionDelivered (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_DAY_N(1) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_DAY_1 | PreviousDay CostConsumptionReceived (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_DAY_N(1) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_DAY_2 | PreviousDay2 CostConsumptionDelivered (Optional) ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_DAY_N(2) For
the remaining days, use the ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_DAY_N(prev_d ay) macro. |
| ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_DAY_2 | PreviousDay2 CostConsumptionReceived (Optional) ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_DAY_N(2)
For the remaining days, use the ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_DAY_N(pr ev_day) macro. |
| ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_WEEK_0 | CurrentWeek CostConsumptionDelivered (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_WEEK_N(0) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_WEEK_0 | CurrentWeek CostConsumptionReceived (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_WEEK_N( 0) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_WEEK_1 | PreviousWeek CostConsumptionDelivered (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_WEEK_N(1) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_WEEK_1 | PreviousWeek CostConsumptionReceived (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_WEEK_N( 1) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_WEEK_2 | PreviousWeek2 CostConsumptionDelivered (Optional) ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_WEEK_N(2)
For the remaining weeks, use the ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_WEEK_N(prev _week) macro. |
| ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_WEEK_2 | PreviousWeek2 CostConsumptionReceived (Optional) ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_WEEK_N(
2) For the remaining weeks, use the ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_WEEK_N( prev_week) macro. |
| ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_MONTH_0 | CurrentMonth CostConsumptionDelivered (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_MONTH_N(0) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_MONTH_0 | CurrentMonth CostConsumptionReceived (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_MONTH_ N(0) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_MONTH_1 | PreviousMonth CostConsumptionDelivered (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_MONTH_N(1) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_MONTH_1 | PreviousMonth CostConsumptionReceived (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_MONTH_ N(1) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_MONTH_2 | PreviousMonth2 CostConsumptionDelivered (Optional) ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_MONTH_N(2)
For the remaining months, use the ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_MONTH_N(pre v_month) macro. |
| ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_MONTH_2 | PreviousMonth2 CostConsumptionReceived (Optional) ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_MONTH_
N(2) For the remaining months, use the ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_MONTH_ N(prev_month) macro. |
| ZCL_PREPAY_SVR_ATTR_HIST_FREEZE_TIME | Historical Freeze Time (Optional) |
ZbZclPrepayCreditTypeT
Credit Type Field enumerations
| ZCL_PREPAY_CREDIT_TYPE_INCREMENTAL | Credit Incremental |
| ZCL_PREPAY_CREDIT_TYPE_ABSOLUTE | Credit Absolute |
ZbZclPrepayDebtRecMethodT
Debt Recovery Method enumerations
| ZCL_PREPAY_REC_METHOD_TIME | Time Based |
| ZCL_PREPAY_REC_METHOD_PERCENTAGE | Percentage Based |
| ZCL_PREPAY_REC_METHOD_CATCH_UP | Catch-up Based |
| /**< | 0x03 -0xff Reserved |
ZbZclPrepayDebtTypeT
Debt Type Field enumerations
| ZCL_PREPAY_DEBT_TYPE_1_ABSOLUTE | Debt Type 1 Absolute |
| ZCL_PREPAY_DEBT_TYPE_1_INCREMENTAL | Debt Type 1 Incremental |
| ZCL_PREPAY_DEBT_TYPE_2_ABSOLUTE | Debt Type 2 Absolute |
| ZCL_PREPAY_DEBT_TYPE_2_INCREMENTAL | Debt Type 2 Incremental |
| ZCL_PREPAY_DEBT_TYPE_3_ABSOLUTE | Debt Type 3 Absolute |
| ZCL_PREPAY_DEBT_TYPE_3_INCREMENTAL | Debt Type 3 Incremental |
| /**< | 0x06 - 0xff Reserved. |
Originating Device Field enumerations
| ZCL_PREPAY_ORIGIN_DEVICE_ESI | Energy Service Interface |
| ZCL_PREPAY_ORIGIN_DEVICE_METER | Meter |
| ZCL_PREPAY_ORIGIN_DEVICE_IHD | In-Home Display Device |
ZbZclPrepaySnapshotPayloadTypeT
Prepayment Snapshot Payload type.
| ZCL_PREPAY_SNAPSHOT_PAYLOAD_TYPE_DEBT_STATUS | Debt/Credit Status |
Result Type Field enumerations
| ZCL_PREPAY_TOPUP_RSLT_ACCEPTED | Accepted |
| ZCL_PREPAY_TOPUP_RSLT_RJCTD_INVALID | Rejected-Invalid Top Up |
| ZCL_PREPAY_TOPUP_RSLT_RJCTD_DUPLICATE | Rejected-Duplicate Top Up |
| ZCL_PREPAY_TOPUP_RSLT_RJCTD_ERROR | Rejected-Error |
| ZCL_PREPAY_TOPUP_RSLT_RJCTD_MAX_CREDIT | Rejected-Max Credit Reached |
| ZCL_PREPAY_TOPUP_RSLT_RJCTD_KEYPAD_LOCK | Rejected-Keypad Lock |
| ZCL_PREPAY_TOPUP_RSLT_RJCTD_TOO_LARGE | Rejected-Top Up Value Too Large |
| ZCL_PREPAY_TOPUP_RSLT_ACCPD_SUPPLY_ENABLED | Accepted – Supply Enabled |
| ZCL_PREPAY_TOPUP_RSLT_ACCPD_SUPPLY_DISABLED | Accepted – Supply Disabled |
| ZCL_PREPAY_TOPUP_RSLT_ACCPD_SUPPLY_ARMED | Accepted – Supply Armed |
Structures
Parameters
| uint32_t issuer_event_id | Issuer Event ID |
| char debt_label | Debt Label, first byte is length. |
| int32_t debt_amount | Debt Amount |
| enum ZbZclPrepayDebtRecMethodT
rec_method |
Debt Recovery Method. |
| enum ZbZclPrepayDebtTypeT debt_type | Debt Amount Type. |
| uint32_t rec_start_time | Debt Recovery Start Time. |
| uint16_t rec_collect_time | Debt Recovery Collection Time. |
| uint8_t rec_freq | Debt Recovery Frequency. |
| int32_t rec_amount | Debt Recovery Amount. |
| uint16_t rec_bal_percent | Debt Recovery Balance Percentage. |
| bool to_bomd | If true, the timeout for this command is extended since it’s being sent to a BOMD via a Mirror device. |
Change Payment Mode command structure (ZCL_PREPAY_CLI_CMD_CHANGE_PAYMENT_MODE)
Parameters
| uint32_t provider_id | Provider ID |
| uint32_t implement_time | Implementation Date/Time |
| uint16_t ctrl_config | Proposed Payment Control Configuration |
| int32_t cutoff_value | Cut Off Value |
Consumer Change Supply Mode Response command structure
Parameters
| uint8_t friendly_credit | Friendly Credit Bitmap |
| uint32_t friendly_calendar_id | Friendly Credit Calendar Id |
| uint32_t emerg_credit_limit | Emergency Credit Limit |
| uint32_t emerg_credit_thresh | Emergency Credit Threshold |
Parameters
origin_device |
Originating Device |
| uint8_t topup_code | TopUp Code (ZCL octet string, first byte is length) |
Parameters
| enum ZbZclPrepayTopUpResultT result | Result Type Field enumeration |
