1. Scope
This wiki describes the implementation of the Exegin ZSDK (Zigbee software design kit) API (application programming interface) for Zigbee on the STM32WBA Series based on V1.5 STM32Cube Firmware release supporting R23_FFD [1]. It describes all APIs used to control the stack. In particular, it covers APIs used to access to the following layers: BDB (base device behavior), APS (applications services), NWK (network layer services) and ZDO (Zigbee device object).
2. Zigbee stack handle
The stack is initialized by calling the function ZbInit(), which returns a stack instance handle of type ZigBeeT *. To the application this is an anonymous pointer, the contents of which are private to the stack. The application should only interact with ZigBeeT * to provide it back to the stack when calling most stack API functions. For this reason, stack API functions follow this format:
ZbFunc(struct ZigBeeT *zb, ...)
3. Status codes
Many functions in the Zigbee stack return a status code as an enumeration. The general status codes are the most common, and are included below as an example of their format.
3.1. General status codes
| Value | Status Code |
| 0x00 | ZB_STATUS_SUCCESS |
| 0x70 | ZB_STATUS_ALLOC_FAIL |
| 0x71 | ZB_STATUS_TIMEOUT |
3.2. ZDP status codes
| Status Value | Status Code |
| 0x00 | ZB_ZDP_STATUS_SUCCESS |
| 0x80 | ZB_ZDP_STATUS_INV_REQTYPE |
| 0x81 | ZB_ZDP_STATUS_DEVNOTFOUND |
| 0x82 | ZB_ZDP_STATUS_INVALID_EP |
| 0x83 | ZB_ZDP_STATUS_NOT_ACTIVE |
| 0x84 | ZB_ZDP_STATUS_NOT_SUPPORTED |
| 0x85 | ZB_ZDP_STATUS_TIMEOUT |
| 0x86 | ZB_ZDP_STATUS_NO_MATCH |
| 0x88 | ZB_ZDP_STATUS_NO_ENTRY |
| 0x89 | ZB_ZDP_STATUS_NO_DESCRIPTOR |
| 0x8a | ZB_ZDP_STATUS_INSUFFICIENT_SPACE |
| 0x8b | ZB_ZDP_STATUS_NOT_PERMITTED |
| 0x8c | ZB_ZDP_STATUS_TABLE_FULL |
| 0x8d | ZB_ZDP_STATUS_NOT_AUTHORIZED |
| 0x8e | ZB_ZDP_STATUS_DEVICE_BINDING_TABLE_FULL |
| 0x8f | ZB_ZDP_STATUS_INVALID_INDEX |
3.3. APS status codes
| 0x00 | ZB_APS_STATUS_SUCCESS |
| 0xa0 | ZB_APS_STATUS_ASDU_TOO_LONG |
| 0xa1 | ZB_APS_STATUS_DEFRAG_DEFERRED |
| 0xa2 | ZB_APS_STATUS_DEFRAG_UNSUPPORTED |
| 0xa3 | ZB_APS_STATUS_ILLEGAL_REQUEST |
| 0xa4 | ZB_APS_STATUS_INVALID_BINDING |
| 0xa5 | ZB_APS_STATUS_INVALID_GROUP |
| 0xa6 | ZB_APS_STATUS_INVALID_PARAMETER |
| 0xa7 | ZB_APS_STATUS_NO_ACK |
| 0xa8 | ZB_APS_STATUS_NO_BOUND_DEVICE |
| 0xa9 | ZB_APS_STATUS_NO_SHORT_ADDRESS |
| 0xaa | ZB_APS_STATUS_NOT_SUPPORTED |
| 0xab | ZB_APS_STATUS_SECURED_LINK_KEY |
| 0xac | ZB_APS_STATUS_SECURED_NWK_KEY |
| 0xad | ZB_APS_STATUS_SECURITY_FAIL |
| 0xae | ZB_APS_STATUS_TABLE_FULL |
| 0xaf | ZB_APS_STATUS_UNSECURED |
| 0xb0 | ZB_APS_STATUS_UNSUPPORTED_ATTRIBUTE |
4. Timers
Timers are fundamental to the operation of the stack. The stack uses many different timers internally, and timer operation impacts events such as timeout. Some APIs have been exposed so applications may use the timer.
4.1. ZbTimerAlloc()
A timer is created by calling ZbTimerAlloc() along with a callback function (app_timer_callback). This callback will be invoked when the timer expires.
ZbTimerAlloc() Example
struct ZbTimerT *timer; timer = ZbTimerAlloc(zb, app_timer_callback, NULL);
4.2. ZbTimerReset()
Once created, the timer must be reset to become active. The following example will reset and start the timer with a delay of 1000 ms or 1 sec, and includes the necessary application callback function.
ZbTimerReset() Prototype
ZbTimerReset(timer, 1000); static void app_timer callback(struct ZigBeeT *zb, void *arg)
4.3. ZbTimerStop()
Stop a timer before it expires.
ZbTimerStop() Prototype
ZbTimerStop(timer);
4.4. ZbTimerRemaining()
Returns the time remaining in milliseconds before the timer expires.
ZbTimerRemaining() Prototype
ZbTimerRemaining(timer);
Will return UINT_MAX if the timer is not running.
4.5. ZbTimerFree()
Frees a timer.
ZbTimerFree() Prototype
ZbTimerFree(timer);
4.6. ZbTimerChangeCallback()
Changes the callback function for the specified timer, without the need to free and allocate a new timer.
ZbTimerChangeCallback() Prototype
void ZbTimerChangeCallback(struct ZbTimerT *timer, void (*callback)(struct ZigBeeT *zb, void *cb_arg), void *arg);
Parameters
- timer – Zigbee timer structure
- zb – Zigbee stack structure
- arg – callback argument
4.7. ZbTimerRunning()
Returns true if the given timer is active.
ZbTimerRunning() Prototype
bool ZbTimerRunning(struct ZbTimerT *timer);
Parameters
4.8. ZbUptime()
Retrieves the current uptime in milliseconds. This is typically only used internally by the stack for the timers.
ZbUptime() Prototype
ZbUptimeT ZbUptime(void);
Returns the current uptime in milliseconds. Note that this function will never return 0. Values are from 1 to ZB_UPTIME_MAX.
4.9. ZbTimeoutRemaining()
Used with ZbUptime. This function returns the time difference between expire_time and now, or 0 if the time has expired (now >= expire_time). This function handles the case where the time value has rolled over starting back from 0.
ZbTimeoutRemaining() Prototype
unsigned int ZbTimeoutRemaining(ZbUptimeT now, ZbUptimeT expire_time);
Parameters
- now – current time
- expire_time – The time when the timer was set to expire
5. Packet and message filters
Packet and message filters are primarily used internally by the stack. Typical applications will not need to use packet and message filters. Message filters are so central to stack operation that they afford a mechanism for applications to extend stack functionality. As messages traverse the stack, through the MAC, NWK, APS, ZDO or ZCL layers, filters are used to direct messages to the appropriate destination. A filter is defined with certain criteria. When a message is processed, the filters are checked and matching messages are directed to the requesting filter.
6. MAC initialization
The stack can operate on many different real and virtual MAC interfaces. Physical devices can be connected by SPI, UART, or USB. The MAC and stack can be coresident, or operate on separate MCUs. When on a separate MCU, Exegin SIO, MCP (MAC Control Protocol) or a proprietary protocol may be used.
Device options and configuration are highly variably. The specific API is device-dependent. However. The ultimate goal is for a WpanPublicT *device pointer to be created and passed to the stack, which has no knowledge of the device used.
6.1. Bare Metal device initialization
The device accesses the radio through the use of memory-mapped registers. On powerup, the radio hardware must be initialized. In this case, the PHY is local so that hardware specific PHY device is created, and a MAC instance created which uses this PHY interface.
Bare Metal device initialization example
#include "phy.h" #include "wpan_mac_init.h" WpanPublicT *device; struct phyif phy; uint64_t ext_addr; /* initialize radio */ radio_init(&phy); ext_addr = radio_get_ext_addr(); /* obtain from device */ /* optional callbacks not used for simplicity */ device = WpanMacInit(&phy, ext_addr, NULL, NULL);
7. Network management
ZbStartup executes the standard startup procedure. The startup function handles callbacks from the stack to maintain the network and security processes. For example, these include the handling of APSME-UPDATEDEVICE.indication messages when acting as a coordinator trust center, to handle the authentication procedure described in section 4.6.3.2 of the Zigbee specification document.
The message callback handlers can be overridden by the application by creating message filters using ZbMsgFilterRegister. This function and the entire startup code can be bypassed by the application, and the network layer APIs used directly, if so desired. If security is enabled (nwkSecurityLevel != 0), this function overloads the APSME callback functions and performs the authentication procedure.
This is purely a helper function, and if finer-grained control of startup and authentication is necessary then the application can perform these tasks manually.
8. Stack configuration
Most stack configuration parameters are controlled by the ZbStartupT structure passed to ZbStartup1.
ZbStartupT Structure
struct ZbStartupT config;
There are many configuration settings. Most applications want to first initialize the configuration with the default ZigBee PRO settings, or the default smart energy application settings:
Zigbee Pro startup default configuration
ZbStartupConfigGetProDefaults(&config);
Zigbee Smart Energy startup default configuration
ZbStartupConfigGetProSeDefaults(&config);
These functions do not set the channel list, which must be set manually by the application.
The following shows how to set the available channels (channel mask) to 11 and 15 on channel page 0 (2.4 GHz):
Setting the channel list
config.channelList.list[0].page = 0; config.channelList.list[0].channelMask = (uint32_t)((1ul << 11) | (1ul << 15)); config.channelList.count = 1;
Each page must have its own mask. The list can contain a total of MAX_CHANNEL_LIST_ENTRIES.
A common configuration is the commissioning mode.
Commissioning mode configuration
config.bdbCommissioningMode |= BDB_COMMISSION_MODE_FIND_BIND;
The Touchlink commissioning mode is used frequently.
Touchlink commissioning mode configuration
config.bdbCommissioningMode |= BDB_COMMISSION_MODE_TOUCHLINK; config.touchlink.flags = 0; config.touchlink.zb_info = ZCL_TL_ZBINFO_TYPE_ROUTER; config.touchlink.zb_info |= ZCL_TL_ZBINFO_RX_ON_IDLE;
9. APS layer
9.1. Functions
9.1.1. ZbApsAddrIsBcast
bool ZbApsAddrIsBcast(const struct ZbApsAddrT *addr);
Check if an address is set to broadcast.
Parameters
| addr | Address to check |
Return
- Returns true if the address is set to broadcast, false otherwise
9.1.2. ZbApsAddrIsLocal
bool ZbApsAddrIsLocal(struct ZigBeeT *zb, const struct ZbApsAddrT *addr);
Check if an address is that of the provided Zigbee stack structure.
Parameters
| zb | Zigbee stack instance |
Return
- Returns true if the address is local, false otherwise.
9.1.3. ZbApsBindSrcExists
bool ZbApsBindSrcExists(struct ZigBeeT *zb, uint8_t endpoint, uint16_t clusterId);
Returns true if there is a binding entry in the Binding Table that matches the local device as the source address, and a matching source endpoint and cluster Id.
Parameters
| endpoint | Source endpoint |
| clusterId | Cluster Id |
Return
- Returns true if binding exists, false otherwise.
9.1.4. ZbApsCommandSecurityCheck
bool ZbApsCommandSecurityCheck(struct ZigBeeT *zb, enum ZbApsCmdIdT cmdId, uint64_t srcExtAddr, enum ZbSecEncryptT encryptKeyType);
Check if an incoming command has the appropriate security level.
Parameters
| cmdId | Command Id |
| srcExtAddr | Source extended address |
| encryptKeyType | Key type |
Return
- Returns true if the command is allowed, false otherwise
9.1.5. ZbApsEndpointExists
bool ZbApsEndpointExists(struct ZigBeeT *zb, uint8_t endpoint);
Determine if an endpoint currently exists.
Parameters
| endpoint | endpoint |
Return
- Returns true if the endpoint is found, false otherwise
9.1.6. ZbApsEndpointProfile
uint16_t ZbApsEndpointProfile(struct ZigBeeT *zb, uint8_t endpoint);
Retrieve the profile ID of an endpoint.
Parameters
Return
- Returns profile ID, or ZCL_PROFILE_WILDCARD (0xffff) on error
9.1.7. ZbApsFilterClusterAdd
struct ZbApsFilterT * ZbApsFilterClusterAdd(struct ZigBeeT *zb, uint8_t endpoint, uint16_t clusterId, uint16_t profileId, enum zb_msg_filter_rc (*callback) (struct ZbApsdeDataIndT *dataInd, void *cb_arg), void *arg);
Create an APSDE-DATA.indication filter for a specific endpoint and cluster Id. being filtered. For any incoming APS data packets that match this filter, the provided 'callback' function is called. The filter is freed by calling ZbApsFilterEndpointFree.
Parameters
| zb | Zigbee instance |
| endpoint | Endpoint Id to match with incoming packets |
| clusterId | Cluster Id to match with incoming packets |
| profileId | Profile Id to match with incoming packets |
| callback | APSDE-DATA.indication callback if the filter matches the incoming packet |
| arg | Application callback argument, which will be passed to callback() |
Return
- Filter pointer (handle)
9.1.8. ZbApsFilterEndpointAdd
struct ZbApsFilterT * ZbApsFilterEndpointAdd(struct ZigBeeT *zb, uint8_t endpoint, uint16_t profileId, enum zb_msg_filter_rc (*callback) (struct ZbApsdeDataIndT *dataInd, void *cb_arg), void *arg);
Create an APSDE-DATA.indication filter for a specific endpoint, with no specific cluster being filtered. For any incoming APS data packets that match this filter, the provided 'callback' function is called. The filter is freed by calling ZbApsFilterEndpointFree.
Parameters
| callback | APSDE-DATA.indication callback if the filter matches the incoming packet. |
Return
9.1.9. ZbApsFilterEndpointFree
Remove and free an APS indication filter.
void ZbApsFilterEndpointFree(struct ZigBeeT *zb, struct ZbApsFilterT *filter);
Parameters
| filter | Filter handle to remove and free |
Return
- Returns void
9.1.10. ZbApsFragDropTxAdd
bool ZbApsFragDropTxAdd(struct ZigBeeT *zb, uint8_t blockNum);
Used by the zbcli application as a DUT during ZCP certification testing (TP/PRO/BV-43 and TP/PRO/BV-44). It causes the stack to drop the next APS fragment to be transmitted matching the block number given by 'blockNum'.
Parameters
| blockNum | APS fragment block number to drop and prevent from being sent. |
Return
- True if the block number entry was created, false otherwise.
9.1.11. ZbApsFragDropTxClear
void ZbApsFragDropTxClear(struct ZigBeeT *zb);
Used by the zbcli application as a DUT during ZCP certification testing (TP/PRO/BV-43 and TP/PRO/BV-44). It clears all entries created by ZbApsFragDropTxAdd to drop APS fragments about to be transmitted. No fragments will be purposefully dropped after this point.
Parameters
Return
- Returns void
9.1.12. ZbApsGetIndex
enum ZbStatusCodeT ZbApsGetIndex(struct ZigBeeT *zb, enum ZbApsmeIbAttrIdT attrId, void *attrPtr, unsigned int attrSz, unsigned int attrIndex);
Performs an APSME-GET.request. Retrieve the value of the attribute corresponding to the supplied index.
Parameters
| attrId | Attribute Id |
| attrPtr | Attribute pointer |
| attrSz | attribute size |
Return
ZCL_STATUS_SUCCESSif successful, or otherZclStatusCodeTvalue on error
9.1.13. ZbApsGroupIsMember
bool ZbApsGroupIsMember(struct ZigBeeT *zb, uint16_t groupAddr, uint8_t endpoint);
Check if the local device is a member of a specified group.
Parameters
| groupAddr | Group address |
| endpoint | Endpoint of interest, or ZB_ENDPOINT_BCAST to determine if any endpoint is a member of the group |
Return
- Returns true if the device is a member, false otherwise
9.1.14. ZbApsGroupsGetCapacity
uint8_t ZbApsGroupsGetCapacity(struct ZigBeeT *zb);
Retrieve the number of free entries in the group table.
Parameters
Return
- Returns the number of free entries in the group table
9.1.15. ZbApsGroupsGetMembership
uint8_t ZbApsGroupsGetMembership(struct ZigBeeT *zb, uint8_t endpoint, uint16_t *group_list, uint8_t max_len);
Retrieve all group addresses on this endpoint.
Parameters
| group_list | (OUT) list of groups on this endpoint |
| max_len | Maximum number of groups to be returned |
Return
- Returns a number of group addresses
9.1.16. ZbApsLinkKeyExists
bool ZbApsLinkKeyExists(struct ZigBeeT *zb, uint64_t partner);
Check if a link key exists in the AIB.
Parameters
| Partner | address |
Return
- Returns true if the key exists, false otherwise
9.1.17. ZbApsLookupKey
struct ZbApsmeKeyPairT * ZbApsLookupKey(struct ZigBeeT *zb, struct ZbApsmeKeyPairT *key, uint64_t addr, unsigned int *idx);
Look up an APS key pair descriptor from the apsDeviceKeyPairSet AIB attribute/key table.
Parameters
| key | (OUT) key pair descriptor |
| addr | Partner addresses |
| idx | (OUT) index value into Device Key Pair Set Table for the APS key returned, if successful |
Return
- Returns key pair on success, or NULL if no such entry was found
9.1.18. ZbApsSetIndex
enum ZbStatusCodeT ZbApsSetIndex(struct ZigBeeT *zb, enum ZbApsmeIbAttrIdT attrId, const void *attrPtr, unsigned int attrSz, unsigned int attrIndex);
Performs an APSME-SET.request. Set the value of the attribute corresponding to the supplied index.
Parameters
Return
- ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error
9.1.19. ZbApsUnbindAllReq
void ZbApsUnbindAllReq(struct ZigBeeT *zb);
Remove all entries from the binding table.
Parameters
Return
- Returns void
9.1.20. ZbApsdeDataReqCallback
enum ZbStatusCodeT ZbApsdeDataReqCallback(struct ZigBeeT *zb, struct ZbApsdeDataReqT *req, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send an APSDE-DATA.request.
Parameters
| req | APSDE-DATA.request data structure |
| callback | Application callback to call for APSDE-DATA.confirm. May be set to NULL |
Return
- ZCL_STATUS_SUCCESS if the packet was queued, or other ZclStatusCodeT value on error
9.1.21. ZbApsmeAddEndpoint
void ZbApsmeAddEndpoint(struct ZigBeeT *zb, struct ZbApsmeAddEndpointReqT *r, struct ZbApsmeAddEndpointConfT *c);
Register an endpoint with the ZigBee stack. Typically called during initialization. Should be safe to call from an init function.
Parameters
| r | APSME-ADD-ENDPOINT.request |
| c | APSME-ADD-ENDPOINT.confirm |
Return
- Returns void
9.1.22. ZbApsmeAddGroupReq
void ZbApsmeAddGroupReq(struct ZigBeeT *zb, struct ZbApsmeAddGroupReqT *r, struct ZbApsmeAddGroupConfT *c);
Add an entry to the group table.
Parameters
| r | APSME-ADD-GROUP.request |
| c | APSME-ADD-GROUP.confirm |
Return
- Returns void
9.1.23. ZbApsmeAddKeyReq
void ZbApsmeAddKeyReq(struct ZigBeeT *zb, struct ZbApsmeAddKeyReqT *req, struct ZbApsmeAddKeyConfT *conf);
Perform an APSME-ADD-KEY.request.
Parameters
| req | APSME-ADD-KEY.request |
| conf | APSME-ADD-KEY.confirm |
Return
- Returns void
9.1.24. ZbApsmeBindReq
void ZbApsmeBindReq(struct ZigBeeT *zb, struct ZbApsmeBindReqT *bindReqPtr, struct ZbApsmeBindConfT *bindConfPtr);
Add an entry to the stack binding table. The size of the binding table is determined in the tableSizes parameter to ZbInit(). The binding table is maintained by the stack.
Parameters
| bindReqPtr | APSME-BIND.request |
| bindConfPtr | |
| APSME-BIND.confirm |
Return
- Returns void
9.1.25. ZbApsmeConfirmKeyReq
void ZbApsmeConfirmKeyReq(struct ZigBeeT *zb, struct ZbApsmeConfirmKeyReqT *req, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Perform an APSME-CONFIRM-KEY.request.
Parameters
| req | APSME-CONFIRM-KEY.request |
Return
- Returns void
9.1.26. ZbApsmeEndpointClusterListAppend
bool ZbApsmeEndpointClusterListAppend(struct ZigBeeT *zb, uint8_t endpoint, uint16_t cluster_id, bool is_input);
Add a cluster ID to the input cluster list of an existing endpoint.
Parameters
| cluster_id | ID of cluster to be added |
| is_input | true if input cluster, false if output cluster |
Return
- Returns true on success, false otherwise
9.1.27. ZbApsmeEndpointClusterListRemove
bool ZbApsmeEndpointClusterListRemove(struct ZigBeeT *zb, uint8_t endpoint, uint16_t cluster_id, bool is_input);
Remove a cluster from an endpoint’s cluster list.
Parameters
| cluster_id | ID of cluster to be removed |
Return
9.1.28. ZbApsmeGetKeyReq
void ZbApsmeGetKeyReq(struct ZigBeeT *zb, struct ZbApsmeGetKeyReqT *req, struct ZbApsmeGetKeyConfT *conf);
Perform an APSME-GET-KEY.request.
Parameters
| req | APSME-GET-KEY.request |
| conf | APSME-GET-KEY.confirm |
Return
- Returns void
9.1.29. ZbApsmeRemoveAllGroupsReq
void ZbApsmeRemoveAllGroupsReq(struct ZigBeeT *zb, struct ZbApsmeRemoveAllGroupsReqT *r, struct ZbApsmeRemoveAllGroupsConfT *c);
Remove all entries from the group table.
Parameters
| r | APSME-REMOVE-ALL-GROUPS.request |
| c | APSME-REMOVE-ALL-GROUPS.confirm |
Return
- Returns void
9.1.30. ZbApsmeRemoveDeviceReq
void ZbApsmeRemoveDeviceReq(struct ZigBeeT *zb, struct ZbApsmeRemoveDeviceReqT *req);
Perform an APSME-REMOVE-DEVICE.request.
Parameters
| req | APSME-REMOVE-DEVICE.request |
Return
- Returns void
9.1.31. ZbApsmeRemoveEndpoint
void ZbApsmeRemoveEndpoint(struct ZigBeeT *zb, struct ZbApsmeRemoveEndpointReqT *r, struct ZbApsmeRemoveEndpointConfT *c);
Unregister and remove an endpoint from the APS endpoint table. Typically called when terminating an application.
Parameters
| r | APSME-REMOVE-ENDPOINT.request |
| c | APSME-REMOVE-ENDPOINT.confirm |
Return
- Returns void
9.1.32. ZbApsmeRemoveGroupReq
void ZbApsmeRemoveGroupReq(struct ZigBeeT *zb, struct ZbApsmeRemoveGroupReqT *r, struct ZbApsmeRemoveGroupConfT *c);
Remove an entry from the group table
Parameters
| r | APSME-REMOVE-GROUP.request |
| c | APSME-REMOVE-GROUP.confirm |
Return
- Returns void
9.1.33. ZbApsmeRemoveKeyReq
void ZbApsmeRemoveKeyReq(struct ZigBeeT *zb, struct ZbApsmeRemoveKeyReqT *req, struct ZbApsmeRemoveKeyConfT *conf);
Perform an APSME-REMOVE-KEY.request.
Parameters
| req | APSME-REMOVE-KEY.request |
| conf | APSME-REMOVE-KEY.confirm |
Return
- Returns void
9.1.34. ZbApsmeRequestKeyReq
enum ZbStatusCodeT ZbApsmeRequestKeyReq(struct ZigBeeT *zb, struct ZbApsmeRequestKeyReqT *req);
Perform an APSME-REQUEST-KEY.request.
Parameters
| req | APSME-REQUEST-KEY.request |
Return
9.1.35. ZbApsmeSwitchKeyReq
void ZbApsmeSwitchKeyReq(struct ZigBeeT *zb, struct ZbApsmeSwitchKeyReqT *req);
Perform an APSME-SWITCH-KEY.request.
Parameters
| req | APSME-SWITCH-KEY.request |
Return
- Returns void
9.1.36. ZbApsmeTransportKeyReq
void ZbApsmeTransportKeyReq(struct ZigBeeT *zb, struct ZbApsmeTransportKeyReqT *req);
Perform an APSME-TRANSPORT-KEY.request.
Parameters
| req | APSME-TRANSPORT-KEY.request |
Return
- Returns void
9.1.37. ZbApsmeUnbindReq
void ZbApsmeUnbindReq(struct ZigBeeT *zb, struct ZbApsmeUnbindReqT *unbindReqPtr, struct ZbApsmeUnbindConfT *unbindConfPtr);
Remove an entry from the binding table.
Parameters
| unbindReqPtr | APSME-UNBIND.request |
| unbindConfPtr | APSME-UNBIND.confirm |
Return
- Returns void
9.1.38. ZbApsmeUpdateDeviceReq
enum ZbSecHdrKeyIdT ZbApsmeUpdateDeviceReq(struct ZigBeeT *zb, struct ZbApsmeUpdateDeviceReqT *req);
Perform an APSME-UPDATE-DEVICE.request.
Parameters
| req | APSME-UPDATE-DEVICE.request |
Return
- Returns security key used to send Update Device
9.1.39. ZbApsmeVerifyKeyReq
void ZbApsmeVerifyKeyReq(struct ZigBeeT *zb, struct ZbApsmeVerifyKeyReqT *req);
Perform an APSME-VERIFY-KEY.request.
Parameters
| req | APSME-VERIFY-KEY.request |
Return
- Returns void
9.2. Enumerations
9.2.1. ZbApsAddrModeT
APSDE and interpan addressing modes
| ZB_APSDE_ADDRMODE_NOTPRESENT | DstAddress and DstEndpoint not present |
| ZB_APSDE_ADDRMODE_GROUP | 16-bit group address for DstAddress; DstEndpoint not present |
| ZB_APSDE_ADDRMODE_SHORT | 16-bit address for DstAddress and DstEndpoint present |
| ZB_APSDE_ADDRMODE_EXT | 64-bit extended address for DstAddress and DstEndpoint present |
| ZB_APSDE_ADDRMODE_IPGROUP | InterPAN |
9.2.2. ZbApsCmdIdT
APS command frame IDs
| ZB_APS_CMD_TRANSPORT_KEY | Transport Key |
| ZB_APS_CMD_UPDATE_DEVICE | Update Device |
| ZB_APS_CMD_REMOVE_DEVICE | Remove Device |
| ZB_APS_CMD_REQUEST_KEY | Request Key |
| ZB_APS_CMD_SWITCH_KEY | Switch Key |
| ZB_APS_CMD_TUNNEL | Tunnel |
| ZB_APS_CMD_VERIFY_KEY | Verify Key |
| ZB_APS_CMD_CONFIRM_KEY | Confirm Key |
| ZB_APS_CMD_RELAY_DOWNSTREAM | Relay Downstream |
| ZB_APS_CMD_RELAY_UPSTREAM | Relay Upstream |
9.2.3. ZbApsInitialJoinAuthMethodT
Initial join authentication method used with DLK.
| ZB_APS_INITIAL_JOIN_AUTH_NONE | Initial join authentication - none. |
| ZB_APS_INITIAL_JOIN_AUTH_INSTALL_CODE_KEY | Initial join authentication - install code key. |
| ZB_APS_INITIAL_JOIN_AUTH_ANON_KEY_NEGO | Initial join authentication - anonymous key negotiation. |
ZB_APS_INITIAL_JOIN_AUTH_KEY_NEGO_WITH_AUTH |
Initial join authentication - authentication key negotiation. |
9.2.4. ZbApsPostJoinKeyUpdateMethodT
Post join key update method.
| ZB_APS_POST_JOIN_KEY_UPDATE_NONE | Post join key update - none. |
| ZB_APS_POST_JOIN_KEY_UPDATE_REQUEST_KEY | Post join key update - request key. |
| ZB_APS_POST_JOIN_KEY_UPDATE_UNAUTH_DLK | Post join key update - anonymous DLK. |
| ZB_APS_POST_JOIN_KEY_UPDATE_AUTH_DLK | Post join key update - authentication DLK. |
| ZB_APS_POST_JOIN_KEY_UPDATE_CBKE | Post join key update - CBKE. |
9.2.5. ZbApsRequestKeyTypeT
RequestKeyType values
| ZB_APS_REQKEY_KEYTYPE_APP_LINK | Application Link Key |
| ZB_APS_REQKEY_KEYTYPE_TC_LINK | Trust Center Link Key |
9.2.6. ZbApsmeDeviceStatusT
Device status values for APSME-UPDATE-DEVICE.request and indication
| ZB_APSME_DEV_STD_SECURE_REJOIN | Standard device secured rejoin |
| ZB_APSME_DEV_STD_INSECURE_JOIN | Standard device unsecured join |
| ZB_APSME_DEV_LEFT | Device left |
| ZB_APSME_DEV_STD_INSECURE_REJOIN | Standard device trust center rejoin |
9.2.7. ZbApsmeIbAttrIdT
APS IB attributes
| ZB_APS_IB_ID_BINDING_TABLE | apsBindingTable (type: struct ZbApsmeBindT, reset: yes, persist: yes) |
| ZB_APS_IB_ID_DESIGNATED_COORD | apsDesignatedCoordinator (type: uint8_t, reset: yes, persist: yes) |
| ZB_APS_IB_ID_CHANNEL_MASK | apsChannelMaskList. Converted to a list in R22 (type:
struct ZbChannelListT, reset: yes, persist: yes) |
| ZB_APS_IB_ID_USE_EPID | apsUseExtendedPANID (type: uint64_t, reset: yes, persist: no) |
| ZB_APS_IB_ID_GROUP_TABLE | apsGroupTable (type: struct ZbApsmeGroupT, reset: yes, persist: yes) |
| ZB_APS_IB_ID_USE_INSECURE_JOIN | apsUseInsecureJoin (type: uint8_t, reset: yes, persist: yes) |
| ZB_APS_IB_ID_INTERFRAME_DELAY | apsInterframeDelay (type: uint8_t, reset: no, persist: no) |
| ZB_APS_IB_ID_LAST_CHANNEL_ENERGY |
apsLastChannelEnergy (type: uint8_t, reset: yes, persist: no) |
| ZB_APS_IB_ID_LAST_CHANNEL_FAILRATE | apsLastChannelFailureRate (type: uint8_t, reset: yes, persist: no) |
| ZB_APS_IB_ID_CHANNEL_TIMER |
apsChannelTimer (type: ZbUptimeT, reset: yes, persist: no) |
| ZB_APS_IB_ID_MAX_WINDOW_SIZE | apsMaxWindow Size (type: uint8_t, reset: no, persist: no) |
| ZB_APS_IB_ID_ZDO_RESTRICTED_MODE | R23 (type: uint8_t, reset: yes, persist: no) |
| ZB_APS_IB_ID_STAT_TABLE | R23 (type: uint8_t, reset: no, persist: no) |
| ZB_APS_IB_ID_DEVICE_KEY_PAIR_SET | apsDeviceKeyPairSet (type: struct ZbApsmeKeyPairT, reset: yes, persist: yes) |
| ZB_APS_IB_ID_TRUST_CENTER_ADDRESS | apsTrustCenterAddress (type: uint64_t, reset: yes, persist: yes) |
| ZB_APS_IB_ID_SECURITY_TIMEOUT_PERIOD | apsSecurityTimeoutPeriod, milliseconds (type: uint16_t, reset: no, persist: no) |
| ZB_APS_IB_ID_TRUST_CENTER_POLICY | trustCenterPolicies. Trust center policy table bitmask Represents the following AIBs:
allowJoins = 0xad, requireInstallCodesOrPresetPassphrase = 0xaf, updateTrustCenterLinkKeysRequired = 0xb3, allowRejoinsWithWellKnownKey = 0xb6, allowTrustCenterLinkKeyRequests = 0xb7, networkKeyUpdateMethod = 0xba, allowApplicationKeyRequests = 0xbb, allowRemoteTcPolicyChange = 0xbd, allowVirtualDevices = 0xbe (type: uint32_t, enum ZbApsmePolicyT, reset: no, persist: no) |
| ZB_APS_IB_ID_SUPPORTED_KEY_NEGO_METHODS | apsSupportedKeyNegotiationMethods (R23) (type: uint8_t, reset: no, persist: no) |
| ZB_APS_IB_ID_CHALLENGE_VALUE | apsChallengeValue (R23) (type: uint64_t, reset: no, persist: no) |
| ZB_APS_IB_ID_CHALLENGE_TARGET_EUI64 | apsChallengeTargetEui64 (R23) (type: uint64_t, reset: no, persist: no) |
| ZB_APS_IB_ID_DEVICE_INTERVIEW_TIMEOUT_PERIOD | apsDeviceInterviewTimeoutPeriod (R23), seconds (type: uint8_t, reset: no, persist: no). The TC will refresh the Device Interview Timeout for each APS Downstream Relay sent to the joining device. The joining device will refresh the Device Interview Timeout for each APS Downstream Relay it receives from the TC. |
| ZB_APS_IB_ID_SCAN_COUNT | ZDO join parameter. (type: uint8_t, reset: no, persist: yes) |
| ZB_APS_IB_ID_LEAVE_REMOVE_CHILDREN | ZDO leave parameter (type: uint8_t, reset: yes, persist:yes) |
| ZB_APS_IB_ID_PRECONFIGURED_LINK_KEY | apsPreconfiguredLinkKey. Preconfigured Trust Center Link Key. (type: array of uint8_t of size ZB_SEC_KEYSIZE, reset: yes, persist: yes) |
| ZB_APS_IB_ID_DISTRIBUTED_GLOBAL_KEY |
apsDistributedGlobalKey (type: array of uint8_t of size ZB_SEC_KEYSIZE, reset: yes, persist: yes) |
| ZB_APS_IB_ID_KEY_UPDATE_PERIOD |
KeyUpdatePeriod. From the trust center policy table. (type: uint32_t, reset: yes, persist: no) |
| ZB_APS_IB_ID_MANUFACTURER_ID | Manufacturer ID (type: uint16_t, reset: no, persist: no) |
| ZB_APS_IB_ID_SEND_PKT_COOLDOWN | Send packet cooldown in milliseconds (type: uint16_t, reset: no, persist: no) |
| ZB_APS_IB_ID_BIND_ADDR_RESOLVE_PERIOD | Bind address resolve period in seconds, 0 = disabled
| ZB_APS_IB_ID_FRAGMENTATION_THRESH |
apsFragmentationThresh. Fragmentation Threshold (type: uint8_t, reset: no, persist: no) |
| ZB_APS_IB_ID_SUPPORTED_PSK_SECRETS | apsSupportedPreSharedSecrets (R23) (type: uint8_t, reset: no, persist: no) |
| ZB_APS_IB_ID_MAX_IN_QUEUED_PACKETS |
The maximum number of incoming packets the APS is allowed to queue. Default is 0, which means there is no limit, other than available memory. A SED may want to set this value between 2 to 4 so it does not get overwhelmed with requests during its wake cycle. (type: uint16_t, reset: no, persist: no) |
| ZB_APS_IB_ID_SUSPEND_ZCL_APSDE_DATA_REQ | apsSuspendZclApsdeDataReq. When set to true transmission of ASPDE-DATA.requests from ZCL are suspended and will return error right away. (type: uint8_t, reset: yes, persist: yes) |
| ZB_APS_IB_ID_MAX |
9.2.8. ZbApsmePolicyT
Trust center policy flags (ZB_APS_IB_ID_TRUST_CENTER_POLICY)
| ZB_APSME_POLICY_ALLOW_JOIN | allowJoins |
| ZB_APSME_POLICY_WHITELIST | useWhiteList |
| ZB_APSME_POLICY_IC_MASK | allowInstallCodes |
| ZB_APSME_POLICY_IC_NOT_SUPPORTED | 0x00 - Do not support Install Codes Or Preset Passphrase |
| ZB_APSME_POLICY_IC_SUPPORTED | 0x01 - Support but do not require Install Codes Or Preset Passphrase |
| ZB_APSME_POLICY_IC_REQUIRED | 0x02 - Require the use of Install Codes Or Preset Passphrase) |
| ZB_APSME_POLICY_TCLK_UPDATE_REQUIRED | updateTrustCenterLinkKeysRequired |
| ZB_APSME_POLICY_ALLOW_REJOIN | allowRejoins |
| ZB_APSME_POLICY_TC_KEY_REQ_MASK | allowTrustCenterLinkKeyRequests |
| ZB_APSME_POLICY_TC_KEY_REQ_ANY | 0x01 - Any device may request |
| ZB_APSME_POLICY_TC_KEY_REQ_PROV | allowApplicationKeyRequests |
| ZB_APSME_POLICY_APP_KEY_REQ_NEVER | 0x00 - Never |
| ZB_APSME_POLICY_APP_KEY_REQ_ANY | 0x01 - Any |
| ZB_APSME_POLICY_APP_KEY_REQ_PROV | 0x02 - Provisional, requires "applicationKeyRequestList" to be implemented |
| ZB_APSME_POLICY_TC_POLICY_CHANGE | allowRemoteTcPolicyChange |
| ZB_APSME_POLICY_ALLOW_VIRTUAL_DEVICES | allowVirtualDevices |
| ZB_APSME_POLICY_DUMMY_KEY |
9.3. Structures
9.3.1. ZbApsAddrT
APS address information data structure
Parameters
| enum ZbApsAddrModeT mode | Address mode (e.g. short, group, extended) |
| uint16_t endpoint | Destination endpoint. If set to ZB_ENDPOINT_INTERPAN, then packet is sent as an InterPAN packet |
| uint16_t panId | Destination PAN Id. This is for InterPAN packets, when the endpoint == ZB_ENDPOINT_INTERPAN |
| uint16_t nwkAddr |
Destination network address when mode == ZB_APSDE_ADDRMODE_SHORT, ZB_APSDE_ADDRMODE_GROUP or ZB_APSDE_ADDRMODE_IPGROUP |
| uint64_t extAddr |
Destination extended address when mode == ZB_APSDE_ADDRMODE_EXT |
| uint16_t nwkBcastAddr | nwkBcastAddr - This indicates the broadcast address used for groupcast messages (DstAddrMode = 0x01). Valid range: 0xFFFC - 0xFFFF |
9.3.2. ZbApsBufT
Buffer descriptor for vectored/scatter-gather API. Used when ZB_APSDE_DATAREQ_TXOPTIONS_VECTOR TX
Options bit is set.
Parameters
| const uint8_t *data | Data |
| unsigned int len | Length |
9.3.3. ZbApsRelayInfoT
APS relay information data structure
Parameters
| bool relayMsg | If true, APS packet shall be relayed. |
| uint64_t relayExtAddr | Destination EUI64 for downstream, source EUI64 in case of upstream relay command. |
| uint64_t relayDstAddr | APS relay command destination address. Address of intermediate router (multi-hop) or unauthorized joiner (single-hop) for downstream. Address of intermediate router (multi-hop) or TC (single-hop) for upstream. |
9.3.4. ZbApsdeDataConfT
APSDE-DATA.confirm data structure
Parameters
| struct ZbApsAddrT dst | DstAddrMode - Destination address information of the APSDE-DATA.request |
| uint8_t srcEndpt | SrcEndpoint - Source endpoint of the APSDE-DATA.request |
| uint32_t asduHandle | The optional handle ID from the APSDE-DATA.request |
| enum ZbStatusCodeT status | Zigbee Status Code |
9.3.5. ZbApsdeDataIndT
APSDE-DATA.indication data structure. These messages are received from the stack after setting up the proper message filter using ZbApsFilterEndpointAdd or ZbApsFilterClusterAdd.
Parameters
| struct ZbApsAddrT dst | DstAddress - Destination address information of the incoming APS message |
| struct ZbApsAddrT src | SrcAddress - Source address information of the incoming APS message |
| uint16_t profileId | ProfileId - The profile for which this frame is intended |
| uint16_t clusterId | ClusterId - The object for which this frame is intended |
| uint8_t *asdu | asdu - The set of octets comprising the ASDU that was received |
| uint16_t asduLength | asduLength - The number of octets comprising the ASDU |
| enum ZbStatusCodeT securityStatus |
SecurityStatus - The security level used to encrypt the incoming frame. One of: ZB_APS_STATUS_UNSECURED (no decryption necessary), ZB_APS_STATUS_SECURED_NWK_KEY (decrypted with the Network Key), ZB_APS_STATUS_SECURED_LINK_KEY, (decrypted with a Link Key) |
| uint8_t linkQuality | LinkQuality - The incoming Link Quality value, or set to 0 if not supported by lower layers |
| int8_t rssi | The incoming RSSI value, or set to PHY_RSSI_INVALID (-128) if not supported by lower layers |
| uint16_t linkAddr | Exegin Addon for Inter-PAN portability |
| struct ZbApsRelayInfoT relayInfo | Contains required information to relay the APS packet. |
9.3.6. ZbApsdeDataReqT
Parameters
| struct ZbApsAddrT dst | DstAddress - DstEndpoint Destination address information, including address mode, address and endpoint |
| uint16_t profileId | ProfileId - ProfileId The profile for which this frame is intended |
| uint16_t srcEndpt | SrcEndpoint - The source endpoint |
| const void *asdu | ASDU - The set of octets comprising the ASDU to be transferred |
| uint16_t asduLength | ASDULength - The number of octets comprising the ASDU |
An optional handle ID to use to match up with the APSDE-DATA.confirm |
| uint16_t txOptions |
TxOptions -Transmit options bitmask (for example ZB_APSDE_DATAREQ_TXOPTIONS_SECURITY) |
| bool discoverRoute | discoverRoute - If you perform route discovery separately using ZbNlmeRouteDiscReq(), then you can set discoverRoute to zero, decreasing the length of time an APS data request may take if there is a problem sending the packet to the target |
| uint8_t radius | Radius - Network radius. If 0, default value is used |
| uint16_t aliasAddr | AliasSrcAddr - Requires ZB_APSDE_DATAREQ_TXOPTIONS_ALIAS to be enabled |
| uint8_t aliasSeqnum | AliasSeqNumb - Requires ZB_APSDE_DATAREQ_TXOPTIONS_ALIAS to be enabled |
9.3.7. ZbApsmeAddEndpointConfT
APSME-ADD-ENDPOINT.confirm - Exegin Custom
Parameters
| enum ZbStatusCodeT status | Status |
9.3.8. . ZbApsmeAddEndpointReqT
APSME-ADD-ENDPOINT.request - Exegin Custom
Parameters
| uint8_t endpoint | Endpoint |
| uint16_t profileId | Profile Id |
| uint16_t deviceId | Device Id |
| uint8_t version | Version |
| uint8_t inputClusterCount | Supported Server Clusters |
| const uint16_t *inputClusterList | Pointer to the input cluster list |
| uint8_t outputClusterCount | Pointer to the output cluster list |
uint16_t bdbCommissioningGroupID |
e.g. DEFAULT_EP_BDB_COMMISSION_GRP_ID; |
9.3.9. ZbApsmeAddGroupConfT
APSME-ADD-GROUP.confirm Parameters
| uint16_t groupAddr | GroupAddress |
| uint8_t endpt | Endpoint |
9.3.10. ZbApsmeAddGroupReqT
Parameters
9.3.11. ZbApsmeAddKeyConfT
APSME-ADD-KEY.confirm - Exegin custom
Parameters
9.3.12. ZbApsmeAddKeyReqT
APSME-ADD-KEY.request - Exegin custom
Parameters
| enum ZbSecKeyTypeT keyType | Key type e.g, ZB_SEC_KEYTYPE_STANDARD_NWK. |
| uint8_t key | Input Key. |
| uint8_t keyAttribute | Key attribute e.g, ZB_APSME_KEY_ATTR_VERIFIED |
| uint8_t keySeqNumber | Sequence number of the input key. |
| uint64_t partnerAddr | Partner address of the key added to APS KeyPair table. |
| uint32_t outgoingCounter | Post join key update method. (R23+) |
| enum ZbSelKeyNegoMethodT selKeyNegoMethod | Selected key negotiation method. (R23+) |
| enum ZbApsKeyNegoStateT keyNegoState | APS key negotiation state. (R23+) |
| enum ZbApsPreSharedKeyTypeT preSharedKeyType | APS pre-shared key type. (R23+) |
| uint8_t passphrase | Passphrase to use for authentication DLK. (R23+) |
| bool passphraseUpdateAllowed | APS passphrase update allowed. (R23+) |
| bool verifiedFrameCounter |
Indicates whether the incoming frame counter value has been verified through a challenge response. Frame counters are implicitly verified after join, i.e, TCLK/DLK etc. However, after reboot FC shall be verified using ZDO Security_Challenge_req/rsp (R23+) |
| uint8_t capabilities |
Link key features and capabilities e.g, ZB_APS_SEC_CAPABILITY_FC_SYNC_SUPPORT. |
9.3.13. ZbApsmeBindConfT
APSME-BIND.confirm
Parameters
| uint64_t srcExtAddr | SrcAddr |
| uint8_t srcEndpt | SrcEndpoint |
| uint16_t clusterId | ClusterId |
| struct ZbApsAddrT dst | APS address information data structure |
9.3.14. ZbApsmeBindReqT
APSME-BIND.request
Parameters
9.3.15. ZbApsmeBindT
APS binding table entry
Parameters
| uint64_t srcExtAddr | SrcAddr - if zero, entry is invalid |
9.3.16. ZbApsmeConfirmKeyIndT
APSME-CONFIRM-KEY.indication
Parameters
| uint64_t srcExtAddr | SrcAddress |
| enum ZbSecKeyTypeT keyType | StandardKeyType |
| enum ZbSecEncryptT encryptKeyType | Contains information required to relay the APS packet. |
9.3.17. ZbApsmeConfirmKeyReqT
Parameters
| uint64_t dstExtAddr | DestAddress |
| struct ZbApsRelayInfoT relayInfo | Contains information required to relay the APS packet. |
9.3.18. ZbApsmeGetKeyReqT
APSME-GET-KEY.request - Exegin custom
Parameters
| uint8_t keySeqNumber | KeySeqNumber |
| uint64_t partnerAddr | PartnerAddress |
9.3.19. ZbApsmeGroupT
APS group ID table entry
Parameters
9.3.20. ZbApsmeKeyNegoConfirmT
APSME-KEY-NEGOTIATION.Confirm
Parameters
| enum ZbStatusCodeT status | ZDO status. |
| uint8_t partnerPubPoint | Partner public point data |
| uint64_t partnerLongAddr | Partner extended address. |
| bool relayCommand | This indicates whether or not the response was relayed through another router. |
| uint64_t relayLongAddr | Extended address of intermediate relay device. |
9.3.21. ZbApsmeKeyNegoIndT
APSME-KEY-NEGOTIATION.indication (R23)
Parameters
| uint8_t seqnum | ZDO sequence number. |
| bool relayCommand | This indicates whether or not the response should be relayed through another router. |
9.3.22. ZbApsmeRemoveAllGroupsConfT
Parameters
9.3.23. ZbApsmeRemoveAllGroupsReqT
Parameters
9.3.24. ZbApsmeRemoveDeviceIndT
APSME-REMOVE-DEVICE.indication
Parameters
| uint64_t targetAddr | TargetAddress |
9.3.25. ZbApsmeRemoveDeviceReqT
Parameters
| uint64_t dstExtAddr | ParentAddress |
9.3.26. ZbApsmeRemoveEndpointConfT
APSME-REMOVE-ENDPOINT.confirm - Exegin custom
Parameters
9.3.27. ZbApsmeRemoveEndpointReqT
APSME-REMOVE-ENDPOINT.request - Exegin custom
Parameters
9.3.28. ZbApsmeRemoveGroupConfT
Parameters
9.3.29. ZbApsmeRemoveGroupReqT
Parameters
9.3.30. ZbApsmeRemoveKeyConfT
APSME-REMOVE-KEY.confirm - Exegin custom
Parameters
9.3.31. ZbApsmeRemoveKeyReqT
APSME-REMOVE-KEY.request - Exegin custom
Parameters
9.3.32. ZbApsmeRequestKeyIndT
APSME-REQUEST-KEY.indication
Parameters
| enum ZbApsRequestKeyTypeT keyType | RequestKeyType |
9.3.33. ZbApsmeRequestKeyReqT
Parameters
| uint64_t partnerAddr | PartnerAddress - Only used with application keys |
9.3.34. ZbApsmeSecChallengeIndT
APSME-SEC-CHALLENGE.indication (R23 - Exegin add-on)
Parameters
| uint16_t devShortAddr | Device short address. |
| uint64_t devExtAddr | Extended address of partner device to perform APS Frame counter synchronization. |
9.3.35. ZbApsmeSecChallengeReqT
APSME-SEC-CHALLENGE.request (R23 - Exegin add-on)
Parameters
9.3.36. ZbApsmeSwitchKeyIndT
APSME-SWITCH-KEY.indication
Parameters
| uint8_t keySeqNum | KeySeqNumber |
9.3.37. ZbApsmeSwitchKeyReqT
Parameters
9.3.38. ZbApsmeTransKeyIndT
APSME-TRANSPORT-KEY.indication
Parameters
| union { struct { uint8_t key | Key |
| bool capabilities_valid | True, if a valid Link key and features TLV found. |
| uint8_t capabilities | Link key features and capabilities e.g, ZB_APS_SEC_CAPABILITY_FC_SYNC_SUPPORT. Valid only if 'capabilities_valid' is true. |
| struct { uint8_t keySeqNumber | KeySeqNumber |
| uint8_t key | Key |
| struct { uint64_t partnerAddr | PartnerAddress |
| bool initiator | Initiator |
| uint8_t key | Key |
9.3.39. ZbApsmeTransportKeyReqT
Parameters
| union { struct { uint64_t parentAddr | ParentAddress |
| uint8_t key | Key |
| uint8_t key | NetworkKey |
| bool useParent | UseParent |
| uint8_t key | Key |
9.3.40. ZbApsmeUnbindConfT
Parameters
9.3.41. ZbApsmeUnbindReqT
Parameters
9.3.41.1. 14.3.42. ZbApsmeUpdateDeviceIndT
APSME-UPDATE-DEVICE.indication
Parameters
| uint64_t devExtAddr | DeviceAddress |
| uint16_t devShortAddr | DeviceShortAddress |
| enum ZbApsmeDeviceStatusT status | Status - Device status values |
| enum ZbSecEncryptT encryptKeyType | TLVs of the joining device as relayed during Network Commissioning |
9.3.41.2. 14.3.43. ZbApsmeUpdateDeviceReqT
Parameters
| struct ZbJoinerTLVsT joinerTLVs | TLVs of the joining device as relayed during Network Commissioning |
9.3.41.3. 14.3.44. ZbApsmeVerifyKeyIndT
APSME-VERIFY-KEY.indication
Parameters
| uint8_t hash | ReceivedInitiatorHashValue |
9.3.41.4. 14.3.45. ZbApsmeVerifyKeyReqT
Parameters
9.3.41.5. 14.3.46. ZbMsgApsCommandT
APS Command Indication struct. Used with the message filter Id 'ZB_MSG_FILTER_APS_COMMAND_IND'.