| int32_t value | Top Up Value |
| enum ZbZclPrepayOriginDeviceT source | Originating Device Field enumeration |
| int32_t credit_remain | Credit Remaining |
Credit Adjustment command structure (ZCL_PREPAY_CLI_CMD_CREDIT_ADJUST)
Parameters
| uint32_t start_time | Start Time |
| enum ZbZclPrepayCreditTypeT
credit_adjust_type |
Credit Adjustment Type |
| int32_t credit_adjust_value | Credit Adjustment Value |
ZbZclPrepayDebtRecordT
Debt Payload structure
Parameters
| uint32_t collect_time | Collection Time - UTC Time |
| uint32_t amount_collect | Amount Collected |
| enum ZbZclPrepayDebtTypeT debt_type | Debt Type |
| uint32_t outstand_debt | Outstanding Debt |
Parameters
Parameters
| uint32_t latest_end_time | Latest EndTime - UTC Time |
| uint8_t number_of_debts | Number of Debts |
Get Prepay Snapshot command structure (ZCL_PREPAY_CLI_CMD_GET_PREPAY_SNAPSHOT)
Parameters
| uint32_t start_time | Earliest Start Time - UTC Time |
| uint32_t latest_end_time | Latest End Time - UTC Time |
| uint8_t snapshot_offset | Snapshot offset. |
| uint32_t snapshot_cause | Snapshot cause. |
Parameters
| uint8_t number_of_records | Number of Records |
Parameters
| uint8_t command_index | Command Index |
| uint8_t total_commands | Total Number of Commands |
| struct ZbZclPrepayDebtRecordT
debt_records |
Debt Payload |
| uint8_t num_records | Number of records in 'debt_records' |
Parameters
| uint32_t issue_time | Command Issue Date/Time |
origin_device |
Prepayment Server callbacks configuration
Parameters
| select_avail_emerg_credit
(callback function pointer) |
enum ZclStatusCodeT (*select_avail_emerg_credit)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepaySelectAvailEmergCreditReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Select Available Emergency Credit command (ZCL_PREPAY_CLI_CMD_SELECT_AVAIL_EMERG_CREDIT). Return ZCL status code (e.g. ZCL_STATUS_SUCCESS) to include in Default Response. If the application callback returns ZCL status of ZCL_STATUS_SUCCESS, then the stack updates ZCL_PREPAY_SVR_ATTR_CREDIT_STATUS attribute as per the command. |
| change_debt
enum ZclStatusCodeT (*change_debt)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepayChangeDebtReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Change Debt command (ZCL_PREPAY_CLI_CMD_CHANGE_DEBT). Return ZCL status code (e.g. ZCL_STATUS_SUCCESS) to include in Default Response. If the application callback returns ZCL status of ZCL_STATUS_SUCCESS, then the stack updates attributes ZCL_PREPAY_SVR_ATTR_DEBT_LABEL_N(n) to ZCL_PREPAY_SVR_ATTR_DEBT_REC_TOPUP_PERCENT_N(n) as per the command. |
| emerg_credit_setup
enum ZclStatusCodeT (*emerg_credit_setup)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepayEmergCreditSetupReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Emergency Credit Setup command (ZCL_PREPAY_CLI_CMD_EMERG_CREDIT_SETUP). Return ZCL status code (e.g. ZCL_STATUS_SUCCESS) to include in Default Response. If the application callback returns ZCL status of ZCL_STATUS_SUCCESS, then the stack updates the attributes ZCL_PREPAY_SVR_ATTR_EMERG_CREDIT_ALLOWANCE and ZCL_PREPAY_SVR_ATTR_EMERG_CREDIT_THRESHOLD, provided start_time is != 0xffffffff. If start_time is 0xffffffff then previous scheduled & unactioned emerg_credit_setup requests with matching 'IssuerEvent ID' will be cancelled. |
| consumer_topup
enum ZclStatusCodeT (*consumer_topup)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepayConsumerTopUpReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Consumer Top Up command. Return ZCL_STATUS_SUCCESS if log(s) found and Consumer Top Up Response sent (ZbZclPrepayServerConsumerTopUpRsp), or ZCL_STATUS_NOT_FOUND otherwise. |
| credit_adjust
enum ZclStatusCodeT (*credit_adjust)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepayCreditAdjustReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Credit Adjustment command (ZCL_PREPAY_CLI_CMD_CREDIT_ADJUST). Return ZCL status code (e.g. ZCL_STATUS_SUCCESS) to include in Default Response. If the application callback returns ZCL status of ZCL_STATUS_SUCCESS, then the stack updates the attribute ZCL_PREPAY_SVR_ATTR_CREDIT_REMAINING, provided start_time is != 0xffffffff. If start_time is 0xffffffff then previous scheduled & unactioned credit_adjust requests with matching 'IssuerEvent ID' will be cancelled. |
| change_payment_mode
enum ZclStatusCodeT (*change_payment_mode)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepayChangePaymentModeReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Change Payment Mode command (ZCL_PREPAY_CLI_CMD_CHANGE_PAYMENT_MODE). Returns ZCL status code from sending ZbZclPrepayServerChangePaymentModeRsp() (e.g. ZCL_STATUS_SUCCESS) to include in Default Response. If the application callback returns ZCL status of ZCL_STATUS_SUCCESS, then the stack updates the attribute ZCL_PREPAY_SVR_ATTR_PAYMENT_CONTROL_CONFIG, provided start_time is != 0xffffffff. If start_time is 0xffffffff then previous scheduled & unactioned change_payment_mode requests with matching 'Provider ID' and 'IssuerEvent ID' will be cancelled. |
| get_prepay_snapshot
enum ZclStatusCodeT (*get_prepay_snapshot)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepayGetPrepaySnapshotReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Prepay Snapshot command. Return ZCL_STATUS_SUCCESS if snapshot(s) found and Publish Snapshot command sent (ZbZclPrepayServerPublishPrepaySnapshotRsp), or ZCL_STATUS_NOT_FOUND otherwise. |
| get_debt_repay_log
enum ZclStatusCodeT (*get_debt_repay_log)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepayGetDebtRepayLogReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Debt Repayment Log command. Return ZCL_STATUS_SUCCESS if log(s) found and Publish Debt Log command(s) sent (ZbZclPrepayServerPublishDebtLogRsp), or ZCL_STATUS_NOT_FOUND otherwise. |
| get_topup_log
enum ZclStatusCodeT (*get_topup_log)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepayGetTopUpLogReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get TopUp Log command. Return ZCL_STATUS_SUCCESS if log(s) found and Publish TopUp Log command(s) sent (ZbZclPrepayServerPublishTopUpLogRsp), or ZCL_STATUS_NOT_FOUND otherwise. |
| set_low_credit_warn_level
enum ZclStatusCodeT (*set_low_credit_warn_level)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepaySetLowCreditWarnLevelReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Set Low Credit Warning Level command (ZCL_PREPAY_CLI_CMD_SET_LOW_CREDIT_WARN_LEVEL). Return ZCL status code (e.g. ZCL_STATUS_SUCCESS) to include in Default Response. If the application callback returns ZCL status of ZCL_STATUS_SUCCESS, then the stack updates the attributes ZCL_PREPAY_SVR_ATTR_LOW_CREDIT_WARNING and ZCL_PREPAY_SVR_ATTR_CREDIT_REMAINING. |
| set_max_credit_limit