Parameters
| enum ZbApsCmdIdT id | The APS Command Id. e.g. ZB_APS_CMD_TRANSPORT_KEY |
| union { struct ZbApsmeTransKeyIndT trans_key |
10. BDB Layer
#include "zigbee.bdb.h"
10.1. Functions
10.1.1. ZbBdbGetEndpointStatus
enum ZbBdbCommissioningStatusT ZbBdbGetEndpointStatus(struct ZigBeeT *zb, uint8_t endpoint);
Get commissioning status for the given endpoint (same for all endpoints?). If endpoint = ZB_ENDPOINT_BCAST, returns the status for the first endpoint found.
Parameters
| endpoint | Endpoint identifier |
Return
- Returns ZB_BDB_COMMISS_STATUS_SUCCESS on success, other BDB status code on failure
10.1.2. ZbBdbGetIndex
enum ZbStatusCodeT ZbBdbGetIndex(struct ZigBeeT *zb, enum ZbBdbAttrIdT attrId, void *attrPtr, unsigned int attrSz, unsigned int attrIndex);
Read a BDB IB attribute.
Parameters
| attrId | Attribute ID |
| attrPtr | Pointer to the attribute |
| attrSz | Attribute size |
| attrIndex | Index attribute |
Return
10.1.3. ZbBdbSetIndex
enum ZbStatusCodeT ZbBdbSetIndex(struct ZigBeeT *zb, enum ZbBdbAttrIdT attrId, const void *attrPtr, unsigned int attrSz, unsigned int attrIndex);
Write a BDB IB attribute.
Parameters
Return
10.2. Enumerations
10.2.1. ZbBdbAttrIdT
BDB IB attributes
| ZB_BDB_CommissioningMode | bdbCommissioningMode -BDB_COMMISSION_MODE_MASK (type: uint8_t, reset: no, persist: no) |
| ZB_BDB_JoinUsesInstallCodeKey | bdbJoinUsesInstallCodeKey - Deprecated in BDB 3.1
| ZB_BDB_NodeCommissioningCapability | bdbNodeCommissioningCapability Deprecated in BDB 3.1 (type: uint8_t, reset: no, persist: no) |
| ZB_BDB_NodeIsOnANetwork | bdbNodeIsOnANetwork - Checks nwkExtendedPanId if non-zero Deprecated in BDB 3.1 (type: uint8_t, reset: no, persist: no) |
| ZB_BDB_NodeJoinLinkKeyType | bdbNodeJoinLinkKeyType -BDB_JOINLINK_KEYTYPE_FLAG, Link key with which the node was able to decrypt the network key
Deprecated in BDB 3.1 (type: uint8_t, reset: yes, persist:no) |
| ZB_BDB_PrimaryChannelSet |
bdbPrimaryChannelSet (type: uint32_t, reset: no, persist:no) |
| ZB_BDB_ScanDuration | bdbScanDuration (type: uint8_t, reset: no, persist: no) |
| ZB_BDB_SecondaryChannelSet | bdbSecondaryChannelSet (type: uint32_t, reset: no, persist: no) |
| ZB_BDB_TCLK_ExchangeAttempts |
bdbTCLinkKeyExchangeAttempts - Deprecated in BDB 3.1, still used as a counter to keep track of number of TCLK exchange attempts made. (type: uint8_t, reset: no, persist: no) |
| ZB_BDB_TCLK_ExchangeAttemptsMax | bdbTCLKExchangeAttempts (type: uint8_t, reset: no, persist: no) |
| ZB_BDB_TCLinkKeyExchangeMethod |
bdbTCLinkKeyExchangeMethod - Deprecated in BDB 3.1 (type: uint8_t / enum ZbBdbLinkKeyExchMethodT, reset:no, persist: no) |
| ZB_BDB_TrustCenterNodeJoinTimeout |
bdbTrustCenterNodeJoinTimeout - Deprecated in BDB 3.1 (type: uint8_t, reset: no, persist: no) |
| ZB_BDB_TrustCenterRequiresKeyExchange |
bdbTrustCenterRequireKey-Exchange. Modifies ZB_APSME_POLICY_TCLK_UPDATE_REQUIRED bit in ZB_APS_IB_ID_TRUST_CENTER_POLICY - Deprecated in BDB 3.1 (type: uint8_t, reset: no, persist:no) |
| ZB_BDB_AcceptNewUnsolicitedTCLinkKey | acceptNewUnsolicitedTrustCenterLinkKey (type: uint8_t, reset: no, persist: no) |
| ZB_BDB_AcceptNewUnsolicitedApplicationLinkKey | acceptNewUnsolicitedApplicationLinkKey (type: uint8_t, reset: no, persist: no) |
| ZB_BDB_vDoPrimaryScan | Boolean whether to use ZB_BDB_PrimaryChannelSet or ZB_BDB_SecondaryChannelSet (type: uint8_t, reset: no, persist: no) |
| ZB_BDB_FreeNetAddrBegin | (type: uint16_t, reset: no, persist: no) |
| ZB_BDB_FreeNetAddrCurrent | (type: uint16_t, reset: no, persist: no) |
| ZB_BDB_FreeNetAddrEnd | (type: uint16_t, reset: no, persist: no) |
| ZB_BDB_TLRssiMin |
Minimum RSSI threshold for Touchlink commissioning (type: int8_t, reset: no, persist: yes) |
| ZB_BDB_UpdateDeviceKeyId |
E.g. ZB_SEC_KEYID_NETWORK (default) or ZB_SEC_KEYID_LINK. (type: uint8_t / enum ZbSecHdrKeyIdT, reset: no, persist: yes) |
| ZB_BDB_JoinScanType |
ZB_SCAN_TYPE_ACTIVE (default) or ZB_SCAN_TYPE_ENHANCED (type: uint8_t, reset: no, persist: yes) |
| ZB_BDB_PrevJoinScanType | (type: uint8_t, reset: no, persist: yes) |
| ZB_BDB_NlmeSyncFailNumBeforeError |
Number of consecutive NLME-SYNC failures before reporting ZB_NWK_STATUS_CODE_PARENT_LINK_FAILURE (type: uint8_t, reset: no, persist: yes) |
| ZB_BDB_ZdoTimeout |
ZDO response wait timeout in milliseconds - default is 6000 mS. (type: uint32_t, reset: no, persist: yes) |
| ZB_BDB_TLStealFlags | Touchlink Stealing Flags (TOUCHLINK_STEAL_xxx defines. (type: uint8_t, reset: no, persist: yes) |
| ZB_BDB_JoinTclkNodeDescReqDelay | (type: uint16_t, reset: no, persist: yes) |
| ZB_BDB_JoinTclkRequestKeyDelay | (type: uint16_t, reset: no, persist: yes) |
| ZB_BDB_TLKey | Touchlink preconfigured link key (type: array of uint8_t, reset: no, persist: yes) |
| ZB_BDB_TLKeyIndex | Touchlink key encryption algorithm key index (type: uint8_t / enum ZbBdbTouchlinkKeyIndexT, reset: no, persist: yes) |
| ZB_BDB_ZdoZigbeeProtocolRevision | Default = 23 (R23) (type: uint8_t, reset: no, persist: yes) |
| ZB_BDB_PersistTimeoutMs |
Minimum delay between persistence updates (type: uint32_t, reset: no, persist: yes) |
| ZB_BDB_JoinAttemptsMax | Maximum number attempts to join a network. If an attempt fails, the EPID is added to a blacklist before the next attempt. (type: uint8_t, reset: no, persist: yes) |
| ZB_BDB_MaxConcurrentJoiners | Maximum number of concurrent joiners the coordinator supports. (type: uint8_t, reset: no, persist: yes) |
| ZB_BDB_Uptime |
Returns the current stack uptime in milliseconds (ZbUptime). (type: uint32_t, reset: no, persist: no) |
| ZB_BDB_Flags |
e.g. ZB_BDB_FLAG_IGNORE_COST_DURING_JOIN (type: uint32_t, reset: no, persist: no) |
| ZB_BDB_TC_Supports_ZD | Boolean value that indicates whether TC supports Zigbee Direct. This value is automatically discovered after joining by Match-Desc.request for ZCL_CLUSTER_ZDD. (type: uint8_t, reset: yes, persist: yes) |
| ZB_BDB_ZVD_SecureSessionRenegotiated |
Boolean value that indicates if ZVD successfully renegotiated secure session during network join or rejoin. (type: uint8_t, reset: yes, persist: no) |
| ZB_BDB_TLIdentifyTime | Touchlink Indetify Time Duration - default is 7 seconds. Setting the IB to zero will disable sending the TL identify request. (type: uint16_t, reset: no, persist: no) |
| ZB_BDB_AppendBeaconAppendix | Boolean value that determines if the Beacon appendix will be appended to the beacons sent from an R23 device. By default, this is always true. (type: uint8_t, reset: no, persist: yes) |
| ZB_BDB_StartupLongDelayMs |
Configurable delay added to the end of a successful ZbStartup when joining or rejoining a network. This is to give the stack time to send and receive a NWK Link Status command which is necessary for routing. Otherwise, the application may be trying to send packets right away and get failures until the first Link Status commands are exchanged. This delay is not applicable to end-devices or when forming a network. The default value is 17000 mS (17 seconds). (type: uint32_t, reset: no, persist: no) |
| ZB_BDB_ZclBomdReqWaitTimeoutMs | Timeout value in milliseconds to wait for a ZCL request sent to a BOMD device, via mirroring. Default is 10 minutes. (type: uint32_t, reset: no, persist: no) |
| ZB_BDB_ZclBomdReqQueueTimeoutMs |
Timeout value in milliseconds for the ZCL request to be queued for a BOMD device on the Mirror. If this timeout expires before the BOMD polls for this message, a Default Response with status of ZCL_STATUS_TIMEOUT is returned to the requestor. The default timeout is 10 minutes minus 10 seconds (slightly less than ZB_BDB_ZclBomdReqWaitTimeoutMs). (type: uint32_t, reset: no, persist: no) |
| ZB_BDB_ZclSequenceNumber | API to get/set the ZCL Sequence number provided by the stack. (type: uint8_t, reset: no, persist: no) |
| ZB_BDB_KE_Status |
Key Establishment status code from CBKE during ZbStartup. The initial value is set to ZCL_KEY_STATUS_NOT_STARTED (Exegin extension to the status codes) at the beginning of ZbStartup. It will be set to the status code returned by the KE process. It’s a uint8_t type, but it’s based on the 'enum ZbZclKeyStatusT' values. (type: uint8_t, reset: no, persist: no) |
| ZB_BDBC_MaxSameNetworkRetryAttempts | (type: uint8_t, reset: no, persist: no) |
| ZB_BDBC_MinCommissioningTime | Seconds (type: uint8_t, reset: no, persist: no) |
| ZB_BDBC_RecSameNetworkRetryAttempts | (type: uint8_t, reset: no, persist: no) |
| ZB_BDBC_TLInterPANTransIdLifetime | Seconds (type: uint8_t, reset: no, persist: no) |
| ZB_BDBC_TLMinStartupDelayTime | Seconds (type: uint8_t, reset: no, persist: no) |
| ZB_BDBC_TLRxWindowDuration | Seconds (type: uint8_t, reset: no, persist: no) |
| ZB_BDBC_TLScanTimeBaseDuration | Milliseconds (type: uint8_t, reset: no, persist: no) |
10.2.2. ZbBdbCommissioningStatusT
bdbCommissioningStatus
| ZB_BDB_COMMISS_STATUS_SUCCESS | SUCCESS - The commissioning sub-procedure was successful |
| ZB_BDB_COMMISS_STATUS_IN_PROGRESS | IN_PROGRESS - One of the commissioning subprocedures has started but is not yet complete |
| ZB_BDB_COMMISS_STATUS_NOT_AA_CAPABLE | NOT_AA_CAPABLE - The initiator is not address assignment capable during touchlink |
| ZB_BDB_COMMISS_STATUS_NO_NETWORK | NO_NETWORK - A network has not been found during network steering or touchlink |
| ZB_BDB_COMMISS_STATUS_TARGET_FAILURE | TARGET_FAILURE - A node has not joined a network when requested during touchlink |
| ZB_BDB_COMMISS_STATUS_FORMATION_FAILURE | FORMATION_FAILURE - A network could not be formed during network formation |
| ZB_BDB_COMMISS_STATUS_NO_IDENTIFY_QUERY_RESPONSE | NO_IDENTIFY_QUERY_RESPONSE - No response to an identify query command has been received during finding & binding |
| ZB_BDB_COMMISS_STATUS_BINDING_TABLE_FULL | BINDING_TABLE_FULL - A binding table entry could not be created due to insufficient space in the binding table during finding & binding |
| ZB_BDB_COMMISS_STATUS_NO_SCAN_RESPONSE | NO_SCAN_RESPONSE - No response to a scan request inter-PAN command has been received during touchlink |
| ZB_BDB_COMMISS_STATUS_NOT_PERMITTED | NOT_PERMITTED - A touchlink (steal) attempt was made when a node is already connected to a centralized security network or when end node attempts to form network |
| ZB_BDB_COMMISS_STATUS_TCLK_EX_FAILURE | TCLK_EX_FAILURE - The Trust Center link key exchange procedure has failed attempting to join a centralized security network |
| ZB_BDB_COMMISS_STATUS_NOT_ON_A_NETWORK | NOT_ON_A_NETWORK - A commissioning procedure was forbidden since the node was not currently on a network. |
| ZB_BDB_COMMISS_STATUS_ON_A_NETWORK | ON_A_NETWORK - A commissioning procedure was forbidden since the node was currently on a network. |
10.2.3. ZbBdbLinkKeyExchMethodT
| BDB_LINKKEY_EXCHANGE_METHOD_APS | APS Request Key |
| BDB_LINKKEY_EXCHANGE_METHOD_CBKE | Certificate Based Key Exchange (CBKE) |
10.2.4. ZbBdbTouchlinkKeyIndexT
| TOUCHLINK_KEY_INDEX_DEVELOPMENT | Development key |
| TOUCHLINK_KEY_INDEX_PRODUCTION | Production key |
| TOUCHLINK_KEY_INDEX_CERTIFICATION | Certification key |
11. DLK utilities
#include "zigbee.dlk.h"
11.1. Description
This file defines all the public APIs used as part of ZigBee dynamic link key (DLK) implementation.
11.2. Functions
11.2.1. ZbDlkKeyNegoWithDevice
enum ZbStatusCodeT ZbDlkKeyNegoWithDevice(struct ZigBeeT *zb, uint64_t partnerAddr, void (*callback)(enum ZbStatusCodeT status, void *arg), void *arg);
Perform dynamic link key negotiation (DLK) with a partner R23 device after the initiator has joined the network. The initiator and the responder devices can be TC or non-TC. In effect, this API can be used to negotiate both trust center and application link key.
Parameters
| partnerAddr | EUI64 of the responder for DLK. |
| callback | Callback function pointer. |
| cbarg | Callback argument. |
Return
- ZB status code. If not ZB_STATUS_SUCCESS, then the callback will not be called.
11.3. Enumerations
11.3.1. ZbSelKeyNegoMethodT
Enumeration for selected key negotiation methods.
| ZB_SEL_DLK_METHOD_RESERVED | Reserved |
| ZB_SEL_DLK_METHOD_C25519_AES_MMO_128 | ECDHE using Curve25519 with Hash AES-MMO-128 |
| ZB_SEL_DLK_METHOD_C25519_SHA_256 | ECDHE using Curve25519 with Hash SHA-256 |
Enumeration for selected PSK (Pre-shared) secret.
| ZB_SEL_PSK_SYMMETRIC_AUTH_TOKEN | Symmetric authentication token negotiated using DLK |
| ZB_SEL_PSK_IC_KEY | Pre-configured link-key derived from installation code |
| ZB_SEL_PSK_PASSCODE_PAKE | Variable-length pass code (for PAKE protocols) |
| ZB_SEL_PSK_BASIC_ACCESS_KEY | Basic Access Key |
| ZB_SEL_PSK_ADMIN_ACCESS_KEY | Administrative Access Key |
| ZB_SEL_PSK_ANON_WELL_KNOWN_SECRET | Well-known secret - 'ZigBeeAlliance18' |
12. Zigbee message filters
#include "zigbee.filter.h"
12.1. Functions
12.1.1. ZbMsgFilterRegister
struct ZbMsgFilterT * ZbMsgFilterRegister(struct ZigBeeT *zb, uint32_t mask, uint8_t prio, enum zb_msg_filter_rc (*callback)(struct ZigBeeT *zb, uint32_t id, void *msg, void *cbarg), void *arg);
Register message filter with the stack.
Parameters
| zb | Pointer to Zigbee stack instance |
| mask | Message filter mask flag |
| prio | Message filter priority |
| callback | Callback function invoked after message matching filter is received |
| arg | Callback function argument |
Return
- Undocumented
12.1.2. ZbMsgFilterRemove
void ZbMsgFilterRemove(struct ZigBeeT *zb, struct ZbMsgFilterT *filter);
Removes the given message filter from the stack.
Parameters
Return
- Undocumented
12.2. Enumerations
12.2.1. zb_msg_filter_rc
Message filter callback return values. Used for the return codes with the callbacks for ZbMsgFilterRegister, ZbApsFilterEndpointAdd, etc.
| ZB_MSG_CONTINUE | Continue processing any further filter callbacks. |
| ZB_MSG_DISCARD | Stop processing further filter callbacks. |
12.3. Structures
12.3.1. ZbMsgStackEventT
A message that is sent if the device is an end-device and it has received an NLME-NETWORK-STATUS.indication with the PARENT_LINK_FAILURE status set. Outside of testing 18.4.* TP/R23/ZDO/APC-*, the application should attempt to rejoin the network using the ZbStartupRejoin() API call at its convenience.
Parameters
| enum ZbMsgStackEventTypeT type | Enumeration of different stack event message type, sent to higher layer. |
| unsigned int val | Depends on message type. E.g. enum ZbStatusCodeT status. |
13. Zigbee utilities
#include "zigbee.h"
13.1. Description
This file groups global/external definitions from all the layer specific header files for example, aps, nwk, zdo etc… into a single place, so that one can just include zigbee.h for all the global definitions eliminating the header file inclusion clutter from source files.
13.2. Functions
13.2.1. ZbChangeExtAddr
void ZbChangeExtAddr(struct ZigBeeT *zb, uint64_t extAddr);
Change extended address of the stack instance
Parameters
Return
- Undocumented
13.2.2. ZbCheckTime
unsigned int ZbCheckTime(struct ZigBeeT *zb);
Returns the length of time (in milliseconds) until the next scheduled timer will elapse, or UINT_MAX if there are no scheduled timers.
Parameters
Return
- Returns Length of time on success, 0 on failure
13.2.3. ZbDestroy
void ZbDestroy(struct ZigBeeT *zb);
Deallocates a Zigbee stack instance.
None Return
- Undocumented
13.2.4. ZbDestroyWithCb
enum ZbStatusCodeT ZbDestroyWithCb(struct ZigBeeT *zb, void (*callback)(void *arg), void *arg);
Deallocates a Zigbee stack instance and save callback to application structure
Parameters
| callback | Callback function |
| arg | Callback argument |
Return
- Returns ZB_STATUS_SUCCESS on success, other status code on failure
13.2.5. ZbExtendedAddress
uint64_t ZbExtendedAddress(struct ZigBeeT *zb);
Returns the Extended address of the Zigbee stack.
Parameters
Return
- Returns extended address
13.2.6. ZbHeapAvailable
unsigned long ZbHeapAvailable(struct ZigBeeT *zb);
Current size of memory available in the zigbee stack heap
Parameters
Return
- Returns the amount of memory available in the zigbee stack heap, or 0 if unknown or unbounded
13.2.7. ZbHeapHighWaterMark
unsigned long ZbHeapHighWaterMark(struct ZigBeeT *zb);
Zigbee memory heap high-water mark. Useful during testing to determine maximum amount of memory consumed from total heap size.
Parameters
Return
- Returns the worst-case heap usage (high-water mark)
13.2.8. ZbHeapUsed
unsigned long ZbHeapUsed(struct ZigBeeT *zb);
Current size of memory allocated from the zigbee stack heap
Parameters
Return
- Returns the memory allocated from the zigbee stack heap
13.3. ZbIfAttach
bool ZbIfAttach(struct ZigBeeT *zb, struct WpanPublicT *dev);
Attaches an IEEE 802.15.4 device driver to the ZigBee stack. Uses the link pointers within the device structure for linking.
| dev | Pointer to wpan device |
Return
13.4. ZbIfDetach
void ZbIfDetach(struct ZigBeeT *zb, struct WpanPublicT *dev);
Detaches an IEEE 802.15.4 device driver from the ZigBee stack.
Parameters
Return
- Undocumented
13.5. ZbInit
struct ZigBeeT * ZbInit(uint64_t extAddr, struct ZbInitTblSizesT *tblSizes, struct ZbInitSetLoggingT *setLogging);
This is called to create a new Zigbee stack instance. One of the parameters provided is an optional pointer to a struct that defines the sizes of some of the tables within the stack (e.g. NNT, Routing Table, Security Keys Table). This lets the application developer tailor the memory usage depending on the type of device being developed.
Parameters
| extAddr | EUI to be assigned to this Zigbee stack instance. |
| tblSizes | Optional pointer to a struct ZbInitTblSizesT data structure defining some of the table sizes to be allocated.
| setLogging | Optional pointer to a struct ZbInitSetLoggingT data structure defining the log mask and callback to call to print log messages.
Return
- Pointer to Zigbee stack instance, or NULL if there was a problem (for example, not enough memory)
13.6. ZbLeaveReq
enum ZbStatusCodeT ZbLeaveReq(struct ZigBeeT *zb, void (*callback)(struct ZbNlmeLeaveConfT *conf, void *arg), void *cbarg);
Send a leave request to the stack
Parameters
| cbarg | Callback argument |
Return
13.7. ZbPersistGet
unsigned int ZbPersistGet(struct ZigBeeT *zb, uint8_t *buf, unsigned int maxlen);
Get the stack persistence data and write it to the buffer provided by buf. If buf is NULL and maxlen is zero, this function determines the buffer size required to save the persistence data. Use ZbStartupPersist to restore the persistence data to the stack and restart the zigbee stack.
Parameters
| buf | Pointer to memory to write persistence data |
| maxlen | Max length of persistence data |
Return
- Returns length of persistence data
13.8. ZbPersistNotifyRegister
bool ZbPersistNotifyRegister(struct ZigBeeT *zb, void (*callback)(struct ZigBeeT *zb, void *cbarg), void *cbarg);
Configure the persistence callback that tells the application when important stack parameters have changed and should be saved.
Return
- True if callback was registered, false otherwise.
13.9. ZbPortStackEventFd
int ZbPortStackEventFd(struct ZigBeeT *zb);
Called to get the file descriptor to be used to wake-up the stack thread calling ZbTimerWork if a stack event needs to be processed. This is only required in multi-threaded environments. Without this event, it is possible for a user thread to initiate a stack function which does not activate the MAC layer, which in turn would wake up the stack thread.