enum ZclStatusCodeT (*set_max_credit_limit)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepaySetMaxCreditLimitReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Set Max Credit Limit command (ZCL_PREPAY_CLI_CMD_SET_MAX_CREDIT_LIMIT). Return ZCL status code (e.g. ZCL_STATUS_SUCCESS) to include in Default Response. If the application callback returns ZCL status of ZCL_STATUS_SUCCESS, then the stack updates the attributes ZCL_PREPAY_SVR_ATTR_MAX_CRED_LIMIT and ZCL_PREPAY_SVR_ATTR_MAX_CRED_PER_TOPUP, provided start_time is != 0xffffffff. If start_time is 0xffffffff then previous scheduled & unactioned set_max_credit_limit requests with matching 'Provider ID' and 'IssuerEvent ID' will be cancelled. |
| set_overall_debt_cap
enum ZclStatusCodeT (*set_overall_debt_cap)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepaySetOverallDebtCapReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Set Overall Debt Cap command (ZCL_PREPAY_CLI_CMD_SET_OVERALL_DEBT_CAP). Return ZCL status code (e.g. ZCL_STATUS_SUCCESS) to include in Default Response. If the application callback returns ZCL status of ZCL_STATUS_SUCCESS, then the stack updates the attribute ZCL_PREPAY_SVR_ATTR_OVERALL_DEBT_CAP, provided start_time is != 0xffffffff. If start_time is 0xffffffff then previous scheduled & unactioned set_overall_debt_cap requests with matching 'Provider ID' and 'IssuerEvent ID' will be cancelled. |
Parameters
| uint32_t warn_level | Low Credit Warning Level |
Set Maximum Credit Limit
Parameters
| uint32_t implement_time | Implementation Data/Time |
| uint32_t max_credit_level | Maximum Credit Level |
| uint32_t max_credit_per_topup | Maximum Credit Per Top Up |
Parameters
| int32_t overall_debt_cap | Overall Debt Cap |
6.4.9. Price
#include "zcl/se/zcl.price.h"
Functions
ZbZclPriceClientAlloc
struct ZbZclClusterT * ZbZclPriceClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclPriceClientCallbacksT *callbacks, void *arg);
Create a new instance of the Price Client cluster
Parameters
| zb | Zigbee stack instance |
| endpoint | Endpoint on which to create cluster |
| callbacks | Structure containing any callback function pointers for this cluster |
| arg | Pointer to application data that will included in the callback when invoked. |
Return
- Cluster pointer, or NULL if there is an error
ZbZclPriceClientCommandGetBillingPeriodReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetBillingPeriodReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetBillingPeriodT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Billing Period command
Parameters
| cluster | Cluster instance from which to send this command |
| cmd_req | Get Billing Period command structure |
| callback | Callback function that will be invoked when the response is received. |
Return
ZbZclPriceClientCommandGetBlockPeriodReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetBlockPeriodReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetBlockPeriodT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Block Period(s) command
Parameters
| cmd_req | Get Block Period(s) command structure |
Return
ZbZclPriceClientCommandGetBlockThresholdsReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetBlockThresholdsReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetBlockThresholdsT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Block Thresholds command
Parameters
| cmd_req | Get Block Thresholds command structure |
Return
ZbZclPriceClientCommandGetCO2ValueReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetCO2ValueReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetCO2ValueT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get CO2 Value command
Parameters
| cmd_req | Get CO2 Value command structure |
Return
ZbZclPriceClientCommandGetCalorificValueReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetCalorificValueReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetCalorificValueT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Calorific Value command
Parameters
| cmd_req | Get Calorific Value command structure |
Return
ZbZclPriceClientCommandGetConsolidatedBillReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetConsolidatedBillReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetConsolidatedBillT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Consolidated Bill command
Parameters
| cmd_req | Get Consolidated Bill command structure |
| arg | Pointer to application data that will be provided back to the callback function when invoked. |
Return
ZbZclPriceClientCommandGetConversionFactorReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetConversionFactorReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetConversionFactorT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Conversion Factor command
Parameters
| cmd_req | Get Conversion Factor command structure |
Return
ZbZclPriceClientCommandGetCurrencyConversionReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetCurrencyConversionReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Currency Conversion command
Parameters
Return
ZbZclPriceClientCommandGetCurrentPriceReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetCurrentPriceReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Current Price command
Parameters
Return
ZbZclPriceClientCommandGetPriceMatrixReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetPriceMatrixReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetPriceMatrixT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Price Matrix command
Parameters
| cmd_req | Get Price Matrix command structure |
Return
ZbZclPriceClientCommandGetScheduledPricesReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetScheduledPricesReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetScheduledPricesT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Scheduled Prices command
Parameters
| cmd_req | Get Scheduled Prices command structure |
Return
ZbZclPriceClientCommandGetTariffInfoReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetTariffInfoReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetTariffInfoT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Tariff Information command
Parameters
| cmd_req | Get Tariff Information command structure |
Return
ZbZclPriceClientCommandPriceAckReq
enum ZclStatusCodeT ZbZclPriceClientCommandPriceAckReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientPriceAckT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Price Acknowledgement command
Parameters
| cmd_req | Price Acknowledge command structure |
Return
ZbZclPriceMirrorAlloc
struct ZbZclClusterT * ZbZclPriceMirrorAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *price_server, struct ZbZclClusterT *meter_mirror, struct ZbZclClusterT *meter_client);
Allocates a Price Client Mirror cluster.