Parameters
None Return
- Undocumented
13.10. ZbReset
void ZbReset(struct ZigBeeT *zb);
Helper function to perform an APS and NWK reset
Parameters
None Return
- Undocumented
13.11. ZbShortAddress
uint16_t ZbShortAddress(struct ZigBeeT *zb);
Returns the Short address of the Zigbee stack.
Return
- Returns short address
13.12. ZbShutdown
void ZbShutdown(struct ZigBeeT *zb);
This API moves the stack to shutdown mode, used in case of a sleepy end device to conserve power.
Parameters
None Return
- Undocumented
13.13. ZbStateGet
unsigned int ZbStateGet(struct ZigBeeT *zb, uint8_t *buf, unsigned int maxlen);
Same as ZbPersistGet, but saves additional more dynamic data such as routing tables. Use the same
ZbStartupPersist to restore the persistence data to the stack and to restart the zigbee stack.
Parameters
| buf | Pointer to memory to write persistence and additional data |
| maxlen | Max length of persistence and additional data |
Return
- Returns length of persistence and additional data
13.14. ZbTimeoutRemaining
Zigbee timeout remaining function.
| now | Current time |
| expire_time | time of timeout expiry |
Return
- Returns 0 if now >= expire_time, difference in milliseconds between now and timeout if now < expire_time.
13.15. ZbTimerAlloc
struct ZbTimerT * ZbTimerAlloc(struct ZigBeeT *zb, void (*callback)(struct ZigBeeT *zb, void *cb_arg), void *arg);
Creates a ZigBee timer structure.
Parameters
Return
- Zigbee timer structure
13.16. ZbTimerChangeCallback
Changes callback function for the specified timer, without the need to free and allocate a new timer.
Parameters
| timer | Pointer to Zigbee timer structure |
Return
- Undocumented
13.17. ZbTimerFree
void ZbTimerFree(struct ZbTimerT *timer);
Free a timer.
Parameters
None Return
- Undocumented
13.18. ZbTimerRemaining
unsigned int ZbTimerRemaining(struct ZbTimerT *timer);
Returns time remaining in ms for a timer.
Parameters
Return
- Time remaining in ms as an unsigned int
13.19. ZbTimerReset
void ZbTimerReset(struct ZbTimerT *timer, unsigned int timeout);
Reset and schedule a ZigBee timer.
Parameters
Return
- Undocumented
13.20. ZbTimerRunning
Checks if the specified timer is active.
| timer | Callback argument |
Return
- True if the specified timer is active
13.21. ZbTimerStop
void ZbTimerStop(struct ZbTimerT *timer);
Parameters
None Return
- Undocumented
13.22. ZbTimerWork
void ZbTimerWork(struct ZigBeeT *zb);
Called periodically to run the stack.
Parameters
None Return
- Undocumented
13.23. ZbWakeupCallbackConfig
void ZbWakeupCallbackConfig(struct ZigBeeT *zb, void (*wakeup_cb)(void));
Configure a callback to activate the application if there is a stack event to process. Not required by all stack ports.
Parameters
Return
- Undocumented
13.24. ZbZclBasicPostAlarm
bool ZbZclBasicPostAlarm(struct ZigBeeT *zb, uint8_t endpoint, uint8_t alarm_code);
Post an alarm code to the Basic Cluster.
Parameters
| endpoint | Endpoint of basic cluster |
| alarm_code | Alarm code |
Return
13.25. ZbZclBasicReadDirect
enum ZclStatusCodeT ZbZclBasicReadDirect(struct ZigBeeT *zb, uint16_t attrId, void *buf, unsigned int max_len);
Read a Basic Server attribute
Parameters
| attrId | The attribute Id to read |
| buf | Pointer to the attribute data, in the ZCL defined format. |
| len | Maximum length of the attribute data. May exceed the length of the particular attribute. |
Return
- ZCL status code
13.26. ZbZclBasicServerConfigDefaults
void ZbZclBasicServerConfigDefaults(struct ZigBeeT *zb, const struct ZbZclBasicServerDefaults *defaults);
Configure the default ZCL Basic Server attribute values. The Basic Server is integral to the stack in order for the attribute values to be made "global" and shared between all Basic Server instances on all endpoints. This should be
called after calling ZbInit and before creating any ZCL endpoints.
Parameters
Return
- Undocumented
13.27. ZbZclBasicWriteDirect
enum ZclStatusCodeT ZbZclBasicWriteDirect(struct ZigBeeT *zb, uint16_t attrId, const void *buf, unsigned int max_len);
Write to a Basic Server attribute
Parameters
| attrId | The attribute Id to write |
Return
- ZCL status code
14. Structures
14.1. ZbChannelListEntryT
A single channel list entry. It includes the channel page and channel mask. It is used within struct ZbChannelListT when describing a list of channels masks, or on its own in some cases.
Parameters
| uint8_t page | The 802.15.4 Channel Page (e.g. 2.4 GHz O-QPSK = Page 0) |
| uint32_t channelMask | The 32-bit Channel Mask. The 5 MSB Channel Page bits are not used and should be set to 0. The 27 LSB define the channel(s) supported or to be used during commissioning. |
14.2. ZbChannelListT
The Channel list structure. It includes a list of struct ZbChannelListEntryT entries; one for each channel page supported or to be used during commissioning.
Parameters
| uint8_t count | Number of channel masks in 'list'. Maximum is ZB_CHANNEL_LIST_NUM_MAX. |
| struct ZbChannelListEntryT list | The list of Channel Pages and Masks. |
14.3. ZbInitSetLoggingT
Same parameters as ZbSetLogging takes. Allows debug log output as stack is being initialized.
Parameters
| uint32_t mask | e.g. ZB_LOG_MASK_LEVEL_2 |
| func
(callback function pointer) |
void (*func)(struct ZigBeeT *zb, uint32_t mask, const char *hdr, const char *fmt, va_list argptr)
Callback function to print log messages. |
14.4. ZbInitTblSizesT
A pointer to this struct type is passed to ZbInit to define the various ZigBee tables used in the stack. If the pointer to ZbInit is NULL, the default sizes are used.
Parameters
| void *heapPtr | Pointer to memory to use for stack’s run-time heap. Size equals heapSz bytes. If heapSz is zero, set this to NULL and the buffer will be allocated using ZbMalloc(). If the stack is built with CONFIG_ZB_ALLOC_STATIC, then heapPtr and heapSz must be non-zero and provided by the application. |
| unsigned int heapSz | Size of memory buffer provided by heapPtr. If heapSz is zero, then a default value of 32 kB for FFD or 16 kB for RFD is chosen, and memory will be allocated through ZbMalloc(). An FFD vs RFD type of stack is controlled by the CONFIG_ZB_ENDNODE when the stack is built. |
| unsigned int nwkNeighborTblSz | Network Neighbor Table (NNT) number of entries. Default is 64. |
| unsigned int nwkRouteTblSz | Default is 32. |
| unsigned int nwkAddrMapTblSz | Default is 32. |
| unsigned int nwkBttSz | Default is 32. |
| unsigned int nwkRReqSz | Default is 16. |
| unsigned int apsPeerLinkKeyTblSz |
14.5. ZbJoinerTLVsT
TLV structure the application can use to include TLVs in certain packet payloads during the commissioning process.
Parameters
| uint8_t length | Length of the TLV buffer 'buf'. Maximum length is ZB_JOINER_TLVS_MAX_SIZE. |
| uint8_t buf | Buffer containing the TLV data. The data is in the format as would appear over-the-air (i.e. binary blob format) |
14.6. ZbZclBasicServerDefaults
This data structure is used to configure the default attribute values for the basic server. All values are in ZCL data format (that is to say, strings are prefixed with the length byte)
Parameters
| uint8_t app_version | ZCL_BASIC_ATTR_APP_VERSION |
| uint8_t stack_version | ZCL_BASIC_ATTR_STACK_VERSION |
| uint8_t hw_version | ZCL_BASIC_ATTR_HARDWARE_VERSION |
| uint8_t mfr_name | ZCL_BASIC_ATTR_MFR_NAME (First byte length) |
| uint8_t model_name | ZCL_BASIC_ATTR_MODEL_NAME (First byte length) |
| uint8_t date_code | ZCL_BASIC_ATTR_DATE_CODE (First byte length) |
| uint8_t power_source | ZCL_BASIC_ATTR_POWER_SOURCE (e.g. ZCL_BASIC_POWER_UNKNOWN) |
| uint8_t sw_build_id | ZCL_BASIC_ATTR_SW_BUILD_ID (First byte length) |
15. Hash Utilities
#include "zigbee.hash.h"
15.1. Description
This file defines the Exegin specific ZigBee AES Hash structure and also provides the declaration of Hashing APIs. Customers with their own hashing implementation can simply replace this file with their variant. In effect, it helps to plug customer specific hashing implementation into ZSDK stack.
16. NWK Layer
#include "zigbee.nwk.h"
16.1. Functions
16.1.1. ZbNlmeBcnSurveyReq
enum ZbStatusCodeT ZbNlmeBcnSurveyReq(struct ZigBeeT *zb, struct ZbNlmeBcnSurveyReqT *req, void (*callback)(struct ZbNlmeBcnSurveyConfT *conf, void *cbarg), void *cbarg);
Starts the NLME beacon survey procedure and returns the survey results as part of the NLME-BEACONSURVEY.confirm primitive.
Parameters
| zb | ZigBee stack structure. |
| req | Beacon survey request structure. |
Return
- Undocumented
16.1.2. ZbNlmeDirectJoinReq
void ZbNlmeDirectJoinReq(struct ZigBeeT *zb, struct ZbNlmeDirectJoinReqT *directJoinReqPtr, struct ZbNlmeDirectJoinConfT *directJoinConfPtr);
NLME-DIRECT-JOIN.request
Parameters
| directJoinReqPtr | Pointer to NLME-DIRECT-JOIN.request data structure |
Return
- Undocumented
16.1.3. ZbNlmeEdScanReq
enum ZbStatusCodeT ZbNlmeEdScanReq(struct ZigBeeT *zb, struct ZbNlmeEdScanReqT *req, void (*callback) (struct ZbNlmeEdScanConfT *scanConf, void *arg), void *cbarg);
NLME-ED-SCAN.request
Parameters
| req | Pointer to NLME-ED-SCAN.request data structure |
| cbarg | Callback function argument |
Return
- Returns ZB_NWK_STATUS_SUCCESS on success, or other ZbStatusCodeT on failure
16.1.4. ZbNlmeGetInterface
void ZbNlmeGetInterface(struct ZigBeeT *zb, struct ZbNlmeGetInterfaceReqT *req, struct ZbNlmeGetInterfaceConfT *conf);
NLME-GET-INTERFACE.request
Parameters
| req | Pointer to NLME-GET-INTERFACE.request data structure |
Return
- Undocumented
16.1.5. ZbNlmeGetReq
void ZbNlmeGetReq(struct ZigBeeT *zb, struct ZbNlmeGetReqT *getReqPtr, struct ZbNlmeGetConfT *getConfPtr);
NLME-GET.request
Parameters
| getReqPtr | Pointer to NLME-GET.request data structure |
Return
- Undocumented
16.1.6. ZbNlmeIeeeJoiningListClear
void ZbNlmeIeeeJoiningListClear(struct ZigBeeT *zb);
Clear IEEE joining list
Parameters
None Return
- Undocumented
16.1.7. ZbNlmeIeeeJoiningListRemove
bool ZbNlmeIeeeJoiningListRemove(struct ZigBeeT *zb, uint64_t extAddr);
Remove extended address from IEEE joining list
Parameters
| extAddr | Extended address to remove |
Return
- Returns true on success, or false otherwise
16.1.8. ZbNlmeJoinPolicyTimeoutRefresh
void ZbNlmeJoinPolicyTimeoutRefresh(struct ZigBeeT *zb);
Refresh join policy timer
Parameters
None Return
- Undocumented
16.1.9. ZbNlmeJoinReq
enum ZbStatusCodeT ZbNlmeJoinReq(struct ZigBeeT *zb, struct ZbNlmeJoinReqT *joinReqPtr, void (*callback)(struct ZbNlmeJoinConfT *joinConf, void *arg), void *cbarg);
NLME-JOIN.request
Parameters
| joinReqPtr | Pointer to NLME-JOIN.request data structure |
Return
16.1.10. ZbNlmeJoiningPolicyConfigure
bool ZbNlmeJoiningPolicyConfigure(struct ZigBeeT *zb, enum WpanJoinPolicyT policy, uint64_t *extAddrList, unsigned int numExtAddr, uint8_t *updateIdOverride);
External API to configure the joining policy and IEEE joining list. Should only be called by the Coordinator application. Router and End Devices applications should not be calling this, but rather obtain these parameters from the Coordinator through ZDP commands.
Parameters
| policy | New policy value |
| extAddrList | Pointer to extended address list |
| numExtAddr | Extended address index |
| updateIdOverride | Optional update ID to override old value intead of incrementing |
Return
16.1.11. ZbNlmeJoiningPolicyGet
enum WpanJoinPolicyT ZbNlmeJoiningPolicyGet(struct ZigBeeT *zb);
Get the value of ZB_NWK_NIB_ID_JoiningPolicy
Parameters
Return
- Returns joining policy enumeration value
16.1.12. ZbNlmeLeaveReq
enum ZbStatusCodeT ZbNlmeLeaveReq(struct ZigBeeT *zb, struct ZbNlmeLeaveReqT *leaveReqPtr, void (*callback) (struct ZbNlmeLeaveConfT *leaveConfPtr, void *arg), void *cbarg);
NLME-LEAVE.request
Parameters
| leaveReqPtr | Pointer to NLME-LEAVE.request data structure |
Return
16.1.13. ZbNlmeNetDiscReq
enum ZbStatusCodeT ZbNlmeNetDiscReq(struct ZigBeeT *zb, struct ZbNlmeNetDiscReqT *req, void (*callback) (struct ZbNlmeNetDiscConfT *conf, void *cbarg), void *cbarg);
NLME-NETWORK-DISCOVERY.request
Parameters
| req | Pointer to NLME-NETWORK-DISCOVERY.request data structure |
Return
16.1.14. ZbNlmeNetFormReq
enum ZbStatusCodeT ZbNlmeNetFormReq(struct ZigBeeT *zb, struct ZbNlmeNetFormReqT *req, void (*callback) (struct ZbNlmeNetFormConfT *formConf, void *arg), void *cbarg);
NLME-NETWORK-FORMATION.request
Parameters
| req | Pointer to NLME-NETWORK-FORMATION.request data structure |
Return
16.1.15. ZbNlmePanIdUpdateReq
void ZbNlmePanIdUpdateReq(struct ZigBeeT *zb, struct ZbNlmePanIdUpdateReqT *req, struct ZbNlmePanIdUpdateConfT *conf);
Sends a NWK update command to switch the NWK PanId.
Parameters
| req | PanId update request structure. |
Return
- Undocumented
16.1.16. ZbNlmePermitJoinReq
void ZbNlmePermitJoinReq(struct ZigBeeT *zb, struct ZbNlmePermitJoinReqT *permitReq, struct ZbNlmePermitJoinConfT *permitConf);
NLME-PERMIT-JOIN.request
Parameters
| permitReq | Pointer to NLME-PERMIT-JOIN.request data structure |
Return
- Undocumented
16.1.17. ZbNlmeResetReq
void ZbNlmeResetReq(struct ZigBeeT *zb, struct ZbNlmeResetReqT *resetReqPtr, struct ZbNlmeResetConfT *resetConfPtr);
NLME-RESET.request
Parameters
| resetReqPtr | Pointer to NLME-RESET.request data structure |
Return
- Undocumented
16.1.18. ZbNlmeRouteDiscReq
enum ZbStatusCodeT ZbNlmeRouteDiscReq(struct ZigBeeT *zb, struct ZbNlmeRouteDiscReqT *routeDiscReqPtr, void (*callback) (struct ZbNlmeRouteDiscConfT *discConf, void *cbarg), void *arg);
NLME-ROUTE-DISCOVERY.request
Parameters
| routeDiscReqPtr | Pointer to NLME-ROUTE-DISCOVERY.request data structure |
Return
16.1.19. ZbNlmeSetInterface
void ZbNlmeSetInterface(struct ZigBeeT *zb, struct ZbNlmeSetInterfaceReqT *req, struct ZbNlmeSetInterfaceConfT *conf);
NLME-SET-INTERFACE.request
Parameters
| req | Pointer to NLME-SET-INTERFACE.request data structure |
Return
- Undocumented
16.1.20. ZbNlmeSetReq
void ZbNlmeSetReq(struct ZigBeeT *zb, struct ZbNlmeSetReqT *setReqPtr, struct ZbNlmeSetConfT *setConfPtr);
NLME-SET.request
Parameters
| setReqPtr | Pointer to NLME-SET.request data structure |
Return
- Undocumented
16.1.21. ZbNlmeStartRouterReq
void ZbNlmeStartRouterReq(struct ZigBeeT *zb, struct ZbNlmeStartRouterReqT *req, struct ZbNlmeStartRouterConfT *conf);
NLME-START-ROUTER.request Parameters
| req | Pointer to NLME-START-ROUTER.request data structure |
Return
- Undocumented
16.1.22. ZbNlmeSyncReq
enum ZbStatusCodeT ZbNlmeSyncReq(struct ZigBeeT *zb, struct ZbNlmeSyncReqT *syncReqPtr, void (*callback) (struct ZbNlmeSyncConfT *syncConfPtr, void *arg), void *arg);
NLME-SYNC.request
Parameters
| syncReqPtr | Pointer to NLME-SYNC.request data structure |
Return
16.1.23. ZbNwkAddrLookupExt
uint64_t ZbNwkAddrLookupExt(struct ZigBeeT *zb, uint16_t nwkAddr);
Look up extended address from network address
Parameters
| zb | Zigbee instance |
| nwkAddr | Network address |
Return
- Returns extended address that corresponds to the network address if known, otherwise returns 0.
16.1.24. ZbNwkAddrLookupNwk
uint16_t ZbNwkAddrLookupNwk(struct ZigBeeT *zb, uint64_t extAddr);
Look up network address from extended address
Parameters
| extAddr | Extended address |
Return
- Returns network address that corresponds to the extended address if known, otherwise returns ZB_NWK_ADDR_UNDEFINED.
16.1.25. ZbNwkAddrSetNextChildAddr
void ZbNwkAddrSetNextChildAddr(struct ZigBeeT *zb, uint16_t nextChildAddr);
Set network address of next child to known value rather than stochastically assigned address.
Parameters
Return
- Undocumented
16.1.26. ZbNwkAddrStoreMap
bool ZbNwkAddrStoreMap(struct ZigBeeT *zb, uint16_t nwkAddr, uint64_t extAddr, bool resolve_now);
Store new address mapping
Parameters
| nwkAddr | New network address |
| extAddr | New extended address |
| resolve_now | Boolean that determines if address conflict resolution should be done now or after a delay |
Return
16.1.27. ZbNwkClearActiveKey
bool ZbNwkClearActiveKey(struct ZigBeeT *zb);
Clear the active key sequence number
Parameters
Return
16.1.28. ZbNwkCommissioningConfig
bool ZbNwkCommissioningConfig(struct ZigBeeT *zb, struct ZbNwkCommissioningInfo *commission_info);
Configures the MAC interface to be able to send and receive commissioning InterPAN packets. This API is provided so the stack does not need to expose the MLME-SET API. This should be called before the stack has been started (that is to say ZbStartup).
Parameters
| zb | Zigbee instance. |
| commission_info | Pointer to commissioning configuration data structure. |
Return
- True if configuration was successfully applied, false otherwise.
16.1.29. ZbNwkFastPollRelease
bool ZbNwkFastPollRelease(struct ZigBeeT *zb, struct nwk_fastpoll_entry_t *handle);
Release a fast polling request. If this is the last fast polling request, then fast polling is stopped.
Parameters
| entry | Fast polling entry pointer (handle) returned by ZbNwkFastPollRequest |
Return
- True if found and removed, false otherwise.
16.1.30. ZbNwkFastPollRequestWithDesc
struct nwk_fastpoll_entry_t * ZbNwkFastPollRequestWithDesc(struct ZigBeeT *zb, unsigned int delay, unsigned int timeout, const char *desc);
Make the stack begin (or continue) fast polling. Fast polling period is defined by ZB_NWK_NIB_ID_FastPollPeriod.
Parameters
| delay | Delay in milliseconds before sending the first NLME-SYNC (e.g. ZB_NWK_SYNC_DEFAULT_DELAY_MS) |
| timeout | Timeout in milliseconds for this fast polling interval. If 0, then interval is indefinite and only stopped by calling ZbNwkFastPollRelease |
| desc | Debug string indicating where this fast polling instance was started. |
Return
- Fast polling entry pointer, to be used as a handle to track this polling request.
16.1.31. ZbNwkFastPollResourceCount
unsigned int ZbNwkFastPollResourceCount(struct ZigBeeT *zb);
Get the current number of fast polling requests to the stack.
Parameters
Return
- Number of outstanding fast polling requests.
16.1.32. ZbNwkGet
enum ZbStatusCodeT ZbNwkGet(struct ZigBeeT *zb, enum ZbNwkNibAttrIdT attrId, void *attrPtr, unsigned int attrSz);
Performs an NLME-GET.request for an attribute with fixed length data, usually uint8_t, uint16_t, uint32_t, or uint64_t data types.
Parameters
| attrId | NWK Attribute Id to get |
| attrPtr | Pointer to memory to write attribute data |
| attrSz | Size of the attribute data |
Return
- Zigbee status code (e.g. ZB_STATUS_SUCCESS or ZB_NWK_STATUS_INVALID_PARAMETER)
16.1.33. ZbNwkGetActiveKey
bool ZbNwkGetActiveKey(struct ZigBeeT *zb, struct ZbNwkSecMaterialT *active_key);
Searches the nwkSecurityMaterialSet NIB attribute for a valid entry with a sequence number matching the active key sequence number. If found, the key will be copied into the out buffer and out will be returned.
Parameters
| active_key | Pointer to memory to write security material |
Return
16.1.34. ZbNwkGetArray
enum ZbStatusCodeT ZbNwkGetArray(struct ZigBeeT *zb, enum ZbNwkNibAttrIdT attrId, void *attrPtr, unsigned int *attrSz);
Performs an NLME-GET.request for an attribute with variable length data.
Parameters
| attrSz | Pointer to integer that reprsents maximum size of data that can be written to attrPtr. On function return, it contains the size of data actually written. |
Return
- Zigbee status code (for example, ZB_STATUS_SUCCESS or ZB_NWK_STATUS_INVALID_PARAMETER)
16.1.35. ZbNwkGetIndex
enum ZbStatusCodeT ZbNwkGetIndex(struct ZigBeeT *zb, enum ZbNwkNibAttrIdT attrId, void *attrPtr, unsigned int attrSz, unsigned int attrIndex);
Performs an NLME-GET.request for an attribute containing an array of values using an index.
Parameters
| attrId | NWK Attribute Id to set |
| attrSz | Size of attrPtr |
| attrIndex | Index of value |
Return
16.1.36. ZbNwkGetSecMaterial
bool ZbNwkGetSecMaterial(struct ZigBeeT *zb, uint8_t keySeqno, struct ZbNwkSecMaterialT *material);
Gets a network key for a given sequence number. Will also return the frame counter if requested. If extAddr is 0, then the outgoing frame counter will be written to frameCounterPtr. Otherwise, if extAddr is non-zero, the incoming frame counter corresponding to extAddr will be written to frameCounterPtr;
Parameters
| keySeqno | Sequence number |
| material | Pointer to memory to write security material |
Return
16.1.37. ZbNwkIeeeJoiningListEnabled
bool ZbNwkIeeeJoiningListEnabled(struct ZigBeeT *zb);
Check if join policy is set to WPAN_JOIN_POLICY_IEEELIST
Parameters
Return
16.1.38. ZbNwkIfGetTxPower
bool ZbNwkIfGetTxPower(struct ZigBeeT *zb, const char *name, int8_t *tx_power);
Gets the transmit power of an interface.
Parameters
| zb | ZigBee stack structure |
| name | Name of the interface |
| tx_power | Pointer to hold returned tx power value |
Return
16.1.39. ZbNwkIfSetTxPower
bool ZbNwkIfSetTxPower(struct ZigBeeT *zb, const char *name, int8_t tx_power);
Sets the transmit power of an interface.
Parameters
| tx_power | New tx power value |
Return
16.1.40. ZbNwkNntGetZdExtAddr
uint64_t ZbNwkNntGetZdExtAddr(struct ZigBeeT *zb);
Get the EUI-64 of the connected remote Zigbee Direct device, if applicable and available.
Parameters
Return
- EUI-64 of the connected remote Zigbee Direct device, or 0 if none found.
16.1.41. ZbNwkSendEdkaReq
bool ZbNwkSendEdkaReq(struct ZigBeeT *zb, void (*callback)(enum ZbStatusCodeT status, void *arg), void *arg);
Called by the application to manually send the End Device Timeout Request Command.
ZB_NWK_NIB_ID_DisablePeriodicTimers must be first set to 1, to disable the automatic sending of these commands. The application may want the periodic timers to be disabled, so it has more control of when packets are being transmit from the SED, in order to have fine control of battery power usage.
Parameters
| callback | Callback function pointer. This callback is called after the transmission of the End Device Timeout Request Command, and returns the status code for that transmission. It lets the application know if the command was able to be sent to the parent or not. For instance, a status of ZB_STATUS_SUCCESS (0x00) means command was received by the parent, and a status of ZB_WPAN_STATUS_NO_ACK (0xe9) means the command was not. |
Return
- Undocumented
16.1.42. ZbNwkSendLinkPowerDeltaNotify
bool ZbNwkSendLinkPowerDeltaNotify(struct ZigBeeT *zb);
Network Link power delta notify.
Parameters
Return
16.1.43. ZbNwkSendLinkPowerDeltaReq
bool ZbNwkSendLinkPowerDeltaReq(struct ZigBeeT *zb);
Network Link power delta request.
Parameters
Return
16.1.44. ZbNwkSet
enum ZbStatusCodeT ZbNwkSet(struct ZigBeeT *zb, enum ZbNwkNibAttrIdT attrId, void *attrPtr, unsigned int attrSz);
Performs an NLME-SET.request for an attribute.
Parameters
| attrPtr | Pointer to new attribute data |
| attrSz | Size of new attribute data |
Return
- Zigbee Status Code (for example, ZB_STATUS_SUCCESS or ZB_NWK_STATUS_INVALID_PARAMETER)
16.1.45. ZbNwkSetActiveKey
bool ZbNwkSetActiveKey(struct ZigBeeT *zb, struct ZbNwkSecMaterialT *active_key);
Perform an APSME-ADD-KEY.request and update the active key sequence number
Parameters
| active_key | Security material used for the request |
Return
16.1.46. ZbNwkSetFrameCounter
bool ZbNwkSetFrameCounter(struct ZigBeeT *zb, uint8_t keySeqno, uint64_t srcAddr, uint32_t newFrameCount);
Inserts or updates a frame counter in a given material set. If srcAddr is 0, or our local extended address then this call will update the outgoing frame counter. Otherwise this call will update (or create) an incoming frame counter. This function will compare the new frame counter against the existing one (if found). If the new value of the frame counter is stale then the update will be rejected and this function will return false. Otherwise, the update will always succeed (with a possible LRU eviction if the table is full). However, due to some known buggy devices, frame counter resets have been observed out in the wild. Therefore, stale frame counters will be accepted into the table subject to rate limiting and cooldown policies (controlled by the nwkFrameCounterCooldown NIB attribute).
Parameters
| keySeqno | Key sequence number |
| srcAddr | Extended address |
| newFrameCount | New frame counter |
Return
16.1.47. ZbNwkSetIndex
enum ZbStatusCodeT ZbNwkSetIndex(struct ZigBeeT *zb, enum ZbNwkNibAttrIdT attrId, void *attrPtr, unsigned int attrSz, unsigned int attrIndex);
Performs an NLME-SET.request for an attribute containing an array of values using an index.
Parameters
| attrIndex | Index of value to modify |
Return
16.1.48. ZbNwkToggleDutyCycle
bool ZbNwkToggleDutyCycle(struct ZigBeeT *zb, bool enable);
Enable or disable Duty Cycle management in the MAC. Disabling duty cycle will also clear the duty cycle history and set the status to MCP_DUTYCYCLE_STATUS_NORMAL. This function would typically be used in conjunction with ZB_NWK_NIB_ID_TxPowerMgmtSupported, which configures TX power control in the NWK and MAC.
Parameters
| enable | New duty cycle setting |
Return
16.1.49. ZbNwkZdGenerateBasicKey
bool ZbNwkZdGenerateBasicKey(struct ZigBeeT *zb, uint64_t zvd_eui, uint8_t key[ZB_SEC_KEYSIZE], uint8_t seqno);
Generate the basic key using network key with input seqnuence number and the ZVD EUI. This can used to generate basic key using old network keys as well.
Parameters
| zvd_eui | ZVD EUI64 |
| key | Output array to store generated basic key. |
| seqno | Sequence number of network key to use. |
Return
- true if basic key is generated successfully, false otherwise.
16.1.50. nwk_mac_filter_add
bool nwk_mac_filter_add(struct ZigBeeT *zb, uint64_t extAddr, uint16_t nwkAddr, uint8_t in_cost);
Add a new address filter. If the in_cost parameter is set to 0, then all matching frames are dropped.
Parameters
| extAddr | The EUI-64 address to filter, or 0. |
| nwkAddr | The NWK short address to filter, or ZB_NWK_ADDR_UNDEFINED. |
| in_cost | The incoming cost (e.g. LQI) to assign to this device. If 0, all frames from this matching device are dropped. |
Return
- True if the filter was added, false otherwise.
16.1.51. nwk_mac_filter_debug
void nwk_mac_filter_debug(struct ZigBeeT *zb);
When called, prints the address filtering table to the Zigbee debug log (level = ZB_LOG_MASK_INFO). Used for debugging only.
Parameters
Return
- None
16.1.52. nwk_mac_filter_del
bool nwk_mac_filter_del(struct ZigBeeT *zb, uint64_t extAddr, uint16_t nwkAddr);
Removes an address filter matching either of the addresses provided.
Parameters
| extAddr | The EUI-64 address of the filter to remove, or 0. |
| nwkAddr | The NWK short address of the filter to remove, or ZB_NWK_ADDR_UNDEFINED. |
Return
- True if the filter was removed, false otherwise.
16.2. Enumerations
16.2.1. ZbNwkNetworkStatusCodeT
NLME-NWK-STATUS.indication status codes
| ZB_NWK_STATUS_CODE_NO_ROUTE_AVAILABLE | No route available |
| ZB_NWK_STATUS_CODE_TREE_LINK_FAILURE | Tree link failure |
| ZB_NWK_STATUS_CODE_NON_TREE_LINK_FAILURE | Non-tree link failure |
| ZB_NWK_STATUS_CODE_LOW_BATTERY | Low battery level |
| ZB_NWK_STATUS_CODE_NO_ROUTING_CAPACITY | No routing capacity |
| ZB_NWK_STATUS_CODE_NO_INDIRECT_CAPACITY | No indirect capacity |
| ZB_NWK_STATUS_CODE_INDIRECT_EXPIRY | Indirect transaction expiry |
| ZB_NWK_STATUS_CODE_TARGET_UNAVAILABLE | Target device unavailable |
| ZB_NWK_STATUS_CODE_TARGET_UNALLOCATED | Target address unallocated |
| ZB_NWK_STATUS_CODE_PARENT_LINK_FAILURE | Parent link failure |
| ZB_NWK_STATUS_CODE_VALIDATE_ROUTE | Validate route |
| ZB_NWK_STATUS_CODE_SOURCE_ROUTE_FAILURE | Source route failure |
| ZB_NWK_STATUS_CODE_MANY_TO_ONE_FAILURE | Many-to-one route failure |
| ZB_NWK_STATUS_CODE_ADDRESS_CONFLICT | Address conflict |
| ZB_NWK_STATUS_CODE_VERIFY_ADDRESS | Verify address |
| ZB_NWK_STATUS_CODE_PANID_UPDATE | PAN identifier update |
| ZB_NWK_STATUS_CODE_ADDRESS_UPDATE | Network address update |
| ZB_NWK_STATUS_CODE_BAD_FRAME_COUNTER | Bad frame counter |
| ZB_NWK_STATUS_CODE_BAD_KEY_SEQNUM | Bad key sequence number |
| ZB_NWK_STATUS_CODE_UNKNOWN_COMMAND | Unknown Command |
| ZB_NWK_STATUS_CODE_PANID_CONFLICT_REPORT | PanId conflict report. |
ZB_NWK_STATUS_CODE_INCOMING_FRAME_COUNTER |
(Exegin custom) An incoming frame counter is greater than 0x80000000 |
16.3. Structures
16.3.1. ZbNlmeBcnSurveyConfT
NLME-BEACON-SURVEY.confirm
Parameters
| enum ZbStatusCodeT status | status |
| uint8_t total_beacons | Total number of beacons received during a beacon survey. |
| uint8_t on_nwk_beacons | The total number of Zigbee Network beacons where the Extended PAN ID matches the local device’s nwkExtendedPanId. |
| uint8_t potential_parent_beacons | The total number of Zigbee Network beacons where the Extended PAN ID matches and the Zigbee Beacon payload indicates End Device Capacity = TRUE. |
| uint8_t other_nwk_beacons | The total number of IEEE 802.15.4 beacons from other Zigbee networks or other IEEE 802.15.4 networks. Other Zigbee network beacons are defined as when the Extended PAN ID does not match the local Extended PAN ID. |
| struct { uint8_t count | Count of potential parents detected. |
| struct { uint16_t nwkaddr | Network/Short address of potential parent. |
| uint8_t lqa | LQA for the parent link. |
| /*< Single potential parent entry. */
} *potential_parent_list |
Potential parent list. |
16.3.2. ZbNlmeBcnSurveyReqT
NLME-BEACON-SURVEY.request
Parameters
| struct ZbChannelListT scan_channels | ScanChannelList structure. |
| uint8_t scan_duration | Scan duration. |
| uint8_t scan_type | Scan type: ZB_SCAN_TYPE_ACTIVE or ZB_SCAN_TYPE_ENHANCED |
16.3.3. ZbNlmePanIdUpdateConfT
NLME-PANID-UPDATE.confirm
Parameters
16.3.4. ZbNlmePanIdUpdateReqT
NLME-PANID-UPDATE.request
Parameters
| uint16_t new_pan_id | New NWK PanId. |
16.3.5. ZbNwkCommissioningInfo
Commissioning configuration.
Parameters
| uint8_t ifc_index | NWK interface index. Starts at 0. |
| uint16_t nwk_addr | Network Address to configure (default is ZB_NWK_ADDR_UNDEFINED) |
| uint16_t pan_id | PAN Id to configure (default is ZB_NWK_ADDR_UNDEFINED) |
| uint8_t rx_on | Configures RxOnWhenIdle to MAC |
| uint8_t page | Channge Page to configure |
| uint8_t channel | Channel to configure |
17. Security utilities
#include "zigbee.security.h"
17.1. Functions
17.1.1. ZbAesMmoHash
bool ZbAesMmoHash(uint8_t const *data, const unsigned int length, uint8_t *digest);
Performs an AES MMO hash on the selected data
Parameters
| zb | Zigbee stack instance |
| data | data to hash |
| length | length of data to hash |
| digest | hash must be AES_BLOCK_SIZE in size |
Return
- Undocumented
17.1.2. ZbSecAddDeviceLinkKeyByInstallCode
enum ZbStatusCodeT ZbSecAddDeviceLinkKeyByInstallCode(struct ZigBeeT *zb, uint64_t extAddr, uint8_t *ic, unsigned int len);
ZbApsmeAddKeyReq helper function. Adds a device key-pair to the stack as a Trust Center Link Key type. This API is typically only used by a Trust Center to add link keys for devices that need to join the network. On the joiner side, the link key is set to the preconfiguredLinkKey parameter in the ZbStartupT configuration when calling ZbStartup to join the network.
Parameters
| extAddr | The EUI64 address of the device matching the link key |
| ic | The install code, including the trailing 2-octet CRC |
| len | Length of the Install Code in bytes |
Return
17.1.3. ZbSecAddDeviceLinkKeyByKey
enum ZbStatusCodeT ZbSecAddDeviceLinkKeyByKey(struct ZigBeeT *zb, uint64_t extAddr, uint8_t *key);
ZbApsmeAddKeyReq helper function. Adds a device key-pair to the stack as a Trust Center Link Key type. This API is typically only used by a trust center to add link keys for devices that need to join the network. On the Joiner side, the link key is set to the preconfiguredLinkKey parameter in the ZbStartupT configuration when calling ZbStartup to join the network.
Parameters
| key | The link key, of length ZB_SEC_KEYSIZE, to add |
Return
18. Startup
#include "zigbee.startup.h"
18.1. Functions
18.1.1. ZbStartup
enum ZbStatusCodeT ZbStartup(struct ZigBeeT *zb, struct ZbStartupT *configPtr, void (*callback)(enum ZbStatusCodeT status, void *cb_arg), void *arg);
The startup code also handles callbacks from the stack to maintain the network and security processes. For example, these include the handling of APSME-UPDATE-DEVICE.indication messages when acting as a Coordinator Trust Center, to handle the authentication procedure described in section 4.6.3.2 of Zigbee R22.
The message callback handlers can be overridden by the application by creating message filters using ZbMsgFilterRegister.
This function and the entire startup code can be bypassed by the application, and the network layer APIs used directly, if so desired.
Parameters
| configPtr | Pointer to ZbStartupT configuration structure. |
| callback | Application callback that is called with the final result of the startup procedure. |
Return
- Zigbee status code whether the startup procedure has been started. If ZB_STATUS_SUCCESS, then the callback will be called with the final result.
18.1.2. ZbStartupConfigGetProDefaults
void ZbStartupConfigGetProDefaults(struct ZbStartupT *configPtr);
Get the default configuration for a PRO network.
Parameters
| configPtr | Startup configuration to initialize |
Return
- None
18.1.3. ZbStartupConfigGetProSeDefaults
void ZbStartupConfigGetProSeDefaults(struct ZbStartupT *configPtr);
Same as ZbStartupConfigGetProDefaults, but clears the preconfigured global link keys.
Parameters
Return
- None
18.1.4. ZbStartupDeviceInterviewComplete
bool ZbStartupDeviceInterviewComplete(struct ZigBeeT *zb, uint64_t joiner_eui64, bool success);
The application calls this when it is done with the Device Interview process for a particular Joiner. The Device Interview process starts in the application when the stack calls the device_interview_cb() callback function defined in the 'struct ZbStartupT' startup configuration.
Parameters
| joiner_eui64 | The EUI64 address of the Joiner being interviewed. |
| success | If true, then the stack will send the Transport Key with the Network Key to end the Device Interview and Joining process. |
Return
- True if the request was processed successfully (that is to say the joiner is actively being tracked by the stack), or false otherwise.
18.1.5. ZbStartupFindBindStart
enum ZbStatusCodeT ZbStartupFindBindStart(struct ZigBeeT *zb, void (*callback)(enum ZbStatusCodeT status, void *arg), void *arg);
Manually start Finding & Binding. F&B is also started automatically after joining the network.
Parameters
| callback | Application callback to call after Finding & Binding complete |
| arg | Application callback argument |
Return
18.1.6. ZbStartupFindBindStartEndpoint
enum ZbStatusCodeT ZbStartupFindBindStartEndpoint(struct ZigBeeT *zb, uint8_t endpoint, void (*callback)(enum ZbStatusCodeT status, void *arg), void *arg);
Same as ZbStartupFindBindStart, but only for a single endpoint.
Parameters
| endpoint | Endpoint to perform Finding & Binding from. |
Return
18.1.7. ZbStartupPersist
enum ZbStatusCodeT ZbStartupPersist(struct ZigBeeT *zb, const void *pdata, unsigned int plen, struct ZbStartupCbkeT *cbke_config, void (*callback)(enum ZbStatusCodeT status, void *arg), void *arg);
Try starting stack using persistence data provided. NOTE: In case of a Zigbee virtual device (ZVD) this API only takes care of restoring the stack from persistence data and does not perform secure rejoin. So the ZVD application shall reestablish the secure session over BLE using basic or admin key and then perform the secure rejoin using ZbStartupRejoin() API.
Parameters
| pdata | Pointer to persistent data |
| plen | Length of persistent data |
| cbke_config | Optional pointer to CBKE configuration data structure. |
| callback | Application callback to call after persistence is completed. It is necessary for the application to specify this callback so it knows exactly when it is safe to start transmitting packets to the Zigbee network. If this function returns an error, then no callback will be generated. |
Return
18.1.8. ZbStartupRejoin
enum ZbStatusCodeT ZbStartupRejoin(struct ZigBeeT *zb, void (*callback)(struct ZbNlmeJoinConfT *conf, void *arg), void *cbarg);
ZbStartupRejoin is a wrapper for ZbNlmeJoinReq(ZB_NWK_REJOIN_TYPE_NWKREJOIN). Use ZbStartupRejoin instead, because the internal startup handler will restart any timers we need to maintain our parent.
Must already be connected to a network. If not on a network and want to rejoin as way to connect, use ZbStartup with ZbStartTypeRejoin.
Parameters
| callback | Application callback to call after rejoin is complete, indicating success or failure. |
| cbarg | Application callback argument |
Return
enum ZbStatusCodeT ZbStartupTclkStart(struct ZigBeeT *zb, void (*callback)(enum ZbStatusCodeT status, void *arg), void *arg);
18.1.9. ZbStartupTclkStart
The application can call ZbStartupTclkStart if it wants to update the trust center link key post join using APS-Request Key method. This is usually done under following scenarios,
Note. In case of a Zigbee Direct (ZDD) updating a provisional link key, after it was commissioned via out-of-band commissioning mechanism. 2. To periodically generate a new APS Link Key with the Trust Center. Continual cycling of the TC Link Key is a 'Works With All Hubs (WWAHU)' security recommendation.
Parameters
| callback | Application callback that is called with the final result of the tclk procedure. |
Return
- true if the tclk is completed successfuly, false otherwise.
18.1.10. ZbStartupTcsoAbort
bool ZbStartupTcsoAbort(struct ZigBeeT *zb);
Abort a TCSO, if it’s running. This function should not be necessary, but a Sleepy Device application may need it if it wants to go to sleep before ZbStartupTcsoStart has finished.
Parameters
Return
- True if TCSO was aborted, false otherwise (i.e. wasn’t running).
18.1.11. ZbStartupTcsoStart
bool ZbStartupTcsoStart(struct ZigBeeT *zb, void (*callback)(enum ZbTcsoStatusT status, void *arg), void *arg);
The Stack with the help of the ZCL Keep Alive cluster will automatically detect the loss of the Trust Center and start the TCSO process. Before the TCSO process starts and the 'tcso_callback' callback is provided in the startup configuration, it is called to check if the application wants to halt the TCSO process from starting or let it continue. Refer to the description for 'tcso_callback' in the startup configuration for more info.
The application can call ZbStartupTcsoStart at any time if it thinks it has lost communication with the Trust Center and to manually begin the TCSO process.
Parameters
| zvd_parent_info | Parent information structure in case of ZVD. This parameter shall be set to NULL if not acting as ZVD. |
| callback | Application callback that is called after TCSO is complete. |
Return
- True if TCSO was started and to wait for callback to indicate completion. False if TCSO wasn’t started.
18.1.12. ZbStartupTouchlinkTargetStop
enum ZbStatusCodeT ZbStartupTouchlinkTargetStop(struct ZigBeeT *zb);
If Touchlink Target was started with ZbStartup, this API can be used to stop it.
Parameters
Return
- Zigbee status code whether touchlink was successfully stopped or not.
18.1.13. ZbTrustCenterRejoin
enum ZbStatusCodeT ZbTrustCenterRejoin(struct ZigBeeT *zb, void (*callback)(enum ZbStatusCodeT status, void *arg), void *cbarg);
Trust Center Rejoin - unsecured rejoin (already joined to network, but missed a NWK key update).
Parameters
| callback | Application callback to call after Trust Center rejoin is complete. If this function returns an error, then no callback will be generated. |
Return
18.2. Enumerations
18.2.1. ZbStartType
Startup control-codes as per the ZCL Spec, Commissioning Cluster’s StartupControl attribute in the "Startup Parameters Attribute Set"
| ZbStartTypePreconfigured | (0x00) Preconfigured. No explicit form, join or rejoin to be performed. |
| ZbStartTypeForm | (0x01) Form network |
| ZbStartTypeRejoin | (0x02) Rejoin network |
| ZbStartTypeJoin | (0x03) Join network |
| ZbStartTypeTouchlink | [Internal stack use only] Touchlink |
| ZbStartTypeFindBind | [Internal stack use only] Finding & Binding |
| ZbStartTypeNone | [Internal stack use only] None |
18.3. Structures
18.3.1. ZbStartupCbkeT
CBKE configuration parameters for ZbStartup. This configuration is only applicable if the 'suite_mask' is non-zero.
Parameters
| uint8_t endpoint | Endpoint to assign ZCL Key Exchange cluster. Default is ZB_ENDPOINT_CBKE_DEFAULT (240) |
| uint16_t deviceId | Device Id to assign to the endpoint created for the ZCL Key Exchange cluster. Default is ZCL_DEVICE_METER |
| uint16_t suite_mask | The Key Exchange suite bitmask. E.g. ZCL_KEY_SUITE_CBKE2_ECMQV for CBKE version 2 (cbke_v2). |
| struct ZbZclCbkeInfoT cbke_v1 | CBKE version 1 certificate and security keys configuration. Only applicable if ZCL_KEY_SUITE_CBKE_ECMQV is set in suite_mask. |
| struct ZbZclCbke2InfoT cbke_v2 | CBKE version 2 certificate and security keys configuration. Only applicable if ZCL_KEY_SUITE_CBKE2_ECMQV is set in suite_mask. |
| uint8_t term_wait_time | This is the time in seconds to include in the Wait Time field in the Terminate Key Establishment command. The Wait Time is the time for the CBKE initiator to wait before trying again. The default value is 0xfe (254 seconds). |
| bool tc_keepalive_server_enable | = 0), this flag determines whether to allocate the Trust Center Keep Alive Server (true) or Client (false). The Trust Center should set this flag to true, and all other joiners should set this flag to false. |
| uint8_t tc_keepalive_base | Trust Center Keep Alive Server 'Base' attribute value in minutes. If zero, let the stack choose a default value. |
| uint16_t tc_keepalive_jitter | Trust Center Keep Alive Server 'Jitter' attribute value in seconds. If zero, let the stack choose a default value. |
| tcso_callback
bool (*tcso_callback)(enum ZbTcsoStatusT status, void *arg)
Application callback that is called to notify of any Trust Center Swap Out (TCSO) events initiated by the Keep Alive Client cluster. If the status is set to ZB_TCSO_STATUS_DISCOVERY_UNDERWAY, the application can return false to this callback to halt the TCSO process from continuing. This allows the application to dictate when to start TCSO; for example, during the next wake-cycle if the device is sleepy. The Keep Alive Client is also halted in this case, but will restart after the application calls ZbStartupTcsoStart to perform TCSO, or it calls ZbZclKeepAliveClientStart to restart the Keep Alive mechanism. If the application returns true to this callback, then the TCSO process will proceed normally. |
| void *tcso_arg |
18.3.2. ZbStartupT
The set of configuration parameters used to form or join a network using ZbStartup. Should be first initialized using ZbStartupConfigGetProDefaults or ZbStartupConfigGetProSeDefaults.
Parameters
| uint16_t shortAddress | Network short address. Only applicable if startupControl is ZbStartTypePreconfigured or ZbStartTypeRejoin |
| uint16_t panId | Network PAN Id. Only applicable if startupControl is ZbStartTypePreconfigured or ZbStartTypeRejoin |
| uint16_t networkManagerAddress | Network Manager Address. Only applicable if startupControl is ZbStartTypePreconfigured or ZbStartTypeRejoin |
| uint64_t extendedPanId | Extended PAN Id.
If startupControl is ZbStartTypeForm and extendedPanId is zero, then the device extended address (EUI) is used. If startupControl is ZbStartTypeRejoin a non-zero extendedPanId must be provided. If startupControl is ZbStartTypeJoin, the device only attempts to join a network matching the extendedPanId. If extendedPanId is zero, then the device attempts to join any available network, sorted by LQI. If startupControl is ZbStartTypePreconfigured a non-zero extendedPanId must be provided. |
| struct ZbChannelListT channelList | Specify the channel mask(s) to use. If no channel masks are specified, ZB_BDB_PrimaryChannelSet and ZB_BDB_SecondaryChannelSet are used instead. |
| uint8_t stackProfile | Network Stack Profile. If not ZB_NWK_STACK_PROFILE_PRO, application must configure the following NIB parameters before calling ZbStartup: nwkMaxChildren, nwkReportConstantCost, nwkLinkStatusPeriod, nwkTransactionPersistenceTime, nwkPassiveAckTimeout, nwkMaxBroadcastRetries, nwkSecureAllFrames, nwkSecurityLevel |
| uint8_t bdbCommissioningMode | BDB Commissioning Mode mask. Set to 0 by default. If BDB_COMMISSION_MODE_TOUCHLINK is set, then Touchlink will be used. If BDB_COMMISSION_MODE_FIND_BIND is set, then Finding &Binding will be used after joining. |
| enum ZbStartType startupControl | Startup Type. Not applicable if BDB_COMMISSION_MODE_TOUCHLINK commissioning mode is set.