Parameters
| price_server | Pointer to Price Server cluster. This is used by the Metering Mirror to send mirrored commands to the BOMD. |
| meter_mirror | Pointer to Metering Mirror cluster. This is used to queue any commands that need to be forwarded to the BOMD when it wakes up. |
| meter_client | Pointer to Metering Client cluster. This is used to know the existing notification scheme setup between BOMD & ESI and to determine if the command needs to be queued or only the notification flag needs to be set. |
Return
ZbZclPriceServerAlloc
struct ZbZclClusterT * ZbZclPriceServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclPriceServerCallbacksT *callbacks, void *arg);
Create a new instance of the Price Server cluster
Parameters
Return
ZbZclPriceServerPublishPriceInit
void ZbZclPriceServerPublishPriceInit(struct ZbZclPriceServerPublishPriceT *rsp);
Initialize Publish Price information
Parameters
| rsp | Publish Price command structure |
Return
- Void
ZbZclPriceServerSendPublishBillingPeriodRsp
enum ZclStatusCodeT ZbZclPriceServerSendPublishBillingPeriodRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPriceServerPublishBillingPeriodT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Billing Period command as a response
Parameters
| dst | Destination address for command, including sequence number and tx options |
| info | Publish Billing Period command structure |
| callback | Callback function for an APSDE-DATA.confirm |
| arg | Pointer to application data that will later be provided back to the callback function when invoked |
Return
ZbZclPriceServerSendPublishBillingPeriodUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishBillingPeriodUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishBillingPeriodT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Billing Period command
Parameters
| dst | Destination address for command |
| callback | Callback function that will be invoked when response is received, if one is expected. If broadcasting, then this should be set to NULL since no response is expected |
Return
ZbZclPriceServerSendPublishBlockPeriodRsp
enum ZclStatusCodeT ZbZclPriceServerSendPublishBlockPeriodRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPriceServerPublishBlockPeriodT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Block Period command as a response
Parameters
| info | Publish Block Period command structure |
Return
ZbZclPriceServerSendPublishBlockPeriodUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishBlockPeriodUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishBlockPeriodT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Block Period command
Parameters
Return
ZbZclPriceServerSendPublishBlockThresholdsRsp
enum ZclStatusCodeT ZbZclPriceServerSendPublishBlockThresholdsRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPriceServerPublishBlockThresholdsT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Block Thresholds command as a response
Parameters
| info | Publish Block Thresholds command structure |
Return
ZbZclPriceServerSendPublishBlockThresholdsUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishBlockThresholdsUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishBlockThresholdsT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Block Thresholds command
Parameters
Return
ZbZclPriceServerSendPublishCO2ValueRsp
enum ZclStatusCodeT ZbZclPriceServerSendPublishCO2ValueRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPriceServerPublishCO2ValueT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish CO2 Value command as a response
Parameters
| info | Publish CO2 Value command structure |
Return
ZbZclPriceServerSendPublishCO2ValueUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishCO2ValueUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishCO2ValueT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish CO2 Value command
Parameters
Return
ZbZclPriceServerSendPublishCalorificValueRsp
enum ZclStatusCodeT ZbZclPriceServerSendPublishCalorificValueRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPriceServerPublishCalorificValueT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Calorific Value command as a response
Parameters
| info | Publish Calorific Value command structure |
Return
ZbZclPriceServerSendPublishCalorificValueUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishCalorificValueUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishCalorificValueT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Calorific Value command
Parameters
Return
ZbZclPriceServerSendPublishConsolidatedBillRsp
enum ZclStatusCodeT ZbZclPriceServerSendPublishConsolidatedBillRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPriceServerPublishConsolidatedBillT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Consolidated Bill command as a response
Parameters
| info | Publish Consolidated Bill command structure |
Return
- ZCL_STATUS_SUCCESS if successful, or other ZCL_STATUS value on error
ZbZclPriceServerSendPublishConsolidatedBillUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishConsolidatedBillUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishConsolidatedBillT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Consolidated Bill command
Parameters
| callback | Callback function that will be invoked when response is received, if one is expected. If broadcasting, then this should be set to NULL since no response is expected. |
Return
ZbZclPriceServerSendPublishConversionFactorRsp
enum ZclStatusCodeT ZbZclPriceServerSendPublishConversionFactorRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPriceServerPublishConversionFactorT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Conversion Factor command as a response
Parameters
| info | Publish Conversion Factor command structure |
Return
ZbZclPriceServerSendPublishConversionFactorUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishConversionFactorUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishConversionFactorT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Conversion Factor command
Parameters
Return
ZbZclPriceServerSendPublishCurrencyConversionRsp
enum ZclStatusCodeT ZbZclPriceServerSendPublishCurrencyConversionRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPriceServerPublishCurrencyConversionT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Currency Conversion command as a response
Parameters
| info | Publish Currency Conversion command structure |
Return
- ZCL_STATUS_SUCCESS or other ZCL_STATUS value on error
ZbZclPriceServerSendPublishCurrencyConversionUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishCurrencyConversionUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishCurrencyConversionT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Currency Conversion command
Parameters
Return
- ZCL_STATUS_SUCCESS if successful or other ZCL_STATUS value on error
ZbZclPriceServerSendPublishMatrixUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishMatrixUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishPriceMatrixT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Price Matrix command
Parameters
| info | Publish Price Matrix command structure |
Return
ZbZclPriceServerSendPublishPriceRsp
enum ZclStatusCodeT ZbZclPriceServerSendPublishPriceRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPriceServerPublishPriceT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Price command as a response
Parameters
| info | Publish Price command structure |
Return
- ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error
ZbZclPriceServerSendPublishPriceUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishPriceUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishPriceT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Price command
Parameters
Return