If startup type is ZbStartTypeJoin, the ZB_APS_IB_ID_SCAN_COUNT attribute is used to control the number of scans to perform while searching for a network to join. Similarily, the ZB_BDB_ScanDuration attribute is used to configure the MAC scan duration to use for scans during network joining and forming. |
| struct { uint8_t level | Security Level. Default is 0x05. |
| bool useInsecureRejoin | Configures ZB_APS_IB_ID_USE_INSECURE_JOIN. |
| uint64_t trustCenterAddress |
Configures ZB_APS_IB_ID_TRUST_CENTER_ADDRESS. If forming the network and assuming the role of Trust Center, the device’s extended address will be used instead, unless this parameter has been explicitly set to ZB_DISTRIBUTED_TC_ADDR. |
| uint8_t preconfiguredLinkKey | Preconfigured Link Key |
| uint8_t distributedGlobalKey | Preconfigured Distributed Global Link Key |
| uint8_t networkKey |
Configures the Network Key with key type set to ZB_SEC_KEYTYPE_STANDARD_NWK. Only applicable if startupControl is ZbStartTypePreconfigured. |
| uint8_t networkKeySeqNum | Configures the Network Key Sequence Number for the Network Key. Also sets ZB_NWK_NIB_ID_ActiveKeySeqNumber to this value. Only applicable if startupControl is ZbStartTypePreconfigured. |
| enum ZbSecKeyTypeT networkKeyType | Deprecated and not used. |
| struct ZbStartupCbkeT cbke | CBKE certificate configuration |
| uint8_t zdLinkKeyFlags | APS Link key flags provided as part of commissioning join to ZDD e.g, ZD_TLV_LINK_KEY_FLAG_UNIQUE. NOTE: Only applicable with CONFIG_ZB_ZDD_SUPPORT. |
| uint8_t nwkUpdateId | ZB_NWK_NIB_ID_UpdateId, only used in case of ZDD (Zigbee Direct Device) Commissioning form/OOB join performed by ZVD (Zigbee Virtual Device). NOTE: Only applicable with CONFIG_ZB_ZDD_SUPPORT. |
| uint8_t capability | Device capability mask. Default value includes:
MCP_ASSOC_CAP_PWR_SRC (mains power), MCP_ASSOC_CAP_RXONIDLE (radio receiver is on, not sleepy), MCP_ASSOC_CAP_ALLOC_ADDR (parent allocates network address), MCP_ASSOC_CAP_DEV_TYPE (full function device) |
| uint8_t endDeviceTimeout |
End-device timeout is only used by end-devices. It configures the time used to periodically update the Parent device so this device is not removed from the Parent’s NWK Neighbor Table. Configures ZB_NWK_NIB_ID_EndDeviceTimeoutDefault. Timeout = (60 * 2^n) seconds for n > 0. If n = 0, timeout = 10 seconds. Setting to ZB_NWK_CONST_ENDDEV_TIMEOUT_DISABLED (0xff) disables end-device timeout. |
| uint16_t fastPollPeriod | Configures ZB_NWK_NIB_ID_FastPollPeriod. |
| struct { uint8_t tl_endpoint | Endpoint for the Touchlink Cluster (e.g. ) |
| uint8_t bind_endpoint | Endpoint to use when binding clusters from Initiator to Target. |
| uint16_t deviceId | e.g. ZCL_DEVICE_ONOFF_SWITCH |
| uint8_t zb_info | e.g. ZCL_TL_ZBINFO_TYPE_ROUTER |
| uint8_t flags | e.g. ZCL_TL_FLAGS_IS_TARGET |
| const void *persist_buf |
Pointer to persistence data. Only applicable if ZCL_TL_ZBINFO_USE_PERSIST flag is set in zb_info. |
| unsigned int persist_len | Length of persistence data. |
| struct ZbTouchlinkCallbacks callbacks | Callback functions for Touchlink Controller Device Utility commands. |
| void *cb_arg | Pointer to application data that will be used with Touchlink callbacks. |
| struct { uint8_t server_ep | Endpoint to assign to Sub-GHz server cluster to perform duty cycle checks. |
| uint16_t device_id | DeviceId to assign to the endpoint on which Sub-GHz server cluster is created. |
| uint8_t supp_key_nego_methods | A bitmask of the supported key negotiation methods e.g, ZB_DLK_STATIC_KEY_REQUEST. |
| uint8_t supp_pre_shared_secrets | A bitmask of the supported pre-shared secrets e.g, ZB_DLK_SUPP_PSK_SYMMETRIC_AUTH_TOKEN. |
| device_interview_cb
void (*device_interview_cb)(struct ZbApsRelayInfoT *relay_info, uint64_t joiner_eui, void *arg)
Device Interview callback. This is called for a device acting as the Trust Center when the Device Interview process can start with the Joiner. As packets are sent as Downstream Relays to the Joiner, the security timer is refreshed by the amount given by apsDeviceInterviewTimeoutPeriod. The 'relay_info' parameter includes the information about where to send packets for the interview process so the Joiner can receive them. The 'joiner_eui' parameter is the Extended Address of the Joiner. Once the TC application is done with the interview process, it must call ZbStartupDeviceInterviewComplete. Refer to that function’s description for more information. |
| void *device_interview_cb_arg | Argument pointer to include in the device interview callback. |
19. TLV Utilities
#include "zigbee.tlv.h"
19.1. Description
This file defines all the ZigBee TLV APIs and macros.
19.2. Functions
19.2.1. zb_tlv_decode
int zb_tlv_decode(const uint8_t *buffer, unsigned int buffer_length, struct zb_tlv *tlv_array, const unsigned int tlv_count);
Given a list of desired TLVs, examine all the TLVs as per the 'General TLV processing rules'. Update the desired TLV list with all matching TLVs found in the buffer. It is expected that the desired TLV list will have the length field populated with the 'minimum known length' for all the entries. Desired TLVs found in the buffer with length < than the 'minimum known length' are considered 'malformed TLVs'. All the unknown TLVs found in the buffer are locally stored to ensure no duplicate TLVs are present.
Parameters
| buffer | (IN) input buffer with TLVs. |
| buffer_length | (IN) input buffer length. |
| tlv_array | (IN/OUT) the TLVs that we are looking for. |
| tlv_count | (IN) number of TLVs in the array we are looking for. |
Return
- length of buffer decoded on success. ZB_TLV_STATUS_FAILURE, if any of the input parameters were invalid. ZB_TLV_STATUS_DUPLICATE_TLV, if a duplicate TLV is found. ZB_TLV_STATUS_BUFFER_TRUNCATED, if any TLV is found to be malformed.
19.2.2. zb_tlv_decode_check_mandatory
bool zb_tlv_decode_check_mandatory(const struct zb_tlv *tlv_array, const unsigned int tlv_count);
Check all mandatory TLVs have non-NULL value fields.
Parameters
| tlv_array | (IN) TLV array. |
| tlv_count | (IN) depth of input TLV array. |
Return
- true if all mandatory TLVs were found false otherwise
19.2.3. zb_tlv_encode
int zb_tlv_encode(uint8_t *buffer, unsigned int buffer_length, const struct zb_tlv *tlv_array, const unsigned int tlv_count);
Given a list of TLVs, this API encodes TLV list into input buffer.
Parameters
| tlv_array | (IN) array of TLVs to be encoded. |
| tlv_count | (IN) depth of TLV array. |
Return
- length encoded, negative on error
19.2.4. zb_tlv_encode_length
int zb_tlv_encode_length(struct zb_tlv *tlv_array, const unsigned int tlv_count);
Compute the size of buffer required, if the input TLVs were to be encoded.
Parameters
| tlv_array | (IN) input TLV array. |
Return
- size of buffer required to encode input TLVs.
19.2.5. zb_tlv_type_exists
bool zb_tlv_type_exists(uint8_t *buffer, unsigned int buffer_length, enum zb_tlv_type type);
Check if the TLV type exists in the input buffer. This API will return failure if the TLV does not exist or is found to be truncated.
Parameters
| buffer | (IN) input buffer for TLV processing. |
| type | (IN/OUT) TLV type ID being searched. |
Return
- true if TLV exists, false otherwise
19.3. Enumerations
19.3.1. zb_tlv_type
ZigBee TLV type ID enumeration. TLV IDs have been split into local and global TLVs based on their usage. Local TLVs are specific to a single message and their tag IDs may overlap with the local TLV IDs of different messages. Range of local TLV tag IDs is 0-63. However, global TLVs have a single format across all messages and layers and are used in 2 or more different messages. Global TLV IDs represent a global state and is not completely ephemeral in nature. Range of global TLV tag IDs is 64-255.
| ZB_TLV_CLEAR_ALL_BIND_REQ_EUI64 | Clear_All_Bindings_req EUI64 TLV. |
| ZB_TLV_KEY_NEGO_CURVE25519_PUB | Security_Key_negotiation_req/rsp Curve25519 Public Point TLV. |
| ZB_TLV_AUTH_TOKEN_ID | Security_Retrieve_authentication_token_req Authentication Token ID TLV. |
| ZB_TLV_TARGET_IEEE_ADDR | ZDO Security_Get_authentication_level_req Target IEEE Address TLV. |
| ZB_TLV_DEVICE_AUTH_LEVEL | ZDO Security_Get_authentication_level_rsp Device Authentication Level TLV. |
| ZB_TLV_PROCESSING_STATUS | ZDO Security_Set_Configuration_rsp Processing Status TLV. |
| ZB_TLV_KEY_UPDATE_SEL_KEY_NEGO_METHOD | Security_Key_update_req/rsp selected key negotiation method TLV. |
| ZB_TLV_DEVICE_EUI64_LIST | ZDO Security_Decommission_req Device EUI64 List TLV. |
| ZB_TLV_APS_FC_CHALLENGE | ZDO Security_Challenge_req APS frame counter challenge TLV. |
| ZB_TLV_APS_FC_RESPONSE | ZDO Security_Challenge_rsp APS frame counter response TLV. |
| ZB_TLV_NODE_DESC_RSP_SEL_KEY_NEGO_METHOD | Node_Desc_Rsp selected key negotiation method TLV. |
| ZB_TLV_BCN_SURVEY_CONFIG | Mgmt_Beacon_Survey_req Configuration TLV. |
| ZB_TLV_BCN_SURVEY_RESULTS | Mgmt_Beacon_Survey_rsp Results TLV. |
| ZB_TLV_BCN_SURVEY_POTENTIAL_PARENTS | Mgmt_Beacon_Survey_rsp Potential Parents TLV. |
| ZB_TLV_RELAY_MSG | APS Relay message TLV. |
| ZB_TLV_LINK_KEY_FEATURES_CAPABILITIES | Link-Key Features & Capabilities TLV. |
| ZB_TLV_MFG_SPECIFIC | Manufacturer specific TLV (ID 64 / 0x40) |
| ZB_TLV_SUPP_KEY_NEGO_METHOD | Supported key negotiation method TLV (ID 65 / 0x41) |
| ZB_TLV_PANID_CONFLICT_REPORT | PANID conflict report global TLV (ID 66 / 0x42) |
| ZB_TLV_NEXT_PANID | Next PAN ID TLV (ID 67 / 0x43) |
| ZB_TLV_NEXT_CHANNEL | Next channel change TLV (ID 68 / 0x44) |
| ZB_TLV_PASSPHRASE_128 | Symmetric passphrase TLV (ID 69 / 0x45) |
| ZB_TLV_ROUTER_INFO | Router Information TLV (ID 70 / 0x46) |
| ZB_TLV_FRAG_PARAM | Fragmentation Parameters TLV (ID 71 / 0x47) |
| ZB_TLV_JOINER_ENCAPSULATION | Joiner Encapsulation TLV (ID 72 / 0x48) |
| ZB_TLV_BEACON_APPENDIX_ENCAPSULATION | Beacon Appendix Encapsulation TLV (ID 73 / 0x49) |
| ZB_TLV_CONFIG_PARAM | Configuration params TLV (ID 75 / 0x4b) |
| ZB_TLV_DEVICE_CAP_EXT_GLOBAL | Device Capability Extension Global TLV (ID 76 / 0x4c) |
| ZB_TLV_ID_RESERVED | Global TLV ID’s >= this ID are reserved (ID 77 / 0x4d) |
19.4. Structures
19.4.1. zb_tlv
ZigBee TLV structure definition.
Parameters
| enum zb_tlv_type type | Valid range for length field is 1-256. If the caller of TLV API zb_tlv_encode() provides length field of a TLV as 0 or >256 it is treated as invalid and returned with error ZB_TLV_STATUS_INVALID_LEN. |
| const uint8_t *value |
20. ZDO Layer
#include "zigbee.zdo.h"
20.1. Description
This file provides the declaration of all the public APIs and macros used by the ZDO layer.
20.2. Functions
20.2.1. ZbZdoActiveEpReq ==
enum ZbStatusCodeT ZbZdoActiveEpReq(struct ZigBeeT *zb, struct ZbZdoActiveEpReqT *req, void (*callback) (struct ZbZdoActiveEpRspT *rsp, void *cb_arg), void *arg);
Retrieve the active endpoint list for a device.
Parameters
| req | Active_ep_req |
| callback | Function to call on completion |
Return
- ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error
20.2.2. ZbZdoBcnSurveyReq
enum ZbStatusCodeT ZbZdoBcnSurveyReq(struct ZigBeeT *zb, struct ZbZdoBcnSurveyReqT *req, void (*callback) (struct ZbZdoBcnSurveyRspT *rsp, void *cb_arg), void *arg); Sends ZDO Mgmt_Beacon_Survey_req command.
Parameters
| req | Beacon survey req struct. |
| callback | callback function pointer. |
| arg | argument to response handler function. |
Return
- enum ZbStatusCodeT
20.2.3. ZbZdoBindReq
enum ZbStatusCodeT ZbZdoBindReq(struct ZigBeeT *zb, struct ZbZdoBindReqT *req, void (*callback)(struct ZbZdoBindRspT *rsp, void *cb_arg), void *arg);
Perform a ZDO Bind operation.
Parameters
| req | Bind_req |
Return
20.2.4. ZbZdoClearAllBindingsReq
enum ZbStatusCodeT ZbZdoClearAllBindingsReq(struct ZigBeeT *zb, struct ZbZdoClearAllBindingsReqT *req, void (*callback)(struct ZbZdoClearAllBindingsRspT *rsp, void *cb_arg), void *arg);
Send a ZDO Security Clear all bindings request command.
Parameters
| req | clear all bindings req struct |
| callback | callback function pointer |
| arg | argument to response handler function |
Return
20.2.5. ZbZdoDeviceAnnce
void ZbZdoDeviceAnnce(struct ZigBeeT *zb, struct ZbZdoDeviceAnnceT *deviceAnncePtr);
Send a Device_annce message to the network. Automatically called by the stack after joining.
Parameters
| deviceAnncePtr | Pointer to Device_annce structure |
Return
- Returns void
20.2.6. ZbZdoDeviceAnnceAlias
void ZbZdoDeviceAnnceAlias(struct ZigBeeT *zb, struct ZbZdoDeviceAnnceT *deviceAnncePtr);
Send a Device_annce message to the network using aliasing.
Parameters
Return
- Returns void
20.2.7. ZbZdoDeviceAnnceFilterRegister
struct ZbZdoFilterT * ZbZdoDeviceAnnceFilterRegister(struct ZigBeeT *zb, struct ZbZdoFilterT *filter, enum zb_msg_filter_rc (*callback)(struct ZigBeeT *zb, struct ZbZdoDeviceAnnceT *annce, uint8_t seqno, void *arg), void *arg);
Register a filter in the ZDO for the application to receive Device_Annce messages.
Parameters
| filter | Optional pointer to a pre-allocated ZbZdoFilterT structure. If NULL, the struct will be allocated via ZbHeapAlloc(). |
| callback | Function to call upon reception of a valid ZDO Device-Annce message. Callback can return ZB_MSG_CONTINUE to process other filters, or ZB_MSG_DISCARD if all processing of this message should stop. |
Return
- Pointer to filter structure
20.2.8. ZbZdoGetNextSeqNum
uint8_t ZbZdoGetNextSeqNum(struct ZigBeeT *zb);
Return and increment the next ZDO sequence number.
Parameters
Return
- Returns ZDO sequence number.
20.2.9. ZbZdoIeeeAddrReq
enum ZbStatusCodeT ZbZdoIeeeAddrReq(struct ZigBeeT *zb, struct ZbZdoIeeeAddrReqT *req, void (*callback) (struct ZbZdoIeeeAddrRspT *rsp, void *cb_arg), void *arg);
Retrive the 64-bit extended address for a device if given a short network address.
Parameters
| req | IEEE_Addr_req |
Return
20.2.10. ZbZdoLeaveReq
enum ZbStatusCodeT ZbZdoLeaveReq(struct ZigBeeT *zb, struct ZbZdoLeaveReqT *req, void (*callback)(struct ZbZdoLeaveRspT *rsp, void *cb_arg), void *arg);
Perform a Mgmt_leave_req command.
Parameters
| req | Mgmt_Leave_req |
Return
20.2.11. . ZbZdoLqiReq
Perform a Mgmt_Lqi_req command.
enum ZbStatusCodeT ZbZdoLqiReq(struct ZigBeeT *zb, struct ZbZdoLqiReqT *req, void (*callback)(struct ZbZdoLqiRspT *rsp, void *cb_arg), void *arg);
Parameters
| req | Mgmt_Lqi_req |
Return
20.2.12. ZbZdoMatchDescMulti
enum ZbStatusCodeT ZbZdoMatchDescMulti(struct ZigBeeT *zb, struct ZbZdoMatchDescReqT *req, void (*callback)(struct ZbZdoMatchDescRspT *rsp, void *cb_arg), void *arg);
Send a ZDO Match-Desc request and receive multiple responses. The responses, if any, are received by the callback. Each callback contains the result of a callback from a single device. The callback will be called each time a response is received. After a timeout period, the callback is called with a status of ZB_ZDP_STATUS_TIMEOUT to indicate the internal response filter is removed and any additional responses for this request are not processed.
Parameters
| req | Match_desc_req |
| arg | Callback argument |
Return
- ZB_ZDP_STATUS_SUCCESS for received responses, ZB_ZDP_STATUS_TABLE_FULL if there’s a problem starting the request, ZB_ZDP_STATUS_TIMEOUT when the stack decides to stop receiving responses, or other ZclStatusCodeT value on error
20.2.13. ZbZdoMatchDescReq
enum ZbStatusCodeT ZbZdoMatchDescReq(struct ZigBeeT *zb, struct ZbZdoMatchDescReqT *req, void (*callback) (struct ZbZdoMatchDescRspT *rsp, void *cb_arg), void *arg);
Retrieve the mach descriptor for a device.
Parameters
Return
20.2.14. ZbZdoMgmtBindReq
enum ZbStatusCodeT ZbZdoMgmtBindReq(struct ZigBeeT *zb, struct ZbZdoMgmtBindReqT *req, void (*callback) (struct ZbZdoMgmtBindRspT *rsp, void *cb_arg), void *arg); Perform a Mgmt_Bind_req command.
Parameters
| req | Mgmt_bind_req |
Return
20.2.15. ZbZdoNodeDescReq
enum ZbStatusCodeT ZbZdoNodeDescReq(struct ZigBeeT *zb, struct ZbZdoNodeDescReqT *req, void (*callback) (struct ZbZdoNodeDescRspT *rsp, void *cb_arg), void *arg);
Retrieve the node descriptor for a device.
Parameters
| req | Node_desc_req |
Return
20.2.16. ZbZdoNwkAddrReq
enum ZbStatusCodeT ZbZdoNwkAddrReq(struct ZigBeeT *zb, struct ZbZdoNwkAddrReqT *req, void (*callback) (struct ZbZdoNwkAddrRspT *rsp, void *cb_arg), void *arg);
Retrieve the 16-bit short address for a device if given an extended address.
Parameters
| req | NWK_Addr_req |
Return
20.2.17. ZbZdoNwkEnhUpdateNotifyFilterRegister
struct ZbZdoFilterT * ZbZdoNwkEnhUpdateNotifyFilterRegister(struct ZigBeeT *zb, struct ZbZdoFilterT *filter, enum zb_msg_filter_rc (*callback)(struct ZigBeeT *zb, struct ZbZdoNwkUpdateNotifyT *msg, uint8_t seqno, void *arg), void *arg);
Register a filter in the ZDO for the application to receive Mgmt_Nwk_Enhanced_Update_notify messages.
Parameters
| callback | Function to call upon reception of a valid ZDO NWK-Update-Notify message. Callback can return ZB_MSG_CONTINUE to process other filters, or ZB_MSG_DISCARD if all processing of this message should stop. |
Return
20.2.18. ZbZdoNwkEnhUpdateReq
enum ZbStatusCodeT ZbZdoNwkEnhUpdateReq(struct ZigBeeT *zb, struct ZbZdoNwkEnhUpdateReqT *req, void (*callback)
(struct ZbZdoNwkUpdateNotifyT *reqPtr, void *cb_arg), void *arg); Perform a Mgmt_Nwk_Enhanced_Update_req command.
Parameters
| req | Mgmt_Nwk_Enhanced_Update_req |
Return
20.2.19. ZbZdoNwkIeeeJoinListBcastAll
unsigned int ZbZdoNwkIeeeJoinListBcastAll(struct ZigBeeT *zb);
Send an IEEE-Joining-List.response broadcast message for all entries in the IEEE Join List. Used primarily by GB868 applications.
Parameters
Return
- Returns number of entries sent
20.2.20. ZbZdoNwkIeeeJoinListReq
enum ZbStatusCodeT ZbZdoNwkIeeeJoinListReq(struct ZigBeeT *zb, struct ZbZdoNwkIeeeJoinListReqT *req, void (*callback)(struct ZbZdoNwkIeeeJoinListRspT *rsp, void *cb_arg), void *arg);
Send an IEEE-Joining-List request.
Parameters
| IEEE-Joining-List.request | Structure |
Return
20.2.21. ZbZdoNwkIeeeJoinListRsp
unsigned int ZbZdoNwkIeeeJoinListRsp(struct ZigBeeT *zb, uint16_t dstNwkAddr, uint8_t startIndex, uint8_t seqnum, bool fromRequest);
Send an IEEE-Joining-List.response. Used primarily by GB868 applications.
Parameters
| dstNwkAddr | Destination network address |
| startIndex | Start index |
| seqnum | Sequence number |
| fromRequest | Use start index from request |
Return
- Number of entries sent in response
20.2.22. ZbZdoNwkUpdateNotify
enum ZbStatusCodeT ZbZdoNwkUpdateNotify(struct ZigBeeT *zb, struct ZbZdoNwkUpdateNotifyT *reqPtr);
Send an unsolicited Mgmt_Nwk_Update_notify command to the network manager. Does not wait for any response.
Parameters
| reqPtr | Mgmt_Nwk_Update_notify |
Return
20.2.23. ZbZdoNwkUpdateNotifyFilterRegister
struct ZbZdoFilterT * ZbZdoNwkUpdateNotifyFilterRegister(struct ZigBeeT *zb, struct ZbZdoFilterT *filter, enum zb_msg_filter_rc (*callback)(struct ZigBeeT *zb, struct ZbZdoNwkUpdateNotifyT *msg, uint8_t seqno, void *arg), void *arg);
Register a filter in the ZDO for the application to receive Mgmt_Nwk_Update_notify messages.
Parameters
Return
20.2.24. ZbZdoNwkUpdateReq
enum ZbStatusCodeT ZbZdoNwkUpdateReq(struct ZigBeeT *zb, struct ZbZdoNwkUpdateReqT *req, void (*callback)(struct ZbZdoNwkUpdateNotifyT *reqPtr, void *cb_arg), void *arg);
Perform a Mgmt_Nwk_update_req command.
Parameters
| req | Mgmt_Nwk_update_req |
Return
20.2.25. ZbZdoPermitJoinReq
enum ZbStatusCodeT ZbZdoPermitJoinReq(struct ZigBeeT *zb, struct ZbZdoPermitJoinReqT *req, void (*callback)(struct ZbZdoPermitJoinRspT *rsp, void *cb_arg), void *arg);
Sends a ZDO Mgmt_permit_join_req command.
With R23 and above, there are new fields added to the ZDO Mgmt_permit_join_req command e.g, 'Frame Control' & 'Global Beacon Appendix'
In case of centralized security networks only TC can send this command with TLV_UPDATE bit set to 1 in frame control field. And if a non-TC device invokes this API with TLV_UPDATE bit set, it will be treated as an invalid request.