ZbZclPriceServerSendPublishTariffInfoUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishTariffInfoUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishTariffInfoT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Tariff Information command
Parameters
| info | Publish Tariff Info command structure |
Return
Enumerations
ZbZclPriceSvrAttrT
Price Server Attribute IDs
| ZCL_PRICE_SVR_ATTR_TIER1_LABEL | Tier1PriceLabel (Optional)
ZCL_PRICE_SVR_ATTR_TIERN_LABEL(1) For all the tiers, use the ZCL_PRICE_SVR_ATTR_TIERN_LABEL(tier) macro. |
| ZCL_PRICE_SVR_ATTR_BLOCK1_THRESHOLD | Block1Threshold (Optional)
ZCL_PRICE_SVR_ATTR_BLOCKN_THRESHOLD(1) For all the blocks, use the ZCL_PRICE_SVR_ATTR_BLOCKN_THRESHOLD(block) macro. For all tiers and blocks, use the ZCL_PRICE_SVR_ATTR_TIERN_BLOCKN_THRESHOLD(tier, block) macro |
| ZCL_PRICE_SVR_ATTR_BLOCK_THRESHOLD_COUNT | BlockThresholdCount (Optional) ZCL_PRICE_SVR_ATTR_TIERN_BLOCK_THRESHOLD_COUNT(0) For all the tiers, use the ZCL_PRICE_SVR_ATTR_TIERN_BLOCK_THRESHOLD_COUNT(tier) macro. |
| ZCL_PRICE_SVR_ATTR_START_OF_BLOCK_PERIOD | StartofBlockPeriod (Optional) |
| ZCL_PRICE_SVR_ATTR_BLOCK_PERIOD_DURATION | BlockPeriodDuration (Optional) |
| ZCL_PRICE_SVR_ATTR_THRESHOLD_MULTIPLIER | ThresholdMultiplier (Optional) |
| ZCL_PRICE_SVR_ATTR_THRESHOLD_DIVISOR | ThresholdDivisor (Optional) |
| ZCL_PRICE_SVR_ATTR_BLOCK_PERIOD_DURATION_TYPE | BlockPeriodDurationType (Optional) |
| ZCL_PRICE_SVR_ATTR_COMMODITY_TYPE | CommodityType (Optional) |
| ZCL_PRICE_SVR_ATTR_STANDING_CHARGE | StandingCharge (Optional) |
| ZCL_PRICE_SVR_ATTR_CONVERSION_FACTOR | ConversionFactor (Optional) |
| ZCL_PRICE_SVR_ATTR_CONVERSION_FACTOR_TRAILING_DIGIT | ConversionFactorTrailingDigit (Optional) |
| ZCL_PRICE_SVR_ATTR_CALORIFIC_VALUE | CalorificValue (Optional) |
| ZCL_PRICE_SVR_ATTR_CALORIFIC_VALUE_UNIT | CalorificValueUnit (Optional) |
| ZCL_PRICE_SVR_ATTR_CALORIFIC_VALUE_TRAILING_DIG IT | CalorificValueTrailingDigit (Optional) |
| ZCL_PRICE_SVR_ATTR_NO_TIER_BLOCK1_PRICE | NoTierBlock1Price (Optional) ZCL_PRICE_SVR_ATTR_NO_TIER_BLOCKN_PRICE(1) For all the blocks, use the ZCL_PRICE_SVR_ATTR_NO_TIER_BLOCKN_PRICE(block) macro. |
| ZCL_PRICE_SVR_ATTR_TIER1_BLOCK1_PRICE | Tier1Block1Price (Optional) ZCL_PRICE_SVR_ATTR_TIERN_BLOCKN_PRICE(1,1) For all the tiers and blocks, use the ZCL_PRICE_SVR_ATTR_TIERN_BLOCKN_PRICE(tier, block) macro. |
| ZCL_PRICE_SVR_ATTR_PRICE_TIER16 | PriceTier16 (Optional) ZCL_PRICE_SVR_ATTR_PRICE_TIERN(16) For all the tiers, use the ZCL_PRICE_SVR_ATTR_PRICE_TIERN(tier) macro. |
| ZCL_PRICE_SVR_ATTR_CPP1_PRICE | CPP1 Price (Optional) |
| ZCL_PRICE_SVR_ATTR_CPP2_PRICE | CPP2 Price (Optional) |
| ZCL_PRICE_SVR_ATTR_TARIFF_LABEL | TariffLabel (Optional) |
| ZCL_PRICE_SVR_ATTR_NO_PRICE_TIERS_IN_USE | NumberOfPriceTiersInUse (Optional) |
| ZCL_PRICE_SVR_ATTR_NO_BLOCK_THRESH_IN_USE | NumberOfBlockThresholdsInUse (Optional) |
| ZCL_PRICE_SVR_ATTR_TIER_BLOCK_MODE | TierBlockMode (Optional) |
| ZCL_PRICE_SVR_ATTR_UNIT_OF_MEASURE | UnitOfMeasure (Optional) |
| ZCL_PRICE_SVR_ATTR_CURRENCY | Currency (Optional) |
| ZCL_PRICE_SVR_ATTR_PRICE_TRAILING_DIGIT | PriceTrailingDigit (Optional) |
| ZCL_PRICE_SVR_ATTR_TARIFF_RESLTN_PERIOD | TariffResolutionPeriod (Optional) |
| ZCL_PRICE_SVR_ATTR_CO2 | CO2Value (Optional) |
| ZCL_PRICE_SVR_ATTR_CO2_UNIT | CO2ValueUnit (Optional) |
| ZCL_PRICE_SVR_ATTR_CO2_TRAILING_DIGIT | CO2TrailingDigit (Optional) |
| ZCL_PRICE_SVR_ATTR_CBP_START | CurrentBillingPeriodStart (Optional) |
| ZCL_PRICE_SVR_ATTR_CBP_DURATION | CurrentBillingPeriodDuration (Optional) |
| ZCL_PRICE_SVR_ATTR_LBP_START | LastBillingPeriodStart (Optional) |
| ZCL_PRICE_SVR_ATTR_LBP_DURATION | LastBillingPeriodDuration (Optional) |
| ZCL_PRICE_SVR_ATTR_LBP_CONSOLIDATED_BILL | LastBillingPeriodConsolidatedBill (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_DUE_DATE | CreditPaymentDueDate (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_STATUS | CreditPaymentStatus (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_OVERDUE_AMT | CreditPaymentOverdueAmount (Optional) |
| ZCL_PRICE_SVR_ATTR_PAYMENT_DISCOUNT | PaymentDiscount (Optional) |
| ZCL_PRICE_SVR_ATTR_PAYMENT_DISCOUNT_PERIOD | PaymentDiscountPeriod (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_1 | CreditPayment#1 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_DATE_1 | CreditPaymentDate#1 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_REF_1 | CreditPaymentRef#1 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_2 | CreditPayment#2 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_DATE_2 | CreditPaymentDate#2 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_REF_2 | CreditPaymentRef#2 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_3 | CreditPayment#3 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_DATE_3 | CreditPaymentDate#3 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_REF_3 | CreditPaymentRef#3 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_4 | CreditPayment#4 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_DATE_4 | CreditPaymentDate#4 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_REF_4 | CreditPaymentRef#4 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_5 | CreditPayment#5 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_DATE_5 | CreditPaymentDate#5 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_REF_5 | CreditPaymentRef#5 (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_TIER1_LABEL | ReceivedTier1PriceLabel ZCL_PRICE_SVR_ATTR_RECV_TIERN_LABEL(1) For all the tiers, use the ZCL_PRICE_SVR_ATTR_RECV_TIERN_LABEL(tier) macro. |
| ZCL_PRICE_SVR_ATTR_RECV_BLOCK1_THRESHOLD | ReceivedBlock1Threshold ZCL_PRICE_SVR_ATTR_RECV_BLOCKN_THRESHOLD(1)
For all the blocks, use the ZCL_PRICE_SVR_ATTR_RECV_BLOCKN_THRESHOLD(block) macro. |
| ZCL_PRICE_SVR_ATTR_RECV_START_OF_BLOCK_PERIOD | ReceivedStartofBlockPeriod (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_BLOCK_PERIOD_DURATION | ReceivedBlockPeriodDuration (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_THRESHOLD_MULTIPLIER | ReceivedThresholdMultiplier (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_THRESHOLD_DIVISOR | ReceivedThresholdDivisor (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_NO_TIER_BLOCK1_PRICE | RxNoTierBlock1Price ZCL_PRICE_SVR_ATTR_RECV_NO_TIER_BLOCKN_PRICE(1) For all the blocks, use the ZCL_PRICE_SVR_ATTR_RECV_NO_TIER_BLOCKN_PRICE(block) macro. |
| ZCL_PRICE_SVR_ATTR_RECV_TIER1_BLOCK1_PRICE | RxTier1Block1Price ZCL_PRICE_SVR_ATTR_RECV_TIERN_BLOCKN_PRICE(1,1)
For all the tiers and blocks, use the ZCL_PRICE_SVR_ATTR_RECV_TIERN_BLOCKN_PRICE(tier, block) macro. |
| ZCL_PRICE_SVR_ATTR_RECV_PRICE_TIER16 | RxPriceTier16 ZCL_PRICE_SVR_ATTR_RECV_PRICE_TIERN(16) For all the tiers, use the ZCL_PRICE_SVR_ATTR_RECV_PRICE_TIERN(tier) macro. |
| ZCL_PRICE_SVR_ATTR_RECV_TARIFF_LABEL | ReceivedTariffLabel (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_NO_PRICE_TIERS_IN_USE | ReceivedNumberOfPriceTiersInUse (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_NO_BLOCK_THRESH_IN_U SE | ReceivedNumberOfBlockThresholdsInUse (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_TIER_BLOCK_MODE | ReceivedTierBlockMode (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_TARIFF_RESLTN_PERIOD | ReceivedTariffResolutionPeriod (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_CO2 | ReceivedCO2Value (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_CO2_UNIT | ReceivedCO2ValueUnit (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_CO2_TRAILING_DIGIT | ReceivedCO2TrailingDigit (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_CBP_START | ReceivedCurrentBillingPeriodStart (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_CBP_DURATION | ReceivedCurrentBillingPeriodDuration (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_LBP_START | ReceivedLastBillingPeriodStart (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_LBP_DURATION | ReceivedLastBillingPeriodDuration (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_LBP_CONSOLIDATED_BILL | ReceivedLastBillingPeriodConsolidatedBill (Optional) |
ZbZclPriceTariffChargingSchemeT
Tariff Charging Scheme Enumeration
| ZCL_PRICE_CHARGE_TOU_TARIFF | TOU Tariff |
| ZCL_PRICE_CHARGE_BLOCK_TARIFF | Block Tariff |
| ZCL_PRICE_CHARGE_BLOCK_TOU_COMM_THRESH | Block/TOU Tariff with common thresholds |
| ZCL_PRICE_CHARGE_BLOCK_TOU_IND_THRESH | Block/TOU Tariff with individual thresholds per tier |
ZbZclPriceTariffTypeT
Tariff Type Enumeration
| ZCL_PRICE_TARIFF_TYPE_DELIV | Delivered tariff |
| ZCL_PRICE_TARIFF_TYPE_RECV | Received tariff |
| ZCL_PRICE_TARIFF_TYPE_DELIV_RECV | Delivered and received tariff |
| ZCL_PRICE_TARIFF_TYPE_UNSPECIFIED | Unspecified tariff type, meaning any tariff type. |
ZbZclPriceTierBlockModeT
Tier Block Mode Enumeration
| ZCL_PRICE_TIER_BLOCK_MODE_0 | This tariff employs a single set of thresholds. |
| ZCL_PRICE_TIER_BLOCK_MODE_1 | This tariff employs a single set of thresholds common across all TOU tiers. |
| ZCL_PRICE_TIER_BLOCK_MODE_2 | This combination tariff employs an individual set of Thresholds for each TOU tier. |
Structures
Price Client callbacks configuration
Parameters
| publish_price
enum ZclStatusCodeT (*publish_price)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishPriceT *price, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Price command. |
| publish_conversion_factor
enum ZclStatusCodeT (*publish_conversion_factor)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishConversionFactorT *co2, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Conversion Factor command. |
| publish_calorific_value
enum ZclStatusCodeT (*publish_calorific_value)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishCalorificValueT *calorific, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Calorific Value command. |
| publish_tariff_info
enum ZclStatusCodeT (*publish_tariff_info)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishTariffInfoT *tariff_info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Tariff information command. |
| publish_price_matrix
enum ZclStatusCodeT (*publish_price_matrix)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishPriceMatrixT *price_matrix, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Price Matrix command. |
| publish_block_thresholds
enum ZclStatusCodeT (*publish_block_thresholds)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishBlockThresholdsT *block_threshs, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Block Thresholds command. |
| publish_block_period
enum ZclStatusCodeT (*publish_block_period)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishBlockPeriodT *block_period, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Block Period command. |
| publish_co2_value
enum ZclStatusCodeT (*publish_co2_value)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishCO2ValueT *co2, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish CO2 Value command. |
| publish_billing_period
enum ZclStatusCodeT (*publish_billing_period)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishBillingPeriodT *period, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Billing Period command. |
| publish_consolidated_bill
enum ZclStatusCodeT (*publish_consolidated_bill)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishConsolidatedBillT *bill, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Consolidated Bill command. |
| publish_currency_conversion
enum ZclStatusCodeT (*publish_currency_conversion)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishCurrencyConversionT *conversion, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Currency Conversion command. |
| optional
enum ZclStatusCodeT (*optional)(struct ZbZclClusterT *cluster, struct ZbZclHeaderT *zclHdrPtr, struct ZbApsdeDataIndT *dataIndPtr)
Callback to application, invoked on receipt of optional Server commands. |
Parameters
| uint32_t earliest_start_time | Earliest Start Time |
| uint32_t min_issuer_event_id | Min. Issuer Event ID |
| uint8_t num_commands | Number of Commands |
| enum ZbZclPriceTariffTypeT tariff_type | Optional - Tariff Type |
Get Block Period command structure
Parameters
| uint32_t start_time | Start Time - UTC Time |
| uint8_t num_events | Number of Events requested |
| enum ZbZclPriceTariffTypeT tariff_type | Tariff Type |
Parameters
| uint32_t issuer_tariff_id | Issuer Tariff ID |
Parameters
Parameters
Parameters
Parameters
ZbZclPriceClientGetCurrentPriceT
Get Current Price command structure
Parameters
| uint8_t command_options | Command Options |
Parameters
Parameters
| uint32_t startTime | StartTime |
| uint8_t maxPrices | NumberofEvents |
Parameters
Parameters
| uint32_t price_ack_time | Price Ack Time |
| uint8_t control | Control. E.g. ZCL_PRICE_CTRL_MASK_PRICE_ACK |
ZbZclPriceServerBlockThreshEntryT
Block Threshold Entry structure
Parameters
| uint8_t tier_num_block_thresh | Tier/NumberOfBlockThresholds |
| uint64_t *block_thresh | Block Threshold |
Price Server callbacks configuration
Parameters
| get_current_price
enum ZclStatusCodeT (*get_current_price)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetCurrentPriceT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Current command. Return ZCL_STATUS_SUCCESS if Publish Price command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| price_ack
enum ZclStatusCodeT (*price_ack)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientPriceAckT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Price Acknowledgement command. |
| get_scheduled_prices
enum ZclStatusCodeT (*get_scheduled_prices)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetScheduledPricesT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Scheduled Prices command. Return ZCL_STATUS_SUCCESS if relevant Events are sent in Publish Price commands or ZCL_STATUS_NOT_FOUND otherwise. |
| get_tariff_info
enum ZclStatusCodeT (*get_tariff_info)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetTariffInfoT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Tariff Information command. Return ZCL_STATUS_SUCCESS if Publish Tariff Information command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| get_price_matrix
enum ZclStatusCodeT (*get_price_matrix)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetPriceMatrixT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Price Matrix command. Return ZCL_STATUS_SUCCESS if Publish Price Matrix command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| get_block_thresholds
enum ZclStatusCodeT (*get_block_thresholds)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetBlockThresholdsT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Block Thresholds command. Return ZCL_STATUS_SUCCESS if Publish Block Thresholds command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| get_calorific_value
enum ZclStatusCodeT (*get_calorific_value)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetCalorificValueT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Calorific Value command. Return ZCL_STATUS_SUCCESS if Publish Calorific Value command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| get_co2_value
enum ZclStatusCodeT (*get_co2_value)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetCO2ValueT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get CO2 Value command. Return ZCL_STATUS_SUCCESS if Publish CO2 Value command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| get_conversion_factor
enum ZclStatusCodeT (*get_conversion_factor)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetConversionFactorT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Conversion Factor command. Return ZCL_STATUS_SUCCESS if Publish Conversion Factor command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| get_block_period