Parameters
| req | Mgmt_permit_joining_req |
Return
20.2.26. ZbZdoPowerDescReq
enum ZbStatusCodeT ZbZdoPowerDescReq(struct ZigBeeT *zb, struct ZbZdoPowerDescReqT *req, void (*callback) (struct ZbZdoPowerDescRspT *rsp, void *cb_arg), void *arg);
Retrieve the power descriptor for a device.
Parameters
| req | Power_desc_req |
Return
20.2.27. ZbZdoRtgReq
enum ZbStatusCodeT ZbZdoRtgReq(struct ZigBeeT *zb, struct ZbZdoRtgReqT *req, void (*callback)(struct ZbZdoRtgRspT *rsp, void *cb_arg), void *arg);
Perform a Mgmt_Rtg_req command.
Parameters
| req | Mgmt_Rtg_req |
Return
20.2.28. ZbZdoSecChallengeReq
enum ZbStatusCodeT ZbZdoSecChallengeReq(struct ZigBeeT *zb, struct ZbZdoSecChallengeReqT *req, void (*callback)(struct ZbZdoSecChallengeRspT *rsp, void *cb_arg), void *arg);
Sends ZDO Security_Challenge_req command.
Parameters
| req | challenge req struct. |
Return
20.2.29. ZbZdoSecDecommissionReq
enum ZbStatusCodeT ZbZdoSecDecommissionReq(struct ZigBeeT *zb, struct ZbZdoSecDecommissionReqT *req, void (*callback) (struct ZbZdoSecDecommissionRspT *rsp, void *cb_arg), void *arg);
Sends ZDO Security_Decommission_req command.
Parameters
| req | decommission req struct. |
Return
20.2.30. ZbZdoSecGetAuthLevelReq
enum ZbStatusCodeT ZbZdoSecGetAuthLevelReq(struct ZigBeeT *zb, struct ZbZdoSecGetAuthLevelReqT *req, void (*callback)(struct ZbZdoSecGetAuthLevelRspT *rsp, void *cb_arg), void *arg);
Send a ZDO Security get authentication level request command.
Parameters
| req | get authentication level req struct |
Return
20.2.31. ZbZdoSecGetConfigReq
enum ZbStatusCodeT ZbZdoSecGetConfigReq(struct ZigBeeT *zb, struct ZbZdoSecGetConfigReqT *req, void (*callback)(struct ZbZdoSecGetConfigRspT *rsp, void *cb_arg), void *arg);
Sends ZDO Security get configuration request command.
Parameters
| req | get configuration req struct. |
Return
20.2.32. ZbZdoSecKeyUpdateReq
enum ZbStatusCodeT ZbZdoSecKeyUpdateReq(struct ZigBeeT *zb, struct ZbZdoSecKeyUpdateReqT *req, void (*callback)(struct ZbZdoSecKeyUpdateRspT *rsp, void *cb_arg), void *arg);
Send a ZDO Security Key Update Request.
Parameters
| req | security key update req struct |
Return
20.2.33. ZbZdoSecSetConfigReq
enum ZbStatusCodeT ZbZdoSecSetConfigReq(struct ZigBeeT *zb, struct ZbZdoSecSetConfigReqT *req, void (*callback)(struct ZbZdoSecSetConfigRspT *rsp, void *cb_arg), void *arg);
Send a ZDO Security set configuration request command.
Parameters
| req | set configuration req struct. |
Return
20.2.34. ZbZdoSimpleDescReq
enum ZbStatusCodeT ZbZdoSimpleDescReq(struct ZigBeeT *zb, struct ZbZdoSimpleDescReqT *req, void (*callback) (struct ZbZdoSimpleDescRspT *rsp, void *cb_arg), void *arg);
Retrieve the simple descriptor for a device.
Parameters
| req | Simple_desc_req |
Return
20.2.35. ZbZdoUnbindReq
enum ZbStatusCodeT ZbZdoUnbindReq(struct ZigBeeT *zb, struct ZbZdoBindReqT *req, void (*callback)(struct ZbZdoBindRspT *rsp, void *cb_arg), void *arg);
Perform a ZDP Unbind Bind operation.
| req | Unbind_req |
| Function | to call on completion |
Return
20.3. Enumerations
20.3.1. ZbZdoAddrReqTypeT
NWK_addr_req / IEEE_addr_req definitions
| ZB_ZDO_ADDR_REQ_TYPE_SINGLE | Single address request - Returns the information requested only |
| ZB_ZDO_ADDR_REQ_TYPE_EXTENDED | Extended address request - Returns the information requested and appends the devices in its network table |
20.4. Structures
20.4.1. ZbNodeDescriptorT
ZigBee Node Descriptor
Parameters
| uint8_t logicalType | Logical type |
| uint8_t fragSupported | Fragmentation Supported |
| uint8_t apsFlags | APS flags |
| uint8_t freqBands | Frequency band |
| uint8_t macCapability | MAC capability flags |
| uint16_t mfrCode | Manufacturer code |
| uint8_t maxBuffer | Maximum buffer size |
| uint16_t maxIncomingTransfer | Maximum incoming transfer size |
| uint16_t serverMask | Server mask |
| uint16_t maxOutgoingTransfer | Maximum outgoing transfer size |
| uint8_t descCapability | Descriptor capability field |
20.4.2. ZbPowerDescriptorT
ZigBee power descriptor
Parameters
| uint8_t currentMode | Current power mode |
| uint8_t availableSources | Available power sources |
| uint8_t currentSource | Current power source |
| uint8_t currentLevel | Current power source level |
20.4.3. ZbSimpleDescriptorT
ZigBee simple (application) descriptor.
Parameters
| uint8_t endpoint | Endpoint |
| uint16_t profileId | Application profile identifier |
| uint16_t deviceId | Application device identifier |
| uint8_t version | Application device version |
| uint8_t inputClusterCount | Application input cluster count |
| uint16_t inputClusterList | Application input cluster list |
| uint8_t outputClusterCount | Application output cluster count |
| uint16_t outputClusterList | Application output cluster list |
20.4.4. ZbZdoActiveEpReqT
Active_EP_req
| uint16_t dstNwkAddr | Destination network address |
| uint16_t nwkAddrOfInterest | NWKAddrOfInterest |
| struct ZbApsRelayInfoT relayInfo | Contains information required to relay the APS packet. (R23+) |
20.4.5. ZbZdoActiveEpRspT
Active_EP_rsp
Parameters
| enum ZbStatusCodeT status | Status |
| uint16_t nwkAddr | NWKAddrOfInterest |
| uint8_t activeEpCount | ActiveEPCount |
| uint8_t activeEpList | ActiveEPList |
20.4.6. ZbZdoBcnSurveyReqT
Mgmt_Beacon_Survey_Req.
Parameters
| uint16_t dest_addr | destination address. |
| struct ZbChannelListT scan_channels | ScanChannelListStructure. |
| uint8_t config_bitmask | bit 0: 0 Active Scan 1 Enhanced Active Scan. bit 1 - 7: reserved. |
20.4.7. ZbZdoBcnSurveyRspT
Mgmt_Beacon_Survey_Rsp.
Parameters
| enum ZbStatusCodeT status | Status. |
/*< Single potential parent entry. */ } *potential_parent_list |
20.4.8. ZbZdoBindReqT
Bind_req
Parameters
| uint16_t target | Destination for the ZDO Bind Request message |
| uint64_t srcExtAddr | SrcAddress |
| uint8_t srcEndpt | SrcEndp |
| uint16_t clusterId | ClusterID |
| struct ZbApsAddrT dst | DstAddrMode, DstAddress, DstEndp |
Contains information required to relay the APS packet. NOTE: Only required for Golden Unit behaviour and if stack was built with CONFIG_ZB_ENABLE_GU condition enabled, otherwise it’s ignored. (R23+) |
20.4.9. ZbZdoBindRspT
Bind_rsp
Parameters
20.4.10. ZbZdoBindingDescT
Binding descriptor
| uint64_t srcAddr | SrcAddr |
| uint8_t srcEndpt | SrcEndpoint |
| uint16_t clusterId | ClusterId |
| struct ZbApsAddrT dst | DstAddr |
20.4.11. ZbZdoClearAllBindingsReqT
Parameters
| uint16_t destAddr | destination address. |
| uint8_t eui64_count | EUI64count |
| uint64_t eui64_array | EUI64_array. |
20.4.12. ZbZdoDeviceAnnceT
Device_annce (ZB_ZDO_DEVICE_ANNCE)
Parameters
| uint16_t nwkAddr | NWKAddr |
| uint64_t extAddr | IEEEAddr |
| uint8_t capability | Capability |
20.4.13. ZbZdoIeeeAddrReqT
IEEE_addr_req
Parameters
| enum ZbZdoAddrReqTypeT reqType | RequestType |
| uint8_t startIndex | StartIndex |
20.4.14. ZbZdoLeaveReqT
Mgmt_Nwk_Leave_req
Parameters
| uint16_t destAddr | Destination address |
| uint64_t deviceAddr | Device address |
| uint8_t flags | Remove Children, Rejoin |
20.4.15. ZbZdoLeaveRspT
Mgmt_Nwk_Leave_rsp
Parameters
20.4.16. ZbZdoLqiReqT
Mgmt_Lqi_req
Parameters
20.4.17. ZbZdoLqiRspT
Mgmt_Lqi_rsp
Parameters
| uint16_t respAddr | Response address |
| uint8_t neighborTblSz | NeighborTableEntries |
| uint8_t neighborListSz | NeighborTableListCount |
| struct ZbZdoNeighborDescT neighborList | NeighborTableList |
20.4.18. ZbZdoMatchDescReqT
Match_Desc_req
Parameters
| uint16_t profileId | ProfileID |
| uint8_t numInClusters | NumInClusters |
| uint16_t inClusterList | InClusterList |
| uint8_t numOutClusters | NumOutClusters |
| uint16_t outClusterList | OutClusterList |
20.4.19. ZbZdoMatchDescRspT
Match_Desc_rsp
Parameters
| uint8_t matchLength | MatchLength |
| uint8_t matchList | MatchList |
20.4.20. ZbZdoMgmtBindReqT
Mgmt_Bind_req
Parameters
20.4.21. ZbZdoMgmtBindRspT
Mgmt_Bind_rsp
Parameters
| uint8_t bindTblSz | BindingTableEntries |
| uint8_t bindListSz | BindingTableListCount |
| struct ZbZdoBindingDescT bindList | BindingTableList |
20.4.22. ZbZdoNeighborDescT
Neighbor Descriptor
Parameters
| uint64_t epid | Extended PAN ID |
| uint64_t extAddr | Extended address |
| uint16_t nwkAddr | Network address |
| uint8_t deviceType | Device type |
| uint8_t rxOnWhenIdle | RxOnWhenIdle |
| uint8_t relationship | Relationship |
| uint8_t permitJoin | Permit joining |
| uint8_t depth | Depth |
| uint8_t lqi | LQI |
20.4.23. ZbZdoNetworkDescT
Network descriptor
Parameters
| uint64_t epid | ExtendedPANId |
| uint8_t logicalChannel | LogicalChannel |
| uint8_t version | ZigBeeVersion |
| uint8_t stackProfile | StackProfile |
| uint8_t superframeOrder | SuperframeOrder |
| uint8_t beaconOrder | BeaconOrder |
| uint8_t permitJoin | PermitJoining |
20.4.24. ZbZdoNodeDescReqT
Node_Desc_req
Parameters
| uint16_t dstNwkAddr | Destination network address. |
| uint16_t nwkAddrOfInterest | Network address on interest. |
| uint64_t joinerExtAddr | Extended address of joiner. (R23+) |
| uint8_t suppKeyNegoMethod | Supported key negotiation method. (R23+) |
| uint8_t suppPreSharedSecrets | Supported Pre-Shared secrets. (R23+) |
20.4.25. ZbZdoNodeDescRspT
Node_Desc_rsp
Parameters
| uint16_t nwkAddr | short address. |
| struct ZbNodeDescriptorT nodeDesc | Node descriptor structure. |
| enum ZbSelKeyNegoMethodT selKeyNegoMethod | Selected key negotiation method. (R23+) |
| enum ZbSelPreSharedSecretT selPreSharedSecret | Selected Pre-Shared secret. (R23+) |
20.4.26. ZbZdoNwkAddrReqT
NWK_addr_req
Parameters
| uint16_t dstNwkAddr | Destination network address, not in spec |
20.4.27. ZbZdoNwkAddrRspT
NWK_addr_rsp
Parameters
| uint64_t extAddr | IEEEAddrRemoteDev |
| uint16_t nwkAddr | NWKAddrRemoteDev |
| uint8_t deviceCount | NumAssocDev |
| uint16_t deviceList | NWKAddrAssocDevList |
20.4.28. ZbZdoNwkEnhUpdateReqT
Parameters
| struct ZbChannelListT channelList | ScanChannelsListStructure |
| uint8_t scanDuration | ScanDuration |
| uint8_t scanCount | ScanCount |
| uint8_t updateId | nwkUpdateId |
| uint16_t managerAddr | nwkManagerAddr |
20.4.29. ZbZdoNwkIeeeJoinListReqT
Mgmt_Nwk_Ieee_Joining_List_req
Parameters
20.4.30. ZbZdoNwkIeeeJoinListRspT
Mgmt_Nwk_Ieee_Joining_List_rsp
Parameters
| uint8_t updateId | IeeeJoiningListUpdateID |
| enum WpanJoinPolicyT joiningPolicy | JoiningPolicy |
| uint8_t ieeeJoiningListTotal | IeeeJoiningListTotal |
| uint8_t ieeeJoiningListCount | IeeeJoiningCount |
| uint64_t ieeeJoiningList | IeeeJoiningList |
20.4.31. ZbZdoNwkUpdateNotifyT
Parameters
| uint32_t scannedChannels | ScannedChannels |
| uint16_t txTotal | TotalTransmissions |
| uint16_t txFails | TransmissionFailures |
| uint8_t channelListSz | ScannedChannelsListCount |
| uint8_t channelList | Channel energy list |
20.4.32. ZbZdoNwkUpdateReqT
Mgmt_Nwk_Update_req
Parameters
| uint32_t channelMask | ScanChannels |
20.4.33. ZbZdoPermitJoinReqT
ZDO Mgmt_Permit_Join_req
Parameters
| uint16_t destAddr | Short dst addr |
| uint8_t duration | Permit join duration |
| uint8_t tcSignificance | Boolean flag which if TRUE, indicates request to change TC policy. |
| uint8_t tlvData | Optional TLV data in case of R23 devices. In case of TC, it shall be beacon appendix encapsulation TLV. (R23+) |
| uint8_t tlvDataLen | Length of TLV data, if present. (R23+) |
20.4.34. ZbZdoPermitJoinRspT
ZDO Mgmt_Permit_Join_rsp
Parameters
20.4.35. ZbZdoPowerDescReqT
Power_Desc_req
Parameters
20.4.36. ZbZdoPowerDescRspT
Power_Desc_rsp
Parameters
| struct ZbPowerDescriptorT powerDesc | PowerDescriptor |
20.4.37. ZbZdoRoutingDescT
Routing descriptor
Parameters
| uint8_t status | Status |
| uint8_t constrained | Memory Constrained |
| uint8_t manyToOne | Many-to-one |
| uint8_t recordRequired | Route record required |
| uint16_t nextHopAddr | Next-hop address |
20.4.38. ZbZdoRtgReqT
Mgmt_Rtg_req
Parameters
20.4.39. ZbZdoRtgRspT
Mgmt_Rtg_rsp
Parameters
| uint8_t routeTblSz | RoutingTableEntries |
| uint8_t routeListSz | RoutingTableListCount |
| struct ZbZdoRoutingDescT routeList | RoutingTableList |
20.4.40. ZbZdoSecGetConfigReqT
Security_Get_Configuration_Req.
Parameters
| uint8_t tlvCount | Number of TLV ID’s present in the TLV list. |
| uint8_t tlvIdList | Variable length TLV ID list. |
20.4.41. ZbZdoSecGetConfigRspT
Security_Get_Configuration_Rsp.
Parameters
| uint8_t tlvList | Variable length TLV list. |
| uint8_t tlvListSize | Size of TLV list. |
20.4.42. ZbZdoSecKeyUpdateReqT
Security_Key_Update_Req.
Parameters
| uint16_t dstNwkAddr | Destination short address. |
| enum ZbSelKeyNegoMethodT selKeyNegoMethod | Selected key negotiation method. |
| enum ZbSelPreSharedSecretT selPreSharedSecret | Selected Pre-Shared secret. |
| uint16_t nodeId | Node of the device that the subsequent fragmentation parameters apply to. |
| uint16_t maxInputBufferSize | Maximum Reassembled Input Buffer Size. |
| struct ZbApsRelayInfoT relayInfo | Contains information required to relay the APS packet. |
20.4.43. ZbZdoSimpleDescReqT
Simple_Desc_req
Parameters
| uint8_t endpt | Endpoint |
20.4.44. ZbZdoSimpleDescRspT
Simple_Desc_rsp
Parameters
| struct ZbSimpleDescriptorT simpleDesc | SimpleDescriptor |
21. Zigbee ZCL Core
#include "zcl/zcl.h"
21.1. Functions
21.1.1. ZbZclAppendHeader
int ZbZclAppendHeader(struct ZbZclHeaderT *zclHdrPtr, uint8_t *data, unsigned int max_len);
Builds and appends a ZCL Header to the end of a buffer. Returns length of data written, or negative value (-1) on error.
Parameters
None Return
- Undocumented
21.1.2. ZbZclAttrEuiRead
uint64_t ZbZclAttrEuiRead(struct ZbZclClusterT *cluster, uint16_t attributeId, enum ZclStatusCodeT *statusPtr);
Helper to ZbZclAttrRead to read an EUI-64 attribute value.
Parameters
| cluster | Cluster instance |
| attributeId | The attribute Id |
| statusPtr | ZCL Status Code that can be returned to caller if pointer provided. |
Return
- The EUI-64 value
21.1.3. ZbZclAttrEuiWrite
enum ZclStatusCodeT ZbZclAttrEuiWrite(struct ZbZclClusterT *cluster, uint16_t attributeId, uint64_t eui);
Helper to ZbZclAttrWrite to write an EUI-64 attribute value.
Parameters
| eui | The EUI-64 value to write to the attribute. |
Return
- ZCL Status Code
21.1.4. ZbZclAttrIntegerIncrement
enum ZclStatusCodeT ZbZclAttrIntegerIncrement(struct ZbZclClusterT *cluster, uint16_t attributeId, long long value);
Helper to ZbZclAttrWrite to read, increment and write an integer attribute value.
Parameters
| value | The value to increment the attribute by. |
Return
- ZCL status code
21.1.5. ZbZclAttrIntegerRead
long long ZbZclAttrIntegerRead(struct ZbZclClusterT *cluster, uint16_t attributeId, enum ZclDataTypeT *typePtr, enum ZclStatusCodeT *statusPtr);
Helper to ZbZclAttrRead to read an integer attribute value.
Parameters
| typePtr | If pointer provided, returns the attribute type. |
Return
- Value of attribute
21.1.6. ZbZclAttrIntegerWrite
enum ZclStatusCodeT ZbZclAttrIntegerWrite(struct ZbZclClusterT *cluster, uint16_t attributeId, long long value);
Helper to ZbZclAttrWrite to write an integer attribute value.
Parameters
| value | The value to write to the attribute. |
Return
- ZCL status code
21.1.7. ZbZclAttrRead
enum ZclStatusCodeT ZbZclAttrRead(struct ZbZclClusterT *cluster, uint16_t attrId, enum ZclDataTypeT *attrType, void *outputBuf, unsigned int max_len, bool isReporting);
Reads a local cluster attribute value. Returns the attribute type if provided as a pointer through 'attrType'.
Parameters
| attrId | Attribute Id of the attribute to read |
| attrType |
Pointer to the attribute type. If not NULL and this function returns ZCL_STATUS_SUCCESS, the type value of the attribute is returned in this parameter. |
| outputBuf | Buffer to write attribute value data to. |
| max_len | Maximum length of 'outputBuf'. |
| isReporting | If true and this attribute is being read for generating a report, the attribute’s flag is checked for ZCL_ATTR_FLAG_REPORTABLE and if not set, a status of ZCL_STATUS_UNREPORTABLE_ATTRIBUTE is returned. |
Return
- ZCL status code
21.1.8. ZbZclAttrReportConfigDefault
enum ZclStatusCodeT ZbZclAttrReportConfigDefault(struct ZbZclClusterT *clusterPtr, uint16_t attrId, uint16_t default_min, uint16_t default_max, double *default_change);
Configure an attribute’s default reporting intervals. It will also set the active reporting intervals to these values and reset the reporting timer. The Reportable Change value will also be reset back to defaults (value = 1).
Parameters
| clusterPtr | Cluster instance |
| attrId | Attribute Id of the attribute to modify |
| default_min | New default minimum reporting interval in seconds. |
| default_max | New default maximum reporting interval in seconds. |
| default_change | (Optional) New default reportable change value. |
Return
- ZCL status code
21.1.9. ZbZclAttrReportConfigReq
enum ZclStatusCodeT ZbZclAttrReportConfigReq(struct ZbZclClusterT *cluster, struct ZbZclAttrReportConfigT *config, void (*callback)(struct ZbZclCommandRspT *cmd_rsp, void *arg), void *arg);
Send a Configure Reporting Command. Response is returned in the 'callback' if provided by application.
Parameters
| config | Attribute reporting configuration destination and records |
| callback | Callback function to receive Configure Reporting Response Command |
Return
- ZCL status code
21.1.10. ZbZclAttrReportReadReq
enum ZclStatusCodeT ZbZclAttrReportReadReq(struct ZbZclClusterT *cluster, struct ZbZclAttrReportReadT *report, void (*callback)(struct ZbZclCommandRspT *cmd_rsp, void *arg), void *arg);
Send a Read Reporting Configuration Command. Response is returned in the 'callback' if provided by application.
Parameters
| report | Attribute reporting configuration destination and records to read |
| callback | Callback function to receive Read Reporting Configuration Response Command |
Return
- ZCL status code
21.1.11. ZbZclAttrStringWriteLong
enum ZclStatusCodeT ZbZclAttrStringWriteLong(struct ZbZclClusterT *cluster, uint16_t attributeId, const uint8_t *zcl_str);
Helper to ZbZclAttrWrite to write a string attribute value of type ZCL_DATATYPE_STRING_LONG_OCTET or ZCL_DATATYPE_STRING_LONG_CHARACTER.
Parameters
| zcl_str | ZCL String. First two bytes is the string length. |
Return
- ZCL status code
21.1.12. ZbZclAttrStringWriteShort
enum ZclStatusCodeT ZbZclAttrStringWriteShort(struct ZbZclClusterT *cluster, uint16_t attributeId, const uint8_t *zcl_str);
Helper to ZbZclAttrWrite to write a string attribute value of type ZCL_DATATYPE_STRING_OCTET or ZCL_DATATYPE_STRING_CHARACTER.
Parameters
| zcl_str | ZCL String. First byte is the string length. |
Return
- ZCL status code
21.1.13. ZbZclAttrWrite
enum ZclStatusCodeT ZbZclAttrWrite(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *src, uint16_t attr_id, const uint8_t *attr_data, unsigned int max_len, ZclWriteModeT mode);
Writes a local cluster’s attribute value.
Parameters
| src | Source address of this command. May be NULL if generated locally. |
| attr_id | Attribute Id of the attribute to write |
| attr_data | Attribute data in ZCL format (i.e. same as what is sent over-the-air) |
| max_len | Maximum length of attribute data (attr_data) buffer. |
| mode | Write mode |
Return
- ZCL status code
21.1.14. ZbZclClusterCommandReqWithRspFilter
enum ZclStatusCodeT ZbZclClusterCommandReqWithRspFilter(struct ZbZclClusterT *cluster, struct ZbZclClusterCommandReqT *req, uint8_t rspCmd, unsigned int delay, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
ZbZclClusterCommandReq is a helper wrapper to ZbZclCommandReq. Information from the cluster is used when sending the command (source addressing, APS TX Options).
Parameters
| req | Request struct pointer |
| rspCmd | The Command Id of the response to wait for, which is added to the APS filter. This may be set to ZCL_REQ_CMD_RSP_ID_IGNORE, in which case only the matching ZCL sequence number, direction bit, etc, are used. The ZCL Default Response is always added to the APS filter. |
| delay | Delay in milliseconds. If non-zero, then a copy of the ASDU must be made, and the message is sent later, after the delay time expires. |
| callback | Callback function. This may be set to NULL. |
| arg | Callback argument. Provided to the callback function and used by the application. |
Return
- ZCL Status Code. If ZCL_STATUS_SUCCESS, the caller can expect the callback once the command is complete. If something other than ZCL_STATUS_SUCCESS, that indicates an error and the callback is never called in that case.