enum ZclStatusCodeT (*get_block_period)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetBlockPeriodT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Block Period command. Return ZCL_STATUS_SUCCESS if Publish Block Period command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| get_billing_period
enum ZclStatusCodeT (*get_billing_period)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetBillingPeriodT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Billing Period command. Return ZCL_STATUS_SUCCESS if Publish Billing Period command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| get_consolidated_bill
enum ZclStatusCodeT (*get_consolidated_bill)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetConsolidatedBillT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Consolidated Bill command. Return ZCL_STATUS_SUCCESS if Publish Consolidated Bill command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| get_currency_conversion
enum ZclStatusCodeT (*get_currency_conversion)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Currency Conversion command. Return ZCL_STATUS_SUCCESS if Publish Currency Conversion command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| optional
Callback to application, invoked on receipt of optional Client commands. |
ZbZclPriceServerPriceMatrixEntryT
Price Matrix Entry structure
Parameters
| uint8_t tier_block_id | Tier/Block ID |
| uint32_t price | Price |
Parameters
| uint32_t start_time | Billing Period Start Time - UTC Time |
| uint32_t duration | Billing Period Duration |
| uint8_t duration_type | Billing Period Duration Type |
Parameters
| uint32_t block_period_start_time | Block Period Start Time - UTC Time |
| uint32_t block_period_duration | Block Period Duration |
| uint8_t block_period_control | Block Period Control |
| uint8_t block_period_duration_type | Block Period Duration Type |
| uint8_t tariff_resolution_period | Tariff Resolution Period |
Parameters
| uint8_t total_number_commands | Total Number of Commands |
| uint8_t sub_payload_control | Sub-payload Control |
| uint8_t num_sub_payload | Number of items in Block Threshold Sub-payload |
| struct ZbZclPriceServerBlockThreshEntryT sub_payload | Block Threshold Sub-payload |
Parameters
| uint32_t co2_value | CO2 Value |
| uint8_t co2_value_unit | CO2 Value Unit |
| uint8_t co2_value_trail_digits | CO2 Value Trailing Digit |
Parameters
| uint32_t calorific_value | Calorific Value |
| uint8_t calorific_value_unit | Calorific Value Unit |
| uint8_t calorific_value_trail_digits | Calorific Value Trailing Digit |
Parameters
| uint32_t consolidated_bill | Consolidated Bill |
| uint16_t currency | Currency |
| uint8_t bill_trail_digits | Bill Trailing Digit |
Parameters
| uint32_t conversion_factor | Conversion Factor |
| uint8_t conversion_factor_trail_digits | Conversion Factor Trailing Digit |
Parameters
| uint16_t old_currency | Old Currency |
| uint16_t new_currency | New Currency |
| uint8_t conversion_trail_digits | Conversion Trailing Digit |
| uint32_tcurrency_change_control_flags | Currency Change Control Flags |
Parameters
| uint8_t num_sub_payload | Number of items in Price Matrix Sub-payload |
| struct ZbZclPriceServerPriceMatrixEntryT
sub_payload |
Parameters
| char rate_label | Rate Label array |
| uint32_t current_Time | Current Time - UTC Time |
| enum ZbZclMeterUnitsT
unit_of_measure |
Unit of Measure |
| enum ZbZclPriceCurrencyCodeT
currency |
Currency |
| uint8_t trailing_digit_and_price_tier | Price Trailing Digit & Price Tier |
| uint8_t num_price_tiers | Number of Price Tiers & Register Tier |
| uint16_t duration | Duration in Minutes |
| uint8_t price_ratio | Price Ratio (Optional) |
| uint32_t generation_price | Generation Price (Optional) |
| uint8_t generation_price_ratio | Generation Price Ratio (Optional) |
| uint32_t alternate_cost_delivered | Alternate Cost Delivered (Optional) |
| uint8_t alternate_cost_units | Alternate Cost Unit (Optional) |
| uint8_t alternate_cost_trail_digits | Alternate Cost Trailing Digit (Optional) |
| uint8_t num_block_thresholds | Number of Block Thresholds (Optional) |
| uint8_t price_control | Price Control (Optional) |
| uint8_t number_of_gen_tiers | Number of Generation Tiers (Optional) |
| uint8_t gen_tier | Generation Tier (Optional) |
| uint8_t ext_number_price_tiers | Extended Number of Price Tiers (Optional) |
| uint8_t ext_price_tier | Extended Price Tier (Optional) |
| uint8_t ext_register_tier | Extended Register Tier (Optional) |
Parameters
| uint8_t
tariff_type_and_charging_scheme |
Tariff Type/Charging Scheme |
| char tariff_label | Tariff Label array |
| uint8_t number_of_price_tiers_in_use | Number of Price Tiers in Use |
| uint8_t
number_of_block_thresh_in_use |
Number of Block Thresholds in Use |
| uint8_t unit_of_measure | Unit of Measure |
| uint8_t price_trailing_digit | Price Trailing Digit |
| uint32_t standing_charge | Standing Charge |
| uint8_t tier_block_mode | TierBlockMode |
| uint32_t block_thresh_multiplier | Block Threshold Multiplier - 24-bit |
| uint32_t block_thresh_divisor | Block Threshold Divisor - 24-bit |
6.4.10. Tunneling
#include "zcl/se/zcl.tunnel.h"
Functions
ZbZclTunnelClientAddProto
enum ZclStatusCodeT ZbZclTunnelClientAddProto(struct ZbZclClusterT *cluster, enum ZbZclTunnelProtocolT protocol, uint16_t mfr, uint16_t mtu, struct ZbZclTunnelProtoCbT *callbacks);
Add a protocol tunnel to the server
Parameters
| protocol | Protocol ID enumeration |
| mfr | Manufacturer ID |
| mtu | Protocol’s MTU |
| callbacks | Protocol callbacks |
Return
ZbZclTunnelClientAlloc
struct ZbZclClusterT * ZbZclTunnelClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Tunneling Client cluster
Parameters
Return
ZbZclTunnelClientCloseQuietReq
enum ZclStatusCodeT ZbZclTunnelClientCloseQuietReq(struct ZbZclClusterT *cluster);
Close the local tunnel without informing the server
Parameters
Return
ZbZclTunnelClientCloseReq
enum ZclStatusCodeT ZbZclTunnelClientCloseReq(struct ZbZclClusterT *cluster, struct ZbZclTunnelCloseT *close, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Close Tunnel command
Parameters
| close | Close Tunnel command structure. |
Return
ZbZclTunnelClientGetSupportedProtocols
enum ZclStatusCodeT ZbZclTunnelClientGetSupportedProtocols(struct ZbZclClusterT *cluster, struct ZbApsAddrT *dst, struct ZbZclTunnelGetSupportedProtocolsT *suppported_proto, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Get Supported Protocols command
Parameters
| dst | Destination address for this command. |
| suppported_proto | Get Supported Protocol command structure. |
Return
ZbZclTunnelClientSendReq
enum ZclStatusCodeT ZbZclTunnelClientSendReq(struct ZbZclClusterT *cluster, struct ZbZclTunnelDataT *data, void (*callback)(struct ZbZclCommandRspT *rspPr, void *arg), void *arg);
Send a Transfer Data command
Parameters
| data | Tunnel Data information structure. |
Return
ZbZclTunnelMirrorAlloc
struct ZbZclClusterT * ZbZclTunnelMirrorAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *tunnel, struct ZbZclClusterT *meter_mirror);
Allocates a Tunneling Client/Server Mirror cluster. The caller (application) must attach any attributes to the cluster you want to mirror.
Parameters
| events_client | Pointer to Events Client cluster. This is used by the Metering Mirror to send mirrored commands to the BOMD. |
Return
ZbZclTunnelSendData
enum ZclStatusCodeT ZbZclTunnelSendData(struct ZbZclClusterT *cluster, struct ZbZclTunnelStateT *state, struct ZbZclTunnelDataT *data, void (*callback)(struct ZbZclCommandRspT *rspPtr, void *arg), void *arg);
Send data via the tunnel. If the input cluster is server then the data will be sent to the client and vice versa.
Parameters
| state | State of the tunnel |
| callback | Callback function to handle response |
Return
ZbZclTunnelServerAddProto
enum ZclStatusCodeT ZbZclTunnelServerAddProto(struct ZbZclClusterT *cluster, enum ZbZclTunnelProtocolT protocol, uint16_t mfr, uint16_t mtu, struct ZbZclTunnelProtoCbT *callbacks);
Parameters
Return
ZbZclTunnelServerAlloc
struct ZbZclClusterT * ZbZclTunnelServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Tunneling Server cluster
Parameters
Return
ZbZclTunnelServerStateFindById
struct ZbZclTunnelStateT * ZbZclTunnelServerStateFindById(struct ZbZclClusterT *cluster, uint16_t tunnel_id);
Get tunnel server state by tunnel ID
Parameters
| tunnel_id | Tunnel ID |
Return
- State of the tunnel
ZbZclTunnelStateGetDataLen
uint32_t ZbZclTunnelStateGetDataLen(struct ZbZclTunnelStateT *state, bool clear_data);
Get received data length using Tunneling Cluster State structure
Parameters
| state | Tunneling Cluster State structure |
| clear_data | If true, clear any data queued in the tunnel. The application would first call ZbZclTunnelStateGetDataLen with clear_data set to false to get the length and process the data. Once complete, it will call ZbZclTunnelStateGetDataLen with clear_data set to true. |
Return
- Length of data in the buffer
ZbZclTunnelStateGetDataPtr
uint8_t * ZbZclTunnelStateGetDataPtr(struct ZbZclTunnelStateT *state);
Get received data using Tunneling Cluster State structure
Parameters
Return
- Pointer to received data buffer. Length of data is determined by ZbZclTunnelStateGetDataLen.
ZbZclTunnelStateGetId
uint16_t ZbZclTunnelStateGetId(struct ZbZclTunnelStateT *state);
Get ID using Tunneling Cluster State structure
Parameters
Return
- Allocated tunnel ID
ZbZclTunnelStateGetMtu
uint16_t ZbZclTunnelStateGetMtu(struct ZbZclTunnelStateT *state);
Get the current tunnel’s MTU, which is the smaller of the two side’s MTUs.
Parameters
Return
- MTU size in bytes
ZbZclTunnelStateGetProtocol
enum ZbZclTunnelProtocolT ZbZclTunnelStateGetProtocol(struct ZbZclTunnelStateT *state);
Get Tunneling Protocol Instance using Tunneling Cluster State structure
Parameters
Return
- Tunneling Protocol Instance structure
ZbZclTunnelStateGetRmtAddr
bool ZbZclTunnelStateGetRmtAddr(struct ZbZclTunnelStateT *state, uint64_t *addr, uint8_t *endpoint);
Get the current tunnel’s remote addressing.
Parameters
| addr | Pointer to write EUI-64 of the remote device’s address. |
| endpoint | Pointer to write EUI-64 of the remote device’s endpoint. |
Return
- True if address info is present and valid, false otherwise.
Enumerations
Tunneling Protocol ID enumerations
| ZCL_TUNNEL_PROTO_DLMS_COSEM | DLMS/COSEM (IEC 62056) |
| ZCL_TUNNEL_PROTO_IEC_61107 | IEC 61107 |
| ZCL_TUNNEL_PROTO_ANSI_C12 | ANSI C12 |
| ZCL_TUNNEL_PROTO_M_BUS | M-BUS |
| ZCL_TUNNEL_PROTO_SML | SML |
| ZCL_TUNNEL_PROTO_CLIMATE_TALK | ClimateTalk |
| ZCL_TUNNEL_PROTO_GB_HRGP | GB-HRGP |
| ZCL_TUNNEL_PROTO_IPV4 | IP v4 |
| ZCL_TUNNEL_PROTO_IPV6 | IP v6 |
| ZCL_TUNNEL_PROTO_MANUF_MIN | Start of manufacturer specific protocols. For values greater than or equal to this value, the Protocol Id and Manufacturer Code must match. |
| ZCL_TUNNEL_PROTO_RESERVED | Reserved |
ZbZclTunnelStatusT
Tunneling Status Values
| ZCL_TUNNEL_STATUS_SUCCESS | Success |
| ZCL_TUNNEL_STATUS_BUSY | Busy |
| ZCL_TUNNEL_STATUS_NO_RESOURCES | No more tunnel IDs |
| ZCL_TUNNEL_STATUS_PROTO_UNSUPPORTED | Protocol not supported |
| ZCL_TUNNEL_STATUS_FLOW_UNSUPPORTED | Flow control not supported |
ZbZclTunnelSvrAttrT
Tunneling Server Attribute IDs
| ZCL_TUNNEL_SVR_ATTR_TIMEOUT | CloseTunnelTimeout |
| ZCL_TUNNEL_SVR_ATTR_NUM_TUNNELS | This is an internal attribute that can be used by the application to set the number of tunnels that tunnel server shall support. After this, the server shall return NO_RESOURCES error for any request to create the tunnel. by default it is set to ZCL_TUNNEL_SVR_NUM_TUNNELS_MAX. |
| ZCL_TUNNEL_SVR_ATTR_PERSIST | This is an internal attribute used to read/write the tunnel data from/to tunnel server. |
ZbZclTunnelXferStatusT
Tunneling Transfer Data Status Values
| ZCL_TUNNEL_XFER_STATUS_NO_TUNNEL | No such tunnel |
| ZCL_TUNNEL_XFER_STATUS_WRONG_DEVICE | Wrong device |
| ZCL_TUNNEL_XFER_STATUS_OVERFLOW | Data overflow |
| ZCL_TUNNEL_XFER_STATUS_NO_RESPONSE | No Response - If zcl_tunnel_handle_data returns ZCL_TUNNEL_XFER_STATUS_NO_RESPONSE, don’t send a response |
Structures
ZbZclTunnelCloseT
Parameters
| uint8_t mirror_ep | ESI Mirror endpoint to send Tunnel data in case the destination is BOMD and to_bomd flag is set to 'true'. |
ZbZclTunnelConnectT
Request Tunnel command structure
Parameters
ZbZclTunnelDataT
Tunnel Data command structure
Parameters
| uint8_t *data | Pointer to the data being sent over the Tunnel. |
| uint16_t len | Data length. |
Get Supported Protocols command structure
Parameters
| uint8_t protocol_offset | Protocol offset |
ZbZclTunnelProtoCbT
ZbZclTunnelServerAddProto and ZbZclTunnelClientAddProto callback data structure
Parameters
| request
enum ZbZclTunnelStatusT (*request)(struct ZbZclClusterT *clusterPtr, struct ZbZclTunnelStateT *statePtr, void *priv)
Callback to handle a Request Tunnel (ZCL_TUNNEL_CLI_CMD_REQUEST) command. The callback returns a tunnel state structure, which is used to identify the tunnel to the server cluster. It is an opaque structure, meaning the application does not have access to the internals, but the application can call functions such as ZbZclTunnelStateGetId to get the tunnel Id from the state. |
| input
void (*input)(struct ZbZclClusterT *clusterPtr, struct ZbZclTunnelStateT *statePtr, void *priv)
Callback to handle received data from the tunnel (ZCL_TUNNEL_CLI_CMD_DATA). The application uses the ZbZclTunnelStateGetDataPtr and ZbZclTunnelStateGetDataLen to get the current received data queued in the tunnel cluster. |
| close
void (*close)(struct ZbZclClusterT *clusterPtr, struct ZbZclTunnelStateT *statePtr, void *priv)
Callback to handle a Close Tunnel command, to close the tunnel (Optional). |
| error
bool (*error)(struct ZbZclClusterT *clusterPtr, struct ZbZclTunnelStateT *statePtr, void *priv, enum ZbZclTunnelXferStatusT status)
Callback to handle an Error command (ZCL_TUNNEL_SVR_CMD_ERROR) (Optional). Return false if tunnel should also be closed. Return true to keep tunnel open and continue normally. |
| void *priv | Application private data pointer |
7. References