21.1.15. ZbZclClusterRegisterAlarmResetHandler
enum ZclStatusCodeT ZbZclClusterRegisterAlarmResetHandler(struct ZbZclClusterT *cluster, enum ZclStatusCodeT (*callback) (struct ZbZclClusterT *cluster, uint8_t alarm_code, uint16_t cluster_id, struct ZbApsdeDataIndT *data_ind, struct ZbZclHeaderT *hdr));
Register a callback handler for the given cluster to receive Alarm "Reset Alarm" and "Reset all alarms" commands.
Parameters
| callback | Application callback to handle reset alarm(s) commands. |
Return
- ZCL status code
21.1.16. ZbZclClusterReportConfirmCallbackAttach
void ZbZclClusterReportConfirmCallbackAttach(struct ZbZclClusterT *cluster, void (*callback)(struct ZbZclClusterT *cluster));
Attach a confirm callback function to be called on sending ZCL Attribute Report Commands.
Parameters
| callback | Application callback to handle Report commands. |
Return
- None
21.1.17. ZbZclClusterReportsSend
enum ZclStatusCodeT ZbZclClusterReportsSend(struct ZbZclClusterT *cluster, bool send_all, void (*callback) (struct ZbZclClusterT *cluster, unsigned int next_timeout, void *arg), void *arg);
If the application disables the automatic attribute reporting mechanism in the stack by setting the NIB 'ZB_NWK_NIB_ID_DisablePeriodicTimers' to 1, then the application will need to manually and periodically send reports by calling this function.
Parameters
| send_all | If true, send all reportable attributes no matter if they have changed or reporting interval has timed-out. Normally, when used by a sleepy device application to manually drive reporting, this parameter should be set to false. |
| callback | Callback that is called once all reports have been sent. The 'next_timeout' parameter is the time until the next scheduled report, in milliseconds. |
Return
- ZCL Status Code. If not ZCL_STATUS_SUCCESS, then callback will not be called.
21.1.18. ZbZclClusterReverseBind
struct ZbApsFilterT * ZbZclClusterReverseBind(struct ZbZclClusterT *cluster);
ZbZclClusterReverseBind is used by the Alarms Server so it can receive loopback messages sent in the direction of the client (i.e. reverse).
Parameters
Return
- Filter pointer (handle)
21.1.19. ZbZclClusterReverseUnbind
void ZbZclClusterReverseUnbind(struct ZbZclClusterT *cluster, struct ZbApsFilterT *filter);
Remove the reverse (loopback) filter and free it.
Parameters
| filter | Filter to remove and free |
Return
- None
21.1.20. ZbZclClusterSendAlarm
void ZbZclClusterSendAlarm(struct ZbZclClusterT *cluster, uint8_t src_endpoint, uint8_t alarm_code);
Send an alarm from a cluster as if it originated from the alarms cluster on the same endpoint. Typically, src_endpoint = cluster¬endpoint. If the cluster appears on multiple endpoints (e.g. Basic Cluster), the src_endpoint is required to know which one to actually send the Alarm Command from. The alarm message is sent via APS binding(s).
Parameters
| src_endpoint | |
| alarm_code |
Return
- None
21.1.21. ZbZclCommandReqWithRspFilter
enum ZclStatusCodeT ZbZclCommandReqWithRspFilter(struct ZigBeeT *zb, struct ZbZclCommandReqT *zclReq, uint8_t rspCmd, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a ZCL command. The callback function is called when the associated ZCL response is received, or there’s an error.
Parameters
| zclreq | ZCL Command Request info |
| callback | Callback function to receive ZCL Response |
Return
- ZCL Status Code. ZCL_STATUS_SUCCESS if command was sent and caller can wait for the callback to be called. Otherwise, there was a problem sending the command and the callback is never called in this case.
21.1.22. ZbZclIsDefaultRsp
bool ZbZclIsDefaultRsp(struct ZbZclHeaderT *hdr);
This is a helper function that inspects a ZCL header struct and returns true if it’s for a ZCL Default Response command, or false otherwise.
Parameters
| hdr | ZCL Header struct |
Return
- True if ZCL header indicates it’s for a ZCL Default Response command, or false otherwise.
21.1.23. ZbZclParseHeader
int ZbZclParseHeader(struct ZbZclHeaderT *zclHdrPtr, const uint8_t *buf, unsigned int len);
Parses a ZCL Header from a received frame. Returns Length of the ZCL header, or negative value (-1) on error.
Parameters
None Return
- Undocumented
21.1.24. ZbZclParseInteger
long long ZbZclParseInteger(enum ZclDataTypeT dataType, const uint8_t *data, enum ZclStatusCodeT *statusPtr);
Parses a integer number from a buffer starting at the given pointer and returns it as a long long integer. Note that the length of the buffer isn’t checked. The caller is assumed to have sanity-checked the buffer length already by a call to ZbZclAttrParseLength or ZbZclAttrTypeLength
Parameters
| dataType | ZCL Attribute data type. |
| data | ZCL attribute data. |
| statusPtr | ZCL Status Code (OUT) |
Return
- The parsed value, if *statusPtr == SUCCESS
21.1.25. ZbZclPrependHeader
int ZbZclPrependHeader(struct ZbZclHeaderT *zclHdrPtr, uint8_t *data, unsigned int len);
Builds and appends a ZCL Header to the start of a buffer. Returns length of data written, or negative value (-1) on error.
Parameters
None Return
- Undocumented
21.1.26. zcl_get_bomd_req_queue_timeout_abs
ZbUptimeT zcl_get_bomd_req_queue_timeout_abs(struct ZigBeeT *zb);
Helper function to return the timeout value, based on the BDB parameter 'ZB_BDB_ZclBomdReqQueueTimeoutMs'
Parameters
Return
- ZbZclUptime() plus the ZB_BDB_ZclBomdReqQueueTimeoutMs value.
21.1.27. zcl_get_bomd_req_wait_timeout_ms
uint32_t zcl_get_bomd_req_wait_timeout_ms(struct ZigBeeT *zb);
Helper function to return value from BDB parameter 'ZB_BDB_ZclBomdReqWaitTimeoutMs'
Parameters
Return
- Timeout value in milliseconds
21.1.28. zcl_hexstr_to_bin
int zcl_hexstr_to_bin(const char *str, uint8_t *out, unsigned int maxlen);
This is a helper function to convert an ascii string of hexidecimal characters to an array of binary octets. The input string can have upper or lower case hex characters, and must not contain any delimiters. Since this is a helper function, it may change or be removed in the future.
Parameters
| str | Input ascii string to convert, null terminated. |
| out | Output buffer to write converted binary data to. |
| maxlen | Maximum length of output buffer. If output length would be longer than the maximum length, then -1 is returned. |
Return
- Number of bytes written to 'out' or -1 on error.
21.2. Enumerations
21.2.1. ZbZclAttrCbTypeT
Attribute Callback Types
| ZCL_ATTR_CB_TYPE_READ | Read attribute callback. Use to have the application handle the ZCL Read Requests, rather than the cluster. |
| ZCL_ATTR_CB_TYPE_WRITE | Write attribute callback. Used to have the application handle the ZCL Write Requests, rather than the cluster. If not used, the cluster will handle the incoming requests. |
21.3. Structures
21.3.1. ZbZclAttrCbInfoT
Attribute callback information
Parameters
| const struct ZbZclAttrT *info | Pointer to the original info struct used to create the attribute |
| enum ZbZclAttrCbTypeT type | Callback type (read, write, etc) |
| uint8_t *zcl_data | Incoming or outgoing ZCL attribute payload data.
If callback type is ZCL_ATTR_CB_TYPE_WRITE, this is the source of the new value, to be validated and written back to attr_data if applicable. If callback type is ZCL_ATTR_CB_TYPE_READ, this is the destination of the value to return in the ZCL Read Response. |
| unsigned int zcl_len | Maximum length of 'zcl_data' |
| ZclWriteModeT write_mode | Write mode (e.g. normal, test, force, persist). Only applicable if type == ZCL_ATTR_CB_TYPE_WRITE. |
| void *attr_data |
Pointer to local attribute storage. Only applicable if type == ZCL_ATTR_CB_TYPE_WRITE. If NULL, then application is maintaining attribute value (i.e. both ZCL_ATTR_FLAG_CB_READ and ZCL_ATTR_FLAG_CB_WRITE were set). If not NULL, current attribute value can be read from here, and updated value from WRITE command to be written here. |
| const struct ZbApsAddrT *src | Source of the command, if not locally generated. May be NULL. |
| enum ZbStatusCodeT security_status |
security_status - The security level used to decrypt the incoming frame. Only valid if 'src' address parameter is not NULL. If present, it will be one of: ZB_APS_STATUS_UNSECURED (no decryption necessary), ZB_APS_STATUS_SECURED_NWK_KEY (decrypted with the Network Key), ZB_APS_STATUS_SECURED_LINK_KEY, (decrypted with a Link Key) |
| void *app_cb_arg | Application’s defined callback argument |
21.3.2. ZbZclAttrT
The structure used to initialize a ZCL attribute when calling ZbZclAttrAppendList.
Parameters
| uint16_t attributeId | The attribute ID |
| enum ZclDataTypeT dataType | The attribute data type (ZCL_DATATYPE_UNKNOWN if last entry) |
| ZclAttrFlagT flags | Attribute flags (e.g. writeable, reportable, etc) |
| unsigned int customValSz |
A custom size is required if the data type is one of: ZCL_DATATYPE_STRING_OCTET, ZCL_DATATYPE_STRING_CHARACTER, ZCL_DATATYPE_STRING_LONG_OCTET, ZCL_DATATYPE_STRING_LONG_CHARACTER, ZCL_DATATYPE_ARRAY, ZCL_DATATYPE_STRUCT, ZCL_DATATYPE_SET, ZCL_DATATYPE_BAG A custom size is also required if both customRead and customWrite callbacks are provided and ZCL_ATTR_FLAG_PERSISTABLE is set. The maximum size should not exceed ZB_APS_CONST_MAX_FRAG_SIZE. |
callback (callback function pointer) |
enum ZclStatusCodeT (*callback)(struct ZbZclClusterT *cluster, struct ZbZclAttrCbInfoT *info) If flags ZCL_ATTR_FLAG_CB_READ or ZCL_ATTR_FLAG_CB_WRITE are set, then this callback is called for attribute read or write commands. |
| struct { double min | Optional integer attribute value range. If both are set to zero, range checking is disabled. |
| struct { uint16_t interval_min | Default minimum reporting interval in seconds. |
| uint16_t interval_max | Default maximum reporting interval in seconds. |
22. Touchlink
#include "zcl/zcl.touchlink.h"
22.1. Functions
22.1.1. ZbZclTouchlinkInitiatorGetEpListReq
enum ZclStatusCodeT ZbZclTouchlinkInitiatorGetEpListReq(struct ZigBeeT *zb, struct ZbTlGetEpListReqCmd *cmd, const struct ZbApsAddrT *dst, void (*callback)(struct ZbTlGetEpListRspCmd *rsp, void *arg), void *arg);
Sends a Touchlink Utility Get Endpoint List Request Command
Parameters
| zb | Zigbee stack instance |
| dst | Destination address |
| cmd | Get Endpoint List Request Command structure |
| callback | Callback function that will be invoked when the response is received. |
| arg | Pointer to application data that will included in the callback when invoked. |
Return
22.1.2. ZbZclTouchlinkInitiatorGetGrpIdReq
enum ZclStatusCodeT ZbZclTouchlinkInitiatorGetGrpIdReq(struct ZigBeeT *zb, struct ZbTlGetGroupIdsReqCmd *cmd, const struct ZbApsAddrT *dst, void (*callback)(struct ZbTlGetGroupIdsRspCmd *rsp, void *arg), void *arg);
Sends a Touchlink Utility Get Group Identifiers Request Command
Parameters
| cmd | Get Group Identifiers Request structure |
Return
22.1.3. ZbZclTouchlinkTargetSendEpInfoCmd
enum ZclStatusCodeT ZbZclTouchlinkTargetSendEpInfoCmd(struct ZigBeeT *zb, uint8_t endpoint, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Sends a Touchlink Utility Endpoint Information Command
Parameters
| endpoint | Endpoint identifier. Must match the endpoint already registered with Touchlink through the ZbStartup configuration, otherwise an error is returned. |
Return
22.2. Structures
22.2.1. ZbTlEndpointList
Endpoint Information Record entry
Parameters
| uint8_t endpoint | Endpoint identifier |
| uint16_t profileId | Profile identifier |
| uint16_t deviceId | Device identifier |
| uint8_t version | Version |
22.2.2. ZbTlEpInfoCmd
Endpoint Information command
Parameters
| uint64_t ieeeAddr | IEEE address |
22.2.3. ZbTlGetEpListReqCmd
Get Endpoint List Request command
Parameters
| uint8_t startIdx | Start Index |
22.2.4. ZbTlGetEpListRspCmd
Get Endpoint List Response command
Parameters
| enum ZclStatusCodeT status | ZCL Status code |
| uint8_t total | Total |
| uint8_t startIdx | Start index |
| uint8_t count | Count |
| struct ZbTlEndpointList endpoint_list | Endpoint Information Record Entry |
22.2.5. ZbTlGetGroupIdsReqCmd
Get Group Identifiers Request command
Parameters
22.2.6. ZbTlGetGroupIdsRspCmd
Get Group Identifiers Response command
Parameters
| enum ZclStatusCodeT status | ZCL status code |
| struct ZbTlGroupRecordList record_list | Group Information Record List |
22.2.7. ZbTlGroupRecordList
Group Information Record list
Parameters
| uint16_t groupId | Group list |
| uint8_t groupType | Group type - Must be 0 |
22.2.8. ZbTouchlinkCallbacks
Zigbee Touchlink callback functions for Touchlink Controller Device Utility commands. These are configured by "struct ZbStartupT" with ZbStartup().
Parameters
ep_info_cb (callback function pointer) |
enum ZclStatusCodeT (*ep_info_cb)(struct ZigBeeT *zb, struct ZbTlEpInfoCmd *cmd, struct ZbZclAddrInfoT *srcInfo, void *arg) Endpoint Info callback |
23. Key Exchange (CBKE)
#include "zcl/key/zcl.key.h"
23.1. Description
The Certificate-based Key Establishment (CBKE) cluster is handled internally by the stack. When CBKE is enabled, the stack creates an instance of the CBKE cluster. There is no exposed public API to the CBKE cluster itself. CBKE is configured in the security.cbke (struct ZbStartupCbkeT) section of the ZbStartupT startup config. The basic setup procedure is to enable the supported suites in suite_mask and load the corresponding suite configuration and certificates for the enabled suites into the startup config before starting the stack.
CBKE configuration struct for ZbStartup. This is only applicable if the 'suite_mask' is non-zero.
ZbStartupCbkeT
| uint8_t endpoint |
| uint16_t deviceId |
Device Id to assign to the endpoint created for the ZCL Key Exchange cluster. Default is ZCL_DEVICE_METER. |
The Key Exchange suite bitmask. E.g. ZCL_KEY_SUITE_CBKE2_ECMQV for CBKE version 2 (cbke_v2). If the suite_mask is empty (zero), then no Key Establishment or Keep Alive features are enabled. |
| bool tc_keepalive_server_enable | Determines whether to allocate the Keep Alive Server or Client cluster. |
| uint8_t tc_keepalive_jitter | Trust Center Keep Alive Server 'Jitter' attribute value in seconds. If zero, let the stack choose a default value. |
void (*tcso_callback)(enum ZbTcsoStatusT status, void *arg) |
Application callback which is called for any Trust Center Swap Out (TCSO) process initiated by the Keep Alive Client cluster. This includes when a TCSO has been started and the final outcome of a TCSO process. |
| void *tcso_arg | Application callback argument for tcso_callback. |
24. Appendix A: Zigbee status codes
24.1. NWK status codes
| Status Value | Status Code |
| 0x00 | ZB_NWK_STATUS_SUCCESS |
| 0xc1 | ZB_NWK_STATUS_INVALID_PARAMETER |
| 0xc2 | ZB_NWK_STATUS_INVALID_REQUEST |
| 0xc3 | ZB_NWK_STATUS_NOT_PERMITTED |
| 0xc4 | ZB_NWK_STATUS_STARTUP_FAILURE |
| 0xc5 | ZB_NWK_STATUS_ALREADY_PRESENT |
| 0xc6 | ZB_NWK_STATUS_SYNC_FAILURE |
| 0xc7 | ZB_NWK_STATUS_TABLE_FULL |
| 0xc8 | ZB_NWK_STATUS_UNKNOWN_DEVICE |
| 0xc9 | ZB_NWK_STATUS_UNSUPPORTED_ATTRIBUTE |
| 0xca | ZB_NWK_STATUS_NO_NETWORKS |
| 0xcb | ZB_NWK_STATUS_LEAVE_UNCONFIRMED |
| 0xcc | ZB_NWK_STATUS_MAX_FRM_CNTR |
| 0xcd | ZB_NWK_STATUS_NO_KEY |
| 0xce | ZB_NWK_STATUS_BAD_CCM_OUTPUT |
| 0xcf | ZB_NWK_STATUS_NO_ROUTING_CAPACITY |
| 0xd0 | ZB_NWK_STATUS_ROUTE_DISCOVERY_FAILED |
| 0xd1 | ZB_NWK_STATUS_ROUTE_ERROR |
| 0xd2 | ZB_NWK_STATUS_BT_TABLE_FULL |
| 0xd3 | ZB_NWK_STATUS_FRAME_NOT_BUFFERED |
| 0xd4 | ZB_NWK_STATUS_INVALID_INDEX |
| 0xd5 | ZB_NWK_STATUS_INTERNAL_ERR |
24.1.1. WPAN Status Codes
| 0x00 | ZB_WPAN_STATUS_SUCCESS |
| 0xdb | ZB_WPAN_STATUS_COUNTER_ERROR |
| 0xdc | ZB_WPAN_STATUS_IMPROPER_KEY_TYPE |
| 0xdd | ZB_WPAN_STATUS_IMPROPER_SECURITY_LEVEL |
| 0xde | ZB_WPAN_STATUS_UNSUPPORTED_LEGACY |
| 0xdf | ZB_WPAN_STATUS_UNSUPPORTED_SECURITY |
| 0xe0 | ZB_WPAN_STATUS_BEACON_LOSS |
| 0xe1 | ZB_WPAN_STATUS_CHANNEL_ACCESS_FAILURE |
| 0xe2 | ZB_WPAN_STATUS_DENIED |
| 0xe3 | ZB_WPAN_STATUS_DISABLE_TRX_FAILURE |
| 0xe4 | ZB_WPAN_STATUS_SECURITY_ERROR |
| 0xe5 | ZB_WPAN_STATUS_FRAME_TOO_LONG |
| 0xe6 | ZB_WPAN_STATUS_INVALID_GTS |
| 0xe7 | ZB_WPAN_STATUS_INVALID_HANDLE |
| 0xe8 | ZB_WPAN_STATUS_INVALID_PARAMETER |
| 0xe9 | ZB_WPAN_STATUS_NO_ACK |
| 0xea | ZB_WPAN_STATUS_NO_BEACON |
| 0xeb | ZB_WPAN_STATUS_NO_DATA |
| 0xec | ZB_WPAN_STATUS_NO_SHORT_ADDRESS |
| 0xed | ZB_WPAN_STATUS_OUT_OF_CAP |
| 0xee | ZB_WPAN_STATUS_PAN_ID_CONFLICT |
| 0xef | ZB_WPAN_STATUS_REALIGNMENT |
| 0xf0 | ZB_WPAN_STATUS_TRANSACTION_EXPIRED |
| 0xf1 | ZB_WPAN_STATUS_TRANSACTION_OVERFLOW |
| 0xf2 | ZB_WPAN_STATUS_TX_ACTIVE |
| 0xf3 | ZB_WPAN_STATUS_UNAVAILABLE_KEY |
| 0xf4 | ZB_WPAN_STATUS_UNSUPPORTED_ATTRIBUTE |
| 0xf5 | ZB_WPAN_STATUS_INVALID_ADDRESS |
| 0xf6 | ZB_WPAN_STATUS_ON_TIME_TOO_LONG |
| 0xf7 | ZB_WPAN_STATUS_PAST_TIME |
| 0xf8 | ZB_WPAN_STATUS_TRACKING_OFF |
| 0xf9 | ZB_WPAN_STATUS_INVALID_INDEX |
| 0xfa | ZB_WPAN_STATUS_LIMIT_REACHED |
| 0xfb | ZB_WPAN_STATUS_READ_ONLY |
| 0xfc | ZB_WPAN_STATUS_SCAN_IN_PROGRESS |
| 0xfd | ZB_WPAN_STATUS_SUPERFRAME_OVERLAP |
| 0xfe | ZB_WPAN_STATUS_DRIVER_ERROR |
| 0xff | ZB_WPAN_STATUS_DEVICE_ERROR |
24.1.2. ZCL status codes
| 0z00 | ZCL_STATUS_SUCCESS |
| 0x01 | ZCL_STATUS_FAILURE |
| 0x70 | ZCL_STATUS_ALLOC_FAIL |
| 0x7e | ZCL_STATUS_NOT_AUTHORIZED |
| 0x80 | ZCL_STATUS_MALFORMED_COMMAND |
| 0x81 | ZCL_STATUS_UNSUPP_CLUSTER_COMMAND |
| 0x82 | ZCL_STATUS_UNSUPP_GENERAL_COMMAND |
| 0x83 | ZCL_STATUS_UNSUPP_MFR_CLUSTER_COMMAND |
| 0x84 | ZCL_STATUS_UNSUPP_MFR_GENERAL_COMMAND |
| 0x85 | ZCL_STATUS_INVALID_FIELD |
| 0x86 | ZCL_STATUS_UNSUPP_ATTRIBUTE |
| 0x87 | ZCL_STATUS_INVALID_VALUE |
| 0x88 | ZCL_STATUS_READ_ONLY |
| 0x89 | ZCL_STATUS_INSUFFICIENT_SPACE |
| 0x8a | ZCL_STATUS_DUPLICATE_EXISTS |
| 0x8b | ZCL_STATUS_NOT_FOUND |
| 0x8c | ZCL_STATUS_UNREPORTABLE_ATTRIBUTE |
| 0x8d | ZCL_STATUS_INVALID_DATA_TYPE |
| 0x8e | ZCL_STATUS_INVALID_SELECTOR |
| 0x8f | ZCL_STATUS_WRITE_ONLY |
| 0x90 | ZCL_STATUS_INCONSISTENT_STARTUP_STATE |
| 0x91 | ZCL_STATUS_DEFINED_OUT_OF_BAND |
| 0x92 | ZCL_STATUS_INCONSISTENT |
| 0x93 | ZCL_STATUS_ACTION_DENIED |
| 0x94 | ZCL_STATUS_TIMEOUT |
| 0x95 | ZCL_STATUS_ABORT |
| 0x96 | ZCL_STATUS_INVALID_IMAGE |
| 0x97 | ZCL_STATUS_WAIT_FOR_DATA |
| 0x98 | ZCL_STATUS_NO_IMAGE_AVAILABLE |
| 0x99 | ZCL_STATUS_REQUIRE_MORE_IMAGE |
| 0x9A | ZCL_STATUS_NOTIFICATION_PENDING |
| 0xc0 | ZCL_STATUS_HARDWARE_FAILURE |
| 0xc1 | ZCL_STATUS_SOFTWARE_FAILURE |
| 0xc2 | ZCL_STATUS_CALIBRATION_ERROR |
| 0xc3 | ZCL_STATUS_UNSUPP_CLUSTER |
| 0xc4 | ZCL_STATUS_LIMIT_REACHED |
24.1.3. Trust Center Swap Out status codes
| 0x00 | ZB_TCSO_STATUS_SUCCESS |
| 0x01 | ZB_TCSO_STATUS_DISCOVERY_UNDERWAY |
| 0x02 | ZB_TCSO_STATUS_REJOIN_PREV |
| 0x03 | ZB_TCSO_STATUS_NOT_FOUND |
| 0x04 | ZB_TCSO_STATUS_FATAL |
24.1.4. Key Establishment status codes
| 0x00 | ZCL_KEY_STATUS_SUCCESS |
| 0x01 | ZCL_KEY_STATUS_UNKNOWN_ISSUER |
| 0x02 | ZCL_KEY_STATUS_BAD_KEY_CONFIRM |
| 0x03 | ZCL_KEY_STATUS_BAD_MESSAGE |
| 0x04 | ZCL_KEY_STATUS_NO_RESOURCES |
| 0x05 | ZCL_KEY_STATUS_UNSUPPORTED_SUITE |
| 0x06 | ZCL_KEY_STATUS_INVALID_CERTIFICATE |
| 0x07 | ZCL_KEY_STATUS_TIMEOUT |
| 0x08 | ZCL_KEY_STATUS_MATCH_DESC_FAILED |
25. References
